      TT-Tom @manylopmy last edited by TT-Tom
      @manylopmy
      Stell im Script bitte mal debug auf true
      const Debug: boolean = true;
      dann ical-Adapter Neustarten und aus Log die Meldungen mal posten
        Sorry, habe keine Erfahrung hier mit dem Editor. Ich kann den log nur direkt hier rein kopieren. 😕
        javascript.0
        2023-07-21 21:28:30.018 warn at processImmediate (node:internal/timers:464:21)
        javascript.0
        2023-07-21 21:28:30.018 warn at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5909:56)
        javascript.0
        2023-07-21 21:28:30.018 warn at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
        javascript.0
        2023-07-21 21:28:30.017 warn at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1255:38)
        javascript.0
        2023-07-21 21:28:30.017 warn at Object.<anonymous> (script.js.common.Panel_1:2788:12)
        javascript.0
        2023-07-21 21:28:30.017 warn at __awaiter (script.js.common.Panel_1:4:12)
        javascript.0
        2023-07-21 21:28:30.017 warn at new Promise (<anonymous>)
        javascript.0
        2023-07-21 21:28:30.017 warn at script.js.common.Panel_1:8:71
        javascript.0
        2023-07-21 21:28:30.017 warn at Object.next (script.js.common.Panel_1:14:53)
        javascript.0
        2023-07-21 21:28:30.017 warn at step (script.js.common.Panel_1:33:23)
        javascript.0
        2023-07-21 21:28:30.017 warn at Object.<anonymous> (script.js.common.Panel_1:2792:17)
        javascript.0
        2023-07-21 21:28:30.017 warn at HandleScreensaverUpdate (script.js.common.Panel_1:8248:13)
        javascript.0
        2023-07-21 21:28:30.016 warn at HandleScreensaverStatusIcons (script.js.common.Panel_1:8395:30)
        javascript.0
        2023-07-21 21:28:30.015 warn getState "deconz.0.Sensors.5.open" not found (3)
        javascript.0
        2023-07-21 21:28:30.015 warn at processImmediate (node:internal/timers:464:21)
        javascript.0
        2023-07-21 21:28:30.015 warn at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5909:56)
        javascript.0
        2023-07-21 21:28:30.015 warn at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
        javascript.0
        2023-07-21 21:28:30.015 warn at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1255:38)
        javascript.0
        2023-07-21 21:28:30.014 warn at Object.<anonymous> (script.js.common.Panel_1:2788:12)
        javascript.0
        2023-07-21 21:28:30.014 warn at __awaiter (script.js.common.Panel_1:4:12)
        javascript.0
        2023-07-21 21:28:30.014 warn at new Promise (<anonymous>)
        javascript.0
        2023-07-21 21:28:30.014 warn at script.js.common.Panel_1:8:71
        javascript.0
        2023-07-21 21:28:30.014 warn at Object.next (script.js.common.Panel_1:14:53)
        javascript.0
        2023-07-21 21:28:30.014 warn at step (script.js.common.Panel_1:33:23)
        javascript.0
        2023-07-21 21:28:30.014 warn at Object.<anonymous> (script.js.common.Panel_1:2792:17)
        javascript.0
        2023-07-21 21:28:30.014 warn at HandleScreensaverUpdate (script.js.common.Panel_1:8248:13)
        javascript.0
        2023-07-21 21:28:30.014 warn at HandleScreensaverStatusIcons (script.js.common.Panel_1:8368:25)
        javascript.0
        2023-07-21 21:28:30.012 warn getState "deconz.0.Sensors.5.open" not found (3)
        host.raspberrypi
        2023-07-21 21:28:28.339 info instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        ical.0
        2023-07-21 21:28:27.692 info Terminated (NO_ERROR): Without reason
          hier die logs vom ical adapter.
          ical.0
          2023-07-21 21:30:09.378 info Terminated (NO_ERROR): Without reason
          ical.0
          2023-07-21 21:30:04.080 info processing URL: calendar1 https://calendar.google.com/calendar/ical/9844e909dcfd49955c0fdd9d6c1ecf91246f838a8cb54c61192c9a1d48989a15%40group.calendar.google.com/private-a00087e2da83529a6d91077168a66fc0/basic.ics
          ical.0
          2023-07-21 21:30:03.442 info starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v16.13.0, js-controller: 4.0.23
          ical.0
          ical.0
          2023-07-21 21:28:22.505 info processing URL: calendar1 https://calendar.google.com/calendar/ical/9844e909dcfd49955c0fdd9d6c1ecf91246f838a8cb54c61192c9a1d48989a15%40group.calendar.google.com/private-a00087e2da83529a6d91077168a66fc0/basic.ics
          ical.0
            @manylopmy
            um log Meldungen in Codetag zu packen
              ical.0
              ical.0
              ical.0
              ical.0
              ical.0
              ical.0
              Danke.Sin das die richtigen logs?
