    4. Node-Red
    5. shelly Status zur Fallunterscheidung nutzen
      Rudi 3 @mickym last edited by
      Hier nochmal in Code-tags:
      {"status":{"wifi_sta":{"connected":true,"ssid":"Kellerfritz","ip":"192.168.2.196","rssi":-46},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"15:16","serial":1,"has_update":true,"mac":"10521C06EE47","relays":[{"ison":false,"has_timer":false,"overpower":false,"overtemperature":false,"is_valid":true},{"ison":false,"has_timer":false,"overpower":false,"overtemperature":false,"is_valid":true}],"rollers":[{"state":"stop","power":0,"is_valid":true,"safety_switch":false,"overtemperature":false,"stop_reason":"normal","last_direction":"stop","current_pos":101,"calibrating":false,"positioning":true}],"meters":[{"power":0,"is_valid":true,"timestamp":1689347786,"counters":[0,0,0],"total":0},{"power":0,"is_valid":true,"timestamp":1689347786,"counters":[0,0,0],"total":0}],"inputs":[{"input":0},{"input":0}],"temperature":56.18,"overtemperature":false,"tmp":{"tC":56.18,"tF":133.12,"is_valid":"true"},"update":{"status":"pending","has_update":true,"new_version":"20230503-095750/v1.13.0-g9aed950","old_version":"20191217-074901/1047-long-id-for-shelly-devices@ab2bdce7"},"ram_total":49480,"ram_free":37016,"fs_size":233681,"fs_free":157628,"voltage":235.06,"uptime":6684},"payload":{"relays":[{"ison":false,"has_timer":false,"overpower":false,"overtemperature":false,"is_valid":true},{"ison":false,"has_timer":false,"overpower":false,"overtemperature":false,"is_valid":true}],"rollers":[{"state":"stop","power":0,"is_valid":true,"safety_switch":false,"overtemperature":false,"stop_reason":"normal","last_direction":"stop","current_pos":101,"calibrating":false,"positioning":true}],"meters":[{"power":0,"is_valid":true,"timestamp":1689347786,"counters":[0,0,0],"total":0},{"power":0,"is_valid":true,"timestamp":1689347786,"counters":[0,0,0],"total":0}],"inputs":[{"input":0},{"input":0}],"tmp":{"tC":56.18,"tF":133.12,"is_valid":"true"}},"_msgid":"9bd7710f1fddad89"}
      • mickym
        mickym Most Active @Rudi 3 last edited by mickym
        @rudi-3 Ok danke in Deiner function Node stand irgendwas von emeters - nun sind es aber nur meters - das deckt sich also NICHT.
        Musst Du dann halt ändern - aber das Prinzip für den oberen Flow solltest Du ja verstanden haben.
          Hallo Micky, ich habe es gerade mal nachvollzogen und statt dem inject node das shelly 3EM angehängt. -funktioniert. Soweit ich es verstanden habe, setzt Du die payload mit: payload.emeters.power und das bringt dann alle drei Phasen in ein array? Dein Aufbau ist in der Tat wesentlich kompakter...
          • mickym
            @rudi-3 sagte in shelly Status zur Fallunterscheidung nutzen:
            Ja - das ist der Riesenvorteil von JSONATA - da es einzelne Ergebnisse einzeln darstellt - mehrfache automatisch in ein Array verfrachtet.
            Das ganze geht dann noch kompakter wenn Du das als EINE Regel definierst in EINER Change Node machst:
            Damit ist alles direkt abgefrühstückt und kannst in deinem Gauge ausgeben.
            In Summe schaut dass dann so aus:
            und das ohne irgendwelche Zusatznodes und Spirenzchen. 😉
            Hier nochmal zum Import:
                    "id": "17cb0b933b223630",
                    "type": "ui_text",
                    "z": "a3ff42d9e3f31af7",
                    "g": "1c8edee959741467",
                    "group": "504d6fd769a4772b",
                    "order": 3,
                    "width": 0,
                    "height": 0,
                    "name": "",
                    "label": "Phase3",
                    "format": "{{msg.payload.emeters[2].power}}",
                    "layout": "row-spread",
                    "className": "",
                    "style": false,
                    "font": "",
                    "fontSize": "",
                    "color": "#000000",
                    "x": 440,
                    "y": 460,
                    "wires": []
                    "id": "504d6fd769a4772b",
                    "type": "ui_group",
                    "name": "Phasen",
                    "tab": "942cb02b.fe603",
                    "order": 1,
                    "disp": true,
                    "width": "6",
                    "collapse": false,
                    "className": ""
                    "id": "942cb02b.fe603",
                    "type": "ui_tab",
                    "name": "Energiemanagement",
                    "icon": "home",
                    "order": 1,
                    "disabled": false,
                    "hidden": false
            • mickym
              Als erstes nehme ich mal diese 3. Ausgabe aus - das soll wohl eine Anzeige sein, die ist aber nicht definiert und gesetzt:
              Ich geh mal davon aus, dass es LED2 heißen soll. Und hab die Ausgabe mal so geändert:
              return [msg.payload2,LED1,LED2];
              Ansonsten kann ich Deinen Fehler nachvollziehen:
              So UND nun komme ich zu dem Punkt - warum DU function Nodes VERMEIDEN sollst, wo es geht. Du kannst keine Debug NOdes ansetzen und musst nun im Code suchen. Schöner wäre es doch in einem Flow zu suchen. Wir sollten - ABER NUR WENN DU Lust hast - im letzten Schritt Deine function Node durch einen schönen Flow ersetzen, was meinst Du?
