    3. Einsteigerfragen
    4. Installation
    5. iobroker mit node.js 16 installieren
    • ch90045
      ch90045 last edited by
      @meister-mopper Ja, die Idee ist mir dann auch gekommen ... aber:
      ./install.sh
      library: loaded
      Library version=2022-12-09
          Welcome to the ioBroker installer!
          Installer version: 2023-04-16
          Installing prerequisites (1/4)
      Hit:1 http://security.debian.org bullseye-security InRelease
      Hit:2 http://ftp.debian.org/debian bullseye InRelease
      Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
      Reading package lists... Done
      Installed npm
      Changing npm registry to https://registry.npmjs.org
      Installed build-essential
      Installed gcc-c++
      Installed libavahi-compat-libdnssd-dev
      Installed libudev-dev
      Installed libpam0g-dev
      Installed git
      Installed libcairo2-dev
      Installed libpango1.0-dev
      Installed libjpeg-dev
      Installed libgif-dev
      Installed librsvg2-dev
      Installed net-tools
      Installed cmake
          Creating ioBroker user and directory (2/4)
      User iobroker created
      Created /etc/sudoers.d/iobroker
      Directory /opt/iobroker created
          Installing ioBroker (3/4)
      npm ERR! code EBADENGINE
      npm ERR! engine Unsupported engine
      npm ERR! engine Not compatible with your version of node/npm: iobroker.backitup@2.6.23
      npm ERR! notsup Not compatible with your version of node/npm: iobroker.backitup@2.6.23
      npm ERR! notsup Required: {"node":">=14.0.0"}
      npm ERR! notsup Actual:   {"npm":"7.5.2","node":"v12.22.12"}
      npm ERR!     /root/.npm/_logs/2023-07-20T15_57_04_799Z-debug.log
          Finalizing installation (4/4)
      Enabling autostart...
      Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
      Autostart enabled!
      Fixing directory permissions...
          ioBroker was installed successfully
          Open http://192.168.0.67:8081 in a browser and start configuring!
      You need to re-login before doing anything else on the console!
      root@tempbroker:~# iob status
      internal/modules/cjs/loader.js:818
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
          at Function.Module._load (internal/modules/cjs/loader.js:667:27)
          at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
          at internal/main/run_main_module.js:17:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      root@tempbroker:~# iob fix
      library: loaded
      ioBroker is not installed in /opt/iobroker! Cannot fix anything...
      root@tempbroker:~# cd /opt/
      root@tempbroker:/opt# cd iobroker/
      root@tempbroker:/opt/iobroker# ls
      INSTALLER_INFO.txt  iob  iobroker  package.json
      root@tempbroker:/opt/iobroker# ./iob
      iob       iobroker
        throw err;
        requireStack: []
      • Meister Mopper
        Meister Mopper @ch90045 last edited by
        @ch90045
        Ich dachte eher an
        iob stop
        die node.js Ziffer ändern
        sudo apt update && sudo apt full-upgrade
        sicherheitshalber einen reboot
        und dann sollte es leben.
        ch90045 1 Reply Last reply Reply Quote 1
        • ch90045
          ch90045 @Meister Mopper last edited by
          @meister-mopper Proxmox sei dank - gib mir 5min ....
            Thomas Braun Most Active @ch90045 last edited by
            @ch90045
            Installier gezielt eine bestimmte Version von nodejs. Wie das geht steht in meiner Signatur. Ganz unabhängig von proxmox. Allerdings hampelt man auch da NICHT als root durch die Gegend.
            ch90045 1 Reply Last reply Reply Quote 0
              @ch90045
              Ich meine mich erinnern zu können das der Adapter im GitHub auch mit nodejs@18 parat kommt.
              • ch90045
                ch90045 @Thomas Braun last edited by
                @thomas-braun Lieber Thomas, ich hampel nicht! Dein Tipp hat funktioniert. Ich lege bloss nicht für eine Testinstallation noch einen Benutzer an um ihn 3min später wieder mit dem ganzen Container zu löschen.
                • ch90045
                    @ch90045
                    root shell ist immer Gehampel.
                    https://github.com/Apollon77/ioBroker.daikin-cloud/issues/188
                    Uwe1984 created this issue in Apollon77/ioBroker.daikin-cloud
                    closed Adapter nicht kompatibel mit Node.js 18.5.0 und npm 9.5.0? #188
                      Thomas Braun Most Active @ch90045 last edited by Thomas Braun
                      @ch90045
                      Hier installiert das Ding sauber mit nodejs@18.17.0 und auch sonst bleeding edge Versionen. Wurde allerdings nicht in einer root shell ausgeführt.
