    4. Stromzähler Apator Norax 3D
      Thomas Braun Most Active @TT-Tom last edited by
      Wie testet man denn ob der Kopf funktioniert? Ich bekomme nämlich fast rein gar nichts in der Tasmota-Konsole angezeigt...
      00:00:00.001 HDW: ESP8266EX
      00:00:00.050 CFG: Loaded from flash at F5, Count 23
      00:00:00.055 SER: Set to 8N1 9600 bit/s
      00:00:00.056 QPC: Count 1
      00:00:00.074 Project tasmota - bitShake SmartMeterReader Version 12.4.0(tasmota)-2_7_4_9(2023-05-06T09:06:26)
      00:00:00.075 Script: nv=0, tv=0, vns=0, vmem=16, smem=2560
      00:00:00.076 Script: performs "sensor53 r"
      00:00:00.084 SNS: Hardware Serial
      00:00:00.084 sml memory error!
      00:00:00.086 RSL: RESULT = {"Time":"1970-01-01T00:00:00","SML":{"CMD":"restart"}}
      00:00:00.090 SNS: Hardware Serial
      00:00:00.090 sml memory error!
      00:00:00.530 WIF: Connecting to AP1 MEIN_WLAN Channel 1 BSSId 0C:72:74:E9:2A:23 in mode 11n as tasmota-143039-4153...
      00:00:01.754 WIF: Connected
      00:00:02.008 HTP: Web server active on tasmota-143039-4153 with IP address 192.168.178.65
      17:05:47.053 RSL: INFO1 = {"Info1":{"Module":"Generic","Version":"12.4.0(tasmota)","FallbackTopic":"cmnd/DVES_143039_fb/","GroupTopic":"cmnd/tasmotas/"}}
      17:05:47.055 RSL: INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"tasmota-143039-4153","IPAddress":"192.168.178.65"}}
      17:05:47.057 RSL: INFO3 = {"Info3":{"RestartReason":"Power On","BootCount":12}}
      17:05:50.469 QPC: Reset
      17:05:51.434 RSL: STATE = {"Time":"2023-07-14T17:05:51","Uptime":"0T00:00:08","UptimeSec":8,"Heap":22,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Wifi":{"AP":1,"SSId":"MEIN_WLAN","BSSId":"0C:72:74:E9:2A:23","Channel":1,"Mode":"11n","RSSI":54,"Signal":-73,"LinkCount":1,"Downtime":"0T00:00:03"}}
      17:10:51.416 RSL: STATE = {"Time":"2023-07-14T17:10:51","Uptime":"0T00:05:08","UptimeSec":308,"Heap":21,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Wifi":{"AP":1,"SSId":"MEIN_WLAN","BSSId":"0C:72:74:E9:2A:23","Channel":1,"Mode":"11n","RSSI":54,"Signal":-73,"LinkCount":1,"Downtime":"0T00:00:03"}}
      17:15:51.409 RSL: STATE = {"Time":"2023-07-14T17:15:51","Uptime":"0T00:10:08","UptimeSec":608,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Wifi":{"AP":1,"SSId":"MEIN_WLAN","BSSId":"0C:72:74:E9:2A:23","Channel":1,"Mode":"11n","RSSI":52,"Signal":-74,"LinkCount":1,"Downtime":"0T00:00:03"}}
      17:18:47.934 script compressed to 44 bytes = 100 %
      17:18:47.936 Script: nv=0, tv=0, vns=0, vmem=16, smem=2560
      17:18:47.937 Script: performs "sensor53 r"
      17:18:47.944 SNS: Hardware Serial
      17:18:47.945 sml memory error!
      17:18:47.947 RSL: RESULT = {"Time":"2023-07-14T17:18:47","SML":{"CMD":"restart"}}
      17:20:51.424 RSL: STATE = {"Time":"2023-07-14T17:20:51","Uptime":"0T00:15:08","UptimeSec":908,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Wifi":{"AP":1,"SSId":"MEIN_WLAN","BSSId":"0C:72:74:E9:2A:23","Channel":1,"Mode":"11n","RSSI":48,"Signal":-76,"LinkCount":1,"Downtime":"0T00:00:03"}}
        TT-Tom @Thomas Braun last edited by TT-Tom
        Gib mal in der Konsole ein
        sensor53 d1
        Da sollte ein hex Code kommen
        Edit: was mich wundert ist der SML Error.
