    4. Node-Red
    5. 2 Werte Subtrtahieren in Node Red
      siporax @mickym last edited by
      @mickym said in 2 Werte Subtrtahieren in Node Red:
      @siporax Wie gesagt das brauchst Du nur, wenn Dir der Tech-Pow trigger nicht ausreicht. 😉 Sonst langt die einfache Lösung. 😉
      Setze mich später gleich man dran an das ganze.Melde mich dann wieder.
      • mickym
        mickym Most Active @siporax last edited by
        @siporax Die einfache Lösung nur mit der Trigger des Sonoff - war hier (sind nur 4 Nodes): https://forum.iobroker.net/post/1019849
          So habs soweit übernommen u d angepasst läuft aber nicht bzw schreib keine Daten in den Broker da steht immer Null
                  "id": "78f6b708eb6bd2fe",
                  "type": "tab",
                  "label": "Realer Teichverbrauch",
                  "disabled": false,
                  "info": "",
                  "env": []
                  "id": "4e110ac9e3526a1d",
                  "type": "ioBroker in",
                  "z": "78f6b708eb6bd2fe",
                  "name": "Teich-Pow",
                  "topic": "sonoff.0.Teich-Verbrauch.ENERGY_Power",
                  "payloadType": "value",
                  "onlyack": "",
                  "func": "all",
                  "gap": "",
                  "fireOnStart": "false",
                  "outFormat": "MQTT",
                  "x": 120,
                  "y": 100,
                  "wires": [
                          "e6795d8dc9d84fcc"
                  "id": "be61f3942177482d",
                  "type": "ioBroker get",
                  "name": "WR-Fritz",
                  "topic": "fritzdect.0.DECT_116570079058.power",
                  "attrname": "wr",
                  "errOnInvalidState": "nothing",
                  "x": 520,
                  "y": 100,
                  "wires": [
                          "719b166cf1c4cf56"
                  "id": "719b166cf1c4cf56",
                  "type": "change",
                  "name": "TeichPow - WR",
                  "rules": [
                          "t": "set",
                          "p": "payload",
                          "pt": "msg",
                          "to": "verbrauch - wr",
                          "tot": "jsonata"
                  "action": "",
                  "property": "",
                  "from": "",
                  "to": "",
                  "reg": false,
                  "x": 700,
                  "y": 140,
                  "wires": [
                          "2528507974039f88",
                          "ec4528823eccb390"
                  "id": "2528507974039f88",
                  "type": "ioBroker out",
                  "d": true,
                  "name": "Realer_Teichverbrauch",
                  "topic": "0_userdata.0.Node_Red_Realer_Teichverbrauch",
                  "ack": "true",
                  "autoCreate": "false",
                  "stateName": "",
                  "role": "",
                  "payloadType": "",
                  "readonly": "",
                  "stateUnit": "",
                  "stateMin": "",
                  "stateMax": "",
                  "x": 950,
                  "y": 180,
                  "wires": []
                  "id": "ec4528823eccb390",
                  "type": "debug",
                  "name": "Ergebnis nur payload",
                  "active": true,
                  "tosidebar": true,
                  "console": false,
                  "tostatus": false,
                  "complete": "payload",
                  "targetType": "msg",
                  "statusVal": "",
                  "statusType": "auto",
                  "x": 940,
                  "y": 140,
                  "wires": []
                  "id": "e6795d8dc9d84fcc",
                  "type": "change",
                  "name": "",
                  "rules": [
                          "t": "move",
                          "p": "payload",
                          "pt": "msg",
                          "to": "verbrauch",
                          "tot": "msg"
                  "action": "",
                  "property": "",
                  "from": "",
                  "to": "",
                  "reg": false,
                  "x": 320,
                  "y": 100,
                  "wires": [
                          "be61f3942177482d"
                  "id": "5413c6e8e87d1659",
                  "name": "WR-Fritz",
                  "onlyack": "",
                  "func": "all",
                  "gap": "",
                  "x": 120,
                  "y": 180,
                  "wires": [
                          "e857e6e86301279a"
                  "id": "8e2c30a2834a5bc7",
                  "attrname": "verbrauch",
                  "x": 530,
                  "y": 180,
                  "wires": [
                          "719b166cf1c4cf56"
                  "id": "e857e6e86301279a",
                  "type": "change",
                  "name": "",
                  "rules": [
                          "t": "move",
                          "p": "payload",
                          "pt": "msg",
                          "to": "wr",
                          "tot": "msg"
                  "action": "",
                  "property": "",
                  "from": "",
                  "to": "",
                  "reg": false,
                  "x": 320,
                  "y": 180,
                  "wires": [
                          "8e2c30a2834a5bc7"
