Adapter Hyundai (Bluelink) oder KIA (UVO)
Guten Morgen!
Kann mir einer sagen was dies bedeutet?
2023-07-20 11:45:05.839 - error: bluelink.0 (8379) undefined is not a valid state value 2023-07-20 11:45:05.848 - error: bluelink.0 (8379) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2023-07-20 11:45:05.849 - error: bluelink.0 (8379) unhandled promise rejection: undefined is not a valid state value 2023-07-20 11:45:05.850 - error: bluelink.0 (8379) Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at Bluelink._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5388:49) at Bluelink.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5349:21) at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:121:34) at async Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:253:17) at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:90:21) at async Bluelink.receiveEVInformation (/opt/iobroker/node_modules/iobroker.bluelink/main.js:383:17) at async ae. (/opt/iobroker/node_modules/iobroker.bluelink/main.js:222:25) 2023-07-20 11:45:05.851 - error: bluelink.0 (8379) undefined is not a valid state value 2023-07-20 11:45:06.306 - error: bluelink.0 (8379) Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717.consumption.devices": DB closed 2023-07-20 11:45:06.307 - warn: bluelink.0 (8379) Could not perform strict object check of state bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717.consumption.engine: DB closed 2023-07-20 11:45:06.309 - warn: bluelink.0 (8379) get state error: Connection is closed. 2023-07-20 11:45:06.310 - error: bluelink.0 (8379) Error: Could not check object existence of bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717.consumption.devices: Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717.consumption.devices": DB closed 2023-07-20 11:45:06.314 - error: bluelink.0 (8379) Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717.consumption.battery": Connection is closed. 2023-07-20 11:45:06.316 - error: bluelink.0 (8379) Error: Could not check object existence of bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717.consumption.battery: Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717.consumption.battery": Connection is closed. 2023-07-20 11:45:06.445 - error: host.raspberrypi instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)Nach dem Start des Adapters haut mir diese Fehlermeldung 3x ins log, danach schließt ioBroker automatisch den Adapter.
Adapterversionen: 2.3.5/2.3.2
Plattform:
linux
Betriebssystem:
linux
Architektur:
arm
CPUs:
Geschwindigkeit:
1500 MHz
Modell:
unknown
RAM:
3.7 GB
System-Betriebszeit:
9 T. 05:14:06
Node.js:
v18.17.0
time:
1689846274481
Adapter-Anzahl:
563
NPM:
9.6.7
Datenträgergröße:
14.3 GB
Freier Festplattenspeicher:
6.4 GB
Betriebszeit:
05:02:18
Aktive Instanzen:
35
Pfad:
/opt/iobroker/
aktiv:
_nodeCurrent:
18.17.0
_nodeNewest:
18.17.0
_nodeNewestNext:
18.17.0
_npmCurrent:
9.6.7
_npmNewest:
9.6.7
_npmNewestNext:
9.6.7 -
@michaelnorge Bitte mal auf debug stellen.
@newan Habe ich hier vorliegen - kann ich Dir das per Mail oder so senden? Sind ne haufen Infos drinne die ich nicht alle rausgefiltert bekomme.
Bräuchte dann eine Emailaddy von Dir
@michaelnorge ALSO
ersmal adapter von Git installieren dann dann alle Objekte löschen
dann adapter startenfalls jetzt zum Abbruch kommt ..l den abbruch Posten..
die Stelle passt nicht zum sourcode was du da hast..
@arteck Frische Installation oder drüber installieren?
Hab ich gemacht, jetzt die Version 2.3.5.
Das Problem besteht weiterhin. Bluelink versucht 3x zu starten und wird dann vom Host gestoppt.
