    4. js-controller 5.0.x jetzt in der BETA
    • foxriver76
      foxriver76 Developer last edited by foxriver76
      @ticaki bzw war da noch mehr log vom Upgrade manager vor successfully stopped müsste mindestens noch was gewesen sein
        ticaki @foxriver76 last edited by ticaki
        @foxriver76
        Hab gleichartige Logeinträge ausgelassen (...) sind trotzdem sehr viele
        2023-07-27 18:34:14.145 - info: host.iobroker Controller will upgrade itself to version 5.0.9
        2023-07-27 18:34:14.859 - info: host.iobroker [CONTROLLER_AUTO_UPGRADE] Stopping controller
        2023-07-27 18:34:14.896 - info: javascript.0 (29336) Stop script script.js.Verwaltung.Luftbefeuchter
        2023-07-27 18:34:14.895 - info: backitup.0 (1377) cleaned everything up...
        2023-07-27 18:34:14.921 - info: backitup.0 (1377) terminating
        2023-07-27 18:34:14.923 - info: backitup.0 (1377) Terminated (NO_ERROR): Without reason
        2023-07-27 18:34:14.883 - info: host.iobroker received SIGTERM
        2023-07-27 18:34:14.888 - info: admin.0 (371) terminating https server on port 443
        2023-07-27 18:34:14.890 - info: yahka.0 (1252) cleaning up ...
        2023-07-27 18:34:14.893 - info: yahka.0 (1252) cleaned up ...
        2023-07-27 18:34:14.919 - info: yahka.0 (1252) terminating
        2023-07-27 18:34:14.919 - info: yahka.0 (1252) Terminated (NO_ERROR): Without reason
        2023-07-27 18:34:14.904 - info: reolink.0 (689) terminating
        2023-07-27 18:34:14.916 - info: reolink.0 (689) Terminated (NO_ERROR): Without reason
        2023-07-27 18:34:14.908 - info: admin.0 (371) terminating
        2023-07-27 18:34:14.909 - info: admin.0 (371) Terminated (NO_ERROR): Without reason
        2023-07-27 18:34:14.897 - info: javascript.0 (29336) Stop script script.js.Beleuchtung_(mehrere_Räume).hue_convert_Virtuelle_Light_on-off_0%-100%_brightness
        2023-07-27 18:34:14.913 - info: javascript.0 (29336) Stop script script.js.Messages.Sensorüberwachung
        2023-07-27 18:34:14.884 - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
        2023-07-27 18:34:14.916 - info: host.iobroker stopInstance system.adapter.backitup.0 (force=false, process=true)
        2023-07-27 18:34:14.947 - info: backitup.0 (1377) Got terminate signal TERMINATE_YOURSELF
        2023-07-27 18:34:14.951 - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
        2023-07-27 18:34:14.958 - info: javascript.0 (29336) Got terminate signal TERMINATE_YOURSELF
        2023-07-27 18:34:14.951 - info: host.iobroker stopInstance system.adapter.email.0 send kill signal
        2023-07-27 18:34:14.962 - info: javascript.0 (29336) terminating
        2023-07-27 18:34:14.962 - info: javascript.0 (29336) Terminated (NO_ERROR): Without reason
        2023-07-27 18:34:14.967 - info: telegram.0 (76948) Got terminate signal TERMINATE_YOURSELF
        2023-07-27 18:34:14.920 - info: fritzdect.0 (1230) cleaned everything up...
        2023-07-27 18:34:14.981 - info: fritzdect.0 (1230) Got terminate signal TERMINATE_YOURSELF
        2023-07-27 18:34:14.947 - info: notification-manager.0 (1345) terminating
        2023-07-27 18:34:14.988 - info: notification-manager.0 (1345) Terminated (NO_ERROR): Without reason
        2023-07-27 18:34:14.988 - info: notification-manager.0 (1345) Got terminate signal TERMINATE_YOURSELF
        2023-07-27 18:34:14.997 - warn: zigbee2mqtt.0 (772) Start try again in 1 seconds...
        2023-07-27 18:34:14.888 - error: mihome-vacuum.0 (508) Socket Close
        2023-07-27 18:34:14.923 - info: sma-em.0 (1329) cleaned everything up...
        2023-07-27 18:34:15.001 - info: sma-em.0 (1329) UDP Socket closed ...
        2023-07-27 18:34:14.911 - info: yahka.1 (757) cleaning up ...
        2023-07-27 18:34:14.915 - info: yahka.1 (757) cleaned up ...
        2023-07-27 18:34:14.973 - info: iot.0 (742) Got terminate signal TERMINATE_YOURSELF
        2023-07-27 18:34:15.012 - info: iot.0 (742) Connection changed: disconnect
        2023-07-27 18:34:15.017 - info: iot.0 (742) Connection lost
        2023-07-27 18:34:14.949 - info: pushover.0 (457) Got terminate signal TERMINATE_YOURSELF
        2023-07-27 18:34:14.974 - info: alexa2.0 (659) Got terminate signal TERMINATE_YOURSELF
        2023-07-27 18:34:14.945 - info: mqtt.0 (553) Disconnected from mqtt.tims.home: undefined
        2023-07-27 18:34:14.929 - info: hm-rpc.1 (24701) xmlrpc -> 192.168.179.201:42010/ init ["http://192.168.179.7:42010",""]
        2023-07-27 18:34:15.029 - info: hm-rpc.1 (24701) Got terminate signal TERMINATE_YOURSELF
        2023-07-27 18:34:14.953 - info: discovery.0 (725) terminating
        2023-07-27 18:34:15.022 - info: discovery.0 (725) Terminated (NO_ERROR): Without reason
        2023-07-27 18:34:15.027 - info: discovery.0 (725) Got terminate signal TERMINATE_YOURSELF
        2023-07-27 18:34:14.904 - info: homepilot20.0 (704) terminating homepilot20 adapter
        2023-07-27 18:34:14.999 - error: homepilot20.0 (704) Adapter will be stopped
        2023-07-27 18:34:15.032 - info: hyperion_ng.0 (1185) terminating
        2023-07-27 18:34:15.033 - info: hyperion_ng.0 (1185) Terminated (NO_ERROR): Without reason
        2023-07-27 18:34:14.932 - info: hm-rpc.0 (24716) xmlrpc -> 192.168.179.201:42001/ init ["http://192.168.179.7:42001",""]
        2023-07-27 18:34:15.035 - info: hm-rpc.0 (24716) Got terminate signal TERMINATE_YOURSELF
