    4. Support Adapter Energiefluss-erweitert v0.7.7
      kiste01 @Homoran last edited by
      Using Instance: energiefluss-erweitert.0
      about:blank:1 An iframe which has both allow-scripts and allow-same-origin for its sandbox attribute can escape its sandboxing.
      functions.min.js:1 Loading config for instance: 0
      functions.min.js:1 Using Icon-Proxy for Icons!
      functions.min.js:1 Loading initial Data.
      functions.min.js:1 Error while receiving icon mdi:cog {"readyState":0,"status":0,"statusText":"timeout"}
      error @ functions.min.js:1
      192.168.178.45/:1     Failed to load resource: net::ERR_CONNECTION_REFUSED
      und debug log
      2023-07-20 11:16:44.315	debug	Using language: de
      2023-07-20 11:16:44.311	info	Requesting the following states: energiefluss-erweitert.0.configuration
      2023-07-20 11:16:44.310	info	Configuration loaded!
      2023-07-20 11:16:44.309	debug	RAW-Source-Values: {}
      2023-07-20 11:16:44.309	debug	RAW-Values: {}
      2023-07-20 11:16:44.309	debug	Sources: {}
      2023-07-20 11:16:44.309	debug	Initial Fill-Values: {}
      2023-07-20 11:16:44.308	debug	Initial Values: {}
      2023-07-20 11:16:44.308	debug	Settings: {}
      2023-07-20 11:16:44.308	debug	CSS: {}
      2023-07-20 11:16:44.307	debug	{}
      2023-07-20 11:16:44.307	warn	This is the first time, the adapter starts. Setting config to default (empty)!
      2023-07-20 11:16:44.304	info	Adapter started. Loading config!
      2023-07-20 11:16:44.274	info	starting. Version 0.0.2-alpha.12 (non-npm: SKB-CGN/ioBroker.energiefluss-erweitert#6de10d4bc13356ed792f93aba489c8ebc8ca7bc6) in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v18.16.0, js-controller: 4.0.24
      2023-07-20 11:16:42.851	debug	States connected to redis: 0.0.0.0:6379
      2023-07-20 11:16:42.847	debug	States create User PubSub Client
      2023-07-20 11:16:42.846	debug	States create System PubSub Client
      2023-07-20 11:16:42.842	debug	Redis States: Use Redis connection: 0.0.0.0:6379
      2023-07-20 11:16:42.718	debug	Objects connected to redis: 0.0.0.0:9001
      2023-07-20 11:16:42.714	debug	Objects client initialize lua scripts
      2023-07-20 11:16:42.444	debug	Objects create User PubSub Client
      2023-07-20 11:16:42.444	debug	Objects create System PubSub Client
      2023-07-20 11:16:42.443	debug	Objects client ready ... initialize now
      2023-07-20 11:16:42.333	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
      2023-07-20 11:16:38.662	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-07-20 11:16:38.662	info	terminating
      2023-07-20 11:16:38.661	info	Cleared interval for relative values!
      2023-07-20 11:16:38.661	info	Got terminate signal TERMINATE_YOURSELF
      2023-07-20 11:16:35.925	debug	Using language: de
      2023-07-20 11:16:35.919	info	Requesting the following states: energiefluss-erweitert.0.configuration
      2023-07-20 11:16:35.919	info	Configuration loaded!
      2023-07-20 11:16:35.918	debug	RAW-Source-Values: {}
      2023-07-20 11:16:35.918	debug	RAW-Values: {}
      2023-07-20 11:16:35.918	debug	Sources: {}
      2023-07-20 11:16:35.918	debug	Initial Fill-Values: {}
      2023-07-20 11:16:35.917	debug	Initial Values: {}
      2023-07-20 11:16:35.917	debug	Settings: {}
      2023-07-20 11:16:35.917	debug	CSS: {}
      2023-07-20 11:16:35.916	debug	{}
      2023-07-20 11:16:35.915	warn	This is the first time, the adapter starts. Setting config to default (empty)!
      2023-07-20 11:16:35.910	info	Adapter started. Loading config!
      2023-07-20 11:16:35.876	info	starting. Version 0.0.2-alpha.12 (non-npm: SKB-CGN/ioBroker.energiefluss-erweitert#6de10d4bc13356ed792f93aba489c8ebc8ca7bc6) in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v18.16.0, js-controller: 4.0.24
      2023-07-20 11:16:34.437	debug	States connected to redis: 0.0.0.0:6379
      2023-07-20 11:16:34.431	debug	States create User PubSub Client
      2023-07-20 11:16:34.430	debug	States create System PubSub Client
      2023-07-20 11:16:34.422	debug	Redis States: Use Redis connection: 0.0.0.0:6379
      2023-07-20 11:16:34.312	debug	Objects connected to redis: 0.0.0.0:9001
      2023-07-20 11:16:34.308	debug	Objects client initialize lua scripts
      2023-07-20 11:16:33.975	debug	Objects create User PubSub Client
      2023-07-20 11:16:33.974	debug	Objects create System PubSub Client
      2023-07-20 11:16:33.972	debug	Objects client ready ... initialize now
      2023-07-20 11:16:33.734	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
      2023-07-20 11:16:29.824	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-07-20 11:16:29.823	info	terminating
      2023-07-20 11:16:29.823	info	Cleared interval for relative values!
