    4. esphome - wird dies noch gepflegt?
    • frana120500
      frana120500 @andreas_n last edited by
      @andreas_n Ich konnte es nur lösen über eine IoBroker Neuinstallation
        Rushmed Most Active last edited by Rushmed
        nachdem ich das WebUI nichtmehr öffnen konnte habe ich den Adapter deinstelliert und die Daten gelöscht mit
        rm /opt/iobroker/iobroker-data/esphome.0/.esphome -r
        Beim Versuch den Adapter neu zu installieren bekomme ich nun:
        $ iobroker add esphome --host Smartazamba
        host.Smartazamba Unknown packetName esphome. Please install packages from outside the repository using npm!
        ERROR: Process exited with code 12
        Was mache ich falsch?
        Edit: Bookworm
          Thomas Braun Most Active @Rushmed last edited by Thomas Braun
          @rushmed
          iob update
          iob add esphome --host Smartazamba --debug
            Rushmed Most Active @Thomas Braun last edited by
            @thomas-braun sagte in esphome - wird dies noch gepflegt?:
            pi@Smartazamba:~ $ iob update
            Used repository: Stable (default)
            Adapter    "admin"        : 6.3.5    , installed 6.6.0
            Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
            Adapter    "backitup"     : 2.6.23   , installed 2.6.23
            Adapter    "denon"        : 1.15.2   , installed 1.15.2
            Adapter    "device-watcher": 2.9.2   , installed 2.9.2
            Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
            Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
            Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
            Adapter    "hue"          : 3.9.3    , installed 3.9.3
            Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
            Adapter    "info"         : 1.9.26   , installed 1.9.26
            Adapter    "iot"          : 1.14.5   , installed 1.14.5
            Adapter    "javascript"   : 7.0.3    , installed 7.0.3
            Controller "js-controller": 4.0.24   , installed 4.0.24
            Adapter    "kodi"         : 2.0.9    , installed 2.0.9
            Adapter    "linux-control": 1.1.3    , installed 1.1.3
            Adapter    "logparser"    : 2.2.0    , installed 2.2.0
            Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
            Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
            Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
            Adapter    "ping"         : 1.5.3    , installed 1.5.3
            Adapter    "pixelit"      : 0.2.0    , installed 0.2.0
            Adapter    "shelly"       : 6.4.1    , installed 6.4.1
            Adapter    "shuttercontrol": 1.5.0   , installed 1.5.0
            Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
            Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
            Adapter    "telegram"     : 1.16.0   , installed 1.16.0
            Adapter    "unifi"        : 0.6.6    , installed 0.6.6
            Adapter    "weatherunderground": 3.4.2, installed 3.4.2
            Adapter    "windows-control": 0.1.5  , installed 0.1.5
            Adapter    "wiobrowser"   : 2.0.1    , installed 2.0.1
            Adapter    "wled"         : 0.6.7    , installed 0.7.0
            Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
            Adapter    "zigbee"       : 1.8.16   , installed 1.8.16
            pi@Smartazamba:~ $ iob add esphome --host Smartazamba --debug
              Homoran Global Moderator Administrators @Rushmed last edited by
              @rushmed sagte in esphome - wird dies noch gepflegt?:
              oder wechsel vorübergehend ins Beta-Repo
                @rushmed
                Gibt es nicht über das Stable-Repo.
                Beta kurz scharf schalten.
                esphome
                github:	0.2.4
                latest:	0.2.4 for 23 months
                stable:	-.-.-
                  NPM version: 9.6.7
                  Installing iobroker.esphome@0.2.4... (System call)
                  npm ERR! code 1
                  npm ERR! path /opt/iobroker/node_modules/iobroker.esphome
                  npm ERR! command failed
                  npm ERR! command sh -c npip install
                  npm ERR! No python_modules directory; installing pip locally if needed.
                  npm ERR! pip 23.0.1 from /usr/lib/python3/dist-packages/pip (python 3.11)
                  npm ERR! error: externally-managed-environment
                  npm ERR!
                  npm ERR! × This environment is externally managed
                  npm ERR! ╰─> To install Python packages system-wide, try apt install
                  npm ERR!     python3-xyz, where xyz is the package you are trying to
                  npm ERR!     install.
                  npm ERR!
                  npm ERR!     If you wish to install a non-Debian-packaged Python package,
                  npm ERR!     create a virtual environment using python3 -m venv path/to/venv.
                  npm ERR!     Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
                  npm ERR!     sure you have python3-full installed.
                  npm ERR!
                  npm ERR!     If you wish to install a non-Debian packaged Python application,
                  npm ERR!     it may be easiest to use pipx install xyz, which will manage a
                  npm ERR!     virtual environment for you. Make sure you have pipx installed.
                  npm ERR!
                  npm ERR!     See /usr/share/doc/python3.11/README.venv for more information.
                  npm ERR!
                  npm ERR! note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
                  npm ERR! hint: See PEP 668 for the detailed specification.
                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-07-28T08_03_31_442Z-debug-0.log
                  host.Smartazamba Cannot install iobroker.esphome@0.2.4: 1
                  Den Fehler
                  bekomm ich auch beim Versuch der Python für das Zigbee Stick Update per SSH zu installieren.
