    4. [Adapter] cloudfreie Auslesung von Deye-Invertern
    • Eduard77
      Eduard77 @Rene55 last edited by Eduard77
      @rene55
      guten Abend. Ich habe gestern Adapter installiert und mit meiner Deye angebunden.
      Es läuft so weit und es werden die Werte übertragen.
      Allerdings habe ich im Log Warnungen.
      2023-07-11 19:14:35.776 - warn: deyeidc.0 (579) ControlCode faulty!: Data may be corrupt, therefore discarded
      2023-07-11 19:15:57.216 - info: admin.0 (301) ==> Connected system.user.admin from ::ffff:192.168.178.31
      2023-07-11 19:16:35.826 - warn: deyeidc.0 (579) ControlCode faulty!: Data may be corrupt, therefore discarded
      2023-07-11 19:22:41.922 - warn: deyeidc.0 (579) ControlCode faulty!: Data may be corrupt, therefore discarded
      2023-07-11 19:25:54.214 - info: web.0 (433) ==> Connected system.user.admin from ::ffff:192.168.178.31
      2023-07-11 19:25:57.671 - info: admin.0 (301) <== Disconnect system.user.admin from ::ffff:192.168.178.31 admin
      2023-07-11 19:26:03.737 - info: web.0 (433) <== Disconnect system.user.admin from ::ffff:192.168.178.31 vis.0
      2023-07-11 19:26:04.013 - info: web.0 (433) ==> Connected system.user.admin from ::ffff:192.168.178.31
      2023-07-11 19:32:31.814 - info: web.0 (433) ==> Connected system.user.admin from ::ffff:192.168.178.31
      2023-07-11 19:32:36.894 - info: web.0 (433) <== Disconnect system.user.admin from ::ffff:192.168.178.31 vis.0
      2023-07-11 19:33:44.953 - info: web.0 (433) ==> Connected system.user.admin from ::ffff:192.168.178.31
      2023-07-11 19:33:48.695 - warn: web.0 (433) Read-only state "deyeidc.0.3942394996.Apo_t1" has been written without ack-flag with value "0"
      2023-07-11 19:33:58.649 - warn: web.0 (433) Read-only state "deyeidc.0.3942394996.Etdy_ge0" has been written without ack-flag with value "0"
      2023-07-11 19:34:05.304 - info: web.0 (433) <== Disconnect system.user.admin from ::ffff:192.168.178.31 vis.0
      2023-07-11 19:34:05.990 - info: web.0 (433) ==> Connected system.user.admin from ::ffff:192.168.178.31
      2023-07-11 19:34:17.289 - info: web.0 (433) <== Disconnect system.user.admin from ::ffff:192.168.178.31 vis.0
      2023-07-11 19:34:17.958 - info: web.0 (433) ==> Connected system.user.admin from ::ffff:192.168.178.31
      2023-07-11 19:36:23.481 - warn: web.0 (433) Read-only state "deyeidc.0.3942394996.Apo_t1" has been written without ack-flag with value "90"
      Was kann ich dagegen machen?
      • Rene55
        @edis77 Von diesen Warnungen hatte ich heute -im gegensatz zu anderen Tagen - sehr viele. Dieser Controllcode wird im WR berechnet und hängt von ... keine Ahnung was ab. Erst mal ignorieren und morgen noch mal schauen. Ändern kann man daran nichts.
        Eduard77 1 Reply Last reply Reply Quote 0
        • Eduard77
          @rene55 Alles klar.
          habe gerade auch noch meldung von Web.0
          web.0  2023-07-11 19:36:23.481	warn	Read-only state "deyeidc.0.3942394996.Apo_t1" has been written without ack-flag with value "90"
          • Rene55
            Rene55 @Eduard77 last edited by
            @edis77 Bei mir im Log sehe ich vom web.0 überhaupt nichts. (Ich weiß gar nicht, wofür ich web überhaupt brauchen könnte). Machst du sonst noch was mit den Daten vom deyeidc? Visualisierung?
            • Eduard77
              @rene55
              Ich habe in VIS eine kleine Grafik
              • Rene55
                @edis77 Ob die web-Warnungen daher kommen kann ich nicht sagen. Ich bin mir nur sicher, dass ich die States 'has been written without ack-flag' mit ack-Flag schreibe.
