    4. Bambu lab 3d Drucker MQTT Integration
      djalexz last edited by djalexz
      ich hab nochmal bisschen was gebastelt.
      Hiermit könnt ihr den Drucker steuern.
      Verwendung auf eigene Gefahr
      Die MQTT Node muss entsprechend angepasst werden.
              "id": "e4deb3c0f6038918",
              "type": "function",
              "z": "9582121ff81174a6",
              "name": "Druck stoppen",
              "func": "var P1P_Push = {\n    \"print\": {\n        \"sequence_id\": \"1\",\n        \"command\": \"stop\"\n    },\n    \"user_id\": \"1234567890\"\n}\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 460,
              "y": 1000,
              "wires": [
                      "896709af54cf95f3"
              "id": "d719c311cd5fe8ec",
              "type": "inject",
              "name": "True",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "true",
              "payloadType": "bool",
              "x": 210,
              "y": 1000,
              "wires": [
                      "e4deb3c0f6038918"
              "id": "da8e98a7bcfc4791",
              "type": "mqtt out",
              "name": "bambu-mqtt-out x1c",
              "topic": "device/Deine-Seriennummer/request",
              "qos": "1",
              "retain": "false",
              "respTopic": "",
              "contentType": "",
              "userProps": "",
              "correl": "",
              "expiry": "",
              "broker": "84f61d394ba2ab34",
              "x": 360,
              "y": 1520,
              "wires": []
              "id": "c23cf05567e62a0d",
              "type": "function",
              "name": "Druck pausieren",
              "func": "var P1P_Push = {\n    \"print\": {\n        \"sequence_id\": \"1\",\n        \"command\": \"pause\"\n    },\n    \"user_id\": \"1234567890\"\n}\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 460,
              "y": 1080,
              "wires": [
                      "896709af54cf95f3"
              "id": "698ef4715c618988",
              "type": "inject",
              "name": "True",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "true",
              "x": 210,
              "y": 1080,
              "wires": [
                      "c23cf05567e62a0d"
              "id": "da3ebb8e9395ace1",
              "type": "function",
              "name": "Kammerlicht einschalten",
              "func": "var P1P_Push = {\n    \"system\": {\n        \"sequence_id\": \"0\",\n        \"command\": \"ledctrl\",\n        \"led_node\": \"chamber_light\",\n        \"led_mode\": \"on\",\n        \"led_on_time\": 500,\n        \"led_off_time\": 500,\n        \"loop_times\": 0,\n        \"interval_time\": 0\n    }\n}\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 1150,
              "y": 1000,
              "wires": [
                      "1bde76ee31c86b7b"
              "id": "9d65a19652402ab5",
              "type": "inject",
              "name": "True",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "true",
              "x": 870,
              "y": 1000,
              "wires": [
                      "da3ebb8e9395ace1"
              "id": "1f169dd6fc7f6387",
              "type": "function",
              "name": "Kammerlicht ausschalten",
              "func": "var P1P_Push = \n{\"system\": { \"sequence_id\": \"0\",\n    \"command\": \"ledctrl\",\n    \"led_node\": \"chamber_light\",\n    \"led_mode\": \"off\",\n    \"led_on_time\": 500,\n    \"led_off_time\": 500,\n    \"loop_times\": 0,\n    \"interval_time\": 0\n    }  }\n\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 1150,
              "y": 1060,
              "wires": [
                      "1bde76ee31c86b7b"
              "id": "02dfb1cf089be4e9",
              "type": "inject",
              "name": "True",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "true",
              "x": 870,
              "y": 1060,
              "wires": [
                      "1f169dd6fc7f6387"
              "id": "6b016ea02facbdd4",
              "type": "function",
              "name": "Druck fortsetzen",
              "func": "var P1P_Push = {\n    \"print\": {\n        \"sequence_id\": \"1\",\n        \"command\": \"resume\"\n    },\n    \"user_id\": \"1234567890\"\n}\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 460,
              "y": 1040,
              "wires": [
                      "896709af54cf95f3"
              "id": "b1cee73a8525cbd6",
              "type": "inject",
              "name": "True",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "true",
              "x": 210,
              "y": 1040,
              "wires": [
                      "6b016ea02facbdd4"
              "id": "4644dad9484e5ebd",
              "type": "function",
              "name": "Geschwindigkeitsmodus",
              "func": "var P1P_Push = { \"print\": \n{ \"sequence_id\": \"0\",\n \"command\": \"print_speed\",\n  \"param\": msg.payload } }\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 490,
