    4. E-INK Display OpenEPaperLink - Displayanzeige mit Batterie
    • GR
      GR @draexler last edited by
      @draexler
      hab jetzt mal ein CURL-Anfrage gebaut. Das JSON muss URL-Encoded werden. Ich schick das mit dem EXEC-Blockly raus.
       curl 'http://192.168.11.11/jsonupload' \
        -H 'Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7' \
        -H 'Accept-Language: de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7' \
        -H 'Cache-Control: no-cache' \
        -H 'Connection: keep-alive' \
        -H 'Content-Type: application/x-www-form-urlencoded' \
        -H 'Origin: http://192.168.11.11' \
        -H 'Pragma: no-cache' \
        -H 'Referer: http://192.168.11.11/jsontemplate-demo.html' \
        -H 'Upgrade-Insecure-Requests: 1' \
        -H 'User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36' \
        --data-raw 'mac=0000021EDC223B15&json=%5B%0D%0A++++%7B%22text%22%3A+%5B5%2C5%2C%22Bahnschrift+20%22%2C%22fonts%2Fbahnschrift20%22%2C1%5D%7D%2C%0D%0A++++%7B%22box%22%3A+%5B10%2C30%2C20%2C20%2C1%5D%7D%2C%0D%0A++++%7B%22box%22%3A+%5B35%2C30%2C20%2C20%2C2%5D%7D%2C%0D%0A++++%7B%22triangle%22%3A+%5B60%2C30%2C60%2C50%2C80%2C40%2C1%5D%7D%2C%0D%0A++++%7B%22text%22%3A+%5B5%2C80%2C%22Plain+text+glasstown_nbp_tf%22%2C%22glasstown_nbp_tf%22%2C1%5D%7D%2C%0D%0A++++%7B%22text%22%3A+%5B5%2C95%2C%22Plain+text+7x14_tf%22%2C%227x14_tf%22%2C2%5D%7D%2C%0D%0A++++%7B%22text%22%3A+%5B5%2C110%2C%22Plain+text+t0_14b_tf%22%2C%22t0_14b_tf%22%2C1%5D%7D%2C%0D%0A++++%7B%22text%22%3A+%5B135%2C5%2C%2230%22%2C%22fonts%2Fbahnschrift30%22%2C2%5D%7D%2C%0D%0A++++%7B%22text%22%3A+%5B215%2C5%2C%2270%22%2C%22fonts%2Fbahnschrift70%22%2C1%5D%7D%2C%0D%0A++++%7B%22text%22%3A+%5B150%2C80%2C%2250%22%2C%22fonts%2Fcalibrib50%22%2C2%2C0%5D%7D%2C%0D%0A++++%7B%22text%22%3A+%5B205%2C60%2C%2280%22%2C%22fonts%2Fcalibrib80%22%2C2%5D%7D%2C%0D%0A++++%7B%22text%22%3A+%5B90%2C35%2C%22calibrib30%22%2C%22fonts%2Fcalibrib30%22%2C1%5D%7D%2C%0D%0A++++%7B%22line%22%3A+%5B10%2C120%2C290%2C120%2C1%5D%7D%2C%0D%0A++++%7B%22line%22%3A+%5B10%2C115%2C290%2C115%2C2%5D%7D%0D%0A%5D%0D%0A++++++++++++' \
        --compressed \
        --insecure
      Das funktioniert jetzt mal für JSON-Inputs
      draexler 1 Reply Last reply Reply Quote 0
      • draexler
        draexler @GR last edited by draexler
        @gr super 👍 danke 👍 wie wäre dann der Aufbau der json url in im Tag selber?
        • draexler
          draexler @draexler last edited by draexler
          @GR Aber wenn ich richtige verstehe schiebst du das ganze in den jsonupload Ordner (in deinem Fall hat der AP die IP 192.168.11.11) und gibt in dem Dara-raw nur noch die MAC des Tags mit. Korrekt?! Aber wieso enthält dein Code Fragmente (oder Verweis keine Ahnung) auf das "jsontemplate-demo.html?
