    5. Script lässt sich nicht importieren
      crunchip Forum Testing Most Active @Nefetz last edited by
      @nefetz welche Fehlermeldung?
      Nefetz 1 Reply Last reply Reply Quote 0
      • Nefetz
        Nefetz @crunchip last edited by
        @crunchip
        Wenn ich es ber "Blöcke importieren" mache, kommt diese Meldung:
        BlocklyJavascriptTypeScriptRules
        Skript läuft nicht
        Protokoll
        Fehler beim Importieren
        Error: textToDom was unable to parse: <xml xmlns="https://developers.google.com/blockly/xml"> <block type="schedule" id="Q$=Ccopsd-uFI0g2/Tj" x="-62" y="37"> <field name="SCHEDULE">*/60 * * * *</field> <statement name="STATEMENT"> <block type="comment" id="YDc*pElpmgz!IH!hjYf*"> <field name="COMMENT">Maximalen und Minimalen Preis ermitteln</field> <next> <block type="variables_set" id="B:K}F;q_vqBrLl.Bgx2M"> <field name="VAR" id="THiM4y#NlzZ-ZAX9?uX5">preisDelta</field> <value name="VALUE"> <block type="math_number" id="#WDrVc5kX)B_RAVM7WtZ"> <field name="NUM">0</field> </block> </value> <next> <block type="variables_set" id="Q80|S3S~:f+-:fUm39#l"> <field name="VAR" id="*0|tT|UDQ(nmLv{tGwVm">maximalerPreis</field> <value name="VALUE"> <block type="math_number" id="){:4(-C2+H}4}SeNa91"> <field name="NUM">-5</field> </block> </value> <next> <block type="variables_set" id="wi~Bc]cUx8ay1tYr?Ft3"> <field name="VAR" id="JI9?]{XJ1JS-+tO6n4iu">minimalerPreis</field> <value name="VALUE"> <block type="math_number" id="{vEf|/WjHMIHkM;/Rzf"> <field name="NUM">5</field> </block> </value> <next> <block type="controls_forEach" id="ZeNLSBug06L.gXBO]k)z"> <field name="VAR" id="tYvq5-S3n.[Igz#{=nJ/">i</field> <value name="LIST"> <block type="selector" id="T0ZK!1}xcui=#C(tPHd"> <field name="TEXT">channel[state.id=tibberconnect.0.Homes.<YOUR_TIBBER_HOME_ID>.PricesToday..total]</field> </block> </value> <statement name="DO"> <block type="controls_if" id="3!9Eo.Nb|6,Z3Q)7,tL"> <value name="IF0"> <block type="logic_compare" id="7AnCO5T~:a20K_T:wvL"> <field name="OP">LT</field> <value name="A"> <block type="variables_get" id="2u#A4!97CEF5PmkGbpAK"> <field name="VAR" id="0|tT|UDQ(nmLv{tGwVm">maximalerPreis</field> </block> </value> <value name="B"> <block type="get_value_var" id="W[8f8:r.olh2?ciy=U8K"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text"> <field name="TEXT"></field> </shadow> <block type="variables_get" id="[K_G~8q7BbJ)DArJvm"> <field name="VAR" id="tYvq5-S3n.[Igz#{=nJ/">i</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="variables_set" id="gVe_mFQ.b2RLcbd.)v/"> <field name="VAR" id="0|tT|UDQ(nmLv{tGwVm">maximalerPreis</field> <value name="VALUE"> <block type="get_value_var" id="6){0o8|(Gm@GCAdawH$"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text"> <field name="TEXT"></field> </shadow> <block type="variables_get" id="@w!k@Jl^ar;nmu,QSiU"> <field name="VAR" id="tYvq5-S3n.[Igz#{=nJ/">i</field> </block> </value> </block> </value> </block> </statement> <next> <block type="controls_if" id="lJQ-1$3:[qu~#J_SmN!n"> <value name="IF0"> <block type="logic_compare" id="1mJ(kzhj^@8SKc0JJ/A"> <field name="OP">GT</field> <value name="A"> <block type="variables_get" id=":v6KfNRBs1mqUF@0K@="> <field name="VAR" id="JI9?]