    4. Test Adapter powerfox v0.0.2-x
      hydraold @sadir last edited by
      @sadir ich habe auch probleme mit dem adapter die werte sind wie eingefroren würde den adatper neu einspielen aber ist nicht mehr erreichbar im Netz
        AxLED @hydraold last edited by
        @hydraold
        habe mich mal an der Überarbeitung des Adapters versucht: Adapter powerfox2
        AxLED
        D A 2 Replies Last reply Reply Quote 0
          darkblu @AxLED last edited by darkblu
          ups, war hier falsch
            Blotto112 last edited by
            Guten Tag,
            Ist irgendetwas bei dem Powerfox verändert worden?
            Ich bekomme keine Daten mehr in ioBroker.
            MfG
              Thomas Braun Most Active @Blotto112 last edited by
              @blotto112
              Und im LogFile steht dazu was?
                Blotto112 @Thomas Braun last edited by
                host.raspberrypi
                2023-01-09 17:37:54.001 warn instance system.adapter.powerfox2.0 already running with pid 284100
                host.raspberrypi
                2023-01-09 17:37:45.001 warn instance system.adapter.powerfox2.0 already running with pid 284100
                host.raspberrypi
                2023-01-09 17:37:36.002 warn instance system.adapter.powerfox2.0 already running with pid 284100
                host.raspberrypi
                2023-01-09 17:37:27.002 warn instance system.adapter.powerfox2.0 already running with pid 284100
                host.raspberrypi
                2023-01-09 17:37:18.003 warn instance system.adapter.powerfox2.0 already running with pid 284100
                host.raspberrypi
                2023-01-09 17:37:09.002 warn instance system.adapter.powerfox2.0 already running with pid 284100
                host.raspberrypi
                2023-01-09 17:37:00.002 warn instance system.adapter.powerfox2.0 already running with pid 284100
                host.raspberrypi
                2023-01-09 17:36:54.001 warn instance system.adapter.powerfox2.0 already running with pid 284100
                host.raspberrypi
                2023-01-09 17:36:45.001 warn instance system.adapter.powerfox2.0 already running with pid 284100
                host.raspberrypi
                2023-01-09 17:36:36.002 warn instance system.adapter.powerfox2.0 already running with pid 284100
                host.raspberrypi
                2023-01-09 17:36:27.001 warn instance system.adapter.powerfox2.0 already running with pid 284100
                host.raspberrypi
                2023-01-09 17:36:18.003 warn instance system.adapter.powerfox2.0 already running with pid 284100
                host.raspberrypi
                2023-01-09 17:36:09.002 warn instance system.adapter.powerfox2.0 already running with pid 284100
                host.raspberrypi
                2023-01-09 17:36:00.003 warn instance system.adapter.powerfox2.0 already running with pid 284100
                host.raspberrypi
                2023-01-09 17:35:54.002 warn instance system.adapter.powerfox2.0 already running with pid 284100
                host.raspberrypi
                2023-01-09 17:35:45.002 warn instance system.adapter.powerfox2.0 already running with pid 284100
                host.raspberrypi
                2023-01-09 17:35:36.001 warn instance system.adapter.powerfox2.0 already running with pid 284100
                Habe nichts verändert
                  @blotto112
                  Bitte Text immer in CodeTags eingebettet posten. Danke.
                    Habe es alles gelöscht.
                    Neu Installiert.
                    Nun gehts wieder
                    N 1 Reply Last reply Reply Quote 1
                    • N
                      nobbiman @Blotto112 last edited by
                      @blotto112
                      Ich habe auch immer wieder das Problem, dass die Daten im ioBroker nicht aktualisiert werden - in der powerfox-App sind sie zu sehen. Heute habe ich wieder mal auf "timestamp" im Device geschaut und gesehen, dass die letzte Aktualisierung vom 16.7. war, das sind jetzt 5 Tage her. Im Log ist kein Fehler zu sehen!
