    5. [gelöst] Payload Daten in Objekte schreiben
    • GregorS
      GregorS @Homoran last edited by
      Ok.
      Hier das komplette JSON:
      {"end_device_ids":{"device_id":"eui-xxxxxxxxxxxxxxxxxxx","application_ids":{"application_id":"gs-mg-dragino-01"},"dev_eui":"xxxxxxxxxxxxxxxxxxx","join_eui":"yyyyyyyyyyyyyyyyyyy","dev_addr":"zzzzzzzzz"},"correlation_ids":["as:up:01H5KSJPMRECPFW9X31X3RZVV2","gs:conn:01H4KAYPR4MRPH50CJE9DZ7YHC","gs:up:host:01H4KAYPRB2CYT22K4H1T83DQS","gs:uplink:01H5KSJPE94D98RBTM11WVQ1SY","ns:uplink:01H5KSJPEA3KC8FPJJSHNZ1QQX","rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01H5KSJPEAS7598TVH1ZPW5BJ8","rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01H5KSJPMQT2K85MP8BY0FY6SN"],"received_at":"2023-07-18T06:04:10.775410433Z","uplink_message":{"session_key_id":"AYleIPJHcDVYfnq3XreUCg==","f_port":2,"f_cnt":2648,"frm_payload":"NOwAAAAAAAA0/0E=","decoded_payload":{"ACI1_mA":0, "ACI2_mA":0, "AVI1_V":13.548, "AVI2_V":0, "DI1_status":"L", "DI2_status":"H", "DO1_status":"H", "DO2_status":"H", "Hardware_mode":"LT22222", "RO1_status":"OFF", "RO2_status":"OFF", "Work_mode":"2ACI+2AVI"},"rx_metadata":[{"gateway_ids":{"gateway_id":"eui-7076ff0056080b0f","eui":"7076FF0056080B0F"},"time":"2023-07-18T06:04:10.444Z","timestamp":3101631076,"rssi":-116,"channel_rssi":-116,"snr":-9.5,"uplink_token":"CiIKIAoUZXVpLTcwNzZmZjAwNTYwODBiMGYSCHB2/wBWCAsPEOTE/MYLGgwI2tbYpQYQk7fJjwIgoK35vKLj9wEqDAja1tilBhCAztvTAQ==","channel_index":7,"gps_time":"2023-07-18T06:04:10.444Z","received_at":"2023-07-18T06:04:10.277432218Z"}],"settings":{"data_rate":{"lora":{"bandwidth":125000, "spreading_factor":12, "coding_rate":"4/5"}}, "frequency":"868500000", "timestamp":3101631076, "time":"2023-07-18T06:04:10.444Z"},"received_at":"2023-07-18T06:04:10.570656374Z","consumed_airtime":"1.482752s","version_ids":{"brand_id":"dragino", "model_id":"lt22222-l", "hardware_version":"_unknown_hw_version_", "firmware_version":"1.5.6", "band_id":"EU_863_870"},"network_ids":{"net_id":"000013","tenant_id":"ttn","cluster_id":"eu1","cluster_address":"eu1.cloud.thethings.network"}}}
      Bei jeder neuen Meldung kommt ein neues JSON-File mit aktualisierten Daten.
        Homoran Global Moderator Administrators @GregorS last edited by
        @gregors sagte in Payload Daten in Objekte schreiben:
        und du willst immer
        die decoded payload in einzelne Datepunkte schreiben?
        es kommen auch immer nur diese Attribute an?
        • Marc Berg
          Marc Berg Most Active @Homoran last edited by Marc Berg
          @homoran @GregorS
          Nur ein kleiner Hinweis, der LT22222 hat die unangenehme Eigenschaft, abhängig vom "work_mode" unterschiedliche Payloads bereitzustellen. Der mögliche Payload ist wesentlich größer, als der im Beispiel dargestellte!
          Im "Exit Mode" ist es beispielweise dieser:
                decode.Work_mode= "Exit mode";
                decode.Mode_status= bytes[9] ? "True":"False";
                decode.AV1L_flag= (bytes[0] &0x80)? "True":"False";
                decode.AV1H_flag= (bytes[0] &0x40)? "True":"False";
                decode.AV2L_flag= (bytes[0] &0x20)? "True":"False";
                decode.AV2H_flag= (bytes[0] &0x10)? "True":"False";
                decode.AC1L_flag= (bytes[0] &0x08)? "True":"False";
                decode.AC1H_flag= (bytes[0] &0x04)? "True":"False";
                decode.AC2L_flag= (bytes[0] &0x02)? "True":"False";
                decode.AC2H_flag= (bytes[0] &0x01)? "True":"False";
                decode.AV1L_status= (bytes[1] &0x80)? "True":"False";
                decode.AV1H_status= (bytes[1] &0x40)? "True":"False";
                decode.AV2L_status= (bytes[1] &0x20)? "True":"False";
                decode.AV2H_status= (bytes[1] &0x10)? "True":"False";
                decode.AC1L_status= (bytes[1] &0x08)? "True":"False";
                decode.AC1H_status= (bytes[1] &0x04)? "True":"False";
                decode.AC2L_status= (bytes[1] &0x02)? "True":"False";
                decode.AC2H_status= (bytes[1] &0x01)? "True":"False";
                decode.DI2_status= (bytes[2] &0x08)? "True":"False";
                decode.DI2_flag= (bytes[2] &0x04)? "True":"False";
                decode.DI1_status= (bytes[2] &0x02)? "True":"False";
                decode.DI1_flag= (bytes[2] &0x01)? "True":"False";
          paul53 Homoran 2 Replies Last reply Reply Quote 1
            Homoran Global Moderator Administrators @Homoran last edited by Homoran
            @homoran sagte in Payload Daten in Objekte schreiben:
            Liegt es in einem Datenpunkt?
            wenn ja, triggerst du auf diesen DP bei Änderung.