{XJ1JS-+tO6n4iu">minimalerPreis</field> </block> </value> <value name="B"> <block type="get_value_var" id="Kmo1b)1T[1X=ETO-!i|$"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text"> <field name="TEXT"></field> </shadow> <block type="variables_get" id="!c-!1V/0MHGKnQ,fp7D"> <field name="VAR" id="tYvq5-S3n.[Igz#{=nJ/">i</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="variables_set" id="821h;.v7(yvkJ$r1dU)]"> <field name="VAR" id="JI9?]{XJ1JS-+tO6n4iu">minimalerPreis</field> <value name="VALUE"> <block type="get_value_var" id="zjti$NQ6jyh}Qyj9h$4"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text"> <field name="TEXT"></field> </shadow> <block type="variables_get" id="oCteKnTXZ6JX:($J@n)"> <field name="VAR" id="tYvq5-S3n.[Igz#{=nJ/">i</field> </block> </value> </block> </value> </block> </statement> </block> </next> </block> </statement> <next> <block type="controls_forEach" id="Ry{Sc;21]^0EXMAvjF*"> <field name="VAR" id="tYvq5-S3n.[Igz#{=nJ/">i</field> <value name="LIST"> <block type="selector" id="X)wXgqLk~xBD_Yezorq"> <field name="TEXT">channel[state.id=tibberconnect.0.Homes.<YOUR_TIBBER_HOME_ID>.PricesTomorrow.*.total]</field> </block> </value> <statement name="DO"> <block type="controls_if" id="Z#pidO$8iTHECJBmODY["> <value name="IF0"> <block type="logic_compare" id="Qu:VI?N:3W)6]0K-Cxr-"> <field name="OP">LT</field> <value name="A"> <block type="variables_get" id="cbJy=ph8.Bv)1M3yosuN"> <field name="VAR" id="*0|tT|UDQ(nmLv{tGwVm">maximalerPreis</field> </block> </value> <value name="B"> <block type="get_value_var" id="n$C,w#DPTzBYwp**p2w."> <field name="ATTR">val</field> <value name="OID"> <shadow type="text"> <field name="TEXT"></field> </shadow> <block type="variables_get" id=")WWZ6)NPkUj|*Ka|6/T*"> <field name="VAR" id="tYvq5-S3n.[Igz#{=nJ/">i</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="variables_set" id="}AP-8kvtEVyo7)]_{Q%!"> <field name="VAR" id="*0|tT|UDQ(nmLv{tGwVm">maximalerPreis</field> <value name="VALUE"> <block type="get_value_var" id="z3df}yqg|u3OdR{lZ(_1"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text"> <field name="TEXT"></field> </shadow> <block type="variables_get" id="c{FBum;F~QmM}gBqvQ;:"> <field name="VAR" id="tYvq5-S3n.[Igz#{=nJ/">i</field> </block> </value> </block> </value> </block> </statement> <next> <block type="controls_if" id="@Ft4fd1{L1;BP2lE)T4J"> <value name="IF0"> <block type="logic_compare" id="2,mbJna[!ea{zB%A#q2"> <field name="OP">GT</field> <value name="A"> <block type="variables_get" id="3$)Wb=Bjx]A%G(j6+?CJ"> <field name="VAR" id="JI9?]{XJ1JS-+tO6n4iu">minimalerPreis</field> </block> </value> <value name="B"> <block type="get_value_var" id="J1lQOWH*}NNyn2zzb0:r"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text"> <field name="TEXT"></field> </shadow> <block type="variables_get" id="5p*9$QLX:!!8dV,(tiOt"> <field name="VAR" id="tYvq5-S3n.[Igz#{=nJ/">i</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="variables_set" id="@+UC_DtT#WzgzDqY;rWe"> <field name="VAR" id="JI9?]{XJ1JS-+tO6n4iu">minimalerPreis</field> <value name="VALUE"> <block type="get_value_var" id="tEt4mDS|]^oA.9M3A,)l"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text"> <field name="TEXT"></field> </shadow> <block type="variables_get" id="6S+cZHK;C%Q||D0O:2t"> <field name="VAR" id="tYvq5-S3n.