    3. Off Topic
    4. ConBee2 auf Raspi 4 umziehen [gelöst]
    • I
      ichwersonst @Thomas Braun last edited by
      pi@raspberrypi:~ $ apt policy deconz
      deconz:
        Installed: 2.22.02-raspbian-buster-stable
        Candidate: 2.22.02-raspbian-buster-stable
        Version table:
       *** 2.22.02-raspbian-buster-stable 500
              500 http://phoscon.de/apt/deconz bullseye/main armhf Packages
              100 /var/lib/dpkg/status
      pi@raspberrypi:~ $ systemctl status deconz*
      ● deconz-update.service - deCONZ: ZigBee gateway -- Update Service
           Loaded: loaded (/lib/systemd/system/deconz-update.service; disabled; vendor preset: enabled)
           Active: active (running) since Fri 2023-07-28 17:00:27 CEST; 27min ago
         Main PID: 403 (deCONZ-update2.)
            Tasks: 2 (limit: 3932)
              CPU: 26.548s
           CGroup: /system.slice/deconz-update.service
                   ├─ 403 /bin/bash /usr/bin/deCONZ-update2.sh
                   └─4797 sleep 10
      Jul 28 17:00:27 raspberrypi systemd[1]: Started deCONZ: ZigBee gateway -- Update Service.
      Jul 28 17:00:38 raspberrypi deCONZ-update2.sh[403]: found deCONZ port 80
      Jul 28 17:00:38 raspberrypi deCONZ-update2.sh[403]: use database file /home/pi/.local/share/dresden-elektronik/deCONZ/zll.db
      Jul 28 17:00:38 raspberrypi deCONZ-update2.sh[403]: process update state allreadytoinstall
      ● deconz-wifi.service - deCONZ: ZigBee gateway -- WIFI Service
           Loaded: loaded (/lib/systemd/system/deconz-wifi.service; enabled; vendor preset: enabled)
         Main PID: 404 (deCONZ-WIFI2.sh)
              CPU: 1min 23.458s
           CGroup: /system.slice/deconz-wifi.service
                   ├─ 404 /bin/bash /usr/bin/deCONZ-WIFI2.sh
                   └─5050 sleep 1
      Jul 28 17:00:27 raspberrypi systemd[1]: Started deCONZ: ZigBee gateway -- WIFI Service.
      Jul 28 17:00:42 raspberrypi deCONZ-WIFI2.sh[1244]: command failed: Network is down (-100)
      ● deconz.service - deCONZ: ZigBee gateway -- REST API
           Loaded: loaded (/lib/systemd/system/deconz.service; enabled; vendor preset: enabled)
         Main PID: 406 (deCONZ)
            Tasks: 5 (limit: 3932)
              CPU: 1min 7.592s
           CGroup: /system.slice/deconz.service
                   └─406 /usr/bin/deCONZ -platform minimal --http-port=80
        Thomas Braun Most Active @ichwersonst last edited by
        @ichwersonst
        Über die phoscon app im Browser kommst du an die Geräte ran?
        • I
          leider nein ... wenn ich auf Geräte einlernen gehe passiert nichts.
          Wirkt fast so als wäre der Stick noch nicht empfangsbereit...
            @ichwersonst
            Dann kann der deconz-Adapter da auch nix reißen.
            I 2 Replies Last reply Reply Quote 0
            • I
              genau ... der stick findet meine Geräte nicht
              • I
                aber am alten 3b+ geht er ohne Probleme
                  @ichwersonst sagte in ConBee2 auf Raspi 4 umziehen:
                  Und das heißt?
                  • I
                    das der Stick schon mal nicht kaputt ist und es nicht an dem liegt
                      @ichwersonst
                      Das hat auch keiner behauptet.
                      iob diag
                      in der Langfassung?
                      Und schalt den Desktop-Scheiß zuvor aus!
                      • I
                        mit welchen befehl mache ich das den desktop ausschalten?