          Sorry für die doofen Fragen, aber das ist mir zu hoch....
          GR 1 Reply Last reply Reply Quote 0
          • GR
            GR @draexler last edited by GR
            @draexler Den Referrer könnte ich wahrscheinlich löschen. Ich hab den Datenverkehr kopiert, als ich über die Webseite "jsontemplate-demo.html" mein JSON hochgeladen habe.
            Dann hab ich das Ergebnis in einBlockly-Exec kopiert. Das hat funktioniert.
            Hier die Anleitung:
            https://everything.curl.dev/usingcurl/copyas
            • GR
              @draexler
              Die Seite musst Du im Browser aufrufen mit http://ip-deines-AP/jsontemplate-demo.html
              Hier kannst Du dann die Mac Deines Tags eingeben und das JSON mit dem Inhalt z.B.
                  {"box": [0,0,296,40,1]},
                  {"text": [46,10,"BATTERIESTAND","fonts/calibrib30",0]},
                  {"text": [82,40,"99","fonts/calibrib120",2]},
                  {"text": [200,102,"%","fonts/calibrib30",2]}
              • draexler
                @gr sagte in EPS E-INK Display Ansteuerung -> Statusdisplay für 2€:
                Ah, langsam wird ein Schuh draus und was kommt hier als URL?
                Gibt es eine Möglichkeiten damit auch mehrere Displays gleichzeitig mit dem gleichen Inhalt anzusteuern? Also nur unterschiedliche MAC Adressen?
                  bimmi @draexler last edited by
                  @draexler du könntest Dein Blockly dementsprechend einfach mehrerer "exec" hinzufügen. Aktuell wird aber an einer "Gruppierung" gearbeitet.
                  • draexler
                    draexler @bimmi last edited by
                    @bimmi Aktuell verfolge ich das ganze Thema ohne ioBroker. Und da finde ich die Eingabemöglichkeit bzw. das absenden der JSON innerhalb des AP als Perfekte Idee.
                    Aber was muss nun in das URL Feld im Tag? (Siehe Post davor)
                      @draexler ich habe mich mit dem json noch nicht beschäftigt. ich denke da muss gar nichts rein. einfach mal die jsonupload html mal testen. die funktioniert ja unabhängig.
                      • draexler
                        @bimmi Stimmt, GR hat ja gepostet 🙂 Dir natürlich auch Danke für die ganze Hilfe.
                          @draexler beschäftige mich ja selber erst seit 3 oder 4 wochen damit 😄
                          • O
                            oxident last edited by
                            Das Projekt ist wirklich toll. Kämpfe aber damit, es einfach im iobroker ansteuern zu können:
                            Screenshot einer bestimmten View vom Vis via Pupetteer scheitert, weil ich das Ergebnis nicht via Vis zur Verfügung stellen kann (landet bei mir im Redis und ich schaffe es nicht, die Datei in den richtigen Ordner zu schieben).
                            JSON klingt gut, aber da gehen keine Bilder 😞
                            Habt ihr noch Ideen?
                            • O
                              oxident @oxident last edited by oxident
                              Alles klar, habe es jetzt mal selber "gefrickelt". Hierzu habe ich im Vis eine View erstellt und mir dort als Hilfsmittel einen 296x128px Rahmen gezogen. Außerdem habe ich den Adapter "Puppeteer" installiert.