2023-07-20 13:37:37.076 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.consumption.total is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json 2023-07-20 13:37:37.080 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer. 2023-07-20 13:37:37.092 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2023-07-20 13:37:37.093 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value 2023-07-20 13:37:37.097 - error: bluelink.0 (12152) Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at Bluelink._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5388:49) at Bluelink.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5349:21) at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:121:34) at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:92:21) at async Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:253:17) at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:90:21) at async Bluelink.driveHistory (/opt/iobroker/node_modules/iobroker.bluelink/main.js:444:17) at async Te. (/opt/iobroker/node_modules/iobroker.bluelink/main.js:272:29) 2023-07-20 13:37:37.098 - error: bluelink.0 (12152) undefined is not a valid state value 2023-07-20 13:37:37.106 - warn: bluelink.0 (12152) Terminated (UNCAUGHT_EXCEPTION): Without reason 2023-07-20 13:37:37.108 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.consumption.engine is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json 2023-07-20 13:37:37.109 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer. 2023-07-20 13:37:37.118 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2023-07-20 13:37:37.119 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value 2023-07-20 13:37:37.120 - error: bluelink.0 (12152) Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at Bluelink._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5388:49) at Bluelink.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5349:21) at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:121:34) at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:92:21) at async Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:253:17) at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:90:21) at async Bluelink.driveHistory (/opt/iobroker/node_modules/iobroker.bluelink/main.js:444:17) at async Te. (/opt/iobroker/node_modules/iobroker.bluelink/main.js:272:29) 2023-07-20 13:37:37.121 - error: bluelink.0 (12152) undefined is not a valid state value 2023-07-20 13:37:37.125 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.consumption.climate is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json 2023-07-20 13:37:37.126 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer. 2023-07-20 13:37:37.141 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2023-07-20 13:37:37.141 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value 2023-07-20 13:37:37.142 - error: bluelink.0 (12152) Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at Bluelink._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5388:49) at Bluelink.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5349:21) at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:121:34) at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:92:21) at async Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:253:17) at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:90:21) at async Bluelink.driveHistory (/opt/iobroker/node_modules/iobroker.bluelink/main.js:444:17) at async Te. (/opt/iobroker/node_modules/iobroker.bluelink/main.js:272:29) 2023-07-20 13:37:37.142 - error: bluelink.0 (12152) undefined is not a valid state value 2023-07-20 13:37:37.147 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.consumption.devices is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json 2023-07-20 13:37:37.149 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer. 2023-07-20 13:37:37.162 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2023-07-20 13:37:37.162 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value 2023-07-20 13:37:37.163 - error: bluelink.0 (12152) Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at Bluelink._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5388:49) at Bluelink.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5349:21) at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:121:34) at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:92:21) at async Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:253:17) at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:90:21) at async Bluelink.driveHistory (/opt/iobroker/node_modules/iobroker.bluelink/main.js:444:17) at async Te. (/opt/iobroker/node_modules/iobroker.bluelink/main.js:272:29) 2023-07-20 13:37:37.163 - error: bluelink.0 (12152) undefined is not a valid state value 2023-07-20 13:37:37.169 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.consumption.battery is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json 2023-07-20 13:37:37.169 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer. 2023-07-20 13:37:37.185 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2023-07-20 13:37:37.186 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value 2023-07-20 13:37:37.187 - error: bluelink.0 (12152) Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at Bluelink._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5388:49) at Bluelink.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5349:21) at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:121:34) at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:92:21) at async Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:253:17) at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:90:21) at async Bluelink.driveHistory (/opt/iobroker/node_modules/iobroker.bluelink/main.js:444:17) at async Te. (/opt/iobroker/node_modules/iobroker.bluelink/main.js:272:29) 2023-07-20 13:37:37.187 - error: bluelink.0 (12152) undefined is not a valid state value 2023-07-20 13:37:37.191 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.regen is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json 2023-07-20 13:37:37.192 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer. 2023-07-20 13:37:37.215 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2023-07-20 13:37:37.216 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value 2023-07-20 13:37:37.217 - error: bluelink.0 (12152) Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at Bluelink._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5388:49) at Bluelink.