                @manylopmy
                hast du im Abfallscript den Debug auf true gesetzt?
                  Wie du geschrieben hattest.
                  * Version 4.0.1
                   * Das Script erstellt die Datenpunkte und Alias für den Abfallkalender im Sonoff NSPanel
                   * Es wird der iCal Adapter benötigt und eine URL mit Terminen vom Entsorger bzw. eine .ics-Datei mit den Terminen.
                   * Das Script triggert auf dem bereitgestellten JSON im iCal adapter und füllt die 0_userdata.0 Datenpunkte
                   * Weitere Informationen findest du in der FAQ auf Github https://github.com/joBr99/nspanel-lovelace-ui/wiki
                  const idAbfalliCal: string = 'ical.0'; // iCal Instanz zum Abfallkalender
                  const idUserdataAbfallVerzeichnis: string = '0_userdata.0.Abfallkalender'; // Name des Datenpunktverzeichnis unter 0_userdata.0 -> Strandard = 0_userdata.0.Abfallkalender
                  const idAliasPanelVerzeichnis: string = 'alias.0.NSPanel'; //Name PanelVerzeichnis unter alias.0. Standard = alias.0.NSPanel.1
                  const idAliasAbfallVerzeichnis: string = 'Abfall'; //Name Verzeichnis unterhalb der idPanelverzeichnis  Standard = Abfall
                  const idZeichenLoeschen: number = 14; // x Zeichen links vom String abziehen, wenn vor dem Eventname noch Text steht z.B. Strassenname; Standard = 0
                  const idRestmuellName: string = 'Hausmüll'; // Schwarze Tonne
                  const idWertstoffName: string = 'Gelber Sack'; // Gelbe Tonne / Sack
                  const idPappePapierName: string = 'Papier';  // Blaue Tonne
                  const idBioabfaelleName: string = 'Biomüll'; // Braune Tonne
                    @manylopmy
                    das sollte rauskommen
                    21:40:36.919	info	javascript.0 (310140) script.js.common.Abfall_to_NSPanel: %Gelber Sack%
                    21:40:36.920	info	javascript.0 (310140) script.js.common.Abfall_to_NSPanel: %Papier%
                    21:40:36.920	info	javascript.0 (310140) script.js.common.Abfall_to_NSPanel: %Biomüll%
                    21:40:36.921	info	javascript.0 (310140) script.js.common.Abfall_to_NSPanel: %Hausmüll%
                      Sorry, welchesr logfile ist gemeint?
                      Ich glaube, da bin ich völlig falsch.
                        @manylopmy
                        kannst du mal den Inhalt vom Datenpunkt ical.0.data.table posten. muss mir mal die Rohdaten ansehen.
                          manylopmy last edited by manylopmy
                          gelöscht.
                            Ich glaube, das ist der logfile, den Du angeforderst hattest. Ich würde gerne den Inhalt des DP wieder löschen. Zu viele pers. Infos drin
                            2023-07-21 21:54:37.021  - info: javascript.0 (23580) script.js.common.Abfall_NSPanel_ts: %%
                            2023-07-21 21:54:37.023  - info: javascript.0 (23580) script.js.common.Abfall_NSPanel_ts: %%
                            2023-07-21 21:54:37.024  - info: javascript.0 (23580) script.js.common.Abfall_NSPanel_ts: %%
                            2023-07-21 21:54:37.185  - warn: trashschedule.0 (31389) (5) nextAfter has no entries. Check configuration of ical (increase preview) and trashschedule!
