    4. Rotex HPSU / Daikin Altherma Wärmepumpe über ioBroker.canbus
    • crycode
      crycode Developer @RaspiUser last edited by
      @raspiuser Hmm... sieht eigentlich gut aus. Prüfe mal deine Adapterconfig (besonders das Interface) und aktiviere mal das Debug-Log für die Adapterinstanz.
      RaspiUser 1 Reply Last reply Reply Quote 0
      • RaspiUser
        RaspiUser @crycode last edited by
        @crycode
        ... hier der Log:
        canbus.0
        	2023-07-23 19:09:54.062	debug	Plugin sentry Initialize Plugin (enabled=true)
        canbus.0
        	2023-07-23 19:09:49.119	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        canbus.0
        	2023-07-23 19:09:49.118	debug	Plugin sentry destroyed
        canbus.0
        	2023-07-23 19:09:49.117	info	terminating
        canbus.0
        	2023-07-23 19:09:49.116	debug	cleaned everything up...
        canbus.0
        	2023-07-23 19:09:49.113	info	Got terminate signal TERMINATE_YOURSELF
        canbus.0
        	2023-07-23 19:09:30.656	error	Error starting can interface: Error: Error while creating channel
        canbus.0
        	2023-07-23 19:09:30.585	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.canbus, node: v18.17.0, js-controller: 4.0.24
        canbus.0
        	2023-07-23 19:09:30.149	debug	Plugin sentry Initialize Plugin (enabled=true)
        canbus.0
        	2023-07-23 19:09:30.117	debug	States connected to redis: 127.0.0.1:9000
        canbus.0
        	2023-07-23 19:09:30.102	debug	States create User PubSub Client
        canbus.0
        	2023-07-23 19:09:30.101	debug	States create System PubSub Client
        canbus.0
        	2023-07-23 19:09:30.092	debug	Redis States: Use Redis connection: 127.0.0.1:9000
        canbus.0
        	2023-07-23 19:09:30.068	debug	Objects connected to redis: 127.0.0.1:9001
        canbus.0
        	2023-07-23 19:09:30.059	debug	Objects client initialize lua scripts
        canbus.0
        	2023-07-23 19:09:30.036	debug	Objects create User PubSub Client
        canbus.0
        	2023-07-23 19:09:30.033	debug	Objects create System PubSub Client
        canbus.0
        	2023-07-23 19:09:30.031	debug	Objects client ready ... initialize now
        canbus.0
        	2023-07-23 19:09:29.989	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
        canbus.0
        	2023-07-23 19:09:25.199	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        canbus.0
        	2023-07-23 19:09:25.194	info	terminating
        canbus.0
        	2023-07-23 19:09:25.190	info	Got terminate signal TERMINATE_YOURSELF
        canbus.0
        	2023-07-23 19:08:39.954	error	Error starting can interface: Error: Error while creating channel
        canbus.0
        	2023-07-23 19:08:39.877	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.canbus, node: v18.17.0, js-controller: 4.0.24
        ... sonst passiert nix ... und hier die Einstellungen (ohne Änderungen zw. Buste rund Bookworm)
        crycode 1 Reply Last reply Reply Quote 0
        • crycode
          @raspiuser In deiner Config steht vcan0, aber das Interface heißt can0. 😉
          • RaspiUser
            @crycode said in Rotex HPSU / Daikin Altherma Wärmepumpe über ioBroker.canbus:
            nö ... vcan0 ist richtig ... Ich habe / hatte ja bereits ein funktionsfähige Anbindung (siehe #280).
            (Ich habe wirklich "nur" eine frische Bullseye / Bookworm Karte mit Backitup eingesetzt. Und dann ist ja vcan0 immer noch richtig ... funktioniert unter Buster ja einwandfrei ...)
            Ich klone die Buster Karte und upgrade dann DIESE Installation ohne ein ganz frische Installation ... vielleicht ist dann die Lösung ...
            • crycode
              @raspiuser Ah moment... du hast den Adapter ja auf einem anderen System laufen und das CAN-Interface vom Raspi mittel Cannelloni weitergegeben, richtig?
              Den Cannelloni Service hast du auf beiden Seiten richtig eingerichtet?
              Dann schau mal ins Log von den Services, ob dort irgendwelche Fehler gemeldet werden:
              sudo journalctl -u cannelloni-can0.service
              bzw.
              sudo journalctl -u cannelloni-vcan0.service
              Wahrscheinlich klemmt da irgendwas, wodurch dann van0 auf deinem ioBroker System nicht richtig verfügbar ist.
