    4. Test Adapter Awtrix-Light (Awtrix 3)
    • Bravestarr
      Bravestarr last edited by
      Hi!
      Now that I can show any information from ioBroker I fell in love with this adapter. This works great for "apps" But what is the idea to display "notifications" with e.g. "Spotify"? I have the current playing song in spotify in spotify-premium.0.player.trackName But when I use your adapter in "App mode" this will always be displayed. But I need this only when the value in spotify-premium.0.player.trackName changes and only one time. What is the best way to do this with your adapter? I saw "blocky" in your documentation. Is this the way to go?
      • DJMarc75
        DJMarc75 @Bravestarr last edited by DJMarc75
        @bravestarr sagte in Test Adapter Awtrix-Light:
        Yes
        example:
          Czarno13 @DJMarc75 last edited by Czarno13
          @djmarc75
          Aber es geht auch mit App:
          wird nur dann angezeigt, wenn Spotify läuft
          Bravestarr 1 Reply Last reply Reply Quote 0
          • Bravestarr
            Bravestarr @Czarno13 last edited by Bravestarr
            @czarno13 No the app is always active and does not disapear or appear when a song is played.
            What works is this:
            // Create a state change listener for spotify-premium.0.player.trackName
            on({ id: 'spotify-premium.0.player.trackName', change: 'ne', ack: true }, function (obj) {
                if (!obj || !obj.state || obj.state.val === null) {
                    console.warn('Invalid trackName state object or null value.');
                    return;
                const newTrackName = obj.state.val;
                const notificationText = `Now playing: ${newTrackName}`;
                if (newTrackName.trim() === '') {
                    console.warn('Track name is empty.');
                    return;
                // Send the notification to Awtrix display
                sendTo('awtrix-light', 'notification', { text: notificationText, repeat: 1, duration: 5, stack: true, wakeup: true }, (res) => {
                    if (res && res.error) {
                        console.error(res.error);
            C M 2 Replies Last reply Reply Quote 1
              Czarno13 @Bravestarr last edited by Czarno13
              @bravestarr
              no, for me it works exactly like that, it only displays something when spotify is playing
                MCU @Bravestarr last edited by
                @bravestarr Please set all of Code in Code Tags. Thanks.
                • Bravestarr
                  @czarno13 said in Test Adapter Awtrix-Light:
                  @bravestarr
                  Yes, but what I wanted and accomplished with the notice triggered by the js adapter is when a songs starts its name is briefly displayed and disappears after 3 seconds. I do not want to keep the song visible while spotify is playing.
                  BTW: how can I display an icon cia id in the js notice?
                  • Bravestarr
                    Bravestarr @MCU last edited by
                    @mcu done
                    DJMarc75 1 Reply Last reply Reply Quote 1
                    • DJMarc75
                      @bravestarr Warum eigentlich auf englisch ??? Du hast in Deinen vergangenen Beiträgen in deutsch geschrieben.... ist das Schikane oder ein Scherz ??
                      Bravestarr 1 Reply Last reply Reply Quote 1
                      • Bravestarr
                        Bravestarr @DJMarc75 last edited by
                        @djmarc75 ich kann auch deutsch, aber so verstehen es mehr Leute. Das hilft ja auch anderen wenn ich dumme Fragen stelle
                        • DJMarc75
                          definitiv nicht - im deutschen Forum 😉
                          Das Blockly schon probiert ?
                          Das ist nämlich genau für so was vorgesehen.
                          Bravestarr 1 Reply Last reply Reply Quote 3
                          • haus-automatisierung
                            haus-automatisierung Developer Most Active @JB_Sullivan last edited by
                            @jb_sullivan sagte in Test Adapter Awtrix-Light:
                            Uiiii - mit der 0.71 Firmware kann man auch Ringtone Dateien abspielen.
                            Was ist daran neu in der Version?
                              Mir persönlich kommt es so vor, als ob der Adapter eine Art Datenbank nutzt, welche im Hintergrund eingelesen wird.
                              Ich hab Dir das doch schon öfter hier erklärt: Der Adapter selbst macht hier gar nichts. Die komplette Konfigurationsseite kommt so aus dem Admin-Adapter. Also: Keine "Datenbank" o.ä. Das ist pures JavaScript im Frontend auf dem Client.
