    5. [gelöst] Payload Daten in Objekte schreiben
    • GregorS
      GregorS @paul53 last edited by
      Habe ich korrigiert. Der Teufel steckt im Detail
      19:01:43.238	info	javascript.0 (652027) script.js.LoRAWAN_DEV_1: {"end_device_ids":{"device_id":"eui-a840414601871305","application_ids":{"application_id":"gs-mg-dragino-01"},"dev_eui":"A840414601871305","join_eui":"A840410000000101","dev_addr":"260BE9CF"},"correlation_ids":["as:up:01H5Z8SJDEQ23SXYZE51TC07BD","gs:conn:01H5TF5M58SGAQZTB5B766P6EM","gs:up:host:01H5TF5M5DGPVSKX7RKJ1HPXFF","gs:uplink:01H5Z8SJ70D6PACPHB0R2GHN04","ns:uplink:01H5Z8SJ712X5TEW0CWDE4CXQM","rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01H5Z8SJ715Z75WJ51BS6ZWF31","rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01H5Z8SJDDM0YCG82TXN5P6Q2T"],"received_at":"2023-07-22T17:01:43.213639158Z","uplink_message":{"session_key_id":"AYlu5XV3aMaeiMVAq8yISw==","f_port":2,"f_cnt":4377,"frm_payload":"NiwAAAAAAAA0/0E=","decoded_payload":{"ACI1_mA":"0.000", "ACI2_mA":"0.000", "AVI1_V":"13.868", "AVI2_V":"0.000", "Acount_times":null, "Count1_times":null, "Count2_times":null, "DI1_status":"L", "DI2_status":"H", "DI3_status":null, "DO1_status":"H", "DO2_status":"H", "DO3_status":null, "First_status":null, "Hardware_mode":"LT22222", "RO1_status":"OFF", "RO2_status":"OFF", "Work_mode":"2ACI+2AVI"},"rx_metadata":[{"gateway_ids":{"gateway_id":"eui-7076ff0056080b0f","eui":"7076FF0056080B0F"},"time":"2023-07-22T17:01:42.871Z","timestamp":1199555188,"rssi":-118,"channel_rssi":-118,"snr":-13.8,"uplink_token":"CiIKIAoUZXVpLTcwNzZmZjAwNTYwODBiMGYSCHB2/wBWCAsPEPSE/7sEGgsI95bwpQYQ0Mb0AyCgqr7Y9K0mKgwI9pbwpQYQwM+pnwM=","channel_index":4,"gps_time":"2023-07-22T17:01:42.871Z","received_at":"2023-07-22T17:01:42.714662309Z"}],"settings":{"data_rate":{"lora":{"bandwidth":125000, "spreading_factor":12, "coding_rate":"4/5"}}, "frequency":"867900000", "timestamp":1199555188, "time":"2023-07-22T17:01:42.871Z"},"received_at":"2023-07-22T17:01:43.009292984Z","consumed_airtime":"1.482752s","version_ids":{"brand_id":"dragino", "model_id":"lt22222-l", "hardware_version":"_unknown_hw_version_", "firmware_version":"1.5.6", "band_id":"EU_863_870"},"network_ids":{"net_id":"000013","tenant_id":"ttn","cluster_id":"eu1","cluster_address":"eu1.cloud.thethings.network"}}}
      19:01:43.238	info	javascript.0 (652027) script.js.LoRAWAN_DEV_1: {'ACI1_mA':'0.000','ACI2_mA':'0.000','AVI1_V':'13.868','AVI2_V':'0.000','Acount_times':null,'Count1_times':null,'Count2_times':null,'DI1_status':'L','DI2_status':'H','DI3_status':null,'DO1_status':'H','DO2_status':'H','DO3_status':null,'First_status':null,'Hardware_mode':'LT22222','RO1_status':'OFF','RO2_status':'OFF','Work_mode':'2ACI+2AVI'}
      paul53 GregorS 2 Replies Last reply Reply Quote 0
        paul53 @GregorS last edited by paul53
        @gregors sagte: Der Teufel steckt im Detail
        ... und nun wurde auch der Datenpunkt "AVI1_V" mit dem Wert 13.87 gefüllt?
        • GregorS
          GregorS @GregorS last edited by
          @Homoran
          @marc-berg
          Danke für Eure Geduld und die Hilfe.
          Jetzt funktioniert es.
          GregorS 1 Reply Last reply Reply Quote 0
          • GregorS
            Wie kann ich denn
            "rssi" und "time"
            extrahieren?
            Alle anderen Infos haben funktioniert.
