    4. [Aufruf] IKEA-Trådfri v0.4.4 testen
    • AlCalzone
      Hmm, dann brauche ich nochmal den ausführlichen Debug-Log.
      > no connection to objects DB
      Liegt nicht am Adapter. Weiß gerade nicht ob das schlimm ist.
        maniac last edited by
        Sollst Du haben.
        ! /opt/iobroker$ cd /opt/iobroker/node_modules/iobroker.tradfri
        ! /opt/iobroker/node_modules/iobroker.tradfri$ DEBUG=node-*-client node main.js –force --logs
        ! 2017-10-20T06:26:11.856Z node-coap-client CoAP client version 0.4.8
        ! ac
        ! starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.tradfri, node: v6.11.4
        ! ac
        ! startfile = /opt/iobroker/node_modules/iobroker.tradfri/main.js
        ! ac
        ! 2017-10-20T06:26:31.866Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => establishing new connection
        ! ac
        ! 2017-10-20T06:26:33.335Z node-coap-client socket creation for origin coaps://gw-xxxxxxxxxxx.fritz.box:5684 failed: Error: The DTLS handshake timed out
        ! ac
        ! 2017-10-20T06:26:33.777Z node-coap-client successfully created socket for origin coaps://gw-xxxxxxxxxxx.fritz.box:5684
        ! ac
        ! state with id tradfri.0.info.connection updated: ack=true; val=true
        ! ac
        ! 2017-10-20T06:26:34.113Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! ac
        ! 2017-10-20T06:26:34.121Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! ac
        ! 2017-10-20T06:26:34.184Z node-coap-client remembering request: msgID=0x1, token=4d158d4c, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684/15001
        ! ac
        ! 2017-10-20T06:26:34.200Z node-coap-client added message to send queue, new length = 1
        ! ac
        ! 2017-10-20T06:26:34.218Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:34.222Z node-coap-client concurrency low enough, sending message 0x1
        ! ac
        ! 2017-10-20T06:26:34.230Z node-coap-client request 0x1: concurrency changed => 1
        ! ac
        ! 2017-10-20T06:26:34.299Z node-coap-client remembering request: msgID=0x2, token=4d158d4d, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684/15004
        ! ac
        ! 2017-10-20T06:26:34.300Z node-coap-client added message to send queue, new length = 1
        ! ac
        ! 2017-10-20T06:26:34.304Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:34.347Z node-coap-client received message: ID=0x1, token=4d158d4c
        ! ac
        ! 2017-10-20T06:26:34.355Z node-coap-client response with payload: [65536,65538,65537,65539,65540]
        ! ac
        ! 2017-10-20T06:26:34.357Z node-coap-client received ACK for message 0x1, stopping retransmission…
        ! ac
        ! 2017-10-20T06:26:34.361Z node-coap-client request 0x1: concurrency changed => 0
        ! ac
        ! 2017-10-20T06:26:34.363Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:34.365Z node-coap-client concurrency low enough, sending message 0x2
        ! ac
        ! 2017-10-20T06:26:34.375Z node-coap-client request 0x2: concurrency changed => 1
        ! ac
        ! got all devices: [65536,65538,65537,65539,65540]
        ! ac
        ! adding devices with keys [65536,65537,65538,65539,65540]
        ! ac
        ! 2017-10-20T06:26:34.469Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! ac
        ! 2017-10-20T06:26:34.476Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! ac
        ! 2017-10-20T06:26:34.496Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! ac
        ! 2017-10-20T06:26:34.503Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! 2017-10-20T06:26:34.509Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! 2017-10-20T06:26:34.523Z node-coap-client remembering request: msgID=0x3, token=4d158d4e, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684/15001/65536
        ! 2017-10-20T06:26:34.524Z node-coap-client added message to send queue, new length = 1
        ! 2017-10-20T06:26:34.526Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! 2017-10-20T06:26:34.545Z node-coap-client remembering request: msgID=0x4, token=4d158d4f, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684/15001/65537
        ! 2017-10-20T06:26:34.546Z node-coap-client added message to send queue, new length = 2
        ! 2017-10-20T06:26:34.549Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! 2017-10-20T06:26:34.555Z node-coap-client remembering request: msgID=0x5, token=4d158d50, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684/15001/65538
        ! 2017-10-20T06:26:34.556Z node-coap-client added message to send queue, new length = 3
        ! 2017-10-20T06:26:34.559Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! 2017-10-20T06:26:34.565Z node-coap-client remembering request: msgID=0x6, token=4d158d51, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684/15001/65539
        ! 2017-10-20T06:26:34.566Z node-coap-client added message to send queue, new length = 4
        ! 2017-10-20T06:26:34.570Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:34.577Z node-coap-client remembering request: msgID=0x7, token=4d158d52, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684/15001/65540
        ! 2017-10-20T06:26:34.580Z node-coap-client added message to send queue, new length = 5
        ! 2017-10-20T06:26:34.584Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! removing devices with keys []
        ! ac
        ! 2017-10-20T06:26:34.740Z node-coap-client received message: ID=0x2, token=4d158d4d
        ! ac
        ! 2017-10-20T06:26:34.747Z node-coap-client response with payload: [183550]
        ! ac
        ! 2017-10-20T06:26:34.757Z node-coap-client received ACK for message 0x2, stopping retransmission…
        ! ac
        ! 2017-10-20T06:26:34.763Z node-coap-client request 0x2: concurrency changed => 0
        ! ac
        ! 2017-10-20T06:26:34.771Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:34.777Z node-coap-client concurrency low enough, sending message 0x3
        ! 2017-10-20T06:26:34.779Z node-coap-client request 0x3: concurrency changed => 1
        ! ac
        ! got all groups: [183550]
        ! ac
        ! adding groups with keys [183550]
        ! ac
        ! 2017-10-20T06:26:34.894Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! ac
        ! 2017-10-20T06:26:34.908Z node-coap-client remembering request: msgID=0x8, token=4d158d53, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684/15004/183550
        ! ac
        ! 2017-10-20T06:26:34.919Z node-coap-client added message to send queue, new length = 5
        ! 2017-10-20T06:26:34.927Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! removing groups with keys []
        ! ac
        ! 2017-10-20T06:26:35.047Z node-coap-client received message: ID=0x3, token=4d158d4e
        ! 2017-10-20T06:26:35.049Z node-coap-client response with payload: {"9001":"1.Fernbedienung","15009":[{"9003":0}],"9002":1505835514,"3":{"0":"IKEA of Sweden","1":"TRADFRI remote control","2":"","3":"1.2.214","6":3,"9":87},"9020":1508416775,"9003":65536,"9054":0,"5750":0,"9019":1}
        ! 2017-10-20T06:26:35.050Z node-coap-client received ACK for message 0x3, stopping retransmission…
        ! ac
        ! 2017-10-20T06:26:35.059Z node-coap-client request 0x3: concurrency changed => 0
        ! 2017-10-20T06:26:35.063Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! 2017-10-20T06:26:35.067Z node-coap-client concurrency low enough, sending message 0x4
        ! 2017-10-20T06:26:35.068Z node-coap-client request 0x4: concurrency changed => 1
        ! ac
        ! 2017-10-20T06:26:35.650Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:35.678Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:35.693Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! 2017-10-20T06:26:35.700Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:35.726Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:35.733Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:35.750Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:35.757Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:35.886Z node-coap-client received message: ID=0x4, token=4d158d4f
        ! ac
        ! 2017-10-20T06:26:35.889Z node-coap-client response with payload: {"9001":"Sofa_R","9002":1505835604,"3":{"0":"IKEA of Sweden","1":"TRADFRI bulb E27 WS opal 980lm","2":"","3":"1.2.217","6":1},"9020":1508474721,"9003":65537,"9054":0,"5750":2,"9019":1,"3311":[{"5850":0,"5851":254,"5707":0,"5708":0,"5709":30140,"5710":26909,"5711":0,"5706":"f1e0b5","9003":0}]}
        ! 2017-10-20T06:26:35.890Z node-coap-client received ACK for message 0x4, stopping retransmission…
        ! 2017-10-20T06:26:35.891Z node-coap-client request 0x4: concurrency changed => 0
        ! 2017-10-20T06:26:35.895Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:35.899Z node-coap-client concurrency low enough, sending message 0x5
        ! 2017-10-20T06:26:35.900Z node-coap-client request 0x5: concurrency changed => 1
        ! ac
        ! 2017-10-20T06:26:36.134Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:36.189Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:36.196Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! object with id tradfri.0.RC-65536 updated
        ! ac
        ! object with id tradfri.0.RC-65536.alive updated
        ! ac
        ! object with id tradfri.0.RC-65536.lastSeen updated
        ! ac
        ! object with id tradfri.0.L-65537 updated
        ! ac
        ! object with id tradfri.0.L-65537.alive updated
        ! ac
        ! 2017-10-20T06:26:36.806Z node-coap-client received message: ID=0x5, token=4d158d50
        ! ac
        ! 2017-10-20T06:26:36.808Z node-coap-client response with payload: {"9001":"Sofa_L","9002":1505835664,"3":{"0":"IKEA of Sweden","1":"TRADFRI bulb E27 WS opal 980lm","2":"","3":"1.2.217","6":1},"9020":1508474910,"9003":65538,"9054":0,"5750":2,"9019":1,"3311":[{"5850":0,"5851":254,"5707":0,"5708":0,"5709":30140,"5710":26909,"5711":0,"5706":"f1e0b5","9003":0}]}