[Igz#{=nJ/">i</field> </block> </value> </block> </value> </block> </statement> </block> </next> </block> </statement> <next> <block type="comment" id="PRV_T.t:f$4]LrzVSyL."> <field name="COMMENT">Preisunterschied ermitteln</field> <next> <block type="variables_set" id="92P-#dfwg0D9vCD2%uAj"> <field name="VAR" id="THiM4y#NlzZ-ZAX9?uX5">preisDelta</field> <value name="VALUE"> <block type="math_arithmetic" id="bC3@h^r-9s+X+]T.(D:]"> <field name="OP">MINUS</field> <value name="A"> <shadow type="math_number" id="(]v.Ts.1glWWn_PKofd"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="~uyQY=!,cEl@r#2#_LBP"> <field name="VAR" id="0|tT|UDQ(nmLv{tGwVm">maximalerPreis</field> </block> </value> <value name="B"> <shadow type="math_number" id="dqYRu)n+/sjtApX$8Yiw"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="Lk)rK7m)Hy0VV-haPHAn"> <field name="VAR" id="JI9?]{XJ1JS-+tO6n4iu">minimalerPreis</field> </block> </value> </block> </value> <next> <block type="comment" id="t@k=o?E^hJlO5$79K@"> <field name="COMMENT">Falls der Preisunterschied die Akkunutzung rechtfertigt, wird der Akku genutzt</field> <next> <block type="controls_if" id="0MLldLQDZwV@eRb#0(LS"> <mutation else="1"></mutation> <value name="IF0"> <block type="logic_compare" id=".=/G1=S,tn95dCD=a/T"> <field name="OP">GT</field> <value name="A"> <block type="variables_get" id="|t{d%|xC/7,.Ym:VBF4h"> <field name="VAR" id="THiM4y#NlzZ-ZAX9?uX5">preisDelta</field> </block> </value> <value name="B"> <block type="math_number" id="/iRZP617nIw._enOfgSL"> <field name="NUM">0.12</field> </block> </value> </block> </value> <statement name="DO0"> <block type="debug" id="X._8ZET8_3}_9v29kAe]"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="S.Z#.)-8B(S9?w#Q)U="> <field name="TEXT">Preisdelta rechtfertigt Akkunutzung</field> </shadow> <block type="text_join" id="{utoh0lTh2Ws1A)h|[l2"> <mutation items="6"></mutation> <value name="ADD0"> <block type="text" id=".W]?ZV2=]u5h{4TCMR@"> <field name="TEXT">Preisdelta rechtfertigt Akkunutzung. Preisdelta beträgt: </field> </block> </value> <value name="ADD1"> <block type="variables_get" id=";#TZiJ46oa:9{kHy8:{d"> <field name="VAR" id="THiM4y#NlzZ-ZAX9?uX5">preisDelta</field> </block> </value> <value name="ADD2"> <block type="text" id="rBE/bZM$P[/)Y%MJU}mj"> <field name="TEXT">der minimale Preis liegt bei: </field> </block> </value> <value name="ADD3"> <block type="variables_get" id="!DUj?B^Drd)RS8=R7V5G"> <field name="VAR" id="JI9?]{XJ1JS-+tO6n4iu">minimalerPreis</field> </block> </value> <value name="ADD4"> <block type="text" id="$!@9xez4F3u}]Wcc34;2"> <field name="TEXT">der maximale Preis liegt bei: </field> </block> </value> <value name="ADD5"> <block type="variables_get" id="MU$.hrQ3=@c;qEM14AWV"> <field name="VAR" id="*0|tT|UDQ(nmLv{tGwVm">maximalerPreis</field> </block> </value> </block> </value> <next> <block type="controls_if" id="~3,cyF(uO=an#u@HbxRL"> <value name="IF0"> <block type="logic_compare" id="N%4J3H@cg/^$]b++rxF("> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id=",*$eG53]Nk,@N%M+|0:$"> <field name="ATTR">val</field> <field name="OID">tibberconnect.0.Homes.