    4. js-controller 5.0.x jetzt in der BETA
      arteck Developer Most Active @Marius Schäfer last edited by
      @marius-schäfer installier die GIT version oder warte auf 1.8.18..
      • Feuersturm
        Feuersturm @foxriver76 last edited by
        @foxriver76 Update auf Master Slave Testsystem war erfolgreich
        Beim Master kommt nach dem Update auf 5.0.8 und starten des Controllers folgende Warnung
        2023-07-16 12:37:00.799 - warn: host.ioBrokerTestsystem-Server Objects 192.168.178.78:58884 Error from InMemDB: Error: Unknown Script b0bd9e6fd92479ccf43654a7ba7443c915d0a742
        at RedisHandler. (/opt/iobroker/node_modules/@iobroker/db-objects-jsonl/build/lib/objects/objectsInMemServerRedis.js:301:59)
        at RedisHandler.emit (node:events:513:28)
        at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/db-base/build/lib/redisHandler.js:132:37)
        at process.processImmediate (node:internal/timers:476:21)
        Log Master:
        2023-07-16 12:35:28.691 - info: host.ioBrokerTestsystem All instances are stopped.
        2023-07-16 12:35:28.827 - info: host.ioBrokerTestsystem terminated
        2023-07-16 12:35:33.225 - info: host.ioBrokerTestsystem [CONTROLLER_AUTO_UPGRADE] Successfully stopped js-controller
        2023-07-16 12:35:33.242 - info: host.ioBrokerTestsystem [CONTROLLER_AUTO_UPGRADE] Server is running on http://localhost:8081
        2023-07-16 12:36:48.197 - info: host.ioBrokerTestsystem [CONTROLLER_AUTO_UPGRADE]
        removed 123 packages, and changed 21 packages in 1m
        143 packages are looking for funding
        run `npm fund` for details
        2023-07-16 12:36:48.872 - info: host.ioBrokerTestsystem [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:36:54.084 - info: host.ioBrokerTestsystem [CONTROLLER_AUTO_UPGRADE] Successfully started js-controller
        2023-07-16 12:36:58.279 - info: host.ioBrokerTestsystem iobroker.js-controller version 5.0.8 js-controller starting
        2023-07-16 12:36:58.292 - info: host.ioBrokerTestsystem Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
        2023-07-16 12:36:58.295 - info: host.ioBrokerTestsystem hostname: ioBrokerTestsystem, node: v18.16.1
        2023-07-16 12:36:58.308 - info: host.ioBrokerTestsystem ip addresses: 192.168.178.77 fe80::f854:cfff:fe5f:6c25
        2023-07-16 12:37:02.688 - info: host.ioBrokerTestsystem connected to Objects and States
        2023-07-16 12:37:02.834 - info: host.ioBrokerTestsystem added notifications configuration of host
        2023-07-16 12:37:04.623 - info: host.ioBrokerTestsystem Delete state "system.host.ioBrokerTestsystem.versions.nodeCurrent"
        2023-07-16 12:37:04.627 - info: host.ioBrokerTestsystem 62 instances found
        2023-07-16 12:37:04.812 - info: host.ioBrokerTestsystem starting 36 instances
        Im Log vom Slave taucht ein paar Mal diese Meldung auf (während der Master aktualisiert wird).