        ! 2017-10-20T06:26:36.810Z node-coap-client received ACK for message 0x5, stopping retransmission…
        ! ac
        ! 2017-10-20T06:26:36.811Z node-coap-client request 0x5: concurrency changed => 0
        ! ac
        ! 2017-10-20T06:26:36.816Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:36.821Z node-coap-client concurrency low enough, sending message 0x6
        ! 2017-10-20T06:26:36.822Z node-coap-client request 0x6: concurrency changed => 1
        ! ac
        ! state with id tradfri.0.RC-65536.alive updated: ack=true; val=true
        ! ac
        ! state with id tradfri.0.RC-65536.lastSeen updated: ack=true; val=1508416775
        ! ac
        ! state with id tradfri.0.L-65537.alive updated: ack=true; val=true
        ! ac
        ! object with id tradfri.0.L-65537.lastSeen updated
        ! ac
        ! object with id tradfri.0.L-65537.lightbulb updated
        ! ac
        ! object with id tradfri.0.L-65537.lightbulb.color updated
        ! object with id tradfri.0.L-65537.lightbulb.brightness updated
        ! ac
        ! object with id tradfri.0.L-65537.lightbulb.state updated
        ! ac
        ! object with id tradfri.0.L-65537.lightbulb.transitionDuration updated
        ! ac
        ! 2017-10-20T06:26:37.374Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:37.382Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:37.390Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:37.401Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:37.420Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:37.442Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:37.462Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:37.474Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:37.485Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:37.496Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:37.524Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:37.681Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! state with id tradfri.0.L-65537.lastSeen updated: ack=true; val=1508474721
        ! ac
        ! state with id tradfri.0.L-65537.lightbulb.color updated: ack=true; val=63
        ! ac
        ! state with id tradfri.0.L-65537.lightbulb.brightness updated: ack=true; val=254
        ! ac
        ! state with id tradfri.0.L-65537.lightbulb.state updated: ack=true; val=false
        ! state with id tradfri.0.L-65537.lightbulb.transitionDuration updated: ack=true; val=0.5
        ! ac
        ! 2017-10-20T06:26:38.482Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! 2017-10-20T06:26:38.489Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! 2017-10-20T06:26:38.495Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! 2017-10-20T06:26:38.502Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! 2017-10-20T06:26:38.514Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:38.522Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! 2017-10-20T06:26:38.530Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! 2017-10-20T06:26:38.536Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! object with id tradfri.0.L-65538 updated
        ! ac
        ! object with id tradfri.0.L-65538.alive updated
        ! ac
        ! object with id tradfri.0.L-65538.lastSeen updated
        ! ac
        ! object with id tradfri.0.L-65538.lightbulb updated
        ! ac
        ! object with id tradfri.0.L-65538.lightbulb.color updated
        ! object with id tradfri.0.L-65538.lightbulb.brightness updated
        ! ac
        ! object with id tradfri.0.L-65538.lightbulb.state updated
        ! ac
        ! object with id tradfri.0.L-65538.lightbulb.transitionDuration updated
        ! ac
        ! 2017-10-20T06:26:38.669Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:38.677Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:38.684Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:38.743Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:38.760Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! state with id tradfri.0.L-65538.alive updated: ack=true; val=true
        ! ac
        ! state with id tradfri.0.L-65538.lastSeen updated: ack=true; val=1508474910
        ! ac
        ! state with id tradfri.0.L-65538.lightbulb.color updated: ack=true; val=63
        ! ac
        ! state with id tradfri.0.L-65538.lightbulb.brightness updated: ack=true; val=254
        ! ac
        ! state with id tradfri.0.L-65538.lightbulb.state updated: ack=true; val=false
        ! ac
        ! state with id tradfri.0.L-65538.lightbulb.transitionDuration updated: ack=true; val=0.5
        ! ac
        ! 2017-10-20T06:26:39.095Z node-coap-client received message: ID=0x6, token=4d158d51
        ! ac
        ! 2017-10-20T06:26:39.100Z node-coap-client response with payload: {"9001":"Essen_L","9002":1506688866,"3":{"0":"IKEA of Sweden","1":"FLOALT panel WS 30x90","2":"","3":"1.2.217","6":1},"9020":1508473933,"9003":65539,"9054":0,"5750":2,"9019":1,"3311":[{"5850":0,"5851":254,"5707":0,"5708":0,"5709":33135,"5710":27211,"5711":0,"5706":"efd275","9003":0}]}
        ! ac
        ! 2017-10-20T06:26:39.146Z node-coap-client received ACK for message 0x6, stopping retransmission…
        ! ac
        ! 2017-10-20T06:26:39.151Z node-coap-client request 0x6: concurrency changed => 0
        ! ac
        ! 2017-10-20T06:26:39.158Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:39.185Z node-coap-client concurrency low enough, sending message 0x7
        ! ac
        ! 2017-10-20T06:26:39.206Z node-coap-client request 0x7: concurrency changed => 1
        ! ac
        ! 2017-10-20T06:26:39.614Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:39.621Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:39.628Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:39.635Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:39.642Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:39.649Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:39.656Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:39.663Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:39.815Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:39.832Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:39.840Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:39.851Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! 2017-10-20T06:26:39.862Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! object with id tradfri.0.L-65539 updated
        ! ac
        ! object with id tradfri.0.L-65539.alive updated
        ! ac
        ! object with id tradfri.0.L-65539.lastSeen updated
        ! ac
        ! 2017-10-20T06:26:40.060Z node-coap-client received message: ID=0x7, token=4d158d52
        ! ac
        ! 2017-10-20T06:26:40.061Z node-coap-client response with payload: {"9001":"Essen_R","9002":1506691198,"3":{"0":"IKEA of Sweden","1":"FLOALT panel WS 30x90","2":"","3":"1.2.217","6":1},"9020":1508480594,"9003":65540,"9054":0,"5750":2,"9019":1,"3311":[{"5850":0,"5851":254,"5707":0,"5708":0,"5709":33135,"5710":27211,"5711":0,"5706":"efd275","9003":0}]}
        ! ac
        ! 2017-10-20T06:26:40.070Z node-coap-client received ACK for message 0x7, stopping retransmission…
        ! ac
        ! 2017-10-20T06:26:40.104Z node-coap-client request 0x7: concurrency changed => 0
        ! ac
        ! 2017-10-20T06:26:40.108Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:40.113Z node-coap-client concurrency low enough, sending message 0x8
        ! ac
        ! 2017-10-20T06:26:40.114Z node-coap-client request 0x8: concurrency changed => 1
        ! ac
        ! object with id tradfri.0.L-65539.lightbulb updated
        ! ac
        ! object with id tradfri.0.L-65539.lightbulb.color updated
        ! ac
        ! object with id tradfri.0.L-65539.lightbulb.brightness updated
        ! ac
        ! object with id tradfri.0.L-65539.lightbulb.state updated
        ! ac
        ! object with id tradfri.0.L-65539.lightbulb.transitionDuration updated
        ! ac
        ! 2017-10-20T06:26:40.307Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! state with id tradfri.0.L-65539.alive updated: ack=true; val=true
        ! ac
        ! state with id tradfri.0.L-65539.lastSeen updated: ack=true; val=1508473933
        ! ac
        ! state with id tradfri.0.L-65539.lightbulb.color updated: ack=true; val=100
        ! ac
        ! state with id tradfri.0.L-65539.lightbulb.brightness updated: ack=true; val=254
        ! ac
        ! object with id tradfri.0.L-65540 updated
        ! ac
        ! state with id tradfri.0.L-65539.lightbulb.state updated: ack=true; val=false
        ! ac
        ! state with id tradfri.0.L-65539.lightbulb.transitionDuration updated: ack=true; val=0.5
        ! ac
        ! 2017-10-20T06:26:40.875Z node-coap-client received message: ID=0x8, token=4d158d53
        ! ac
        ! 2017-10-20T06:26:40.876Z node-coap-client response with payload: {"9001":"Gateway","9002":1505835526,"9003":183550,"5850":1,"5851":0,"9039":220374,"9018":{"15002":{"9003":[65536,65538,65537,65539,65540]}}}
        ! 2017-10-20T06:26:40.877Z node-coap-client received ACK for message 0x8, stopping retransmission…
        ! ac
        ! 2017-10-20T06:26:40.878Z node-coap-client request 0x8: concurrency changed => 0
        ! 2017-10-20T06:26:40.879Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! 2017-10-20T06:26:40.989Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! ac
        ! 2017-10-20T06:26:41.010Z node-coap-client remembering request: msgID=0x9, token=4d158d54, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684/15005/183550
        ! ac
        ! 2017-10-20T06:26:41.011Z node-coap-client added message to send queue, new length = 1
        ! ac
        ! 2017-10-20T06:26:41.015Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:41.019Z node-coap-client concurrency low enough, sending message 0x9
        ! ac
        ! 2017-10-20T06:26:41.020Z node-coap-client request 0x9: concurrency changed => 1
        ! ac