        2023-07-27 18:34:14.960 - info: hm-rega.0 (538) Got terminate signal TERMINATE_YOURSELF
        2023-07-27 18:34:15.036 - info: iot.0 (742) terminating
        2023-07-27 18:34:14.969 - info: daikin.0 (644) Got terminate signal TERMINATE_YOURSELF
        2023-07-27 18:34:15.036 - info: daikin.0 (644) terminating
        2023-07-27 18:34:15.037 - info: daikin.0 (644) Terminated (NO_ERROR): Without reason
        2023-07-27 18:34:14.999 - info: mihome-vacuum.0 (508) Got terminate signal TERMINATE_YOURSELF
        2023-07-27 18:34:15.039 - info: fritzdect.0 (1230) terminating
        2023-07-27 18:34:15.039 - info: fritzdect.0 (1230) Terminated (NO_ERROR): Without reason
        2023-07-27 18:34:15.004 - info: sma-em.0 (1329) Terminated (NO_ERROR): Without reason
        2023-07-27 18:34:15.036 - info: iot.0 (742) Terminated (NO_ERROR): Without reason
        2023-07-27 18:34:14.989 - warn: influxdb.1 (493) Store data for 149 points and 0 conflicts
        2023-07-27 18:34:15.045 - info: mihome-vacuum.0 (508) terminating
        2023-07-27 18:34:15.045 - info: mihome-vacuum.0 (508) Terminated (NO_ERROR): Without reason
        2023-07-27 18:34:15.032 - info: homepilot20.0 (704) Got terminate signal TERMINATE_YOURSELF
        2023-07-27 18:34:15.047 - info: alexa2.0 (659) terminating
        2023-07-27 18:34:15.047 - info: alexa2.0 (659) Terminated (NO_ERROR): Without reason
        2023-07-27 18:34:15.028 - info: mqtt.0 (553) Got terminate signal TERMINATE_YOURSELF
        2023-07-27 18:34:15.049 - info: hm-rpc.1 (24701) Disconnected
        2023-07-27 18:34:15.049 - info: homepilot20.0 (704) terminating
        2023-07-27 18:34:15.050 - info: homepilot20.0 (704) Terminated (NO_ERROR): Without reason
        2023-07-27 18:34:15.051 - info: hm-rpc.0 (24716) Disconnected
        2023-07-27 18:34:15.055 - info: hm-rpc.1 (24701) terminating
        2023-07-27 18:34:15.055 - info: hm-rpc.1 (24701) Terminated (NO_ERROR): Without reason
        2023-07-27 18:34:15.057 - info: hm-rpc.0 (24716) terminating
        2023-07-27 18:34:15.057 - info: hm-rpc.0 (24716) Terminated (NO_ERROR): Without reason
        2023-07-27 18:34:15.062 - info: hm-rega.0 (538) terminating
        2023-07-27 18:34:15.063 - info: hm-rega.0 (538) Terminated (NO_ERROR): Without reason
        2023-07-27 18:34:15.126 - info: zigbee2mqtt.0 (772) terminating
        2023-07-27 18:34:15.127 - info: zigbee2mqtt.0 (772) Terminated (NO_ERROR): Without reason
        2023-07-27 18:34:15.388 - info: pushover.0 (457) Terminated (NO_ERROR): Without reason
        2023-07-27 18:34:15.395 - info: mqtt.0 (553) Terminated (NO_ERROR): Without reason
        2023-07-27 18:34:15.403 - info: sonoff.0 (674) Terminated (NO_ERROR): Without reason
        2023-07-27 18:34:15.451 - info: telegram.0 (76948) Terminated (NO_ERROR): Without reason
        2023-07-27 18:34:15.459 - info: host.iobroker instance system.adapter.yahka.0 terminated with code 0 (NO_ERROR)
        2023-07-27 18:34:15.459 - info: host.iobroker stopInstance system.adapter.hyperion_ng.0 killing pid 1185
        2023-07-27 18:34:15.481 - info: fritzdect.0 (1230) terminating
        2023-07-27 18:34:15.484 - info: sma-em.0 (1329) terminating
        2023-07-27 18:34:15.482 - info: yahka.1 (757) terminating
        2023-07-27 18:34:15.500 - info: homepilot20.0 (704) terminating
        2023-07-27 18:34:15.528 - info: host.iobroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
        2023-07-27 18:34:15.528 - info: host.iobroker instance system.adapter.reolink.0 terminated with code 0 (NO_ERROR)
        2023-07-27 18:34:15.528 - info: host.iobroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
        2023-07-27 18:34:15.583 - warn: host.iobroker instance system.adapter.hyperion_ng.0 terminated due to SIGTERM
        2023-07-27 18:34:15.583 - info: host.iobroker instance system.adapter.hyperion_ng.0 terminated with code null ()
        2023-07-27 18:34:15.932 - info: host.iobroker instance system.adapter.sonoff.0 terminated with code 0 (NO_ERROR)
        2023-07-27 18:34:15.952 - info: host.iobroker stopInstance system.adapter.telegram.0 killing pid 76948
        2023-07-27 18:34:15.966 - warn: host.iobroker instance system.adapter.telegram.0 terminated due to SIGTERM
        2023-07-27 18:34:15.966 - info: host.iobroker instance system.adapter.telegram.0 terminated with code null ()
        2023-07-27 18:34:17.896 - info: tuya.0 (568) terminating
        2023-07-27 18:34:17.897 - info: tuya.0 (568) Terminated (NO_ERROR): Without reason
        2023-07-27 18:34:18.416 - info: host.iobroker instance system.adapter.tuya.0 terminated with code 0 (NO_ERROR)
        2023-07-27 18:34:18.417 - info: host.iobroker All instances are stopped.
        2023-07-27 18:34:18.555 - info: host.iobroker terminated
        2023-07-27 18:34:22.577 - info: host.iobroker [CONTROLLER_AUTO_UPGRADE] Successfully stopped js-controller
        2023-07-27 18:39:08.511 - info: host.iobroker iobroker.js-controller version 5.0.8 js-controller starting
          crunchip Forum Testing Most Active @foxriver76 last edited by crunchip
          @foxriver76 per gui ging es diesmal bei mir auch nicht, beim beenden der Adapter kamen viele Error, zum Schluss wurde js-controller beendet und dann tat sich nix mehr.
          Gesamte log kann ich gerne zur Verfügung stellen, bin aber grad nur per Handy on.
