    4. Probleme mit HomeMatic RPC
      sunny9999 last edited by
      Servus,
      seit ca. 1 Woche auch selbes Problem....
      Nach Update auf Node.js v18.16.1
      hm-rpc.0
      2023-07-20 07:09:39.961	info	new HMIP devices/channels after filter: 0
      hm-rpc.0
      2023-07-20 07:09:39.914	info	xmlrpc <- newDevices 135
      hm-rpc.0
      2023-07-20 07:09:39.722	info	xmlrpc -> 0 devices
      hm-rpc.0
      2023-07-20 07:09:39.676	info	xmlrpc <- listDevices ["IOBROKER:hm-rpc.0:f2527166436f6b3475572711cd4879fa"]
      hm-rpc.0
      2023-07-20 07:09:39.641	info	Connected
      hm-rpc.0
      2023-07-20 07:09:39.606	info	xmlrpc client is trying to connect to 192.168.30.22:2010/ with ["http://192.168.30.16:2010","IOBROKER:hm-rpc.0:f2527166436f6b3475572711cd4879fa"]
      hm-rpc.0
      2023-07-20 07:09:39.606	info	xmlrpc server is trying to listen on 192.168.30.16:2010
      hm-rpc.0
      2023-07-20 07:09:39.456	info	starting. Version 1.15.18 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.16.1, js-controller: 4.0.24
      hm-rpc.0
      2023-07-20 07:09:08.005	info	Terminated (NO_ERROR): Without reason
      hm-rpc.0
      2023-07-20 07:09:08.005	info	terminating
      hm-rpc.0
      2023-07-20 07:09:08.004	error	Cannot call init: [http://192.168.30.16:2010, ""] Unexpected end Line: 0 Column: 0 Char:
      hm-rpc.0
      2023-07-20 07:09:07.993	info	xmlrpc -> 192.168.30.22:2010/ init ["http://192.168.30.16:2010",""]
      hm-rpc.0
      2023-07-20 07:09:07.992	error	Init not possible, going to stop: Unexpected end Line: 0 Column: 0 Char:
      hm-rpc.0
      2023-07-20 07:08:37.993	error	Init not possible, going to stop: Unexpected end Line: 0 Column: 0 Char:
      hm-rpc.0
      2023-07-20 07:08:07.976	info	Disconnected
      hm-rpc.0
      2023-07-20 07:08:07.976	error	Ping error [IOBROKER:hm-rpc.0:65c87fdf10e9c7b9cb3cd1afde10f6d1]: Unexpected end Line: 0 Column: 0 Char:
      hm-rpc.0
      2023-07-20 07:06:37.957	info	Connected
      hm-rpc.0
      2023-07-20 07:06:27.847	info	Disconnected
      hm-rpc.0
      2023-07-20 07:06:27.847	error	Ping error [IOBROKER:hm-rpc.0:65c87fdf10e9c7b9cb3cd1afde10f6d1]: Unexpected end Line: 0 Column: 0 Char:
      hm-rpc.0
      2023-07-20 07:04:57.831	info	Connected
      hm-rpc.0
      2023-07-20 07:04:33.496	info	Disconnected
      hm-rpc.0
      2023-07-20 07:04:33.495	error	Ping error [IOBROKER:hm-rpc.0:65c87fdf10e9c7b9cb3cd1afde10f6d1]: Unexpected end Line: 0 Column: 0 Char:
      Alle 1-2 Stunden restartet der Adapter.....
      Sunny
        Str_n last edited by
        Das Problem lässt sich übrigens stabil reproduzieren, indem man die ping Zeit in den Adaptereinstellungen auf 10 Sekunden stellt. Nach ein paar Minuten ist es dann immer wieder da.
        Starte ich mit einem 2 Wochen alten Backup ist alles ok. Leider habe ich zu viel in der Zwischenzeit geupdated um noch nachzuvollziehen wer der Übeltäter war.
          ticaki Developer last edited by
          @teletapi
          Proxmox ist sowas wie docker nur das es den ganzen Rechner kontrolliert und darauf läuft unter anderem auch iobroker.