        ! object with id tradfri.0.L-65540.alive updated
        ! ac
        ! object with id tradfri.0.L-65540.lastSeen updated
        ! ac
        ! object with id tradfri.0.L-65540.lightbulb updated
        ! ac
        ! object with id tradfri.0.L-65540.lightbulb.color updated
        ! ac
        ! object with id tradfri.0.L-65540.lightbulb.brightness updated
        ! ac
        ! object with id tradfri.0.L-65540.lightbulb.state updated
        ! ac
        ! object with id tradfri.0.L-65540.lightbulb.transitionDuration updated
        ! ac
        ! 2017-10-20T06:26:41.099Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! 2017-10-20T06:26:41.100Z node-coap-client workOffSendQueue > queue empty
        ! 2017-10-20T06:26:41.101Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! 2017-10-20T06:26:41.102Z node-coap-client workOffSendQueue > queue empty
        ! 2017-10-20T06:26:41.103Z node-coap-client workOffSendQueue > queue empty
        ! 2017-10-20T06:26:41.104Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! 2017-10-20T06:26:41.105Z node-coap-client workOffSendQueue > queue empty
        ! 2017-10-20T06:26:41.106Z node-coap-client workOffSendQueue > queue empty
        ! 2017-10-20T06:26:41.107Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! 2017-10-20T06:26:41.108Z node-coap-client workOffSendQueue > queue empty
        ! 2017-10-20T06:26:41.109Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! state with id tradfri.0.L-65540.alive updated: ack=true; val=true
        ! ac
        ! 2017-10-20T06:26:41.140Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! 2017-10-20T06:26:41.162Z node-coap-client received message: ID=0x9, token=4d158d54
        ! ac
        ! 2017-10-20T06:26:41.163Z node-coap-client response with payload: [201475,216044,228955,203159,220374,207688,214751,215881,220286]
        ! 2017-10-20T06:26:41.164Z node-coap-client received ACK for message 0x9, stopping retransmission…
        ! ac
        ! 2017-10-20T06:26:41.185Z node-coap-client request 0x9: concurrency changed => 0
        ! 2017-10-20T06:26:41.186Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! got all scenes in group 183550: [201475,216044,228955,203159,220374,207688,214751,215881,220286]
        ! ac
        ! adding scenes with keys [201475,203159,207688,214751,215881,216044,220286,220374,228955] to group 183550
        ! ac
        ! 2017-10-20T06:26:41.254Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! ac
        ! 2017-10-20T06:26:41.261Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! ac
        ! 2017-10-20T06:26:41.267Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! ac
        ! 2017-10-20T06:26:41.273Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! ac
        ! 2017-10-20T06:26:41.279Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! ac
        ! 2017-10-20T06:26:41.465Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! ac
        ! 2017-10-20T06:26:41.481Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! ac
        ! 2017-10-20T06:26:41.491Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! ac
        ! 2017-10-20T06:26:41.503Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! ac
        ! 2017-10-20T06:26:41.534Z node-coap-client remembering request: msgID=0xa, token=4d158d55, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684/15005/183550/201475
        ! ac
        ! 2017-10-20T06:26:41.535Z node-coap-client added message to send queue, new length = 1
        ! ac
        ! 2017-10-20T06:26:41.541Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! 2017-10-20T06:26:41.564Z node-coap-client concurrency low enough, sending message 0xa
        ! 2017-10-20T06:26:41.565Z node-coap-client request 0xa: concurrency changed => 1
        ! ac
        ! 2017-10-20T06:26:41.596Z node-coap-client remembering request: msgID=0xb, token=4d158d56, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684/15005/183550/203159
        ! ac
        ! 2017-10-20T06:26:41.613Z node-coap-client added message to send queue, new length = 1
        ! 2017-10-20T06:26:41.617Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:41.626Z node-coap-client remembering request: msgID=0xc, token=4d158d57, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684/15005/183550/207688
        ! ac
        ! 2017-10-20T06:26:41.627Z node-coap-client added message to send queue, new length = 2
        ! 2017-10-20T06:26:41.633Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:41.642Z node-coap-client remembering request: msgID=0xd, token=4d158d58, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684/15005/183550/214751
        ! ac
        ! 2017-10-20T06:26:41.643Z node-coap-client added message to send queue, new length = 3
        ! ac
        ! 2017-10-20T06:26:41.649Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:41.658Z node-coap-client remembering request: msgID=0xe, token=4d158d59, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684/15005/183550/215881
        ! ac
        ! 2017-10-20T06:26:41.659Z node-coap-client added message to send queue, new length = 4
        ! ac
        ! 2017-10-20T06:26:41.665Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:41.674Z node-coap-client remembering request: msgID=0xf, token=4d158d5a, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684/15005/183550/216044
        ! ac
        ! 2017-10-20T06:26:41.676Z node-coap-client added message to send queue, new length = 5
        ! ac
        ! 2017-10-20T06:26:41.696Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:41.706Z node-coap-client remembering request: msgID=0x10, token=4d158d5b, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684/15005/183550/220286
        ! ac
        ! 2017-10-20T06:26:41.707Z node-coap-client added message to send queue, new length = 6
        ! ac
        ! 2017-10-20T06:26:41.714Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:41.883Z node-coap-client remembering request: msgID=0x11, token=4d158d5c, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684/15005/183550/220374
        ! ac
        ! 2017-10-20T06:26:41.884Z node-coap-client added message to send queue, new length = 7
        ! ac
        ! 2017-10-20T06:26:41.891Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:41.901Z node-coap-client remembering request: msgID=0x12, token=4d158d5d, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684/15005/183550/228955
        ! ac
        ! 2017-10-20T06:26:41.902Z node-coap-client added message to send queue, new length = 8
        ! ac
        ! 2017-10-20T06:26:41.909Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! removing scenes with keys [] from group 183550
        ! ac
        ! 2017-10-20T06:26:42.038Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:42.056Z node-coap-client received message: ID=0xa, token=4d158d55
        ! ac
        ! 2017-10-20T06:26:42.057Z node-coap-client response with payload: {"9001":"EVERYDAY","9002":1505835526,"9003":201475,"9057":0,"9068":1,"15013":[{"5850":1,"5851":203,"5707":0,"5708":0,"5709":30140,"5710":26909,"5711":0,"5706":"f1e0b5","9003":65538},{"5850":1,"5851":203,"5707":0,"5708":0,"5709":30140,"5710":26909,"5711":0,"5706":"f1e0b5","9003":65537},{"5850":1,"5851":203,"5707":0,"5708":0,"5709":30140,"5710":26909,"5711":0,"5706":"f1e0b5","9003":65539},{"5850":1,"5851":203,"5707":0,"5708":0,"5709":30140,"5710":26909,"5711":0,"5706":"f1e0b5","9003":65540}]}
        ! 2017-10-20T06:26:42.059Z node-coap-client received ACK for message 0xa, stopping retransmission…
        ! 2017-10-20T06:26:42.060Z node-coap-client request 0xa: concurrency changed => 0
        ! 2017-10-20T06:26:42.066Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:42.073Z node-coap-client concurrency low enough, sending message 0xb
        ! ac
        ! 2017-10-20T06:26:42.089Z node-coap-client request 0xb: concurrency changed => 1
        ! ac
        ! 2017-10-20T06:26:42.577Z node-coap-client received message: ID=0xb, token=4d158d56
        ! ac
        ! 2017-10-20T06:26:42.579Z node-coap-client response with payload: {"9001":"Lesen","9002":1506168972,"9003":203159,"9057":3,"9068":0,"15013":[{"5850":1,"5851":254,"5707":0,"5708":0,"5709":24930,"5710":24694,"5711":0,"5706":"f5faf6","9003":65538},{"5850":1,"5851":254,"5707":0,"5708":0,"5709":24930,"5710":24694,"5711":0,"5706":"f5faf6","9003":65537},{"5850":1,"5851":254,"5707":0,"5708":0,"5709":24930,"5710":24694,"5711":0,"5706":"f5faf6","9003":65539},{"5850":1,"5851":254,"5707":0,"5708":0,"5709":24930,"5710":24694,"5711":0,"5706":"f5faf6","9003":65540}]}
        ! 2017-10-20T06:26:42.580Z node-coap-client received ACK for message 0xb, stopping retransmission…
        ! ac
        ! 2017-10-20T06:26:42.581Z node-coap-client request 0xb: concurrency changed => 0
        ! ac
        ! 2017-10-20T06:26:42.588Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:42.595Z node-coap-client concurrency low enough, sending message 0xc
        ! 2017-10-20T06:26:42.596Z node-coap-client request 0xc: concurrency changed => 1
        ! ac
        ! 2017-10-20T06:26:42.766Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:42.778Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:42.790Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:42.814Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:42.827Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! 2017-10-20T06:26:42.838Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! 2017-10-20T06:26:42.850Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:42.918Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:42.935Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:43.032Z node-coap-client received message: ID=0xc, token=4d158d57
        ! ac
