    4. Probleme mit HomeMatic RPC
      rascal @rascal last edited by
      Ich habe wieder ein paar Fehlermeldunge....
      Zeit
      error
      Nachricht
      hm-rpc.2
      2023-07-20 12:31:41.339	error	Cannot call init: [http://192.168.1.226:2010, ""] Unexpected endLine: 0Column: 0Char:
      hm-rpc.2
      2023-07-20 12:31:41.323	error	Init not possible, going to stop: Unexpected endLine: 0Column: 0Char:
      hm-rpc.2
      2023-07-20 12:31:11.325	error	Init not possible, going to stop: Unexpected endLine: 0Column: 0Char:
      hm-rpc.2
      2023-07-20 12:30:41.305	error	Ping error [iobroker:hm-rpc.2:fb3416f7897b52e870029128aa102b2e]: Unexpected endLine: 0Column: 0Char:
      hm-rpc.2
      2023-07-20 12:30:15.451	error	Cannot call setValue: Unexpected endLine: 0Column: 0Char:
      hm-rpc.2
      2023-07-20 12:30:15.449	error	xmlrpc -> setValue ["001118A9A58F1B:4","LEVEL",0] FLOAT
      hm-rpc.2
      2023-07-20 12:30:13.448	error	Cannot call setValue: Unexpected endLine: 0Column: 0Char:
      hm-rpc.2
      2023-07-20 12:30:13.447	error	xmlrpc -> setValue ["00111A49A8DE25:4","LEVEL",0] FLOAT
      hm-rpc.2
      2023-07-20 12:30:09.450	error	Cannot call setValue: Unexpected endLine: 0Column: 0Char:
      hm-rpc.2
      2023-07-20 12:30:09.449	error	xmlrpc -> setValue ["00111D89AB034E:4","LEVEL",0] FLOAT
      hm-rpc.2
      2023-07-20 12:29:57.679	error	Cannot call setValue: Unexpected endLine: 0Column: 0Char:
      hm-rpc.2
      2023-07-20 12:29:57.678	error	xmlrpc -> setValue ["001118A9925408:4","LEVEL",0] FLOAT
      hm-rpc.2
      2023-07-20 12:29:56.675	error	Cannot call setValue: Unexpected endLine: 0Column: 0Char:
      hm-rpc.2
      2023-07-20 12:29:56.674	error	xmlrpc -> setValue ["001118A9A58F1B:4","LEVEL",0] FLOAT
      hm-rpc.2
      2023-07-20 12:29:54.684	error	Cannot call setValue: Unexpected endLine: 0Column: 0Char:
      hm-rpc.2
      2023-07-20 12:29:54.683	error	xmlrpc -> setValue ["00111A49A8DE25:4","LEVEL",0] FLOAT
      das sind alles HM-IP Rolladenaktoren, die Datenpunkte sind allerdings vorhanden und die Rolläden werden auch gefahren, trotz der Fehlermeldungen.
        Lucky_ESA Developer Most Active last edited by Lucky_ESA
        könnt ihr mal Sentry für die netroffenen Instanzen deaktivieren.
        Ich habe seit dem kein Problem mehr...Kann aber auch Zufall sein. Bei mir kam das Thema mit einem Update auf 5.0.8.
        Edit:
        Wer nicht weiß wie es geht. Den grünen Button drücken:
        Gruß//Lucky
        D S Feuersturm M T 6 Replies Last reply Reply Quote 3
          darkiop Most Active @Lucky_ESA last edited by
          @lucky_esa
          Kann ich bestätigen.
          js-controller 5.0.8
          npm 9.6.7
          node 18.17.0
            Str_n @Lucky_ESA last edited by
            @lucky_esa
            Das sieht gut aus bei mir. Habe die Ping Zeit im Adapter auf 10 Sekunden gestellt. Nach spätestens 5 Minuten ist der Fehler dann da. Mit deaktiviertem Sentry scheint der Fehler nicht mehr zu kommen.
              darkiop Most Active last edited by
              Klingt nach einen Fall für Ingo 🙂 @apollon77
                Ergibt Sinn!
                ich glaube da gab es auch ein Problem mit Sentry beim Zigbee Adapter, @arteck ?
                dann passt aber nicht, dass angeblich nichts geändert wurde.
                  @homoran sagte in Probleme mit HomeMatic RPC:
                  Die Änderung kann ja auch sentry-Server-seitig sein.
                    @thomas-braun sagte in Probleme mit HomeMatic RPC:
                    manno 😞
                    du findest aber auch für alles eine Möglichkeit 😉
                      Ich bekomms auch nicht mehr aufgelöst was ich alles geändert wurde. Habe die Tage den js-controller auf die 5.x gehoben und nodejs auf 18.x.
                      Der Bauch sagt auch Sentry Server 😉
                      • Feuersturm
                        Feuersturm @Lucky_ESA last edited by
                        Hab bei mir Sentry für die Instanz auch mal auf meinem Testsystem (mit js-controller 5) deaktiviert wo das Problem auftritt.