                Kannst du die Vis (oder den Teil davon) morgen mal abschalten und berichten?
                  Pino72 last edited by
                  hatte bisher Version 0.0.7 wunderbar am LAufen, habe eben über den Link
                  https://github.com/raschy/ioBroker.deyeidc
                  die 0.0.9 drüberinstalliert, sieht man auch im IOBroker dass er sie installiert hat leider geht der Adapter nicht mehr an, immer wenn ich auf Starten drücke macht er für 1 Sekunde was und stoppt dann wieder??
                  Woran könnte das liegen und wie könnte ich auf 0.0.7 zurück gehen? Im Log sehe ich keine Fehler beim versuchten starten??
                  Plattform
                  Windows
                  Betriebssystem
                  win32
                  Architektur
                  x64
                  CPUs
                  Geschwindigkeit
                  1498 MHz
                  Modell
                  Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
                  RAM
                  7.85 GB
                  System-Betriebszeit
                  00:00:09
                  Node.js
                  v14.18.0 (Es gibt eine neuere Version: v14.21.3 - Empfohlene Version v18.17.0)
                    Thomas Braun Most Active @Pino72 last edited by
                    @pino72 sagte in [neuer Adapter] cloudfreie Auslesung von Deye-Invertern:
                    Node.js
                      Pino72 @Thomas Braun last edited by
                      Jo das wars 🙂
                      Thomas Braun Rene55 2 Replies Last reply Reply Quote 0
                        @pino72
                        Das ist es furchtbar oft. Insbesondere, wenn die fragliche Version auch bereits abgekündigt wurde. Die Hinweise auf Updates stehen nicht zur Zierde da.
                        • Rene55
                          Rene55 @Pino72 last edited by
                          @pino72 Da der Adapter in kürze ins Repository aufgenommen werden soll, musste ich leider node 14.x kicken. So ist halt der Fortschritt.
                            Pino72 @Rene55 last edited by
                            @rene55
                            Alles gut, leider ist IOBroker noch sehr weit weg von einem "Wartungsfreien" System....der Aufwand bei updates gerade auch bei Windows ist schon immer recht groß. SChade, dass das nicht innerhalb der WebUI gemacht werden kann auf Knopfdruck.
                            Der neue Windows Installer könnte da etwas Abhilfe schaffen , leider ist mein System noch mit dem alten aufgesetzt und das passt nicht zusammen.
                              Kann es auch nicht werden, dafür spielen da viel zu viele Komponenten rein.
                              wcag22 1 Reply Last reply Reply Quote 0
                              • wcag22
                                wcag22 @Thomas Braun last edited by
                                @thomas-braun sagte in [neuer Adapter] cloudfreie Auslesung von Deye-Invertern:
                                Richtig. Und dann ist ja auch noch die Frage, was man unter "wartungsfrei" versteht.
                                Selbst mein Auto braucht ab und zu eine Wartung 🙂
                                Updates sind doch normal. Und "sehr weit weg" - naja, das ist wohl eine individuelle Betrachtung
                                Selbst in Windoof gibt es Updates und dass die dann im Hintergrund laufen, ist nicht immer von Vorteil.
                                Genau wie @rene55 schrieb: "So ist halt der Fortschritt."
                                Das Einzige, was man sich zur Not wünschen könnte, dass man vlt. per Mail über vorhandene Updates informiert wird.
                                (Oder gibt es das etwa schon und ich weiß das nicht?)
                                Nicht Jeder wird wie ich die Zeit haben, täglich ioBroker zu kontrollieren/überwachen.
                                • Rene55
                                  Rene55 @wcag22 last edited by
                                  @pi-ter Wenn der Adapter im Repository ist (latest oder stable) gibt ja der ioBroker selbst die Hinweise auf Updates installierter Adapter. Dann wird das alles besser zu handeln sein. Mailkontakt zu den Usern (außer zu dir) habe ich ja nicht und wäre auch etwas aufwändig.
