    4. backitup Fehlermeldung
      maximinus @Thomas Braun last edited by
      Ich greife das Thema nocheinmal auf. Nach Befolgung deiner Hinweise zeigt die Telegram Nachricht über das nächtliche Backup immer noch die selben Warnungen, obwohl die Backups alle auber gespeichert werden. Im Zusammenhanfg mit einer Aktualisierung des am selben Raspberry laufenden evcc, bekomme ich nach sudo apt update diese Warnungen:
      pi@raspberrypi:~ $ Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
      W: An error occurred during the signature verification. The repository is not up        dated and the previous index files will be used. GPG error: https://repos.influx        data.com/debian bullseye InRelease: The following signatures couldn't be verifie        d because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: An error occurred during the signature verification. The repository is not up        dated and the previous index files will be used. GPG error: https://packages.gra        fana.com/oss/deb stable InRelease: The following signatures couldn't be verified        because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
      W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease        The following signatures couldn't be verified because the public key is not avai        lable: NO_PUBKEY 9E439B102CF3C0C6
      W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease
      Nach Studium dieses Links scheint mir deren Behebeung als Linux Neuling zu kompliziert (gefährlich)
      https://itsfoss.com/apt-key-deprecated/
      sudo apt keylist bringt diese Ausgabe
      pi@raspberrypi:~ $ sudo apt-key list
      /etc/apt/trusted.gpg
      pub   rsa2048 2012-04-01 [SC]
            A0DA 38D0 D76E 8B5D 6388  7281 9165 938D 90FD DD2E
      uid           [ unknown] Mike Thompson (Raspberry Pi Debian armhf ARMv6+VFP) <mpthompson@gmail.com>
      sub   rsa2048 2012-04-01 [E]
      pub   rsa4096 2015-09-28 [SC]
            05CE 1508 5FC0 9D18 E99E  FB22 684A 14CF 2582 E0C5
      uid           [ unknown] InfluxDB Packaging Service <support@influxdb.com>
      sub   rsa4096 2015-09-28 [E]
      /etc/apt/trusted.gpg.d/raspberrypi-archive-stable.gpg
      pub   rsa2048 2012-06-17 [SC]
            CF8A 1AF5 02A2 AA2D 763B  AE7E 82B1 2992 7FA3 303E
      uid           [ unknown] Raspberry Pi Archive Signing Key
      sub   rsa2048 2012-06-17 [E]
      Gibt es eine einfachere Möglichkeit diese Warnungen zu beseitigen oder soll man das so lassen?
      Vielleicht hat das auch etwas mit den nicht endenden Fehlermeldungen des backitup adapters zu tun.
      LG Gerhard
        Thomas Braun Most Active @maximinus last edited by
        @maximinus
        https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
          Danke habe ich alles gemacht. da kommt aber jetzt das:
          pi@raspberrypi:~ $ sudo apt update
          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:3 https://apt.grafana.com stable InRelease
          Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
          Get:5 https://dl.cloudsmith.io/public/evcc/stable/deb/raspbian bullseye InRelease [5,127 B]
          Ign:6 https://repos.influxdata.com/raspbian bullseye InRelease
          Err:7 https://repos.influxdata.com/raspbian bullseye Release
            404  Not Found [IP: 18.66.26.28 443]
          Reading package lists... Done
          E: The repository 'https://repos.influxdata.com/raspbian bullseye Release' does not have a Release file.
          N: Updating from such a repository can't be done securely, and is therefore disabled by default.
          N: See apt-secure(8) manpage for repository creation and user configuration details.
          pi@raspberrypi:~ $
          Hast Du dafür auch eine Lösung?
            @maximinus
            Ähnliche Übung für das influx-Repository.
            Steht in dem Thread etwas später drin.
