    3. Off Topic
    4. Restore auf neuem Raspberry
      Homoran Global Moderator Administrators @loverz last edited by
      @loverz sagte in Restore auf neuem Raspberry:
      Kann ja nicht so schwer sein ioBroker neu zu installieren
      @homoran sagte in Restore auf neuem Raspberry:
      hat ja mit iobroker selbst nichts zu tun.
        loverz @Thomas Braun last edited by
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Model           : Raspberry Pi 4 Model B Rev 1.1
        Architecture    : aarch64
        Docker          : false
        Virtualization  : none
        Distributor ID: Debian
        Description:    Debian GNU/Linux 11 (bullseye)
        Release:        11
        Codename:       bullseye
        PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
        NAME="Debian GNU/Linux"
        VERSION_ID="11"
        VERSION="11 (bullseye)"
        VERSION_CODENAME=bullseye
        ID=debian
        HOME_URL="https://www.debian.org/"
        SUPPORT_URL="https://www.debian.org/support"
        BUG_REPORT_URL="https://bugs.debian.org/"
        Systemuptime and Load:
         22:37:18 up  3:22,  1 user,  load average: 0.00, 0.01, 0.00
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        Other values than 0x0 hint to temperature/voltage problems
        temp=49.1'C
        volt=0.8563V
        *** Time and Time Zones ***
                       Local time: Sun 2023-07-16 22:37:18 CEST
                   Universal time: Sun 2023-07-16 20:37:18 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            1.8G        573M        913M        1.0M        362M        1.2G
        Swap:            99M          0B         99M
        Total:          1.9G        573M        1.0G
                 1849 M total memory
                  573 M used memory
                  703 M active memory
                  136 M inactive memory
                  913 M free memory
                   35 M buffer memory
                  326 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /dev/root      ext4      117G  3.6G  109G   4% /
        devtmpfs       devtmpfs  667M     0  667M   0% /dev
        tmpfs          tmpfs     925M     0  925M   0% /dev/shm
        tmpfs          tmpfs     370M  1.1M  369M   1% /run
        /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
        tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
        [Sun Jul 16 19:14:48 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:43:7C:47 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f60dec51-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Sun Jul 16 19:14:49 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sun Jul 16 19:14:49 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Sun Jul 16 19:14:51 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        Show mounted filesystems (real ones only):
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        608M    /var/
        257M    /var/cache
        251M    /var/cache/apt
        160M    /var/lib
        151M    /var/cache/apt/archives
        Archived and active journals take up 88.0M in the file system.
        /opt/iobroker/backups:
        91M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        173M    /opt/iobroker/iobroker-data/
        98M     /opt/iobroker/iobroker-data/files
        52M     /opt/iobroker/iobroker-data/files/javascript.admin
        34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
        33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        36M     /opt/iobroker/iobroker-data/objects.jsonl
        9.5M    /opt/iobroker/iobroker-data/states.jsonl
        6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.312d98a8.chunk.js.map
        6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
        5.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/44.59b48e42.chunk.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.16.1
        /usr/bin/node           v18.16.1
        /usr/bin/npm            9.5.1
        /usr/bin/npx            9.5.1
        nodejs:
          Installed: 18.16.1-deb-1nodesource1
          Candidate: 18.16.1-deb-1nodesource1
          Version table:
         *** 18.16.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u4 500
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
             12.22.12~dfsg-1~deb11u3 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
        No problems detected
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        MULTIHOSTSERVICE/enabled: false
        Core adapters versions
        js-controller:  4.0.24
        admin:          6.3.5
        javascript:     7.0.3
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.0                  : admin                 : Eck29-ioBroker                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.alexa2.0                 : alexa2                : Eck29-ioBroker                           - disabled
        + system.adapter.backitup.0               : backitup              : Eck29-ioBroker                           -  enabled
          system.adapter.daswetter.0              : daswetter             : Eck29-ioBroker                           - disabled
