    3. Off Topic
    4. InfluxDB
    5. InfluxDB 2 BackItUp Error
    • Fredi009sg
      Fredi009sg last edited by Fredi009sg
      Über den Befehl sudo systemctl status influxdb sehe ich, dass der Service läuft und ich kann über die Webseite die Einrichtung starten.
      Weiterhin kann ich aber über influx setup diese nicht starten.
      Grundsätzlich brauche ich einen Token für BackItUp.
      pi@raspberrypi:~ $ sudo systemctl status influxdb
      ```influxdb.service - InfluxDB is an open-source, distributed, time series database
           Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
           Active: active (running) since Thu 2023-07-13 15:10:47 CEST; 29min ago
             Docs: https://docs.influxdata.com/influxdb/
          Process: 13291 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=0/SUCCESS)
         Main PID: 13292 (influxd)
            Tasks: 9 (limit: 3932)
              CPU: 5.189s
           CGroup: /system.slice/influxdb.service
                   └─13292 /usr/bin/influxd
      Jul 13 15:25:20 raspberrypi influxd-systemd-start.sh[13292]: ts=2023-07-13T13:25:20.630612Z lvl=info msg=Unauthorized log_id=0i~qr3v0000 error="authorization not found"
      Jul 13 15:25:30 raspberrypi influxd-systemd-start.sh[13292]: ts=2023-07-13T13:25:30.639551Z lvl=info msg=Unauthorized log_id=0i~qr3v0000 error="authorization not found"
      Jul 13 15:25:40 raspberrypi influxd-systemd-start.sh[13292]: ts=2023-07-13T13:25:40.649854Z lvl=info msg=Unauthorized log_id=0i~qr3v0000 error="authorization not found"
      Jul 13 15:25:50 raspberrypi influxd-systemd-start.sh[13292]: ts=2023-07-13T13:25:50.658906Z lvl=info msg=Unauthorized log_id=0i~qr3v0000 error="authorization not found"
      Jul 13 15:26:00 raspberrypi influxd-systemd-start.sh[13292]: ts=2023-07-13T13:26:00.667691Z lvl=info msg=Unauthorized log_id=0i~qr3v0000 error="authorization not found"
      Jul 13 15:26:10 raspberrypi influxd-systemd-start.sh[13292]: ts=2023-07-13T13:26:10.676095Z lvl=info msg=Unauthorized log_id=0i~qr3v0000 error="authorization not found"
      Jul 13 15:26:20 raspberrypi influxd-systemd-start.sh[13292]: ts=2023-07-13T13:26:20.699380Z lvl=info msg=Unauthorized log_id=0i~qr3v0000 error="authorization not found"
      Jul 13 15:26:30 raspberrypi influxd-systemd-start.sh[13292]: ts=2023-07-13T13:26:30.708714Z lvl=info msg=Unauthorized log_id=0i~qr3v0000 error="authorization not found"
      Jul 13 15:40:47 raspberrypi influxd-systemd-start.sh[13292]: ts=2023-07-13T13:40:47.226212Z lvl=info msg="Retention policy deletion check (start)" log_id=0i~qr3v0000 service=retentio>
      Jul 13 15:40:47 raspberrypi influxd-systemd-start.sh[13292]: ts=2023-07-13T13:40:47.227493Z lvl=info msg="Retention policy deletion check (end)" log_id=0i~qr3v0000 service=retention >
        Homoran Global Moderator Administrators @DJMarc75 last edited by
        @djmarc75 sagte in InfluxDB 2 BackItUp Error:
        CODETAGS einsetzen bitte.
        die sind doch im Output drin, wenn man sie nicht rausoperiert
          TT-Tom @Fredi009sg last edited by TT-Tom
          @fredi009sg
          Warum richtest du sie nicht über Website ein? Da bekommst du auch den Token für Backitup bzw. den Influx Adapter.
          Welche Version von Influx hast du installiert??
          Hast du die influx-cli installiert???
            A Former User @Fredi009sg last edited by A Former User
            @fredi009sg sagte in InfluxDB 2 BackItUp Error:
            pi@raspberrypi:~ $ influx setup
            -bash: /usr/local/bin/influx: Kann die Binärdatei nicht ausführen: Fehler im Format der Programmdatei
            Moin,
            Du hast schlicht und ergreifend die falsche Binär Datei installiert, eine die nicht für Dein Raspi ist.
            sudo file /usr/local/bin/influx*
            Da kommt dann eine Ausgabe, die Dir sagt, für welche CPU Architektur diese Datei ist.