            siporax @siporax last edited by
            @siporax said in 2 Werte Subtrtahieren in Node Red:
                    "type": "tab",
                    "disabled": false,
                    "info": "",
                    "env": []
                    "onlyack": "",
                    "func": "all",
                    "gap": "",
                    "x": 120,
                    "y": 100,
                    "wires": [
                            "e6795d8dc9d84fcc"
                    "name": "WR-Fritz",
                    "attrname": "wr",
                    "x": 520,
                    "y": 100,
                    "wires": [
                            "719b166cf1c4cf56"
                    "type": "change",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "tot": "jsonata"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 700,
                    "y": 140,
                    "wires": [
                            "2528507974039f88",
                            "ec4528823eccb390"
                    "d": true,
                    "ack": "true",
                    "stateName": "",
                    "role": "",
                    "payloadType": "",
                    "readonly": "",
                    "stateUnit": "",
                    "stateMin": "",
                    "stateMax": "",
                    "x": 950,
                    "y": 180,
                    "wires": []
                    "type": "debug",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 940,
                    "y": 140,
                    "wires": []
                    "type": "change",
                    "name": "",
                    "rules": [
                            "t": "move",
                            "p": "payload",
                            "pt": "msg",
                            "to": "verbrauch",
                            "tot": "msg"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 320,
                    "y": 100,
                    "wires": [
                            "be61f3942177482d"
                    "name": "WR-Fritz",
                    "onlyack": "",
                    "func": "all",
                    "gap": "",
                    "x": 120,
                    "y": 180,
                    "wires": [
                            "e857e6e86301279a"
                    "x": 530,
                    "y": 180,
                    "wires": [
                            "719b166cf1c4cf56"
                    "type": "change",
                    "name": "",
                    "rules": [
                            "t": "move",
                            "p": "payload",
                            "pt": "msg",
                            "to": "wr",
                            "tot": "msg"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 320,
                    "y": 180,
                    "wires": [
                            "8e2c30a2834a5bc7"
            • mickym
              mickym Most Active @siporax last edited by mickym
              @siporax Ja dann mach mal ein Screenshot und zeig den Status bzw. mach Debug Nodes dran. Wenn 100-100 = 0 rauskommt, dann ist das ja richtig.
              Und es stimmt ja nicht, dass er nichts schreibt:
              Der Datenpunkt wurde um 14:34 heute beschrieben.
              S geschild 2 Replies Last reply Reply Quote 0
                • mickym
                  @siporax Na dann kommt doch das Ergebnis raus. Du musst doch nur die iobroker-Out Node wieder aktivieren.
                  Die Debug Node kannst wieder wegschmeissen - das ist doch nur zur Fehlersuche bzw. zur Demonstration. Und wie gesagt - ich sehe die Sonoff Node trigger meistens - dann könntest auch die einfache Lösung mit den 4 Nodes nehmen:
                        "id": "1abbb3ad15f02df1",
                        "z": "289f539dcc33814e",
                        "onlyack": "",
                        "func": "all",
                        "gap": "",
                        "x": 2440,
                        "y": 4320,
                        "wires": [
                                "db726a38cace8780"
                        "id": "db726a38cace8780",
                        "name": "WR-Fritz",
                        "attrname": "wr",
                        "x": 2600,
                        "y": 4320,
                        "wires": [
                                "5a663fa76121848c"
                        "id": "5a663fa76121848c",
                        "type": "change",
                        "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "to": "payload - wr",
                                "tot": "jsonata"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 2780,
                        "y": 4320,
                        "wires": [
                                "086dd9b2dd01f025"
                        "id": "086dd9b2dd01f025",
                        "ack": "true",
                        "stateName": "",
                        "role": "",
                        "payloadType": "",
                        "readonly": "",
                        "stateUnit": "",
                        "stateMin": "",
                        "stateMax": "",
                        "x": 3010,
                        "y": 4320,
                        "wires": []
                  • geschild
                    geschild @mickym last edited by
                    @mickym
                    Sorry: </> Code einfügen hab ich kapiert, aber wie daraus einen Spoiler macht ???