              "y": 1200,
              "wires": [
                      "896709af54cf95f3"
              "id": "6f7b98709d756f1f",
              "type": "inject",
              "name": "Leise",
              "props": [
                      "p": "payload"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "1",
              "payloadType": "str",
              "x": 210,
              "y": 1140,
              "wires": [
                      "4644dad9484e5ebd"
              "id": "5f530bccf798a5a0",
              "type": "function",
              "name": "Homing",
              "func": "var P1P_Push = {\n    \"print\": {\n        \"command\": \"gcode_line\",\n        \"param\": \"G28 \\n\",\n        \"reason\": \"SUCCESS\",\n        \"result\": \"SUCCESS\",\n        \"sequence_id\": \"20086\",\n        \"user_id\": \"1767420324\"\n    }\n}\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 440,
              "y": 1340,
              "wires": [
                      "896709af54cf95f3"
              "id": "170ca7b1e2747db8",
              "type": "inject",
              "name": "True",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "true",
              "x": 210,
              "y": 1340,
              "wires": [
                      "5f530bccf798a5a0"
              "id": "70adf86313f86654",
              "type": "function",
              "name": "x10 (Druckkopf nach rechts)",
              "func": "var P1P_Push = {\n    \"print\": {\n        \"command\": \"gcode_line\",\n        \"param\": \"M211 S \\nM211 X1 Y1 Z1\\nM1002 push_ref_mode\\nG91 \\nG1 X10,0 F3000\\nM1002 pop_ref_mode\\nM211 R\\n\",\n        \"reason\": \"SUCCESS\",\n        \"result\": \"SUCCESS\",\n        \"sequence_id\": \"20014\",\n        \"user_id\": \"1767420324\"\n    }\n}\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 1160,
              "y": 1160,
              "wires": [
                      "f0a3aa20cb7b1ec7"
              "id": "015cd820c30ac3c1",
              "type": "inject",
              "name": "True",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "true",
              "x": 870,
              "y": 1160,
              "wires": [
                      "70adf86313f86654"
              "id": "3c2d33e74b34ba3a",
              "type": "function",
              "name": "x-10 (Druckkopf nach links)",
              "func": "var P1P_Push = {\n    \"print\": {\n        \"command\": \"gcode_line\",\n        \"param\": \"M211 S \\nM211 X1 Y1 Z1\\nM1002 push_ref_mode\\nG91 \\nG1 X-10,0 F3000\\nM1002 pop_ref_mode\\nM211 R\\n\",\n        \"reason\": \"SUCCESS\",\n        \"result\": \"SUCCESS\",\n        \"sequence_id\": \"20014\",\n        \"user_id\": \"1767420324\"\n    }\n}\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 1160,
              "y": 1220,
              "wires": [
                      "f0a3aa20cb7b1ec7"
              "id": "0741e0b4170ed242",
              "type": "inject",
              "name": "True",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "true",
              "x": 870,
              "y": 1220,
              "wires": [
                      "3c2d33e74b34ba3a"
              "id": "4896f4921f935873",
              "type": "function",
              "name": "y10 (Druckkopf nach hinten)",
              "func": "var P1P_Push = {\n    \"print\": {\n        \"command\": \"gcode_line\",\n        \"param\": \"M211 S \\nM211 X1 Y1 Z1\\nM1002 push_ref_mode\\nG91 \\nG1 Y10,0 F3000\\nM1002 pop_ref_mode\\nM211 R\\n\",\n        \"reason\": \"SUCCESS\",\n        \"result\": \"SUCCESS\",\n        \"sequence_id\": \"20014\",\n        \"user_id\": \"1767420324\"\n    }\n}\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 1160,
              "y": 1320,
              "wires": [
                      "f0a3aa20cb7b1ec7"
              "id": "e0894718eaf714d6",
              "type": "inject",
              "name": "True",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "true",
              "x": 870,
              "y": 1320,
              "wires": [
                      "4896f4921f935873"
              "id": "8d19b57b1b50a939",
              "type": "function",
              "name": "y-10 (Druckkopf nach vorne)",
              "func": "var P1P_Push = {\n    \"print\": {\n        \"command\": \"gcode_line\",\n        \"param\": \"M211 S \\nM211 X1 Y1 Z1\\nM1002 push_ref_mode\\nG91 \\nG1 Y-10,0 F3000\\nM1002 pop_ref_mode\\nM211 R\\n\",\n        \"reason\": \"SUCCESS\",\n        \"result\": \"SUCCESS\",\n        \"sequence_id\": \"20014\",\n        \"user_id\": \"1767420324\"\n    }\n}\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 1160,
              "y": 1380,
              "wires": [
                      "f0a3aa20cb7b1ec7"
              "id": "ec7ef6667698c77b",
              "type": "inject",
              "name": "True",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "true",
              "x": 870,
              "y": 1380,
              "wires": [
                      "8d19b57b1b50a939"
              "id": "5666441b74594399",