            Da Du zwei Pakete brauchst, einmal den Datenbankmanager influxd und einmal den Client, zum Backup machen influx, hast Du die richtige Architektur des Datenbankmanagers genommen und die falsche für den Client.
            Beispiel
            $ file /usr/bin/influx*
            /usr/bin/influx:  ELF 64-bit LSB pie executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, BuildID[sha1]=2bc954d6fdfb7d16de125fd391a386f4918b3bbe, for GNU/Linux 4.4.0, stripped
            /usr/bin/influxd: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, BuildID[sha1]=8f3719307508ee5ed2625282f0922e3facd89b60, for GNU/Linux 4.4.0, stripped
            Aber ist eh Jacke, wie Hose, Du solltest das richtig über die Repositories installieren.
            Wie man das macht, steht auf der Seite https://docs.influxdata.com/influxdb/v2.2/install/?t=Linux
            VG
            Bernd
            Fredi009sg 1 Reply Last reply Reply Quote 0
            • Fredi009sg
              Fredi009sg @Guest last edited by
              @dp20eic
              pi@raspberrypi:~ $ sudo file /usr/local/bin/influx*
              /usr/local/bin/influx: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), statically linked, Go BuildID=UoS6lY0ZS2TNiFP4F4pw/FR2nKxI-_h3dLdH57lkL/Bry0DcDVLmxJGEisd1QF/qlYlrt6ezD9nJOXQdXED, stripped
              Thomas Braun ? 2 Replies Last reply Reply Quote 0
                Thomas Braun Most Active @Fredi009sg last edited by Thomas Braun
                x86-64
                Passt halt nicht zu deinem ARM-Rechner.
                Das ganze Ding ist total schräg, aus meiner Sicht.
                  Moin,
                  wie gesagt, das ist für eine Intel/AMD CPU und nicht für
                  ** BASE SYSTEM ***
                  Model : Raspberry Pi 4 Model B Rev 1.2
                  Architecture : aarch64
                  Erkennst Du den Unterschied?
                  VG
                  Bernd
                    A Former User @Thomas Braun last edited by
                    @thomas-braun sagte in InfluxDB 2 BackItUp Error:
                    x86-64
                    Moin,
                    Jup, sehe ich auch so, und wieder nach YT, da schaut man nicht wie alt der Quatsch ist, sonder macht einfach drauf los.
                    @Fredi009sg
                    Hast Du schon viel mit influxDB gemacht? Also schon viele Daten erfasst?
                    Du musst uns genau sagen welche Befehle Du genutzt hast um das zu Installieren, dann kann man Dir helfen das zurückzubauen.
                    Ansonsten, Backup und von ganz vorne, dann aber sauber aufsetzen und Backup zurückspielen. <- Habe gelernt, dass das meist die bessere Variante ist 🙂
                    VG
                    Bernd
                    • Fredi009sg
                      @dp20eic said in InfluxDB 2 BackItUp Error:
                      x86-64
                      Moin,
                      @Fredi009sg
                      VG
                      Bernd
                      Ich habe anfänglich die Quelle von InfluxDB benutzt. Meine Vermutung ist gerade das ich versehentlich die falsche Version gewählt habe.
                      Was ich mich jetzt allerdings Frage ist, wenn ich es über sudo apt install installiert er immer diese Version. Kann es seine, dass ich hier zufällig die falsche Quelle hinterlegt habe.
                        Thomas Braun Most Active last edited by
                        Welche Version und welche Quelle?
                        sudo apt update
                        apt policy influxdb*
                        • Fredi009sg
                          Fredi009sg @Thomas Braun last edited by Fredi009sg
                          wenn ich jetzt sudo apt install influxdb2 eingebe wird folgendes installiert:
                          pi@raspberrypi:~ $ sudo apt install influxdb2
                          Paketlisten werden gelesen… Fertig
                          Abhängigkeitsbaum wird aufgebaut… Fertig
                          Statusinformationen werden eingelesen… Fertig
                          Die folgenden zusätzlichen Pakete werden installiert:
                            influxdb2-cli
                          Die folgenden NEUEN Pakete werden installiert:
                            influxdb2 influxdb2-cli
                          0 aktualisiert, 2 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                          Es müssen noch 0 B von 54,5 MB an Archiven heruntergeladen werden.
                          Nach dieser Operation werden 123 MB Plattenplatz zusätzlich benutzt.
                          Möchten Sie fortfahren? [J/n] y
                          Vormals nicht ausgewähltes Paket influxdb2 wird gewählt.
                          (Lese Datenbank ... 131343 Dateien und Verzeichnisse sind derzeit installiert.)