              Aber als erstes suchen wir wo der Fehler auftritt.
                Stimmt, die Variable "statusrel0" war ein Debug-Versuch von mir, die hatte ich anstelle einer LED genutzt. Mir wäre es auch sehr lieb, wenn ich die Fallunterscheidungen ohne Programmcode machen könnte, schliesslich war es genau das was ich an Node-Red so gut finde. Die function node war dann eher ein Behelf, da ich keine Idee hat die Unterscheidung mit nodes zu machen. Man fällt irgendwie in die Programmierübungen aus der Schulzeit zurück 😉
                • mickym
                  Na wenn das so ist, dann stecke ich in die function Node keine Energie mehr rein - wollen wir den unteren Teil dann gleich neu machen?
                    Eine Verständnisfrage zwischendurch. Ich habe testweise nach Deinem Vorbild eine change-node genommen um aus der Payload vom shelly-relays einen Teil zu extrahieren. Dabei kam aber wieder das ganze Nachrichtenobjekt raus. Warum ist das so?
                      Wenn's in der function node für mich was zu lernen gibt, wäre es zumindest interessant. Aber wenn ich nur mit nodes arbeiten kann, bin ich auch schon happy
                      • mickym
                        Vielleicht ein Syntax- Leerzeichen oder irgendwas - was ich so auch nicht sehe. Oder nicht ÜBERNEHMEN geklickt. 😉 Keine Ahnung. Bei mir funktioniert es:
                        Hier der Import:
                               "id": "b540dd62c4b7bb4b",
                               "type": "inject",
                               "name": "Shelly Input",
                               "props": [
                                       "p": "payload"
                               "repeat": "",
                               "crontab": "",
                               "once": false,
                               "onceDelay": 0.1,
                               "topic": "",
                               "payload": "{\"status\":{\"wifi_sta\":{\"connected\":true,\"ssid\":\"Kellerfritz\",\"ip\":\"192.168.2.196\",\"rssi\":-46},\"cloud\":{\"enabled\":false,\"connected\":false},\"mqtt\":{\"connected\":false},\"time\":\"15:16\",\"serial\":1,\"has_update\":true,\"mac\":\"10521C06EE47\",\"relays\":[{\"ison\":false,\"has_timer\":false,\"overpower\":false,\"overtemperature\":false,\"is_valid\":true},{\"ison\":false,\"has_timer\":false,\"overpower\":false,\"overtemperature\":false,\"is_valid\":true}],\"rollers\":[{\"state\":\"stop\",\"power\":0,\"is_valid\":true,\"safety_switch\":false,\"overtemperature\":false,\"stop_reason\":\"normal\",\"last_direction\":\"stop\",\"current_pos\":101,\"calibrating\":false,\"positioning\":true}],\"meters\":[{\"power\":0,\"is_valid\":true,\"timestamp\":1689347786,\"counters\":[0,0,0],\"total\":0},{\"power\":0,\"is_valid\":true,\"timestamp\":1689347786,\"counters\":[0,0,0],\"total\":0}],\"inputs\":[{\"input\":0},{\"input\":0}],\"temperature\":56.18,\"overtemperature\":false,\"tmp\":{\"tC\":56.18,\"tF\":133.12,\"is_valid\":\"true\"},\"update\":{\"status\":\"pending\",\"has_update\":true,\"new_version\":\"20230503-095750/v1.13.0-g9aed950\",\"old_version\":\"20191217-074901/1047-long-id-for-shelly-devices@ab2bdce7\"},\"ram_total\":49480,\"ram_free\":37016,\"fs_size\":233681,\"fs_free\":157628,\"voltage\":235.06,\"uptime\":6684},\"payload\":{\"relays\":[{\"ison\":false,\"has_timer\":false,\"overpower\":false,\"overtemperature\":false,\"is_valid\":true},{\"ison\":false,\"has_timer\":false,\"overpower\":false,\"overtemperature\":false,\"is_valid\":true}],\"rollers\":[{\"state\":\"stop\",\"power\":0,\"is_valid\":true,\"safety_switch\":false,\"overtemperature\":false,\"stop_reason\":\"normal\",\"last_direction\":\"stop\",\"current_pos\":101,\"calibrating\":false,\"positioning\":true}],\"meters\":[{\"power\":0,\"is_valid\":true,\"timestamp\":1689347786,\"counters\":[0,0,0],\"total\":0},{\"power\":0,\"is_valid\":true,\"timestamp\":1689347786,\"counters\":[0,0,0],\"total\":0}],\"inputs\":[{\"input\":0},{\"input\":0}],\"tmp\":{\"tC\":56.18,\"tF\":133.12,\"is_valid\":\"true\"}},\"_msgid\":\"9bd7710f1fddad89\"}",
                               "payloadType": "json",
                               "x": 210,
                               "y": 1040,
                               "wires": [
                                       "326d78cdf99b0b69",
                                       "d5a4defd13b3e3cf"
                               "id": "84167164063b10b2",
                               "type": "debug",
                               "name": "ison?",
                               "active": true,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "complete": "payload",
                               "targetType": "msg",
                               "statusVal": "",
