    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Shelly Plus 2PM und shuttercontrol [gelöst]
      docsnyder7 @Homoran last edited by
      @homoran völlig richtig... schon spät heute, hole ich umgehend morgen nach...
        Homoran Global Moderator Administrators @docsnyder7 last edited by
        @docsnyder7 dann direkt mit debug-log
          docsnyder7 @Homoran last edited by Homoran
          2023-07-25 06:51:53.309 - info: admin.0 (1995) ==> Connected system.user.admin from ::ffff:192.168.178.72
          2023-07-25 06:53:30.157 - info: host.evccpi stopInstance system.adapter.shuttercontrol.0 (force=false, process=true)
          2023-07-25 06:53:30.165 - info: shuttercontrol.0 (16955) Got terminate signal TERMINATE_YOURSELF
          2023-07-25 06:53:30.168 - info: shuttercontrol.0 (16955) cleaned everything up...
          2023-07-25 06:53:30.171 - info: shuttercontrol.0 (16955) terminating
          2023-07-25 06:53:30.173 - info: shuttercontrol.0 (16955) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-07-25 06:53:30.205 - info: host.evccpi stopInstance system.adapter.shuttercontrol.0 send kill signal
          2023-07-25 06:53:30.583 - info: admin.0 (1995) <== Disconnect system.user.admin from ::ffff:192.168.178.72
          2023-07-25 06:53:30.738 - info: host.evccpi instance system.adapter.shuttercontrol.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-07-25 06:53:33.237 - info: host.evccpi instance system.adapter.shuttercontrol.0 started with pid 16971
          2023-07-25 06:53:36.029 - info: shuttercontrol.0 (16971) starting. Version 1.5.0 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.17.0, js-controller: 4.0.24
          2023-07-25 06:54:45.982 - info: homee.0 (13720) initialize 1 homeegrams
          2023-07-25 06:55:05.230 - info: homee.0 (13720) initialize 1 homeegrams
          2023-07-25 06:55:41.355 - info: admin.0 (1995) ==> Connected system.user.admin from ::ffff:192.168.178.72
          2023-07-25 06:55:54.486 - info: admin.0 (1995) <== Disconnect system.user.admin from ::ffff:192.168.178.72
          Guten Morgen...
          anbei die Einstellungen in shuttercontrol und das log von heute...
          aufgefallen ist mir, dass die Richtungspfeile im shuttercontrol grau bleiben, egal welchen eintrag aus dem shelly ich verwende..
          Prosst Kaffee
          Homoran T 3 Replies Last reply Reply Quote 0
            @docsnyder7 sagte in Shelly Plus 2PM und shuttercontrol:
            leider kein debug-log.
            nimm mal nicht...(Automatik)
            D Homoran 2 Replies Last reply Reply Quote 0
              das sind keine Richtungspfeile für die Rollläden, sondern für die Reihenfolge der konfigurierten Geräte. Bei nur einem Rollladen kann man die Reihenfolge nicht ändern.
                ticaki Developer @docsnyder7 last edited by
                @docsnyder7
                Damit schiebt man Geräte hoch runter. Die Pfeile haben nix mit der Position zu tun.
                https://github.com/simatec/ioBroker.shuttercontrol/blob/master/docs/de/shuttercontrol.md#grundlegendes
                Stelle den positionsstate dort ein, stelle das öffenen und schließen nach Uhrzeit so ein dass es passt und lass das mal in ruhe 🙂 wenn er nicht öffnet und schließt können wir hier weiter machen.
                Für die ganzen anderen Funktionen brauchst du auch die entsprechenden Sensoren.
                  @homoran hilf mir mal bitte bzgl debug log…im Reiter ist doch debug ausgewählt?
                  Ok…mit den Pfeile hab ich kapiert 👍
                  Ändere das ganze ab und lasse es mal stehen
                  Homoran OstfrieseUnterwegs 2 Replies Last reply Reply Quote 0
                    bitte vollständig lesen!
                    da steht alles drin.
                    • OstfrieseUnterwegs
                      OstfrieseUnterwegs @docsnyder7 last edited by
                      @docsnyder7 In dem screenshot sieht die ID komisch aus. Leerzeichen sollten da normalerweise nicht drin sein.
                      Außerdem hast du bei Name 'Position' vergeben, da würde ich sowas nehmen wie 'Schlafzimmer.rechts.Position'
                        docsnyder7 @OstfrieseUnterwegs last edited by
                        @ostfrieseunterwegs
                        da hab ich die ID wegretuschiert... Entschuldigung
                        OstfrieseUnterwegs 1 Reply Last reply Reply Quote 0
                          docsnyder7 @ticaki last edited by
                          @ticaki
                          es gibt Position….level.blind. oder cover status…..state
                            @ticaki
                            das Feld ist frei beschreibbar, damit du weisst um welchen Rollladen es da geht.
                            bei vielen Rollläden wird es sonst unübersichtlich wenn alle Sensoren gleich heißen
                              @docsnyder7 Kannst du denn im Objecttree mit der ID, die du dort eingetragen hast den Level/Position der Jalousie steuern? Also wenn du da 50 reinschreibst, geht sie dann auf 50% und fährt sie bei 0 und 100 die Endlagen an? Außerdem muss der Adapter wissen, ob 100=auf oder 100=zu ist (Ich hab gerade keine Shellys als shutter konfiguriert, deher weiss ich es nicht)
                                @homoran das hab ich verstanden, aber bei dem einen Testrollo war das momentan nicht ganz so dramatisch…Aber prinzipiell werden die natürlich korrekt benannt
                                  @ostfrieseunterwegs ja das geht
                                  100% sind auf
                                  T OstfrieseUnterwegs 2 Replies Last reply Reply Quote 0
                                    @docsnyder7
                                    Diesen State setzt du bei shuttercontrol ein, änderst den öffnungszeitpunkt auf jetzt +5Minuten und machst ihn zu. Dann warten.
                                      Homoran Global Moderator Administrators @Homoran last edited by
                                      @docsnyder7
                                      @homoran sagte in Shelly Plus 2PM und shuttercontrol:
                                      hast du das geändert?
                                        Dann passt das soweit, Was anderes, als den Zielwert reinschreiben macht ja Shuttercontrol auch nicht.
                                        Hast du das gesehen?
                                        • Wohnbereich (Automatik):
                                          Der Rollladen fährt zu den Zeiten wie in Einstellungen für den Wohnbereich konfiguriert und zusätzlich wird auf den unter Extra-Einstellungen festgelegten Trigger Objekt-ID zum aktivieren/deaktivieren des Auto-Wohnbereichs geachtet. Steht dieser auf false wird der Rollladen nicht automatisch gefahren.
                                          @homoran hab ich auf Wohnbereich ohne Automatik geändert
                                          @OstfrieseUnterwegs das checke ich gleich
                                          @ticaki das ist der Position….level.blind
                                            docsnyder7 @docsnyder7 last edited by
                                            So... erschlagt mich bitte nicht...
                                            Fehler gefunden.. mich hat gestört, dass die logs alle ne Stunden weniger anzeigen, als meine Uhr zeigte...
                                            da ich den PI erst die Tage auf 64 bit gewechselt hatte, ist mir wohl die zeitzone durchgerutscht😠
                                            Hab die geändert und siehe da, der shutter fährt!
                                            @Homoran
                                            @OstfrieseUnterwegs
                                            @ticaki
                                            ganz herzlichen Dank für eure Geduld und eure Hilfe!!!
                                            3859
