Yamaha Adaper - Problem seit Update
Hallo Rainer,
wie schaltet man nen Adapter auf Debug?
Herbert
Edit: Hab gefunden wie man den Debug aktiviert.
Selber Fehler bei mir. Irgendwelche Lösungsansätze?
hier der aktuelle LOG. Fehler ist noch da - ich hoffe ihr könnt uns damit helfen.
! host-raspberrypi 2016-07-15 20:33:27.146 info Restart adapter system.adapter.yamaha.0 because enabled
! host-raspberrypi 2016-07-15 20:33:27.145 error instance system.adapter.yamaha.0 terminated with code 6 (uncaught exception)
! TypeError: 2016-07-15 20:33:26.126 error at WS. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:258:10)
! TypeError: 2016-07-15 20:33:26.126 error at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:441:14)
! TypeError: 2016-07-15 20:33:26.126 error at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20)
! TypeError: 2016-07-15 20:33:26.126 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
! TypeError: 2016-07-15 20:33:26.126 error at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:323:16)
! TypeError: 2016-07-15 20:33:26.126 error at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
! TypeError: 2016-07-15 20:33:26.126 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
! TypeError: 2016-07-15 20:33:26.126 error at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
! TypeError: 2016-07-15 20:33:26.126 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8)
! TypeError: 2016-07-15 20:33:26.126 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
! TypeError: 2016-07-15 20:33:26.126 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
! TypeError: 2016-07-15 20:33:26.126 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12)
! TypeError: 2016-07-15 20:33:26.126 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
! TypeError: 2016-07-15 20:33:26.126 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:150:27)
! TypeError: 2016-07-15 20:33:26.126 error at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2647:61
! TypeError: 2016-07-15 20:33:26.126 error at /opt/iobroker/node_modules/iobroker.yamaha/lib/soef.js:681:54
! TypeError: 2016-07-15 20:33:26.126 error Cannot read property 'val' of null
! uncaught 2016-07-15 20:33:26.120 error exception: Cannot read property 'val' of null
! yamaha-0 2016-07-15 20:33:26.059 info starting. Version 0.1.8 in /opt/iobroker/node_modules/iobroker.yamaha
! yamaha-0 2016-07-15 20:33:25.983 debug statesDB connected
! yamaha-0 2016-07-15 20:33:25.959 debug objectDB connected
! host-raspberrypi 2016-07-15 20:33:23.081 info instance system.adapter.yamaha.0 started with pid 868
! host-raspberrypi 2016-07-15 20:33:23.060 info object change system.adapter.yamaha.0Gruß
Herbert
ich hab zwar selber keinen Yamaha Receiver aber da sich bisher niemand anders gefunden hat, versuche ich mal den Blindflug …
Ich hab gestern beim Umstellen auf Redis eine Verhaltensänderung am js-controller festgestellt, die auch hier die Ursache zu sein scheint:
Wenn für ein in der Objekt-Datenbank angelegtes Attribut noch kein Wert in die states-DB eingetragen wurde, wird nun als obj null gesendet und nicht nur für obj.val. Deswegen schlägt jetzt auch die Funktion readAllExistingObjects fehl, weil diese ohne Prüfung auf die Werte aller unter yamaha.0 gefundenen Attribute zugreift.
Ich habe nun mal die entsprechende js-Datei angepasst.
Kann jemand mal die Datei im Verzeichnis /opt/iobroker/node_modules/iobroker.yamaha/lib austauchen und schauen, ob der Adapter nun wieder läuft?
632_soef.js -
Hallo nobody,
es läuft wieder!!!
Vielen, vielen Dank
Herbert
ok, erstelle ich mal einen Pull-Request auf github für den Adapter.
Weiß jemand, ob soef sich noch um den Adapter kümmert?
Adapter läuft wieder. Vielen Dank.
Leider bekomme ich immer noch den ominösen Fehler alle 120 Sekunden, also im Updateintervall, im Log. Hatte auch schon mal den Yamaha AV vom Netz genommen, hat aber nix gebracht.