                  Fehlt da noch was für Bookworm?
                    @Thomas-Braun Bin jetzt mit deinem Tipp von hier etwas weiter gekommen.
                    NPM version: 9.6.7
                    npm ERR! code 127
                    npm ERR! sh: 1: npip: Permission denied
                    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-07-28T08_19_07_068Z-debug-0.log
                    host.Smartazamba Cannot install iobroker.esphome@0.2.4: 127
                      @rushmed
                      Lösche die Datei /usr/lib/python3.x/EXTERNALLY-MANAGED
                      oder
                      verwende bei pip das Argument --break-system-packages
                      oder
                      füge in ~/.config/pip/pip.conf den Text ein:
                      [global]
                      break-system-packages = true
                        @rushmed
                        Ansonsten noch:
                        https://forum.iobroker.net/search?term=npm ERR! command sh -c npip install npm ERR! sh%3A 1%3A npip%3A Permission denied&in=posts&matchWords=all&sortBy=timestamp&sortDirection=desc&showAs=posts
                        Die Fehlermeldung ist bekannt.
                          Rushmed Most Active @Thomas Braun last edited by Rushmed
                          @thomas-braun Puh, erstmal danke für die Hilfe.
                          EXTERNALLY-MANAGED ist aus den Verzeichnis entfernt.
                          Wie kann ich bei der Adapterinstalletion bei pip das Argument --break-system-packages anfügen?
                          /.config/pip/pip.conf finde ich im Homeverzeichnis meines ioBroker Nutzers nicht.
                          In dem Thread war schließlich nur die Neuinstallation die Lösung.
                          Nach:
                          cd /opt/iobroker
                          npm i nopy
                          sudo -u iobroker chmod ug+x /opt/iobroker/node_modules/nopy/src/n*
                          Konnte ich den Adapter installieren.
                          Danke!
                            @rushmed
                            Du musst nur eine der drei Optionen umsetzen.
                              @thomas-braun Ich hatte doch hier schon EXTERNALLY-MANAGED entfernt.
                              Damit kam ich ja zu:
                              NPM version: 9.6.7
                              npm ERR! code 127
                              Davor war die Ausgabe folgende:
                              NPM version: 9.6.7
                              npm ERR! code 1
                              npm ERR!
                              npm ERR!     install.
                              npm ERR!
                              npm ERR!
                              npm ERR!
                              npm ERR!
                                @rushmed
                                Ja, dann war das mit nopy der richtige nächste Schritt.
                                  Wenn es noch wichtig ist....
                                  Es ist eine neue Version (Zur Zeit noch Beta) herausgekommen.
                                  Diese Version hat Module aus dem Internet geladen sodass alles wieder funktioniert. (Problem mit PlatformIO)
                                  Besten Dank @Dutchman
                                  Eines ist mir noch aufgefallen, was zwar die Funktion nicht beeinträchtigt aber unschön ist.
                                  Im Log finde ich viele Einträge, dass die Verbindung zu ioBroker mehrfach aufgebaut und einzeln abgebaut werden. (Dies ist neu - wird wohl am Beta-Stand liegen . oder?)
                                  [16:42:38][C][wifi:389]:   Signal strength: -49 dB ▂▄▆█
                                  [16:42:38][C][wifi:393]:   Channel: 5
                                  [16:42:38][C][wifi:394]:   Subnet: 255.255.255.0
                                  [16:42:38][C][wifi:395]:   Gateway: 192.168.1.1
                                  [16:42:38][C][wifi:396]:   DNS1: 192.168.1.1
                                  [16:42:38][C][wifi:397]:   DNS2: 0.0.0.0
                                  [16:42:38][D][api.connection:1050]: ESPHome Logs 2023.10.6 (192.168.1.95): Connected successfully
                                  [16:42:38][C][logger:416]: Logger:
                                  [16:42:38][C][logger:417]:   Level: DEBUG
                                  [16:42:38][C][logger:418]:   Log Baud Rate: 0
                                  [16:42:38][C][logger:420]:   Hardware UART: UART0
                                  [16:42:38][D][api:102]: Accepted 192.168.1.95
                                  [16:42:39][D][api:102]: Accepted 192.168.1.95
                                  [16:42:39][C][mdns:115]: mDNS:
                                  [16:42:39][C][mdns:116]:   Hostname: lifepo4-48vsolar1
                                  [16:42:39][C][ota:097]: Over-The-Air Updates:
                                  [16:42:39][C][ota:098]:   Address: lifepo4-48vsolar1.local:3232
                                  [16:42:39][C][ota:101]:   Using Password.
                                  [16:42:39][C][api:139]: API Server:
                                  [16:42:39][C][api:140]:   Address: lifepo4-48vsolar1.local:6053
                                  [16:42:39][C][api:142]:   Using noise encryption: YES
                                  [16:42:39][D][api.connection:1050]: ESPHome Logs 2023.10.6 (192.168.1.95): Connected successfully
                                  [16:42:39][W][component:214]: Component api took a long time for an operation (0.05 s).