          system.adapter.deconz.0                 : deconz                : Eck29-ioBroker                           - disabled, port: 80
          system.adapter.easee.0                  : easee                 : Eck29-ioBroker                           - disabled
          system.adapter.ems-esp.0                : ems-esp               : Eck29-ioBroker                           - disabled
          system.adapter.hmip.0                   : hmip                  : Eck29-ioBroker                           - disabled
          system.adapter.hs100.0                  : hs100                 : Eck29-ioBroker                           - disabled
          system.adapter.hue.0                    : hue                   : Eck29-ioBroker                           - disabled, port: 443
        + system.adapter.influxdb.0               : influxdb              : Eck29-ioBroker                           -  enabled, port: 8086
          system.adapter.info.0                   : info                  : Eck29-ioBroker                           - disabled
          system.adapter.javascript.0             : javascript            : Eck29-ioBroker                           - disabled
          system.adapter.km200.0                  : km200                 : Eck29-ioBroker                           - disabled
          system.adapter.knx.0                    : knx                   : Eck29-ioBroker                           - disabled, bind: 192.168.1.166
          system.adapter.mydlink.0                : mydlink               : Eck29-ioBroker                           - disabled
          system.adapter.netatmo-crawler.0        : netatmo-crawler       : Eck29-ioBroker                           - disabled
          system.adapter.philips-tv.0             : philips-tv            : Eck29-ioBroker                           - disabled
          system.adapter.ping.0                   : ping                  : Eck29-ioBroker                           - disabled
          system.adapter.rpi2.0                   : rpi2                  : Eck29-ioBroker                           - disabled
          system.adapter.shelly.0                 : shelly                : Eck29-ioBroker                           - disabled, port: 1882, bind: 192.168.1.166
          system.adapter.solarmanpv.0             : solarmanpv            : Eck29-ioBroker                           - disabled
          system.adapter.telegram.0               : telegram              : Eck29-ioBroker                           - disabled, port: 8443, bind: 0.0.0.0
          system.adapter.telegram.1               : telegram              : Eck29-ioBroker                           - disabled, port: 8443, bind: 0.0.0.0
          system.adapter.yahka.0                  : yahka                 : Eck29-ioBroker                           - disabled
          system.adapter.yahka.3                  : yahka                 : Eck29-ioBroker                           - disabled
          system.adapter.yeelight-2.0             : yeelight-2            : Eck29-ioBroker                           - disabled
        + instance is alive
        ioBroker-Repositories
        latest        : http://iobroker.live/repo/sources-dist-latest.json
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.3.5    , installed 6.3.5
        Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
        Adapter    "backitup"     : 2.6.23   , installed 2.6.23
        Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
        Adapter    "deconz"       : 1.3.21   , installed 1.3.21
        Adapter    "easee"        : 1.0.7    , installed 1.0.7
        Adapter    "ems-esp"      : 1.30.0   , installed 1.30.0
        Adapter    "hmip"         : 1.20.0   , installed 1.20.0
        Adapter    "hs100"        : 2.1.2    , installed 2.1.2
        Adapter    "hue"          : 3.9.3    , installed 3.9.3
        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
        Adapter    "info"         : 1.9.26   , installed 1.9.26
        Adapter    "javascript"   : 7.0.3    , installed 7.0.3
        Controller "js-controller": 4.0.24   , installed 4.0.24
        Adapter    "km200"        : 2.0.3    , installed 2.0.3
        Adapter    "knx"          : 2.0.17   , installed 2.0.18
        Adapter    "mydlink"      : 1.3.1    , installed 1.3.1
        Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
        Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
        Adapter    "ping"         : 1.5.3    , installed 1.5.3
        Adapter    "shelly"       : 6.4.1    , installed 6.4.1
        Adapter    "solarmanpv"   : 0.5.0    , installed 0.5.0
        Adapter    "telegram"     : 1.15.6   , installed 1.15.6
        Adapter    "yahka"        : 0.17.0   , installed 1.0.3
        Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
        Objects and States
        Objects:        10835
        States:         8894
        W: GPG error: https://repos.influxdata.com/debian stretch InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        E: The repository 'https://repos.influxdata.com/debian stretch InRelease' is not signed.