              "type": "function",
              "name": "z10 (Druckbett nach unten)",
              "func": "var P1P_Push = {\n    \"print\": {\n        \"command\": \"gcode_line\",\n        \"param\": \"M211 S \\nM211 X1 Y1 Z1\\nM1002 push_ref_mode\\nG91 \\nG1 Z10,0 F3000\\nM1002 pop_ref_mode\\nM211 R\\n\",\n        \"reason\": \"SUCCESS\",\n        \"result\": \"SUCCESS\",\n        \"sequence_id\": \"20014\",\n        \"user_id\": \"1767420324\"\n    }\n}\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 1160,
              "y": 1480,
              "wires": [
                      "f0a3aa20cb7b1ec7"
              "id": "19077e4a51bf2443",
              "type": "inject",
              "name": "True",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "true",
              "x": 870,
              "y": 1480,
              "wires": [
                      "5666441b74594399"
              "id": "2e3395031ac16968",
              "type": "function",
              "name": "z-10 z10 (Druckbett nach oben)",
              "func": "var P1P_Push = {\n    \"print\": {\n        \"command\": \"gcode_line\",\n        \"param\": \"M211 S \\nM211 X1 Y1 Z1\\nM1002 push_ref_mode\\nG91 \\nG1 Z-10,0 F3000\\nM1002 pop_ref_mode\\nM211 R\\n\",\n        \"reason\": \"SUCCESS\",\n        \"result\": \"SUCCESS\",\n        \"sequence_id\": \"20014\",\n        \"user_id\": \"1767420324\"\n    }\n}\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 1170,
              "y": 1540,
              "wires": [
                      "f0a3aa20cb7b1ec7"
              "id": "68696ed4c9c24eef",
              "type": "inject",
              "name": "True",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "true",
              "x": 870,
              "y": 1540,
              "wires": [
                      "2e3395031ac16968"
              "id": "22d040578162e373",
              "type": "inject",
              "name": "Standard",
              "props": [
                      "p": "payload"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "2",
              "x": 220,
              "y": 1180,
              "wires": [
                      "4644dad9484e5ebd"
              "id": "6143cca7c358a854",
              "type": "inject",
              "name": "Sport",
              "props": [
                      "p": "payload"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "3",
              "x": 210,
              "y": 1220,
              "wires": [
                      "4644dad9484e5ebd"
              "id": "e8e4bbd46511a0ea",
              "type": "inject",
              "name": "Verrückt",
              "props": [
                      "p": "payload"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "4",
              "x": 220,
              "y": 1260,
              "wires": [
                      "4644dad9484e5ebd"
              "id": "896709af54cf95f3",
              "type": "link out",
              "name": "link out 1",
              "mode": "link",
              "links": [
                  "d7996921de135b61"
              "x": 685,
              "y": 1100,
              "wires": []
              "id": "f0a3aa20cb7b1ec7",
              "type": "link out",
              "name": "link out 2",
              "mode": "link",
              "links": [
                  "d7996921de135b61"
              "x": 1365,
              "y": 1380,
              "wires": []
              "id": "d7996921de135b61",
              "type": "link in",
              "name": "link in 1",
              "links": [
                  "f0a3aa20cb7b1ec7",
                  "896709af54cf95f3",
                  "1bde76ee31c86b7b",
                  "d1dbc9388bfe6774"
              "x": 175,
              "y": 1520,
              "wires": [
                      "da8e98a7bcfc4791"
              "id": "1bde76ee31c86b7b",
              "type": "link out",
              "name": "link out 3",
              "mode": "link",
              "links": [
                  "d7996921de135b61"
              "x": 1335,
              "y": 1080,
              "wires": []
              "id": "84f61d394ba2ab34",
              "type": "mqtt-broker",
              "name": "Bambu X1C MQTT Bambu_X1C",
              "broker": "IP-Deines-Druckers",
              "port": "8883",
              "tls": "",
              "clientid": "",
              "autoConnect": true,
              "usetls": true,
              "protocolVersion": "4",
              "keepalive": "60",
              "cleansession": true,
              "birthTopic": "",
              "birthQos": "0",
              "birthPayload": "",
              "birthMsg": {},
              "closeTopic": "",
              "closeQos": "0",
              "closePayload": "",
              "closeMsg": {},
              "willTopic": "",
              "willQos": "0",
              "willPayload": "",
              "willMsg": {},
              "userProps": "",
              "sessionExpiry": ""
      Das ist natürlich nur ein Beispiel-Flow wie es gehen kann.