                                  • wcag22
                                    wcag22 @Rene55 last edited by
                                    @rene55 sagte in [neuer Adapter] cloudfreie Auslesung von Deye-Invertern:
                                    Grüß Dich @rene55 🙂
                                    Ja, das ist natürlich richtig. Im Kontext der Aussage "wartungsfreies System" bezog ich mich auch nicht ausschließlich auf Deinen oder einen Adapter, sondern auf ioBroker gesamt.
                                    Ich selbst habe ein ziemlich eingefahrenes Ritual für den frühen Vormittag:
                                    • Mail checken
                                    • Statistik pflegen (diverse Zählerstände)
                                    • Website pflegen
                                    • ioBroker checken
                                    • Kontrolle Lovelace und jarvis
                                    • und etwa im 2- bis 3-Wochentakt via ssh auf OS-Updates checken
                                    Nicht Jeder hat diese zeitliche Freiheit. Für diese Nutzer wäre eine Benachrichtigung aus ioBroker heraus möglicherweise hilfreich.
                                    Was die Adapter angeht: ja. Ich warte auch immer auf stable. 🙂
                                    Klar, das wäre auch schon wieder ein Fall für den deutschen Datenschutz, hihi...
                                    • Rene55
                                      @pi-ter So ein Smart-Home-System wird niemals wartungsfrei sein. Selbst wenn die Software ohne weiteres läuft, fällt mal irgendwo ein Sensor aus oder die Batterie ist leer.
                                      Schön, wenn man so ein morgendliches Ritual hat - und sich auch noch daran hält.
                                      • wcag22
                                        Naja, vorbeugen ist besser, als nach hinten fallen ... oder so. Das ist wie mit der Datensicherung - wo auch immer.
                                        Aus Fehlern darf man ja lernen. 🤷‍♂️
                                          Pino72 @wcag22 last edited by Pino72
                                          Hab das heute mal in den Logs gefunden? Der Adapter wurde auch immer wieder mal als nicht verbunden angezeigt...hat das mit dem schlechten Wetter zu tun wo er wenn zu wenig Sonne scheint die Verbindung verliert?
                                          deyeidc.0
                                          	2023-07-24 14:10:09.092	warn	ControlCode faulty!: Data may be corrupt, therefore discarded
                                          deyeidc.0
                                          	2023-07-24 14:08:09.330	warn	ControlCode faulty!: Data may be corrupt, therefore discarded
                                          deyeidc.0
                                          	2023-07-24 14:06:08.989	warn	ControlCode faulty!: Data may be corrupt, therefore discarded
                                          deyeidc.0
                                          	2023-07-24 14:04:09.274	warn	ControlCode faulty!: Data may be corrupt, therefore discarded
                                          deyeidc.0
                                          	2023-07-24 14:02:07.934	warn	ControlCode faulty!: Data may be corrupt, therefore discarded
                                          deyeidc.0
                                          	2023-07-24 14:00:07.874	warn	ControlCode faulty!: Data may be corrupt, therefore discarded
                                          deyeidc.0
                                          	2023-07-24 13:58:08.175	warn	ControlCode faulty!: Data may be corrupt, therefore discarded
                                          deyeidc.0
                                          	2023-07-24 13:05:18.972	warn	ControlCode faulty!: Data may be corrupt, therefore discarded
                                          deyeidc.0
                                          	2023-07-24 13:03:18.933	warn	ControlCode faulty!: Data may be corrupt, therefore discarded
                                          deyeidc.0
                                          	2023-07-24 13:01:19.223	warn	ControlCode faulty!: Data may be corrupt, therefore discarded
                                          deyeidc.0
                                          	2023-07-24 12:59:10.177	warn	ControlCode faulty!: Data may be corrupt, therefore discarded
                                          deyeidc.0
                                          	2023-07-24 12:57:09.847	warn	ControlCode faulty!: Data may be corrupt, therefore discarded
                                          Rene55 F 2 Replies Last reply Reply Quote 0
                                          • Rene55
                                            @pino72 Auch da sage ich mal: ja. Da hat der Inverter wohl Mühe, aus den Tiefen seiner selbst alle Daten zusammenzubringen. Dann stimmt der Controllcode nicht und die Antwort wird verworfen, bevor im ioBroker Mist angezeigt wird.
                                            1158
                                            365084