                              Im Vis tobe ich mich dann innerhalb des Rahmens aus und nutze folgendes Javascript:
                              sendTo('puppeteer.0', 'screenshot', {
                                  url: 'http://localhost:8082/vis/index.html#NAME_DER_VIEW',
                                  ioBrokerOptions: {
                                      storagePath: 'test.jpg',
                                    waitOption: {
                                      waitForTimeout: 5000,
                                    viewportOptions: {
                                      width: 296,
                                      height: 128
                                    type: "jpeg",
                                    quality: 100
                              }, obj => {
                                    if (obj.error) {
                                      log(`Error taking screenshot: ${obj.error.message}`, 'error');
                                    } else {
                                      log('Sucessfully took screenshot');
                                      sendImageToEPaper(obj.result, "MAC-VOM-DISPLAY");
                              function sendImageToEPaper(objImage, sMac) {
                                  var request = require('request');
                                  var options = {
                                          url: 'http://IP-VOM-AP/imgupload',
                                          method: 'POST',
                                          formData: {
                                              "dither": "0",
                                              "mac": sMac,
                                              "image": objImage },
                                  request(options,function (error, response, body){
                                          //log("Login-Antwort: " + JSON.stringify(response));
                                          if(parseInt(body.error_code)==0) {
                                          } else {
                              R 1 Reply Last reply Reply Quote 2
                                bimmi last edited by bimmi
                                @oxident so ähnlich mache ich es auch. setze aber die werte über die datenpunkte. mir wäre so ein script auch viel lieber bin aber eher der blockly fan 😄 und da komm ich nicht weiter mit clip usw...
                                mein blockly sieht so aus:
                                es holt die werte aus den datenpunkten und befüllt die datenpunkte vom puppeteer damit:
                                anschließend sende ich per curl einen refresh an den AP.
                                Gibt sicher bessere Lösungen aber so funktioniert es!
                                • O
                                  oxident @bimmi last edited by
                                  @bimmi Ahh, gut gelöst!
                                  Ist schon spannend, was man damit machen kann. Ich bin auch schwer begeistert davon, dass die Teilchen die gerenderte Vis so genial darstellen können. Damit habe ich maximale Flexibilität beim Gestalten der Oberfläche und kann vorhandene Widgets einfach übernehmen.
                                  Tolles Projekt 😊
                                    bimmi @oxident last edited by
                                    @oxident ja schon gut gelöst aber noch nicht optimal 😄 die Übertragung nervt mich noch, da ja zwei stellen sich unterschiedlich aktualisieren und pupetter nich 100% beim screenshot hat. das ist aber zwingend nötig, damit die Grafik nicht ausfranst.
                                    Ich will das ganze per embedded Script übers Blockly lösen- wie in diesem Beitrag: https://forum.iobroker.net/topic/54944/puppeteer-screenshots-phantomjs-alternative/205 - jedoch scheitert es da bei mir 😄 und die Antworten bzw. Hilfestellungen blieben bisher aus 😞
                                    Am liebsten wäre es mir mit dem sendto script puppeteer, dann bei der Meldung OK, schicke per curl an imgupload. Das wäre die beste Lösung, dann könnte man den AP auch entlasten!
                                    • draexler
                                      Allgemeine Frage… hat von euch auch jemand das Problem das der AP manchmal nach 10 Minuten, machmal aber erst nach Stunden nicht mehr erreichbar ist? Laut Router ist er auch nicht mehr verbunden. Ich habe ZWEI „MiniAPs“ gekauft über den Shop der hier schon öfters verlinkt worden ist und beide haben das selbe Problem.
                                        bimmi @draexler last edited by bimmi
                                        @draexler nein. Aber es gibt wohl einen Bug im esp32 Layout wo der wifi Sender vom Board den reset Knopf trigger 🙈 Abhilfe gibt es indem man die wifi DB reduziert auf 8 reduziert. Das geht mit der 1.6 beta Firmware! Auch die neuen s3 haben das Problem.
                                        https://www.wemos.cc/en/latest/c3/c3_mini_1_0_0.html
                                        Was sagt denn der serial log?
                                        • draexler
                                          @bimmi Log, sat leider nichts... Aber ich probiere es mal mit den DB Wert kleiner als 8. Ich berichte 🙂
                                            @draexler der serial log wenn du ihn direkt am Rechner hängen hast sagt nix? Mit terraterm oder so
                                            1028
                                            333253
