[gelöst] Iobroker Deamon stoppt laufend - nach JS Update
So….hier mal ein Update....
IoBroker Log unter /opt/iobroker/logs
! 2017-10-16 14:00:27.320 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-16 14:00:27.320 - [32minfo[39m: harmony.0 client ended: Harmony_Hub
! 2017-10-16 14:00:31.129 - [32minfo[39m: harmony.0 keep alive failed: Error: Timed out after 5000 ms
! 2017-10-16 14:00:41.214 - [33mwarn[39m: harmony.0 could not connect to Harmony Hub: Error: Timed out after 5000 ms
! 2017-10-16 14:00:54.373 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-16 14:00:54.387 - [32minfo[39m: harmony.0 connecting to Harmony Hub
! 2017-10-16 14:00:57.940 - [32minfo[39m: harmony.0 connected to Harmony Hub
! 2017-10-16 14:00:59.156 - [32minfo[39m: harmony.0 synced hub config
! 2017-10-16 14:01:57.521 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-16 14:01:57.521 - [32minfo[39m: harmony.0 client ended: Harmony_Hub
! 2017-10-16 14:01:58.641 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-16 14:02:05.750 - [32minfo[39m: harmony.0 connecting to Harmony Hub
! 2017-10-16 14:02:08.071 - [32minfo[39m: harmony.0 connected to Harmony Hub
! 2017-10-16 14:02:09.394 - [32minfo[39m: harmony.0 synced hub config
! 2017-10-16 14:03:00.044 - [32minfo[39m: host.IoBroker instance system.adapter.dwd.0 started with pid 1460
! 2017-10-16 14:03:00.433 - [32minfo[39m: dwd.0 starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.dwd, node: v4.7.2
! 2017-10-16 14:03:01.175 - [32minfo[39m: host.IoBroker instance system.adapter.dwd.0 terminated with code 0 (OK)
! 2017-10-16 14:21:42.881 - [32minfo[39m: harmony.0 keep alive failed: Error: Timed out after 5000 ms
! 2017-10-16 14:21:42.882 - [32minfo[39m: harmony.0 client ended: Harmony_Hub
! 2017-10-16 14:21:44.806 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-16 14:22:26.223 - [32minfo[39m: harmony.0 discovered Harmony Hub[/spoiler]Das Log im Admin hingegen hat den letzten Eintrag um 13:43 (siehe Bild)
Irgendwo dazwischen hat IoBroker wieder gestoppt.
Der Harmony-Adapter, welcher mir die Warnings erzeugt, bleibt jetzt erst mal ganz aus!
Ratlosigkeit geht weiter….
Update 17:40
Ohne Harmony Adapter sah es erst gut aus.
ABER…
a) Wenn ich VIS im Browser am PC offen habe, lösen View-Wechsel kein Problem aus.
b) Am Tablet (mit Vis App) löste soeben ein View-Wechsel wieder einen Absturz des Iobroker Dienstes aus.
Somit sehe ich keine direkte Abhängigkeit vom Harmony Adapter und denke gerade darüber nach ob das VIS Update hier etwas ausgelöst hat.
Alles sehr seltsam.
Habt ihr ähnliche Abstürze oder Probleme mit VIS?
So… mal wieder ein Update.
heute Morgen hat sich der IoBroker Deamon wieder selbst gestoppt.
Das Log zeigt folgendes:
host.IoBroker 2017-10-20 09:11:09.005 info instance system.adapter.admin.0 started with pid 7853
host.IoBroker 2017-10-20 09:11:08.932 info starting 19 instances
host.IoBroker 2017-10-20 09:11:08.928 info 28 instances found
host.IoBroker 2017-10-20 09:11:08.920 info InMemoryDB connected
host.IoBroker 2017-10-20 09:11:08.897 info inMem-objects listening on port 9001
host.IoBroker 2017-10-20 09:11:08.427 info inMem-states listening on port 9000
host.IoBroker 2017-10-20 09:11:00.024 info ip addresses: 192.168.0.13 fe80::20c:29ff:fea7:e65a
host.IoBroker 2017-10-20 09:11:00.023 info hostname: IoBroker, node: v4.7.2
host.IoBroker 2017-10-20 09:11:00.023 info Copyright (c) 2014-2017 bluefox, hobbyquaker
host.IoBroker 2017-10-20 09:11:00.021 info iobroker.js-controller version 1.2.0 js-controller starting
web.0 2017-10-20 09:10:41.353 info 2017-10-20T07:10:41.353Z Connected system.user.admin
harmony.0 2017-10-20 09:10:33.582 info discovered Harmony Hub
harmony.0 2017-10-20 09:09:49.132 warn lost Harmony Hub
web.0 2017-10-20 09:08:41.349 info 2017-10-20T07:08:41.349Z Connected system.user.admin
web.0 2017-10-20 09:08:41.347 info 2017-10-20T07:08:41.347Z Connected system.user.admin
web.0 2017-10-20 09:06:41.341 info 2017-10-20T07:06:41.341Z Connected system.user.admin
web.0 2017-10-20 09:06:41.340 info 2017-10-20T07:06:41.340Z Connected system.user.admin
web.0 2017-10-20 09:04:41.334 info 2017-10-20T07:04:41.334Z Connected system.user.admin
web.0 2017-10-20 09:04:41.332 info 2017-10-20T07:04:41.332Z Connected system.user.admin
web.0 2017-10-20 09:02:41.326 info 2017-10-20T07:02:41.326Z Connected system.user.admin
web.0 2017-10-20 09:02:41.324 info 2017-10-20T07:02:41.324Z Connected system.user.admin
web.0 2017-10-20 09:00:41.317 info 2017-10-20T07:00:41.317Z Connected system.user.admin
web.0 2017-10-20 09:00:41.316 info 2017-10-20T07:00:41.316Z Connected system.user.admin
web.0 2017-10-20 08:58:41.309 info 2017-10-20T06:58:41.309Z Connected system.user.admin
web.0 2017-10-20 08:58:41.309 info 2017-10-20T06:58:41.308Z Connected system.user.admin
harmony.0 2017-10-20 08:56:59.925 info discovered Harmony Hub
web.0 2017-10-20 08:56:41.304 info 2017-10-20T06:56:41.304Z Connected system.user.admin
web.0 2017-10-20 08:56:41.303 info 2017-10-20T06:56:41.303Z Connected system.user.admin
harmony.0 2017-10-20 08:56:33.929 warn lost Harmony Hub
web.0 2017-10-20 08:54:41.296 info 2017-10-20T06:54:41.296Z Connected system.user.admin
