    5. [gelöst] Payload Daten in Objekte schreiben
    • GregorS
      GregorS @Marc Berg last edited by
      Danke.
      Werde es mal die Tage probieren.
      GregorS 1 Reply Last reply Reply Quote 0
      • GregorS
        GregorS @GregorS last edited by
        Leider hat es nicht funktioniert.
        Beim Blockly kommen folgende Fehlermeldungen:
        avascript.0
        	2023-07-20 18:55:46.674	error	script.js.LoRaWAN_DEV_1: Cannot get AVI2_V of null
        javascript.0
        	2023-07-20 18:55:46.674	error	script.js.LoRaWAN_DEV_1: Cannot get ACI1_mA of undefined
        javascript.0
        	2023-07-20 18:53:46.292	error	script.js.LoRaWAN_DEV_1: Cannot get AVI2_V of null
        javascript.0
        	2023-07-20 18:53:46.292	error	script.js.LoRaWAN_DEV_1: Cannot get ACI1_mA of null
        javascript.0
        	2023-07-20 18:52:46.262	error	script.js.LoRaWAN_DEV_1: Cannot get AVI2_V of null
        javascript.0
        	2023-07-20 18:52:46.261	error	script.js.LoRaWAN_DEV_1: Cannot get ACI1_mA of undefined
        Habe es dann noch mit einem JS versucht (hier aus dem Forum).
        Alles angepasst, aber dies hat auch nicht funktioniert.
        javascript.0
        	2023-07-20 18:57:52.096	error	at Script.runInContext (node:vm:141:12)
        javascript.0
        	2023-07-20 18:57:52.096	error	at script.js.LoRAWAN_DEV_1:127:3
        javascript.0
        	2023-07-20 18:57:52.096	error	at script.js.LoRAWAN_DEV_1:1:1
        javascript.0
        	2023-07-20 18:57:52.095	error	script.js.LoRAWAN_DEV_1: ReferenceError: ttn_decode is not defined
        Wie deffiniere ich den TTN_decode?
        ttn_decode
        //Device
        createState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI_1", false, {
            read: true,
            write: false,
            desc: "",
            def: 0,
            unit: "mA",
            role: "",
            type: "number"
        createState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI_2", false, {
            read: true,
            write: false,
            desc: "",
            def: 0,
            unit: "mA",
            role: "",
            type: "number"
        createState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI_1", false, {
            read: true,
            write: false,
            desc: "",
            def: 0,
            unit: "V",
            role: "",
            type: "number"
        createState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI_2", false, {
            read: true,
            write: false,
            desc: "",
            def: 0,
            unit: "V",
            role: "",
            type: "number"
        //const fs = require('fs');
        on({id: 'v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/up', change: "ne"}, function (obj) {
            obj = JSON.parse(getState("v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/up").val);
            setState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI_1", parseFloat(obj["payload_fields"]["ACI1_mA"].toFixed(2)), true);
            setState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI_2", parseFloat(obj["payload_fields"]["ACI2_mA"].toFixed(2)), true);
            setState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI_1", parseFloat(obj["payload_fields"]["AVI1_V"].toFixed(2)), true);
            setState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI_2", parseFloat(obj["payload_fields"]["AVI2_V"].toFixed(2)), true);
            var file = "/opt/iobroker/ttn_log.csv";
            if(!fs.existsSync(file)) {
                fs.writeFileSync(file, "Time\tData\r\n");
            fs.appendFileSync(file, (new Date()).toISOString() + "\t" + getState("on({id: 'v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/up', change: "ne"}, function (obj) {
        ").val + "\r\n");
        Brauche da wohl ein bisschen Nachilfe.
          Homoran Global Moderator Administrators @GregorS last edited by
          @gregors sagte in Payload Daten in Objekte schreiben:
          Hast du die Überprüfung, ob der Inhalt existiert nicht umgesetzt?
          @marc-berg sagte in Payload Daten in Objekte schreiben:
          @paul53 sagte in Payload Daten in Objekte schreiben:
          Dann sollte man prüfen.
          ja, genau. Wenn man zum Beispiel einen Schaltbefehl als Downlink absetzt, bekommt man immer zwei Uplinks zurück. Einen mit Work_mode "Exit mode" und einen mit Work_Mode "2ACI+2AVI". Das ist zunächst etwas verwirrend, aber sicher der vielfältigen Möglichkeiten geschuldet, die man mit diesem Gerät hat.
          und hier die Lösung
          @marc-berg sagte: unterschiedliche Payloads
          • GregorS
            GregorS @Homoran last edited by GregorS
            Komme mit mit Blockly nicht klar.