                                  [16:42:39][W][component:215]: Components should block for at most 20-30ms.
                                  [16:42:40][W][api.connection:103]: ESPHome Logs 2023.10.6 (192.168.1.95): Connection closed
                                  [16:42:40][D][api:102]: Accepted 192.168.1.95
                                  [16:42:40][D][api.connection:1050]: ESPHome Logs 2023.10.6 (192.168.1.95): Connected successfully
                                  [16:42:40][W][component:214]: Component api took a long time for an operation (0.05 s).
                                  [16:42:40][W][component:215]: Components should block for at most 20-30ms.
                                  [16:42:41][D][api.connection:1050]: ESPHome Logs 2023.10.6 (192.168.1.95): Connected successfully
                                  [16:42:41][D][api:102]: Accepted 192.168.1.95
                                  [16:42:41][W][api.connection:103]: ESPHome Logs 2023.10.6 (192.168.1.95): Connection closed
                                    WolfgangFB last edited by
                                    @andreas_n
                                    Ich haabe hier die 0.41 im Einsatz und bei der passiert das bei mir auch ständig. Komischerweise aber nur mit ESPs die ich mit der neuen Version erstellt habe. Ich habe hier ältere ESPs die seit Jahren durchlaufen, da tritt das komischerweise nicht auf.
                                      andreas_n @WolfgangFB last edited by
                                      @wolfgangfb
                                      Bei mir ist es 0.5.0 Beta 8. (Läuft soweit aber ganz OK)
                                        tobiasp @andreas_n last edited by
                                        ich wollte ESPHome installieren.
                                        pi@raspberrypi:~ $ iob add esphome --host raspberrypi --debug
                                        installiert ist es, aber soblad ich das Dashboard aktiviere wirde der Adapter Rot.
                                          Thomas Braun Most Active @tobiasp last edited by
                                          @tobiasp sagte in esphome - wird dies noch gepflegt?:
                                          Du zeigst kein Log davon.
                                            tobiasp @Thomas Braun last edited by
                                            stimmt sorry
                                            host.raspberrypi
                                            	2024-01-13 12:29:12.798	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                            esphome.0
                                            	2024-01-13 12:29:12.393	info	terminating
                                            esphome.0
                                            	2024-01-13 12:29:11.711	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                            esphome.0
                                            	2024-01-13 12:29:11.707	info	terminating
                                            esphome.0
                                            	2024-01-13 12:29:11.662	error	Exception-Code: MODULE_NOT_FOUND: Cannot find module '@mongodb-js/zstd-linux-arm-gnueabihf'Require stack:- /opt/iobroker/node_modules/@mongodb-js/zstd/index.js
                                            esphome.0
                                            	2024-01-13 12:29:11.661	error	Error: Cannot find module '@mongodb-js/zstd-linux-arm-gnueabihf'Require stack:- /opt/iobroker/node_modules/@mongodb-js/zstd/index.js at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1134:15) at Function.Module._load (node:internal/modules/cjs/loader:975:27) at Module.require (node:internal/modules/cjs/loader:1225:19) at require (node:internal/modules/helpers:177:18) at Object.<anonymous> (/opt/iobroker/node_modules/@mongodb-js/zstd/index.js:131:29) at Module._compile (node:internal/modules/cjs/loader:1356:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1414:10) at Module.load (node:internal/modules/cjs/loader:1197:32) at Function.Module._load (node:internal/modules/cjs/loader:1013:12) at ModuleWrap.<anonymous> (node:internal/modules/esm/translators:202:29)
                                            esphome.0
                                            	2024-01-13 12:29:11.660	error	unhandled promise rejection: Cannot find module '@mongodb-js/zstd-linux-arm-gnueabihf'Require stack:- /opt/iobroker/node_modules/@mongodb-js/zstd/index.js
                                            esphome.0
                                            	2024-01-13 12:29:11.657	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                            esphome.0
                                            	2024-01-13 12:29:11.267	info	[Error caught and send to Sentry, thank you collaborating!] error: Error: Cannot find module '@mongodb-js/zstd-linux-arm-gnueabihf'Require stack:- /opt/iobroker/node_modules/@mongodb-js/zstd/index.js at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1134:15) at Function.Module._load (node:internal/modules/cjs/loader:975:27) at Module.require (node:internal/modules/cjs/loader:1225:19) at require (node:internal/modules/helpers:177:18) at Object.<anonymous> (/opt/iobroker/node_modules/@mongodb-js/zstd/index.js:131:29) at Module._compile (node:internal/modules/cjs/loader:1356:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1414:10) at Module.load (node:internal/modules/cjs/loader:1197:32) at Function.Module._load (node:internal/modules/cjs/loader:1013:12) at ModuleWrap.<anonymous> (node:internal/modules/esm/translators:202:29)
                                            esphome.0
                                            	2024-01-13 12:29:10.907	info	Native Integration of ESPHome Dashboard enabled
                                            esphome.0
                                            	2024-01-13 12:29:10.417	info	starting. Version 0.5.0-beta.8 in /opt/iobroker/node_modules/iobroker.esphome, node: v18.19.0, js-controller: 5.0.17
                                            4991