web.0 2017-10-20 08:54:41.295 info 2017-10-20T06:54:41.295Z Connected system.user.admin
web.0 2017-10-20 08:52:41.289 info 2017-10-20T06:52:41.289Z Connected system.user.admin
web.0 2017-10-20 08:50:41.281 info 2017-10-20T06:50:41.281Z Connected system.user.admin
web.0 2017-10-20 08:50:41.280 info 2017-10-20T06:50:41.280Z Connected system.user.admin
web.0 2017-10-20 08:48:41.274 info 2017-10-20T06:48:41.274Z Connected system.user.admin
web.0 2017-10-20 08:48:41.273 info 2017-10-20T06:48:41.273Z Connected system.user.admin
web.0 2017-10-20 08:46:41.266 info 2017-10-20T06:46:41.266Z Connected system.user.admin
web.0 2017-10-20 08:46:41.265 info 2017-10-20T06:46:41.265Z Connected system.user.admin
web.0 2017-10-20 08:44:41.259 info 2017-10-20T06:44:41.258Z Connected system.user.admin
web.0 2017-10-20 08:44:41.257 info 2017-10-20T06:44:41.257Z Connected system.user.admin
web.0 2017-10-20 08:42:41.250 info 2017-10-20T06:42:41.250Z Connected system.user.admin
web.0 2017-10-20 08:40:41.245 info 2017-10-20T06:40:41.245Z Connected system.user.admin
web.0 2017-10-20 08:40:41.244 info 2017-10-20T06:40:41.244Z Connected system.user.admin
harmony.0 2017-10-20 08:39:27.539 info discovered Harmony Hub
harmony.0 2017-10-20 08:38:53.759 warn lost Harmony Hub
web.0 2017-10-20 08:38:41.237 info 2017-10-20T06:38:41.237Z Connected system.user.admin
web.0 2017-10-20 08:38:41.236 info 2017-10-20T06:38:41.236Z Connected system.user.admin
web.0 2017-10-20 08:36:41.229 info 2017-10-20T06:36:41.229Z Connected system.user.admin
web.0 2017-10-20 08:36:41.228 info 2017-10-20T06:36:41.228Z Connected system.user.admin
web.0 2017-10-20 08:34:41.220 info 2017-10-20T06:34:41.220Z Connected system.user.admin
web.0 2017-10-20 08:34:41.219 info 2017-10-20T06:34:41.219Z Connected system.user.admin
web.0 2017-10-20 08:32:41.215 info 2017-10-20T06:32:41.215Z Connected system.user.admin
web.0 2017-10-20 08:30:41.210 info 2017-10-20T06:30:41.210Z Connected system.user.admin
web.0 2017-10-20 08:30:41.209 info 2017-10-20T06:30:41.209Z Connected system.user.admin
web.0 2017-10-20 08:28:41.205 info 2017-10-20T06:28:41.205Z Connected system.user.admin
web.0 2017-10-20 08:28:41.204 info 2017-10-20T06:28:41.204Z Connected system.user.admin
harmony.0 2017-10-20 08:26:55.670 info discovered Harmony Hub
web.0 2017-10-20 08:26:41.199 info 2017-10-20T06:26:41.199Z Connected system.user.admin
web.0 2017-10-20 08:26:41.198 info 2017-10-20T06:26:41.198Z Connected system.user.admin
harmony.0 2017-10-20 08:26:13.577 warn lost Harmony Hub
web.0 2017-10-20 08:24:41.193 info 2017-10-20T06:24:41.193Z Connected system.user.admin
web.0 2017-10-20 08:24:41.192 info 2017-10-20T06:24:41.192Z Connected system.user.admin
web.0 2017-10-20 08:22:41.188 info 2017-10-20T06:22:41.187Z Connected system.user.admin
web.0 2017-10-20 08:22:41.187 info 2017-10-20T06:22:41.187Z Connected system.user.admin
web.0 2017-10-20 08:20:41.182 info 2017-10-20T06:20:41.182Z Connected system.user.admin
web.0 2017-10-20 08:20:41.181 info 2017-10-20T06:20:41.181Z Connected system.user.admin
web.0 2017-10-20 08:18:41.177 info 2017-10-20T06:18:41.177Z Connected system.user.admin
web.0 2017-10-20 08:18:41.176 info 2017-10-20T06:18:41.176Z Connected system.user.admin
web.0 2017-10-20 08:16:41.170 info 2017-10-20T06:16:41.170Z Connected system.user.admin
web.0 2017-10-20 08:16:41.169 info 2017-10-20T06:16:41.169Z Connected system.user.admin
web.0 2017-10-20 08:14:41.164 info 2017-10-20T06:14:41.164Z Connected system.user.admin
harmony.0 2017-10-20 08:14:23.391 info discovered Harmony Hub
harmony.0 2017-10-20 08:13:53.465 warn lost Harmony Hub
web.0 2017-10-20 08:12:41.157 info 2017-10-20T06:12:41.156Z Connected system.user.admin
web.0 2017-10-20 08:12:41.155 info 2017-10-20T06:12:41.155Z Connected system.user.admin
web.0 2017-10-20 08:10:41.149 info 2017-10-20T06:10:41.149Z Connected system.user.admin
web.0 2017-10-20 08:10:41.147 info 2017-10-20T06:10:41.147Z Connected system.user.admin
harmony.0 2017-10-20 08:09:22.616 info discovered Harmony Hub
harmony.0 2017-10-20 08:08:48.411 warn lost Harmony Hub
web.0 2017-10-20 08:08:41.142 info 2017-10-20T06:08:41.142Z Connected system.user.admin
web.0 2017-10-20 08:08:41.141 info 2017-10-20T06:08:41.141Z Connected system.user.admin
web.0 2017-10-20 08:06:41.135 info 2017-10-20T06:06:41.135Z Connected system.user.admin
web.0 2017-10-20 08:06:41.134 info 2017-10-20T06:06:41.134Z Connected system.user.admin
web.0 2017-10-20 08:04:41.131 info 2017-10-20T06:04:41.131Z Connected system.user.admin
web.0 2017-10-20 08:04:41.130 info 2017-10-20T06:04:41.130Z Connected system.user.admin
web.0 2017-10-20 08:04:41.129 info 2017-10-20T06:04:41.129Z Connected system.user.admin
web.0 2017-10-20 08:04:41.125 info 2017-10-20T06:04:41.124Z Connected system.user.adminAb 8.04 Uhr gingen massiv viele Meldungen vom Web0 ins Log Gegen 9.08 Uhr war er dann aus und ich musste den Deamon wieder neu starten was etwa gegen 09.09 Uhr war. Habt ihr Ideen zu den Auslösern? Harmony Adapter habe ich ja am WE schon ausschließen können. Danke vorab! Gruß Sascha
Scheinbar kommen parallele Requests an. Das sagen die Logs. Und am Ende ist ja hier zu sehen das der js-controller weg ist und neu gestartet wird.
