    4. Node-Red
    5. 2 Werte Subtrtahieren in Node Red
      siporax @mickym last edited by siporax
      @mickym said in 2 Werte Subtrtahieren in Node Red:
      Übrigens Deine Function Node 😉
      var topic = msg.topic;
      flow.set('teichPowTopic', topic);
      msg.payload = flow.get('teichPowTopic');
      return msg;
      kann man auch mit einer ChangeNode ohne Codieren machen. 😉
      Das macht das Gleiche:
      So habs zum rechnen gebracht steht zwar ein minus davor im Zielordner beim Ergebnis aber damit kann ich leben.
             "id": "78f6b708eb6bd2fe",
             "type": "tab",
             "label": "Realer Teichverbrauch",
             "disabled": false,
             "info": "",
             "env": []
             "id": "4e110ac9e3526a1d",
             "type": "ioBroker in",
             "z": "78f6b708eb6bd2fe",
             "name": "Teich-Pow",
             "topic": "sonoff.0.Teich-Verbrauch.ENERGY_Power",
             "payloadType": "value",
             "onlyack": "",
             "func": "all",
             "gap": "",
             "fireOnStart": "false",
             "outFormat": "MQTT",
             "x": 120,
             "y": 100,
             "wires": [
                     "e6795d8dc9d84fcc"
             "id": "be61f3942177482d",
             "type": "ioBroker get",
             "name": "WR-Fritz",
             "topic": "fritzdect.0.DECT_116570079058.power",
             "attrname": "wr",
             "errOnInvalidState": "nothing",
             "x": 520,
             "y": 100,
             "wires": [
                     "719b166cf1c4cf56"
             "id": "719b166cf1c4cf56",
             "type": "change",
             "name": "TeichPow - WR",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "verbrauch - wr",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 700,
             "y": 140,
             "wires": [
                     "2528507974039f88"
             "id": "2528507974039f88",
             "type": "ioBroker out",
             "name": "Realer_Teichverbrauch",
             "topic": "0_userdata.0.Node_Red_Realer_Teichverbrauch",
             "ack": "true",
             "autoCreate": "false",
             "stateName": "",
             "role": "",
             "payloadType": "",
             "readonly": "",
             "stateUnit": "",
             "stateMin": "",
             "stateMax": "",
             "x": 950,
             "y": 140,
             "wires": []
             "id": "e6795d8dc9d84fcc",
             "type": "change",
             "name": "",
             "rules": [
                     "t": "move",
                     "p": "payload",
                     "pt": "msg",
                     "to": "verbrauch",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 320,
             "y": 100,
             "wires": [
                     "be61f3942177482d"
             "id": "5413c6e8e87d1659",
             "name": "WR-Fritz",
             "onlyack": "",
             "func": "all",
             "gap": "",
             "x": 120,
             "y": 180,
             "wires": [
                     "e857e6e86301279a"
             "id": "8e2c30a2834a5bc7",
             "attrname": "verbrauch",
             "x": 530,
             "y": 180,
             "wires": [
                     "719b166cf1c4cf56"
             "id": "e857e6e86301279a",
             "type": "change",
             "name": "",
             "rules": [
                     "t": "move",
                     "p": "payload",
                     "pt": "msg",
                     "to": "wr",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 320,
             "y": 180,
             "wires": [
                     "8e2c30a2834a5bc7"
      • geschild
        geschild @mickym last edited by geschild
        @mickym Danke. Wie gesagt, komme vom Script und muss mir die Möglichkeiten von nodered erst aneignen. Schönen Sonntag noch.
        PS. Kannst du mir den elektrischen Aufbau von @siporax erklären?
        • mickym
          mickym Most Active @siporax last edited by mickym
          @siporax Das Minus kannst Du eliminieren, wenn Du die Subtraktion umdrehst oder halt den absoluten Wert nimmst.
          Um den absoluten Wert zu erhalten - einfach die ChangeNode wie folgt ändern:
          Oder alternativ mit -1 multiplizieren also
          (payload-wr) * -1
          • mickym
            mickym Most Active @geschild last edited by
            @geschild sagte in 2 Werte Subtrtahieren in Node Red:
            Nee - das muss @siporax selbst machen - ich bin nur für die Logik in NodeRed zuständig. 😉
              Habe eine Warnmeldungen
                siporax @siporax last edited by
                @siporax said in 2 Werte Subtrtahieren in Node Red:
                Wenn Wechselrichter ausgeschaltet ist hat der Teich dennoch Verbrauch der wird mir nicht dan angezeigt ?