        2023-07-16 12:36:34.300 - error: host.ioBrokerNew Could not execute primary host determination: Error Unknown Script b0bd9e6fd92479ccf43654a7ba7443c915d0a742
        2023-07-16 02:12:48.100 - info: host.ioBrokerNew Delete log file iobroker.2023-07-08.log.gz
        2023-07-16 12:35:33.812 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
        2023-07-16 12:35:33.848 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
        2023-07-16 12:35:38.832 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
        2023-07-16 12:35:38.860 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
        2023-07-16 12:35:43.842 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
        2023-07-16 12:35:43.870 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
        2023-07-16 12:35:48.858 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
        2023-07-16 12:35:48.883 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
        2023-07-16 12:35:53.864 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
        2023-07-16 12:35:53.905 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
        2023-07-16 12:35:58.892 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
        2023-07-16 12:35:58.912 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
        2023-07-16 12:36:03.900 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
        2023-07-16 12:36:03.923 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
        2023-07-16 12:36:08.907 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
        2023-07-16 12:36:08.935 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
        2023-07-16 12:36:13.922 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
        2023-07-16 12:36:13.943 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
        2023-07-16 12:36:18.929 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
        2023-07-16 12:36:18.950 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
        2023-07-16 12:36:23.946 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
        2023-07-16 12:36:23.956 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
        2023-07-16 12:36:28.953 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
        2023-07-16 12:36:28.963 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
        2023-07-16 12:36:33.967 - info: host.ioBrokerNew Objects database successfully reconnected
        2023-07-16 12:36:33.974 - info: host.ioBrokerNew Objects database successfully reconnected
        2023-07-16 12:36:34.302 - error: host.ioBrokerNew Could not execute primary host determination: Error Unknown Script b0bd9e6fd92479ccf43654a7ba7443c915d0a742
        2023-07-16 12:36:45.498 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
        2023-07-16 12:36:45.575 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
        2023-07-16 12:36:50.505 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
        2023-07-16 12:36:50.584 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
        2023-07-16 12:36:55.517 - error: host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
        2023-07-16 12:36:55.589 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
        2023-07-16 12:37:00.524 - info: host.ioBrokerNew Objects database successfully reconnected
        2023-07-16 12:37:00.595 - error: host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
        2023-07-16 12:37:00.859 - error: host.ioBrokerNew Could not execute primary host determination: Error Unknown Script b0bd9e6fd92479ccf43654a7ba7443c915d0a742
        2023-07-16 12:37:05.601 - info: host.ioBrokerNew Objects database successfully reconnected
        2023-07-16 12:42:21.065 - info: host.ioBrokerNew Controller will upgrade itself to version 5.0.8
        2023-07-16 12:42:25.561 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Stopping controller
        2023-07-16 12:42:25.701 - info: host.ioBrokerNew received SIGTERM
        2023-07-16 12:42:25.707 - info: host.ioBrokerNew stopInstance system.adapter.history.1 (force=false, process=false)
        2023-07-16 12:42:25.708 - info: host.ioBrokerNew stopInstance system.adapter.sql.0 (force=false, process=false)
        2023-07-16 12:42:25.710 - info: host.ioBrokerNew stopInstance system.adapter.discovery.0 (force=false, process=false)
        2023-07-16 12:42:25.789 - info: host.ioBrokerNew terminated
        2023-07-16 12:42:29.896 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Successfully stopped js-controller
        2023-07-16 12:42:29.915 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Server is running on http://localhost:8081
        2023-07-16 12:43:21.442 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE]
        changed 19 packages in 48s
        81 packages are looking for funding
        2023-07-16 12:43:22.417 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:23.423 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:25.447 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:26.460 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:27.468 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:28.480 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:29.495 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:30.498 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:31.504 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:32.508 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:33.521 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:34.534 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:35.549 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:36.548 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:37.562 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:38.582 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:39.589 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:40.596 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:41.602 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:42.605 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:43.620 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:44.631 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:45.636 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:46.650 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:47.655 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:48.665 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:49.676 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:50.682 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:51.687 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:52.699 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:53.700 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:54.709 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:55.736 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:56.722 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:57.727 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:58.747 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:43:59.745 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:44:00.754 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:44:01.760 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:44:02.768 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:44:03.776 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:44:04.783 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:44:05.796 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:44:06.789 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:44:07.806 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:44:08.810 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:44:09.819 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:44:10.828 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:44:11.842 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:44:12.851 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:44:13.855 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:44:14.874 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:44:15.878 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:44:16.883 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:44:17.905 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:44:18.905 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:44:19.915 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:44:20.922 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:44:21.934 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Final information delivered
        2023-07-16 12:44:24.588 - info: host.ioBrokerNew [CONTROLLER_AUTO_UPGRADE] Successfully started js-controller
        2023-07-16 12:44:26.169 - info: host.ioBrokerNew iobroker.js-controller version 5.0.8 js-controller starting
        2023-07-16 12:44:26.180 - info: host.ioBrokerNew Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
        2023-07-16 12:44:26.182 - info: host.ioBrokerNew hostname: ioBrokerNew, node: v18.16.0
        2023-07-16 12:44:26.185 - info: host.ioBrokerNew ip addresses: 192.168.178.78 fe80::d4a0:37ff:fe8e:f0c1
        2023-07-16 12:44:26.843 - info: host.ioBrokerNew connected to Objects and States
        2023-07-16 12:44:26.900 - info: host.ioBrokerNew added notifications configuration of host
        2023-07-16 12:44:28.166 - info: host.ioBrokerNew 62 instances found
        2023-07-16 12:44:28.214 - warn: host.ioBrokerNew does not start any instances on this host
        Diese Warnung/Fehler ist mir bisher noch nicht aufgefallen. Vielleicht könnt ihr damit etwas anfangen.