                    Egal. Code in .txt. Habe mal die topics in flow Variable gepackt. Jetzt braucht man die iobrokerIn/Out nur noch wie gewohnt mit den DP verbinden.
                    Könnte man das so machen. (Ich lerne gern dazu)
                    • mickym
                      mickym Most Active @geschild last edited by
                      @geschild Den Spoiler machst Du mit dem Auge. 😉
                      code_text
                      Dann innerhalb des Spoilers die Code Tags:
                      • mickym
                        mickym Most Active @geschild last edited by mickym
                        @geschild So nun zu Deinem Flow. 😉
                        Das wird zwar so funktionieren - aber in dem Fall finde ich es übertrieben Flow variablen zu setzen, nur um das topic zu vereinfachen. Insbesondere ändert sich der Wert dieser Flowvariablen ja nie. Das würde nur Sinn machen, wenn Du unabhängig die Initialisierung triggern würdest. Dann lieber wieder das topic direkt setzen:
                               "id": "c32a0a1f4a2b9221",
                               "topic": "0_userdata.0.TeichMinus.Teich-Pow",
                               "onlyack": "",
                               "func": "all",
                               "gap": "",
                               "outFormat": "ioBroker",
                               "x": 180,
                               "y": 560,
                               "wires": [
                                       "f85da542bcf883c8"
                               "id": "eceba02fa565ce76",
                               "name": "WR-Fritz",
                               "topic": "0_userdata.0.TeichMinus.WR-Fritz",
                               "onlyack": "",
                               "func": "all",
                               "gap": "",
                               "x": 180,
                               "y": 640,
                               "wires": [
                                       "363c25994833957b"
                               "id": "11f59eb25158b200",
                               "name": "Ergebnis",
                               "topic": "0_userdata.0.TeichMinus.Ergebnis",
                               "ack": "false",
                               "stateName": "",
                               "role": "",
                               "payloadType": "",
                               "readonly": "",
                               "stateUnit": "",
                               "stateMin": "",
                               "stateMax": "",
                               "x": 840,
                               "y": 600,
                               "wires": []
                               "id": "9a2bda7d9bbb1ca2",
                               "type": "function",
                               "name": "wrFritz - teichPow",
                               "func": "var topic = msg.topic;\nvar teichPow;\nvar wrFritz;\nvar ergebnis;\n\nvar teichPow = context.get('teichPowData') || 0;;\nvar wrFritz = context.get('wrFritzData') || 0;;\n\n\nif (topic == 'teichPowTopic') {\n//if (topic == \"0_userdata.0.TeichMinus.Teich-Pow\") {\n    teichPow = parseInt(msg.payload);\n    context.set('teichPowData', teichPow)\n}\n\nif (topic == 'wrFritzTopic') {\n//if (topic == \"0_userdata/0/TeichMinus/WR-Fritz\") {\n    wrFritz = parseInt(msg.payload);\n    context.set('wrFritzData', wrFritz) \n}\n\nergebnis = wrFritz - teichPow;\nmsg.payload = ergebnis;\nreturn msg;\n\n\n",
                               "outputs": 1,
                               "noerr": 0,
                               "initialize": "",
                               "finalize": "",
                               "libs": [],
                               "x": 610,
                               "y": 600,
                               "wires": [
                                       "11f59eb25158b200"
                               "id": "f85da542bcf883c8",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "topic",
                                       "pt": "msg",
                                       "to": "teichPowTopic",
                                       "tot": "str"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 380,
                               "y": 560,
                               "wires": [
                                       "9a2bda7d9bbb1ca2"
                               "id": "363c25994833957b",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "topic",
                                       "pt": "msg",
                                       "to": "wrFritzTopic",
                                       "tot": "str"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 380,
                               "y": 640,
                               "wires": [
                                       "9a2bda7d9bbb1ca2"
                        geschild 1 Reply Last reply Reply Quote 0
                        • geschild
                          @mickym Ist klar, aber wollte @siporax das Leben leichter machen.