            Zerlegst den Inhalt des DP mit Attribut von.. und dem "Pfad zum Wert", z.b. uplink_message.decoded_payload.ACI1_mA
            das schreibst du dann in deinen selbst angelegten Datenpunkt.
            ich habe hier das json als Text eingefügt und das Ergebnis als debug ausgegeben.
            du müsstest mit dem Wert des JSON DP arbeiten und unten die ID des DP für di ACI1 einsetzen
              paul53 @Marc Berg last edited by
              @marc-berg sagte: unterschiedliche Payloads
              Dann sollte man prüfen.
              Marc Berg 1 Reply Last reply Reply Quote 1
                Homoran Global Moderator Administrators @Marc Berg last edited by
                @marc-berg sorry, der cache hatte deine Antwort geschluckt. hab sie jetzt nur durch Pauls reponse gefunden.
                • Marc Berg
                  Marc Berg Most Active @paul53 last edited by
                  @paul53 sagte in Payload Daten in Objekte schreiben:
                  ja, genau. Wenn man zum Beispiel einen Schaltbefehl als Downlink absetzt, bekommt man immer zwei Uplinks zurück. Einen mit Work_mode "Exit mode" und einen mit Work_Mode "2ACI+2AVI". Das ist zunächst etwas verwirrend, aber sicher der vielfältigen Möglichkeiten geschuldet, die man mit diesem Gerät hat.
                  GregorS 1 Reply Last reply Reply Quote 0
                  • GregorS
                    GregorS @Marc Berg last edited by
                    Danke.
                    Werde es mal die Tage probieren.
                    • GregorS
                      GregorS @GregorS last edited by
                      Leider hat es nicht funktioniert.
                      Beim Blockly kommen folgende Fehlermeldungen:
                      avascript.0
                      	2023-07-20 18:55:46.674	error	script.js.LoRaWAN_DEV_1: Cannot get AVI2_V of null
                      javascript.0
                      	2023-07-20 18:55:46.674	error	script.js.LoRaWAN_DEV_1: Cannot get ACI1_mA of undefined
                      javascript.0
                      	2023-07-20 18:53:46.292	error	script.js.LoRaWAN_DEV_1: Cannot get AVI2_V of null
                      javascript.0
                      	2023-07-20 18:53:46.292	error	script.js.LoRaWAN_DEV_1: Cannot get ACI1_mA of null
                      javascript.0
                      	2023-07-20 18:52:46.262	error	script.js.LoRaWAN_DEV_1: Cannot get AVI2_V of null
                      javascript.0
                      	2023-07-20 18:52:46.261	error	script.js.LoRaWAN_DEV_1: Cannot get ACI1_mA of undefined
                      Habe es dann noch mit einem JS versucht (hier aus dem Forum).
                      Alles angepasst, aber dies hat auch nicht funktioniert.
                      javascript.0
                      	2023-07-20 18:57:52.096	error	at Script.runInContext (node:vm:141:12)
                      javascript.0
                      	2023-07-20 18:57:52.096	error	at script.js.LoRAWAN_DEV_1:127:3
                      javascript.0
                      	2023-07-20 18:57:52.096	error	at script.js.LoRAWAN_DEV_1:1:1
                      javascript.0
                      	2023-07-20 18:57:52.095	error	script.js.LoRAWAN_DEV_1: ReferenceError: ttn_decode is not defined
                      Wie deffiniere ich den TTN_decode?
                      ttn_decode
                      //Device
                      createState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI_1", false, {
                          read: true,
                          write: false,
                          desc: "",
                          def: 0,
                          unit: "mA",
                          role: "",
                          type: "number"
                      createState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI_2", false, {
                          read: true,
                          write: false,
                          desc: "",
                          def: 0,
                          unit: "mA",
                          role: "",
                          type: "number"
                      createState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI_1", false, {
                          read: true,
                          write: false,
                          desc: "",
                          def: 0,
                          unit: "V",
                          role: "",
                          type: "number"
                      createState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI_2", false, {
                          read: true,
                          write: false,
                          desc: "",
                          def: 0,
                          unit: "V",
                          role: "",
                          type: "number"
                      //const fs = require('fs');
                      on({id: 'v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/up', change: "ne"}, function (obj) {
                          obj = JSON.parse(getState("v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/up").val);
                          setState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI_1", parseFloat(obj["payload_fields"]["ACI1_mA"].toFixed(2)), true);
                          setState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI_2", parseFloat(obj["payload_fields"]["ACI2_mA"].toFixed(2)), true);
                          setState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI_1", parseFloat(obj["payload_fields"]["AVI1_V"].toFixed(2)), true);
                          setState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI_2", parseFloat(obj["payload_fields"]["AVI2_V"].toFixed(2)), true);
                          var file = "/opt/iobroker/ttn_log.csv";
                          if(!fs.existsSync(file)) {
                              fs.writeFileSync(file, "Time\tData\r\n");
                          fs.appendFileSync(file, (new Date()).toISOString() + "\t" + getState("on({id: 'v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/up', change: "ne"}, function (obj) {
                      ").val + "\r\n");
                      Brauche da wohl ein bisschen Nachilfe.