                               "statusType": "auto",
                               "x": 590,
                               "y": 1040,
                               "wires": []
                               "id": "326d78cdf99b0b69",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "to": "payload.payload.relays[0].ison",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 410,
                               "y": 1040,
                               "wires": [
                                       "84167164063b10b2"
                               "id": "d5a4defd13b3e3cf",
                               "type": "debug",
                               "name": "Komplett",
                               "active": true,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "statusVal": "",
                               "x": 400,
                               "y": 980,
                               "wires": []
                          Bei mir jetzt auch. Um meine Erkenntnis für die Nachwelt zu beschreiben: Ich hatte es erst im Originalflow versucht, da ging es nicht. Dann habe ich den neuen Teil in einen neuen Flow kopiert und jetzt geht's.
                          • mickym
                            mickym Most Active last edited by mickym
                            So ich kann Deinen Fehler nachvollziehen - hatte dann aber nur die Blocks etwas auseinandergezogen und da war der Fehler komischerweise kurz weg.
                            Also um es kurz zu machen, was definitiv falsch ist, sind Deine Ausgaben. Keine dieser 3 variablen sind definiert.
                            Alles was innerhalb von geschweiften Klammern definiert wird, hat auch nur Gültigkeit innerhalb dieser geschweiften Klammern. Und msg.payload2 ist ein Objekt das gar nicht definiert ist. Wenn Du das alles zum Schluss ausgeben willst, dann musst Du auch alles am Anfang definieren.
                              Ich hätte also die Ausgaben direkt in die IF-Blöcke packen müssen / können? Heute habe ich eine steile Lernkurve 😉
                              • mickym
                                @rudi-3 Nein die Variablen LED1 und LED2 vor den IF Abfragen definieren.
                                Dann machst Du Vergleiche - obwohl Dein Kontext gar nicht initialisiert ist, wenn Du das Dashboard nicht vorher betätigt hast:
                                Prüfe also zu jeder Zeit - Deine Kontextdaten und initialisiere die Werte auch bevor Du irgendwas im Dashboard gesetzt hast.
                                • mickym
                                  Desweiteren wenn Du schon function NOde nimmst, dann musst Du darauf achten, dass Du alle Fälle berücksichtigst:
                                  Mit so vielen unterschiedlichen Parametern, ein, aus, und Summe sind da glaub 12 Fälle. Was machst Du denn wenn summe < ein ist - dann passiert gar nichts.
                                  Mit node.warn kannst Du überprüfen, ob was gesetzt ist.
                                  Du siehst es ist alles undefined - ja wenn kein Fall eintritt - ist es empty weil wir gesetzt haben oder undefined.
                                  Auch so was ist Käse:
                                  1. Definierst Du ein Objekt im luftleeren Raum - wenn das ausgegeben werden soll, dann musst Du ein msg Objekt definieren.
                                  Dein Objekt kommt nie und nimmer an.
                                  1. Du musst doch IMMER - wenn Du alles AUSGIBST auch alle Ausgaben definieren oder Du setzt diese auf null. Korrigiere ich noch. Aber Du musst auch den 2. Ausgang definieren - entweder für alles oder in jedem Ast.
                                    Node warn kannte ich noch nicht. Nützliches Ding. Bezüglich der Fälle kommen in der Praxis nicht so viele vor. Wichtig ist mir, das ich die Relais gestuft schalten kann. Etwas tricky ist, das sich der PV-Überschuss in dem Moment kleiner wird, in dem man den Heizstab zuschalten. Ich muss also später noch eine Hystere dazunehmen, sonst schwingt das ganze Werk wild.
                                    • mickym
                                      Gut - also eigentlich will ich nun nicht die ganze function Node umschreiben - es gäbe noch 1000 Dinge zu sagen - wollen wir ohne weiter machen?
                                        Da kommt doch einiges zusammen, das ich erstmal durcharbeiten muss.... Da wird das Wochenende wohl etwas knapp.
                                        • mickym
                                          Also ohne function Node?
                                            @mickym dann versuchen wir es lieber ohne function node. Das hebe ich mir für später auf.
                                            81.1k
                                            1652