          • Feuersturm
            Feuersturm last edited by
            Hat jemand auch das Problem mit einer Node.js Version ungleich v18.16.1?
            Die 18.16.1 ist glaub ich relativ frisch.
            F Thomas Braun 2 Replies Last reply Reply Quote 0
              Farmer-cb @Feuersturm last edited by
              @feuersturm sagte in Probleme mit HomeMatic RPC:
              Node.js v16.20.0 (Es gibt eine neuere Version: v16.20.1 - Empfohlene Version v18.17.0)
                Thomas Braun Most Active @Feuersturm last edited by
                Und bereits durch 18.17.0 abgelöst.
                  Homoran Global Moderator Administrators @teletapi last edited by Homoran
                  @teletapi sagte in Probleme mit HomeMatic RPC:
                  Das ist so nicht ganz richtig
                  Ich hatte...
                  aber das ist
                  @homoran sagte in Probleme mit HomeMatic RPC:
                  keine allgemeingültige Übereinstimmungen bei allen Betroffenen.
                  teletapi 1 Reply Last reply Reply Quote 0
                  • teletapi
                    teletapi @Homoran last edited by
                    Bisher hatte ich keine weiteren Fehler nachdem ich das Backup (komplette Sicherung der Festplatte) drauf gezogen und gestern das Update auf die Node.js 18.7.0 und NPM 9.6.7 gemacht habe.
                    Host ist jetzt immer noch 5.0.6
                    iob Diag(2).txt
                    Im laufe des Tages werde ich aber auf meiner Ersatzplatte das gleiche machen und nochmal den Host auf 5.0.8 draufziehen m,al schauen was sich dann tut
                      das Problem tritt auch bei Usern mit host v4 auf
                      • teletapi
                        teletapi @Homoran last edited by teletapi
                        @homoran said in Probleme mit HomeMatic RPC:
                        das könnte meine Vermutung stützen das ein Adapter mit verantwortlich ist
                        Wobei ich das jetzt hier nur einmal gelesen habe das die V4.XX betroffen ist
                        Die V4.XXX war bei mir ebenfalls betroffen aber nur wenn ich ein Downgrade von der 5.0.8 durchgeführt habe
                        Jetzt gerade habe ich eine 2te M.2 Festplatte mit meiner alten Sicherung beschrieben und alle Updates durchgeführt also ebenfalls neuster Stand und mache jetzt nochmal den Host 5.0.8 drauf mal schauen was dann kommt
                        Diesmal werde ich das Update des Host mal so probieren
                          Vermutungen hatte ich auch, bis nach und nach jede einzelne davon von den Fakten bei anderen Usern widerlegt wurde.
                          Es muss ja etwas sein, das für alle gilt.
                          • teletapi
                            Und schon sind die fehler wieder da.
                              das ist ja unstrittig!
                              aber
                              @ma sagte in Probleme mit HomeMatic RPC:
                              bin auf 4.0.24 (nie auf 5.x.x gewesen)
                              ...und bei anderen tauchte das Problem "vor ein paar Tagen" auf, ohne dass "irgendwas verändert" wurde.
                                rascal last edited by
                                Ich habe, bevor die Probleme anfingen, auf nodejs 18 und den aktuellen Host ge-updated, auf einem Ubuntu System.
                                Jetzt habe ich einen Rasp 4 mit Ubuntu aufgesetzt, iobroker installiert und ein Backup mit Host 5.0.7 eingespielt.
                                Es ist npm 9.2.0 und nodejs 18.13.0 drauf.
                                Nach ein paar "Umzugsschwierigkeiten" läuft das System einmal ohne großartige Fehler.
                                • Feuersturm
                                  Stellt doch einmal eure Instanz auf debug log Level. Vielleicht bekommen wir darüber noch etwas raus.
                                  Auf meiner raspberrymatic (unter proxmox) läuft die Version 3.69.7.20230626
                                    rascal @rascal last edited by
                                    Ich habe wieder ein paar Fehlermeldunge....
