    4. JavaScript
    5. [gelöst] Skriptfehler nach iobroker Update
      mwolle last edited by mwolle
      Hallo zusammen, ich habe mein iobroker mal auf den neusten Stand gebracht:
      js-controller = 5.0.8
      npm = 9.5.1
      node 18.6.1
      javaskript Adapter = 7.1.1
      Seit dem bekomme ich aber diese Fehlermeldung, obwohl die States mit Values da sind:
      2023-07-24 23:00:00.025 - warn: javascript.0 (2968) State "km200:heatingCircuits.hc2.activeSwitchProgram" not found
      2023-07-24 23:00:00.027 - warn: javascript.0 (2968) at setState (C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.javascript\lib\sandbox.js:1730:20)
      2023-07-24 23:00:00.028 - warn: javascript.0 (2968) at Object.cb (script.js.common.Heizprogram_dyn:43:6)
      2023-07-24 23:00:00.028 - warn: javascript.0 (2968) at Immediate._onImmediate (C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.javascript\lib\scheduler.js:96:109)
      2023-07-24 23:00:00.029 - warn: javascript.0 (2968) at processImmediate (node:internal/timers:478:21)
      2023-07-24 23:00:00.029 - warn: javascript.0 (2968) State "km200:heatingCircuits.hc1.activeSwitchProgram" not found
      2023-07-24 23:00:00.030 - warn: javascript.0 (2968) at setState (C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.javascript\lib\sandbox.js:1730:20)
      2023-07-24 23:00:00.031 - warn: javascript.0 (2968) at Object.cb (script.js.common.Heizprogram_dyn:44:6)
      2023-07-24 23:00:00.031 - warn: javascript.0 (2968) at Immediate._onImmediate (C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.javascript\lib\scheduler.js:96:109)
      2023-07-24 23:00:00.032 - warn: javascript.0 (2968) at processImmediate (node:internal/timers:478:21)
      2023-07-24 23:00:00.032 - warn: javascript.0 (2968) State "km200:heatingCircuits.hc2.temperatureLevels.high" not found
      2023-07-24 23:00:00.033 - warn: javascript.0 (2968) at setState (C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.javascript\lib\sandbox.js:1730:20)
      2023-07-24 23:00:00.034 - warn: javascript.0 (2968) at Object.cb (script.js.common.Heizprogram_dyn:57:11)
      2023-07-24 23:00:00.034 - warn: javascript.0 (2968) at Immediate._onImmediate (C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.javascript\lib\scheduler.js:96:109)
      2023-07-24 23:00:00.035 - warn: javascript.0 (2968) at processImmediate (node:internal/timers:478:21)
      2023-07-24 23:00:00.035 - warn: javascript.0 (2968) State "km200:heatingCircuits.hc1.temperatureLevels.high" not found
      2023-07-24 23:00:00.038 - warn: javascript.0 (2968) at setState (C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.javascript\lib\sandbox.js:1730:20)
      2023-07-24 23:00:00.038 - warn: javascript.0 (2968) at Object.cb (script.js.common.Heizprogram_dyn:58:11)
      2023-07-24 23:00:00.039 - warn: javascript.0 (2968) at Immediate._onImmediate (C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.javascript\lib\scheduler.js:96:109)
      2023-07-24 23:00:00.039 - warn: javascript.0 (2968) at processImmediate (node:internal/timers:478:21)
      2023-07-24 23:00:00.040 - info: javascript.0 (2968) script.js.common.Heizprogram_dyn: 24
      2023-07-24 23:00:00.041 - warn: javascript.0 (2968) getState "km200:heatingCircuits.hc2.activeSwitchProgram" not found (3)
      2023-07-24 23:00:00.043 - warn: javascript.0 (2968) at Object.cb (script.js.common.Heizprogram_dyn:65:15)
      2023-07-24 23:00:00.043 - warn: javascript.0 (2968) at Immediate._onImmediate (C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.javascript\lib\scheduler.js:96:109)
      2023-07-24 23:00:00.044 - warn: javascript.0 (2968) at processImmediate (node:internal/timers:478:21)
      ich kann nicht so das Problem nachvollziehen...es hat ja auch vorher alles funktioniert.
