    4. Node-Red
    5. Mehrere Steckdosen Werte vergleichen zum Schalten
    • mickym
      mickym Most Active @Kredar last edited by
      @kredar
      Somit bist Du immer auf dem neuest Stand und nicht erst nach 15 Minuten. Wenn Du nicht willst dass permanent Nachrichten kommen, weil sich die Werte nur geringfügig ändern, kannst Du noch eine Filter Node einbauen und dann wolltest Du ja, dass NUR false weiterkommt.
      Damit würde Dein vollständiger Flow NUR zum Ausschalten der Klima dann wie folgt aussehen:
             "id": "556a4e08f5940d01",
             "type": "ioBroker in",
             "z": "69e883c9af983f50",
             "name": "",
             "topic": "0_userdata.0.Test.PC_Power1",
             "payloadType": "value",
             "onlyack": "",
             "func": "all",
             "gap": "",
             "fireOnStart": "true",
             "outFormat": "ioBroker",
             "x": 260,
             "y": 220,
             "wires": [
                     "bef8f43e26e97cba"
             "id": "41b50f9f23ddf146",
             "name": "",
             "topic": "0_userdata.0.Test.PC_Power2",
             "onlyack": "",
             "func": "all",
             "gap": "",
             "x": 260,
             "y": 280,
             "wires": [
                     "7ad9c5d564286cd9"
             "id": "f7206ede621ac7dd",
             "name": "",
             "topic": "0_userdata.0.Test.PC_Power3",
             "onlyack": "",
             "func": "all",
             "gap": "",
             "x": 260,
             "y": 340,
             "wires": [
                     "530d4b6575143082"
             "id": "3548421128b007da",
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "payload > 20 ? true : false",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 710,
             "y": 280,
             "wires": [
                     "0f824f4bf3764b13"
             "id": "355a7107b476d7e2",
             "type": "debug",
             "name": "Objekt mit Einzelstates",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "complete": "payload",
             "targetType": "msg",
             "statusVal": "",
             "statusType": "auto",
             "x": 1100,
             "y": 240,
             "wires": []
             "id": "0f824f4bf3764b13",
             "type": "join",
             "name": "",
             "mode": "custom",
             "build": "object",
             "property": "payload",
             "propertyType": "msg",
             "key": "topic",
             "joiner": "\\n",
             "joinerType": "str",
             "accumulate": true,
             "timeout": "",
             "count": "1",
             "reduceRight": false,
             "reduceExp": "",
             "reduceInit": "",
             "reduceInitType": "",
             "reduceFixup": "",
             "x": 890,
             "y": 280,
             "wires": [
                     "355a7107b476d7e2",
                     "7938c1ca26d90beb"
             "id": "716d79ef4c4b8fe2",
             "type": "change",
             "name": "OR ?",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "$reduce(payload.*,function($i, $j){$i or $j})",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 1170,
             "y": 280,
             "wires": [
                     "6fe8fcb52a28a72d",
                     "5632858b36b551a4"
             "info": "# Only one or more properties of an object need to be true.\n\n Only one or more properties of an object need to be true.\n\n`{\n    \"Office\": false,\n    \"Bedroom\": false,\n    \"Living Room Balcony\": false,\n    \"Liviueng Room Right Window\": false,\n    \"Living Room Left Window\": false\n}`\n\nis false,\n\n`{\n    \"Office\": false,\n    \"Bedroom\": true,\n    \"Living Room Balcony\": false,\n    \"Living Room Right Window\": false,\n    \"Living Room Left Window\": false\n}`\n\nis true.\n\n# Mindestens eine Eigenschaft des Objektes muss wahr sein.\n\nMindestens eine Eigenschaft des Objektes muss wahr sein.\n\n`{\n    \"Büro Balkon\": false,\n    \"Schlafzimmer Balkon\": false,\n    \"Wohnzimmer Balkon\": false,\n    \"Wohnzimmer rechtes Fenster\": false,\n    \"Wohnzimmer linkes Fenster\": false\n}`\n\nergibt false,\n\n`{\n    \"Büro Balkon\": false,\n    \"Schlafzimmer Balkon\": true,\n    \"Wohnzimmer Balkon\": false,\n    \"Wohnzimmer rechtes Fenster\": false,\n    \"Wohnzimmer linkes Fenster\": false\n}`\n\nergibt true (wahr)."