              maximinus @Thomas Braun last edited by maximinus
              Ich habe alles gelesen aber leider kapier ichs nicht
              mach ich das:
              sudo apt-key del 05CE15085FC09D18E99EFB22684A14CF2582E0C5
              kommt:
              pi@raspberrypi:~ $ sudo apt-key del 05CE15085FC09D18E99EFB22684A14CF2582E0C5
              OK
              pi@raspberrypi:~ $
              rm /etc/apt/sources.list.d/influxdata.list
              da kommt das:
              pi@raspberrypi:~ $ rm /etc/apt/sources.list.d/influxdata.list
              rm: cannot remove '/etc/apt/sources.list.d/influxdata.list': No such file or directory
              pi@raspberrypi:~ $
              dann:
              wget -q -O - https://repos.influxdata.com/influxdb.key | sudo gpg --dearmor -o /usr/share/keyrings/influxdb.gpg
              export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc)
              echo "deb [signed-by=/usr/share/keyrings/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null
              File '/usr/share/keyrings/influxdb.gpg' exists. Overwrite? (y/N) y
              da kommt nichts und dann immer noch der gleiche Fehler:
              Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
              Hit:4 https://apt.grafana.com stable InRelease
              Ign:5 https://repos.influxdata.com/raspbian bullseye InRelease
              Get:6 https://dl.cloudsmith.io/public/evcc/stable/deb/raspbian bullseye InRelease [5,127 B]
              pi@raspberrypi:~ $
              dann:
              pi@raspberrypi:~ $ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
              pi@raspberrypi:~ $ gpg --with-fingerprint  --show-keys ./inluxdata-archive_compat.key
              gpg: directory '/home/pi/.gnupg' created
              gpg: keybox '/home/pi/.gnupg/pubring.kbx' created
              gpg: can't open './inluxdata-archive_compat.key': No such file or directory
              pi@raspberrypi:~ $ cat /etc/apt/sources.list.d/influx*
              deb [signed-by=/usr/share/keyrings/influxdb.gpg] https://repos.influxdata.com/raspbian bullseye stable
              pi@raspberrypi:~ $ cat /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg
              cat: /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg: No such file or directory
              pi@raspberrypi:~ $ gpg --with-fingerprint --show-keys ./influxdata-archive_compat.key
              pub   rsa4096 2023-01-18 [SC] [expires: 2026-01-17]
                    9D53 9D90 D332 8DC7 D6C8  D3B9 D8FF 8E1F 7DF8 B07E
              uid                      InfluxData Package Signing Key <support@influxdata.com>
              Ich denke das sieht nicht schlecht aus aber nach neu booten kommt nach sudo apt update die gleiche Meldung wie bisher. Irgend etwas muss ich übersehen haben.
              Eben merke ich da ist ein Schreibfehler "inlux" satt "influx". Aber auch bei richtiger Schreibweise bleibt der Fehler
              LG Gerhard
                Thomas Braun Most Active @maximinus last edited by Thomas Braun
                @maximinus
                ls -lah /etc/apt/sources.list.d/
                apt-key list | grep -i influx
                sagt?
                  pi@raspberrypi:~ $ ls -lah /etc/apt/sources.list.d/
                  total 28K
                  drwxr-xr-x 2 root root 4.0K Jun 20 13:25 .
                  drwxr-xr-x 8 root root 4.0K Jul 23 11:43 ..
                  -rw-r--r-- 1 root root  418 Jun 20 13:25 evcc-stable.list
                  -rw-r--r-- 1 root root   84 Jul 23 11:37 grafana.list
                  -rw-r--r-- 1 root root  103 Jul 23 18:08 influxdb.list
                  -rw-r--r-- 1 root root  208 Aug 23  2022 nodesource.list
                  -rw-r--r-- 1 root root  191 Apr  4  2022 raspi.list
                  pi@raspberrypi:~ $
                    @maximinus
                    sudo rm /etc/apt/sources.list.d/influxdb.list
                    echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
                    echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                    rm influxdata-archive_compat.key
                      Danke Thomas das wars
                      pi@raspberrypi:~ $ apt list --upgradable
                      Listing... Done
                      grafana/stable 10.0.2 armhf [upgradable from: 9.1.3]
                      N: There are 237 additional versions. Please use the '-a' switch to see them.
                      pi@raspberrypi:~ $
                      Ist es ratsam auf 10.0.2 zu wechseln? ich bin bei influxdb noch auf version1.x
                        A Former User @maximinus last edited by
                        @maximinus sagte in backitup Fehlermeldung:
                        Moin,
                        verwechselst Du da was?
                        Grafana ≠ influx
                        VG
                        Bernd
                          maximinus @Guest last edited by
                          @dp20eic
                          Grafana verarbeitet doch die Daten aus der influxdb. Es wäre ja möglich dass eine neue Version von Grafana auch eine neue Version von influxdb bedingt. Da ich bisher aber nichts vermisse würde ich lieber alles so lassen wie es ist. Es sei denn es wäre dringend angeraten doch upzugraden. Das war gemeint.
                          LG Gerhard
                            @maximinus
                            Updates sind zeitnah einzuspielen.
                              @maximinus
                              Was spuckt ein
                              sudo apt update
                              jetzt aus?
                                maximinus last edited by maximinus
                                Hit:3 https://repos.influxdata.com/debian stable InRelease
                                Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                                Fetched 5,127 B in 2s (3,290 B/s)
                                Building dependency tree... Done
                                1 package can be upgraded. Run 'apt list --upgradable' to see it.
                                pi@raspberrypi:~ $
                                Daher die Frage.
                                  @maximinus
                                  Ja, zieh die Version auf den letzten Stand.
                                  31.7k
                                  79.7k
                                  2040