        ! 2017-10-20T06:26:43.049Z node-coap-client response with payload: {"9001":"Test","9002":1506169025,"9003":207688,"9057":5,"9068":0,"15013":[{"5850":1,"5851":254,"5707":0,"5708":0,"5709":24930,"5710":24694,"5711":0,"5706":"f5faf6","9003":65538},{"5850":1,"5851":254,"5707":0,"5708":0,"5709":33135,"5710":27211,"5711":0,"5706":"efd275","9003":65537},{"5850":1,"5851":254,"5707":0,"5708":0,"5709":33135,"5710":27211,"5711":0,"5706":"efd275","9003":65539},{"5850":1,"5851":254,"5707":0,"5708":0,"5709":30140,"5710":26909,"5711":0,"5706":"f1e0b5","9003":65540}]}
        ! ac
        ! 2017-10-20T06:26:43.051Z node-coap-client received ACK for message 0xc, stopping retransmission…
        ! 2017-10-20T06:26:43.052Z node-coap-client request 0xc: concurrency changed => 0
        ! ac
        ! 2017-10-20T06:26:43.058Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:43.064Z node-coap-client concurrency low enough, sending message 0xd
        ! ac
        ! 2017-10-20T06:26:43.065Z node-coap-client request 0xd: concurrency changed => 1
        ! ac
        ! 2017-10-20T06:26:43.166Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:43.225Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:43.342Z node-coap-client received message: ID=0xd, token=4d158d58
        ! ac
        ! 2017-10-20T06:26:43.343Z node-coap-client response with payload: {"9001":"Aus","9002":1506170286,"9003":214751,"9057":6,"9068":0,"15013":[{"5850":0,"5851":1,"5707":0,"5708":0,"5709":24930,"5710":24694,"5711":0,"5706":"f5faf6","9003":65538},{"5850":0,"5851":1,"5707":0,"5708":0,"5709":24930,"5710":24694,"5711":0,"5706":"f5faf6","9003":65537},{"5850":0,"5851":1,"5707":0,"5708":0,"5709":24930,"5710":24694,"5711":0,"5706":"f5faf6","9003":65539},{"5850":0,"5851":1,"5707":0,"5708":0,"5709":30140,"5710":26909,"5711":0,"5706":"f1e0b5","9003":65540}]}
        ! 2017-10-20T06:26:43.345Z node-coap-client received ACK for message 0xd, stopping retransmission…
        ! ac
        ! 2017-10-20T06:26:43.346Z node-coap-client request 0xd: concurrency changed => 0
        ! ac
        ! 2017-10-20T06:26:43.354Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:43.361Z node-coap-client concurrency low enough, sending message 0xe
        ! ac
        ! 2017-10-20T06:26:43.362Z node-coap-client request 0xe: concurrency changed => 1
        ! ac
        ! 2017-10-20T06:26:43.633Z node-coap-client received message: ID=0xe, token=4d158d59
        ! ac
        ! 2017-10-20T06:26:43.634Z node-coap-client response with payload: {"9001":"Essen","9002":1506691326,"9003":215881,"9057":7,"9068":0,"15013":[{"5850":1,"5851":86,"5707":0,"5708":0,"5709":30140,"5710":26909,"5711":0,"5706":"f1e0b5","9003":65538},{"5850":1,"5851":86,"5707":0,"5708":0,"5709":30140,"5710":26909,"5711":0,"5706":"f1e0b5","9003":65537},{"5850":1,"5851":116,"5707":0,"5708":0,"5709":24930,"5710":24694,"5711":0,"5706":"f5faf6","9003":65539},{"5850":1,"5851":124,"5707":0,"5708":0,"5709":24930,"5710":24694,"5711":0,"5706":"f5faf6","9003":65540}]}
        ! 2017-10-20T06:26:43.635Z node-coap-client received ACK for message 0xe, stopping retransmission…
        ! 2017-10-20T06:26:43.636Z node-coap-client request 0xe: concurrency changed => 0
        ! 2017-10-20T06:26:43.642Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! 2017-10-20T06:26:43.648Z node-coap-client concurrency low enough, sending message 0xf
        ! 2017-10-20T06:26:43.649Z node-coap-client request 0xf: concurrency changed => 1
        ! ac
        ! 2017-10-20T06:26:43.745Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:43.777Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:43.790Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:43.813Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:43.827Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:43.837Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:43.865Z node-coap-client received message: ID=0xf, token=4d158d5a
        ! ac
        ! 2017-10-20T06:26:43.869Z node-coap-client response with payload: {"9001":"RELAX","9002":1505835526,"9003":216044,"9057":1,"9068":1,"15013":[{"5850":1,"5851":25,"5707":0,"5708":0,"5709":33135,"5710":27211,"5711":0,"5706":"efd275","9003":65538},{"5850":1,"5851":25,"5707":0,"5708":0,"5709":33135,"5710":27211,"5711":0,"5706":"efd275","9003":65537},{"5850":1,"5851":25,"5707":0,"5708":0,"5709":33135,"5710":27211,"5711":0,"5706":"efd275","9003":65539},{"5850":1,"5851":25,"5707":0,"5708":0,"5709":33135,"5710":27211,"5711":0,"5706":"efd275","9003":65540}]}
        ! ac
        ! 2017-10-20T06:26:43.870Z node-coap-client received ACK for message 0xf, stopping retransmission…
        ! 2017-10-20T06:26:43.871Z node-coap-client request 0xf: concurrency changed => 0
        ! ac
        ! 2017-10-20T06:26:43.878Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:43.884Z node-coap-client concurrency low enough, sending message 0x10
        ! ac
        ! 2017-10-20T06:26:43.885Z node-coap-client request 0x10: concurrency changed => 1
        ! ac
        ! 2017-10-20T06:26:43.995Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:44.007Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! 2017-10-20T06:26:44.020Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:44.031Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:44.115Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! ac
        ! 2017-10-20T06:26:44.143Z node-coap-client remembering request: msgID=0x13, token=, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684
        ! ac
        ! 2017-10-20T06:26:44.144Z node-coap-client added message to send queue, new length = 3
        ! ac
        ! 2017-10-20T06:26:44.151Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:44.167Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:44.185Z node-coap-client received message: ID=0x10, token=4d158d5b
        ! ac
        ! 2017-10-20T06:26:44.186Z node-coap-client response with payload: {"9001":"Sofa","9002":1506704766,"9003":220286,"9057":8,"9068":0,"15013":[{"5850":1,"5851":86,"5707":0,"5708":0,"5709":30140,"5710":26909,"5711":0,"5706":"f1e0b5","9003":65538},{"5850":1,"5851":86,"5707":0,"5708":0,"5709":30140,"5710":26909,"5711":0,"5706":"f1e0b5","9003":65537},{"5850":0,"5851":1,"5707":0,"5708":0,"5709":24930,"5710":24694,"5711":0,"5706":"f5faf6","9003":65539},{"5850":0,"5851":1,"5707":0,"5708":0,"5709":24930,"5710":24694,"5711":0,"5706":"f5faf6","9003":65540}]}
        ! 2017-10-20T06:26:44.187Z node-coap-client received ACK for message 0x10, stopping retransmission…
        ! ac
        ! 2017-10-20T06:26:44.189Z node-coap-client request 0x10: concurrency changed => 0
        ! 2017-10-20T06:26:44.195Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! 2017-10-20T06:26:44.202Z node-coap-client concurrency low enough, sending message 0x11
        ! 2017-10-20T06:26:44.203Z node-coap-client request 0x11: concurrency changed => 1
        ! ac
        ! 2017-10-20T06:26:44.302Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:44.315Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:44.397Z node-coap-client workOffSendQueue > concurrency = 1 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:44.428Z node-coap-client received message: ID=0x11, token=4d158d5c
        ! ac
        ! 2017-10-20T06:26:44.429Z node-coap-client response with payload: {"9001":"Fernsehen","9002":1506169006,"9003":220374,"9057":4,"9068":0,"15013":[{"5850":1,"5851":86,"5707":0,"5708":0,"5709":30140,"5710":26909,"5711":0,"5706":"f1e0b5","9003":65538},{"5850":1,"5851":86,"5707":0,"5708":0,"5709":30140,"5710":26909,"5711":0,"5706":"f1e0b5","9003":65537},{"5850":1,"5851":50,"5707":0,"5708":0,"5709":33135,"5710":27211,"5711":0,"5706":"efd275","9003":65539},{"5850":1,"5851":48,"5707":0,"5708":0,"5709":33135,"5710":27211,"5711":0,"5706":"efd275","9003":65540}]}
        ! 2017-10-20T06:26:44.431Z node-coap-client received ACK for message 0x11, stopping retransmission…
        ! 2017-10-20T06:26:44.432Z node-coap-client request 0x11: concurrency changed => 0
        ! 2017-10-20T06:26:44.440Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! 2017-10-20T06:26:44.448Z node-coap-client concurrency low enough, sending message 0x12
        ! 2017-10-20T06:26:44.449Z node-coap-client request 0x12: concurrency changed => 1
        ! ac
        ! 2017-10-20T06:26:44.661Z node-coap-client received message: ID=0x12, token=4d158d5d
        ! ac
        ! 2017-10-20T06:26:44.662Z node-coap-client response with payload: {"9001":"FOCUS","9002":1505835526,"9003":228955,"9057":2,"9068":1,"15013":[{"5850":1,"5851":254,"5707":0,"5708":0,"5709":24930,"5710":24694,"5711":0,"5706":"f5faf6","9003":65538},{"5850":1,"5851":254,"5707":0,"5708":0,"5709":24930,"5710":24694,"5711":0,"5706":"f5faf6","9003":65537},{"5850":1,"5851":254,"5707":0,"5708":0,"5709":24930,"5710":24694,"5711":0,"5706":"f5faf6","9003":65539},{"5850":1,"5851":254,"5707":0,"5708":0,"5709":24930,"5710":24694,"5711":0,"5706":"f5faf6","9003":65540}]}
        ! 2017-10-20T06:26:44.664Z node-coap-client received ACK for message 0x12, stopping retransmission…
        ! 2017-10-20T06:26:44.665Z node-coap-client request 0x12: concurrency changed => 0
        ! ac
        ! 2017-10-20T06:26:44.675Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! ac
        ! 2017-10-20T06:26:44.695Z node-coap-client concurrency low enough, sending message 0x13
        ! ac
        ! 2017-10-20T06:26:44.696Z node-coap-client request 0x13: concurrency changed => 1
        ! ac
        ! 2017-10-20T06:26:44.785Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! 2017-10-20T06:26:44.786Z node-coap-client workOffSendQueue > queue empty
        ! 2017-10-20T06:26:44.787Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! 2017-10-20T06:26:44.852Z node-coap-client received message: ID=0x13
        ! ac
        ! 2017-10-20T06:26:44.853Z node-coap-client request 0x13: concurrency changed => 0
        ! 2017-10-20T06:26:44.854Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! 2017-10-20T06:26:44.857Z node-coap-client received response to ping with ID 0x13
        ! ac
        ! 2017-10-20T06:26:44.870Z node-coap-client forgetting request: token=; msgID=0x13
        ! ac
        ! ping successful...