            Muss ich die Variablen "payload","jason" vorher erstellen? Wo?
            Muss ich im Attribut "uplink_message...." den Pfad zu meinem Objekt reinkopieren?
            So sieht meine Struktur aus:
            Ich sende keine Befehle, sondern empfange nur welche von LoRaWan.
            Muss ich trotzdem die Abfrage machen?
            Irgendwie bin ich dazu zu blöd.
              paul53 @GregorS last edited by paul53
              @gregors sagte: Muss ich die Variablen "payload","jason" vorher erstellen? Wo?
              Die Variable payload muss unter "Variablen" erstellt werden.
              Der Datenpunkt "up" dient als Trigger:
              Wert findet man unter "Trigger".
                @gregors sagte: Brauche da wohl ein bisschen Nachilfe.
                const idUp = 'mqtt.2.v3.gs-mg-dragino-01@ttn.devices.eui-a840414601871305.up'/*v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/up*/;
                on(idUp, function (dp) {
                    let payload = JSON.parse(dp.state.val).uplink_message.decoded_paylod;
                    if(payload && payload.AVI1_V != undefined) {
                        setState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI_1", Math.round(payload.ACI1_mA * 100) / 100, true);
                        setState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI_2", Math.round(payload.ACI2_mA * 100) / 100, true);
                        setState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI_1", Math.round(payload.AVI1_V * 100) / 100, true);
                        setState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI_2", Math.round(payload.AVI2_V * 100) / 100, true);
                Zum Triggern muss die DP-ID - nicht der DP-Name - verwendet werden.
                • GregorS
                  Habe ich ausprobiert.
                  Keine Fehler mehr, aber es wird nichts in die Objekte geschrieben.
                    @gregors sagte: es wird nichts in die Objekte geschrieben.
                    Es wird getriggert, d.h. die ID stimmt?
                    • GregorS
                      GregorS @paul53 last edited by GregorS
                      Kann ich nicht erkennen.
                      Zur Auswahl unter ID bekam ich nur das Objekt UP angeboten.
                      on('mqtt.2.v3.gs-mg-dragino-01@ttn.devices.eui-a840414601871305.up', function (dp) {
                              setState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI1_mA", Math.round(payload.ACI1_mA * 100) / 100, true);
                              setState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI2_mA", Math.round(payload.ACI2_mA * 100) / 100, true);
                              setState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI1_V", Math.round(payload.AVI1_V * 100) / 100, true);
                              setState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI2_V", Math.round(payload.AVI2_V * 100) / 100, true);
                      Kann ich auch mit einem Schedule jede Minute triggern?
                        @gregors sagte: Objekt UP
                        Ändert sich der Inhalt? Es wird nur bei Wertänderung getriggert.
                        • GregorS
                          Der Wert im Payload ändert sich.
                          Allerdings nur AVI1_V, da es zur Zeit der einzige angeschlossene Wert ist.
                          Was bedeutet diese Zeile:
                          Es gibt doch 4 Variablen mit Daten.
                          Der Wert von 0_userdata.0.LoRaWAN.eui-a840414601871305.AVI1_V bleibt "0"
                          Habe ihn händisch als Datenpunkt "Number" angelegt.
                            @gregors sagte: Was bedeutet diese Zeile:
                            Es wird geprüft, ob das payload-Objekt vorhanden ist und ob es "AVI1_V" enthält.
                            Wenn "AVI1_V" enthalten ist, sind die anderen auch vorhanden.
                            Die Zeile 1 mit der ID ist hoffentlich als Kommentar gekennzeichnet?
                            • GregorS
                              Die Zeile 1 war natürlich nicht als Kommentar gekennzeichnet.
                              Habe ich aber nachgeholt.