          Rogni @Feuersturm last edited by Rogni
          R
          Rogni
          25 minutes ago
          Hi Leute,
          Seit dem Update auf NodeJS 18 und JS Controller 5.05 hat der Nanoleaf Adapter keine Funktion mehr, da er wohl noch nicht mit dem neuen Node JS zurecht kommt. Gibt es hierfür eine Alternative bzw. Update?? ICh finde hierzu leider nichts.
          Vielen Dank schonmal für Eure Infos
          Log beim Start:
          2023-07-16 13:48:17.068  - info: host.IOBroker-Neu instance system.adapter.nanoleaf-lightpanels.0 started with pid 32183
          2023-07-16 13:48:17.294  - error: host.IOBroker-Neu Caught by controller[0]: node:internal/modules/cjs/loader:1080
          2023-07-16 13:48:17.294  - error: host.IOBroker-Neu Caught by controller[0]:   throw err;
          2023-07-16 13:48:17.294  - error: host.IOBroker-Neu Caught by controller[0]:   ^
          2023-07-16 13:48:17.294  - error: host.IOBroker-Neu Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
          2023-07-16 13:48:17.294  - error: host.IOBroker-Neu Caught by controller[0]: Require stack:
          2023-07-16 13:48:17.294  - error: host.IOBroker-Neu Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels/lib/utils.js
          2023-07-16 13:48:17.294  - error: host.IOBroker-Neu Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels/main.js
          2023-07-16 13:48:17.294  - error: host.IOBroker-Neu Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
          2023-07-16 13:48:17.294  - error: host.IOBroker-Neu Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:922:27)
          2023-07-16 13:48:17.294  - error: host.IOBroker-Neu Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19)
          2023-07-16 13:48:17.294  - error: host.IOBroker-Neu Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:110:18)
          2023-07-16 13:48:17.294  - error: host.IOBroker-Neu Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels/lib/utils.js:63:25)
          2023-07-16 13:48:17.295  - error: host.IOBroker-Neu Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
          2023-07-16 13:48:17.295  - error: host.IOBroker-Neu Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
          2023-07-16 13:48:17.295  - error: host.IOBroker-Neu Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
          2023-07-16 13:48:17.295  - error: host.IOBroker-Neu Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
          2023-07-16 13:48:17.295  - error: host.IOBroker-Neu Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19) {
          2023-07-16 13:48:17.295  - error: host.IOBroker-Neu Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
          2023-07-16 13:48:17.295  - error: host.IOBroker-Neu Caught by controller[0]:   requireStack: [
          2023-07-16 13:48:17.295  - error: host.IOBroker-Neu Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels/lib/utils.js',
          2023-07-16 13:48:17.295  - error: host.IOBroker-Neu Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels/main.js'
          2023-07-16 13:48:17.295  - error: host.IOBroker-Neu Caught by controller[0]:   ]
          2023-07-16 13:48:17.295  - error: host.IOBroker-Neu Caught by controller[0]: }
          2023-07-16 13:48:17.295  - error: host.IOBroker-Neu Caught by controller[0]: Node.js v18.16.1
          2023-07-16 13:48:17.295  - error: host.IOBroker-Neu instance system.adapter.nanoleaf-lightpanels.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2023-07-16 13:48:17.295  - info: host.IOBroker-Neu Rebuild for adapter system.adapter.nanoleaf-lightpanels.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
          2023-07-16 13:48:18.940  - info: host.IOBroker-Neu instance system.adapter.nanoleaf-lightpanels.1 started with pid 32190
          2023-07-16 13:48:19.146  - error: host.IOBroker-Neu Caught by controller[0]: node:internal/modules/cjs/loader:1080
          2023-07-16 13:48:19.146  - error: host.IOBroker-Neu Caught by controller[0]:   throw err;
          2023-07-16 13:48:19.146  - error: host.IOBroker-Neu Caught by controller[0]:   ^
          2023-07-16 13:48:19.146  - error: host.IOBroker-Neu Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
          2023-07-16 13:48:19.146  - error: host.IOBroker-Neu Caught by controller[0]: Require stack:
          2023-07-16 13:48:19.146  - error: host.IOBroker-Neu Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels/lib/utils.js
          2023-07-16 13:48:19.146  - error: host.IOBroker-Neu Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels/main.js
          2023-07-16 13:48:19.146  - error: host.IOBroker-Neu Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
          2023-07-16 13:48:19.146  - error: host.IOBroker-Neu Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:922:27)
          2023-07-16 13:48:19.146  - error: host.IOBroker-Neu Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19)
          2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:110:18)
          2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels/lib/utils.js:63:25)
          2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
          2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
          2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
          2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
          2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19) {
          2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
          2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]:   requireStack: [
          2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels/lib/utils.js',
          2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels/main.js'
          2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]:   ]
          2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]: }
          2023-07-16 13:48:19.147  - error: host.IOBroker-Neu Caught by controller[0]: Node.js v18.16.1
          2023-07-16 13:48:19.147  - error: host.IOBroker-Neu instance system.adapter.nanoleaf-lightpanels.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2023-07-16 13:48:19.147  - info: host.IOBroker-Neu Rebuild for adapter system.adapter.nanoleaf-lightpanels.1 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
          2023-07-16 13:49:00.012  - info: hm-rpc.1 (32124) Scheduled restart.
