    4. [gelöst]Problemsuche error node-gyp ble adapter
    • coyote
      coyote Most Active @Thomas Braun last edited by
      @thomas-braun Egal wohin?
      • coyote
        @thomas-braun so, hab sie mal nach /tmp geschoben und nun?
          Thomas Braun Most Active @coyote last edited by
          @coyote
          Ja.
          sudo mv /usr/lib/python3.11/EXTERNALLY-MANAGED /usr/lib/python3.11/EXTERNALLY-MANAGEDbackup
          wird wohl schon reichen.
            @coyote
            Nicht nach /tmp. Da hast du als user eigentlich auch nix zu suchen.
            • coyote
              @thomas-braun erledigt!
              Wie gehts jetzt weiter? Bekomme beim Start des BLE Adapters immer noch:
              ble.0
              2023-07-28 18:13:45.016	error	Cannot find module '../build/Release/bluetooth_hci_socket.node' Require stack: - /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/native.js - /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/index.js - /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/lib/hci-socket/hci.js - /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/lib/hci-socket/bindings.js - /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/lib/resolve-bindings.js - /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/with-custom-binding.js - /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/index.js - /opt/iobroker/node_modules/iobroker.ble/build/scanProcess.js
                @coyote
                iob update
                iob upgrade ble@0.13.4
                • coyote
                  @thomas-braun sagte in Problemsuche error node-gyp ble adapter:
                  Gleicher Fehler
                    @coyote sagte in Problemsuche error node-gyp ble adapter:
                    Gleicher Fehler
                    Immer vollständige Ein- und Ausgaben zeigen.
                    • coyote
                      coyote@ioBroker:~$ iob update
                      Used repository: beta
                      Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/../node_modules/iobroker.lgtv/io-package.json: /opt/iobroker/node_modules/iobroker.lgtv/io-package.json: Unexpected token } in JSON at position 10582
                      Adapter    "admin"        : 6.6.4    , installed 6.6.4
                      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                      Adapter    "ble"          : 0.13.4   , installed 0.13.4
                      Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
                      Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
                      Adapter    "esphome"      : 0.2.4    , installed 0.2.4
                      Adapter    "eusec"        : 1.0.0    , installed 1.0.0
                      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                      Adapter    "frigate"      : 0.2.5    , installed 0.2.5
                      Adapter    "heatingcontrol": 2.11.0  , installed 2.11.0
                      Adapter    "history"      : 2.2.4    , installed 2.2.4
                      Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
                      Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
                      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                      Adapter    "javascript"   : 7.1.1    , installed 7.1.1
                      Controller "js-controller": 5.0.9    , installed 5.0.9
                      Adapter    "linux-control": 1.1.5    , installed 1.1.5
                      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                      Adapter    "mytime"       : 0.7.12   , installed 0.7.12
                      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                      Adapter    "opendtu"      : 0.1.7    , installed 0.1.7
                      Adapter    "operating-hours": 1.0.4  , installed 1.0.4
                      Adapter    "ph803w"       : 1.1.1    , installed 1.1.1
                      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                      Adapter    "shuttercontrol": 1.6.1   , installed 1.6.1
                      Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                      Adapter    "socketio"     : 6.4.0    , installed 6.4.0
                      Adapter    "solarmanpv"   : 0.5.0    , installed 0.5.0
                      Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
                      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                      Adapter    "unifi"        : 0.6.6    , installed 0.6.6
                      Adapter    "vis"          : 1.4.16   , installed 1.4.16
                      Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
                      Adapter    "vis-2-widgets-material": 0.8.2, installed 0.8.2
                      Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                      Adapter    "web"          : 6.0.3    , installed 6.0.3
                      Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
                      Adapter    "wled"         : 0.7.0    , installed 0.7.0
                      Adapter    "worx"         : 2.3.2    , installed 2.3.2
                      Adapter    "ws"           : 2.4.0    , installed 2.4.0
                      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                      Adapter    "zigbee"       : 1.8.18   , installed 1.8.18
                      coyote@ioBroker:~$ iob upgrade ble@0.13.4
                      Would you like to reinstall version 0.13.4 of ble now? [(y)es, (n)o]: y
                      Update ble from @0.13.4 to @0.13.4
                      NPM version: 9.6.7
                      Installing iobroker.ble@0.13.4... (System call)
                      up to date in 10s
                      158 packages are looking for funding
                        run `npm fund` for details
                      upload [5] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/.eslintrc.js .eslintrc.js application/javascript
                      upload [4] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/ble.png ble.png image/png
                      upload [3] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js build/index.js application/javascript
                      upload [2] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js.map build/index.js.map application/json
                      upload [1] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/index_m.html index_m.html text/html
                      upload [0] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/style.css style.css text/css
                        Da ist ja auch noch anderes schief...
                        coyote Homoran 2 Replies Last reply Reply Quote 0
                        • coyote
                          @thomas-braun das habe ich auch gerade erst gesehen, den Adapter habe ich gestern über die GUI deinstalliert
                            @coyote
                            cd /opt/iobroker && npm ls -a | grep ERR
                            • coyote
                              das kommt nix, Ausgabe ist leer
                                IMMER vollständige Ein- wie Ausgaben zeigen...
                                Nix nacherzählen...
                                • coyote
                                  coyote@ioBroker:~$ cd /opt/iobroker && npm ls -a | grep ERR
                                  coyote@ioBroker:/opt/iobroker$
                                    /js-controller
                                    Beta-Tester!
                                    • coyote
                                      coyote Most Active @Homoran last edited by
                                      @homoran Sicher, warum denn nicht? Schon ewig.
                                        Homoran Global Moderator Administrators @coyote last edited by
                                        @coyote es ist etwas snderes Adapter im Beta-Zustand zu testen, als in der produktiven Umgebung einen frühen Controller zu haben.
                                        • coyote
                                          @homoran ich bin mir der Sache bewusst. Backups sind genug da, kann ohne Probleme zurück. Ich will ja helfen Fehler zu finden. Habe ich beim vorherigen Controller auch gemacht.
                                          Es läuft ja auch alles soweit bisher, nur der BLE will nicht richtig bei mir.
                                            @coyote
                                            iob rebuild iobroker.ble
                                            mal versucht?
                                            Oder ganze Rolle rückwärts und Adapter deinstallieren und nochmal neu drauf.
                                            coyote 2 Replies Last reply Reply Quote 0
                                            ble adapter gyp error node error python
                                            3712