          @foxriver76 habs nur ein wenig eingekürzt
          js-controller.txt
          • Feuersturm
            Feuersturm last edited by
            Hier das gleiche Verhalten beim Update über die GUI.
            Master lies sich in der Vergangenheit über die GUI erfolgreich aktualisieren, von 5.0.8 auf 5.0.9 nicht.
            js-controller wurde gestoppt, es wurde aber kein update im Hintergrund ausgeführt. Ich musste iobroker manuell starten.
            2023-07-27 20:24:10.269 - info: host.ioBrokerTestsystem Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
            2023-07-27 20:26:58.312 - info: host.ioBrokerTestsystem Controller will upgrade itself to version 5.0.9
            2023-07-27 20:27:04.381 - info: host.ioBrokerTestsystem [CONTROLLER_AUTO_UPGRADE] Stopping controller
            2023-07-27 20:27:04.514 - info: host.ioBrokerTestsystem received SIGTERM
            2023-07-27 20:27:04.540 - info: backitup.0 (550) cleaned everything up...
            2023-07-27 20:27:04.521 - info: javascript.0 (348) Stop script script.js.Skripte.Kalender.ical_0_ToHtmlTable
            2023-07-27 20:27:04.535 - info: hm-rpc.0 (502) xmlrpc -> 192.168.178.84:2010/ init ["http://192.168.178.77:2010",""]
            2023-07-27 20:27:04.548 - info: unifi.0 (478) cleaned everything up...
            2023-07-27 20:27:04.582 - info: hm-rpc.0 (502) Disconnected
            2023-07-27 20:27:04.563 - info: info.0 (598) cleaned everything up...
            2023-07-27 20:27:04.539 - info: admin.0 (337) terminating http server on port 8081
            2023-07-27 20:27:04.561 - info: javascript.0 (348) Stop script script.js.Skripte.Kalender.ical_2_ToHtmlTable
            2023-07-27 20:27:04.566 - info: javascript.0 (348) Stop script script.js.Skripte.Kalender.ical_3_ToHtmlTable
            2023-07-27 20:27:04.571 - info: javascript.0 (348) Stop script script.js.Skripte.Kalender.ical_4_ToHtmlTable
            2023-07-27 20:27:04.577 - info: javascript.0 (348) Stop script script.js.Skripte.Kalender.muellkalender
            2023-07-27 20:27:04.582 - info: javascript.0 (348) Stop script script.js.Skripte.Netzwerk.Unifi_Vouchers
            2023-07-27 20:27:04.611 - info: proxmox.0 (642) cleaned everything up...
            2023-07-27 20:27:04.563 - info: simple-api.0 (658) terminating http server on port 8087
            2023-07-27 20:27:04.656 - info: vis-inventwo.0 (1025) cleaned everything up...
            2023-07-27 20:27:04.613 - info: trashschedule.0 (747) cleaned everything up...
            2023-07-27 20:27:04.621 - info: valloxmv.0 (771) cleaned everything up...
            2023-07-27 20:27:04.636 - info: device-watcher.0 (933) cleaned everything up...
            2023-07-27 20:27:04.520 - info: host.ioBrokerTestsystem stopInstance system.adapter.admin.0 (force=false, process=true)
            2023-07-27 20:27:04.525 - info: host.ioBrokerTestsystem stopInstance system.adapter.influxdb.0 (force=false, process=false)
            2023-07-27 20:27:04.526 - info: host.ioBrokerTestsystem stopInstance system.adapter.javascript.0 (force=false, process=true)
            2023-07-27 20:27:04.546 - info: host.ioBrokerTestsystem stopInstance system.adapter.scenes.0 (force=false, process=true)
            2023-07-27 20:27:04.547 - info: host.ioBrokerTestsystem stopInstance system.adapter.telegram.0 (force=false, process=false)
            2023-07-27 20:27:04.549 - info: host.ioBrokerTestsystem stopInstance system.adapter.scheduler.0 (force=false, process=true)
            2023-07-27 20:27:04.550 - info: host.ioBrokerTestsystem stopInstance system.adapter.fritzbox.0 (force=false, process=true)
            2023-07-27 20:27:04.574 - info: host.ioBrokerTestsystem stopInstance system.adapter.hue.0 (force=false, process=false)
            2023-07-27 20:27:04.577 - info: host.ioBrokerTestsystem stopInstance system.adapter.ical.0 (force=false, process=false)
            2023-07-27 20:27:04.579 - info: host.ioBrokerTestsystem stopInstance system.adapter.ical.1 (force=false, process=false)
            2023-07-27 20:27:04.586 - info: host.ioBrokerTestsystem stopInstance system.adapter.ical.2 (force=false, process=false)
            2023-07-27 20:27:04.587 - info: host.ioBrokerTestsystem stopInstance system.adapter.ical.3 (force=false, process=false)
            2023-07-27 20:27:04.588 - info: host.ioBrokerTestsystem stopInstance system.adapter.ical.4 (force=false, process=false)
            2023-07-27 20:27:04.589 - info: host.ioBrokerTestsystem stopInstance system.adapter.ical.5 (force=false, process=false)
            2023-07-27 20:27:04.591 - info: host.ioBrokerTestsystem stopInstance canceled schedule system.adapter.ical.5
            2023-07-27 20:27:04.593 - info: host.ioBrokerTestsystem stopInstance system.adapter.mqtt.0 (force=false, process=false)
            2023-07-27 20:27:04.595 - info: host.ioBrokerTestsystem stopInstance system.adapter.samsung-community.0 (force=false, process=true)
            2023-07-27 20:27:04.638 - info: host.ioBrokerTestsystem stopInstance system.adapter.spotify-premium.0 (force=false, process=false)
            2023-07-27 20:27:04.642 - info: host.ioBrokerTestsystem stopInstance system.adapter.tr-064.0 (force=false, process=true)
            2023-07-27 20:27:04.648 - info: host.ioBrokerTestsystem stopInstance system.adapter.unifi.0 (force=false, process=true)
            2023-07-27 20:27:04.656 - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rpc.0 (force=false, process=true)