Gibt es irgendwas in den Systemlogs? Wurden vllt vom OS Prozesse gekillt weil SIe zuviel Speicher gebraucht haben?
Ich hatte die Logs im Admin und unter /iobroker/Logs verglichen. Zeigen beide das gleiche an. Der VM stehen 4Gb RAM zur Verfügung. Sollte das nicht reichen?
Die Anzahl der Clients welche via Browser oder VIS App zugreifen wird hier ja hoffentlich keine Rolle spielen, oder?
Der VM stehen 4Gb RAM zur Verfügung. Sollte das nicht reichen? `
Deine VM sagt "Access denied" zu meinem User "Glaskugel" … Keine Ahnung was die VM alles noch macht.Du musst schauen was ggf zum Zeitpunkt der Probleme im System los war.
Die Anzahl der Clients welche via Browser oder VIS App zugreifen wird hier ja hoffentlich keine Rolle spielen, oder? `
Indirekt schon. Und je nachdem was Sie tun. Wenn Flot Diagramme hast die aus History Daten abholen dann kann durchaus kurzfristig Bedarf an CPU, I/O und/oder RAM sein und wnen zuviel parallel läuft … -
Danke Apollon,
Die VM ist entspannt. Ist eine reine Debian V11 und nur IoBroker am laufen.
Der Host der VM hat nur 2 Maschinen laufen und ist nicht overcomitted -> ca. 50% der Resourcen sind zugewiesen
Thema VIS:
Ich habe 1 Tablet mit der VIS APP, ein weiteres Tablet in dem Vis im fully Kiosk Browser angezeigt wird und gelegentlich eine 3. Session im Browser am PC offen.
Flot nutze ich nicht. (noch nicht)
Aktive Adapter alle up to date und wie folgt:
Admin
Botovac
Cloud
Harmony
HM-Rega
HM-RPC
iCal
DWD
Javascript
Netatmo
Sayit
VIS
WEB
Habe der VM jetzt mal zum Test 8Gb Ram gegönnt und schaue mir das jetzt weiter an.
Interessant jedoch, dass es auch schon einen Fred gibt zum Thema JS 1.20 und danach Probleme.
Nochmals zu Erinnerung. Mein Sprung war von 0.15.3 wo alles stabil über Monate lief zu 1.20 mit diesen Problemen
Das ist natürlich komisch. Hast du nur einen Client? -
Guten Morgen Bluefox!
Bin mir jetzt nicht sicher ob ich deine Frage richtig verstehe…
1 Client? Als Client verstehe ich zum Beispiel die Ausgabegeräte wie zB ein Tablet mit Vis App.
Meinst du das?
Guten Morgen!
Wurde soeben nach dem Aufstehen wieder von Tablets ohne Anzeige begrüßt.
Heute Nacht hat er sich wieder selbst gestoppt.
anbei mal ein Auszug aus dem Log.