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1976       520/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       11831      483/iobroker.js-con
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13090      483/iobroker.js-con
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      110        14143      482/influxd
        tcp6       0      0 :::3000                 :::*                    LISTEN      111        17439      1086/grafana
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11971      718/io.admin.0
        tcp6       0      0 :::8086                 :::*                    LISTEN      110        13070      482/influxd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          1978       520/sshd: /usr/sbin
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13075      1085/dhcpcd
        udp        0      0 0.0.0.0:33986           0.0.0.0:*                           108        12956      365/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12954      365/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        12955      365/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          15989      1085/dhcpcd
        udp6       0      0 :::33322                :::*                                108        12957      365/avahi-daemon: r
        2023-07-16 19:15:01.139  - info: admin.0 (718) Repository received successfully.
        2023-07-16 19:15:04.078  - info: backitup.0 (849) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.1, js-controller: 4.0.24
        2023-07-16 19:15:04.231  - info: backitup.0 (849) [iobroker] backup will be activated at 03:30 every 1 day(s)
        2023-07-16 19:15:06.143  - info: admin.0 (718) ==> Connected system.user.admin from ::ffff:192.168.1.152
        2023-07-16 19:15:07.139  - info: admin.0 (718) ==> Connected system.user.admin from ::ffff:192.168.1.152
        2023-07-16 19:15:29.199  - info: admin.0 (718) <== Disconnect system.user.admin from ::ffff:192.168.1.152
        2023-07-16 19:15:29.219  - info: admin.0 (718) ==> Connected system.user.admin from ::ffff:192.168.1.152
        2023-07-16 19:15:30.195  - info: admin.0 (718) <== Disconnect system.user.admin from ::ffff:192.168.1.152 admin
        2023-07-16 19:15:30.241  - info: admin.0 (718) ==> Connected system.user.admin from ::ffff:192.168.1.152
        2023-07-16 19:17:19.238  - info: admin.0 (718) <== Disconnect system.user.admin from ::ffff:192.168.1.152
        2023-07-16 19:17:25.259  - info: admin.0 (718) <== Disconnect system.user.admin from ::ffff:192.168.1.152 admin
        2023-07-16 19:17:29.372  - info: admin.0 (718) ==> Connected system.user.admin from ::ffff:192.168.1.152
        2023-07-16 19:17:30.353  - info: admin.0 (718) ==> Connected system.user.admin from ::ffff:192.168.1.152
        2023-07-16 19:19:32.882  - info: admin.0 (718) <== Disconnect system.user.admin from ::ffff:192.168.1.152 admin
        2023-07-16 19:19:32.887  - info: admin.0 (718) <== Disconnect system.user.admin from ::ffff:192.168.1.152
        2023-07-16 20:19:27.316  - info: admin.0 (718) ==> Connected system.user.admin from ::ffff:192.168.1.152
        2023-07-16 20:19:27.344  - info: admin.0 (718) ==> Connected system.user.admin from ::ffff:192.168.1.152
        2023-07-16 20:20:27.788  - info: admin.0 (718) <== Disconnect system.user.admin from ::ffff:192.168.1.152
        2023-07-16 20:20:27.800  - info: admin.0 (718) <== Disconnect system.user.admin from ::ffff:192.168.1.152 admin
        2023-07-16 20:20:27.931  - info: admin.0 (718) ==> Connected system.user.admin from ::ffff:192.168.1.152
        2023-07-16 20:20:27.958  - info: admin.0 (718) ==> Connected system.user.admin from ::ffff:192.168.1.152
        2023-07-16 20:21:27.915  - info: admin.0 (718) <== Disconnect system.user.admin from ::ffff:192.168.1.152 admin
        2023-07-16 20:21:27.924  - info: admin.0 (718) <== Disconnect system.user.admin from ::ffff:192.168.1.152
        2023-07-16 22:36:18.904  - info: admin.0 (718) ==> Connected system.user.admin from ::ffff:192.168.1.152
        2023-07-16 22:36:18.967  - info: admin.0 (718) ==> Connected system.user.admin from ::ffff:192.168.1.152
          Thomas Braun Most Active @loverz last edited by
          @loverz
          Wie vermutet. Das influx-Repo ist für 'stretch' angelegt, du fährst aber 'bullseye'. Und der key ist auch nicht richtig. Man buddelt auch keine mehrere Jahre alten Anleitungen aus dem Netz.