<YOUR_TIBBER_HOME_ID>.CurrentPrice.level</field> </block> </value> <value name="B"> <block type="text" id="=ask@;i[aq5qK_:bYNJ"> <field name="TEXT">VERY CHEAP</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="7vPOlwQuQ_}Di/9b,c."> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">mqtt-client.1.W.<YOUR_VICTRON_ID>.settings.0.Settings.CGwacs.BatteryLife.MinimumSocLimit</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="S9z_Wu+y$._]?BvlPlKB"> <field name="TEXT">{"value": 65.0}</field> </block> </value> <next> <block type="debug" id="~Nee+$z9XFTsB%cri~J."> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="={G7fvR_{8{PBD~4i2Bf"> <field name="TEXT">Akku wird sehr günstig aufgeladen</field> </shadow> </value> </block> </next> </block> </statement> <next> <block type="controls_if" id="^L}BSR?02lI,BEU{Ius-"> <value name="IF0"> <block type="logic_compare" id="*x}#q?Kx%xVfFR4cZ@rU"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="ynY}m^Ta1Op_L$P,r5^"> <field name="ATTR">val</field> <field name="OID">tibberconnect.0.Homes.<YOUR_TIBBER_HOME_ID>.CurrentPrice.level</field> </block> </value> <value name="B"> <block type="text" id="AUg0E=C]|$o@tTA@bIYO"> <field name="TEXT">CHEAP</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="VAo[NXdcPLoduMe?{c6"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">mqtt-client.1.W.<YOUR_VICTRON_ID>.settings.0.Settings.CGwacs.BatteryLife.MinimumSocLimit</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="i2Rksc_AB@lqJIdm/A-m"> <field name="TEXT">{"value": 65.0}</field> </block> </value> <next> <block type="debug" id="D+|@l$U^w@zium1gplum"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="~eo=^$tA!b63m7$QQBQK"> <field name="TEXT">Akku wird günstig aufgeladen</field> </shadow> </value> </block> </next> </block> </statement> <next> <block type="controls_if" id=",cSQh64l1)uV@@QJm@ey"> <value name="IF0"> <block type="logic_compare" id="LN98aVjFFeNI5|}XC%R("> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="mUF-LsDe1pdy{YoSNf]?"> <field name="ATTR">val</field> <field name="OID">tibberconnect.0.Homes.<YOUR_TIBBER_HOME_ID>.CurrentPrice.level</field> </block> </value> <value name="B"> <block type="text" id="4-oZuLL,=MSmdV-f!$;"> <field name="TEXT">NORMAL</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="OjnsK#jVI#fQu_H|!%5f"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">mqtt-client.1.W.<YOUR_VICTRON_ID>.settings.0.Settings.CGwacs.BatteryLife.MinimumSocLimit</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="||CyM[HAzs-}PUBPK{Dd"> <field name="TEXT">{"value": 65.0}</field> </block> </value> <next> <block type="debug" id="oweIIS#*88mfntsme#]"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="WQaD5|#OcxNWaWmaW,aT"> <field name="TEXT">Akku wird aufgeladen</field> </shadow> </value> </block> </next> </block> </statement> <next> <block type="controls_if" id="}5[@|W3UmYRbqLyGs7"> <value name="IF0"> <block type="logic_compare" id="/|Fj$xR#@M|3ExW,}6+"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="*SJ4L:Jr$Mo%_X3i-#5l"> <field name="ATTR">val</field> <field name="OID">tibberconnect.0.Homes.<YOUR_TIBBER_HOME_ID>.CurrentPrice.level</field> </block> </value> <value name="B"> <block type="text" id="l%4E[2[OqXf+a$FCD{$/"> <field name="TEXT">EXPENSIVE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="qlAvW-3/O!S0fbfS$+D!"