! 2017-10-21 00:22:48.311 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 00:23:31.742 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 00:28:28.368 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 00:29:02.623 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 00:44:33.550 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 00:45:05.242 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 00:57:48.689 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 00:58:37.980 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 01:03:48.750 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 01:04:38.923 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 01:16:08.869 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 01:16:40.087 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 01:23:48.945 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 01:24:42.412 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 01:54:34.237 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 01:55:15.699 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 01:59:39.314 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 02:00:16.749 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 02:11:54.449 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 02:12:18.606 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 02:20:09.524 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 02:20:50.078 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 02:34:52.441 - [32minfo[39m: web.0 2017-10-21T00:34:52.440Z Connected system.user.admin
! 2017-10-21 02:34:56.997 - [32minfo[39m: web.0 2017-10-21T00:34:56.997Z Connected system.user.admin
! 2017-10-21 02:38:09.769 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 02:38:53.392 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 03:11:50.159 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 03:12:28.713 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 03:17:10.201 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 03:17:59.460 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 03:22:15.281 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 03:23:00.800 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 03:29:15.381 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 03:30:00.919 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 03:30:25.847 - [32minfo[39m: cloud.0 Connection changed: DISCONNECTED3
! 2017-10-21 03:30:33.389 - [32minfo[39m: cloud.0 Connection changed: CONNECTED2
! 2017-10-21 03:30:33.514 - [32minfo[39m: cloud.0 Connection changed: CONNECTED4
! 2017-10-21 03:34:15.448 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 03:35:02.205 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 03:42:10.519 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 03:42:33.395 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 03:59:30.748 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 04:00:07.698 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 04:04:35.816 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 04:05:08.757 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 04:22:11.013 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 04:22:41.428 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 04:27:16.085 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 04:27:42.487 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 04:39:16.203 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 04:39:43.418 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 04:44:16.256 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 04:44:44.451 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 05:26:11.758 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 05:26:51.377 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 05:31:16.822 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 05:31:51.720 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 05:36:16.862 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 05:36:52.392 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 05:43:31.946 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 05:43:53.365 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 06:00:52.110 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 06:01:26.527 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 06:05:57.192 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 06:06:28.823 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 06:18:12.354 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 06:18:59.421 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 06:35:32.502 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 06:36:02.583 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 06:40:32.580 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 06:41:03.186 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 06:53:12.702 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 06:53:36.842 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 07:05:47.845 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 07:06:38.540 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 07:22:13.025 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 07:22:39.636 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 07:32:38.120 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 07:33:11.339 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 07:37:38.161 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 07:38:12.364 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 07:49:53.287 - [33mwarn[39m: harmony.0 lost Harmony Hub
! 2017-10-21 07:50:45.178 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 07:58:14.127 - [32minfo[39m: host.IoBroker iobroker.js-controller version 1.2.0 js-controller starting
! 2017-10-21 07:58:14.129 - [32minfo[39m: host.IoBroker Copyright2014-2017 bluefox, hobbyquaker
! 2017-10-21 07:58:14.129 - [32minfo[39m: host.IoBroker hostname: IoBroker, node: v4.7.2
! 2017-10-21 07:58:14.130 - [32minfo[39m: host.IoBroker ip addresses: 192.168.0.13 fe80::20c:29ff:fea7:e65a
! 2017-10-21 07:58:17.881 - [32minfo[39m: host.IoBroker inMem-states listening on port 9000
! 2017-10-21 07:58:17.946 - [32minfo[39m: host.IoBroker inMem-objects listening on port 9001
! 2017-10-21 07:58:17.950 - [32minfo[39m: host.IoBroker InMemoryDB connected
! 2017-10-21 07:58:17.955 - [32minfo[39m: host.IoBroker 28 instances found
! 2017-10-21 07:58:17.959 - [32minfo[39m: host.IoBroker starting 18 instances
! 2017-10-21 07:58:17.996 - [32minfo[39m: host.IoBroker instance system.adapter.admin.0 started with pid 2227
! 2017-10-21 07:58:18.067 - [33mwarn[39m: hm-rega.0 Reconnection to DB.
! 2017-10-21 07:58:18.106 - [33mwarn[39m: hm-rega.0 Reconnection to DB.
! 2017-10-21 07:58:18.131 - [33mwarn[39m: cloud.0 Reconnection to DB.
! 2017-10-21 07:58:18.168 - [33mwarn[39m: cloud.0 Reconnection to DB.
! 2017-10-21 07:58:18.557 - [33mwarn[39m: web.0 Reconnection to DB.
! 2017-10-21 07:58:18.783 - [33mwarn[39m: sayit.0 Reconnection to DB.
! 2017-10-21 07:58:18.969 - [32minfo[39m: cloud.0 2017-10-21T05:58:18.969Z Connected system.user.admin
! 2017-10-21 07:58:18.971 - [32minfo[39m: cloud.0 starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.cloud, node: v4.7.2
! 2017-10-21 07:58:18.974 - [32minfo[39m: cloud.0 Connecting with https://iobroker.net:10555 with "bradock_xxxxxxxxxxxxxxxxxx"
! 2017-10-21 07:58:18.975 - [32minfo[39m: cloud.0 Connection changed: DISCONNECTED3
! 2017-10-21 07:58:19.274 - [32minfo[39m: cloud.0 Connection changed: CONNECTED1
! 2017-10-21 07:58:20.337 - [31merror[39m: cloud.0 already running
! 2017-10-21 07:58:20.661 - [31merror[39m: hm-rega.0 already running
! 2017-10-21 07:58:20.681 - [33mwarn[39m: sayit.0 Reconnection to DB.
! 2017-10-21 07:58:20.669 - [33mwarn[39m: hm-rpc.0 Reconnection to DB.
! 2017-10-21 07:58:20.671 - [33mwarn[39m: web.0 Reconnection to DB.
! 2017-10-21 07:58:20.686 - [33mwarn[39m: botvac.0 Reconnection to DB.
! 2017-10-21 07:58:21.038 - [33mwarn[39m: hm-rpc.0 Reconnection to DB.
! 2017-10-21 07:58:21.185 - [32minfo[39m: sayit.0 starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.sayit, node: v4.7.2
! 2017-10-21 07:58:21.185 - [32minfo[39m: sayit.0 Upload announce mp3 files
! 2017-10-21 07:58:21.813 - [31merror[39m: sayit.0 already running
! 2017-10-21 07:58:22.006 - [33mwarn[39m: netatmo.0 Reconnection to DB.
! 2017-10-21 07:58:22.014 - [33mwarn[39m: admin.0 Reconnection to DB.
! 2017-10-21 07:58:22.063 - [32minfo[39m: host.IoBroker instance system.adapter.web.0 started with pid 2233
! 2017-10-21 07:58:22.224 - [33mwarn[39m: botvac.0 Reconnection to DB.
! 2017-10-21 07:58:23.963 - [31merror[39m: web.0 already running
! 2017-10-21 07:58:24.312 - [31merror[39m: hm-rpc.0 already running
! 2017-10-21 07:58:24.920 - [33mwarn[39m: netatmo.0 Reconnection to DB.
! 2017-10-21 07:58:25.094 - [33mwarn[39m: javascript.0 Reconnection to DB.
! 2017-10-21 07:58:25.161 - [33mwarn[39m: admin.0 Reconnection to DB.
! 2017-10-21 07:58:26.832 - [33mwarn[39m: harmony.0 Reconnection to DB.