                        • I
                          ichwersonst @Thomas Braun last edited by Homoran
                          Skript v.2023-04-16
                          *** BASE SYSTEM ***
                          Model           : Raspberry Pi 4 Model B Rev 1.5
                          Architecture    : aarch64
                          Docker          : false
                          Virtualization  : none
                          Distributor ID: Raspbian
                          Description:    Raspbian GNU/Linux 11 (bullseye)
                          Release:        11
                          Codename:       bullseye
                          PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
                          NAME="Raspbian GNU/Linux"
                          VERSION_ID="11"
                          VERSION="11 (bullseye)"
                          VERSION_CODENAME=bullseye
                          ID=raspbian
                          ID_LIKE=debian
                          HOME_URL="http://www.raspbian.org/"
                          SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                          BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                          Systemuptime and Load:
                           17:43:22 up 42 min,  3 users,  load average: 0.68, 0.60, 0.56
                          CPU threads: 4
                          Raspberry only:
                          throttled=0x0
                          Other values than 0x0 hint to temperature/voltage problems
                          temp=50.1'C
                          volt=0.9260V
                          *** Time and Time Zones ***
                                         Local time: Fri 2023-07-28 17:43:22 CEST
                                     Universal time: Fri 2023-07-28 15:43:22 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          *** User and Groups ***
                          pi
                          /home/pi
                          pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                          *** X-Server-Setup ***
                          X-Server:       true
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            3.8G        884M        1.9G         35M        1.0G        2.8G
                          Swap:            99M          0B         99M
                          Total:          3.9G        884M        2.0G
                                   3793 M total memory
                                    884 M used memory
                                   1358 M active memory
                                    383 M inactive memory
                                   1870 M free memory
                                     49 M buffer memory
                                    987 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /dev/root      ext4       56G  5.6G   48G  11% /
                          devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                          tmpfs          tmpfs     759M  1.3M  758M   1% /run
                          /dev/sda1      vfat      253M   51M  202M  20% /boot
                          tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
                          [Fri Jul 28 17:00:33 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:37:DD:BE vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2a31fda3-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                          [Fri Jul 28 17:00:36 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                          [Fri Jul 28 17:00:36 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                          [Fri Jul 28 17:00:38 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                          Show mounted filesystems (real ones only):
                          TARGET  SOURCE    FSTYPE OPTIONS
                          /       /dev/sda2 ext4   rw,noatime
                          `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                          /var:
                          814M    /var/
                          399M    /var/log
                          393M    /var/log/journal/5530f3d80baf4cc0bb1ed682675aa129
                          191M    /var/cache
                          Archived and active journals take up 392.0M in the file system.
                          /opt/iobroker/backups:
                          37M     /opt/iobroker/backups/
                          /opt/iobroker/iobroker-data:
                          314M    /opt/iobroker/iobroker-data/
                          271M    /opt/iobroker/iobroker-data/files
                          88M     /opt/iobroker/iobroker-data/files/echarts.admin
                          57M     /opt/iobroker/iobroker-data/files/echarts
                          52M     /opt/iobroker/iobroker-data/files/javascript.admin
                          31M     /opt/iobroker/iobroker-data/states.jsonl
                          23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
                          23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
                          23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
                          17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b04901d.js.map
                          *** NodeJS-Installation ***
                          /usr/bin/nodejs         v18.17.0
                          /usr/bin/node           v18.17.0
                          /usr/bin/npm            9.6.7
                          /usr/bin/npx            9.6.7
                          nodejs:
                            Installed: 18.17.0-deb-1nodesource1
                            Candidate: 18.17.0-deb-1nodesource1
                            Version table:
                           *** 18.17.0-deb-1nodesource1 500
                                  500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
                               12.22.12~dfsg-1~deb11u4 500
                                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                  500 http://deb.debian.org/debian bullseye-proposed-updates/main armhf Packages
                          No problems detected
                          *** ioBroker-Installation ***
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          MULTIHOSTSERVICE/enabled: false
                          Core adapters versions
                          js-controller:  4.0.24
                          admin:          6.3.5
                          javascript:     7.0.3
                          Adapters from github:   0
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                          + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
                          + system.adapter.broadlink2.1             : broadlink2            : raspberrypi                              -  enabled
                          + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
                            system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
                          + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                            system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
                          + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                          + system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              -  enabled
                          + system.adapter.pushbullet.0             : pushbullet            : raspberrypi                              -  enabled