                      iobroker url https://github.com/Apollon77/ioBroker.daikin-cloud --host chet --debug
                      install Apollon77/ioBroker.daikin-cloud#03b831dac009b1d9cd0a7399f7e9a38486d06d19
                      NPM version: 9.6.7
                      Installing Apollon77/ioBroker.daikin-cloud#03b831dac009b1d9cd0a7399f7e9a38486d06d19... (System call)
                      npm WARN skipping integrity check for git dependency ssh://git@github.com/Apollon77/ioBroker.daikin-cloud.git
                      107 packages are looking for funding run `npm fund` for details
                      upload [6] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/admin.d.ts admin.d.ts video/mp2t
                      upload [5] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/daikin-cloud.jpg daikin-cloud.jpg image/jpeg
                      upload [3] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/index_m.html index_m.html text/html
                      upload [2] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/style.css style.css text/css
                      upload [1] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/warning.png warning.png image/png
                      upload [0] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/words.js words.js application/javascript
                      Process exited with code 0
                      • ch90045
                        ch90045 @Thomas Braun last edited by ch90045
                        @thomas-braun Die Installation stand nie in Frage - eine Instanz wird mit dem Hinweis auf Version 18 abgelehnt. Dein Root Gemeckere nervt - du weisst nicht mit wem du sprichst, ich halte mich bei jemandem, den ich nicht kenne mit nicht zielführender (heisst, mit Nachweiss, dass der Punkt Auslöser für das Problem ist) Kritik zurück - aber vielleicht empfinde ich allein dies als unhöflich/übergriffig.
                        Ich habe das Problem gelöst - danke an alle, die zielführend geholfen haben.
                        Homoran 1 Reply Last reply Reply Quote -1
                          Homoran Global Moderator Administrators @ch90045 last edited by
                          @ch90045 sagte in iobroker mit node.js 16 installieren:
                          ich weiss nicht ob ich dazu auch etwas allgemeingültiges in einen Thread gegossen habe.
                          kurz die Essenz:
                          Die Verwendung von root kann dazu führen, dass Rechte dermaßen verbogen wurden, dass der Sysemuser iobroker nicht mehr normal arbeiten kann.
                          • ch90045
                            ch90045 @Homoran last edited by ch90045
                            @homoran Ich weiss, dass man root nicht nutzen soll. Ich nutze root nicht auf meinem "Produktionssystem" welches genau den Fehler (keine Instanz für den Daikin Cloud Adapter bei node.js >= 18.x) hatte. Ich habe nur "schnell" die tempbroker container instanz installiert um zu testen, ob ich die Version 16 bekommen kann, welche das Installationsskript nicht installiert. Die Lebensdauer der tempbroker instanz lag unter 5min - was ich übrigens auch geschrieben habe - da dann über "du benutzt ja root" zu meckern und nicht einen Hinweis/Nachweis, warum root HIER ein Problem ist, zu geben, welcher hilfreich ist für die Problemstellung, nervt.
                            Die Frage, wie man bei einem aktuellen iobroker Installationsskript node.js <=16 installiert hat wirklich nichts mit root/normaler Nutzer zu tun und war somit auch nicht Teil meiner Frage.
                              @ch90045
                              Verbogene Rechte gerade biegen nervt noch mehr.
                              Einfach immer ordentlich mit einem Debian umgehen, passt.
                              • ch90045
                                @thomas-braun Ungefragte Antworten zu bekommen nervt am meisten - immer noch.
                                  @ch90045
                                  Hast doch eine Antwort bekommen wie man andere Versions-Linien richtig installiert.
                                  Den Hinweis auf den root gab es gratis dazu.
                                  • ch90045
                                    @thomas-braun Und den brauchte ich nicht einmal - aber das willst du ja nicht hören/verstehen ... lässt auf eine herablassende Ignoranz schliessen.
                                    Thomas Braun 1 Reply Last reply Reply Quote -1
                                      @ch90045
                                      Nein, weil der Adapter in aktuellster Version auch mit nodejs@18 kompatibel ist. Hab ich verstanden/gewusst.
                                      Eine user shell ist wie mit dem Anschnallgurt im Auto. Musst du auch anlegen, und wenn es nur bis zum Bäcker die Straße runter ist. Wenn du der Rennleitung ohne Gurt entgegekommst kriegst du da auch ungefragt ein Ticket.
                                      ? 1 Reply Last reply Reply Quote 1
                                        A Former User @Thomas Braun last edited by
                                        @thomas-braun sagte in iobroker mit node.js 16 installieren:
                                        Moin,
                                        kann nicht wiederstehen 🙂
                                        !!! OT on !!!
                                        Das ist nicht wie zum Becker, das ist, ich fahre auf dem eigenen Grundstück, und da muss ich mich nicht anschnallen 😉
                                        Wenn ich dabei etwas zerstöre oder mich verletze, ist das mein Schaden, das muss mir nur bewusst sein, auch dass Versicherungen sich weigern werden da etwas zu zahlen.
                                        !!! OT off !!!
                                        Ich entschuldige mich schon mal für alles, was jetzt daraus wird 🙂
                                        VG
                                        Bernd
                                        P.S.: root sollte trotzdem mit Vorsicht genutzt werden 🙂
                                          @dp20eic
                                          root wird zu 99,99% immer genau von den Kandidaten verwendet, die es eben tunlichst mangels Ahnung nicht machen sollten.
                                          Die mit Ahnung wissen nur zu gut wie gefährlich das sein kann.
                                          Der Waldarbeiter schaltet seine Kettensäge ja auch während seiner Frühstückspause ab und lässt die nicht laufen, weil er die ja in ein paar Minuten wieder braucht.
                                          • ch90045
                                            @thomas-braun Schon wieder eine Vorverurteilung - ich zwischen 1999-2011 Solaris OS support gemacht, bin seit 2011 bei einer IT Firma die unter der Appliance BSD nutzt - ich weiss mit root umzugehen das magst du anders sehen, geht mir aber am ... - noch immer - nichts davon hatte etwas mit meiner Frage zu tun.
                                            2016