          Issue ist eröffnet
          • ESP8266
            ESP8266 last edited by ESP8266
            Es betrifft zwar nicht den js.controller, aber ein Upgrade von Node 16.x.x auf 18.x.x bringt den Maxcul Adapter nicht mehr zum laufen....Issue ist eröffnet.
            Zur Info:
            https://github.com/ioBroker/ioBroker.maxcul/issues/63
            Also scheint es so, als hätten noch andere Adapter das Problem.
            Menne01 created this issue in ioBroker/ioBroker.maxcul
            closed Der Adapter läuft nicht unter Node 18.x.x #63
            • mcm1957
              mcm1957 @Rogni last edited by mcm1957
              @rogni said in js-controller 5.0.x jetzt in der BETA:
              R
              Rogni
              25 minutes ago
              Hi Leute,
              Da Adaptername hier unvollständig angegeben, link zum Adapter:
              https://github.com/daniel-2k/ioBroker.nanoleaf-lightpanels
              • mcm1957
                mcm1957 @mcm1957 last edited by mcm1957
                @mcm57 said in js-controller 5.0.x jetzt in der BETA:
                @apollon77 said in js-controller 5.0.x jetzt in der BETA:
                Neue erkannte Probleme, die noch nicht behandelt sind:
                • stiebel-isg update nötig
                • lgtv sollte fixed sein mit 1.1.12
                • web kann crashen falls Widgets in vis falsch konfiguriert sind (PR in socket-classes existiert bereits)
                • js-controller upgrade via Admin startet js-controller nicht wieder
                • Admin zeigt falsche Log grösse an -> Fixed in Admin 6.5.8+
                • km200 sollte gefixt sein mit 2.0.4
                • miio muss geprüft werden
                • fakeroku GitHub Version gefixt, release fehlt noch
                • pi-hole update nötig
                • node-red muss geprüft werden
                • enigma2.0 mindestens 1.4.0+
                • doorbird update nötig
                • linux-control update nötig
                Liste wär anzupassen:
                Km200 funktioniert weder in 1.4 noch 1.5 stabil.
                Km200 wurde deprecated und wir - sollte sich nicht noch ein dev finden - ab js controller 5.x nicht mehr laufen. ems-esp existiert als ersatz.
                @apollon77
                Weitere Anpassung:
                nanoleaf-lights benötigt update - Version 1.4.0 sollte ab morgen im Latest sein. (@rogni)
                  guergen @ESP8266 last edited by
                  @esp8266 Maxcul läuft hier schon ewig fehlerfrei mit Node 18; mittlerweile 18.16.1
                  • ESP8266
                    ESP8266 @guergen last edited by ESP8266
                    @guergen , komisch über die Schwelle gehe ich nicht. Das war schon nachdem die Empfehlung raus war für Node 18.X.X und mit dem alten 4.x.x Controller. Damals unbeachtet von mir.
                    Vielleicht liegt eine Verwechseung vor mit dem MaxCube Adapter !?
                    Ich wüsste nicht wo dran es liegen sollte.....
                      guergen @ESP8266 last edited by guergen
                      @esp8266 Ich habe den Maxcul definitiv. Ich bin mit meinem System komplett auf Beta unterwegs!