              • RaspiUser
                @crycode
                ... ich war mir nicht sicher auf welchem System ich die Logs erstellen soll und habe mal (laienhaft) beide abgefragt ...
                Hier die Ausgabe auf dem ioBroker Raspi Pi4:
                pi@ioBroker-Raspi:~ $ sudo journalctl -u cannelloni-can0.service
                -- No entries --
                pi@ioBroker-Raspi:~ $ sudo journalctl -u cannelloni-vcan0.service
                -- No entries --
                Und hier auf dem vcan0 Raspi Zero:
                pi@ioBroker-Zero:~ $ sudo journalctl -u cannelloni-vcan0.service
                -- Logs begin at Sat 2023-07-22 18:08:42 CEST, end at Mon 2023-07-24 12:10:35 CE
                -- No entries --
                lines 1-2/2 (END)
                pi@ioBroker-Zero:~ $ sudo journalctl -u cannelloni-can0.service
                -- Logs begin at Sat 2023-07-22 18:08:42 CEST, end at Mon 2023-07-24 12:11:16 CE
                Jul 22 18:09:09 ioBroker-Zero systemd[1]: Started Cannelloni for can0.
                Jul 22 18:09:10 ioBroker-Zero cannelloni[556]: INFO:udpthread.cpp[158]:run:UDPTh
                Jul 22 18:09:10 ioBroker-Zero cannelloni[556]: ERROR:canthread.cpp[88]:start:CAN
                Jul 22 18:09:10 ioBroker-Zero cannelloni[556]: INFO:canthread.cpp[108]:run:CANTh
                lines 1-5/5 (END)...skipping...
                -- Logs begin at Sat 2023-07-22 18:08:42 CEST, end at Mon 2023-07-24 12:11:16 CEST. --
                Jul 22 18:09:10 ioBroker-Zero cannelloni[556]: INFO:udpthread.cpp[158]:run:UDPThread up and running
                Jul 22 18:09:10 ioBroker-Zero cannelloni[556]: ERROR:canthread.cpp[88]:start:CAN_FD is not supported on >can0<
                Jul 22 18:09:10 ioBroker-Zero cannelloni[556]: INFO:canthread.cpp[108]:run:CANThread up and running
                lines 1-5/5 (END)
                lines 1-5/5 (END)
                • crycode
                  @raspiuser Auf dem Raspi Zero sieht soweit gut aus.
                  Mach mal auf dem ioBroker Raspi:
                  sudo systemctl restart cannelloni-vcan0.service
                  sudo systemctl status cannelloni-vcan0.service
                  Das startet den Service neu, fragt den Status ab und gibt das Log aus.
                  Hat der Raspi Zero nach dem Update noch die gleiche IP-Adresse?
                  Falls nicht, musst du in der Datei /etc/systemd/system/cannelloni-vcan0.service auf dem ioBroker Raspi anpassen.
                  • RaspiUser
                    RaspiUser @crycode last edited by RaspiUser
                    @crycode
                    ... sieht wohl so aus, dass ich (erstmal) canneloni auf dem Raspi einrichten muss, oder ?
                    pi@ioBroker-Raspi:~ $ sudo systemctl restart cannelloni-vcan0.service
                    Failed to restart cannelloni-vcan0.service: Unit cannelloni-vcan0.service not found.
                    pi@ioBroker-Raspi:~ $ sudo systemctl status cannelloni-vcan0.service
                    Unit cannelloni-vcan0.service could not be found.
                    -- No entries --
                    EDIT:
                    so, oder ? (siehe auch "meine" Anleitung ab Seite 4 ...)
                    sudo apt install can-utils
                    sudo apt install build-essential cmake git
                    git clone https://github.com/mguentner/cannelloni.git
                    cd cannelloni
                    cmake -DCMAKE_BUILD_TYPE=Release make
                    sudo make install
                    usw.
                    Während der Installation kam diese Fehlermeldung:
                    Job for vcan0-setup.service failed because the control process exited with error code.
                    See "systemctl status vcan0-setup.service" and "journalctl -xeu vcan0-setup.service" for details.