                              Aber die Werte stehen immer noch auf 0
                              Fehler gibt es keine
                              //'mqtt.2.v3.gs-mg-dragino-01@ttn.devices.eui-a840414601871305.up'/*v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/up*/
                                Homoran Global Moderator Administrators @GregorS last edited by Homoran
                                @gregors bleibt noch die uralte Frage
                                @homoran sagte in Payload Daten in Objekte schreiben:
                                es kommen auch immer nur diese Attribute an?
                                bzw. nach dem Hinweis von
                                Nur ein kleiner Hinweis, der LT22222 hat die unangenehme Eigenschaft, abhängig vom "work_mode" unterschiedliche Payloads bereitzustellen.
                                die Variante:
                                was kommt da zurück?
                                u d zwar bei dedem Abruf?
                                • GregorS
                                  Ist eingestellt auf Work-Mode.
                                  {"end_device_ids":{"device_id":"eui-a840414601871305","application_ids":{"application_id":"gs-mg-dragino-01"},"dev_eui":"A840414601871305","join_eui":"A840410000000101","dev_addr":"260BE9CF"},"correlation_ids":["as:up:01H5YXJP5QRH1C5Q08ZD5DCSP3","gs:conn:01H5CGRTDQJ3EW5BPQ15D9SVP8","gs:up:host:01H5CGRTDY5KEGKQ0AQZ22XD9M","gs:uplink:01H5YXJNZ91PEK9H5YJ9MQ3KHY","ns:uplink:01H5YXJNZABG7H54KY0GZK1EHM","rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01H5YXJNZ9DDEYD157A8ZJ4MDJ","rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01H5YXJP5PHV0DBWATNA897E9W"],"received_at":"2023-07-22T13:45:43.350790106Z","uplink_message":{"session_key_id":"AYlu5XV3aMaeiMVAq8yISw==","f_port":2,"f_cnt":4181,"frm_payload":"NhMAAAAAAAA0/0E=","decoded_payload":{"ACI1_mA":0, "ACI2_mA":0, "%(#ff0000)[AVI1_V":13.843], "AVI2_V":0, "DI1_status":"L", "DI2_status":"H", "DO1_status":"H", "DO2_status":"H", "Hardware_mode":"LT22222", "RO1_status":"OFF", "RO2_status":"OFF", "Work_mode":"2ACI+2AVI"},"rx_metadata":[{"gateway_ids":{"gateway_id":"eui-503139534e7d4750","eui":"503139534E7D4750"},"time":"2023-07-22T13:45:35.699393Z","timestamp":518644732,"rssi":-104,"channel_rssi":-104,"snr":-16.75,"uplink_token":"CiIKIAoUZXVpLTUwMzEzOTUzNGU3ZDQ3NTASCFAxOVNOfUdQEPzHp/cBGgsIh7vvpQYQpY2KRSDgoIqNjN+MAQ==","channel_index":1,"received_at":"2023-07-22T13:45:43.144869029Z"}],"settings":{"data_rate":{"lora":{"bandwidth":125000, "spreading_factor":12, "coding_rate":"4/5"}}, "frequency":"868300000", "timestamp":518644732, "time":"2023-07-22T13:45:35.699393Z"},"received_at":"2023-07-22T13:45:43.146061623Z","consumed_airtime":"1.482752s","version_ids":{"brand_id":"dragino", "model_id":"lt22222-l", "hardware_version":"_unknown_hw_version_", "firmware_version":"1.5.6", "band_id":"EU_863_870"},"network_ids":{"net_id":"000013","tenant_id":"ttn","cluster_id":"eu1","cluster_address":"eu1.cloud.thethings.network"}}}
                                  {"end_device_ids":{"device_id":"eui-a840414601871305","application_ids":{"application_id":"gs-mg-dragino-01"},"dev_eui":"A840414601871305","join_eui":"A840410000000101","dev_addr":"260BE9CF"},"correlation_ids":["as:up:01H5YXZGAF6GPBPJ5YGPPSXD5G","gs:conn:01H5CGRTDQJ3EW5BPQ15D9SVP8","gs:up:host:01H5CGRTDY5KEGKQ0AQZ22XD9M","gs:uplink:01H5YXZG3X91BKRBXDNHEJCVKW","ns:uplink:01H5YXZG3ZTVCN6ZG22DTRD5F6","rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01H5YXZG3YM34J05XBMH8KEXC7","rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01H5YXZGAE19SK5WXQGSAY4RX2"],"received_at":"2023-07-22T13:52:43.342421706Z","uplink_message":{"session_key_id":"AYlu