                          Vorbereitung zum Entpacken von .../influxdb2_2.7.1-1_arm64.deb ...
                          Entpacken von influxdb2 (2.7.1-1) ...
                          Vormals nicht ausgewähltes Paket influxdb2-cli wird gewählt.
                          Vorbereitung zum Entpacken von .../influxdb2-cli_2.7.3-1_arm64.deb ...
                          Entpacken von influxdb2-cli (2.7.3-1) ...
                          influxdb2 (2.7.1-1) wird eingerichtet ...
                          Config file /etc/influxdb/config.toml already exists, writing defaults to /etc/influxdb/config.toml.defaults
                          influxdb2-cli (2.7.3-1) wird eingerichtet ...
                          Bei apt policy influxdb*
                          pi@raspberrypi:~ $ apt policy influxdb*
                          N: Paket influxdb2-2.7.0.aarch64.rpm kann nicht gefunden werden.
                          N: Mittels des Musters »influxdb2-2.7.0.aarch64.rpm« konnte kein Paket gefunden werden.
                            @fredi009sg
                            Lösch das rpm-Paket, das da so unnütz in der Gegend herumliegt.
                            rm influxdb2-2.7.0.aarch64.rpm
                            sudo apt update
                            • Fredi009sg
                              jetzt bekomme ich folgendes
                              pi@raspberrypi:~ $ sudo apt update
                              OK:1 http://deb.debian.org/debian bullseye InRelease
                              OK:2 http://deb.debian.org/debian bullseye-updates InRelease
                              OK:3 http://deb.debian.org/debian bullseye-backports InRelease
                              OK:4 http://security.debian.org/debian-security bullseye-security InRelease
                              OK:5 http://archive.raspberrypi.org/debian bullseye InRelease
                              OK:6 https://phoscon.de/apt/deconz bullseye InRelease
                              OK:7 https://download.docker.com/linux/debian bullseye InRelease
                              OK:8 https://deb.nodesource.com/node_16.x bullseye InRelease
                              OK:9 https://repos.influxdata.com/debian stable InRelease
                              OK:10 https://apt.grafana.com stable InRelease
                              Alle Pakete sind aktuell.
                              influxdb2-cli:
                                Installiert:           (keine)
                                Installationskandidat: 2.7.3-1
                                Versionstabelle:
                                   2.7.3-1 500
                                      500 https://repos.influxdata.com/debian stable/main arm64 Packages
                                   2.7.1-2 500
                                   2.6.1 500
                                   2.6.0 500
                                   2.5.0 500
                                   2.4.0 500
                                   2.3.0 500
                              influxdb-client:
                                Installationskandidat: 1.6.7~rc0-1+b5
                                Versionstabelle:
                                   1.6.7~rc0-1+b5 500
                                      500 http://deb.debian.org/debian bullseye/main arm64 Packages
                              influxdb-dev:
                                Installationskandidat: (keine)
                                Versionstabelle:
                              influxdb2-client:
                                Installationskandidat: 2.7.1-1
                                Versionstabelle:
                                   2.7.1-1 500
                              influxdb:
                                Installationskandidat: 1.8.10-1
                                Versionstabelle:
                                   1.8.10-1 500
                                   1.6.7~rc0-1+b5 500
                              influxdb2:
                                Versionstabelle:
                                   2.7.1-1 500
                                      100 /var/lib/dpkg/status
                                   2.7.0-1 500
                                   2.6.1-1 500
                                   2.6.0-1 500
                                   2.5.1-1 500
                                   2.4.0-1 500
                                   2.3.0-1 500
                                   2.2.0 500
                                @fredi009sg
                                Das ist nicht richtig über den Paketmanager installiert sondern 'irgendwie ins System geprügelt' worden.
                                • Fredi009sg
                                  Eine Idee wie ich es rückgängig machen kann ?
                                    @fredi009sg
                                    Den ganzen Summs so wie der reingeballert worden ist auch wieder rauskratzen.
                                    Da haste aber auch irgendwie alles mal versucht reinzuschrauben...
                                    rpm-Pakete, x386-Pakete...
