ZigBee neue Version 1.8.x
@schmuh ok dann verstehe ich das PROBLEM nicht..sry..
ok, gemacht: (da ist noch n Fehler von ner Missglueckten Anmeldung eines Tradfri drin, kannste ignorieren..)
2023-07-21 12:31:58.821 - info: zigbee.0 (444344) Starting Zigbee npm ... 2023-07-21 12:31:58.940 - info: zigbee.0 (444344) Installed Version: iobroker.zigbee@1.8.18 2023-07-21 12:31:58.763 - info: zigbee.0 (444344) starting. Version 1.8.18 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 5.0.8 2023-07-21 12:31:58.820 - info: zigbee.0 (444344) delete old Backup files. keep only last 10 2023-07-21 12:31:58.821 - info: zigbee.0 (444344) Starting Zigbee npm ... 2023-07-21 12:31:58.940 - info: zigbee.0 (444344) Installed Version: iobroker.zigbee@1.8.18 2023-07-21 12:32:00.412 - info: zigbee.0 (444344) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220219}} 2023-07-21 12:32:00.419 - info: zigbee.0 (444344) Unable to disable LED, unsupported function. 2023-07-21 12:32:00.427 - info: zigbee.0 (444344) --> transmitPower : high 2023-07-21 12:32:00.528 - info: zigbee.0 (444344) Currently 227 devices are joined: . . . 2023-07-21 12:32:00.951 - info: zigbee.0 (444344) Zigbee started 2023-07-21 12:32:01.100 - warn: zigbee.0 (444344) download icon Tradfri-1 for undefined Device not available. Check your devices. 2023-07-21 12:32:01.235 - info: zigbee.0 (444344) debug devices set to ["00158d0002278b91"] 2023-07-21 12:32:01.579 - error: zigbee.0 (444344) Device 0xf4b3b1fffe9e1f4d "undefined" not described in statesMapping. 2023-07-21 12:32:01.908 - warn: zigbee.0 (444344) ELEVATED publishToState: message received '{"available":true}' from device 00158d0002278b91 type 'RTCGQ01LM' 2023-07-21 12:32:01.909 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated 'true' from device 00158d0002278b91 for 'Available' 2023-07-21 12:32:01.909 - warn: zigbee.0 (444344) ELEVATED publishToState: message received '{"linkquality":10}' from device 00158d0002278b91 type 'RTCGQ01LM' 2023-07-21 12:32:01.909 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated '10' from device 00158d0002278b91 for 'Link quality' 2023-07-21 12:32:00.412 - info: zigbee.0 (444344) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220219}} 2023-07-21 12:32:00.419 - info: zigbee.0 (444344) Unable to disable LED, unsupported function. 2023-07-21 12:32:00.427 - info: zigbee.0 (444344) --> transmitPower : high 2023-07-21 12:32:00.528 - info: zigbee.0 (444344) Currently 227 devices are joined: . . . . . 2023-07-21 12:32:00.951 - info: zigbee.0 (444344) Zigbee started 2023-07-21 12:32:01.100 - warn: zigbee.0 (444344) download icon Tradfri-1 for undefined Device not available. Check your devices. 2023-07-21 12:32:01.235 - info: zigbee.0 (444344) debug devices set to ["00158d0002278b91"] 2023-07-21 12:32:01.579 - error: zigbee.0 (444344) Device 0xf4b3b1fffe9e1f4d "undefined" not described in statesMapping. 2023-07-21 12:32:01.908 - warn: zigbee.0 (444344) ELEVATED publishToState: message received '{"available":true}' from device 00158d0002278b91 type 'RTCGQ01LM' 2023-07-21 12:32:01.909 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated 'true' from device 00158d0002278b91 for 'Available' 2023-07-21 12:32:01.909 - warn: zigbee.0 (444344) ELEVATED publishToState: message received '{"linkquality":10}' from device 00158d0002278b91 type 'RTCGQ01LM' 2023-07-21 12:32:01.909 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated '10' from device 00158d0002278b91 for 'Link quality' . 