        ! ac
        ! 2017-10-20T06:26:44.901Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! 2017-10-20T06:26:44.902Z node-coap-client workOffSendQueue > queue empty
        ! 2017-10-20T06:26:44.903Z node-coap-client workOffSendQueue > queue empty
        ! 2017-10-20T06:26:44.904Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! 2017-10-20T06:26:44.905Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! 2017-10-20T06:26:45.004Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! 2017-10-20T06:26:45.016Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! 2017-10-20T06:26:45.028Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! 2017-10-20T06:26:45.039Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! 2017-10-20T06:26:45.161Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! 2017-10-20T06:26:45.174Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! 2017-10-20T06:26:45.229Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! 2017-10-20T06:26:45.310Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! 2017-10-20T06:26:45.333Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! 2017-10-20T06:26:45.407Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! 2017-10-20T06:26:45.468Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! 2017-10-20T06:26:45.710Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! state with id tradfri.0.L-65540.lastSeen updated: ack=true; val=1508480594
        ! ac
        ! state with id tradfri.0.L-65540.lightbulb.color updated: ack=true; val=100
        ! ac
        ! state with id tradfri.0.L-65540.lightbulb.brightness updated: ack=true; val=254
        ! ac
        ! state with id tradfri.0.L-65540.lightbulb.state updated: ack=true; val=false
        ! ac
        ! state with id tradfri.0.L-65540.lightbulb.transitionDuration updated: ack=true; val=0.5
        ! ac
        ! object with id tradfri.0.G-183550 updated
        ! ac
        ! object with id tradfri.0.G-183550.activeScene updated
        ! ac
        ! object with id tradfri.0.G-183550.state updated
        ! ac
        ! object with id tradfri.0.G-183550.transitionDuration updated
        ! object with id tradfri.0.G-183550.brightness updated
        ! ac
        ! state with id tradfri.0.G-183550.activeScene updated: ack=true; val=220374
        ! ac
        ! state with id tradfri.0.G-183550.state updated: ack=true; val=true
        ! ac
        ! state with id tradfri.0.G-183550.transitionDuration updated: ack=true; val=0
        ! ac
        ! state with id tradfri.0.G-183550.brightness updated: ack=true; val=0
        ! ac
        ! 2017-10-20T06:26:54.129Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! ac
        ! 2017-10-20T06:26:54.143Z node-coap-client remembering request: msgID=0x14, token=, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684
        ! 2017-10-20T06:26:54.144Z node-coap-client added message to send queue, new length = 1
        ! 2017-10-20T06:26:54.150Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! 2017-10-20T06:26:54.156Z node-coap-client concurrency low enough, sending message 0x14
        ! 2017-10-20T06:26:54.157Z node-coap-client request 0x14: concurrency changed => 1
        ! ac
        ! 2017-10-20T06:26:54.249Z node-coap-client received message: ID=0x14
        ! ac
        ! 2017-10-20T06:26:54.251Z node-coap-client request 0x14: concurrency changed => 0
        ! ac
        ! 2017-10-20T06:26:54.276Z node-coap-client workOffSendQueue > queue empty
        ! ac
        ! 2017-10-20T06:26:54.278Z node-coap-client received response to ping with ID 0x14
        ! ac
        ! 2017-10-20T06:26:54.282Z node-coap-client forgetting request: token=; msgID=0x14
        ! ac
        ! ac
        ! 2017-10-20T06:26:55.171Z node-coap-client workOffSendQueue > queue empty
        ! acac^C
        ! 2017-10-20T06:27:04.149Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! acac
        ! 2017-10-20T06:27:04.152Z node-coap-client remembering request: msgID=0x15, token=, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684
        ! acac
        ! 2017-10-20T06:27:04.153Z node-coap-client added message to send queue, new length = 1
        ! acac
        ! 2017-10-20T06:27:04.159Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! acac
        ! 2017-10-20T06:27:04.165Z node-coap-client concurrency low enough, sending message 0x15
        ! acac
        ! 2017-10-20T06:27:04.166Z node-coap-client request 0x15: concurrency changed => 1
        ! acac
        ! 2017-10-20T06:27:04.216Z node-coap-client received message: ID=0x15
        ! acac
        ! 2017-10-20T06:27:04.217Z node-coap-client request 0x15: concurrency changed => 0
        ! 2017-10-20T06:27:04.218Z node-coap-client workOffSendQueue > queue empty
        ! 2017-10-20T06:27:04.218Z node-coap-client received response to ping with ID 0x15
        ! acac
        ! 2017-10-20T06:27:04.220Z node-coap-client forgetting request: token=; msgID=0x15
        ! acac
        ! acac
        ! 2017-10-20T06:27:05.179Z node-coap-client workOffSendQueue > queue empty
        ! acac
        ! 2017-10-20T06:27:14.163Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! acac
        ! 2017-10-20T06:27:14.186Z node-coap-client remembering request: msgID=0x16, token=, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684
        ! 2017-10-20T06:27:14.186Z node-coap-client added message to send queue, new length = 1
        ! 2017-10-20T06:27:14.193Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! 2017-10-20T06:27:14.200Z node-coap-client concurrency low enough, sending message 0x16
        ! 2017-10-20T06:27:14.201Z node-coap-client request 0x16: concurrency changed => 1
        ! acac
        ! 2017-10-20T06:27:14.362Z node-coap-client received message: ID=0x16
        ! acac
        ! 2017-10-20T06:27:14.365Z node-coap-client request 0x16: concurrency changed => 0
        ! 2017-10-20T06:27:14.366Z node-coap-client workOffSendQueue > queue empty
        ! acac
        ! 2017-10-20T06:27:14.367Z node-coap-client received response to ping with ID 0x16
        ! acac
        ! 2017-10-20T06:27:14.371Z node-coap-client forgetting request: token=; msgID=0x16
        ! acac
        ! acac
        ! 2017-10-20T06:27:15.215Z node-coap-client workOffSendQueue > queue empty
        ! acac
        ! 2017-10-20T06:27:24.171Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! acac
        ! 2017-10-20T06:27:24.214Z node-coap-client remembering request: msgID=0x17, token=, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684
        ! acac
        ! 2017-10-20T06:27:24.215Z node-coap-client added message to send queue, new length = 1
        ! acac
        ! 2017-10-20T06:27:24.224Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! 2017-10-20T06:27:24.232Z node-coap-client concurrency low enough, sending message 0x17
        ! 2017-10-20T06:27:24.233Z node-coap-client request 0x17: concurrency changed => 1
        ! acac
        ! 2017-10-20T06:27:24.266Z node-coap-client received message: ID=0x17
        ! acac
        ! 2017-10-20T06:27:24.268Z node-coap-client request 0x17: concurrency changed => 0
        ! 2017-10-20T06:27:24.269Z node-coap-client workOffSendQueue > queue empty
        ! acac
        ! 2017-10-20T06:27:24.270Z node-coap-client received response to ping with ID 0x17
        ! 2017-10-20T06:27:24.272Z node-coap-client forgetting request: token=; msgID=0x17
        ! acac
        ! acac
        ! 2017-10-20T06:27:25.254Z node-coap-client workOffSendQueue > queue empty
        ! acac
        ! 2017-10-20T06:27:34.225Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! acac
        ! 2017-10-20T06:27:34.228Z node-coap-client remembering request: msgID=0x18, token=, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684
        ! 2017-10-20T06:27:34.229Z node-coap-client added message to send queue, new length = 1
        ! 2017-10-20T06:27:34.235Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! 2017-10-20T06:27:34.241Z node-coap-client concurrency low enough, sending message 0x18
        ! 2017-10-20T06:27:34.242Z node-coap-client request 0x18: concurrency changed => 1
        ! 2017-10-20T06:27:34.265Z node-coap-client received message: ID=0x18
        ! 2017-10-20T06:27:34.266Z node-coap-client request 0x18: concurrency changed => 0
        ! 2017-10-20T06:27:34.266Z node-coap-client workOffSendQueue > queue empty
        ! 2017-10-20T06:27:34.267Z node-coap-client received response to ping with ID 0x18
        ! 2017-10-20T06:27:34.269Z node-coap-client forgetting request: token=; msgID=0x18
        ! acac
        ! acac
        ! 2017-10-20T06:27:35.265Z node-coap-client workOffSendQueue > queue empty
        ! acacac
        ! 2017-10-20T06:27:44.231Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! acacac