> yamaha-0 2016-07-19 20:38:34.982 error {}Hatte diesbezüglich schon einen anderen Thread aufgemacht aber noch nichts zur Fehlerbeseitigung gehört.
Den Fehler erhalte ich auch, ganz frische ioBroker Installation.
Komischerweise werden beim Start des Adapters alle notwendigen Statusangaben geladen, nur das Update funktioniert nicht. Daher lasse ich den Adapter über die Zeitsteuerung alle 2min neu laden. Das klappt zumindest als Workaround.
Nach einer komplette Neuinstallation, habe ich auf einmal auch ein Problem mit dem Yamaha Adapter. Im Log steht folgendes:
host.ioBroker-RasPi 2017-10-20 13:07:06.768 error instance system.adapter.yamaha.0 terminated with code 7 (Adapter already running)
host.ioBroker-RasPi 2017-10-20 13:07:03.711 info instance system.adapter.yamaha.0 started with pid 12759
host.ioBroker-RasPi 2017-10-20 13:06:33.687 info Restart adapter system.adapter.yamaha.0 because enabled
das geht dann in einer Tour durch. Neustart und Neuinstallation brachten leider keine Änderung. Jemand eine Idee?
Gruss Joachim
Neustart und Neuinstallation brachten leider keine Änderung `
Das wundert mich.Dieser fehler wird üblicherweise durch einen Neustart vom Raspi behoben.
Ursache ist, dass (wahrscheinlich bei einem Update) die laufende Instanz nicht beendet wurde, nach dem Update eine weitere gestertet wird, weil die alte ja gestoppt sein müsste.
Du müsstest mal in der Konsole mit top nach den PID der laufenden Instanzen von io.yamaha suchen und diese mit````
sudo kill -9Gruß Rainer</pid> -
sudo kill -9Gruß Rainer</pid> `Ich hatte immer nur Iobroker neu gestartet, nicht den Rapspi. Ich habe dann mal bewusst eine falsche IP Adresse eingetragen und wieder rausgenommen und siehe da, auf einmal klappte es.
Gruss Joachim
Der Yamaha Adapter ist auch bei mir der einzige Adapter, der nicht automatisch gekillt wird. Hier hilft tatsächlich nur "iobroker stop", "kill -9 <yamaha pid="">", "iobroker start".</yamaha>
ich benutze seit längerem den Yamaha Adapter (Vers. 0.3.17). Nun ist ja eine neue Version raus gekommen (Vers.0.3.18). Auf gitHub finde ich aber leider keinen ChangeLog dazu. Kann mir jemand sagen was an dem Adapter verändert wurde?
Beste Grüße!
Danke für den Hinweis!
ich habe derzeit große Probleme mit dem Yamaha-Adapter in ioBroker und komme zu keiner Lösung.
Es sei dazu erwähnt, dass dieses Gebiet für mich absolutes Neuland ist.
Leider kann ich nicht genau sagen, wann der Fehler aufgetreten ist. Ich erinnere mich nur noch daran, dass nach einem Neustart des Raspberry (3b+) der Adapter sich nicht mehr verbinden wollte (Lämpchen wechselte immer zwischen grün und rot). Neustart von ioBroker und Raspberry brachten leider keinen Erfolg. Auch eine Neuinstallation des Adapters sorgte nicht für Abhilfe.
Einen Auszug aus dem Log mit der Fehlermeldung habe ich unten beigefügt.
Für Hilfe wäre ich sehr dankbar, bin am verzweifeln…
Liebe Grüße
19317_fehler_yamahaadapter.png -
IP Richtig?
@ sigi234
Ja, die Ip-Adresse ist so in der Fritzbox reserviert, bzw. festgesetzt.
Bevor ich den Raspberry neu gestartet hatte, lief der Adapter mit dieser IP-Adresse einwandfrei.
19317_yamaha_ip.png -
Ja, wenn ich die IP in den Browser eingebe erreiche ich die "Webinstanz" des Yamaha Verstärkers ohne Probleme.
MfG
Bruce