              @gregors sagte: "rssi" und "time"
                  const msg = JSON.parse(dp.state.val).uplink_message;
                  const payload = msg.decoded_payload;
                  const rx0 = msg.rx_metadata[0];
                  log(rx0.time);
                  log(rx0.rssi);
              • GregorS
                Nachdem ich jetzt die Daten in ioBroker habe, ist mir die Nacht eine
                zusätzliche Anwendung durch den Kopf gegangen.
                Dazu muss ich allerdings RO1 schalten.
                Über das Gateway habe ich bereits Erfolg gehabt, und die Rückmeldung im ioBroker aufgenommen.
                Messaging / Downlink --> 03 00 11 Relais öffnen
                --> 03 01 11 Relais schliessen
                Wie kann ich das RO1 aus ioBroker schalten?
                • Marc Berg
                  Marc Berg Most Active @GregorS last edited by
                  @gregors sagte in [gelöst] Payload Daten in Objekte schreiben:
                  Ich habe das über Node Red umgesetzt, aber den entscheidenden Teil kannst du vielleicht adaptieren.
                  So sieht ein einfacher Beispiel-Flow aus:
                  Der Payload (hier "0501100200") wird in einem Function-Node verarbeitet (Base64 Kodierung + Erzeugung des Downlinks) und dann per MQTT an TTN gesendet.
                  Der Code im Function-Node sieht so aus (in 'msg.hex' steckt "0501100200"):
                  var s=msg.hex;
                  var b=Buffer.from(s, 'hex');            //Buffer erzeugen
                  s=b.toString("base64");                 //to base64
                  msg.payload=
                      "downlinks": [{
                        "f_port": 2,
                        "frm_payload": s,
                        "priority": "NORMAL"
                  return msg;
                  Dieser so aufbereitete Payload wird dann per MQTT an folgendes Topic gesendet:
                  v3/<APPLICATION-ID>@ttn/devices/<DEVICE_ID>/down/replace
                  • GregorS
                    GregorS @Marc Berg last edited by
                    @marc-berg
                    Danke für den Denkanstoss.
                    Habe aber bisher noch keinen Erfolg gehabt.
                    Bekomme das Payload nicht gesendet.
                    Bleibe dran
                    • Marc Berg
                      Bleibe dran
                      Das müsste ja dann bei dir zum Einschalten so aussehen:
                          "downlinks": [{
                            "f_port": 2,
                            "frm_payload": "AwER",
                      und zum Ausschalten so:
                          "downlinks": [{
                            "f_port": 2,
                            "frm_payload": "AwAR",
                      Auf welche Weise sendest du den Downlink?
                      • GregorS
                        GregorS @Marc Berg last edited by GregorS
                        @marc-berg said in [gelöst] Payload Daten in Objekte schreiben:
                        Was meinst du damit?
                        Ich habe mehrer Versionen probiert, aber es hakt immer am "Doppelpunkt" hinter downlinks.
                        Ich galube, da fehlt was entscheidendes.
                        //'mqtt.2.v3.gs-mg-dragino-01@ttn.devices.eui-a840414601871305.down.sent'/*v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/down/sent*/
                        on('mqtt.2.v3.gs-mg-dragino-01@ttn.devices.eui-a840414601871305.down', function (dp)
                          "downlinks": [{
                            "f_port": 2,
                            "frm_payload": "130011=",
                        18:26:04.002	error	javascript.0 (681137) script.js.LoRAWAN_DEV_1_senden compile failed: at script.js.LoRAWAN_DEV_1_senden:4
                        paul53 Marc Berg 2 Replies Last reply Reply Quote 0
                          @gregors
                          Du willst doch keine Daten erhalten (triggern), sondern Daten senden. Das macht man mit sendTo() oder mit setState() auf den Datenpunkt, der an das Topic "v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/down/replace" sendet.
                          • Marc Berg
                            Nun ja, man kann ja die Daten per MQTT oder per API senden. Wie ich jetzt gesehen habe, versuchst du es per MQTT. Das heißt, du hast eine MQTT Instanz erstellt und dich damit an TTN angemeldet? Funktioniert denn die Anmeldung?
                            Zum Scripting kann ich nicht viel sagen, dazu hat sich ja @paul53 schon geäußert.
                            Aber das hier:
                            ist auf jeden Fall falsch Base64 kodiert. Ein guter Konverter ist z.B. der hier https://base64.guru/converter/encode/hex
                            Wenn Du deinen Hexadezimal-Payload "03 01 11" durch den Konverter schickst, kommt "AwER" raus.
                            3580