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5349:21) at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:121:34) at async Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:253:17) at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:90:21) at async Bluelink.driveHistory (/opt/iobroker/node_modules/iobroker.bluelink/main.js:444:17) at async Te. (/opt/iobroker/node_modules/iobroker.bluelink/main.js:272:29) 2023-07-20 13:37:37.217 - error: bluelink.0 (12152) undefined is not a valid state value 2023-07-20 13:37:37.221 - warn: bluelink.0 (12152) Object bluelink.0.XXXXXXXXXXXXXXX.driveHistory.cumulated03.distance is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json 2023-07-20 13:37:37.221 - warn: bluelink.0 (12152) This object will not be created in future versions. Please report this to the developer. 2023-07-20 13:37:37.238 - error: bluelink.0 (12152) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2023-07-20 13:37:37.239 - error: bluelink.0 (12152) unhandled promise rejection: undefined is not a valid state value 2023-07-20 13:37:37.239 - error: bluelink.0 (12152) Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at Bluelink._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5388:49) at Bluelink.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5349:21) at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:121:34) at async Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:253:17) at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:90:21) at async Bluelink.driveHistory (/opt/iobroker/node_modules/iobroker.bluelink/main.js:444:17) at async Te. (/opt/iobroker/node_modules/iobroker.bluelink/main.js:272:29) 2023-07-20 13:37:37.240 - error: bluelink.0 (12152) undefined is not a valid state value 2023-07-20 13:37:37.623 - error: bluelink.0 (12152) Error: Connection is closed. 2023-07-20 13:37:37.625 - error: bluelink.0 (12152) Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230718.regen": Connection is closed. 2023-07-20 13:37:37.627 - error: bluelink.0 (12152) Error: Could not check object existence of bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230718.regen: Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230718.regen": Connection is closed. 2023-07-20 13:37:37.629 - error: bluelink.0 (12152) Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230718.distance": Connection is closed. 2023-07-20 13:37:37.632 - error: bluelink.0 (12152) Error: Could not check object existence of bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230718.distance: Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230718.distance": Connection is closed. 2023-07-20 13:37:37.634 - error: bluelink.0 (12152) Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717": Connection is closed. 2023-07-20 13:37:37.636 - error: bluelink.0 (12152) Error: Could not check object existence of bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717: Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717": Connection is closed. 2023-07-20 13:37:37.638 - error: bluelink.0 (12152) Cannot check object existence of "bluelink.0.XXXXXXXXXXXXXXX.driveHistory.20230717.period": Connection is closed. 2023-07-20 13:37:37.759 - error: host.raspberrypi instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION) 2023-07-20 13:37:37.759 - info: host.raspberrypi Restart adapter system.adapter.bluelink.0 because enabledMich stört das nicht wirklich, zur Not ziehe ich ein Backup von Gestern rein - wäre aber cool zu erfahren wieso das passiert ist
Ich meine ich hätte den JS-Controller upgedated (jetzt v18.17.0)
@michaelnorge mach erstmal in den Einstellungen den EV teil aus( links unten) . da passt was nicht.. dann sollte zumindest der adapter wieder starten
ansonten kannst nochmal von GIT isntallieren..
@arteck Mir war das zu heikel und ich habe direkt nach meinem letzten Post ne 10 Tage alte Version drüber gezogen, noch bevor ich angefangen bin, mit den Betas rumzuspielen.
Vielleicht habe ich einfach was falsch gemacht, vielleicht melden sich auch noch andere hier mit dem gleichen Problem. Sry das ich Dir nicht helfen kann
ich hab da mal was gebastelt damit die Datenpunkte stimmen, bei MHEV/PHEV oder Benziner/Diesel
die können die Klima nicht einschalten
die Motorvariante dementsprechend einstellen ..sonst startet der Adapter nicht.. meldung im LOG beachten
ansonsten kann man jetzt auch fore_login durchführen.. ohne den adapter neu starten zu müssen
ALLE Steuerrungsdatenpunkte sind umgezogen in Control.. bitte adapter Datenpunkte löschen .. damit diese an der richtigen stelle neu erstellt werden
force_update wurde korrigiert.. war als button deklariert..
@arteck
Vielen Dank für das Update, funktioniert alles perfekt
(EV: Kia EV6) -
@michael-loddoch
Mit Version 2.3.5 funktioniert es jetzt. Dankeschön! -
Seit heute morgen 0 Uhr, hat noch jemand die Probleme?
Bluelink App geht aber ohne Problemebluelink.0 2023-07-29 09:18:27.129 error Server is not available or login credentials are wrong bluelink.0 2023-07-29 09:18:27.128 error ManagedBluelinkyError: @EuropeController.getVehicles: [401] Unauthorized on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v1/spa/vehicles - {"retCode":"F","resCode":"4017","resMsg":"Invalid request value - Invalid Application Id. - 32437.111000061035","msgId":"973b7063-9c26-433e-9532-f4c5316b5bdb"} bluelink.0 2023-07-29 09:18:21.185 info Login to api bluelink.0 2023-07-29 09:18:21.140 info starting. Version 2.3.2 (non-npm: Newan/ioBroker.bluelink) in /opt/iobroker/node_modules/iobroker.bluelink, node: v18.15.0, js-controller: 4.0.24 -
@bigal sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
Jap, kommt immer mal wieder vor, die Server spacken mal wieder rum.
@bigal Jepp, hier das Gleiche (Norwegen)
Edit: Ist aber gut das hier im Forum jemand bescheid sagt. Das schließt dann automatisch einen anderen Fehler aus
@bigal @arteck
Ich glaube das liegt an einem Problem der hyundai_kia_Connect_api. Es waren wohl auch andere Programm betroffen.: =>
https://github.com/Hyundai-Kia-Connect/hyundai_kia_connect_api/releases/tag/v3.4.0Habe leider zu wenig Ahnung um das Problem genau nachzuvollziehen. Bei mir besteht es auf alle Fälle weiterhin.
@ron-1 Ja bei mir auch unverändert....
Bei mir funktioniert es seit 11:14 Uhr wieder. Mal sehen wie lang
Hier läufts auch wieder…
@meister-mopper Ja hier auch