            2023-07-27 20:27:04.662 - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rega.0 (force=false, process=true)
            2023-07-27 20:27:04.664 - info: host.ioBrokerTestsystem stopInstance system.adapter.openweathermap.0 (force=false, process=false)
            2023-07-27 20:27:04.666 - info: host.ioBrokerTestsystem stopInstance canceled schedule system.adapter.openweathermap.0
            2023-07-27 20:27:04.667 - info: host.ioBrokerTestsystem stopInstance system.adapter.backitup.0 (force=false, process=true)
            2023-07-27 20:27:04.670 - info: host.ioBrokerTestsystem stopInstance system.adapter.benchmark.0 (force=false, process=false)
            2023-07-27 20:27:04.675 - info: host.ioBrokerTestsystem stopInstance system.adapter.daswetter.0 (force=false, process=false)
            2023-07-27 20:27:04.676 - info: host.ioBrokerTestsystem stopInstance canceled schedule system.adapter.daswetter.0
            2023-07-27 20:27:04.678 - info: host.ioBrokerTestsystem stopInstance system.adapter.dwd.0 (force=false, process=false)
            2023-07-27 20:27:04.679 - info: host.ioBrokerTestsystem stopInstance canceled schedule system.adapter.dwd.0
            2023-07-27 20:27:04.682 - info: host.ioBrokerTestsystem stopInstance system.adapter.fully-tablet-control.0 (force=false, process=false)
            2023-07-27 20:27:04.683 - info: host.ioBrokerTestsystem stopInstance system.adapter.info.0 (force=false, process=true)
            2023-07-27 20:27:04.684 - info: host.ioBrokerTestsystem stopInstance system.adapter.nina.0 (force=false, process=true)
            2023-07-27 20:27:04.686 - info: host.ioBrokerTestsystem stopInstance system.adapter.proxmox.0 (force=false, process=true)
            2023-07-27 20:27:04.689 - info: host.ioBrokerTestsystem stopInstance system.adapter.rainbird.0 (force=false, process=false)
            2023-07-27 20:27:04.690 - info: host.ioBrokerTestsystem stopInstance system.adapter.sayit.0 (force=false, process=false)
            2023-07-27 20:27:04.692 - info: host.ioBrokerTestsystem stopInstance system.adapter.simple-api.0 (force=false, process=true)
            2023-07-27 20:27:04.695 - info: host.ioBrokerTestsystem stopInstance system.adapter.socketio.0 (force=false, process=false)
            2023-07-27 20:27:04.696 - info: host.ioBrokerTestsystem stopInstance system.adapter.tankerkoenig.0 (force=false, process=true)
            2023-07-27 20:27:04.698 - info: host.ioBrokerTestsystem stopInstance system.adapter.trashschedule.0 (force=false, process=true)
            2023-07-27 20:27:04.699 - info: host.ioBrokerTestsystem stopInstance system.adapter.valloxmv.0 (force=false, process=true)
            2023-07-27 20:27:04.701 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-fancyswitch.0 (force=false, process=false)
            2023-07-27 20:27:04.702 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-google-fonts.0 (force=false, process=false)
            2023-07-27 20:27:04.703 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-history.0 (force=false, process=false)
            2023-07-27 20:27:04.704 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-jqui-mfd.0 (force=false, process=false)
            2023-07-27 20:27:04.705 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-justgage.0 (force=false, process=false)
            2023-07-27 20:27:04.706 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-map.0 (force=false, process=false)
            2023-07-27 20:27:04.707 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-materialdesign.0 (force=false, process=false)
            2023-07-27 20:27:04.708 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-timeandweather.0 (force=false, process=false)
            2023-07-27 20:27:04.710 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis.0 (force=false, process=false)
            2023-07-27 20:27:04.711 - info: host.ioBrokerTestsystem stopInstance system.adapter.web.0 (force=false, process=true)
            2023-07-27 20:27:04.712 - info: host.ioBrokerTestsystem stopInstance system.adapter.worx.0 (force=false, process=false)
            2023-07-27 20:27:04.713 - info: host.ioBrokerTestsystem stopInstance system.adapter.device-watcher.0 (force=false, process=true)
            2023-07-27 20:27:04.715 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-2-beta.0 (force=false, process=true)
            2023-07-27 20:27:04.716 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-metro.0 (force=false, process=false)
            2023-07-27 20:27:04.718 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-2-widgets-jaeger-design.0 (force=false, process=false)
            2023-07-27 20:27:04.719 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-2-widgets-energy.0 (force=false, process=false)
            2023-07-27 20:27:04.720 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-2-widgets-gauges.0 (force=false, process=false)
            2023-07-27 20:27:04.729 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-2-widgets-material.0 (force=false, process=false)
            2023-07-27 20:27:04.730 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-inventwo.0 (force=false, process=true)
            2023-07-27 20:27:04.928 - info: unifi.0 (478) Got terminate signal TERMINATE_YOURSELF
            2023-07-27 20:27:04.930 - info: hm-rpc.0 (502) Got terminate signal TERMINATE_YOURSELF
            2023-07-27 20:27:04.934 - info: info.0 (598) Got terminate signal TERMINATE_YOURSELF