! 2017-10-21 07:58:27.194 - [31merror[39m: javascript.0 already running
! 2017-10-21 07:58:27.456 - [31merror[39m: harmony.0 already running
! 2017-10-21 07:58:27.572 - [31merror[39m: web.0 no connection to objects DB
! 2017-10-21 07:58:27.647 - [31merror[39m: admin.0 already running
! 2017-10-21 07:58:28.805 - [32minfo[39m: botvac.0 starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.botvac, node: v4.7.2
! 2017-10-21 07:58:29.605 - [31merror[39m: botvac.0 already running
! 2017-10-21 07:58:30.242 - [31merror[39m: host.IoBroker instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
! 2017-10-21 07:58:30.242 - [32minfo[39m: host.IoBroker Restart adapter system.adapter.admin.0 because enabled
! 2017-10-21 07:58:30.269 - [32minfo[39m: host.IoBroker instance system.adapter.hm-rpc.0 started with pid 2253
! 2017-10-21 07:58:31.606 - [31merror[39m: netatmo.0 already running
! 2017-10-21 07:58:31.674 - [32minfo[39m: web.0 starting. Version 2.1.7 in /opt/iobroker/node_modules/iobroker.web, node: v4.7.2
! 2017-10-21 07:58:31.695 - [31merror[39m: host.IoBroker instance system.adapter.hm-rpc.0 terminated with code 7 (Adapter already running)
! 2017-10-21 07:58:31.695 - [32minfo[39m: host.IoBroker Restart adapter system.adapter.hm-rpc.0 because enabled
! 2017-10-21 07:58:32.827 - [32minfo[39m: vis.0 starting. Version 0.15.5 in /opt/iobroker/node_modules/iobroker.vis, node: v4.7.2
! 2017-10-21 07:58:32.924 - [32minfo[39m: web.0 socket.io server listening on port 8082
! 2017-10-21 07:58:32.924 - [32minfo[39m: web.0 http server listening on port 8082
! 2017-10-21 07:58:32.981 - [32minfo[39m: vis.0 vis license is OK.
! 2017-10-21 07:58:33.762 - [32minfo[39m: host.IoBroker instance system.adapter.vis.0 terminated while should be started once
! 2017-10-21 07:58:33.988 - [32minfo[39m: host.IoBroker instance system.adapter.hm-rega.0 started with pid 2268
! 2017-10-21 07:58:34.197 - [31merror[39m: host.IoBroker instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already running)
! 2017-10-21 07:58:34.197 - [32minfo[39m: host.IoBroker Restart adapter system.adapter.hm-rega.0 because enabled
! 2017-10-21 07:58:34.489 - [32minfo[39m: web.0 2017-10-21T05:58:34.489Z Connected system.user.admin
! 2017-10-21 07:58:37.991 - [32minfo[39m: host.IoBroker instance system.adapter.javascript.0 started with pid 2282
! 2017-10-21 07:58:38.343 - [31merror[39m: host.IoBroker instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
! 2017-10-21 07:58:38.343 - [32minfo[39m: host.IoBroker Restart adapter system.adapter.javascript.0 because enabled
! 2017-10-21 07:59:00.278 - [32minfo[39m: host.IoBroker instance system.adapter.admin.0 started with pid 2310
! 2017-10-21 07:59:00.793 - [32minfo[39m: admin.0 starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.admin, node: v4.7.2
! 2017-10-21 07:59:00.819 - [32minfo[39m: admin.0 requesting all states
! 2017-10-21 07:59:00.820 - [32minfo[39m: admin.0 requesting all objects
! 2017-10-21 07:59:01.303 - [32minfo[39m: admin.0 received all states
! 2017-10-21 07:59:01.398 - [32minfo[39m: admin.0 received all objects
! 2017-10-21 07:59:01.416 - [32minfo[39m: admin.0 http server listening on port 8081
! 2017-10-21 07:59:01.416 - [32minfo[39m: admin.0 Use link "http://localhost:8081" to configure.
! 2017-10-21 07:59:01.439 - [32minfo[39m: admin.0 Request actual repository...
! 2017-10-21 07:59:01.456 - [32minfo[39m: host.IoBroker Update repository "default" under "http://download.iobroker.net/sources-dist.json"
! 2017-10-21 07:59:01.712 - [32minfo[39m: host.IoBroker instance system.adapter.hm-rpc.0 started with pid 2320
! 2017-10-21 07:59:01.859 - [32minfo[39m: admin.0 Repository received successfully.
! 2017-10-21 07:59:01.925 - [32minfo[39m: hm-rpc.0 starting. Version 1.4.14 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v4.7.2
! 2017-10-21 07:59:01.978 - [32minfo[39m: host.IoBroker instance system.adapter.cloud.0 started with pid 2330
! 2017-10-21 07:59:02.006 - [32minfo[39m: hm-rpc.0 binrpc server is trying to listen on 192.168.0.13:2001
! 2017-10-21 07:59:02.006 - [32minfo[39m: hm-rpc.0 binrpc client is trying to connect to 192.168.0.221:2001 with ["xmlrpc_bin://192.168.0.13:2001","hm-rpc.0"]
! 2017-10-21 07:59:02.227 - [32minfo[39m: hm-rpc.0 binrpc <- system.listMethods ["hm-rpc.0"]
! 2017-10-21 07:59:02.236 - [32minfo[39m: hm-rpc.0 binrpc <- listDevices ["hm-rpc.0"]
! 2017-10-21 07:59:02.241 - [32minfo[39m: hm-rpc.0 binrpc -> 227 devices
! 2017-10-21 07:59:02.429 - [32minfo[39m: cloud.0 starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.cloud, node: v4.7.2
! 2017-10-21 07:59:02.435 - [32minfo[39m: cloud.0 Connecting with https://iobroker.net:10555 with "bradock_xxxxxxxxxxxxxxxx"
! 2017-10-21 07:59:02.532 - [32minfo[39m: hm-rpc.0 Connected
! 2017-10-21 07:59:02.545 - [32minfo[39m: cloud.0 2017-10-21T05:59:02.545Z Connected system.user.admin
! 2017-10-21 07:59:02.755 - [32minfo[39m: cloud.0 Connection changed: CONNECTED1