2023-07-21 12:32:26.026 - warn: zigbee.0 (444344) ELEVATED publishToState: message received '{"linkquality":69}' from device 00158d0002278b91 type 'RTCGQ01LM' 2023-07-21 12:32:26.026 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated '69' from device 00158d0002278b91 for 'Link quality' 2023-07-21 12:32:26.027 - warn: zigbee.0 (444344) ELEVATED publishToState: message received '{"occupancy":true}' from device 00158d0002278b91 type 'RTCGQ01LM' 2023-07-21 12:32:26.027 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated 'true' from device 00158d0002278b91 for 'Occupancy' 2023-07-21 12:32:26.027 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated 'true' from device 00158d0002278b91 for 'Time from last motion' 2023-07-21 12:32:26.026 - warn: zigbee.0 (444344) ELEVATED publishToState: message received '{"linkquality":69}' from device 00158d0002278b91 type 'RTCGQ01LM' 2023-07-21 12:32:26.026 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated '69' from device 00158d0002278b91 for 'Link quality' 2023-07-21 12:32:26.027 - warn: zigbee.0 (444344) ELEVATED publishToState: message received '{"occupancy":true}' from device 00158d0002278b91 type 'RTCGQ01LM' 2023-07-21 12:32:26.027 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated 'true' from device 00158d0002278b91 for 'Occupancy' 2023-07-21 12:32:26.027 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated 'true' from device 00158d0002278b91 for 'Time from last motion' 2023-07-21 12:33:56.028 - warn: zigbee.0 (444344) ELEVATED publishToState: message received '{"occupancy":false}' from device 00158d0002278b91 type 'RTCGQ01LM' 2023-07-21 12:33:56.029 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated 'false' from device 00158d0002278b91 for 'Occupancy' 2023-07-21 12:33:56.029 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated 'false' from device 00158d0002278b91 for 'Time from last motion' 2023-07-21 12:33:56.028 - warn: zigbee.0 (444344) ELEVATED publishToState: message received '{"occupancy":false}' from device 00158d0002278b91 type 'RTCGQ01LM' 2023-07-21 12:33:56.029 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated 'false' from device 00158d0002278b91 for 'Occupancy' 2023-07-21 12:33:56.029 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated 'false' from device 00158d0002278b91 for 'Time from last motion' 2023-07-21 12:34:13.450 - warn: zigbee.0 (444344) ELEVATED publishToState: message received '{"linkquality":109}' from device 00158d0002278b91 type 'RTCGQ01LM' 2023-07-21 12:34:13.450 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated '109' from device 00158d0002278b91 for 'Link quality' 2023-07-21 12:34:13.451 - warn: zigbee.0 (444344) ELEVATED publishToState: message received '{"occupancy":true}' from device 00158d0002278b91 type 'RTCGQ01LM' 2023-07-21 12:34:13.451 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated 'true' from device 00158d0002278b91 for 'Occupancy' 2023-07-21 12:34:13.451 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated 'true' from device 00158d0002278b91 for 'Time from last motion' 2023-07-21 12:35:43.451 - warn: zigbee.0 (444344) ELEVATED publishToState: message received '{"occupancy":false}' from device 00158d0002278b91 type 'RTCGQ01LM' 2023-07-21 12:35:43.452 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated 'false' from device 00158d0002278b91 for 'Occupancy' 2023-07-21 12:35:43.452 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated 'false' from device 00158d0002278b91 for 'Time from last motion' 2023-07-21 12:35:43.451 - warn: zigbee.0 (444344) ELEVATED publishToState: message received '{"occupancy":false}' from device 00158d0002278b91 type 'RTCGQ01LM' 2023-07-21 12:35:43.452 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated 'false' from device 00158d0002278b91 for 'Occupancy' 2023-07-21 12:35:43.452 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated 'false' from device 00158d0002278b91 for 'Time from last motion' . . . 2023-07-21 12:36:20.089 - warn: zigbee.0 (444344) ELEVATED publishToState: message received '{"linkquality":91}' from device 00158d0002278b91 type 'RTCGQ01LM' 2023-07-21 12:36:20.089 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated '91' from device 00158d0002278b91 for 'Link quality' 2023-07-21 12:36:20.090 - warn: zigbee.0 (444344) ELEVATED publishToState: message received '{"occupancy":true}' from device 00158d0002278b91 type 'RTCGQ01LM' 2023-07-21 12:36:20.090 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated 'true' from device 00158d0002278b91 for 'Occupancy' 2023-07-21 12:36:20.091 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated 'true' from device 00158d0002278b91 for 'Time from last motion' 2023-07-21 12:36:20.089 - warn: zigbee.0 (444344) ELEVATED publishToState: message received '{"linkquality":91}' from device 00158d0002278b91 type 'RTCGQ01LM' 2023-07-21 12:36:20.089 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated '91' from device 00158d0002278b91 for 'Link quality' 2023-07-21 12:36:20.090 - warn: zigbee.0 (444344) ELEVATED publishToState: message received '{"occupancy":true}' from device 00158d0002278b91 type 'RTCGQ01LM' 2023-07-21 12:36:20.090 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated 'true' from device 00158d0002278b91 for 'Occupancy' 2023-07-21 12:36:20.091 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated 'true' from device 00158d0002278b91 for 'Time from last motion' . . . 2023-07-21 12:37:50.090 - warn: zigbee.0 (444344) ELEVATED publishToState: message received '{"occupancy":false}' from device 00158d0002278b91 type 'RTCGQ01LM' 2023-07-21 12:37:50.091 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated 'false' from device 00158d0002278b91 for 'Occupancy' 2023-07-21 12:37:50.091 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated 'false' from device 00158d0002278b91 for 'Time from last motion' 2023-07-21 12:37:50.090 - warn: zigbee.0 (444344) ELEVATED publishToState: message received '{"occupancy":false}' from device 00158d0002278b91 type 'RTCGQ01LM' 2023-07-21 12:37:50.091 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated 'false' from device 00158d0002278b91 for 'Occupancy' 2023-07-21 12:37:50.091 - warn: zigbee.0 (444344) ELEVATED publishToState: value generated 'false' from device 00158d0002278b91 for 'Time from last motion' -
@arteck sagte in ZigBee neue Version 1.8.x:
die null werte kannst du beschreiben.. womit kein plan
okay, hab ich gemacht (in der Beschreibung stehen Richtwerte), jedoch werden die Werte
,availablepresenceundtarget_distancenicht aktualisiert - und somit auch keine Bewegung erkannt, hier die Objekte:
Woran kann das liegen?
Edit: Nach Neustart wurde
availableaktualisiert -
@latzi sagte in ZigBee neue Version 1.8.x:
available,presenceundtarget_distancenicht aktualisiert - und somit auch keine Bewegung erkannt, hier die Objekte:
Moin,
dass Dein Device gerade nicht
availableist, ist Dir schon klar?VG
Bernd -
@dp20eic sagte in ZigBee neue Version 1.8.x:
dass Dein Device gerade nicht available ist, ist Dir schon klar?
das ist so nicht richtig,
link_qualityundilluminancewerden laufend aktualisiert -availablewurde erst nach einem Adapterstart wieder aktualisiert (hab´s oben alseditangemerkt) -
link_qualityundilluminancewerden laufend aktualisiert -availablewurde erst nach einem Adapterstart wieder aktualisiert (hab´s oben alseditangemerkt)Moin,
passt gerade nicht zu Deinem Problem, aber ich denke da ist auch noch etwas falsch mit dem Datenpunkt, wenn
Buttondann sollte da auch einer sein?
Hast Du mal den
zigbeeAdapter gestoppt, dann die DP im Objektbaum, gelöscht und zigbee gestartet um die Datenpunkte wieder neu zu Ersellen?VG
Bernd -
Hast Du mal den zigbee Adapter gestoppt, dann die DP im Objektbaum, gelöscht und zigbee gestartet um die Datenpunkte wieder neu zu Ersellen?
gerade gemacht, es bleibt leider unverändert:
Moin,
ich muss erst mal noch ein
tfür meinErsellenspendieren
Für
target_distancesteht ja in der BeschreibungTarget_distance (numeric) Distance to target. Value can be found in the published state on the target_distance property. It's not possible to read (/get) or write (/set) this value. The unit of this value is m.Kann das vielleicht mit der
radar_sensitivityzusammenhängen, dass da erst ein Güterzug erkannt wird?Radar_sensitivity (numeric) sensitivity of the radar. Value can be found in the published state on the radar_sensitivity property. It's not possible to read (/get) this value. To write (/set) a value publish a message to topic zigbee2mqtt/FRIENDLY_NAME/set with payload {"radar_sensitivity": NEW_VALUE}. The minimal value is 0 and the maximum value is 9.Hast Du da schon mal mit anderen Werten als 7 probiert?