                      Maxcul 1.3.1, js-controller aktuell ; seit 5 Minuten auch auf 5.0.8
                      ESP8266 2 Replies Last reply Reply Quote 0
                      • ESP8266
                        @guergen , nichts anderes wie bei mir. Ich setze kommende Woche eh neu auf Bookworm auf.
                        Ja, richtig, nichts mit Upgrade von Bullseye auf Bookworm. Ich möchte ein sauberes System und keine alten versteckte Leichen haben. Ist zwar einiges vor zuinstallieren, aber egal.
                        Da bin ich gespannt mit Node 18.x.x. und dem Restore von iob.
                          @esp8266 Ich komme mittlerweile sogar als Upgrades von Deb 9
                            Marty56 @guergen last edited by
                            Update auf JS-Controller 5.0.9 hat Fehlfunktion im VW-Adapter zur Folger
                            vw-connect.0
                            2023-07-21 01:00:11.076	error	SyntaxError: Unexpected token c in JSON at position 1412
                            vw-connect.0
                            2023-07-21 01:00:11.075	error	Error in consent form
                            vw-connect.0
                            2023-07-21 01:00:10.888	error	Restart Adapter in 30min
                            vw-connect.0
                            2023-07-21 01:00:10.887	error	Login Failed
                            vw-connect.0
                            2023-07-21 01:00:05.752	error	Restart adapter
                            mcm1957 Feuersturm 2 Replies Last reply Reply Quote 0
                            • mcm1957
                              mcm1957 @Marty56 last edited by
                              @marty56
                              Bitte auch immer die Adappter Version angeben.
                              Und mach ein issue beim Adapter auf wenn noch nicht existent.
                                Marty56 @mcm1957 last edited by
                                @mcm57 ist die latest.
                                Vermutlich liegt es aber an der Schrott Infrastruktur von VW/Skoda.
                                Es gibt dazu ein Issue. Bei mir, war es, vielleicht zufällig, mit dem Update auf js-controller 5.0.9 korreliert.
                                • mcm1957
                                  @marty56
                                  Danke f Feedback.
                                  Generell bitte immer die Versionen numerisch Ngeben. Warum? Latest ist heute klar. Liegt ein issue aus irgendeinem grund ab dann ist latest ev unklar da es schon eine neuere version geben könnte. Ist für entwickler mügsam zu checken zu welcher release ein issue gehört.
                                  Aber hier ist durch den verweis aus issue alles klar.
                                  • Gaspode
                                    Gaspode last edited by
                                    Ich wollte mir mal das Upgrade des JS-Controllers unter Linux anschauen. Dazu hab ich einen ioBroker unter WSL installiert, ihn auf JS-Controller 5.0.7 gebracht und dann auf der Admin Seite Hosts das Upgrade gestartet. Es kommt nur eine einzige Fehlermeldung:
                                    SyntaxError: JSON.parse: unexpected character at line 1 column 1 of the JSON data
                                    Im Log steht
                                    2023-07-21 11:03:24.112 - debug: host.iobHost Incoming Host message getLogs
                                    2023-07-21 11:03:26.112 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.inputCount
                                    2023-07-21 11:03:26.114 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.inputCount, system.host.iobHost.outputCount
                                    2023-07-21 11:03:26.115 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.inputCount, system.host.iobHost.outputCount, system.host.iobHost.cpu
                                    2023-07-21 11:03:26.115 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.inputCount, system.host.iobHost.outputCount, system.host.iobHost.cpu, system.host.iobHost.mem
                                    2023-07-21 11:03:26.115 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.inputCount, system.host.iobHost.outputCount, system.host.iobHost.cpu, system.host.iobHost.mem, system.host.iobHost.uptime
                                    2023-07-21 11:03:26.115 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.inputCount, system.host.iobHost.outputCount, system.host.iobHost.cpu, system.host.iobHost.mem, system.host.iobHost.uptime, system.host.iobHost.diskFree
                                    2023-07-21 11:03:26.116 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.inputCount, system.host.iobHost.outputCount, system.host.iobHost.cpu, system.host.iobHost.mem, system.host.iobHost.uptime, system.host.iobHost.diskFree, system.host.iobHost.diskSize
                                    2023-07-21 11:03:26.119 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.inputCount, system.host.iobHost.outputCount, system.host.iobHost.cpu, system.host.iobHost.mem, system.host.iobHost.uptime, system.host.iobHost.diskFree, system.host.iobHost.diskSize, system.host.iobHost.diskWarning