                    Nachdem ich dann diesem Wunsch entsprochen habe kam dann dieser ewig lange Text (mit dem ich als Laie nix anfangen kann ...):
                    pi@ioBroker-Raspi:~ $ systemctl status vcan0-setup.service
                    × vcan0-setup.service - Setup vcan0
                         Loaded: loaded (/etc/systemd/system/vcan0-setup.service; enabled; preset: >
                         Active: failed (Result: exit-code) since Mon 2023-07-24 14:43:18 CEST; 1s >
                        Process: 1241 ExecStart=/usr/local/sbin/vcan0-setup.sh start (code=exited, >
                       Main PID: 1241 (code=exited, status=203/EXEC)
                            CPU: 6ms
                    Jul 24 14:43:18 ioBroker-Raspi systemd[1]: Starting vcan0-setup.service - Setup>
                    Jul 24 14:43:18 ioBroker-Raspi (setup.sh)[1241]: vcan0-setup.service: Failed to>
                    Jul 24 14:43:18 ioBroker-Raspi (setup.sh)[1241]: vcan0-setup.service: Failed at>
                    Jul 24 14:43:18 ioBroker-Raspi systemd[1]: vcan0-setup.service: Main process ex>
                    Jul 24 14:43:18 ioBroker-Raspi systemd[1]: vcan0-setup.service: Failed with res>
                    Jul 24 14:43:18 ioBroker-Raspi systemd[1]: Failed to start vcan0-setup.service >
                    lines 1-13/13 (END)...skipping...
                         Loaded: loaded (/etc/systemd/system/vcan0-setup.service; enabled; preset: enabled)
                         Active: failed (Result: exit-code) since Mon 2023-07-24 14:43:18 CEST; 1s ago
                        Process: 1241 ExecStart=/usr/local/sbin/vcan0-setup.sh start (code=exited, status=203/EXEC)
                            CPU: 6ms
                    Jul 24 14:43:18 ioBroker-Raspi systemd[1]: Starting vcan0-setup.service - Setup vcan0...
                    Jul 24 14:43:18 ioBroker-Raspi (setup.sh)[1241]: vcan0-setup.service: Failed to execute /usr/local/sbin/vcan0-setup.sh: Exec format error
                    Jul 24 14:43:18 ioBroker-Raspi (setup.sh)[1241]: vcan0-setup.service: Failed at step EXEC spawning /usr/local/sbin/vcan0-setup.sh: Exec forma>
                    Jul 24 14:43:18 ioBroker-Raspi systemd[1]: vcan0-setup.service: Main process exited, code=exited, status=203/EXEC
                    Jul 24 14:43:18 ioBroker-Raspi systemd[1]: vcan0-setup.service: Failed with result 'exit-code'.
                    Jul 24 14:43:18 ioBroker-Raspi systemd[1]: Failed to start vcan0-setup.service - Setup vcan0.
                    ...skipping...
                            CPU: 6ms
                            CPU: 6ms
                    pi@ioBroker-Raspi:~ $ journalctl -xeu vcan0-setup.service
                    ░░ Subject: A start job for unit vcan0-setup.service has begun execution
                    ░░ Defined-By: systemd
                    ░░ Support: https://www.debian.org/support
                    ░░ A start job for unit vcan0-setup.service has begun execution.
                    ░░ The job identifier is 9756.
                    Jul 24 14:44:49 ioBroker-Raspi (setup.sh)[1333]: vcan0-setup.service: Failed to execute /usr/local/sbin/vcan0-setup.sh: Exec format error
                    Jul 24 14:44:49 ioBroker-Raspi (setup.sh)[1333]: vcan0-setup.service: Failed at step EXEC spawning /usr/local/sbin/vcan0-setup.sh: Exec forma>
                    ░░ Subject: Process /usr/local/sbin/vcan0-setup.sh could not be executed
                    ░░ The process /usr/local/sbin/vcan0-setup.sh could not be executed and failed.
                    ░░ The error number returned by this process is ERRNO.
                    Jul 24 14:44:49 ioBroker-Raspi systemd[1]: vcan0-setup.service: Main process exited, code=exited, status=203/EXEC
                    ░░ Subject: Unit process exited
                    ░░ An ExecStart= process belonging to unit vcan0-setup.service has exited.
                    ░░ The process' exit code is 'exited' and its exit status is 203.
                    Jul 24 14:44:49 ioBroker-Raspi systemd[1]: vcan0-setup.service: Failed with result 'exit-code'.
                    ░░ Subject: Unit failed
                    ░░ The unit vcan0-setup.service has entered the 'failed' state with result 'exit-code'.
                    Jul 24 14:44:49 ioBroker-Raspi systemd[1]: Failed to start vcan0-setup.service - Setup vcan0.
                    ░░ Subject: A start job for unit vcan0-setup.service has failed
                    ░░ A start job for unit vcan0-setup.service has finished with a failure.
                    ░░ The job identifier is 9756 and the job result is failed.
                    lines 4118-4155/4155 (END)
                    • crycode
                      @raspiuser Ja, du musst natürlich Cannelloni installiert und alles eingerichtet haben. 😉
                      Da stimmt etwas mit dem vcan0-setup.sh Script nicht.