Keine Ahnung wie aufwändig es ist, das Teil mal in die Tuya App,
ioBrokerTuya Adapter, zu bekommen, nur um zu schauen, ob es nicht defekt ist.VG
BerndP.S.: Muss mal die Regierung fragen, ob ich mir auch neues Spielzeug anschaffen darf, diese mmWave Teile interessieren mich schon, zumal normale BWM ja so, in manchen Situationen an ihre Grenzen stoßen.
@dp20eic
ja, ich hab die
radar_sensitivityrauf und runter gestellt - keine Änderung
Irgendwas bockt da noch, ich hab auch in diesem Thread gesehen, dass das "Problem" durch den Umstieg auf
zigbee2mgttgelöst wurde, vielleicht hat @arteck noch eine Idee woran das liegen könnte, bis dahin bleibe ich hoffnungsvoll und gehe von keinem defekten Sensor aus
.Mit Tuya kann ich das Teil nicht verbinden, da ich dafür ein extra zigbee-Gateway benötige (was ich nicht besitze) und das koppeln über Wifi schlägt fehl (hätte mich auch überrascht wenn´s funktioniert hätte).
Aus den Erfahrungen anderer hier im Forum glaube ich, dass der Sensor durchaus Potential hat - ich kann´s leider noch nicht beurteilen.
Irgendwas bockt da noch, ich hab auch in diesem Thread gesehen, dass das "Problem" durch den Umstieg auf zigbee2mgtt gelöst wurde, vielleicht hat @arteck noch eine Idee woran das liegen könnte, bis dahin bleibe ich hoffnungsvoll und gehe von keinem defekten Sensor aus
kann ja nicht .. da der sensor noch nicht im converter ist.. also kann der auch nicht im zigbee2mqtt funktionieren..
wie oben schon geschrieben..andere charge.. andere modlidder geht ja _TZE204_sxm7l9xa
ob deiner _TZE204_qasjif9e genauso funktioniert .. weiss ich nicht.. hab den nicht. solltest DU testen.. -
Hi, hast du in dem log was finden können?
kannst du mir bitte erklären, wie genau ich das Teil testen kann - mir fehlt dazu jegliche Kenntnis
Mit den derzeitigen Stand (Adapter von git und modifizierter tuya.js) werden zwar einige DP´s akutalisiert, leider nur nicht jene, die die Bewegung registrieren. -
@arteck Hi, ich habe seit heute morgen das Problem, dass mein Netzwerk nicht aufgebaut wird.
Der CC2652R wir erkannt aber keine Geräte werden verbunden.
Der Adapter ist gelb und beim Öffnen der Instanz-Einstellungen bekomme ich "You need save and run adapter before pairing!".Adapter v1.8.10
js-controller: 4.0.23
node: v16.19.1
npm: 8.19.3Ich habe im Netz gelesen, dass es irgendwie mit den PanID zusammenhängt und dass man alle Router (230V Geräte) ausschalten sollte, die PanID ändern sollte und dann alle Geräte neu anlernen?
Bevor ich nun irgendetwas ändere, die Frage, welche Möglichkeiten ich in Betracht ziehen sollte, buw. wie die korrekte Vorgehensweise ist?2023-07-22 12:51:10.957 error Error herdsman start zigbee.0 2023-07-22 12:51:10.957 error Failed to start Zigbee zigbee.0 2023-07-22 12:51:10.955 error Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby" -
adapter aus
den coordinator in alufolie einwickeln.. so dass kein signal rauskommen kann
adapter start und wartennach 5 min kannst die folie entfernen
@ilovegym nein leider nein
aber wo genau ist das Problem ?? die BWM's machen können nur lle 60 sek getriggert werden
@arteck ???
echt jetzt? Klingt logisch, aber auch AluHutTrägerisch
Das problem ist, dass occupancy immer nach 60sec auf false geht, obwohl in occupancy-timeout 120 steht..
Klar erkennen die erst nach 60 sek wieder aber das timeout wird nicht mehr beachtet..
@arteck Wann wird der "IKEA Rodet" im Zigbee Adapter Integriert.?
LG
@ilovegym ahhh jetzt verstehe ich das dilema
ja, wenn man durch den Flur laeuft, geht jetzt immer nach 60sec das Licht aus, obwohl der occupancy-timeout auf 120 steht, also vorher ist es einfach laenger eingeschaltet geblieben, und jetzt geht es aus, zwar gleich wieder an, aber n Moment steht / laeuft man durchs dunkel..
Der WAF ist stark gesunken und ich bekomme jeden Tag n Anschiss, wann das denn wieder richtig funktioniert...
