    4. Node-Red lädt Nodes beim Starten nicht mehr
      cfau @mickym last edited by
      @mickym said in Node-Red lädt Nodes beim Starten nicht mehr:
      Danke für die schnelle Antwort!
      iob diag
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Architecture    : aarch64
      Docker          : false
      Virtualization  : none
      Distributor ID: Raspbian
      Description:    Raspbian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
       23:06:18 up  9:37,  1 user,  load average: 0.28, 0.32, 0.29
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=64.2'C
      volt=0.9260V
      *** Time and Time Zones ***
                     Local time: Tue 2023-07-18 23:06:18 CEST
                 Universal time: Tue 2023-07-18 21:06:18 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm tty uucp dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            7.8G        958M        5.0G        1.0M        1.8G        6.7G
      Swap:            99M          0B         99M
      Total:          7.9G        958M        5.1G
               7823 M total memory
                958 M used memory
               1235 M active memory
               1338 M inactive memory
               5017 M free memory
                200 M buffer memory
               1646 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      Filesystem            Type      Size  Used Avail Use% Mounted on
      /dev/root             ext4       29G   14G   15G  48% /
      devtmpfs              devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs                 tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs                 tmpfs     1.6G  920K  1.6G   1% /run
      tmpfs                 tmpfs     5.0M  4.0K  5.0M   1% /run/lock
      /dev/sda1             vfat      253M   51M  202M  20% /boot
      //192.168.2.111/homes cifs       11T  2.3T  8.3T  22% /media/NAS
      tmpfs                 tmpfs     783M   24K  783M   1% /run/user/1000
      [Tue Jul 18 13:29:16 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:EA:D1:8C vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=c85e32c5-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Tue Jul 18 13:29:18 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Tue Jul 18 13:29:18 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Tue Jul 18 13:29:20 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET       SOURCE                FSTYPE OPTIONS
      /            /dev/sda2             ext4   rw,noatime
      |-/boot      /dev/sda1             vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      `-/media/NAS //192.168.2.111/homes cifs   rw,nosuid,nodev,noexec,relatime,vers=3.1.1,cache=strict,username=backup,domain=192.168.2.111,uid=1000,noforceuid,gid=1000,noforcegid,addr=192.168.2.111,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
      /var:
      4.0G    /var/
      3.0G    /var/log/journal/45677fd33dca4b97838c0214e7692911
      3.0G    /var/log
      822M    /var/cache
      Archived and active journals take up 2.9G in the file system.
      /opt/iobroker/backups:
      105M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.4G    /opt/iobroker/iobroker-data/
      621M    /opt/iobroker/iobroker-data/files
      558M    /opt/iobroker/iobroker-data/node-red
      543M    /opt/iobroker/iobroker-data/node-red/node_modules
      403M    /opt/iobroker/iobroker-data/files/vis-2-beta
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      31M     /opt/iobroker/iobroker-data/objects.jsonl
      11M     /opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/typescript/lib/tsserverlibrary.js
      11M     /opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/typescript/lib/tsserver.js
      11M     /opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typescript/lib/tsserverlibrary.js
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.16.1
      /usr/bin/node           v18.16.1
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Installed: 18.16.1-deb-1nodesource1
        Candidate: 18.16.1-deb-1nodesource1
        Version table:
       *** 18.16.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      MULTIHOSTSERVICE/enabled: false
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     7.0.3
      Adapters from github:   1
      Adapter State
      + system.adapter.admin.0                  : admin                 : IOBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        system.adapter.alias-manager.0          : alias-manager         : IOBroker                                 - disabled
      + system.adapter.backitup.0               : backitup              : IOBroker                                 -  enabled
      + system.adapter.bmw.0                    : bmw                   : IOBroker                                 -  enabled
      + system.adapter.cul.0                    : cul                   : IOBroker                                 -  enabled, port: 23
      + system.adapter.denon.0                  : denon                 : IOBroker                                 -  enabled
        system.adapter.devices.0                : devices               : IOBroker                                 - disabled