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">mqtt-client.1.W.<YOUR_VICTRON_ID>.settings.0.Settings.CGwacs.BatteryLife.MinimumSocLimit</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="6R|:F@w]I,iKAV!ulIIH"> <field name="TEXT">{"value": 30.0}</field> </block> </value> <next> <block type="debug" id="~:ch(hz/%E]mL/(i{cQ-"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id=".wxx{iT[e^bH5T|G,[|"> <field name="TEXT">Akku kompensiert teure Zeit</field> </shadow> </value> </block> </next> </block> </statement> <next> <block type="controls_if" id="|i]{S|1ODd3E1X?LH7IA"> <value name="IF0"> <block type="logic_compare" id="L?p~4.aa5+}irLrb;9-L"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="Xdl)y0gL8c2uOK0wV!se"> <field name="ATTR">val</field> <field name="OID">tibberconnect.0.Homes.<YOUR_TIBBER_HOME_ID>.CurrentPrice.level</field> </block> </value> <value name="B"> <block type="text" id="}g2#WvtgmA{@/[fZx#ry"> <field name="TEXT">VERY EXPENSIVE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id=")Vju|u2tJ_7fGcp27@I+"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">mqtt-client.1.W.<YOUR_VICTRON_ID>.settings.0.Settings.CGwacs.BatteryLife.MinimumSocLimit</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="!Y{V9GMd%|HT(Gq+gMzm"> <field name="TEXT">{"value": 30.0}</field> </block> </value> <next> <block type="debug" id="YunhZ$fRraS/4.#w4#"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="XF3[j7p_Ez8NbcN=3GxF"> <field name="TEXT">Akku kompensiert sehr teure Zeit</field> </shadow> </value> </block> </next> </block> </statement> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </statement> <statement name="ELSE"> <block type="comment" id="hA1$1W{4+tYNbd{aEr|k"> <field name="COMMENT">Akku wird nicht genutzt.</field> <next> <block type="debug" id="%~H-3Vn}Ko@?Mj1}=xE)"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="oNOQ?)M?;H7],+$vSxA"> <field name="TEXT">test</field> </shadow> <block type="text" id=",G,Xu~q=gT{Q|IF~UD9A"> <field name="TEXT">Akku aktuell nicht genutzt. SoC unverändert</field> </block> </value> </block> </next> </block> </statement> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </statement> </block> <block type="comment" id="h^7IDx!jkiM6nW!BP]7-" x="338" y="188"> <field name="COMMENT">channel[state.id=tibberconnect.0.Homes.<homeID>.PricesToday..total]</field> </block> <block type="comment" id="(PKF$X_AyX^T_jj$V[h5" x="413" y="438"> <field name="COMMENT">....Homes.<homeID>.PricesToday..total]</field> </block> <block type="debug" id="UNPb8.9V|VIxsjjV{VNx" x="117" y="1124"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="~fnjne.+A{,w4}|.pvZ"> <field name="TEXT">Akku wird günstig aufgeladen</field> </shadow> </value> </block></xml>
        Und wenn ich es über "Skripte importieren" mache , kommt diese Meldung:
        Fehler
        Error: Can't find end of central directory : is this a zip file ? If it is, see https://stuk.github.io/jszip/documentation/howto/read_zip.html
          crunchip Forum Testing Most Active last edited by crunchip
          @nefetz das liegt daran, das du deine Id`s nicht angepasst hast, bzw liegt es an dem
          <YOUR_TIBBER_HOME_ID> , daher funktioniert der import nicht
          du musst vorher alle Zeilen mit Id anpassen, z.b.