        ! 2017-10-20T06:27:44.234Z node-coap-client remembering request: msgID=0x19, token=, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684
        ! 2017-10-20T06:27:44.235Z node-coap-client added message to send queue, new length = 1
        ! acacac
        ! 2017-10-20T06:27:44.242Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! acacac
        ! 2017-10-20T06:27:44.248Z node-coap-client concurrency low enough, sending message 0x19
        ! acacac
        ! 2017-10-20T06:27:44.249Z node-coap-client request 0x19: concurrency changed => 1
        ! acacac
        ! 2017-10-20T06:27:44.274Z node-coap-client received message: ID=0x19
        ! acacac
        ! 2017-10-20T06:27:44.275Z node-coap-client request 0x19: concurrency changed => 0
        ! 2017-10-20T06:27:44.276Z node-coap-client workOffSendQueue > queue empty
        ! acacac
        ! 2017-10-20T06:27:44.277Z node-coap-client received response to ping with ID 0x19
        ! acacac
        ! 2017-10-20T06:27:44.290Z node-coap-client forgetting request: token=; msgID=0x19
        ! acacac
        ! acacac
        ! 2017-10-20T06:27:45.269Z node-coap-client workOffSendQueue > queue empty
        ! acacac
        ! 2017-10-20T06:27:54.237Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! acacac
        ! 2017-10-20T06:27:54.247Z node-coap-client remembering request: msgID=0x1a, token=, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684
        ! 2017-10-20T06:27:54.248Z node-coap-client added message to send queue, new length = 1
        ! 2017-10-20T06:27:54.292Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! 2017-10-20T06:27:54.352Z node-coap-client concurrency low enough, sending message 0x1a
        ! 2017-10-20T06:27:54.353Z node-coap-client request 0x1a: concurrency changed => 1
        ! 2017-10-20T06:27:54.475Z node-coap-client received message: ID=0x1a
        ! 2017-10-20T06:27:54.483Z node-coap-client request 0x1a: concurrency changed => 0
        ! 2017-10-20T06:27:54.484Z node-coap-client workOffSendQueue > queue empty
        ! 2017-10-20T06:27:54.485Z node-coap-client received response to ping with ID 0x1a
        ! 2017-10-20T06:27:54.493Z node-coap-client forgetting request: token=; msgID=0x1a
        ! acacac
        ! acacac
        ! 2017-10-20T06:27:55.443Z node-coap-client workOffSendQueue > queue empty
        ! acacac
        ! 2017-10-20T06:28:04.255Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! acacac
        ! 2017-10-20T06:28:04.258Z node-coap-client remembering request: msgID=0x1b, token=, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684
        ! 2017-10-20T06:28:04.259Z node-coap-client added message to send queue, new length = 1
        ! 2017-10-20T06:28:04.265Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! 2017-10-20T06:28:04.271Z node-coap-client concurrency low enough, sending message 0x1b
        ! 2017-10-20T06:28:04.272Z node-coap-client request 0x1b: concurrency changed => 1
        ! 2017-10-20T06:28:04.294Z node-coap-client received message: ID=0x1b
        ! 2017-10-20T06:28:04.295Z node-coap-client request 0x1b: concurrency changed => 0
        ! 2017-10-20T06:28:04.296Z node-coap-client workOffSendQueue > queue empty
        ! 2017-10-20T06:28:04.296Z node-coap-client received response to ping with ID 0x1b
        ! 2017-10-20T06:28:04.298Z node-coap-client forgetting request: token=; msgID=0x1b
        ! acacac
        ! acacac
        ! 2017-10-20T06:28:05.284Z node-coap-client workOffSendQueue > queue empty
        ! acacac
        ! 2017-10-20T06:28:14.267Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! acacac
        ! 2017-10-20T06:28:14.270Z node-coap-client remembering request: msgID=0x1c, token=, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684
        ! 2017-10-20T06:28:14.271Z node-coap-client added message to send queue, new length = 1
        ! 2017-10-20T06:28:14.277Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! 2017-10-20T06:28:14.283Z node-coap-client concurrency low enough, sending message 0x1c
        ! 2017-10-20T06:28:14.283Z node-coap-client request 0x1c: concurrency changed => 1
        ! 2017-10-20T06:28:14.321Z node-coap-client received message: ID=0x1c
        ! 2017-10-20T06:28:14.322Z node-coap-client request 0x1c: concurrency changed => 0
        ! 2017-10-20T06:28:14.323Z node-coap-client workOffSendQueue > queue empty
        ! 2017-10-20T06:28:14.324Z node-coap-client received response to ping with ID 0x1c
        ! 2017-10-20T06:28:14.325Z node-coap-client forgetting request: token=; msgID=0x1c
        ! acacac
        ! acacac
        ! 2017-10-20T06:28:15.312Z node-coap-client workOffSendQueue > queue empty
        ! acacac
        ! 2017-10-20T06:28:24.280Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! acacac
        ! 2017-10-20T06:28:24.283Z node-coap-client remembering request: msgID=0x1d, token=, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684
        ! acacac
        ! 2017-10-20T06:28:24.283Z node-coap-client added message to send queue, new length = 1
        ! acacac
        ! 2017-10-20T06:28:24.289Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! acacac
        ! 2017-10-20T06:28:24.295Z node-coap-client concurrency low enough, sending message 0x1d
        ! 2017-10-20T06:28:24.296Z node-coap-client request 0x1d: concurrency changed => 1
        ! acacac
        ! 2017-10-20T06:28:24.318Z node-coap-client received message: ID=0x1d
        ! acacac
        ! 2017-10-20T06:28:24.319Z node-coap-client request 0x1d: concurrency changed => 0
        ! 2017-10-20T06:28:24.320Z node-coap-client workOffSendQueue > queue empty
        ! acacac
        ! 2017-10-20T06:28:24.321Z node-coap-client received response to ping with ID 0x1d
        ! 2017-10-20T06:28:24.323Z node-coap-client forgetting request: token=; msgID=0x1d
        ! acacac
        ! acacac
        ! 2017-10-20T06:28:25.308Z node-coap-client workOffSendQueue > queue empty
        ! acacacac
        ! 2017-10-20T06:28:34.286Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! acacacac
        ! 2017-10-20T06:28:34.289Z node-coap-client remembering request: msgID=0x1e, token=, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684
        ! acacacac
        ! 2017-10-20T06:28:34.290Z node-coap-client added message to send queue, new length = 1
        ! 2017-10-20T06:28:34.297Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! acacacac
        ! 2017-10-20T06:28:34.304Z node-coap-client concurrency low enough, sending message 0x1e
        ! 2017-10-20T06:28:34.305Z node-coap-client request 0x1e: concurrency changed => 1
        ! acacacac
        ! 2017-10-20T06:28:34.330Z node-coap-client received message: ID=0x1e
        ! acacacac
        ! 2017-10-20T06:28:34.331Z node-coap-client request 0x1e: concurrency changed => 0
        ! 2017-10-20T06:28:34.332Z node-coap-client workOffSendQueue > queue empty
        ! acacacac
        ! 2017-10-20T06:28:34.333Z node-coap-client received response to ping with ID 0x1e
        ! 2017-10-20T06:28:34.334Z node-coap-client forgetting request: token=; msgID=0x1e
        ! acacacac
        ! acacacac
        ! 2017-10-20T06:28:35.319Z node-coap-client workOffSendQueue > queue empty
        ! acacacac
        ! 2017-10-20T06:28:44.297Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! acacacac
        ! 2017-10-20T06:28:44.310Z node-coap-client remembering request: msgID=0x1f, token=, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684
        ! 2017-10-20T06:28:44.311Z node-coap-client added message to send queue, new length = 1
        ! 2017-10-20T06:28:44.317Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! 2017-10-20T06:28:44.324Z node-coap-client concurrency low enough, sending message 0x1f
        ! 2017-10-20T06:28:44.325Z node-coap-client request 0x1f: concurrency changed => 1
        ! 2017-10-20T06:28:44.348Z node-coap-client received message: ID=0x1f
        ! 2017-10-20T06:28:44.349Z node-coap-client request 0x1f: concurrency changed => 0
        ! 2017-10-20T06:28:44.350Z node-coap-client workOffSendQueue > queue empty
        ! 2017-10-20T06:28:44.351Z node-coap-client received response to ping with ID 0x1f
        ! 2017-10-20T06:28:44.352Z node-coap-client forgetting request: token=; msgID=0x1f
        ! acacacac
        ! acacacac
        ! 2017-10-20T06:28:45.339Z node-coap-client workOffSendQueue > queue empty
        ! acacacac
        ! 2017-10-20T06:28:54.321Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! acacacac
        ! 2017-10-20T06:28:54.324Z node-coap-client remembering request: msgID=0x20, token=, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684
        ! acacacac
        ! 2017-10-20T06:28:54.325Z node-coap-client added message to send queue, new length = 1
        ! acacacac