      + system.adapter.discovery.0              : discovery             : IOBroker                                 -  enabled
      + system.adapter.enocean.0                : enocean               : IOBroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : IOBroker                                 -  enabled
        system.adapter.info.0                   : info                  : IOBroker                                 - disabled
      + system.adapter.javascript.0             : javascript            : IOBroker                                 -  enabled
      + system.adapter.klf200.0                 : klf200                : IOBroker                                 -  enabled
      + system.adapter.knx.0                    : knx                   : IOBroker                                 -  enabled, bind: 192.168.3.195
      + system.adapter.kodi.0                   : kodi                  : IOBroker                                 -  enabled, port: 9090
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : IOBroker                                 - disabled, port: 54321
      + system.adapter.node-red.0               : node-red              : IOBroker                                 -  enabled, port: 1880, bind: 192.168.3.195
      + system.adapter.rpi2.0                   : rpi2                  : IOBroker                                 -  enabled
      + system.adapter.sonos.0                  : sonos                 : IOBroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : IOBroker                                 -  enabled
        system.adapter.vis-2-beta.0             : vis-2-beta            : IOBroker                                 - disabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : IOBroker                                 -  enabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : IOBroker                                 -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: IOBroker                                 -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : IOBroker                                 - disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : IOBroker                                 - disabled
        system.adapter.vis.0                    : vis                   : IOBroker                                 - disabled
        system.adapter.web.0                    : web                   : IOBroker                                 - disabled, port: 8082, bind: 192.168.3.195, run as: admin
      + system.adapter.zigbee.1                 : zigbee                : IOBroker                                 -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_fa8660cd8e93eb11a22f214f3d98b6d1-if00-port0
      + instance is alive
      ioBroker-Repositories
      Latest (possibly unstable): http://download.iobroker.net/sources-dist-latest.json
      Stable        : http://download.iobroker.net/sources-dist.json
      Active repo(s): Stable
      Installed ioBroker-Instances
      Used repository: Stable
      Adapter    "admin"        : 6.3.5    , installed 6.3.5
      Adapter    "alias-manager": 1.2.4    , installed 1.2.4
      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
      Adapter    "bmw"          : 2.5.7    , installed 2.5.7
      Adapter    "cul"          : 2.2.0    , installed 2.2.0
      Adapter    "denon"        : 1.15.2   , installed 1.15.2
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "info"         : 1.9.26   , installed 1.9.26
      Adapter    "javascript"   : 7.0.3    , installed 7.0.3
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Adapter    "klf200"       : 1.0.1    , installed 1.0.1
      Adapter    "knx"          : 2.0.17   , installed 2.0.17
      Adapter    "kodi"         : 2.0.9    , installed 2.0.9
      Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
      Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
      Adapter    "openweathermap": 0.3.9   , installed 0.3.9
      Adapter    "sonos"        : 2.3.1    , installed 2.3.1
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "viessmannapi" : 2.0.9    , installed 2.0.9
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
      Adapter    "zigbee"       : 1.8.16   , installed 1.8.16
      Objects and States
      Objects:        5840
      States:         4086
      Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 http://ftp.debian.org/debian bullseye-backports InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists...
      Pending Updates: 3
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          16464      634/vncserver-x11-c
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1705       643/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       1693       481/deCONZ
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       1750       481/deCONZ
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15625      621/cupsd
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1068677    4205/iobroker.js-co
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1069394    4205/iobroker.js-co
      tcp        0      0 192.168.3.195:1880      0.0.0.0:*               LISTEN      1001       1287019    314/node-red