                            2023-07-21 21:54:42.173  - info: ical.0 (30556) Terminated (NO_ERROR): Without reason
                            2023-07-21 21:54:42.777  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                            code_text
                              @manylopmy
                              kannst dein Post löschen, wegen der Daten
                                @manylopmy
                                bitte die Parameter bei dir anpassen. dann den ical nochmal Neustarten und log posten
                                const idZeichenLoeschen: number = 0; // x Zeichen links vom String abziehen, wenn vor dem Eventname noch Text steht z.B. Strassenname; Standard = 0
                                const idRestmuellName: string = 'Restmüll 4wö'; // Schwarze Tonne
                                const idPappePapierName: string = 'Altpapier 4wö';  // Blaue Tonne
                                const idBioabfaelleName: string = 'Bio 2wö'; // Braune Tonne
                                  Ich glaube, das sieht besser aus. Jetzt sind die DP unter alias.0.nspanel.abfall alle mit Daten gefüllt. Ich sehe mir das gleich mal auf dem Panel an, welches leider nicht hier am Arbeitsplatz steht, glaube aber, das hat es gebracht. Vielen Dank für den Support.
                                  2023-07-21 22:11:18.531  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 32415
                                  2023-07-21 22:11:21.842  - info: ical.0 (32415) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v16.13.0, js-controller: 4.0.23
                                  2023-07-21 22:11:22.467  - info: ical.0 (32415) processing URL: calendar1 https://calendar.google.com/calendar/ical/9844e909dcfd49955c0fdd9d6c1ecf91246f838a8cb54c61192c9a1d48989a15%40group.calendar.google.com/private-a00087e2da83529a6d91077168a66fc0/basic.ics
                                  2023-07-21 22:11:22.552  - info: javascript.0 (23580) script.js.common.Abfall_NSPanel_ts: %Altpapier 4wö%
                                  2023-07-21 22:11:22.553  - info: javascript.0 (23580) script.js.common.Abfall_NSPanel_ts: %Gelber Sack%
                                  2023-07-21 22:11:22.553  - info: javascript.0 (23580) script.js.common.Abfall_NSPanel_ts: %Restabfall 4wö%
                                  2023-07-21 22:11:22.554  - info: javascript.0 (23580) script.js.common.Abfall_NSPanel_ts: %Bio 2wö%
                                  2023-07-21 22:11:22.643  - warn: trashschedule.0 (31389) (5) nextAfter has no entries. Check configuration of ical (increase preview) and trashschedule!
                                  2023-07-21 22:11:27.631  - info: ical.0 (32415) Terminated (NO_ERROR): Without reason
                                  2023-07-21 22:11:28.248  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                                    Bin soeben am Panel gewesen. So hatte ich es mir von der Darstellung vorgestellt. Nochmals Vielen Dank, super Hilfe.
                                      @manylopmy sagte in SONOFF NSPanel mit Lovelace UI:
                                      für dein Trashschedule musst du im iCal die Tagesvorschau auf mindestens 30 Tage setzen, dann sollte die Warnung weg sein
                                        australien @TT-Tom last edited by australien
                                        @tt-tom
                                        Hallo tt-tom,
                                        ich hab mir gestern die Weiterentwicklung 1.0.9 deines Skriptes (Fahrplan_to_NSPanel) geladen, Danke fürs weitermachen.
                                        Ich hätte noch einen Wunsch. Könnte man die Verspätungsmeldung nach einer bestimmten Zeit wieder automatisch löschen - nicht mehr anzeigen? Diese bleibt bis zur Bestätigung am Panel stehen.
                                          TT-Tom @australien last edited by
                                          @australien
                                          die erste Meldung sollte nach 10min wieder verschwinden
                                               //Bei Verspätung Daten für PopupNotifypage erzeugen und auslösen
                                                          if (Timedelay > Verspaetungszeit && VerspaetungPopup) {
                                                              setState(DP_NSPanel + 'popupNotify.popupNotifySleepTimeout', 600, true);            // number in sekunden 0 = aus
                                          und die Zusatzinfo nach 1min.
                                             console.log('jetzt kommmt Text 2' + Info + '%');
                                                              setTimeout(function () {
        setState(DP_NSPanel + 'popupNotify.popupNotifySleepTimeout', 60, true);
                                          • Gargano
                                            Gargano last edited by Gargano
                                            Mit JS Version 7.1.1 und JS-Controller 5.0.8 funktioniert icon_mapping.ts nicht mehr. Es genügt schon nur icon_mapping.ts zu starten und schon kommen seitenweise Fehler und alle JS - Instanzen stoppen. Icon_mapping.js funktioniert.
                                            Ich weiß es ist die Dev Version von JS, aber irgendwann wird die auch zu stable.
                                            80.8k
                                            lovelace ui nspanel sonoff
                                            270
                                            7633
                                            6291768