5XV3aMaeiMVAq8yISw==","f_port":2,"f_cnt":4188,"frm_payload":"NjsAAAAAAAA0/0E=","decoded_payload":{"ACI1_mA":0, "ACI2_mA":0, "%(#ff0000)[%(#ff0000)[***AVI1_V":13.883***]], "AVI2_V":0, "DI1_status":"L", "DI2_status":"H", "DO1_status":"H", "DO2_status":"H", "Hardware_mode":"LT22222", "RO1_status":"OFF", "RO2_status":"OFF", "Work_mode":"2ACI+2AVI"},"rx_metadata":[{"gateway_ids":{"gateway_id":"eui-503139534e7d4750","eui":"503139534E7D4750"},"time":"2023-07-22T13:52:35.686763Z","timestamp":938637580,"rssi":-109,"channel_rssi":-109,"snr":-15,"uplink_token":"CiIKIAoUZXVpLTUwMzEzOTUzNGU3ZDQ3NTASCFAxOVNOfUdQEIzyyb8DGgsIq77vpQYQ7pDNPyDgraPZqOuMAQ==","channel_index":3,"received_at":"2023-07-22T13:52:43.133384302Z"},{"gateway_ids":{"gateway_id":"eui-7076ff0056080b0f","eui":"7076FF0056080B0F"},"time":"2023-07-22T13:52:43.065Z","timestamp":2744651724,"rssi":-112,"channel_rssi":-112,"snr":-9.5,"uplink_token":"CiIKIAoUZXVpLTcwNzZmZjAwNTYwODBiMGYSCHB2/wBWCAsPEMyf4JwKGgsIq77vpQYQrK2YTCDg6fbP8OMjKgsIq77vpQYQwKT/Hg==","gps_time":"2023-07-22T13:52:43.065Z","received_at":"2023-07-22T13:52:42.856942638Z"}],"settings":{"data_rate":{"lora":{"bandwidth":125000, "spreading_factor":12, "coding_rate":"4/5"}}, "frequency":"867100000", "timestamp":938637580, "time":"2023-07-22T13:52:35.686763Z"},"received_at":"2023-07-22T13:52:43.135020669Z","consumed_airtime":"1.482752s","version_ids":{"brand_id":"dragino", "model_id":"lt22222-l", "hardware_version":"_unknown_hw_version_", "firmware_version":"1.5.6", "band_id":"EU_863_870"},"network_ids":{"net_id":"000013","tenant_id":"ttn","cluster_id":"eu1","cluster_address":"eu1.cloud.thethings.network"}}}
                                  Der Payload ist immer gleich.
                                  paul53 Marc Berg 2 Replies Last reply Reply Quote 0
                                    alle?
                                    avi2_v ist 0
                                    aci1_mA ebenfalls
                                    avi1_v hat 3 Asterisk davor u d wird deswegen nicht erkannt
                                      @gregors sagte: Der Payload ist immer gleich.
                                      ist ungültig und kann deshalb nicht geparst werden. In der zweiten Ausgabe sieht es noch schlimmer aus.
                                      • GregorS
                                        Habe zur Zeit nur den AVI1_V angeschlossen und DI2 gebrückt.
                                        Alle anderen Eingänge sind offen.
                                        Ist erstmal ein Test.
                                        @paul53 said in Payload Daten in Objekte schreiben:
                                        Bedeutet, ich kann es vergessen.
                                          @gregors sagte: Bedeutet, ich kann es vergessen.
                                          Es gibt dafür eine Ursache (beim Sender?), die behoben werden muss.
                                          Hier war das JSON noch in Ordnung.
                                          • Marc Berg
                                            Marc Berg Most Active @GregorS last edited by Marc Berg
                                            sowas hier:
                                            darf nicht im Payload enthalten sein und es ist mir ein Rätsel, wie das da rein kommt. Schau dir nochmal deinen Payload Formatter im TTN an. Da muss ein Fehler drin sein.
                                            Am besten den von hier nehmen:
                                            https://github.com/dragino/dragino-end-node-decoder/tree/main/LT22222-L
                                            Ggf. auch eine ältere Version.
                                            3603