      Es geht ja hauptsächlich um die Befehle.
      Damit könnt ihr dann weiterbasteln 🙂
      LG Alex
        djalexz @dadonali last edited by djalexz
        @dadonali
        Sollte was für dich sein 🙂
          dadonali @djalexz last edited by
          @djalexz
          Kann ich den flow von dir dann einfach hinzufügen?
          • X
            XSDiver last edited by XSDiver
            geht auch alles über den MQTT Adapter ohne Node Red,
            der liest euch eine JSON aus dem Drucker aus und legt die unter MQTT in einem Datenpunkt ab:
            sieht dann ungefähr so aus:
                "print": {
                    "ams": {
                        "ams": [
                                "humidity": "4",
                                "id": "0",
                                "temp": "30.9",
                                "tray": [
                                        "bed_temp": "0",
                                        "bed_temp_type": "2",
                                        "cols": [
                                            "FFC600FF"
                                        "drying_temp": "55",
                                        "drying_time": "8",
                                        "id": "0",
                                        "nozzle_temp_max": "240",
                                        "nozzle_temp_min": "200",
                                        "remain": 0,
                                        "tag_uid": "DDDE769400000100",
                                        "tray_color": "FFC600FF",
                                        "tray_diameter": "1.75",
                                        "tray_id_name": "A05-Y4",
                                        "tray_info_idx": "GFA05",
                                        "tray_sub_brands": "PLA Silk",
                                        "tray_type": "PLA",
                                        "tray_uuid": "325DA7506BCE447B9F34D1CDC94658DA",
                                        "tray_weight": "1000",
                                        "xcam_info": "A438803EE803E8033333333F"
                                    }, //... weiter AMS Slots
                        "ams_exist_bits": "1",
                        "insert_flag": true,
                        "power_on_flag": false,
                        "tray_exist_bits": "f",
                        "tray_is_bbl_bits": "f",
                        "tray_now": "255",
                        "tray_pre": "255",
                        "tray_read_done_bits": "f",
                        "tray_reading_bits": "0",
                        "tray_tar": "255",
                        "version": 5
                    "ams_rfid_status": 0,
                    "ams_status": 0,
                    "aux_part_fan": true,
                    "bed_target_temper": 0.0,
                    "bed_temper": 37.0,
                    "big_fan1_speed": "0",
                    "big_fan2_speed": "0",
                    "chamber_temper": 35.0,
                    "command": "push_status",
                    "cooling_fan_speed": "0",
                    "fail_reason": "0",
                    "fan_gear": 0,
                    "filam_bak": [],
                    "force_upgrade": false,
                    "gcode_file": "Name des DruckFiles",
                    "gcode_file_prepare_percent": "100",
                    "gcode_start_time": "1687977739",
                    "gcode_state": "FINISH",
                    "heatbreak_fan_speed": "0",
                    "hms": [],
                    "home_flag": 16648,
                    "hw_switch_state": 0,
                    "ipcam": {
                        "ipcam_dev": "1",
                        "ipcam_record": "enable",
                        "resolution": "1080p",
                        "timelapse": "disable"
                    "layer_num": 360,
                    "lifecycle": "product",
                    "lights_report": [
                            "mode": "on",
                            "node": "chamber_light"
                            "mode": "flashing",
                            "node": "work_light"
                    "maintain": 3,
                    "mc_percent": 100,
                    "mc_print_error_code": "0",
                    "mc_print_stage": "1",
                    "mc_print_sub_stage": 0,
                    "mc_remaining_time": 0,
                    "mess_production_state": "active",
                    "nozzle_diameter": "0.4",
                    "nozzle_target_temper": 0.0,
                    "nozzle_temper": 39.0,
                    "online": {
                        "ahb": false,
                        "rfid": false,
                        "version": 9
                    "print_error": 0,
                    "print_gcode_action": 255,
            Ich hab mir dann die Datenpunkte die ich gebrauchen kann manuell angelegt:
            und dann mit einem Blockly ausgelesen und in den Datenpunkt geschrieben.
            • z. B. Nozzle - Temp:
            setState("0_userdata.0.X1C.Temp_Nozzle"/*Temp_Nozzle*/, parseFloat((await jsonataExpression((function () { try {return JSON.parse(getState("mqtt.0.device.00M09A340700121.report").val);} catch(e) {return {};}})(),'print.nozzle_temper'))), true);
            Hier ein noch angefangenes VIS Beispiel:
            Mit Bindings lassen sich auch die Farben im AMS auslesen,
            die einzelnen Lüfter Geschwindigkeiten und einiges mehr...