        ! 2017-10-20T06:28:54.331Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! acacacac
        ! 2017-10-20T06:28:54.337Z node-coap-client concurrency low enough, sending message 0x20
        ! acacacac
        ! 2017-10-20T06:28:54.337Z node-coap-client request 0x20: concurrency changed => 1
        ! acacacac
        ! 2017-10-20T06:28:54.358Z node-coap-client received message: ID=0x20
        ! acacacac
        ! 2017-10-20T06:28:54.361Z node-coap-client request 0x20: concurrency changed => 0
        ! acacacac
        ! 2017-10-20T06:28:54.362Z node-coap-client workOffSendQueue > queue empty
        ! 2017-10-20T06:28:54.363Z node-coap-client received response to ping with ID 0x20
        ! acacacac
        ! 2017-10-20T06:28:54.365Z node-coap-client forgetting request: token=; msgID=0x20
        ! acacacac
        ! acacacac
        ! 2017-10-20T06:28:55.350Z node-coap-client workOffSendQueue > queue empty
        ! cacacacac^C
        ! 2017-10-20T06:29:04.326Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! cacacacac
        ! 2017-10-20T06:29:04.329Z node-coap-client remembering request: msgID=0x21, token=, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684
        ! 2017-10-20T06:29:04.330Z node-coap-client added message to send queue, new length = 1
        ! 2017-10-20T06:29:04.335Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! 2017-10-20T06:29:04.341Z node-coap-client concurrency low enough, sending message 0x21
        ! 2017-10-20T06:29:04.342Z node-coap-client request 0x21: concurrency changed => 1
        ! 2017-10-20T06:29:04.376Z node-coap-client received message: ID=0x21
        ! 2017-10-20T06:29:04.377Z node-coap-client request 0x21: concurrency changed => 0
        ! 2017-10-20T06:29:04.378Z node-coap-client workOffSendQueue > queue empty
        ! 2017-10-20T06:29:04.379Z node-coap-client received response to ping with ID 0x21
        ! cacacacac
        ! 2017-10-20T06:29:04.380Z node-coap-client forgetting request: token=; msgID=0x21
        ! cacacacac
        ! cacacacac
        ! 2017-10-20T06:29:05.364Z node-coap-client workOffSendQueue > queue empty
        ! cacacacac
        ! 2017-10-20T06:29:14.348Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! cacacacac
        ! 2017-10-20T06:29:14.367Z node-coap-client remembering request: msgID=0x22, token=, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684
        ! 2017-10-20T06:29:14.368Z node-coap-client added message to send queue, new length = 1
        ! 2017-10-20T06:29:14.394Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! 2017-10-20T06:29:14.412Z node-coap-client concurrency low enough, sending message 0x22
        ! 2017-10-20T06:29:14.413Z node-coap-client request 0x22: concurrency changed => 1
        ! cacacacac
        ! 2017-10-20T06:29:14.496Z node-coap-client received message: ID=0x22
        ! cacacacac
        ! 2017-10-20T06:29:14.497Z node-coap-client request 0x22: concurrency changed => 0
        ! 2017-10-20T06:29:14.498Z node-coap-client workOffSendQueue > queue empty
        ! cacacacac
        ! 2017-10-20T06:29:14.499Z node-coap-client received response to ping with ID 0x22
        ! 2017-10-20T06:29:14.507Z node-coap-client forgetting request: token=; msgID=0x22
        ! cacacacac
        ! cacacacac
        ! 2017-10-20T06:29:15.431Z node-coap-client workOffSendQueue > queue empty
        ! cacacacac
        ! 2017-10-20T06:29:24.369Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! cacacacac
        ! 2017-10-20T06:29:24.372Z node-coap-client remembering request: msgID=0x23, token=, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684
        ! cacacacac
        ! 2017-10-20T06:29:24.373Z node-coap-client added message to send queue, new length = 1
        ! cacacacac
        ! 2017-10-20T06:29:24.379Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! cacacacac
        ! 2017-10-20T06:29:24.385Z node-coap-client concurrency low enough, sending message 0x23
        ! cacacacac
        ! 2017-10-20T06:29:24.386Z node-coap-client request 0x23: concurrency changed => 1
        ! cacacacac
        ! 2017-10-20T06:29:24.434Z node-coap-client received message: ID=0x23
        ! cacacacac
        ! 2017-10-20T06:29:24.434Z node-coap-client request 0x23: concurrency changed => 0
        ! 2017-10-20T06:29:24.435Z node-coap-client workOffSendQueue > queue empty
        ! cacacacac
        ! 2017-10-20T06:29:24.436Z node-coap-client received response to ping with ID 0x23
        ! 2017-10-20T06:29:24.438Z node-coap-client forgetting request: token=; msgID=0x23
        ! cacacacac
        ! cacacacac
        ! 2017-10-20T06:29:25.409Z node-coap-client workOffSendQueue > queue empty
        ! cacacacac
        ! 2017-10-20T06:29:34.377Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! cacacacac
        ! 2017-10-20T06:29:34.393Z node-coap-client remembering request: msgID=0x24, token=, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684
        ! cacacacac
        ! 2017-10-20T06:29:34.413Z node-coap-client added message to send queue, new length = 1
        ! cacacacac
        ! 2017-10-20T06:29:34.419Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! cacacacac
        ! 2017-10-20T06:29:34.426Z node-coap-client concurrency low enough, sending message 0x24
        ! cacacacac
        ! 2017-10-20T06:29:34.427Z node-coap-client request 0x24: concurrency changed => 1
        ! cacacacac
        ! 2017-10-20T06:29:34.454Z node-coap-client received message: ID=0x24
        ! cacacacac
        ! 2017-10-20T06:29:34.455Z node-coap-client request 0x24: concurrency changed => 0
        ! 2017-10-20T06:29:34.456Z node-coap-client workOffSendQueue > queue empty
        ! cacacacac
        ! 2017-10-20T06:29:34.457Z node-coap-client received response to ping with ID 0x24
        ! 2017-10-20T06:29:34.458Z node-coap-client forgetting request: token=; msgID=0x24
        ! cacacacac
        ! cacacacac
        ! 2017-10-20T06:29:35.446Z node-coap-client workOffSendQueue > queue empty
        ! cacacacac
        ! 2017-10-20T06:29:44.392Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! cacacacac
        ! 2017-10-20T06:29:44.395Z node-coap-client remembering request: msgID=0x25, token=, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684
        ! 2017-10-20T06:29:44.396Z node-coap-client added message to send queue, new length = 1
        ! 2017-10-20T06:29:44.402Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! 2017-10-20T06:29:44.407Z node-coap-client concurrency low enough, sending message 0x25
        ! 2017-10-20T06:29:44.408Z node-coap-client request 0x25: concurrency changed => 1
        ! cacacacac
        ! 2017-10-20T06:29:44.510Z node-coap-client received message: ID=0x25
        ! cacacacac
        ! 2017-10-20T06:29:44.511Z node-coap-client request 0x25: concurrency changed => 0
        ! 2017-10-20T06:29:44.511Z node-coap-client workOffSendQueue > queue empty
        ! cacacacac
        ! 2017-10-20T06:29:44.512Z node-coap-client received response to ping with ID 0x25
        ! 2017-10-20T06:29:44.514Z node-coap-client forgetting request: token=; msgID=0x25
        ! cacacacac
        ! cacacacac
        ! 2017-10-20T06:29:45.451Z node-coap-client workOffSendQueue > queue empty
        ! cacacacac
        ! 2017-10-20T06:29:54.408Z node-coap-client getConnection(coaps://gw-xxxxxxxxxxx.fritz.box:5684) => found existing connection
        ! cacacacac
        ! 2017-10-20T06:29:54.411Z node-coap-client remembering request: msgID=0x26, token=, url=coaps://gw-xxxxxxxxxxx.fritz.box:5684
        ! cacacacac
        ! 2017-10-20T06:29:54.412Z node-coap-client added message to send queue, new length = 1
        ! cacacacac
        ! 2017-10-20T06:29:54.418Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
        ! cacacacac
        ! 2017-10-20T06:29:54.424Z node-coap-client concurrency low enough, sending message 0x26
        ! cacacacac
        ! 2017-10-20T06:29:54.425Z node-coap-client request 0x26: concurrency changed => 1
        ! cacacacac
        ! 2017-10-20T06:29:54.446Z node-coap-client received message: ID=0x26
        ! cacacacac
        ! 2017-10-20T06:29:54.447Z node-coap-client request 0x26: concurrency changed => 0
        ! 2017-10-20T06:29:54.448Z node-coap-client workOffSendQueue > queue empty
        ! cacacacac
        ! 2017-10-20T06:29:54.449Z node-coap-client received response to ping with ID 0x26
        ! cacacacac
        ! 2017-10-20T06:29:54.460Z node-coap-client forgetting request: token=; msgID=0x26
        ! cacacacac
        ! cacacacac
        ! 2017-10-20T06:29:55.437Z node-coap-client workOffSendQueue > queue empty
        ! ac
        • AlCalzone
          Da funktioniert aber noch alles 🙂 Interessanter wäre einer bei dem die Verbindung abbricht.