      Homoran arteck 2 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @mwolle last edited by Homoran
        @mwolle sagte in Skriptfehler nach iobroker Update:
        ist eine Version für Beta-Tester
        bitte in den entsprechenden Beta-Tester Threads melden
        und sollte es Windows sein, bitte solche Informationen in den Eröffnungspost oder in den Threadtitel
          arteck Developer Most Active @mwolle last edited by arteck
          zeigmal im screenshot diesen Datenpunkt
          @Homoran hat nix mit js-controller zu tun
            mwolle @arteck last edited by
            @arteck
              ticaki @mwolle last edited by ticaki
              @mwolle
              im Screenshot fehlt "km200:heatingCircuits." und das wohl fehlende "0." oder "javascript.0."
                mwolle @ticaki last edited by
                @ticaki hier noch mal von hc1, der Pfad sieht für mich vollständig aus:
                javascript.0 ist die Instanz
                  @mwolle wo ist der knoten davor ??
                  km200: heatingCircuits.hc2.activeSwitchProgram
                  zeigmal das getState von dem Datenpunkt im Script.. oder zeig das Script mal
                    @arteck der ganze Pfad sieht so aus. Der Adapter liest zwei Geräte aus, die dann in separaten Pfaden da gestellt werden, EMS-ESP und km200
                      zeigmal das Script
                        @arteck ist etwas unaufgeräumt...
                        //createState("javascript.0.Merker_Heizleistung", 0, {
                        //    name: "Merker_Heizleistung",
                        //    type: 'int'
                        on({
                            change: "ne"
                        }, async function (obj) {
                            var Element2 = (getState("javascript.0.Merker_Heizleistung").val);
                            // var Element3;
                            var Counterschleife = 0;
                            var Leistungswert2 = 41; // (getState("km200.0.heatSources.actualModulation").val);
                            var Heat_on = (getState("km200:heatSources.hs1.flameStatus").val);
                            var WWtemperatur = (getState("ems-esp.0.dhwCircuits.dhw1.wwcurtemp").val);
                            var Leistungswert = (getState("km200:heatSources.hs1.burnerModulationSetpoint").val);
                            var Brennerstarts = (getState("javascript.0.minutenZwischenBrennerStarts").val);
                            var actualPower = (getState("km200:heatSources.hs1.actualPower").val);
                            // var Raumtemperatur = (getState("fritzdect.0.DECT_116300132384.celsius").val);
                            // Weitere Prüfung auf Heizprogramm, Programm soll nur laufen, wenn Heizung aktiv ist
                               var Zeit = new Date();
                                var Stunden = Zeit.getHours();
                                var Minuten = Zeit.getMinutes();
                                var Minuten_Tag = (Stunden * 60) + Minuten;
                                var temp = 360; //Heizprogramm_E[703]; // 300 Minuten ab Mitternacht -> 5 Uhr
                                var temp_2 = 1200; //Heizprogramm_E[45]; // 1200 Minuten ab Mitternacht -> 20 Uhr geht Heizung aus
                        console.log(WWtemperatur);
                        console.log(Leistungswert);
                        console.log(actualPower);
                        console.log(Leistungswert2);
                            if (actualPower <= Leistungswert && actualPower <= Leistungswert2 && WWtemperatur < 41){ // Prüfen ob Leistung für Warmwasser ist
                                //if (Heat_on == 0) { //Prüfen ob Heizung an ist
                                //Counterschleife = 1;
                                   if (Minuten_Tag > temp && Minuten_Tag < temp_2) {
                                // Prüfung, ob Heizung Taktet, wenn ja, Heizleistung um 2 verringern.
                                      if (Brennerstarts <= 30) {
                                    Element2 += 1;
                                    setState("javascript.0.Merker_Heizleistung", (Element2),true);
                                    Counterschleife = 2;
                                      } else {
                                    Element2 = 0;
                                    Counterschleife = 3;
                                if (Element2 >= 2){
                                    //setState("ems-esp.0.heatingCircuits.hc2.activeSwitchProgram"/*heatingCircuits.hc2.activeSwitchProgram*/, 5, true);
                                         setState("km200:heatingCircuits.hc2.activeSwitchProgram"/*heatingCircuits.hc2.activeSwitchProgram*/, 1, true);
                                         setState("km200:heatingCircuits.hc1.activeSwitchProgram"/*heatingCircuits.hc2.activeSwitchProgram*/, 1, true);
                                    Element2 = 0;
                                    setState("javascript.0.Merker_Heizleistung", (Element2),);
                                Counterschleife = 4;
                                    sendTo("whatsapp-cmb", "send", {
                                     text: 'Heizung ausgeschaltet. Folgende Parameter:' + (Brennerstarts) +' Minuten Brennerstarts und ' + (actualPower) + ' Heizung an'
                           // console.log(Heat_on);
                           // console.log(Minuten_Tag);
                           // console.log(Leistungswert);
                           // console.log(actualPower);
                           // console.log(Brennerstarts);
                            // console.log(Raumtemperatur);
                           // console.log(Element2);
                            // console.log(Element3);
                           console.log(Counterschleife);
                        // Wenn Raumtemperatur aber unter 20 Grad ist, Heizleistung erhöhen,
                        // wenn Heizung taktet wird Heizleistung dennoch niedriger da Thermostate ausgedreht
                        on({
                            change: "ne"
                        //    on({
                        //        id: "fritzdect.0.DECT_116300132384.celsius",
                        //        change: "ne"
                        //    }, async function (obj) {
                                // var Element2 = 1;
                                var Heat_on = (getState("km200.0.heatSources.hs1.flameStatus").val);
                                // var Leistungswert = (getState("km200.0.heatSources.powerSetpoint").val);
                                //var Brennerstarts = (getState("javascript.0.minutenZwischenBrennerStarts").val);
                                var Raumtemperatur_Mila = (getState("fritzdect.0.DECT_116300142272.celsius").val);
                                var Raumtemperatur2_Wohnz = (getState("km200:heatingCircuits.hc2.roomtemperature").val);
                                var Aussentemp = (getState("km200:system.sensors.temperatures.outdoor_t1").val)
                                //var Heizprogramm_E = (getState("km200.0.heatingCircuits.hc2.switchPrograms.E").val);
                                // getState("von allen Heizprogrammen") -> später, erst mal das Programm nehmen, welches durchgängig an ist.