                                    2023-07-21 11:03:26.120 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.inputCount, system.host.iobHost.outputCount, system.host.iobHost.cpu, system.host.iobHost.mem, system.host.iobHost.uptime, system.host.iobHost.diskFree, system.host.iobHost.diskSize, system.host.iobHost.diskWarning, system.host.iobHost.logLevel
                                    2023-07-21 11:03:29.760 - debug: host.iobHost Incoming Host message upgradeController
                                    2023-07-21 11:03:29.761 - info: host.iobHost Controller will upgrade itself to version 5.0.8
                                    2023-07-21 11:03:51.836 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.outputCount, system.host.iobHost.cpu, system.host.iobHost.mem, system.host.iobHost.uptime, system.host.iobHost.diskFree, system.host.iobHost.diskSize, system.host.iobHost.diskWarning, system.host.iobHost.logLevel
                                    2023-07-21 11:03:51.836 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.cpu, system.host.iobHost.mem, system.host.iobHost.uptime, system.host.iobHost.diskFree, system.host.iobHost.diskSize, system.host.iobHost.diskWarning, system.host.iobHost.logLevel
                                    2023-07-21 11:03:51.836 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.mem, system.host.iobHost.uptime, system.host.iobHost.diskFree, system.host.iobHost.diskSize, system.host.iobHost.diskWarning, system.host.iobHost.logLevel
                                    2023-07-21 11:03:51.837 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.uptime, system.host.iobHost.diskFree, system.host.iobHost.diskSize, system.host.iobHost.diskWarning, system.host.iobHost.logLevel
                                    2023-07-21 11:03:51.837 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.diskFree, system.host.iobHost.diskSize, system.host.iobHost.diskWarning, system.host.iobHost.logLevel
                                    2023-07-21 11:03:51.838 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.diskSize, system.host.iobHost.diskWarning, system.host.iobHost.logLevel
                                    2023-07-21 11:03:51.838 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.diskWarning, system.host.iobHost.logLevel
                                    2023-07-21 11:03:51.838 - debug: admin.0 (3608) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive, system.host.*.notifications.*, admin.0.info.newsFeed, system.host.iobHost.logLevel
                                    2023-07-21 11:03:51.842 - debug: host.iobHost Incoming Host message getLogFiles
                                    2023-07-21 11:03:51.885 - debug: host.iobHost Incoming Host message getLogs
                                    2023-07-21 11:04:01.682 - debug: host.iobHost Incoming Host message getLogFile
                                    Log Level für Admin und Controller steht auf Debug.
                                    Gibt's da gerade ein bekanntes Problem oder liegt es an mir?
                                    • ESP8266
                                      @guergen sagte in js-controller 5.0.x jetzt in der BETA:
                                      Alles OK, Fehler lag hier. Läuft....
                                      Nachtrag:
                                      Ein upgrade des Nodes von 16.X.X auf 18.X.X in einem vorhandenem System bringt den Maxcul Adapter nicht mehr zum starten. Nur bei einem aktualisiertem Betriebsystem mit Node 18.X.X und neuer iob Installation mit Restore lässt den Maxcul Adapter in Ruhe und läuft....
                                      • foxriver76
                                        foxriver76 Developer @Gaspode last edited by
                                        @gaspode läuft iobroker in WSL als systemd Dienst? Sonst wird es nicht gehen, ich bin leider im Thema nicht drin was installer macht bei WSL
                                        Gaspode 1 Reply Last reply Reply Quote 1
                                        • Gaspode
                                          Gaspode @foxriver76 last edited by
                                          @foxriver76 said in js-controller 5.0.x jetzt in der BETA:
                                          Guter Punkt. Wohl nicht, da ich WSL1 nutzen muss, weil ich aus diversen Gründen Hyper-V nicht nutzen kann.
                                          systemd wird anscheinend erst ab WSL2 unterstützt.
                                          Die Frage wäre, ob man das irgendwie erkennen kann, dass ioBroker nicht als systemd Dienst läuft und das Upgrade dann gar nicht erst anbietet ...
                                            Thomas Braun Most Active @Gaspode last edited by
                                            @gaspode sagte in js-controller 5.0.x jetzt in der BETA:
                                            Kannst ja schauen, ob auf
                                            systemctl status iobroker.service
                                            eine Rückmeldung oder eine Fehlermeldung kommt.
                                            Gaspode 1 Reply Last reply Reply Quote 0
                                            580
                                            185092