! 2017-10-21 07:59:04.232 - [32minfo[39m: host.IoBroker instance system.adapter.hm-rega.0 started with pid 2340
! 2017-10-21 07:59:04.427 - [32minfo[39m: hm-rega.0 starting. Version 1.6.6 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v4.7.2
! 2017-10-21 07:59:04.430 - [32minfo[39m: hm-rega.0 subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
! 2017-10-21 07:59:04.727 - [32minfo[39m: hm-rega.0 ReGaHSS 192.168.0.221 up
! 2017-10-21 07:59:04.747 - [32minfo[39m: hm-rega.0 time difference local-ccu 1s
! 2017-10-21 07:59:04.785 - [32minfo[39m: hm-rega.0 added/updated 2 favorites to enum.favorites
! 2017-10-21 07:59:04.902 - [32minfo[39m: hm-rega.0 added/updated functions to enum.functions
! 2017-10-21 07:59:04.984 - [32minfo[39m: hm-rega.0 added/updated rooms to enum.rooms
! 2017-10-21 07:59:05.195 - [32minfo[39m: hm-rega.0 renamed hm-rpc.0.LEQ0887595.1.ERROR-7_ALARM to "Atrium Tür.ERROR-7_ALARM"
! 2017-10-21 07:59:05.202 - [32minfo[39m: hm-rega.0 got 48 programs
! 2017-10-21 07:59:05.277 - [32minfo[39m: hm-rega.0 added/updated 48 programs
! 2017-10-21 07:59:05.277 - [32minfo[39m: hm-rega.0 deleted 0 programs
! 2017-10-21 07:59:05.385 - [32minfo[39m: hm-rega.0 got 15 variables
! 2017-10-21 07:59:05.447 - [32minfo[39m: hm-rega.0 added/updated 15 variables
! 2017-10-21 07:59:05.447 - [32minfo[39m: hm-rega.0 deleted 0 variables
! 2017-10-21 07:59:05.448 - [32minfo[39m: hm-rega.0 request state values
! 2017-10-21 07:59:05.689 - [32minfo[39m: admin.0 Change log subscriber state: true
! 2017-10-21 07:59:05.690 - [32minfo[39m: hm-rpc.0 system.adapter.admin.0: logging true
! 2017-10-21 07:59:05.690 - [32minfo[39m: web.0 system.adapter.admin.0: logging true
! 2017-10-21 07:59:05.691 - [32minfo[39m: hm-rega.0 system.adapter.admin.0: logging true
! 2017-10-21 07:59:05.692 - [32minfo[39m: cloud.0 system.adapter.admin.0: logging true
! 2017-10-21 07:59:05.693 - [32minfo[39m: admin.0 system.adapter.admin.0: logging true
! 2017-10-21 07:59:05.967 - [32minfo[39m: host.IoBroker instance scheduled system.adapter.dwd.0 3 * * * *
! 2017-10-21 07:59:05.984 - [32minfo[39m: host.IoBroker instance system.adapter.dwd.0 started with pid 2350
! 2017-10-21 07:59:06.259 - [32minfo[39m: dwd.0 starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.dwd, node: v4.7.2
! 2017-10-21 07:59:06.451 - [32minfo[39m: hm-rega.0 got state values
! 2017-10-21 07:59:07.123 - [32minfo[39m: host.IoBroker instance system.adapter.dwd.0 terminated with code 0 (OK)
! 2017-10-21 07:59:08.378 - [32minfo[39m: host.IoBroker instance system.adapter.javascript.0 started with pid 2360
! 2017-10-21 07:59:08.719 - [32minfo[39m: javascript.0 starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.7.2
! 2017-10-21 07:59:08.723 - [32minfo[39m: javascript.0 requesting all states
! 2017-10-21 07:59:08.723 - [32minfo[39m: javascript.0 requesting all objects
! 2017-10-21 07:59:08.918 - [32minfo[39m: javascript.0 received all states
! 2017-10-21 07:59:09.017 - [32minfo[39m: javascript.0 received all objects
! 2017-10-21 07:59:09.962 - [32minfo[39m: host.IoBroker instance scheduled system.adapter.ical.0 0,30 * * * *
! 2017-10-21 07:59:09.980 - [32minfo[39m: host.IoBroker instance system.adapter.ical.0 started with pid 2370
! 2017-10-21 07:59:10.276 - [32minfo[39m: ical.0 starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.ical, node: v4.7.2
! 2017-10-21 07:59:10.863 - [32minfo[39m: ical.0 processing URL: Termine https://calendar.google.com/calendar/ic … /basic.ics
! 2017-10-21 07:59:13.980 - [32minfo[39m: host.IoBroker instance system.adapter.netatmo.0 started with pid 2380
! 2017-10-21 07:59:14.282 - [32minfo[39m: netatmo.0 starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.netatmo, node: v4.7.2
! 2017-10-21 07:59:14.335 - [32minfo[39m: netatmo.0 Registering realtime events with https://iobroker.herokuapp.com/netatmo/
! 2017-10-21 07:59:16.399 - [32minfo[39m: host.IoBroker instance system.adapter.ical.0 terminated with code 0 (OK)
! 2017-10-21 07:59:17.979 - [32minfo[39m: host.IoBroker instance system.adapter.botvac.0 started with pid 2398
! 2017-10-21 07:59:18.354 - [32minfo[39m: botvac.0 starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.botvac, node: v4.7.2
! 2017-10-21 07:59:19.429 - [32minfo[39m: botvac.0 devices found: 1
! 2017-10-21 07:59:21.980 - [32minfo[39m: host.IoBroker instance system.adapter.sayit.0 started with pid 2408
! 2017-10-21 07:59:22.180 - [32minfo[39m: sayit.0 starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.sayit, node: v4.7.2
! 2017-10-21 07:59:22.183 - [32minfo[39m: sayit.0 Upload announce mp3 files
! 2017-10-21 07:59:22.210 - [32minfo[39m: sayit.0 All files uploaded
! 2017-10-21 07:59:25.980 - [32minfo[39m: host.IoBroker instance system.adapter.harmony.0 started with pid 2418
! 2017-10-21 07:59:26.346 - [32minfo[39m: harmony.0 starting. Version 0.7.1 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
! 2017-10-21 07:59:26.353 - [32minfo[39m: harmony.0 searching for Harmony Hubs...