                      • RaspiUser
                        OK, Danke erstmal ...
                        Das einfachste für mich ist es, ich fange mit dem ioBroker-Raspi frisch an.
                        Auf dem CAN-Zero-Raspi sollte ja alles i.O. sein ... mit der "alten" Installation klappt es ja.
                        • hg6806
                          hg6806 Most Active last edited by
                          leider kämpfe ich bei aktivem CAN Adapter noch immer mit einer hohen Prozessorlast.
                          Ich habe den CAN über ein CAN HAT am RasPi 4 4GB angeschlossen.
                          Wie und wo kann ich Abfragetimings einstellen? In der Instanz habe ich nichts gefunden.
                          V1.3.1 ist installiert
                          C crycode 2 Replies Last reply Reply Quote 0
                            cb187 @hg6806 last edited by
                            Intervall !
                            • crycode
                              crycode Developer @hg6806 last edited by
                              @hg6806 Du kannst pro Parser die Option "Automatisch einen bestimmten Wert setzen" aktivieren/deaktivieren und dazu den jeweiligen Intervall in Millisekunden festlegen.
                              Bei sehr vielen aktiven Abfragen (oder sonst sehr hoher Aktivität auf dem Bus) steigt dann logischerweise die Last von deinem System.
                              • hg6806
                                hg6806 Most Active @crycode last edited by
                                @crycode
                                Stimmt, den Intervall Wert kann man aber nur für recht wenige Werte eintragen. Hier habe ich als Minimalen Wert 10 Sek. sonst 1 Min oder auch länger.
                                Manche Abfrage Werte haben keine Intervall Angabe:
                                Kann man die Werte exportieren und dann einfach mal einen Teil löschen, ob es besser werte und dann das File wieder importieren? Die Last muss ja irgendwo herkommen. Ich glaube von dem Abfragen kommt das nicht.
                                • crycode
                                  @hg6806 Das Feld für den Intervall erscheint erst, wenn du den Haken für das automatische Setzen setzt. 😉
                                  Du kannst deine Konfiguration exportieren (über Import/Export in der Konfig als json), dann einige Parser testweise löschen und später einfach die exportierte Konfig wieder importieren, um alles zurück zu haben.
                                  Wie viele Abfragen hast du aktiv?
                                  Hast du die "raw-States" aktiviert? Falls ja mach die mal aus.
                                  Hast du mal auf dem Raspi geschaut, welcher Prozess die CPU-Last erzeugt?
                                  Das müsste mit htop in einem Terminal zu sehen sein. (Falls nicht installiert: sudo apt install htop)
                                  • hg6806
                                    @crycode
                                    Was passiert, wenn der Haken fürs Automatische Setzen nicht gesetzt ist? Wann werden dann die Werte abgefragt bzw. erneuert?
                                    Ich habe vielleicht 20 Abfragen aktiv
                                    Ja, Raw-States ist angehakt. Ich "unchecke" das mal
                                    Hier ist die Last von ioBroker. Ich hoffe das reicht.
                                    • crycode
                                      @hg6806 sagte in Rotex HPSU / Daikin Altherma Wärmepumpe über ioBroker.canbus:
                                      Dann werden die Werte nur abgefragt, wenn du es manuell oder z.B. über ein eigenes Script triggerst.
                                      20 sollten eigentlich ohne größere Probleme funktionieren.
                                        earl80 @cb187 last edited by earl80
                                        @cb187 Hi, danke für die gezeigten Blockly Scripts! Eine Frage habe ich: Woher kommt bei der Leistungsberechnung der Wert "Rotex Verbrauch" her? Müsste der nicht vom Stromzähler kommen?
                                        LG Earl
                                          @earl80 said in Rotex HPSU / Daikin Altherma Wärmepumpe über ioBroker.canbus:
                                          LG Earl
                                          Doch kommt vom eigenen WP Zähler.Bin mittlerweile von einem Modbus Zähler auf Shelly 3em gewechselt.
                                            @cb187 said in Rotex HPSU / Daikin Altherma Wärmepumpe über ioBroker.canbus:
                                            Modbus Zähler
                                            Ok, den kannte ich noch nicht. Hast den im Zählerschrank einbauen lassen, oder am Kabel von der WP?
                                            E Homoran C 3 Replies Last reply Reply Quote 0
                                            1.2k
                                            81.1k
                                            canbus canbus adapter rotex hpsu
                                            25
                                            522
                                            100691