                        Komischerweise hab ich die Fehlermeldung auf meinem Produktivsystem nicht (mit js-controller 4). Dort ist Sentry bei der hm-rpc Instanz auch aktiv.
                        Mal abwarten....
                        • U
                          UV-on-fire last edited by UV-on-fire
                          Also ich hab gestern auch ein Update von 5.0.6 auf 5.0.8 gemacht und danach kam der PingFehler. Hab eben noch Updates gefahren und die Ping Zeit runter genommen und der Fehler kam immer noch. Jetzt ebenfalls Sentry deaktiviert und scheinbar ist der Fehler weg.
                          Hab da jetzt noch eine FRage zum iob diag. In der Zusammenfassung steht was von 61 os updates? Ich habe aber eben auch iob update und iob upgrade self durchgeführt. Wieso sind dann noch os updates offen? Oder missverstehe ich da was?
                          Edit: Bei mir wars übrigens der RPC für die Homematic IP Geräte. Bei euch auch?
                                               v.2023-04-16
                          Operatingsystem:        Debian GNU/Linux 11 (bullseye)
                          Kernel:                 5.15.74-1-pve
                          Installation:           lxc
                          Timezone:               Etc/UTC (UTC, +0000)
                          User-ID:                1000
                          X-Server:               false
                          Boot Target:            graphical.target
                          Pending OS-Updates:     61
                          Pending iob updates:    0
                          Nodejs-Installation:    /usr/bin/nodejs         v18.15.0
                                                  /usr/bin/node           v18.15.0
                                                  /usr/bin/npm            9.5.0
                                                  /usr/bin/npx            9.5.0
                          Recommended versions are nodejs 18.x.y and npm 9.x.y
                          MEMORY:
                          Mem:            4.1G        2.7G        379M        0.0K        1.0G        1.4G
                          Swap:           512M        0.0K        511M
                          Total:          4.6G        2.7G        891M
                          Active iob-Instances:   31
                          Active repo(s): Beta (latest)
                          ioBroker Core:          js-controller           5.0.8
                                                  admin                   6.6.1
                          Objects type: jsonl
                          States  type: jsonl
                          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.213, run as: admin
                            system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 -  enabled
                          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          Objects:                18998
                          States:                 16985
                          Size of iob-Database:
                          19M     /opt/iobroker/iobroker-data/objects.jsonl
                          7.5M    /opt/iobroker/iobroker-data/states.jsonl
                          =================== END OF SUMMA
                          DJMarc75 Feuersturm 2 Replies Last reply Reply Quote 0
                          • DJMarc75
                            DJMarc75 @UV-on-fire last edited by
                            @uv-on-fire sagte in Probleme mit HomeMatic RPC:
                            Das sind updates vom Betriebssstem welche man halt regelmäßig machen sollte
                            sudo apt update
                            sudo apt upgrade
                            • Feuersturm
                              Feuersturm @UV-on-fire last edited by
                              Das sind die offenen Betriebssystem update 😉
                              sudo apt update
                              sudo apt upgrade
                              bewirken wunder 😉
                              U Thomas Braun 2 Replies Last reply Reply Quote 0
                              • U
                                UV-on-fire @Feuersturm last edited by
                                @DJMarc75
                                @feuersturm
                                Danke euch.
                                Ich bin da noch nicht so wirklich fit im Linux aber jetzt ist klar.
                                Hab bisher immer nur die iob updates gemacht aber natürlich ist da noch das Linux als eigentliches Betriebssystem im Hintergrund 👍
                                • DJMarc75
                                  DJMarc75 @UV-on-fire last edited by DJMarc75
                                  nein, das MUSS im Vordergrund sein, weil das ist halt die Basis / Betriebssystem 😉
                                  aber leider OffTopic hier 😞
                                    Thomas Braun Most Active @Feuersturm last edited by
                                    Besser:
                                    sudo apt update
                                    sudo apt full-upgrade
                                    • U
                                      UV-on-fire @Thomas Braun last edited by
                                      Danke euch ✌
                                        Thomas Braun Most Active @UV-on-fire last edited by
                                        @uv-on-fire
                                        Deine Zeitzone ist nicht gesetzt. Ist aber auch OT.
                                        • U
                                          Muss mal in Ruhe den linux werkzeugkasten durchlesen.😊
                                          Erledigt, danke👍
                                          Jetzt aber genug OT🤗
                                            ma @Lucky_ESA last edited by
                                            @lucky_esa
                                            kann ich auch bestätigen
                                            Adapter Version: 1.15.18
                                            CCU Version: 3.69.7
                                            hm-rega: 3.0.46
                                            JS-Controller: 4.0.24
                                            Node: 16.20.0
                                            Operating System: Ubuntu 20.04.6 LTS
                                            168
                                            18895