            2023-07-27 20:27:04.946 - info: backitup.0 (550) Got terminate signal TERMINATE_YOURSELF
            2023-07-27 20:27:04.908 - info: scenes.0 (371) terminating
            2023-07-27 20:27:04.925 - info: samsung-community.0 (447) Got terminate signal TERMINATE_YOURSELF
            2023-07-27 20:27:04.954 - info: proxmox.0 (642) Got terminate signal TERMINATE_YOURSELF
            2023-07-27 20:27:04.954 - info: scenes.0 (371) Terminated (NO_ERROR): Without reason
            2023-07-27 20:27:04.949 - info: simple-api.0 (658) Got terminate signal TERMINATE_YOURSELF
            2023-07-27 20:27:04.933 - info: hm-rega.0 (522) Got terminate signal TERMINATE_YOURSELF
            2023-07-27 20:27:04.944 - info: nina.0 (614) Got terminate signal TERMINATE_YOURSELF
            2023-07-27 20:27:04.962 - info: scenes.0 (371) Got terminate signal TERMINATE_YOURSELF
            2023-07-27 20:27:04.945 - info: tankerkoenig.0 (680) Got terminate signal TERMINATE_YOURSELF
            2023-07-27 20:27:04.926 - info: tr-064.0 (462) Got terminate signal TERMINATE_YOURSELF
            2023-07-27 20:27:04.957 - info: fritzbox.0 (417) Got terminate signal TERMINATE_YOURSELF
            2023-07-27 20:27:04.915 - info: admin.0 (337) Got terminate signal TERMINATE_YOURSELF
            2023-07-27 20:27:04.918 - info: javascript.0 (348) Got terminate signal TERMINATE_YOURSELF
            2023-07-27 20:27:04.920 - info: scheduler.0 (398) Got terminate signal TERMINATE_YOURSELF
            2023-07-27 20:27:04.980 - info: trashschedule.0 (747) Got terminate signal TERMINATE_YOURSELF
            2023-07-27 20:27:04.981 - info: valloxmv.0 (771) Got terminate signal TERMINATE_YOURSELF
            2023-07-27 20:27:04.987 - info: web.0 (917) Got terminate signal TERMINATE_YOURSELF
            2023-07-27 20:27:05.003 - info: device-watcher.0 (933) Got terminate signal TERMINATE_YOURSELF
            2023-07-27 20:27:05.011 - info: vis-inventwo.0 (1025) Got terminate signal TERMINATE_YOURSELF
            2023-07-27 20:27:05.007 - info: vis-2-beta.0 (1014) Got terminate signal TERMINATE_YOURSELF
            2023-07-27 20:27:05.024 - info: fritzbox.0 (417) terminating
            2023-07-27 20:27:05.024 - info: tr-064.0 (462) terminating
            2023-07-27 20:27:05.028 - info: fritzbox.0 (417) Terminated (NO_ERROR): Without reason
            2023-07-27 20:27:05.024 - info: scheduler.0 (398) terminating
            2023-07-27 20:27:05.033 - info: unifi.0 (478) terminating
            2023-07-27 20:27:05.035 - info: hm-rpc.0 (502) terminating
            2023-07-27 20:27:05.032 - info: tr-064.0 (462) Terminated (NO_ERROR): Without reason
            2023-07-27 20:27:05.032 - info: samsung-community.0 (447) terminating
            2023-07-27 20:27:05.028 - info: scheduler.0 (398) Terminated (NO_ERROR): Without reason
            2023-07-27 20:27:05.039 - info: backitup.0 (550) terminating
            2023-07-27 20:27:05.038 - info: unifi.0 (478) Terminated (NO_ERROR): Without reason
            2023-07-27 20:27:05.038 - info: hm-rpc.0 (502) Terminated (NO_ERROR): Without reason
            2023-07-27 20:27:05.040 - info: samsung-community.0 (447) Terminated (NO_ERROR): Without reason
            2023-07-27 20:27:05.038 - info: nina.0 (614) terminating
            2023-07-27 20:27:05.036 - info: proxmox.0 (642) terminating
            2023-07-27 20:27:05.054 - info: trashschedule.0 (747) terminating
            2023-07-27 20:27:05.054 - info: vis-inventwo.0 (1025) terminating
            2023-07-27 20:27:05.044 - info: javascript.0 (348) terminating
            2023-07-27 20:27:05.057 - info: javascript.0 (348) Terminated (NO_ERROR): Without reason
            2023-07-27 20:27:05.064 - info: vis-2-beta.0 (1014) terminating
            2023-07-27 20:27:05.057 - info: vis-inventwo.0 (1025) Terminated (NO_ERROR): Without reason
            2023-07-27 20:27:05.053 - info: info.0 (598) terminating
            2023-07-27 20:27:05.057 - info: device-watcher.0 (933) terminating
            2023-07-27 20:27:05.067 - info: vis-2-beta.0 (1014) Terminated (NO_ERROR): Without reason
            2023-07-27 20:27:05.059 - info: valloxmv.0 (771) terminating
            2023-07-27 20:27:05.055 - info: simple-api.0 (658) terminating
            2023-07-27 20:27:05.053 - info: tankerkoenig.0 (680) terminating
            2023-07-27 20:27:05.048 - info: nina.0 (614) Terminated (NO_ERROR): Without reason
            2023-07-27 20:27:05.058 - info: admin.0 (337) terminating
            2023-07-27 20:27:05.049 - info: backitup.0 (550) Terminated (NO_ERROR): Without reason
            2023-07-27 20:27:05.077 - info: trashschedule.0 (747) Terminated (NO_ERROR): Without reason
            2023-07-27 20:27:05.047 - info: proxmox.0 (642) Terminated (NO_ERROR): Without reason
            2023-07-27 20:27:05.083 - info: device-watcher.0 (933) Terminated (NO_ERROR): Without reason
            2023-07-27 20:27:05.083 - info: info.0 (598) Terminated (NO_ERROR): Without reason
            2023-07-27 20:27:05.097 - info: simple-api.0 (658) Terminated (NO_ERROR): Without reason
            2023-07-27 20:27:05.078 - info: valloxmv.0 (771) Terminated (NO_ERROR): Without reason
            2023-07-27 20:27:05.094 - info: tankerkoenig.0 (680) Terminated (NO_ERROR): Without reason
            2023-07-27 20:27:05.086 - info: admin.0 (337) Terminated (NO_ERROR): Without reason
            2023-07-27 20:27:05.132 - warn: web.0 (917) Timeout by termination of web-extensions!
