    4. Test Adapter MercedesMe v0.0.x
      reddddich @hssk last edited by
      @hssk Danke das ist soweit klar.
      Nur bekomme ich keinen Code gesendet. Siehe mein Log.
      Muss ich denn nirgends mein Passwort eingeben im Adapter?
        reddddich @tombox last edited by
        @tombox
        Kann es evtl. an node 18.x liegen?
        Ich habe bisher keinen Adapter der nicht läuft auf zwei RPi´s...
        2023-06-16 09:30:29.233 - info: host.raspberrypi2 "system.adapter.mercedesme.0" enabled
        2023-06-16 09:30:29.360 - info: host.raspberrypi2 instance system.adapter.mercedesme.0 started with pid 13244
        2023-06-16 09:30:31.331 - debug: mercedesme.0 (13244) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2023-06-16 09:30:31.402 - debug: mercedesme.0 (13244) Objects client ready ... initialize now
        2023-06-16 09:30:31.406 - debug: mercedesme.0 (13244) Objects create System PubSub Client
        2023-06-16 09:30:31.408 - debug: mercedesme.0 (13244) Objects create User PubSub Client
        2023-06-16 09:30:31.459 - debug: mercedesme.0 (13244) Objects client initialize lua scripts
        2023-06-16 09:30:31.468 - debug: mercedesme.0 (13244) Objects connected to redis: 127.0.0.1:9001
        2023-06-16 09:30:31.495 - debug: mercedesme.0 (13244) Redis States: Use Redis connection: 127.0.0.1:9000
        2023-06-16 09:30:31.508 - debug: mercedesme.0 (13244) States create System PubSub Client
        2023-06-16 09:30:31.509 - debug: mercedesme.0 (13244) States create User PubSub Client
        2023-06-16 09:30:31.568 - debug: mercedesme.0 (13244) States connected to redis: 127.0.0.1:9000
        2023-06-16 09:30:31.673 - debug: mercedesme.0 (13244) Plugin sentry Initialize Plugin (enabled=true)
        2023-06-16 09:30:32.051 - info: mercedesme.0 (13244) starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.mercedesme, node: v18.16.0, js-controller: 4.0.24
        2023-06-16 09:30:32.212 - debug: mercedesme.0 (13244) Login
        2023-06-16 09:30:32.561 - error: mercedesme.0 (13244) Not able to request login code
        2023-06-16 09:30:32.563 - error: mercedesme.0 (13244) AxiosError: Request failed with status code 428
        2023-06-16 09:30:32.563 - error: mercedesme.0 (13244) ""
        2023-06-16 09:30:32.564 - error: mercedesme.0 (13244) Login was not successful.
          tombox @reddddich last edited by
          @reddddich brauch ich den account zum testen
            @tombox pm haste 🙂 Danke
              k_b last edited by
              ich habe das Problem, dass ich keine Werte bei meinem EQA in den Objektbäumen "state" und "history" bekomme. Andere Bäume wie "user" sind komplett befüllt.
              Könnte mir jemand einen Tipp geben, wie ich zumindest zum SoC komme?
              Danke im voraus.
                ThePhantom79 last edited by ThePhantom79
                ich habe iobroker als dicker erst mal nur für den mercedesme adapter installiert. (ich nutze knx / loxone / loxberry - und will die werte über MQTT an die anderen Systeme weiter leiten).
                Leider scheitere ich schon an der Einrichtung des Adapters:
                Installiert Version 0.1.1
                Mail-Adresse eingegeben und gespeichert
                PIN bekommen (!!! - nicht wie im Log steht, dass es nicht möglich war) und eingetragen , gespeichert.
                Danach startet der Adapter zwei mal neu, danach "Verbunden mit Host: grün, Lebenszeichen: Grün, Verbunden mit Gerät/Dienst: Rot"
                Im Log:
                mercedesme.0
                2023-06-28 14:36:28.860	error	Login was not successful.
                mercedesme.0
                2023-06-28 14:36:28.860	error	""
                mercedesme.0
                2023-06-28 14:36:28.860	error	AxiosError: Request failed with status code 429
                mercedesme.0
                2023-06-28 14:36:28.859	error	Not able to request login code
                mercedesme.0
                2023-06-28 14:36:28.535	info	starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.mercedesme, node: v18.16.1, js-controller: 4.0.24
                Hat jemand eine Idee?
                Edit: ES waren zu viele Anmeldeversuche, da ich anfangs was falsch gemacht hatte - nun gehts ...
                Ist nun vom Adpater her alles grün, aber ich bekomme keine Werte ausgelesen - habe ich etwas vergessen?