! 2017-10-21 07:59:27.592 - [32minfo[39m: harmony.0 discovered Harmony Hub
! 2017-10-21 07:59:27.606 - [32minfo[39m: harmony.0 connecting to Harmony Hub
! 2017-10-21 07:59:29.946 - [32minfo[39m: harmony.0 connected to Harmony Hub
! 2017-10-21 07:59:32.756 - [32minfo[39m: harmony.0 synced hub config
! 2017-10-21 08:00:00.021 - [32minfo[39m: host.IoBroker instance system.adapter.ical.0 started with pid 2438
! 2017-10-21 08:00:00.319 - [32minfo[39m: ical.0 starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.ical, node: v4.7.2[/spoiler]Bin langsam etwas verzeifelt…
Die Harmony erzeugt zwar viele Einträge im Log, aber wurde ja schon zuvor ausgeschlossen.
Der WAF ist im Keller und der CAF (Children acceptance factor - falls es das schon gibt) wird auch massiv beeinträchtigt....
Bin kurz davor wieder auf eine steinalte Version des JS downzugraden
Update und Frage:
die letzten Tage lief es einigermaßen stabil.
Die einzigen Fehler im Log sind die bekannten Disconnects des Harmony Adapters.
Zur Frage:
Durch andere Freds bin ich auf Node JS Versionen gestoßen und habe gleich mal geprüft, was ich aktuell im Einsatz habe…
-> v4.7.2 ist aktiv :shock:
Ist ein Update in jedem Fall zu empfehlen und wie bewertet ihr das Risiko das etwas crasht?
Danke vorab!
Node Version ist ok
Du hattest hier geschrieben:
https://github.com/Pmant/ioBroker.harmo … -340259687
Aus den Logs kann ich zumindest keinen direkten Zusammenhang zwischen dem Harmony Adapter und den Abstürzen erkennen. Die Reconnects des Harmony Hubs sind ja leider bekannt, aber führen normalerweise nicht zu Abstürzen des JS-Controllers.
Hi Du,
Danke für das lesen!
Ich bin echt am verzweifeln. Hatte die letzten Tage den Harmony Adapter aus und Io lief. Jetzt wieder zugeschaltet und wieder Probleme.
Ich bin mir nicht sicher wo ich noch suchen kann.
Du könntest mal auf einem weiteren Gerät ioBroker und Harmony Adapter installieren, um zu testen, ob dort die selben Abstürze auftreten. Im Moment habe ich auch keine Idee, die Logs helfen so weit ich das sehe kaum, da dort keine konkreten Meldungen vor dem Absturz auftauchen.
Hi again,
ich werde versuchen einen Raspi auszubuddeln und dort mal zu installieren.
Evtl. hilft uns das beim analysieren.
Mal eine ganz andere Idee / Frage
kann es sein, dass der Zugriff vom PC (Firefox) auf zB Admin oder VIS den IoBroker Deamon killt?
Hier was aus dem Log:
! host.IoBroker 2017-10-30 12:30:05.724 error instance system.adapter.hm-rpc.0 terminated with code 7 (Adapter already running)
! host.IoBroker 2017-10-30 12:30:05.521 info instance system.adapter.hm-rpc.0 started with pid 3140
! web.0 2017-10-30 12:30:04.758 info 2017-10-30T11:30:04.758Z Connected system.user.admin
! host.IoBroker 2017-10-30 12:30:02.376 info stopInstance system.adapter.vis.0
! host.IoBroker 2017-10-30 12:30:02.376 info "system.adapter.vis.0" enabled
! host.IoBroker 2017-10-30 12:30:02.376 info object change system.adapter.vis.0
! host.IoBroker 2017-10-30 12:30:02.372 info stopInstance system.adapter.vis.0
! host.IoBroker 2017-10-30 12:30:02.372 info "system.adapter.vis.0" disabled
! host.IoBroker 2017-10-30 12:30:02.372 info object change system.adapter.vis.0
! vis.0 2017-10-30 12:30:02.150 info Upload vis anew, while changes detected…
! vis.0 2017-10-30 12:30:02.147 info Changes in index.html detected => update cache.manifest
! vis.0 2017-10-30 12:30:01.707 info starting. Version 0.10.15 in /opt/iobroker/node_modules/iobroker.vis, node: v4.7.2
! web.0 2017-10-30 12:29:58.867 info http server listening on port 8082
! web.0 2017-10-30 12:29:58.866 info socket.io server listening on port 8082
! web.0 2017-10-30 12:29:58.750 info starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.web, node: v4.7.2
! hm-rpc.0 2017-10-30 12:29:58.743 error already running
! hm-rpc.0 2017-10-30 12:29:58.478 warn Reconnection to DB.
! hm-rpc.0 2017-10-30 12:29:58.435 warn Reconnection to DB.
! harmony.0 2017-10-30 12:29:58.135 error already running
! harmony.0 2017-10-30 12:29:57.904 info starting. Version 0.7.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.7.2
! host.IoBroker 2017-10-30 12:29:57.703 info instance system.adapter.web.0 started with pid 3108
! botvac.0 2017-10-30 12:29:57.673 error already running
! admin.0 2017-10-30 12:29:57.277 error already running
! admin.0 2017-10-30 12:29:57.161 info starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.admin, node: v4.7.2
! botvac.0 2017-10-30 12:29:57.042 warn Reconnection to DB.
! botvac.0 2017-10-30 12:29:57.031 warn Reconnection to DB.
! admin.0 2017-10-30 12:29:57.011 warn Reconnection to DB.
! harmony.0 2017-10-30 12:29:57.005 warn Reconnection to DB.
! admin.0 2017-10-30 12:29:57.000 warn Reconnection to DB.
! harmony.0 2017-10-30 12:29:56.996 warn Reconnection to DB.