            2023-07-27 20:27:05.137 - info: web.0 (917) terminated http server on port 8082
            2023-07-27 20:27:05.177 - info: host.ioBrokerTestsystem stopInstance system.adapter.admin.0 send kill signal
            2023-07-27 20:27:05.205 - info: host.ioBrokerTestsystem stopInstance system.adapter.javascript.0 send kill signal
            2023-07-27 20:27:05.207 - info: host.ioBrokerTestsystem stopInstance system.adapter.scenes.0 send kill signal
            2023-07-27 20:27:05.208 - info: host.ioBrokerTestsystem stopInstance system.adapter.scheduler.0 send kill signal
            2023-07-27 20:27:05.209 - info: host.ioBrokerTestsystem stopInstance system.adapter.fritzbox.0 send kill signal
            2023-07-27 20:27:05.210 - info: host.ioBrokerTestsystem stopInstance system.adapter.samsung-community.0 send kill signal
            2023-07-27 20:27:05.212 - info: host.ioBrokerTestsystem stopInstance system.adapter.tr-064.0 send kill signal
            2023-07-27 20:27:05.213 - info: host.ioBrokerTestsystem stopInstance system.adapter.unifi.0 send kill signal
            2023-07-27 20:27:05.214 - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rpc.0 send kill signal
            2023-07-27 20:27:05.215 - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rega.0 send kill signal
            2023-07-27 20:27:05.216 - info: host.ioBrokerTestsystem stopInstance system.adapter.backitup.0 send kill signal
            2023-07-27 20:27:05.218 - info: host.ioBrokerTestsystem stopInstance system.adapter.info.0 send kill signal
            2023-07-27 20:27:05.219 - info: host.ioBrokerTestsystem stopInstance system.adapter.nina.0 send kill signal
            2023-07-27 20:27:05.220 - info: host.ioBrokerTestsystem stopInstance system.adapter.proxmox.0 send kill signal
            2023-07-27 20:27:05.222 - info: host.ioBrokerTestsystem stopInstance system.adapter.simple-api.0 send kill signal
            2023-07-27 20:27:05.223 - info: host.ioBrokerTestsystem stopInstance system.adapter.tankerkoenig.0 send kill signal
            2023-07-27 20:27:05.224 - info: host.ioBrokerTestsystem stopInstance system.adapter.trashschedule.0 send kill signal
            2023-07-27 20:27:05.226 - info: host.ioBrokerTestsystem stopInstance system.adapter.valloxmv.0 send kill signal
            2023-07-27 20:27:05.227 - info: host.ioBrokerTestsystem stopInstance system.adapter.web.0 send kill signal
            2023-07-27 20:27:05.228 - info: host.ioBrokerTestsystem stopInstance system.adapter.device-watcher.0 send kill signal
            2023-07-27 20:27:05.228 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-2-beta.0 send kill signal
            2023-07-27 20:27:05.229 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-inventwo.0 send kill signal
            2023-07-27 20:27:05.288 - info: scenes.0 (371) terminating
            2023-07-27 20:27:05.351 - info: scheduler.0 (398) terminating
            2023-07-27 20:27:05.344 - info: fritzbox.0 (417) terminating
            2023-07-27 20:27:05.361 - info: unifi.0 (478) terminating
            2023-07-27 20:27:05.347 - info: tr-064.0 (462) terminating
            2023-07-27 20:27:05.367 - info: hm-rega.0 (522) terminating
            2023-07-27 20:27:05.367 - info: backitup.0 (550) terminating
            2023-07-27 20:27:05.374 - info: device-watcher.0 (933) terminating
            2023-07-27 20:27:05.368 - info: web.0 (917) terminating
            2023-07-27 20:27:05.375 - info: vis-2-beta.0 (1014) terminating
            2023-07-27 20:27:05.377 - info: trashschedule.0 (747) terminating
            2023-07-27 20:27:05.377 - info: valloxmv.0 (771) terminating
            2023-07-27 20:27:05.369 - info: tankerkoenig.0 (680) terminating
            2023-07-27 20:27:05.383 - info: hm-rega.0 (522) Terminated (NO_ERROR): Without reason
            2023-07-27 20:27:05.383 - info: javascript.0 (348) terminating
            2023-07-27 20:27:05.348 - info: samsung-community.0 (447) terminating
            2023-07-27 20:27:05.373 - info: simple-api.0 (658) terminating
            2023-07-27 20:27:05.350 - info: nina.0 (614) terminating
            2023-07-27 20:27:05.374 - info: vis-inventwo.0 (1025) terminating
            2023-07-27 20:27:05.370 - info: info.0 (598) terminating
            2023-07-27 20:27:05.403 - info: admin.0 (337) terminating
            2023-07-27 20:27:05.407 - info: proxmox.0 (642) terminating
            2023-07-27 20:27:05.408 - info: web.0 (917) Terminated (NO_ERROR): Without reason
            2023-07-27 20:27:05.414 - info: web.0 (917) terminating
            2023-07-27 20:27:05.484 - info: hm-rega.0 (522) terminating
            2023-07-27 20:27:05.573 - warn: hm-rpc.0 (502) get state error: Connection is closed.
            2023-07-27 20:27:05.576 - info: hm-rpc.0 (502) terminating
            2023-07-27 20:27:05.785 - info: host.ioBrokerTestsystem instance system.adapter.scenes.0 terminated with code 0 (NO_ERROR)
            2023-07-27 20:27:06.037 - info: hm-rega.0 (522) terminating with timeout
            2023-07-27 20:27:06.144 - info: web.0 (917) terminating with timeout
            2023-07-27 20:27:06.177 - info: admin.0 (337) terminating with timeout
            2023-07-27 20:27:06.210 - info: host.ioBrokerTestsystem stopInstance system.adapter.admin.0 killing pid 337
            2023-07-27 20:27:06.564 - info: host.ioBrokerTestsystem instance system.adapter.scheduler.0 terminated with code 0 (NO_ERROR)
            2023-07-27 20:27:06.571 - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rega.0 killing pid 522
            2023-07-27 20:27:06.573 - info: host.ioBrokerTestsystem stopInstance system.adapter.web.0 killing pid 917
            2023-07-27 20:27:08.661 - info: host.ioBrokerTestsystem instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
            2023-07-27 20:27:08.884 - info: host.ioBrokerTestsystem instance system.adapter.fritzbox.0 terminated with code 0 (NO_ERROR)
            2023-07-27 20:27:08.886 - info: host.ioBrokerTestsystem instance system.adapter.samsung-community.0 terminated with code 0 (NO_ERROR)
            2023-07-27 20:27:09.007 - info: host.ioBrokerTestsystem instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
            2023-07-27 20:27:09.009 - info: host.ioBrokerTestsystem instance system.adapter.unifi.0 terminated with code 0 (NO_ERROR)
            2023-07-27 20:27:09.052 - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
            2023-07-27 20:27:09.159 - info: host.ioBrokerTestsystem instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
            2023-07-27 20:27:09.160 - info: host.ioBrokerTestsystem instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
            2023-07-27 20:27:09.279 - info: host.ioBrokerTestsystem instance system.adapter.nina.0 terminated with code 0 (NO_ERROR)
            2023-07-27 20:27:09.281 - info: host.ioBrokerTestsystem instance system.adapter.proxmox.0 terminated with code 0 (NO_ERROR)
            2023-07-27 20:27:09.343 - info: host.ioBrokerTestsystem instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
            2023-07-27 20:27:09.508 - info: host.ioBrokerTestsystem instance system.adapter.tankerkoenig.0 terminated with code 0 (NO_ERROR)
            2023-07-27 20:27:09.509 - info: host.ioBrokerTestsystem instance system.adapter.trashschedule.0 terminated with code 0 (NO_ERROR)
            2023-07-27 20:27:09.586 - info: host.ioBrokerTestsystem instance system.adapter.valloxmv.0 terminated with code 0 (NO_ERROR)
            2023-07-27 20:27:09.587 - info: host.ioBrokerTestsystem instance system.adapter.device-watcher.0 terminated with code 0 (NO_ERROR)
            2023-07-27 20:27:09.653 - info: host.ioBrokerTestsystem instance system.adapter.vis-2-beta.0 terminated with code 0 (NO_ERROR)
            2023-07-27 20:27:09.758 - info: host.ioBrokerTestsystem instance system.adapter.vis-inventwo.0 terminated with code 0 (NO_ERROR)
            2023-07-27 20:27:09.760 - info: host.ioBrokerTestsystem All instances are stopped.