      2023-07-20 11:16:29.822	info	Got terminate signal TERMINATE_YOURSELF
      Homoran SKB 2 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @kiste01 last edited by
        @kiste01 sagte in Test Adapter Energiefluss-erweitert v0.0.x GitHub/Latest:
        hast du da neu gestartet?
        • SKB
          SKB Developer Most Active @kiste01 last edited by
          @kiste01 Danke für das Output. Ich denke, da ist eine Bedingung nicht richtig gewesen.
          Der Icon-Proxy ist im Skript aktiviert, aber nicht im Backend - habe es angepasst.
          Bitte nochmal von Github drüber installieren.
            Hatte den Adapter neu gestartet
              kiste01 @SKB last edited by
              @skb
              ist das dann die alpha-13 oder woran erkenne ich in github die neue Version
              SKB Homoran 2 Replies Last reply Reply Quote 0
              • SKB
                @kiste01 Du installierst einfach mit der Github Adresse drüber.
                Bernd1967 M 2 Replies Last reply Reply Quote 0
                  @kiste01 und mach zur Sicherheit danach noch einen Upload
                  • Bernd1967
                    Bernd1967 @SKB last edited by Bernd1967
                    @skb
                    Hatte das selbe Problem wie kiste01
                    Einstellungen war nicht mehr erreichbar.
                    Erst nach IOB neustart und mit der neusten Version erschien das Einstellung Icon wieder
                      alte Version deinstalliert
                      neue Version installiert
                      Upload
                      Instanz installiert
                      Instanzlink geklickt ==> kurz rotes Kästchen, Kreis dreht sich
                      Instanz gestoppt
                      Reine Web-Sockets (iobroker.ws) verwenden ausgeschaltet
                      Instanz gestartet
                      Leider unverändert
                        MoDisaster @SKB last edited by
                        @skb Moin!
                        Ich habe mir den Adapter heute Vormittag erstmals installiert und erhalte ebenfalls die Meldung, dass Instanz 0 nicht existiert.
                        Eben habe ich den Adapter nochmal gelöscht und über Github neu installiert, leider mit demselben Ergebnis. Bei mir taucht übrigens noch die Version alpha.12 auf.
                        • SKB
                          @kiste01 Was sagt die Browser KOnsole mit F12?
                          • SKB
                            SKB Developer Most Active @MoDisaster last edited by
                            @modisaster Ah, danke, einen Moment. Ich melde mich gleich zurück!
                            • SKB
                              @modisaster @kiste01
                              Ich habe noch eine Anpassung vorgenommen. Diese wird @MoDisaster auf jeden Fall helfen.
                              Wichtig: bitte das Objekt "Energiefluss-erweitert.0.configuration" einmal löschen. Dann den Adapter nochmal installieren.
                              Bei @kiste01 bin ich noch nicht sicher 😉
                              M Bernd1967 2 Replies Last reply Reply Quote 0
                                @skb perfekt, jetzt ist die Instanz da - vielen Dank! 👏
                                • Bernd1967
                                  @skb
                                  Wie ist das mit zwei Instanzen und dem Proxy ?
                                  Ich kann nur eine Instanz starten.
                                  IOB Log:
                                  Error: listen EADDRINUSE: address already in use :::10123 #
                                  • SKB
                                    SKB Developer Most Active @Bernd1967 last edited by SKB
                                    @bernd1967 Dann nimmst Du 10124 bei der nächsten.
                                    Bernd1967 1 Reply Last reply Reply Quote 0
                                    • Bernd1967
                                      @skb
                                      Ja, komm aber nicht in die Einstellungen weil die Instanz nicht startet.
                                      Werde mal den Datenpunkz direkt bearbeiten
                                      • SKB
                                        @bernd1967 In die Einstellungen auf der Instanz kommst du ohne, dass sie startet. Diese Einstellung wird im ioBroker direkt vorgenommen!
                                        • Bernd1967
                                          @skb
                                          Stimmt, funktioniert
                                            @skb
                                            socket.io.js:66 [2023-07-20T11:47:11.212Z] Try to connect
                                            functions.min.js:1 Using direct load via iconify-API!
                                            functions.min.js:1 Loaded additional file: js/iconify.min.js
                                            1.2k
                                            vis
                                            191
                                            4363
                                            5683277