                • mickym
                  @siporax
                  1. Also Du musst halt vorher mit der Logik klar kommen. Die Warnmeldungen kommen, weil Du versucht hast einen schreibgeschützten Wert im Sonoff Adapter zu beschreiben - das darfst Du halt nicht. Überprüfe Deine iobroker-Out Nodes. Bis auf die Werte, die Du zum Steuern verwendest, darf sonst nur der Adapter was reinschreiben.
                  Schreibgeschütze Werte erkennst Du an dem Schloss:
                  1. Ich hab Dir ja gesagt Du sollst die einfache Variante nehmen und dann kannst Du wenn Du keinen Verbrauch auch 0 schreiben und den Wechselrichter ignorieren.
                         "id": "18edda87f3b39f3e",
                         "z": "7e6af0015415146d",
                         "onlyack": "",
                         "func": "all",
                         "gap": "",
                         "x": 2080,
                         "y": 3600,
                         "wires": [
                                 "0ebf71f32dd2b609"
                         "id": "f0133d29a83f3d17",
                         "name": "WR-Fritz",
                         "attrname": "wr",
                         "x": 2400,
                         "y": 3660,
                         "wires": [
                                 "746280ddaeb139a2"
                         "id": "746280ddaeb139a2",
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "(payload - wr) * -1",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 2580,
                         "y": 3660,
                         "wires": [
                                 "1e4d02d4327046e2"
                         "id": "1e4d02d4327046e2",
                         "ack": "true",
                         "stateName": "",
                         "role": "",
                         "payloadType": "",
                         "readonly": "",
                         "stateUnit": "",
                         "stateMin": "",
                         "stateMax": "",
                         "x": 2810,
                         "y": 3580,
                         "wires": []
                         "id": "0ebf71f32dd2b609",
                         "type": "switch",
                         "name": "Verbrauch > 0",
                         "property": "payload",
                         "propertyType": "msg",
                         "rules": [
                                 "t": "eq",
                                 "v": "0",
                                 "vt": "num"
                                 "t": "gt",
                                 "v": "0",
                                 "vt": "num"
                         "checkall": "true",
                         "repair": false,
                         "outputs": 2,
                         "x": 2260,
                         "y": 3600,
                         "wires": [
                                 "1e4d02d4327046e2"
                                 "f0133d29a83f3d17"
                    @siporax
                           "onlyack": "",
                           "func": "all",
                           "gap": "",
                           "x": 2080,
                           "y": 3600,
                           "wires": [
                                   "0ebf71f32dd2b609"
                           "name": "WR-Fritz",
                           "attrname": "wr",
                           "x": 2400,
                           "y": 3660,
                           "wires": [
                                   "746280ddaeb139a2"
                           "type": "change",
                           "rules": [
                                   "t": "set",
                                   "p": "payload",
                                   "pt": "msg",
                                   "tot": "jsonata"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 2580,
                           "y": 3660,
                           "wires": [
                                   "1e4d02d4327046e2"
                           "ack": "true",
                           "stateName": "",
                           "role": "",
                           "payloadType": "",
                           "readonly": "",
                           "stateUnit": "",
                           "stateMin": "",
                           "stateMax": "",
                           "x": 2810,
                           "y": 3580,
                           "wires": []
                           "type": "switch",
                           "rules": [
                                   "t": "eq",
                                   "v": "0",
                                   "vt": "num"
                                   "t": "gt",
                                   "v": "0",
                                   "vt": "num"
                           "checkall": "true",
                           "repair": false,
                           "outputs": 2,
                           "x": 2260,
                           "y": 3600,
                           "wires": [
                                   "1e4d02d4327046e2"
                                   "f0133d29a83f3d17"
                    Versuche das morgen in Ruhe nochmal.
                    bekomme ich damit immer den Teichverbrauch angezeigt auch wenn der Wechselrichter nicht läuft ?
                    • mickym
                      @siporax Na wenn der Wechselrichter nicht läuft, was steht denn dann in dem Datenpunkt. Nein - woran erkennt man denn dass der nicht läuft. Wenn in dem Datenpunkt 0 steht ist es doch egal dann wird halt nichts abgezogen. Wie gesagt die Logik musst Du formulieren - am Besten als Text.
                        Genau wenn nicht abgezogen wird steht die null und der normale Wert soll dann angezeigt werden vom Teich Pow.