            2023-07-27 20:27:09.763 - warn: host.ioBrokerTestsystem instance system.adapter.admin.0 terminated due to SIGTERM
            2023-07-27 20:27:09.764 - info: host.ioBrokerTestsystem instance system.adapter.admin.0 terminated with code null ()
            2023-07-27 20:27:09.765 - info: host.ioBrokerTestsystem All instances are stopped.
            2023-07-27 20:27:10.054 - warn: host.ioBrokerTestsystem instance system.adapter.hm-rega.0 terminated due to SIGTERM
            2023-07-27 20:27:10.055 - info: host.ioBrokerTestsystem instance system.adapter.hm-rega.0 terminated with code null ()
            2023-07-27 20:27:10.056 - info: host.ioBrokerTestsystem All instances are stopped.
            2023-07-27 20:27:10.098 - warn: host.ioBrokerTestsystem instance system.adapter.web.0 terminated due to SIGTERM
            2023-07-27 20:27:10.099 - info: host.ioBrokerTestsystem instance system.adapter.web.0 terminated with code null ()
            2023-07-27 20:27:10.100 - info: host.ioBrokerTestsystem All instances are stopped.
            2023-07-27 20:27:10.195 - info: host.ioBrokerTestsystem terminated
            2023-07-27 20:27:14.476 - info: host.ioBrokerTestsystem [CONTROLLER_AUTO_UPGRADE] Successfully stopped js-controller
            2023-07-27 20:27:14.490 - info: host.ioBrokerTestsystem [CONTROLLER_AUTO_UPGRADE] Server is running on http://localhost:8081
            2023-07-27 20:40:16.918 - info: host.ioBrokerTestsystem iobroker.js-controller version 5.0.8 js-controller starting
            2023-07-27 20:40:16.931 - info: host.ioBrokerTestsystem Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
            2023-07-27 20:40:16.934 - info: host.ioBrokerTestsystem hostname: ioBrokerTestsystem, node: v18.17.0
            2023-07-27 20:40:16.937 - info: host.ioBrokerTestsystem ip addresses: 192.168.178.77 fe80::f854:cfff:fe5f:6c25
            2023-07-27 20:40:20.323 - info: host.ioBrokerTestsystem connected to Objects and States
            2023-07-27 20:40:20.418 - info: host.ioBrokerTestsystem added notifications configuration of host
            2023-07-27 20:40:21.798 - info: host.ioBrokerTestsystem Delete state "system.host.ioBrokerTestsystem.versions.nodeCurrent"
            2023-07-27 20:40:21.802 - info: host.ioBrokerTestsystem 63 instances found
            2023-07-27 20:40:21.935 - info: host.ioBrokerTestsystem starting 33 instances
            • foxriver76
              foxriver76 Developer @Feuersturm last edited by
              @feuersturm hm ok dann haben wir in 5.0.8 irgendwas kaputt gemacht, schauen wir uns an.
              • NinjaTurtle85
                NinjaTurtle85 last edited by
                Ich kann seid dem Upgrade auf 5.0.9 keine Datenpunkte mehr in 0_userdata erstellen.
                  A Former User @NinjaTurtle85 last edited by A Former User
                  @ninjaturtle85 sagte in js-controller 5.0.x jetzt in der BETA:
                  Stimmt, ist hier auch so, Browser Safari, das Popup kommt, ich Füll es aus, aber es lässt sich nur mit abbrechen schließen..
                  Issue erstellt https://github.com/ioBroker/ioBroker.js-controller/issues/2364
                  Ilovegym66 created this issue in ioBroker/ioBroker.js-controller
                  closed 5.0.9 - can't add Objects in userdata #2004
                  • foxriver76
                    foxriver76 Developer @Guest last edited by
                    @ilovegym Liegt mit 99 % Wahrscheinlichkeit am Admin Update
                    • DJMarc75
                      DJMarc75 last edited by
                      @NinjaTurtle85 @ilovegym @foxriver76
                      eben auch auf die Admin 6.6.3 gehoben und da scheint das Problem zu liegen - keine neuen Datenpunkte unter
                      0_userdata
                      erstellbar.
                      Zurück zu 6.6.1 - geht wieder
                      • ESP8266
                        ESP8266 last edited by
                        @djmarc75 , kann ich bestätigen.
                        • Feuersturm
                          Manuelles update auf 5.0.9 war auf meinem Master + Slave erfolgreich. Bisher keine Auffälligkeiten.
                          • foxriver76
                            5.0.10 auf dem Weg
                            • Fixt das UI Upgrade Problem, wie gewohnt allerdings dann erst auf eine Folgeversion, sprich 5.0.8/5.0.9 auf 5.0.10 wird nicht via UI gehen
                            • Verbessertes Logging wenn der UI Upgrade Prozess crasht
                            • Für Devs: Die offiziellen Types von adapter-core Version 3 werden nun aus dem Controller direkt genommen, bei Problemen bitte im Controller ein Issue anlegen
                            ? 1 Reply Last reply Reply Quote 3
                              A Former User @foxriver76 last edited by
                              @foxriver76 sagte in js-controller 5.0.x jetzt in der BETA:
                              5.0.10 auf dem Weg
                              Moin,
                              bei mir wieder das gleiche Verhalten, wie beim Update von 5.0.8 -> 5.0.9
                              [iobroker@arch-iob iobroker]$ tail -f log/iobroker.current.log
                              2023-07-29 10:45:53.318  - warn: host.arch-iob instance system.adapter.web.0 terminated due to SIGTERM
                              2023-07-29 10:45:53.318  - info: host.arch-iob instance system.adapter.web.0 terminated with code null ()
                              2023-07-29 10:45:53.347  - info: host.arch-iob instance system.adapter.zigbee2mqtt.0 terminated with code 0 (NO_ERROR)
                              2023-07-29 10:45:55.181  - info: meross.0 (15291) terminating
                              2023-07-29 10:45:55.182  - info: meross.0 (15291) Terminated (NO_ERROR): Without reason
                              2023-07-29 10:45:55.729  - info: host.arch-iob instance system.adapter.meross.0 terminated with code 0 (NO_ERROR)
                              2023-07-29 10:45:55.729  - info: host.arch-iob All instances are stopped.
