    4. Test Adapter Awtrix-Light (Awtrix 3)
    • Ben1983
      Ben1983 last edited by
      @haus-automatisierung bei mir tritt folgendes Verhalten manchmal auf:
      Abends wird das Display mit power = false deaktivert.
      der Adapter meldet ca. 2-4 min später:
      2023-07-26 22:04:55.074 - warn: awtrix-light.0 (802) (custom?name=gridpower) Unable to update custom app "gridpower": AxiosError: timeout of 3000ms exceeded
      2023-07-26 22:14:39.220 - error: awtrix-light.0 (802) Unable to perform action for indicator.1.active - API is not connected (device not reachable?)
      2023-07-26 22:14:39.224 - error: awtrix-light.0 (802) Unable to perform action for indicator.3.active - API is not connected (device not reachable?)
      2023-07-26 22:14:39.228 - error: awtrix-light.0 (802) Unable to perform action for apps.storagepower.visible - API is not connected (device not reachable?)
      danach keine Fehlermeldung mehr.
      Das Gerät wird morgens wieder aktiviert (display.power = true)
      Daraufhin ca. 30s später:
      2023-07-27 06:00:36.240 - error: awtrix-light.0 (802) Unable to perform action for display.power - API is not connected (device not reachable?)
      dann ist ca. 30min Ruhe und dann fängt es so an:
      2023-07-27 06:30:50.152 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
      2023-07-27 06:30:52.194 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
      2023-07-27 06:30:58.149 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
      2023-07-27 06:31:00.169 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
      2023-07-27 06:31:02.068 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
      2023-07-27 06:31:04.126 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
      2023-07-27 06:31:06.184 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
      2023-07-27 06:31:08.198 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
      2023-07-27 06:31:10.228 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
      2023-07-27 06:31:14.182 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
      2023-07-27 06:31:16.174 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
      Das Gerät ist aus.
      Neustart und alles läuft einwandfrei.
      Die Meldung, dass nicht conected ist, scheint also zu stimmen, aber keine Ahnung, ob das Gerät auch startet durch display.power = true
      (Mit meinen manuellen Versuchen hat es bis jetzt geklappt, allerdings ist morgens das display, wenn ich ins Büro komme manchmal dunkel)=>(Geräthängt dauerhaft am USB)
      arteck NWH 2 Replies Last reply Reply Quote 0
        arteck Developer Most Active @Ben1983 last edited by arteck
        @ben1983 sagte in Test Adapter Awtrix-Light:
        damit hängt es zusammen.... habs auch .. ich mach die dann auf brightness 0 ..
        dann macht die kein disco.. scheint als ob die in Batterie schonmodus geht .. und macht das WIFI aus..
        reconnected sich dann aber nicht
        • Ben1983
          Ben1983 @arteck last edited by
          @arteck OK, allerdings ist dien "Brightness" ja nur readable.
            @ben1983 dann nimm den richtigen
            Ben1983 1 Reply Last reply Reply Quote 1
            • Ben1983
              @arteck Danke. Werde es umstellen und beobachten.
              Scheint als dann wirklich ein sporadisches "Fehlverhalten" der Uhr zu sein, denn jeden Tag ist es nicht.
              • Bravestarr
                Bravestarr @DJMarc75 last edited by
                @djmarc75 Oh sorry. Diese Seite wurde durch GitHub verlinkt vom Entwickler dieses Adapters.
                Blocky ist doch eine Klicky-Bunti Version im JS Adapter? Ich denke, dass JS selber hier viel mehr kann als man mit Blocky abbilden könnte.
                • Bravestarr
                  Bravestarr last edited by
                  Kann man ohne JS/Blocky auch mehrere Werte in einer custom app darstellen? Also Beispiel Spotify Artist + Song Titel über die Oberfläche des Awtrix Adapters? Oder geht immer nur ein Wert?
                    arteck Developer Most Active @Bravestarr last edited by arteck
                    @bravestarr konkatiniere es in eine eigene variable.und zeige die an..oder leg ein alias an.. mit den Werten
                      Kelzith @Michaelnorge last edited by
                      @michaelnorge Anstatt eine veraltete Firmware zu nutzen, solltest du die Hintergrundeffekte nutzen. Dort findest du deine Augen wieder. Einen Punkt als Text mit Textfarbe schwarz und alles ist gut 🙂
                      • NWH
                        NWH @Ben1983 last edited by
                        @ben1983 Darf ich fragen, gibt es hierfür schon eine Lösung?