                                // getState("km200.0.heatingCircuits.hc2.activeSwitchProgram") wir später benötigt, wenn andere Heizprogramme auch aktiviert sind
                                var temp = 420; //Heizprogramm_E[703]; // 300 Minuten ab Mitternacht -> 5 Uhr
                                //if (Heat_on == 1) {
                                //    Counterschleife = 7;
                                        Counterschleife = 5;
                                        if (Raumtemperatur_Mila <= 20 && Raumtemperatur2_Wohnz <= 18.5 || Raumtemperatur2_Wohnz <= 18.3 && Aussentemp <= 9 || Raumtemperatur2_Wohnz < 19.0 && Aussentemp > 9.1) {
                                            //setState("ems-esp.0.heatingCircuits.hc2.activeSwitchProgram"/*heatingCircuits.hc2.activeSwitchProgram*/, 4, true);
                                                 setState("km200:heatingCircuits.hc2.activeSwitchProgram"/*heatingCircuits.hc2.activeSwitchProgram*/, 0,true );
                                                 setState("km200:heatingCircuits.hc1.activeSwitchProgram"/*heatingCircuits.hc2.activeSwitchProgram*/, 0,true );
                                            Counterschleife = 6;
                                                text: 'Heizung eingeschaltet.' + (Raumtemperatur_Mila)+ ' Raumtemperatur Mila und' + (Raumtemperatur2_Wohnz) +'Raumtemperatur Wohnzimmer'
                                console.log(temp);
                                console.log(temp_2);
                                //console.log(actualPower);
                                //console.log(Leitungswert);
                                console.log(Raumtemperatur_Mila);
                                console.log(Raumtemperatur2_Wohnz);
                          seh nur ich den nicht?
                          edit: ist ja nicht aufgeklappt, sorry
                            km200:
                            nicht km200: <-- doppelpunkt
                            sondern km200. <-- da muss ein Punkt hin
                            in Zeile 14, 16, 18, 54, 55,80, 93, 94,121, 122
                            und die insanznummer fehlt da auch
                            also alle km200: auf km200.0. ersetzen... wie in Zeile 13 steht
                            wenn du schon was Editierst dann achte drauf das du es richtig machst
                              mwolle @Homoran last edited by
                              @homoran das ist der hier:
                              die ID heißt so: ems-esp.0.dhwCircuits.dhw1.wwcurtemp
                                ticaki last edited by ticaki
                                Ich bin echt gerade verwirrt...
                                lese bildet 🙂
                                  @arteck ich habe die IDs einfach kopiert...der hat den Doppelpunkt im Bauch. Ich hatte den Datenbaum gelöscht und noch mal neu aufbauen lassen, da ich den Heizungsregler neu getauscht hatte.
                                  T arteck 2 Replies Last reply Reply Quote 0
                                    @mwolle
                                    Du hast noch kein Bild gezeigt wo der gesamte Pfad über km200: bis zum Enddatenpunkt zu sehen ist 🙂
                                    Edit: da könnt ich mal all die ungenutzen States löschen
                                      never... es gibt keinen Datenbaum mit : im object..dann bist du auf caps lock gekommen.. und so ist der : reingekommen anstatt .
                                      ist der gleiche knopp
                                        mwolle @arteck last edited by mwolle
                                        @arteck ja du hast absolut recht...ich habe den Namen kopiert und nicht die ID...der Name der ID ist dann km200:XXX, die ID ist dann richtigerweise ems-esp.0.XXX...
                                        954