                                    Zeit
                                    error
                                    Nachricht
                                    hm-rpc.2
                                    2023-07-20 12:31:41.339	error	Cannot call init: [http://192.168.1.226:2010, ""] Unexpected endLine: 0Column: 0Char:
                                    hm-rpc.2
                                    2023-07-20 12:31:41.323	error	Init not possible, going to stop: Unexpected endLine: 0Column: 0Char:
                                    hm-rpc.2
                                    2023-07-20 12:31:11.325	error	Init not possible, going to stop: Unexpected endLine: 0Column: 0Char:
                                    hm-rpc.2
                                    2023-07-20 12:30:41.305	error	Ping error [iobroker:hm-rpc.2:fb3416f7897b52e870029128aa102b2e]: Unexpected endLine: 0Column: 0Char:
                                    hm-rpc.2
                                    2023-07-20 12:30:15.451	error	Cannot call setValue: Unexpected endLine: 0Column: 0Char:
                                    hm-rpc.2
                                    2023-07-20 12:30:15.449	error	xmlrpc -> setValue ["001118A9A58F1B:4","LEVEL",0] FLOAT
                                    hm-rpc.2
                                    2023-07-20 12:30:13.448	error	Cannot call setValue: Unexpected endLine: 0Column: 0Char:
                                    hm-rpc.2
                                    2023-07-20 12:30:13.447	error	xmlrpc -> setValue ["00111A49A8DE25:4","LEVEL",0] FLOAT
                                    hm-rpc.2
                                    2023-07-20 12:30:09.450	error	Cannot call setValue: Unexpected endLine: 0Column: 0Char:
                                    hm-rpc.2
                                    2023-07-20 12:30:09.449	error	xmlrpc -> setValue ["00111D89AB034E:4","LEVEL",0] FLOAT
                                    hm-rpc.2
                                    2023-07-20 12:29:57.679	error	Cannot call setValue: Unexpected endLine: 0Column: 0Char:
                                    hm-rpc.2
                                    2023-07-20 12:29:57.678	error	xmlrpc -> setValue ["001118A9925408:4","LEVEL",0] FLOAT
                                    hm-rpc.2
                                    2023-07-20 12:29:56.675	error	Cannot call setValue: Unexpected endLine: 0Column: 0Char:
                                    hm-rpc.2
                                    2023-07-20 12:29:56.674	error	xmlrpc -> setValue ["001118A9A58F1B:4","LEVEL",0] FLOAT
                                    hm-rpc.2
                                    2023-07-20 12:29:54.684	error	Cannot call setValue: Unexpected endLine: 0Column: 0Char:
                                    hm-rpc.2
                                    2023-07-20 12:29:54.683	error	xmlrpc -> setValue ["00111A49A8DE25:4","LEVEL",0] FLOAT
                                    das sind alles HM-IP Rolladenaktoren, die Datenpunkte sind allerdings vorhanden und die Rolläden werden auch gefahren, trotz der Fehlermeldungen.
                                      Lucky_ESA Developer Most Active last edited by Lucky_ESA
                                      könnt ihr mal Sentry für die netroffenen Instanzen deaktivieren.
                                      Ich habe seit dem kein Problem mehr...Kann aber auch Zufall sein. Bei mir kam das Thema mit einem Update auf 5.0.8.
                                      Edit:
                                      Wer nicht weiß wie es geht. Den grünen Button drücken:
                                      Gruß//Lucky
                                      D S Feuersturm M T 6 Replies Last reply Reply Quote 3
                                        darkiop Most Active @Lucky_ESA last edited by
                                        @lucky_esa
                                        Kann ich bestätigen.
                                        js-controller 5.0.8
                                        npm 9.6.7
                                        node 18.17.0
                                          Str_n @Lucky_ESA last edited by
                                          @lucky_esa
                                          Das sieht gut aus bei mir. Habe die Ping Zeit im Adapter auf 10 Sekunden gestellt. Nach spätestens 5 Minuten ist der Fehler dann da. Mit deaktiviertem Sentry scheint der Fehler nicht mehr zu kommen.
                                            darkiop Most Active last edited by
                                            Klingt nach einen Fall für Ingo 🙂 @apollon77
                                            168
                                            18863