          diese
          <field name="TEXT">channel[state.id=tibberconnect.0.Homes.<YOUR_TIBBER_HOME_ID>.PricesToday.*.total]</field>
          oder diese
          steht aber eigentlich auf der Seite
          Es folgt der Code im Textfile. Der kann einfach importiert werden (**Vorher Suchen-Ersetzen -> die IDs ändern**):
          Nefetz 1 Reply Last reply Reply Quote 2
          • Nefetz
            Nefetz @crunchip last edited by Nefetz
            @crunchip
            Moin!
            Das hatte ich auch schon erledigt. Ich wollte hier nur nicht den Code mit meinen ID's posten.
            Ich schicke dir mal den Code mit meinen eingetragenen ID's via PM
            Edit: Geht leider nicht, weil Text zu lang.
              @nefetz siehe pm
                markusB12 @crunchip last edited by
                @crunchip
                Moin, bei mir lässt sich das Script auch nicht importieren.
                Habt ihr eine Lösung gefunden? 🙂
                  arteck Developer Most Active @markusB12 last edited by arteck
                  @markusb12 die steht doch da oben .. was zu tun ist.. ausserdem auch im Text ...
                  Es folgt der Code im Textfile. Der kann einfach importiert werden (Vorher Suchen-Ersetzen -> die IDs ändern):
                  • David G.
                    David G. @arteck last edited by David G.
                    Ich hatte noch nie Probleme Blocklys zu importieren, wo verweise auf nicht vorhandene Datenpunkte drinnen waren.
                    Gefühlt schon 100 mal gemacht mit Skripten die hier im Forum geteilt wurden.
                    Dann steht im Block anstatt dem Namen einfach der ganze Pfad.
                    Ich denke den Hinweis hat der Ersteller so gegeben, da es schneller ist, als sich die ganzen Blöcke zu suchen.
                    Meistens scheitert der Import, weil irgendwo ein Zeilenumbruch oder eine Leerstelle falsch ist.
                      hier
                      akkuBlocklyLadescriptTibber.txt
                        markusB12 @arteck last edited by markusB12
                        danke, hat jetzt funktioniert 🤙 hab irgendwas falsch gemacht beim suchen und ersetzen
                          Homoran Global Moderator Administrators @markusB12 last edited by
                          @markusb12 sagte in Script lässt sich nicht importieren:
                          hattest du ein Windows Programm genutzt?
                            markusB12 @Homoran last edited by
                            ja 🙂
                            Homoran D 2 Replies Last reply Reply Quote 0
                              ja 🙂
                              nimm für linux nur notepad++ in Unix Konfiguration
                                dan11hh @markusB12 last edited by
                                @markusb12 Und nutzt Du das Skript? Bin auch dabei es zu importieren, aber tibberconnect will noch nicht so richtig...
                                  crunchip Forum Testing Most Active @dan11hh last edited by
                                  @dan11hh wo hakt es denn? siehe https://forum.iobroker.net/post/1005416
                                  es dürfen keine > < mehr drin sein
                                    dan11hh @crunchip last edited by
                                    @crunchip Ja. Danke. Habe alles inkl. <> ersetzt. Welches Encoding muss ich für den Import nutzen? Unicode, ja oder? Und Line Breaks? Unix?
                                    Hatte das Problem bisher nie.
                                      @dan11hh sagte in Script lässt sich nicht importieren:
                                      Unix
                                        @crunchip Ich krieg es nicht rein. Sollte sich doch auch ohne funktionierenden TibberConnect Adapter importieren lassen. Wollte auf TibberLink umbauen, aber soweit komme ich gar nicht. Danke für Deine Geduld. Ich probier morgen nochmal die IDs auszutauschen. Vllt ist da was schiefgelaufen. Gute Nacht!
                                        890