                Edit 2:
                Nur unter history sehe ich keine Daten ... In den anderen "Unterordnern" sind Wrete vorhanden, insbesondere habe ich die für mich interessanten Werte "Restreichweite Elektro" und "Restreichweite Diesel" gefunden.
                  turtle1987 @k_b last edited by
                  @k_b said in Test Adapter MercedesMe v0.0.x:
                  Hast du da eine Lösung? Bei mir ist History zwar gefüllt aber state auch komplett leer.
                  • Webranger
                    Webranger last edited by
                    Darf ich mal fragen wofür die Tankerkönik Api verwendet wird? Auf welche Daten greift die zurück um was auszurechnen oder anzuzeigen?
                    • amg_666
                      amg_666 @Webranger last edited by
                      @webranger Schau auf Tankerkoenig.de nach, da ist das beschrieben.
                      • Webranger
                        Was hat tankerkönig mit dem Adapter zu tun?
                        Verstehe ich nicht was du damit sagen willst
                          tombox @Webranger last edited by
                          @webranger Er zeichnet deine Tankvorgänge auf mit Liter und Preis
                          Friedhofsblond 1 Reply Last reply Reply Quote 0
                          • Friedhofsblond
                            Friedhofsblond @tombox last edited by Friedhofsblond
                            @tombox
                            Moin,
                            mir fehlt leider der komplette Kilometerstand (oder nicht gefunden?)
                            Oder mach ich was falsch??
                            Habe nur den Stand nach Reset ca. 29Tkm (beim Kauf schon 3TKm auf der Uhr)
                            Aber der andere Gesamtkilometer fehlt (ca. 32Tkm):
                              hssk @Friedhofsblond last edited by
                              @friedhofsblond Also bei mir ist der Gesamt-km-Stand im Ordner odo zu finden. Gruß
                              • Friedhofsblond
                                Friedhofsblond @hssk last edited by
                                @hssk
                                Moin, ja stimmt sorry - und Danke 😄
                                  bishop9191 last edited by
                                  Kann ich bei meinem EQB den Zündungsstatus abfragen?
                                  Bei "ignitionstate" tut sich nichts... Oder schaue ich falsch?
                                    Amokd0c last edited by
                                    Servus!
                                    kann es sein, dass der Dienst down ist?
                                    Der Adapter ist verbunden, aber ich kann von der Couch mein Auto nicht zuschließen. Muss ich jetzt aufstehen, das kann es doch nicht sein! 😸
                                      sruhsam last edited by
                                      habe eine GLC300e, Adapter funktioniert grundsätzlich (öffnen, schließen etc) Wie kann ich denn aber das Ladeprogramm ändern ?
                                      z.b. würde ich gerne vom "Standard" Ladeprogramm in das "Zuhause" wechseln bzw. aktivieren und dort den Max. Ladezustand auf 80% ändern.
                                      sehe unter "state.chargePrograms.chargeProgramsValue" nur die eingestellten Werte, kann diese aber nicht ändern/schreiben.
                                      Gruß Stephan
                                        @sruhsam Du kannst nur ändern was unter commands steht und was in der App geht
                                          sruhsam @tombox last edited by
                                          @tombox
                                          Danke für die Antwort.
                                          In der mercedes me App ist dies natürlich möglich, deshalb versuche ich es ja über den Adapter zu steuern.
                                          im Verzeichnis command stehen ja ganz viele Verzeichnisse, deshalb meine Frage, ob das jemand weis, welcher State hier wie verändert werden muss.
                                          wenn ich diesen auf true setze, wird immer das Standard (default)-Charge-Programm ausgewählt, ich möchte nun aber in das Zuhause (Home) Charge-Program wechseln.
                                          mercedesme.0.W1NKM5GB7PU034353.commands.CHARGE_PROGRAM_CONFIGURE.start
                                          Es geht eigentlich um diesen State:
                                          mercedesme.0.<FIN>.state.chargePrograms.chargeProgramsValue
                                          weis aber wie beschrieben nicht welcher das im Verzeichnis Command ist.
                                          Ich bin mal alle beschreibbaren States durchgegangen, hatte aber leider nichts gefunden und nur probieren möchte ich eigentlich nicht.
                                          Ich dachte hier im Forum Hilfe zu finden.
                                          Vielleicht gibt es auch eine andere Möglichkeit diese State in einem script anzusprechen bzw. zu verändern. bin für jede Hilfe offen.
                                          Stephan
                                            A Former User @sruhsam last edited by A Former User
                                            bitte löschen
                                            mercedes
                                            120
                                            929
                                            230941