      tcp6       0      0 :::5900                 :::*                    LISTEN      0          16463      634/vncserver-x11-c
      tcp6       0      0 :::22                   :::*                    LISTEN      0          1707       643/sshd: /usr/sbin
      tcp6       0      0 :::3500                 :::*                    LISTEN      1001       1072229    4753/io.sonos.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1070137    4284/io.admin.0
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15624      621/cupsd
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1763       835/dhcpcd
      udp        0      0 0.0.0.0:33215           0.0.0.0:*                           108        15017      475/avahi-daemon: r
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15713      646/cups-browsed
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15015      475/avahi-daemon: r
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       1753       481/deCONZ
      udp        0      0 192.168.3.195:35494     0.0.0.0:*                           1001       1072521    5045/io.knx.0
      udp6       0      0 :::5353                 :::*                                108        15016      475/avahi-daemon: r
      udp6       0      0 :::47211                :::*                                108        15018      475/avahi-daemon: r
      2023-07-18 22:56:08.764  - info: bmw.0 (4914) Got terminate signal TERMINATE_YOURSELF
      2023-07-18 22:56:08.766  - info: bmw.0 (4914) terminating
      2023-07-18 22:56:08.768  - info: bmw.0 (4914) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-07-18 22:56:08.851  - info: host.IOBroker stopInstance system.adapter.bmw.0 send kill signal
      2023-07-18 22:56:09.359  - info: host.IOBroker instance system.adapter.bmw.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-07-18 22:56:09.594  - info: admin.0 (4284) <== Disconnect system.user.admin from ::ffff:192.168.2.202
      2023-07-18 22:56:11.944  - info: host.IOBroker instance system.adapter.bmw.0 started with pid 4609
      2023-07-18 22:56:14.286  - info: bmw.0 (4609) starting. Version 2.5.7 in /opt/iobroker/node_modules/iobroker.bmw, node: v18.16.1, js-controller: 4.0.24
      2023-07-18 22:56:15.080  - info: bmw.0 (4609) Start getting mini vehicles
      2023-07-18 22:56:15.440  - error: bmw.0 (4609) getvehicles v2 failed
      2023-07-18 22:56:15.442  - error: bmw.0 (4609) AxiosError: Request failed with status code 404
      2023-07-18 22:56:15.442  - error: bmw.0 (4609) {"statusCode":404,"message":"Resource not found"}
      2023-07-18 22:56:52.797  - info: admin.0 (4284) ==> Connected system.user.admin from ::ffff:192.168.2.202
      2023-07-18 22:57:00.765  - warn: zigbee.1 (4642) DeviceAvailability:Stopping to ping 0x00158d00079a90b9 500.46 after 109 ping attempts
      2023-07-18 23:00:00.004  - info: javascript.0 (4331) script.js.Zentrale_Funktionen.HCL_Helligkeit_nach_Zeit: Variable Helligkeit: 40
      2023-07-18 23:00:00.006  - info: javascript.0 (4331) script.js.Zentrale_Funktionen.HCL_Farbtemperatur_nach_Zeit: Variable Helligkeit: 2000
      2023-07-18 23:00:05.093  - warn: trashschedule.0 (5136) no events matches type "Restmüll" with match "Restmuell"
      2023-07-18 23:00:05.143  - warn: trashschedule.0 (5136) no events matches type "Papier" with match "Papier"
      2023-07-18 23:00:05.193  - warn: trashschedule.0 (5136) no events matches type "Gelber Sack" with match "gelber Sack"
      2023-07-18 23:01:20.520  - error: bmw.0 (4609) getvehicles v2 failed
      2023-07-18 23:01:20.522  - error: bmw.0 (4609) AxiosError: Request failed with status code 404
      2023-07-18 23:01:20.523  - error: bmw.0 (4609) {"statusCode":404,"message":"Resource not found"}
      2023-07-18 23:06:20.518  - error: bmw.0 (4609) getvehicles v2 failed
      2023-07-18 23:06:20.519  - error: bmw.0 (4609) AxiosError: Request failed with status code 404
      2023-07-18 23:06:20.520  - error: bmw.0 (4609) {"statusCode":404,"message":"Resource not found"}
        Nutzt den paletten-Manager.
        Den nehm ich normalerweise auch, nur komm ich da z.Zt. eben nicht mehr ran. 😞
        • mickym
          mickym Most Active @cfau last edited by
          @cfau Nun das einfachste ist erst mal den Node-Red Adapter im Sicherheitsmodus zu starten. Versuch das mal. Wenn das nicht geht - dann ist die Frage, ob Du NodeRed mit dem Backup Adapter gesichert hast?
            cfau @mickym last edited by cfau
            Keine Änderung
            hab auch schon den letzten Export von flows.json nach /opt/iobroker/iobroker-data/node-red zurückgeschrieben, auch das bringt nichts.
            • mickym
              @cfau Nochmal hast Du eine Sicherung von NodeRed im Backitup-Adapter?
              C 2 Replies Last reply Reply Quote 0
                @mickym Sieht nicht so aus (als ich backitup eingerichtet hab, gabs das m.W. noch nicht als Option)
                  @mickym
                  Würde es Sinn machen, auf eine nodejs-version 16.4.x zurückzugehen?
                  • mickym
                    @cfau Ja das ist relativ neu - aber gut dann hast Du es nicht. Nein - das macht keinen Sinn - du musst eh updaten und ich habe keine Probleme.