                              2023-07-29 10:45:55.805  - info: host.arch-iob terminated
                              2023-07-29 10:45:59.869  - info: host.arch-iob [CONTROLLER_AUTO_UPGRADE] Successfully stopped js-controller
                              2023-07-29 10:45:59.874  - info: host.arch-iob [CONTROLLER_AUTO_UPGRADE] Server is running on http://localhost:8081
                              [iobroker@arch-iob iobroker]$ iob stop
                              [iobroker@arch-iob iobroker]$ iob update
                              Used repository: live-beta
                              Adapter    "admin"        : 6.6.4    , installed 6.6.4
                              Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
                              Adapter    "device-watcher": 2.9.3   , installed 2.9.3
                              Adapter    "esphome"      : 0.2.4    , installed 0.2.4
                              Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                              Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                              Adapter    "hoover"       : 0.1.0    , installed 0.1.0
                              Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                              Adapter    "iqontrol"     : 2.3.0    , installed 3.0.0-alpha0.1
                              Adapter    "javascript"   : 7.1.1    , installed 7.1.1
                              Controller "js-controller": 5.0.10   , installed 5.0.9  [Updatable]
                              Adapter    "meross"       : 1.15.1   , installed 1.15.1
                              Adapter    "mpd"          : 1.1.1    , installed 1.1.1
                              Adapter    "openweathermap": 0.3.11  , installed 0.3.11
                              Adapter    "snmp"         : 2.4.11   , installed 2.4.11
                              Adapter    "socketio"     : 6.4.0    , installed 6.4.0
                              Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
                              Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                              Adapter    "synochat"     : 1.3.0    , installed 1.3.0
                              Adapter    "tapo"         : 0.0.8    , installed 0.0.8
                              Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                              Adapter    "vw-connect"   : 0.0.72   , installed 0.0.72
                              Adapter    "web"          : 6.0.3    , installed 6.0.3
                              Adapter    "wolf-smartset": 1.1.1    , installed 1.1.1
                              Adapter    "ws"           : 2.4.0    , installed 2.4.0
                              Adapter    "zigbee2mqtt"  : 2.9.0    , installed 2.9.0
                              [iobroker@arch-iob iobroker]$ iob upgrade self
                              Update js-controller from @5.0.9 to @5.0.10
                              Stopped Objects DB
                              Stopped States DB
                              NPM version: 9.8.1
                              Installing iobroker.js-controller@5.0.10... (System call)
                              changed 12 packages in 30s
                              85 packages are looking for funding
                                run `npm fund` for details
                              [iobroker@arch-iob iobroker]$ iob start
                              Nach Update per Konsole/Terminal alles ok.
                              VG
                              Bernd
                              P.S.: ist vielleicht aber nur mein Problem, da ich nicht Debian, sondern Arch Linux nutze.
                              P.P.S.: Infos zum System
                                  Plattform: linux
                                  Betriebssystem: linux
                                  Architektur: x64
                                  CPUs: 4
                                  Geschwindigkeit: 3200 MHz
                                  Modell: AMD Phenom(tm) II X4 955 Processor
                                  RAM: 4 GB
                                  System-Betriebszeit: 2 T. 18:14:28
                                  Node.js: v18.16.0
                                  time: 1690620931252
                                  timeOffset: -120
                                  Adapter-Anzahl: 578
                                  NPM: 9.8.1
                                  Datenträgergröße: 8.0 GB
                                  Freier Festplattenspeicher: 4.9 GB
                                  Betriebszeit: 00:03:57
                                  Aktive Instanzen: 21
                                  Pfad: /opt/iobroker/
                                  aktiv:
                              • foxriver76
                                @dp20eic gerne lesen was da sonst noch steht außer „1.0.20 auf dem Weg“ vielleicht erklärt es dir ja das Verhalten
                                  Vertipper? 🙂
                                  • foxriver76
                                    foxriver76 Developer @ticaki last edited by
                                    @ticaki Ups da war ich irgendwo bei der App Version in der Nähe 😄
                                    • ESP8266
                                      ESP8266 last edited by ESP8266
                                      Ich habe in letzter Zeit immer mehr das Problem, das sich die Sidebar nicht aufbaut und leer bleibt, weil ein Timeout abgelaufen ist. Bei der zigsten Brouser aktualisierung klapp es dann mal wieder. Es wird langsam zum Glücksspiel.
                                      Edit: Ich besitze keine Hochleistungrechner.
                                        A Former User @ESP8266 last edited by
                                        @esp8266
                                        Redis, JSON oder file?
                                        Version von Admin ?
                                        • ESP8266
                                          @ilovegym , einfach das öffnen von iob im Brouser. Egal welche Sitzung ich hatte. Javascript, Objekte, Logs etc.
                                          Admin 6.6.1
                                          Wenn alles da ist, ich mich im Hauptfenster bewege und zwischen den Ojekten, Instanzen, Javascript switche, gibt es keine Probleme. Nur beim Aktualiseren der Seite mit F5 etc.
                                          Das ganze passiert meistens auch, wenn ich die Rechner gerade hoch gefahren habe. Der Hauptrecher hängt am GB Lan und Schleppi im 5GHz Wlan.
                                          Es ist nicht immer aber sporadisch und wird in letzer Zeit immer heftiger. Manchmal braucht es bis zu 10 Aktualisierungen. Es erschient immer ein Timeout. Das muss man doch irgendwo einstellen können.
                                          und die linke Spalte bleibt dann leer.
                                          Gerade eins Ertappt.
                                          amg_666 ESP8266 2 Replies Last reply Reply Quote 0
                                          • amg_666
                                            amg_666 @ESP8266 last edited by
                                            Update von 5.0.8 auf 5.0.10 über Admin-Oberfläche klappt bei mir nicht.
                                            iob multihost, update auf dem Slave (pi 3b) hat funktioniert. Update des Masters bringt immer die Fehlermeldung
                                            und danach passiert nix mehr. Ich habe das mehrfach versucht, dachte dass da vielleicht temporär was klemmt, komme aber immer wieder auf das Ergebnis.
                                            Wenn ich den iob dann über Konsole neu starte läuft er wieder, aber eben noch mit 5.0.8
                                            iob auf proxmox container (debian12), node.js 18.17.0, npm 9.6.7, der raspberry slave hat denselben Stand.
                                            580
                                            184934