                        Bei mir ist es so, dass ich per Adapter ein paar Werte die sich relative Rasch ändern anzeigen lasse. Das funktioniert soweit alles gut.
                        Aber nach einer Zeit schaltet das Gerät einfach ab. Und ist nicht mehr erreichbar. Ich kann es nur manuell wieder anschalten.( Taste Links und Rechts 3s)
                        Dann geht es wieder und das Spiel fängt von norne an.
                        Das ist leider etwas nervig.
                        Die Ulanzi ist gnaz neu und der Akku ist noch drinnen.
                        Gibt es hierfür eine Lösung, dass das Gerät sich nicht immer ausschaltet?
                        arteck Ben1983 2 Replies Last reply Reply Quote 0
                        • DJMarc75
                          DJMarc75 @Kelzith last edited by
                          @kelzith sagte in Test Adapter Awtrix-Light:
                          Bitte um eine genau Erklärung denn es gibt im Adapter keine Datenpunkte wie "Hintergrundeffekte" oder Ähnliches.
                            arteck Developer Most Active @NWH last edited by
                            @nwh sagte in Test Adapter Awtrix-Light:
                            und was hat das mit dem Adapter zu tun ??
                            NWH 1 Reply Last reply Reply Quote 1
                              Kelzith @DJMarc75 last edited by Kelzith
                              @djmarc75 siehe aktuelles Changelog:
                              0.6.02023-07-26
                              Updated recommended firmware version to 0.71
                              klein0rAdded option for background effects* (klein0r) Setting default of repeat to 0
                              klein0rDropped timer support (removed in firmware 0.71)* (klein0r) Removed native app "eyes" (removed in firmware 0.71)
                              Sieht dann so aus:
                              Alle Hintergrundeffekte sind hier beschrieben -> https://blueforcer.github.io/awtrix-light/#/effects
                              • NWH
                                NWH @arteck last edited by
                                @arteck Keine Ahnung ob es was damit zu tun hat. Vielleicht gibt es eine möglichkeit was einzustellen damit eben das nicht passiert,
                                Kann sein das ich was übersehen od. überlesen habe.
                                • DJMarc75
                                  0.6.02023-07-26
                                  ok, aber dann bitte immer auf die Version vom Adapter hinweisen, denn nicht bei jedem hier kommen AdapterUpdates über das Repo sofort rein.
                                  Bei mir eben erst nach einem manuellen RepoUpdate.
                                  Und JA, in der 0.6.0 gibt es jetzt diese Option.
                                  • SKB
                                    SKB Developer Most Active last edited by
                                    Da ich den Adapter aktuell nicht testen kann, weil ich das admin 6.6 aus dem beta Kanal nicht nutzen möchte, die Frage, ob man schon unterschiedliche Farben/Icons bei unterschiedlichen Werten nutzen kann?
                                    • DJMarc75
                                      DJMarc75 @SKB last edited by
                                      @skb sagte in Test Adapter Awtrix-Light:
                                      Jawoll
                                      SKB haus-automatisierung 2 Replies Last reply Reply Quote 2
                                      • SKB
                                        SKB Developer Most Active @DJMarc75 last edited by SKB
                                        @djmarc75 Danke für die Auskunft 🙂
                                        Ich bleibe trotzdem noch bei meinem Skript für die Uhr, da ich so den beta Admin umgehen kann und zusätzlich noch ein wenig flexibler bin 🙂
                                        • haus-automatisierung
                                          haus-automatisierung Developer Most Active @DJMarc75 last edited by haus-automatisierung
                                          @djmarc75 Mh, da müsste ich mal noch eine Prüfung einbauen, ob die Konfiguration wirklich sinnig ist 🙂 Bei 9,95 würden ja nun beide Regeln bei Dir treffen.
                                          EDIT: Momentan "gewinnt" die "kleiner als"-Regel
                                          • DJMarc75
                                            DJMarc75 @haus-automatisierung last edited by
                                            @haus-automatisierung sagte in Test Adapter Awtrix-Light:
                                            Nein, da ich in dem Fall schon den Wert auf eine Nachkommastelle im OriginalDP setze 🙂
                                            81.1k
                                            2160
                                            1216753