            maniac last edited by
            Kann ich das log auch in eine Datei schreiben lassen? Dann lass ich mal ne Weile laufen.
            Bisher mach ich das im Terminal Adapter im Browser. Copy/Paste
            Das läuft dann aber irgendwann über.
            • AlCalzone
              Sollte so gehen (Linux, oder?):
              DEBUG=node-*-client node main.js --force --logs >> log.txt 2>&1
                Jo, Danke und Sry. Bin eigentlich kein Linuxmann.
                Ich lass das mal ne Weile laufen und Dir dann das Log zukommen.
                  Bisher lief es stabil.
                  3805_logtradfri.zip
                  • AlCalzone
                    Ist das jetzt gut oder schlecht? [emoji23]
                    Edit: v0.4.5 sollte jetzt auch die Adapter-Funktionalität wiederherstellen nach einer erneuten Verbindung.
                      Naja, solange es funktioniert 🙂
                      Aber jetzt komm ich nochmal…
                      Da mir die Performance der Server nicht reicht, habe ich jetzt die dritte Instanz aufgemacht. Natürlich wieder anderes System Windows 🙂
                      Hab den Installer von http://www.iobroker.net/docu/?page_id=2291&lang=de genommen.
                      Backup eingespielt und nix geht 😞
                      Dann wieder alles neu gemacht mit Clean Install. Tradfri installiert (Da musste ich schon das Admin Verzeichnis von Hand anlegen wo die Index.htm drin ist) Daten eingegeben und gestartet.
                      Ergebnis
                      ! host.MediaPlayer 2017-10-20 17:52:00.417 info Restart adapter system.adapter.tradfri.0 because enabled
                      ! host.MediaPlayer 2017-10-20 17:52:00.417 error instance system.adapter.tradfri.0 terminated with code 1 ()
                      ! Caught 2017-10-20 17:52:00.417 error by controller[0]: at Object.Module._extensions..js (module.js:416:10)
                      ! Caught 2017-10-20 17:52:00.417 error by controller[0]: at Module._compile (module.js:409:26)
                      ! Caught 2017-10-20 17:52:00.417 error by controller[0]: at Object. (C:\ioBroker\node_modules\iobroker.tradfri\main.js:1:63)
                      ! Caught 2017-10-20 17:52:00.417 error by controller[0]: at require (internal/module.js:12:17)
                      ! Caught 2017-10-20 17:52:00.417 error by controller[0]: at Module.require (module.js:353:17)
                      ! Caught 2017-10-20 17:52:00.417 error by controller[0]: at Function.Module._load (module.js:300:12)
                      ! Caught 2017-10-20 17:52:00.417 error by controller[0]: at Module.load (module.js:343:32)
                      ! Caught 2017-10-20 17:52:00.417 error by controller[0]: at Module._compile (module.js:373:25)
                      ! Caught 2017-10-20 17:52:00.417 error by controller[0]: at exports.runInThisContext (vm.js:53:16)
                      ! Caught 2017-10-20 17:52:00.417 error by controller[0]: SyntaxError: Unexpected token [
                      ! Caught 2017-10-20 17:52:00.417 error by controller[0]: ^
                      ! Caught 2017-10-20 17:52:00.417 error by controller[0]: for (const [id, obj] of object_polyfill_1.entries(stateObjs)) {
                      ! Caught 2017-10-20 17:52:00.417 error by controller[0]: C:\ioBroker\node_modules\iobroker.tradfri\build\main.js:752
                      ! host.MediaPlayer 2017-10-20 17:52:00.198 info instance system.adapter.tradfri.0 started with pid 3488
                      Ist das nur bei mir wieder mal so?
                      Hat jetzt aber nicht die ganz große Priorität. Wichtig ist die DS, bzw. Raspi (da läuft aber auch gerade gar nix, anderes Thema :))
                      Auf der DS hab ich einfach ein Performance Problem allgemein.
                      • AlCalzone
                        Alte NodeJS-Version (<6)?
                          4.5.0 Sollte die nicht aktuell sein wenn das neu runterlädt? 😛
                          • AlCalzone
                            Installiert der ioBroker-Installer NodeJS mit? Dann sollte der mal aktualisiert werden. Stable ist 6.11, aktuell 8.7
                              @AlCalzone:
                              Installiert der ioBroker-Installer NodeJS mit? Dann sollte der mal aktualisiert werden. Stable ist 6.11, aktuell 8.7 `
                              Ja macht er
                              • AlCalzone
                                Habe lange nichts mehr von euch gehört, kann ich davon ausgehen dass es jetzt stabil läuft?
                                  Leider Nein!
                                  Sorry bin verwirrt :? Ich hatte folgendes live getippt:
                                  auch mit 0.4.3 hing der Rechner irgendwann, mangels Zugriffsmöglichkeiten musste ich ihn komplett rebooten, habe seitdem (2 Tage) 0.4.4 drauf.
                                  Im Moment ist die Instanz .. … .... :shock: abgeschaltet!! :shock:
                                  Kein Wunder dass das Tinkerboard läuft.
                                  Habe den Adapter gerade wieder aktiviert.
                                  Kann damals gewesen sein, dass die andere Installation mit tradfri noch eine ganz alte Version hatte, die habe ich (doch nicht???) upgedated. Dort läuft noch die 0.3.3 und läuft ohne Probleme.
                                  Mir fehlt im Moment die Zeit zum Testen.
                                  Rainer
                                  • AlCalzone
                                    Alles klar, dann warten wir mal ab. In 0.4.4 hab ich den gefundenen Bug im CoAP-Layer behoben. Seitdem hatte ich selbst auch keine Verbindungsabbrüche mehr.
                                      Also sollte ich meine andere Installation jetzt besser von 0.3.3 auch auf 0.4.4 anheben?
                                      Rainer
                                      • AlCalzone
                                        @Homoran:
                                        Also sollte ich meine andere Installation jetzt besser von 0.3.3 auch auf 0.4.4 anheben? `
                                        Wenn du auf 0.3.3 Probleme hast, ist es nen Versuch wert. Oder direkt auf 0.4.5, da musst du nach nem Verbindungsabbruch auch nicht mehr manuell den Adapter neu starten.
                                          So, ich kann nur Danke sagen.
                                          Bin jetzt auf V 0.4.5 und es läuft bisher ohne Probleme.
                                          Es soll jetzt tatsächlich bald ein Update für das Gateway kommen um es Homekit tauglich zu machen. Dann geht wohl alles von vorne los? :shock:
                                          • AlCalzone
                                            @maniac:
                                            Dann geht wohl alles von vorne los? :shock: `
                                            Na ich hoffe doch dass sie die bestehende Schnittstelle beibehalten.
                                            Ich warte mal noch ab, was Homoran zu berichten hat. Wenn ich nichts negatives höre, würde ich 0.4.5 als stable vorschlagen. Das wäre dann wirklich die erste stable-Version seit 0.2.1.
                                            31.7k
                                            79.8k
                                            166
                                            22459