                                      @fredi009sg
                                      sudo apt install --reinstall influxdb2
                                      • Fredi009sg
                                        pi@raspberrypi:/ $ apt policy influxdb*
                                        influxdb2-cli:
                                          Versionstabelle:
                                             2.7.3-1 500
                                             2.7.1-2 500
                                             2.6.1 500
                                             2.6.0 500
                                             2.5.0 500
                                             2.4.0 500
                                             2.3.0 500
                                        influxdb-client:
                                          Versionstabelle:
                                             1.6.7~rc0-1+b5 500
                                        influxdb-dev:
                                          Versionstabelle:
                                        influxdb2-client:
                                          Versionstabelle:
                                             2.7.1-1 500
                                        influxdb:
                                          Versionstabelle:
                                             1.8.10-1 500
                                             1.6.7~rc0-1+b5 500
                                        influxdb2:
                                          Versionstabelle:
                                             2.7.1-1 500
                                             2.7.0-1 500
                                             2.6.1-1 500
                                             2.6.0-1 500
                                             2.5.1-1 500
                                             2.4.0-1 500
                                             2.3.0-1 500
                                             2.2.0 500
                                        pi@raspberrypi:/ $ sudo apt install influxdb2
                                          influxdb2-cli
                                        pi@raspberrypi:/ $ sudo service influxdb start
                                        pi@raspberrypi:/ $ sudo service influxdb status
                                        ● influxdb.service - InfluxDB is an open-source, distributed, time series database
                                             Active: active (running) since Thu 2023-07-13 23:00:52 CEST; 5s ago
                                            Process: 19554 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=0/SUCCES>
                                           Main PID: 19555 (influxd)
                                                CPU: 2.379s
                                                     └─19555 /usr/bin/influxd
                                        Jul 13 23:00:52 raspberrypi influxd-systemd-start.sh[19555]: ts=2023-07-13T21:00:52.384409Z lvl=info msg="Sta>
                                        Jul 13 23:00:52 raspberrypi influxd-systemd-start.sh[19555]: ts=2023-07-13T21:00:52.385799Z lvl=info msg="Sta>
                                        Jul 13 23:00:52 raspberrypi influxd-systemd-start.sh[19555]: ts=2023-07-13T21:00:52.392937Z lvl=info msg="Sta>
                                        Jul 13 23:00:52 raspberrypi influxd-systemd-start.sh[19555]: ts=2023-07-13T21:00:52.421800Z lvl=info msg="Con>
                                        Jul 13 23:00:52 raspberrypi influxd-systemd-start.sh[19555]: ts=2023-07-13T21:00:52.454517Z lvl=info msg=Star>
                                        Jul 13 23:00:52 raspberrypi influxd-systemd-start.sh[19555]: ts=2023-07-13T21:00:52.456480Z lvl=info msg=List>
                                        Jul 13 23:00:52 raspberrypi influxd-systemd-start.sh[19572]: Command "print-config" is deprecated, use the in>
                                        Jul 13 23:00:52 raspberrypi influxd-systemd-start.sh[19583]: Command "print-config" is deprecated, use the in>
                                        Jul 13 23:00:52 raspberrypi influxd-systemd-start.sh[19554]: InfluxDB started
                                        Jul 13 23:00:52 raspberrypi systemd[1]: Started InfluxDB is an open-source, distributed, time series database.
                                        pi@raspberrypi:/ $ influx setup
                                          Da schwirrt noch was von dem Quatsch herum.
                                          ls -lAh /usr/local/bin/
                                          • Fredi009sg
                                            pi@raspberrypi:/ $ ls -lAh /usr/local/bin/
                                            insgesamt 17M
                                            -rwxr-xr-x 1 root root  215 21. Apr 14:00 docker-compose
                                            -rwxr-xr-x 1 root root  212 21. Apr 14:00 dotenv
                                            -rwxr-xr-x 1 root root  16M 10. Jul 16:33 influx
                                            -rwxr-xr-x 1 root root  213 21. Apr 14:00 jsonschema
                                            -rwxr-xr-x 1 root root  244 21. Apr 14:00 normalizer
                                            drwxr-xr-x 2 root root 4,0K 21. Apr 14:00 __pycache__
                                            lrwxrwxrwx 1 root root   29 17. Feb 16:05 raspiBackup -> /usr/local/bin/raspiBackup.sh
                                            -rwxr-xr-x 1 root root 331K 14. Mär 2022  raspiBackup.0.6.6.1.sh
                                            lrwxrwxrwx 1 root root   38 17. Feb 16:05 raspiBackupInstallUI -> /usr/local/bin/raspiBackupInstallUI.sh
                                            -rwxr-xr-x 1 root root 165K 17. Feb 16:05 raspiBackupInstallUI.sh
                                            -rwxr-xr-x 1 root root 358K 17. Feb 16:05 raspiBackup.sh
                                            -rwxr-xr-x 1 root root 358K 17. Feb 15:47 raspiBackup.sh.0.6.8.sh
                                            -rwxr-xr-x 1 root root 7,1K 21. Apr 14:00 wsdump.py
                                            1853