            @thomas-braun okay, dann installiere ich alles nochmal neu und versuche eine neue Anleitung zu finden. Würde am liebsten gerne direkt influxDB v2 verwenden, aber das macht es wahrscheinlich noch komplexer.
            Ist bei Grafana das gleiche Problem vorhanden, oder wieso stellt er die nicht wieder her? Oder meintest du dass der Grafana Key falsch ist?
              @loverz
              Mach es so:
              sudo rm /etc/apt/sources.list.d/infl*
              wget -q https://repos.influxdata.com/influxdata-archive_compat.key
              echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
              echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
              rm influxdata-archive_compat.key
              sudo apt update
              apt policy influx*
                @thomas-braun also komplett neu installieren und dann das hier ausführen?Danach dann den Restore von Backitup?
                  Wer sagt denn das? Du sollst nur das falsche Repo da aus dem System kratzen.
                    @thomas-braun weil du meintest dass ich keine alten Anleitungen nutzen soll. Dachte das ist nun der aktuelle Befehl um Influx zu installieren.
                    Ich hab nun die Befehle von dir ausgeführt und danach nochmal des Restore probiert. Leider klappt es weiterhin nicht.
                    Diese Kommandozeile-Zeugs liegt mir einfach nicht. Ich hab da 0 Ahnung leider.
                    Hast du vielleicht die Tage mal Zeit mit mir zusammen den neuen Raspberry einzurichten? Am besten per Bildschirmfreigabe?
                    Ich brauche eigentlich nur einen neuen Raspberry mit:
                    -ioBroker
                    -InfluxDB (vielleicht gleich v2)
                    -Grafana
                    und die Datensicherungen davon.
                    Optional dann:
                    -Phoscon
                    -Homebridge
                    ebenfalls mit Datensicherungen.
                      Thomas Braun Most Active @loverz last edited by Thomas Braun
                      Nein. Und schon gar nicht per Remote Desktop.
                      Was sagt denn nun
                      sudo apt update
                        Hit:1 http://deb.debian.org/debian bullseye InRelease
                        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                        Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
                        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
                        Hit:6 https://packages.grafana.com/oss/deb stable InRelease
                        Hit:7 https://repos.influxdata.com/debian stable InRelease
                        Fetched 48.4 kB in 2s (24.0 kB/s)
                        Reading package lists... Done
                        Building dependency tree... Done
                        1 package can be upgraded. Run 'apt list --upgradable' to see it.
                        pi@Eck29-ioBroker:~ $
                          @loverz
                          Jetzt passt es.
                          Noch
                          sudo apt full-upgrade
                          apt policy influxdb*
                          ausführen.
                          T L 2 Replies Last reply Reply Quote 0
                            TT-Tom @Thomas Braun last edited by
                            @loverz
                            Bei Influxdb musst du wieder Version 1 nehmen, sonst passt dein Backup nicht. Es gibt die Möglichkeit von 1 auf 2 zu migrieren, aber erst wenn V1 läuft.
                              @thomas-braun jetzt hat er knapp 10 Minuten "rumgeorgelt" aber die Influx Datenbank scheint noch immer leer zu sein:
                              Hab den Restore via Backitup wiederholt:
                              Started restore ...
                              [DEBUG] [influxDB] - Created tmp directory
                              [DEBUG] [influxDB] - Start infuxDB Restore ...
                              [DEBUG] [influxDB] - influxdb.0 is stopped
                              [ERROR] [influxDB] - 2023/07/24 21:24:28 error updating meta: DB metadata not changed. database may already exist
                              restore: DB metadata not changed. database may already exist
                              [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
                              [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
                              [DEBUG] [influxDB] - infuxDB Restore completed successfully
                              [EXIT] influxDB restore done
                              [DEBUG] [influxDB] - influxdb.0 started
                              1148