                    Dann solltest Du zukünftig in jedem Fall das Backup mit aufnehmen.
                    Poste mal deine package.json im Verzeichnis /opt/iobroker/iobroker-data/node-red
                      Hatte ich nach dem Update heute schon erledigt.
                      pi@IOBroker:/opt/iobroker/iobroker-data/node-red $ cat package.json
                        "dependencies": {
                          "node-red-contrib-boolean-logic-ultimate": "~1.0.59",
                          "node-red-contrib-buffer-parser": "~3.2.2",
                          "node-red-contrib-ccu": "~3.4.2",
                          "node-red-contrib-chroma": "~0.0.3",
                          "node-red-contrib-color-convert": "^0.0.8",
                          "node-red-contrib-cul": "0.0.16",
                          "node-red-contrib-deconz": "~2.3.9",
                          "node-red-contrib-enocean": "~0.8.5",
                          "node-red-contrib-influxdb": "~0.6.1",
                          "node-red-contrib-knx-ultimate": "~1.4.13",
                          "node-red-contrib-merge": "~0.1.1",
                          "node-red-contrib-merge-topic": "~0.1.2",
                          "node-red-contrib-schedex": "~1.10.6",
                          "node-red-contrib-sonos-events": "~1.2.1",
                          "node-red-contrib-sonos-plus": "~6.6.1",
                          "node-red-contrib-state": "~1.6.1",
                          "node-red-contrib-string": "~1.0.0",
                          "node-red-contrib-toggle": "~0.1.1",
                          "node-red-contrib-ui-contextmenu": "~2.0.1",
                          "node-red-contrib-zigbee": "~0.21.0",
                          "node-red-dashboard": "~3.3.1",
                          "node-red-node-email": "~1.18.4",
                          "node-red-node-feedparser": "~0.3.0",
                          "node-red-node-tail": "~0.4.0",
                          "node-red-node-ui-table": "~0.4.3"
                      • mickym
                        mickym Most Active @cfau last edited by mickym
                        @cfau ok - dann stoppe mal den Node-Red Adapter. - Irgendwo fehlt zwar in meinen Augen oben was in der Datei. Aber versuchs mal.
                        Benenne Dein node_modules Verzeichnis in dem Node Red Verzeichnis um - und dann lass alles nochmal installieren
                        Bitte kein Sudo und nichts und nur in diesem Verzeichnis
                        /opt/iobroker/iobroker-data/node-red ausführen.
                        Am Besten vorher noch unter der iobroker-Kennung,
                        Also
                        sudo -su iobroker
                        npm install
                          @mickym
                          Das ist das Ergebnis:
                           npm install
                          npm WARN old lockfile
                          npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                          npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                          npm WARN old lockfile This is a one-time fix-up, please be patient...
                          npm WARN deprecated string-similarity@4.0.4: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info.
                          npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                          npm WARN deprecated vis@4.21.0: Please consider using https://github.com/visjs
                          added 641 packages, and audited 687 packages in 2m
                          94 packages are looking for funding
                            run `npm fund` for details
                          27 vulnerabilities (4 low, 14 moderate, 8 high, 1 critical)
                          To address issues that do not require attention, run:
                            npm audit fix
                          To address all issues possible (including breaking changes), run:
                            npm audit fix --force
                          Some issues need review, and may require choosing
                          a different dependency.
                          Run `npm audit` for details.
                          mikeal created this issue in request/request
                          open Request’s Past, Present and Future #3142
                          • mickym
                            @cfau Ok die package-lock.json - kannst du löschen oder weg sichern. Aber es wurde ja nun neu aufgebaut. Startet nun Dein NodeRed Adapter wieder ?
                            Das andere kannst ignorieren.
                              @mickym
                              Das wars, der Editor wird wieder gestartet: MERCI!!!!!
                              Soll ich noch die vorgeschlagenen Fixes durchlaufen lassen?
                              • mickym
                                @cfau Nein mach das nicht - schau in den Paletten-Manager und schau, welche Nodes aktualisiert werden müssen. Wie gesagt lösch noch die package-lock.json - die wird dann wieder neu angelegt, wenn was neu installiert wird.
                                  @mickym
                                  Erledigt, auch nach dem Update der Module läuft alles wieder!
                                  Vielen Dank!!!!
                                  node-red enocean
                                  1192