                        Das macht er auch schon nur steht ein minus davor was ja nicht stimmt.
                        Der Wert ansich stimmt aber schon mal als Zahl 🙂
                        Gerade getestet,Danke mal dafür.
                        Mann würde es erkenen wen der Wert vom WR Fitz nicht mehr wie 0-15 Watt verbraucht im Standby in einer Minute.
                        Denke so könnte man das erkennen wann der Wechselrichter nichts Leistet.
                        • mickym
                          @siporax Dann musst Du halt die Werte über 1 Minute aufsummieren und dann mit einer Minute Verzögerung das ausgeben. Wenn die Summe oder Mittelwert innerhalb der Minute unter 15 ist, setzt Du den Wert des Wechselrichters einfach auf 0.
                          Schau mal: https://flows.nodered.org/node/node-red-contrib-aggregator
                            Kann dir zwar folgen was du meinst aber kein Plan wie man das einstellt.
                            Auch würde dann das minus vor dem Wert noch bleiben.
                            • mickym
                              @siporax Ich hab Dir doch gezeigt - wie Du entweder mit -1 multiplizierst oder den absoluten Wert nimmst.
                              https://forum.iobroker.net/post/1019993
                                Bringen wir das Minus Zeichen noch vor dem Wert weg wenn der wechselrichter aus ist ?
                                Ich macht da morgen weiter damit.
                                • mickym
                                  @siporax
                                  @siporax sagte in 2 Werte Subtrtahieren in Node Red:
                                  Bringen wir das Minus noch vor dem Wert weg ?
                                  Ich versteh Dich nicht. In dem Post habe ich Dir doch 2 Möglichkeiten gezeigt. Entweder mit der Absolutfunktion oder Du multiplizierst mit -1
                                    @siporax
                                    Du hast recht habs mir angesehen,teste morgen bin müde.Danke
                                      siporax @siporax last edited by siporax
                                      @siporax
                                      So habe das wie im Bild abgeändert vom ChangeNode vom TeichPow-WR .
                                      Das Minus ist zwar weg aber es läuft nicht mehr (schreibt nichts mehr neues in den Ordner vom Iobroker )
                                             "id": "85fb4f8bec7a080c",
                                             "type": "tab",
                                             "label": "Realer Teichverbrauch W1",
                                             "disabled": false,
                                             "info": "",
                                             "env": []
                                             "z": "85fb4f8bec7a080c",
                                             "onlyack": "",
                                             "func": "all",
                                             "gap": "",
                                             "x": 140,
                                             "y": 160,
                                             "wires": [
                                                     "0ebf71f32dd2b609"
                                             "name": "WR-Fritz",
                                             "attrname": "wr",
                                             "x": 460,
                                             "y": 220,
                                             "wires": [
                                                     "746280ddaeb139a2"
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "to": "$abs(verbrauch - wr)",
                                                     "tot": "jsonata"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 640,
                                             "y": 220,
                                             "wires": [
                                                     "1e4d02d4327046e2"
                                             "ack": "true",
                                             "stateName": "",
                                             "role": "",
                                             "payloadType": "",
                                             "readonly": "",
                                             "stateUnit": "",
                                             "stateMin": "",
                                             "stateMax": "",
                                             "x": 910,
                                             "y": 140,
                                             "wires": []
                                             "type": "switch",
                                             "rules": [
                                                     "t": "eq",
                                                     "v": "0",
                                                     "vt": "num"
                                                     "t": "gt",
                                                     "v": "0",
                                                     "vt": "num"
                                             "checkall": "true",
                                             "repair": false,
                                             "outputs": 2,
                                             "x": 320,
                                             "y": 160,
                                             "wires": [
                                                     "1e4d02d4327046e2"
                                                     "f0133d29a83f3d17"
                                      • mickym
                                        @siporax
                                        da muss payload und nicht verbrauch rein.
                                        Arbeite auch immer mit Debug Nodes - wenn Du Fehlern auf die Spur kommen willst.
                                          @siporax
                                          So läuft nun. Danke
                                          Wie oft wir der Wert aktualisiert ? Er schreibt alle 4 oder 5 Minuten nur den Wert.
                                          • mickym
                                            @siporax Er schreibt dann der Wert wenn der Sonoff Power Datenpunkt aktualisiert wird. Das hat also nichts mit NodeRed zu tun. Ggf. kannst Du im Sonoff Adapter was einstellen - das musst Du aber dort erfragen.
                                            81.1k
                                            4379