                          • mickym
                            Übrigens Deine Function Node 😉
                            flow.set('teichPowTopic', topic);
                            msg.payload = flow.get('teichPowTopic');
                            return msg;
                            kann man auch mit einer ChangeNode ohne Codieren machen. 😉
                            Das macht das Gleiche:
                              siporax @mickym last edited by siporax
                              return msg;
                              So habs zum rechnen gebracht steht zwar ein minus davor im Zielordner beim Ergebnis aber damit kann ich leben.
                                     "type": "tab",
                                     "disabled": false,
                                     "info": "",
                                     "env": []
                                     "onlyack": "",
                                     "func": "all",
                                     "gap": "",
                                     "x": 120,
                                     "y": 100,
                                     "wires": [
                                             "e6795d8dc9d84fcc"
                                     "name": "WR-Fritz",
                                     "attrname": "wr",
                                     "x": 520,
                                     "y": 100,
                                     "wires": [
                                             "719b166cf1c4cf56"
                                     "type": "change",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "tot": "jsonata"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 700,
                                     "y": 140,
                                     "wires": [
                                             "2528507974039f88"
                                     "ack": "true",
                                     "stateName": "",
                                     "role": "",
                                     "payloadType": "",
                                     "readonly": "",
                                     "stateUnit": "",
                                     "stateMin": "",
                                     "stateMax": "",
                                     "x": 950,
                                     "y": 140,
                                     "wires": []
                                     "type": "change",
                                     "name": "",
                                     "rules": [
                                             "t": "move",
                                             "p": "payload",
                                             "pt": "msg",
                                             "to": "verbrauch",
                                             "tot": "msg"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 320,
                                     "y": 100,
                                     "wires": [
                                             "be61f3942177482d"
                                     "name": "WR-Fritz",
                                     "onlyack": "",
                                     "func": "all",
                                     "gap": "",
                                     "x": 120,
                                     "y": 180,
                                     "wires": [
                                             "e857e6e86301279a"
                                     "x": 530,
                                     "y": 180,
                                     "wires": [
                                             "719b166cf1c4cf56"
                                     "type": "change",
                                     "name": "",
                                     "rules": [
                                             "t": "move",
                                             "p": "payload",
                                             "pt": "msg",
                                             "to": "wr",
                                             "tot": "msg"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 320,
                                     "y": 180,
                                     "wires": [
                                             "8e2c30a2834a5bc7"
                              • geschild
                                geschild @mickym last edited by geschild
                                @mickym Danke. Wie gesagt, komme vom Script und muss mir die Möglichkeiten von nodered erst aneignen. Schönen Sonntag noch.
                                PS. Kannst du mir den elektrischen Aufbau von @siporax erklären?
                                • mickym
                                  @siporax Das Minus kannst Du eliminieren, wenn Du die Subtraktion umdrehst oder halt den absoluten Wert nimmst.
                                  Um den absoluten Wert zu erhalten - einfach die ChangeNode wie folgt ändern:
                                  Oder alternativ mit -1 multiplizieren also
                                  (payload-wr) * -1
                                  • mickym
                                    @geschild sagte in 2 Werte Subtrtahieren in Node Red:
                                    Nee - das muss @siporax selbst machen - ich bin nur für die Logik in NodeRed zuständig. 😉
                                      Habe eine Warnmeldungen
                                        Wenn Wechselrichter ausgeschaltet ist hat der Teich dennoch Verbrauch der wird mir nicht dan angezeigt ?