                          + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
                          + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                          + system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              -  enabled
                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
                            system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                            system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                          + system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              -  enabled
                          + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
                          + instance is alive
                          ioBroker-Repositories
                          Active repo(s): stable
                          Installed ioBroker-Instances
                          Used repository: stable
                          Adapter    "admin"        : 6.3.5    , installed 6.3.5
                          Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                          Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                          Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                          Adapter    "echarts"      : 1.5.1    , installed 1.5.1
                          Adapter    "history"      : 2.2.4    , installed 2.2.4
                          Adapter    "info"         : 1.9.26   , installed 1.9.26
                          Adapter    "javascript"   : 7.0.3    , installed 7.0.3
                          Controller "js-controller": 4.0.24   , installed 4.0.24
                          Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
                          Adapter    "pushbullet"   : 0.0.11   , installed 0.0.11
                          Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                          Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                          Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
                          Adapter    "vis"          : 1.4.16   , installed 1.4.16
                          Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                          Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
                          Adapter    "wled"         : 0.6.7    , installed 0.6.7
                          Objects and States
                          Objects:        4231
                          States:         3203
                          Hit:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease
                          Hit:2 http://phoscon.de/apt/deconz bullseye InRelease
                          Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                          Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
                          Reading package lists...
                          Pending Updates: 0
                          *** Listening Ports ***
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16690      570/iobroker.js-con
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16221      570/iobroker.js-con
                          tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15946      585/vncserver-x11-c
                          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14029      560/cupsd
                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       20844      1673/io.shelly.0
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12952      596/sshd: /usr/sbin
                          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       12988      406/deCONZ
                          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       16541      406/deCONZ
                          tcp6       0      0 :::5900                 :::*                    LISTEN      0          15945      585/vncserver-x11-c
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18185      1011/io.admin.0
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21697      1930/io.web.0
                          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14028      560/cupsd
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          12954      596/sshd: /usr/sbin
                          udp        0      0 0.0.0.0:47627           0.0.0.0:*                           1001       20952      1752/io.broadlink2.
                          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14052      616/cups-browsed
                          udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       23689      2046/io.broadlink2.
                          udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       18361      1752/io.broadlink2.
                          udp        0      0 0.0.0.0:47976           0.0.0.0:*                           1001       18365      1752/io.broadlink2.
                          udp        0      0 0.0.0.0:37808           0.0.0.0:*                           108        15333      399/avahi-daemon: r
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       23555      1834/io.wled.0
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15331      399/avahi-daemon: r
                          udp        0      0 0.0.0.0:52584           0.0.0.0:*                           1001       21248      2046/io.broadlink2.
                          udp        0      0 0.0.0.0:44635           0.0.0.0:*                           1001       18364      1752/io.broadlink2.
                          udp        0      0 0.0.0.0:55030           0.0.0.0:*                           1001       22945      2046/io.broadlink2.
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       86348      23134/io.deconz.0
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       13093      406/deCONZ
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16606      506/dhcpcd
                          udp        0      0 0.0.0.0:51595           0.0.0.0:*                           1001       21249      2046/io.broadlink2.
                          udp6       0      0 :::5353                 :::*                                108        15332      399/avahi-daemon: r
                          udp6       0      0 :::1900                 :::*                                1001       86350      23134/io.deconz.0
                          udp6       0      0 :::1900                 :::*                                1001       86349      23134/io.deconz.0
                          udp6       0      0 :::51200                :::*                                108        15334      399/avahi-daemon: r
                          2023-07-28 17:09:41.943  - info: host.raspberrypi stopInstance system.adapter.deconz.0 send kill signal
                          2023-07-28 17:09:42.434  - info: host.raspberrypi instance system.adapter.deconz.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2023-07-28 17:09:44.991  - info: host.raspberrypi instance system.adapter.deconz.0 started with pid 23134
                          2023-07-28 17:09:47.612  - info: deconz.0 (23134) starting. Version 1.3.21 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.17.0, js-controller: 4.0.24
                          2023-07-28 17:09:47.749  - info: deconz.0 (23134) deConz Version: 2.22.2; API version: 1.16.0
                          2023-07-28 17:31:23.633  - error: vw-connect.0 (1795) Restart adapter
                          2023-07-28 17:31:23.634  - warn: vw-connect.0 (1795) Restart initiated
                          2023-07-28 17:31:23.636  - info: vw-connect.0 (1795) cleaned everything up...