             "id": "bdfc2a74610ea7a7",
             "type": "debug",
             "name": "Ergebnis",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 1560,
             "y": 280,
             "wires": []
             "id": "bef8f43e26e97cba",
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "topic",
                     "pt": "msg",
                     "to": "Steckdose1",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 500,
             "y": 220,
             "wires": [
                     "3548421128b007da"
             "id": "7ad9c5d564286cd9",
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "topic",
                     "pt": "msg",
                     "to": "Steckdose2",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 500,
             "y": 280,
             "wires": [
                     "3548421128b007da"
             "id": "530d4b6575143082",
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "topic",
                     "pt": "msg",
                     "to": "Steckdose3",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 500,
             "y": 340,
             "wires": [
                     "3548421128b007da"
             "id": "7938c1ca26d90beb",
             "type": "rbe",
             "name": "",
             "func": "rbe",
             "gap": "",
             "start": "",
             "inout": "out",
             "septopics": false,
             "topi": "topic",
             "x": 1030,
             "y": 280,
             "wires": [
                     "716d79ef4c4b8fe2"
             "id": "6fe8fcb52a28a72d",
             "type": "switch",
             "name": "Nur false soll triggern",
             "rules": [
                     "t": "false"
             "checkall": "true",
             "repair": false,
             "outputs": 1,
             "x": 1360,
             "y": 280,
             "wires": [
                     "bdfc2a74610ea7a7"
             "id": "5632858b36b551a4",
             "type": "debug",
             "name": "Gesamtstatus",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 1340,
             "y": 320,
             "wires": []
        Kredar @mickym last edited by Kredar
        @mickym
        Wunderbar, das ist jetzt wirklich aufgeräumt. Nun muss ich das noch einpflegen. Habe auch Schaltungen nach Uhrzeit (Licht abends) in kombination mit einem Lichtsensor und eben den wie hier beschriebenen PCs via Strommessung. Erst lasst ich das Licht prüfen, dann die Zeit und dann geht das Licht an. Außer es sind alle PCs aus = keiner im Haus = brauche kein Licht. Da muss ich eben dein neues Node einpflegen.
        Ich danke dir nochmals für deine Hilfe
        mfg
        • mickym
          @kredar sagte in Mehrere Steckdosen Werte vergleichen zum Schalten:
          @mickym
          mfg
          Freut mich. Hauptsache, Du hast die Funktionsweise verstanden - dann kannst Du es ja auf Deine Bedürfnisse entsprechend anpassen. Im Zweifelsfall lieber nochmal fragen. 😉
            @mickym
            Werde es mir mal sehr genau anschauen, hast es ja super erklärt oben 🙂 Merci. Zur Not frage ich nochmal hier.
            So schaut eine Schaltung aus. Da schaue ich gerade drüber 🙂
            mfg
            • mickym
              @kredar Ich glaube das müsste man logisch vereinfachen - das schaut recht komplex aus. 😉
                @mickym
                Haha, war klar das das kommt. Ich würde alles vereinfachen, da es doch komplex ist und damit fehleranfällig.
                mfg
                  Ich bekomme Fehler angezeigt seit der Umstellung:
                  node-red.0
                  2023-06-30 00:45:56.708 error 30 Jun 00:45:56 - [error] [change:923f6883ad9b2e8a] Ungültiger JSONata Ausdruck: The values "false" and 20 either side of operator ">" must be of the same data type30 Jun 00:45:56 - [error] [change:923f6883ad9b2e8a] Ungültiger JSONata Ausdruck: The values "false" and 20 either side of operator ">" must be of the same data type
                  node-red.0
                  2023-06-30 00:45:56.688 error 30 Jun 00:45:56 - [error] [change:923f6883ad9b2e8a] Ungültiger JSONata Ausdruck: The values "false" and 20 either side of operator ">" must be of the same data type
                  Ich meine das liegt an dem setze.msg.payload Node oder?
                  mfg
                  • mickym
                    mickym Most Active @Kredar last edited by mickym
                    923f6883ad9b2e8a
                    Du gibst diese Zahl einfach in das Suchfeld ein - dann siehst Du welche Node den Fehler wirft.
                    Es sieht eher so aus - als ob aus aus den Datenpunkten kein numerischer Wert rauskommt - warum auch immer - eventuell musst Du das abfangen. In der Change Node wird ja, je nachdem welche Leistung in dem Datenpunkt steht true oder false gesetzt.
                    Wenn die payload aber nicht numerisch ist, entsteht dieser Fehler.
                    Wenn Du nicht erklären kannst, wie das zustande kommt, dann musst Du diese Nachrichten raus filtern oder selbst ein numerischen Wert setzen. Die Fehlermeldung sagt ja, dass ich false > 20 ungültig ist.
                    Ich bekomme diesen Fehler, wenn der Datenpunkt zum Beispiel nicht existiert.
                    Einen Filter kannst Du ggf. mit einer Switch NOde setzen, wenn Du nicht sicherstellen kannst, dass Deine Werte numerisch sind:
                      Sorry war verhindert. Werde ich mir anschauen. Das kam nur einmal, bisher nicht mehr. Hmm, mal beobachten ;).
                      Danke für deine Hilfe.
                      mfg
                        @mickym
                        Habe die Meldung noch öfters bekommen, teste gerade deine Switch Lösung. Mal sehen. Merci für die Lösung zum testen. Hoffe es klappt.
                        mfg
                        81.1k
                        2597