                                        • mickym
                                          @siporax
                                          1. Also Du musst halt vorher mit der Logik klar kommen. Die Warnmeldungen kommen, weil Du versucht hast einen schreibgeschützten Wert im Sonoff Adapter zu beschreiben - das darfst Du halt nicht. Überprüfe Deine iobroker-Out Nodes. Bis auf die Werte, die Du zum Steuern verwendest, darf sonst nur der Adapter was reinschreiben.
                                          Schreibgeschütze Werte erkennst Du an dem Schloss:
                                          1. Ich hab Dir ja gesagt Du sollst die einfache Variante nehmen und dann kannst Du wenn Du keinen Verbrauch auch 0 schreiben und den Wechselrichter ignorieren.
                                                 "id": "18edda87f3b39f3e",
                                                 "z": "7e6af0015415146d",
                                                 "onlyack": "",
                                                 "func": "all",
                                                 "gap": "",
                                                 "x": 2080,
                                                 "y": 3600,
                                                 "wires": [
                                                         "0ebf71f32dd2b609"
                                                 "id": "f0133d29a83f3d17",
                                                 "name": "WR-Fritz",
                                                 "attrname": "wr",
                                                 "x": 2400,
                                                 "y": 3660,
                                                 "wires": [
                                                         "746280ddaeb139a2"
                                                 "id": "746280ddaeb139a2",
                                                 "type": "change",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "to": "(payload - wr) * -1",
                                                         "tot": "jsonata"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 2580,
                                                 "y": 3660,
                                                 "wires": [
                                                         "1e4d02d4327046e2"
                                                 "id": "1e4d02d4327046e2",
                                                 "ack": "true",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 2810,
                                                 "y": 3580,
                                                 "wires": []
                                                 "id": "0ebf71f32dd2b609",
                                                 "type": "switch",
                                                 "name": "Verbrauch > 0",
                                                 "property": "payload",
                                                 "propertyType": "msg",
                                                 "rules": [
                                                         "t": "eq",
                                                         "v": "0",
                                                         "vt": "num"
                                                         "t": "gt",
                                                         "v": "0",
                                                         "vt": "num"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 2,
                                                 "x": 2260,
                                                 "y": 3600,
                                                 "wires": [
                                                         "1e4d02d4327046e2"
                                                         "f0133d29a83f3d17"
                                            @siporax
                                                   "onlyack": "",
                                                   "func": "all",
                                                   "gap": "",
                                                   "x": 2080,
                                                   "y": 3600,
                                                   "wires": [
                                                           "0ebf71f32dd2b609"
                                                   "name": "WR-Fritz",
                                                   "attrname": "wr",
                                                   "x": 2400,
                                                   "y": 3660,
                                                   "wires": [
                                                           "746280ddaeb139a2"
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "payload",
                                                           "pt": "msg",
                                                           "tot": "jsonata"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 2580,
                                                   "y": 3660,
                                                   "wires": [
                                                           "1e4d02d4327046e2"
                                                   "ack": "true",
                                                   "stateName": "",
                                                   "role": "",
                                                   "payloadType": "",
                                                   "readonly": "",
                                                   "stateUnit": "",
                                                   "stateMin": "",
                                                   "stateMax": "",
                                                   "x": 2810,
                                                   "y": 3580,
                                                   "wires": []
                                                   "type": "switch",
                                                   "rules": [
                                                           "t": "eq",
                                                           "v": "0",
                                                           "vt": "num"
                                                           "t": "gt",
                                                           "v": "0",
                                                           "vt": "num"
                                                   "checkall": "true",
                                                   "repair": false,
                                                   "outputs": 2,
                                                   "x": 2260,
                                                   "y": 3600,
                                                   "wires": [
                                                           "1e4d02d4327046e2"
                                                           "f0133d29a83f3d17"
                                            Versuche das morgen in Ruhe nochmal.
                                            bekomme ich damit immer den Teichverbrauch angezeigt auch wenn der Wechselrichter nicht läuft ?
                                            4381