                          2023-07-28 17:31:23.647  - info: vw-connect.0 (1795) terminating
                          2023-07-28 17:31:23.649  - info: vw-connect.0 (1795) Terminated (NO_ERROR): Without reason
                          2023-07-28 17:31:24.253  - info: host.raspberrypi instance system.adapter.vw-connect.0 terminated with code 0 (NO_ERROR)
                          2023-07-28 17:31:24.256  - info: host.raspberrypi Restart adapter system.adapter.vw-connect.0 because enabled
                          2023-07-28 17:31:54.305  - info: host.raspberrypi instance system.adapter.vw-connect.0 started with pid 16709
                          2023-07-28 17:31:57.695  - info: vw-connect.0 (16709) starting. Version 0.0.67 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v18.17.0, js-controller: 4.0.24
                          2023-07-28 17:31:57.741  - info: vw-connect.0 (16709) Login in with skoda
                          2023-07-28 17:31:59.705  - warn: vw-connect.0 (16709) /signin-service/v1/...
                          2023-07-28 17:31:59.705  - warn: vw-connect.0 (16709) No valid userid, please check username and password or visit this link or logout and login in your app account:
                          2023-07-28 17:31:59.706  - warn: vw-connect.0 (16709) Bitte in die App einloggen und die Nutzungsbedingungen akzeptieren.
                          2023-07-28 17:31:59.707  - warn: vw-connect.0 (16709) https://identity....
                          2023-07-28 17:31:59.707  - warn: vw-connect.0 (16709) Try to auto accept new consent
                          2023-07-28 17:31:59.715  - error: vw-connect.0 (16709) Login Failed
                          2023-07-28 17:31:59.715  - error: vw-connect.0 (16709) Restart Adapter in 30min
                          2023-07-28 17:32:00.106  - error: vw-connect.0 (16709) Error in consent form
                          2023-07-28 17:32:00.107  - error: vw-connect.0 (16709) SyntaxError: Unexpected token c in JSON at position 1430
                          2023-07-28 17:34:59.399  - warn: deconz.0 (23134) State "deconz.0.Sensors.22.buttonpressed" has no existing object, this might lead to an error in future versions
                            @ichwersonst
                            sudo raspi-config
                            Dann dort:
                            1 System Options
                            S5 Boot / Auto Login
                            B1 Console
                              Da läuft der Adapter doch. Zur Konfiguration kann ich dir nix sagen, hab den nicht in Benutzung.
                              • I
                                okay gemacht...
                                bevor ich den ausgeschalten hatte ist mir noch auf dem desktop was aufgefallen :
                                beim 3b+ erscheint der stick mit bei der Interfaceauswahl
                                  @ichwersonst
                                  Desktop-Geraffel ist per se uninteressant.
                                  • I
                                    hmm dann muss ich weiter das internet durchforsten um da noch auf einen grünen zweig zu kommen.
                                    danke trotzdem erstmal 🙂
                                      @ichwersonst
                                      Hast du denn Objects zu dem Adapter?
                                      • I
                                        jup hab die objects ausm iob vom 3b+ exportiert und hier im iob 4b importiert
                                        • I
                                          und hab auch die stick config exportiert um sie im 4b wieder zu importieren .... also sämtliche dinge die im webinterface einzustellen sind
                                            @ichwersonst
                                            Häh?
                                            Die Objekte werden vom Adapter zur Laufzeit angelegt...
                                            Was haste denn da kopiert?
                                            1956