! sayit.0 2017-10-30 12:29:56.824 error already running
! hm-rega.0 2017-10-30 12:29:56.484 error already running
! netatmo.0 2017-10-30 12:29:55.715 error already running
! cloud.0 2017-10-30 12:29:55.201 error already running
! host.IoBroker 2017-10-30 12:29:54.916 info Restart adapter system.adapter.admin.0 because enabled
! host.IoBroker 2017-10-30 12:29:54.915 error instance system.adapter.admin.0 terminated with code 1 ()
! admin.0 2017-10-30 12:29:54.884 error port 8081 already in use
! host.IoBroker 2017-10-30 12:29:54.809 info Update repository "default" under "http://download.iobroker.net/sources-dist.json"
! admin.0 2017-10-30 12:29:54.791 info Request actual repository...
! admin.0 2017-10-30 12:29:54.764 info received all objects
! admin.0 2017-10-30 12:29:54.675 info received all states
! admin.0 2017-10-30 12:29:54.451 info requesting all objects
! admin.0 2017-10-30 12:29:54.450 info requesting all states
! admin.0 2017-10-30 12:29:54.430 info starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.admin, node: v4.7.2
! web.0 2017-10-30 12:29:54.420 error already running
! javascript.0 2017-10-30 12:29:54.164 error already running
! sonos.0 2017-10-30 12:29:53.996 error already running
! host.IoBroker 2017-10-30 12:29:53.535 info instance system.adapter.admin.0 started with pid 3098
! host.IoBroker 2017-10-30 12:29:53.491 info starting 19 instances
! host.IoBroker 2017-10-30 12:29:53.487 info 28 instances found
! host.IoBroker 2017-10-30 12:29:53.481 info InMemoryDB connected
! inMem-objects 2017-10-30 12:29:53.479 info listening on port 9001
! inMem-states 2017-10-30 12:29:53.416 info listening on port 9000
! host.IoBroker 2017-10-30 12:29:49.681 info ip addresses: 192.168.0.13 fe80::20c:29ff:fea7:e65a
! host.IoBroker 2017-10-30 12:29:49.681 info hostname: IoBroker, node: v4.7.2
! host.IoBroker 2017-10-30 12:29:49.681 info Copyright (c) 2014-2016 bluefox, hobbyquaker
! host.IoBroker 2017-10-30 12:29:49.679 info iobroker.js-controller version 0.15.3 js-controller starting
! harmony.0 2017-10-30 12:29:49.393 info discovered Harmony Hub
! harmony.0 2017-10-30 12:29:45.082 warn lost Harmony Hub
! harmony.0 2017-10-30 12:29:28.374 info discovered Harmony Hub
! harmony.0 2017-10-30 12:29:25.076 warn lost Harmony Hub
! harmony.0 2017-10-30 12:28:30.326 info discovered Harmony Hub
! harmony.0 2017-10-30 12:28:30.063 warn lost Harmony Hub
! harmony.0 2017-10-30 12:27:21.760 info discovered Harmony Hub
! harmony.0 2017-10-30 12:26:55.043 warn lost Harmony Hub
! harmony.0 2017-10-30 12:22:22.072 info discovered Harmony Hub
! harmony.0 2017-10-30 12:21:44.995 warn lost Harmony Hub
! harmony.0 2017-10-30 12:21:23.954 info discovered Harmony Hub
! harmony.0 2017-10-30 12:21:19.989 warn lost Harmony Hub
! harmony.0 2017-10-30 12:20:16.888 info discovered Harmony Hub
! harmony.0 2017-10-30 12:20:14.977 warn lost Harmony Hub
! harmony.0 2017-10-30 12:18:29.800 info discovered Harmony Hub
! harmony.0 2017-10-30 12:18:24.958 warn lost Harmony Hub
! harmony.0 2017-10-30 12:17:45.762 info discovered Harmony Hub
! harmony.0 2017-10-30 12:17:39.952 warn lost Harmony Hub
! harmony.0 2017-10-30 12:17:30.763 info discovered Harmony Hub
! harmony.0 2017-10-30 12:17:29.950 warn lost Harmony Hub
! harmony.0 2017-10-30 12:16:30.709 info discovered Harmony Hub
! harmony.0 2017-10-30 12:16:29.941 warn lost Harmony Hub
! harmony.0 2017-10-30 12:13:25.581 info discovered Harmony Hub
! harmony.0 2017-10-30 12:13:24.902 warn lost Harmony Hub
! harmony.0 2017-10-30 12:13:01.544 info discovered Harmony Hub
! harmony.0 2017-10-30 12:12:59.896 warn lost Harmony Hub
! harmony.0 2017-10-30 12:09:33.396 info discovered Harmony Hub
! harmony.0 2017-10-30 12:09:29.843 warn lost Harmony Hub
! harmony.0 2017-10-30 12:07:52.316 info discovered Harmony HubDer Zugriff vom PC aus erfolgte etwa um 12.29 Uhr
Weder VIS noch Admin waren im Browser aufrufbar.
Danach per Konsole geprüft:
Sieht so aus, als wenn sich der Deamon gekillt hat durch den Zugriff vom PC, oder was denkt ihr dazu???
Guten Morgen liebe Gemeinde.
da ich leider keinen Fehler finde, welcher die Abstürze des IoBroker Deamon auslöst und mittlerweile mein funktionierender Snapshot mit der JS Version 0.15.3 auch nicht mehr stabil läuft, muss ich davon ausgehen, dass etwas am OS (Debian) schief hängt.
Plan B:
Ich würde gerne eine neue VM aufsetzen und IoBroker von Grund auf neu installieren.
Danach möchte ich gerne meine "mühsam" erstellten VIS views umziehen.
Könnt ihr mir bitte helfen zu verstehen, was ich genau wegsichern muss, um mir hier Arbeit zu sparen?
Bitte bedenkt dabei, dass ich aber möglichst kein Problem mit umziehen will.
Besten Dank vorab für Eure Hilfe!
Gruß Sascha
Einmal hoch damit!
Kann mir hier bitte jemand einen Rat / Tipp geben, wie ich am besten meine VIS Views umziehe?
Habe inzwischen eine frische Debian VM mit IoBroker fertig.
Danke vorab!!!