            Vielleicht interessiert das ja jemanden.
            Wenn man sich z.B. im MQTT Adapter einen Datenpunkt: "Request" anlegt:
            kann man auch Befehle schicken:
              "print": {
                "command": "gcode_line",
                "param": "M960 S5 P1",
                "sequence_id": "0"
            mit diesem gCode schaltet man das ToolHead Logo ein. Funktioniert auch wärend des Drucks.
              @dadonali
              Moin, ja sollte gehen.
              • Dutchman
                Dutchman Developer Most Active Administrators @baeri last edited by Dutchman
                @baeri sagte in Bambu lab 3d Drucker MQTT Integration:
                Ich habe auch mal einen Adapter-Request gemacht, vielleicht findet sich ja jemand, der das ganze in einen Adapter adaptieren kann (schöner Satz 😄 ) - vielleicht hilft ja ein Like von dem ein oder anderen, dass sich jemand findet: https://github.com/ioBroker/AdapterRequests/issues/829
                Habe es nun als DAU tatsächlich mit der NodeRed Instanz hinbekommen.
                Ein Adapter wäre natürlich schöner, vielleicht findet sich ja jemand, der Anhand dieses NodeRed Ablaufs einen Adapter bauen kann?
                Da ich auch einen Bambulab X1 habe konnte ich das hier nicht liegen lassen, mit dank an den Informationen hier im forum habe ich einen adapter erstellt der alle Daten per MQTT Verbindung live bekommt. Man muss nur in den Einstellungen die IP Adresse, token und serial hinterlegen
                Schalten werden ich im laufe des tages/morgen implementieren, soweit mir bekannt kann man aber nur start/stop/resume und die Lampe schalten
                Wen jemand die anderen MQTT befehle zum steuern kennt gerne her damit dan ergänze ich das.
                Der adapter ist in einem beta status, die erste version kann über git und NPM installiert werden.
                Wen alles einigermassen läuft mache ich einen PR zur aufnähme in den admin
                Hier zum adapter: ioBroker.bambulab
                wunensche, Anregungen etc gerne als git issue. Möchte diese post hier auch nicht damit sprengen eventuell doch noch einen tester thread erstellen.
                Beim starten des adapters (v0.1.0) kommen noch warnings das Definitionen fehlen, die arbeite ich noch nach. Ist im Grunde nicht wichtig aber sorgt dafür das grad Celsius use richtig dargestellt wird
                • Dutchman
                  Dutchman Developer Most Active Administrators @dadonali last edited by
                  @dadonali sagte in Bambu lab 3d Drucker MQTT Integration:
                  Mal eine Frage zu diesem Github Eintrag:
                  https://github.com/greghesp/ha-bambulab
                  Hat sich hier schon mal mit dem Thema Buttons beschäftigt? Wenn ich das richtig verstehe sollten zumindest Start, Pause und Cancel realisierbar sein? Das wäre natürlich nice wenn man zumindest den Druck übers VIS im iobroker abbrechen könnte ohne immer das scheiß Bambu Studio öffnen zu müssen.
                  Allerdings finde ich nicht wirklich was in meinen Datenpunkten, welche mir NodeRed auswirft.
                  das wird in der 0.1.1 versions meines adapters funktionieren, start/stop/resume und schalten der Lampe
                    DarkDevil last edited by
                    Super, dass es nun einen Adapter gibt 🙂
                    Funktioniert die Kommunikation denn nur, wenn der Drucker im "LAN only" Mode konfiguriert ist?
                    • Dutchman
                      Dutchman Developer Most Active Administrators @DarkDevil last edited by Dutchman
                      @darkdevil sagte in Bambu lab 3d Drucker MQTT Integration:
                      nope geht in beiden Varianten, LAN only modus bedeutet das man die cloud ausschaltet es geht sowohl mit als ohne cloud da der adapter sich local verbindet 🙂
                      PS: in der jetzigen version auf git ist auch das steuern der lampe, start/stop/resume implementiert
                      sobald ich die states fertig habe kommt eine versions 0.2.0
                      • Dutchman
                        Dutchman Developer Most Active Administrators last edited by Dutchman
                        da der adapter stabiel läuft und ich es auch, mit ein wenig Hilfe, geschafft habe die Steuerung der lampen, des Lüfter und custom g-code zu implantieren habe ich dazu ein neuen thread erstellt.
                        Ich würde mich sehr über tester und feedback freuen !
                        https://forum.iobroker.net/topic/67178/bambulab-3d-drucker-adapter?_=1690472648517
                        19353