                        Hast du die Überprüfung, ob der Inhalt existiert nicht umgesetzt?
                        @marc-berg sagte in Payload Daten in Objekte schreiben:
                        und hier die Lösung
                        • GregorS
                          GregorS @Homoran last edited by GregorS
                          Komme mit mit Blockly nicht klar.
                          Muss ich die Variablen "payload","jason" vorher erstellen? Wo?
                          Muss ich im Attribut "uplink_message...." den Pfad zu meinem Objekt reinkopieren?
                          So sieht meine Struktur aus:
                          Ich sende keine Befehle, sondern empfange nur welche von LoRaWan.
                          Muss ich trotzdem die Abfrage machen?
                          Irgendwie bin ich dazu zu blöd.
                            paul53 @GregorS last edited by paul53
                            @gregors sagte: Muss ich die Variablen "payload","jason" vorher erstellen? Wo?
                            Die Variable payload muss unter "Variablen" erstellt werden.
                            Der Datenpunkt "up" dient als Trigger:
                            Wert findet man unter "Trigger".
                              @gregors sagte: Brauche da wohl ein bisschen Nachilfe.
                              const idUp = 'mqtt.2.v3.gs-mg-dragino-01@ttn.devices.eui-a840414601871305.up'/*v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/up*/;
                              on(idUp, function (dp) {
                                  let payload = JSON.parse(dp.state.val).uplink_message.decoded_paylod;
                                  if(payload && payload.AVI1_V != undefined) {
                                      setState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI_1", Math.round(payload.ACI1_mA * 100) / 100, true);
                                      setState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI_2", Math.round(payload.ACI2_mA * 100) / 100, true);
                                      setState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI_1", Math.round(payload.AVI1_V * 100) / 100, true);
                                      setState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI_2", Math.round(payload.AVI2_V * 100) / 100, true);
                              Zum Triggern muss die DP-ID - nicht der DP-Name - verwendet werden.
                              • GregorS
                                Habe ich ausprobiert.
                                Keine Fehler mehr, aber es wird nichts in die Objekte geschrieben.
                                  @gregors sagte: es wird nichts in die Objekte geschrieben.
                                  Es wird getriggert, d.h. die ID stimmt?
                                  • GregorS
                                    GregorS @paul53 last edited by GregorS
                                    Kann ich nicht erkennen.
                                    Zur Auswahl unter ID bekam ich nur das Objekt UP angeboten.
                                    on('mqtt.2.v3.gs-mg-dragino-01@ttn.devices.eui-a840414601871305.up', function (dp) {
                                            setState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI1_mA", Math.round(payload.ACI1_mA * 100) / 100, true);
                                            setState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI2_mA", Math.round(payload.ACI2_mA * 100) / 100, true);
                                            setState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI1_V", Math.round(payload.AVI1_V * 100) / 100, true);
                                            setState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI2_V", Math.round(payload.AVI2_V * 100) / 100, true);
                                    Kann ich auch mit einem Schedule jede Minute triggern?
                                      @gregors sagte: Objekt UP
                                      Ändert sich der Inhalt? Es wird nur bei Wertänderung getriggert.
                                      • GregorS
                                        Der Wert im Payload ändert sich.
                                        Allerdings nur AVI1_V, da es zur Zeit der einzige angeschlossene Wert ist.
                                        Was bedeutet diese Zeile:
                                        Es gibt doch 4 Variablen mit Daten.
                                        Der Wert von 0_userdata.0.LoRaWAN.eui-a840414601871305.AVI1_V bleibt "0"
                                        Habe ihn händisch als Datenpunkt "Number" angelegt.
                                          @gregors sagte: Was bedeutet diese Zeile:
                                          Es wird geprüft, ob das payload-Objekt vorhanden ist und ob es "AVI1_V" enthält.
                                          Wenn "AVI1_V" enthalten ist, sind die anderen auch vorhanden.
                                          Die Zeile 1 mit der ID ist hoffentlich als Kommentar gekennzeichnet?
                                          • GregorS
                                            Die Zeile 1 war natürlich nicht als Kommentar gekennzeichnet.
                                            Habe ich aber nachgeholt.
                                            Aber die Werte stehen immer noch auf 0
                                            Fehler gibt es keine
                                            //'mqtt.2.v3.gs-mg-dragino-01@ttn.devices.eui-a840414601871305.up'/*v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/up*/
                                            3604