                              Du hast ja richtig viele Apps eingerichtet, oder? Ich könnte mir vorstellen, dass die Validierung der Felder nie für hunderte Felder getestet wurde. Eventuell ist das nicht sehr performant. Das wäre auch ein Issue für den Admin-Adapter und man müsste das mal genau untersuchen mit verschiedenen Clients/Browsern usw.
                              • Ben1983
                                Ben1983 last edited by
                                @haus-automatisierung bei mir tritt folgendes Verhalten manchmal auf:
                                Abends wird das Display mit power = false deaktivert.
                                der Adapter meldet ca. 2-4 min später:
                                2023-07-26 22:04:55.074 - warn: awtrix-light.0 (802) (custom?name=gridpower) Unable to update custom app "gridpower": AxiosError: timeout of 3000ms exceeded
                                2023-07-26 22:14:39.220 - error: awtrix-light.0 (802) Unable to perform action for indicator.1.active - API is not connected (device not reachable?)
                                2023-07-26 22:14:39.224 - error: awtrix-light.0 (802) Unable to perform action for indicator.3.active - API is not connected (device not reachable?)
                                2023-07-26 22:14:39.228 - error: awtrix-light.0 (802) Unable to perform action for apps.storagepower.visible - API is not connected (device not reachable?)
                                danach keine Fehlermeldung mehr.
                                Das Gerät wird morgens wieder aktiviert (display.power = true)
                                Daraufhin ca. 30s später:
                                2023-07-27 06:00:36.240 - error: awtrix-light.0 (802) Unable to perform action for display.power - API is not connected (device not reachable?)
                                dann ist ca. 30min Ruhe und dann fängt es so an:
                                2023-07-27 06:30:50.152 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
                                2023-07-27 06:30:52.194 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
                                2023-07-27 06:30:58.149 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
                                2023-07-27 06:31:00.169 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
                                2023-07-27 06:31:02.068 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
                                2023-07-27 06:31:04.126 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
                                2023-07-27 06:31:06.184 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
                                2023-07-27 06:31:08.198 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
                                2023-07-27 06:31:10.228 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
                                2023-07-27 06:31:14.182 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
                                2023-07-27 06:31:16.174 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
                                Das Gerät ist aus.
                                Neustart und alles läuft einwandfrei.
                                Die Meldung, dass nicht conected ist, scheint also zu stimmen, aber keine Ahnung, ob das Gerät auch startet durch display.power = true
                                (Mit meinen manuellen Versuchen hat es bis jetzt geklappt, allerdings ist morgens das display, wenn ich ins Büro komme manchmal dunkel)=>(Geräthängt dauerhaft am USB)
                                arteck NWH 2 Replies Last reply Reply Quote 0
                                  arteck Developer Most Active @Ben1983 last edited by arteck
                                  @ben1983 sagte in Test Adapter Awtrix-Light:
                                  damit hängt es zusammen.... habs auch .. ich mach die dann auf brightness 0 ..
                                  dann macht die kein disco.. scheint als ob die in Batterie schonmodus geht .. und macht das WIFI aus..
                                  reconnected sich dann aber nicht
                                  • Ben1983
                                    Ben1983 @arteck last edited by
                                    @arteck OK, allerdings ist dien "Brightness" ja nur readable.
                                      @ben1983 dann nimm den richtigen
                                      Ben1983 1 Reply Last reply Reply Quote 1
                                      • Ben1983
                                        @arteck Danke. Werde es umstellen und beobachten.
                                        Scheint als dann wirklich ein sporadisches "Fehlverhalten" der Uhr zu sein, denn jeden Tag ist es nicht.
                                        • Bravestarr
                                          @djmarc75 Oh sorry. Diese Seite wurde durch GitHub verlinkt vom Entwickler dieses Adapters.
                                          Blocky ist doch eine Klicky-Bunti Version im JS Adapter? Ich denke, dass JS selber hier viel mehr kann als man mit Blocky abbilden könnte.
                                          • Bravestarr
                                            Kann man ohne JS/Blocky auch mehrere Werte in einer custom app darstellen? Also Beispiel Spotify Artist + Song Titel über die Oberfläche des Awtrix Adapters? Oder geht immer nur ein Wert?
                                            81.1k
                                            2160
                                            1216727