                      Deinstalliere ich den Adapter und installiere ihn neu, geht es wieder ein paar Tage - gefühlt 1x je Woche muss ich de- und neuinstallieren; ein Dauerzustand sieht anders aus!
                      Hat jemand eine Idee, woran das liegt, bzw. was ich unternehmen könnte, um das Problem zu beseitigen?
                      Meine Adapterversion ist die 0.0.12 und ich weiß schon, dass ich hier im Thread v0.0.2-x bin, der wird mir aber im ioBroker nicht angeboten, aber wo bekomme ich den denn her?
                        JoergH @nobbiman last edited by
                        @nobbiman
                        Du musst oben auf den Kopf klicken, dann über die Katze von GitHub installieren, dann kriegst Du auch die neuste Version.
                        • N
                          nobbiman @JoergH last edited by
                          @joergh Oh, noch nie gemacht, wieder etwas gelernt! Ist die Debug-Ausgabe zu installieren?
                            @nobbiman sagte in Test Adapter powerfox v0.0.2-x:
                            Was meinst Du damit? Die Debug Ausgabe kann man aktivieren in den Einstellungen der Instanz, wenn man den Expertenmodus auswählt.
                            • N
                              nobbiman @JoergH last edited by nobbiman
                              @joergh bei der Installation über die Katze erscheint die Checkbox "Debug-Ausgaben"
                                @nobbiman Achso. Da wird nichts installiert, sondern er zeigt Dir eine Debug Ausgabe während der Installation an.
                                • N
                                  @joergh OK und Danke
                                    TurboSasch @bazidibavaria last edited by
                                    ich habe heute auch den PowerFox Adapter installiert und bekomme im Log immer das angezeigt:
                                    powerfox2.0
                                    2023-08-14 19:12:01.904 info Terminated (NO_ERROR): Without reason
                                    powerfox2.0
                                    2023-08-14 19:12:00.901 info starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v16.20.1, js-controller: 4.0.24
                                    Was heißt das und was müsste gegebenfalls geändert werden?
                                    • N
                                      nobbiman @TurboSasch last edited by nobbiman
                                      @turbosasch Ist wie die Fehlermeldung schon sagt, "NO ERROR", also kein Fehler! Der Adapter startet halt für jede Abfrage neu und endet (terminated) danach mit dieser Meldung!
                                        ATARI @AxLED last edited by
                                        @axled Danke das Du den Adapter weiter pflegst.
                                        Hallo zusammen.
                                        Bei mir lief die akt. Version 0.0.12 auf einem TinkerBoard S und auf einer Synology DS im Docker ohne Probleme.
                                        Nach dem Totalausfall vom TinkerBoard habe ich mir einen Raspberry Pi 4 zugelegt.
                                        Auch hier lief der powerfox2 ohne Probleme.
                                        Vor ein paar Tagen habe ich den ioBroker auf dem Raspberry Pi und im Docker auf den akt. Stand gebracht. (Admin, node.js, npm, js-controller…)
                                        Nach dem Update des js-controller von v4.x auf v5.x läuft powerfox2 nicht mehr
                                        auf dem Raspberry Pi, auf Synology im Docker aber weiterhin ohne Probleme.
                                        Als Fehler erhalte ich:
                                        instance system.adapter.powerfox2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        Löschen, neuinstallieren, reboot, iobroker update && upgrade… blieb auf dem Pi erfolglos.
                                        Hat jemand eine Idee?
                                        ATARI
                                          Thomas Braun Most Active @ATARI last edited by
                                          @atari sagte in Test Adapter powerfox v0.0.2-x:
                                          Zeig mal die Langfassung von
                                          iob diag
                                            ATARI @Thomas Braun last edited by
                                            mit Langfassung meinst Du die "Summary"?
                                            energy energy meter energy monitor powerfox
                                            28
                                            147
                                            17569
