    4. backitup Fehlermeldung
      maximinus @Thomas Braun last edited by maximinus
      Ich habe alles gelesen aber leider kapier ichs nicht
      mach ich das:
      sudo apt-key del 05CE15085FC09D18E99EFB22684A14CF2582E0C5
      kommt:
      pi@raspberrypi:~ $ sudo apt-key del 05CE15085FC09D18E99EFB22684A14CF2582E0C5
      Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
      OK
      pi@raspberrypi:~ $
      rm /etc/apt/sources.list.d/influxdata.list
      da kommt das:
      pi@raspberrypi:~ $ rm /etc/apt/sources.list.d/influxdata.list
      rm: cannot remove '/etc/apt/sources.list.d/influxdata.list': No such file or directory
      pi@raspberrypi:~ $
      dann:
      wget -q -O - https://repos.influxdata.com/influxdb.key | sudo gpg --dearmor -o /usr/share/keyrings/influxdb.gpg
      export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc)
      echo "deb [signed-by=/usr/share/keyrings/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null
      File '/usr/share/keyrings/influxdb.gpg' exists. Overwrite? (y/N) y
      da kommt nichts und dann immer noch der gleiche Fehler:
      pi@raspberrypi:~ $ sudo apt update
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
      Hit:4 https://apt.grafana.com stable InRelease
      Ign:5 https://repos.influxdata.com/raspbian bullseye InRelease
      Get:6 https://dl.cloudsmith.io/public/evcc/stable/deb/raspbian bullseye InRelease [5,127 B]
      Err:7 https://repos.influxdata.com/raspbian bullseye Release
        404  Not Found [IP: 18.66.26.28 443]
      Reading package lists... Done
      E: The repository 'https://repos.influxdata.com/raspbian bullseye Release' does not have a Release file.
      N: Updating from such a repository can't be done securely, and is therefore disabled by default.
      N: See apt-secure(8) manpage for repository creation and user configuration details.
      pi@raspberrypi:~ $
      dann:
      pi@raspberrypi:~ $ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
      pi@raspberrypi:~ $ gpg --with-fingerprint  --show-keys ./inluxdata-archive_compat.key
      gpg: directory '/home/pi/.gnupg' created
      gpg: keybox '/home/pi/.gnupg/pubring.kbx' created
      gpg: can't open './inluxdata-archive_compat.key': No such file or directory
      pi@raspberrypi:~ $ cat /etc/apt/sources.list.d/influx*
      deb [signed-by=/usr/share/keyrings/influxdb.gpg] https://repos.influxdata.com/raspbian bullseye stable
      pi@raspberrypi:~ $ cat /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg
      cat: /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg: No such file or directory
      pi@raspberrypi:~ $ gpg --with-fingerprint --show-keys ./influxdata-archive_compat.key
      pub   rsa4096 2023-01-18 [SC] [expires: 2026-01-17]
            9D53 9D90 D332 8DC7 D6C8  D3B9 D8FF 8E1F 7DF8 B07E
      uid                      InfluxData Package Signing Key <support@influxdata.com>
      Ich denke das sieht nicht schlecht aus aber nach neu booten kommt nach sudo apt update die gleiche Meldung wie bisher. Irgend etwas muss ich übersehen haben.
      Eben merke ich da ist ein Schreibfehler "inlux" satt "influx". Aber auch bei richtiger Schreibweise bleibt der Fehler
      LG Gerhard
        Thomas Braun Most Active @maximinus last edited by Thomas Braun
        @maximinus
        ls -lah /etc/apt/sources.list.d/
        apt-key list | grep -i influx
        sagt?
          pi@raspberrypi:~ $ ls -lah /etc/apt/sources.list.d/
          total 28K
          drwxr-xr-x 2 root root 4.0K Jun 20 13:25 .
          drwxr-xr-x 8 root root 4.0K Jul 23 11:43 ..
          -rw-r--r-- 1 root root  418 Jun 20 13:25 evcc-stable.list
          -rw-r--r-- 1 root root   84 Jul 23 11:37 grafana.list
          -rw-r--r-- 1 root root  103 Jul 23 18:08 influxdb.list
          -rw-r--r-- 1 root root  208 Aug 23  2022 nodesource.list
          -rw-r--r-- 1 root root  191 Apr  4  2022 raspi.list
          pi@raspberrypi:~ $
            @maximinus
            sudo rm /etc/apt/sources.list.d/influxdb.list
            echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
            echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
            rm influxdata-archive_compat.key
              Danke Thomas das wars
              pi@raspberrypi:~ $ apt list --upgradable
              Listing... Done
              grafana/stable 10.0.2 armhf [upgradable from: 9.1.3]
              N: There are 237 additional versions. Please use the '-a' switch to see them.
              pi@raspberrypi:~ $
              Ist es ratsam auf 10.0.2 zu wechseln? ich bin bei influxdb noch auf version1.x
                A Former User @maximinus last edited by
                @maximinus sagte in backitup Fehlermeldung:
                Moin,
                verwechselst Du da was?
                Grafana ≠ influx
                VG
                Bernd
                  maximinus @Guest last edited by
                  @dp20eic
                  Grafana verarbeitet doch die Daten aus der influxdb. Es wäre ja möglich dass eine neue Version von Grafana auch eine neue Version von influxdb bedingt. Da ich bisher aber nichts vermisse würde ich lieber alles so lassen wie es ist. Es sei denn es wäre dringend angeraten doch upzugraden. Das war gemeint.
                  LG Gerhard
                    @maximinus
                    Updates sind zeitnah einzuspielen.
                      @maximinus
                      Was spuckt ein
                      sudo apt update
                      jetzt aus?
                        maximinus last edited by maximinus
                        Hit:3 https://repos.influxdata.com/debian stable InRelease
                        Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                        Fetched 5,127 B in 2s (3,290 B/s)
                        Building dependency tree... Done
                        1 package can be upgraded. Run 'apt list --upgradable' to see it.
                        pi@raspberrypi:~ $
                        Daher die Frage.
                          @maximinus
                          Ja, zieh die Version auf den letzten Stand.
                          2864