        Was hast du eigentlich jetzt für ein Lesekopf?
          @tt-tom
          bitShake SmartMeterReader-UART steht drauf.
          T Homoran 2 Replies Last reply Reply Quote 0
            Wenn Tasmota läuft müsste der Befehl trotzdem was liefern.
            sensor53 d0
            Schaltet die Ausgabe wieder ab
              @thomas-braun sagte in Stromzähler Apator Norax 3D:
              der hat kein Tasmota
              wenn man der reitenden Kriegerin glauben darf
                TT-Tom @Homoran last edited by
                Den Kopf hat Thomas bestimmt an ein wemos gebastelt. Auf dem wird dann Tasmota laufen.
                  @tt-tom
                  Richtig, Tasmota 12.4.0 by Theo Arends läuft auf einem (ESP8266EX)
                    @thomas-braun und sicher auch korrekt verdrahtet!?
                    dann bliebe ja nur der Zähler als Übeltäter.
                      @homoran sagte in Stromzähler Apator Norax 3D:
                      Sehr sicher. Hab den an einen meiner Techniker-Kollegen zum löten gegeben. Der macht sowas nicht zum ersten mal... Der Schaltplan ist ja auch sehr simpel.
                        Ich hab da mit dem Handy reingefilmt, da was auch nur ein ganz schwaches IR-Glimmen alle paar Sekunden zu sehen. Sollte das Signal nicht eigentlich kräftig sein?
                          @tt-tom
                          18:22:24.566 CMD: sensor53 d1
                          18:22:24.571 RSL: RESULT = {"Command":"Error"}
                            ja!
                            aber dein Handy könnte auch einen IR Sperrfilter haben
                              Die reine Tasmota Software läuft so nicht. Du musst dir die zusammen setzen. Ist auf der Tasmota Seite beschrieben.
                                Thomas Braun Most Active @TT-Tom last edited by Thomas Braun
                                @tt-tom sagte in Stromzähler Apator Norax 3D:
                                Wat? Das ist Tasmota für SmartMeter. War schon auf dem esp-Ding vorinstalliert.
                                  Thomas Braun Most Active @Thomas Braun last edited by Thomas Braun
                                  Ich liebe es... NIE funktioniert bei mir solche Hardware sofort.
                                  Bei allen anderen: Hier so tun, da klicken, hier drehen, funktioniert.
                                  Bei mir IMMER so'n Scheiß...
                                  Ich glaube aber, die IR-Diode im Zähler ist zu dunkel. Eine IR-Fernbedienung liefert im Handy ein ganz anderes Bild und nicht nur so'n müdes Glimmen.
                                  T frankthegreat 2 Replies Last reply Reply Quote 0
                                    Das hatte ich bei meinem Zähler auch, der wurde anstandslos vom Netzbetreiber gewechselt.
                                    Hast du den wemos dazubekommen? Mich wundert das Tasmota den Sensor Befehl nicht kennt.
                                      @tt-tom
                                      War ein zusammengestelltes Paket. Das sollte eigentlich passen.
                                        hab gerade mal das gesamte Forum quergelesen.
                                        Das Symptom war hauptsächlich bei Holley und Logarex.
                                        edit:
                                        hab was gefunden
                                        https://forum.iobroker.net/post/995340
                                        @tt-tom war auch beteiligt
                                        Thomas Braun T 2 Replies Last reply Reply Quote 0
                                          Zu meinem Apator Norax 3D (ohne +) findet sich eh nur ganz wenig. Weder beim Volkszähler-Wiki noch bei den Tasmota-Skripten findet sich was genaues.
                                            Soll ich dir mal ein wemos schicken mit der selben Tasmota Version, die bei mir läuft?
                                            Ich nutze von Hichi den Lesekopf und habe ihn auch mit einem Wemos verbunden.
                                            4128
