    4. [gelöst]Problemsuche error node-gyp ble adapter
    • coyote
      coyote Most Active @Thomas Braun last edited by
      @thomas-braun so, hab sie mal nach /tmp geschoben und nun?
        Thomas Braun Most Active @coyote last edited by
        @coyote
        Ja.
        sudo mv /usr/lib/python3.11/EXTERNALLY-MANAGED /usr/lib/python3.11/EXTERNALLY-MANAGEDbackup
        wird wohl schon reichen.
          @coyote
          Nicht nach /tmp. Da hast du als user eigentlich auch nix zu suchen.
          • coyote
            @thomas-braun erledigt!
            Wie gehts jetzt weiter? Bekomme beim Start des BLE Adapters immer noch:
            ble.0
            2023-07-28 18:13:45.016	error	Cannot find module '../build/Release/bluetooth_hci_socket.node' Require stack: - /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/native.js - /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/index.js - /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/lib/hci-socket/hci.js - /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/lib/hci-socket/bindings.js - /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/lib/resolve-bindings.js - /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/with-custom-binding.js - /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/index.js - /opt/iobroker/node_modules/iobroker.ble/build/scanProcess.js
              @coyote
              iob update
              iob upgrade ble@0.13.4
              • coyote
                @thomas-braun sagte in Problemsuche error node-gyp ble adapter:
                Gleicher Fehler
                  @coyote sagte in Problemsuche error node-gyp ble adapter:
                  Gleicher Fehler
                  Immer vollständige Ein- und Ausgaben zeigen.
                  • coyote
                    coyote@ioBroker:~$ iob update
                    Used repository: beta
                    Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/../node_modules/iobroker.lgtv/io-package.json: /opt/iobroker/node_modules/iobroker.lgtv/io-package.json: Unexpected token } in JSON at position 10582
                    Adapter    "admin"        : 6.6.4    , installed 6.6.4
                    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                    Adapter    "ble"          : 0.13.4   , installed 0.13.4
                    Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
                    Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
                    Adapter    "esphome"      : 0.2.4    , installed 0.2.4
                    Adapter    "eusec"        : 1.0.0    , installed 1.0.0
                    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                    Adapter    "frigate"      : 0.2.5    , installed 0.2.5
                    Adapter    "heatingcontrol": 2.11.0  , installed 2.11.0
                    Adapter    "history"      : 2.2.4    , installed 2.2.4
                    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
                    Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
                    Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                    Adapter    "javascript"   : 7.1.1    , installed 7.1.1
                    Controller "js-controller": 5.0.9    , installed 5.0.9
                    Adapter    "linux-control": 1.1.5    , installed 1.1.5
                    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                    Adapter    "mytime"       : 0.7.12   , installed 0.7.12
                    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                    Adapter    "opendtu"      : 0.1.7    , installed 0.1.7
                    Adapter    "operating-hours": 1.0.4  , installed 1.0.4
                    Adapter    "ph803w"       : 1.1.1    , installed 1.1.1
                    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                    Adapter    "shuttercontrol": 1.6.1   , installed 1.6.1
                    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                    Adapter    "socketio"     : 6.4.0    , installed 6.4.0
                    Adapter    "solarmanpv"   : 0.5.0    , installed 0.5.0
                    Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
                    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                    Adapter    "unifi"        : 0.6.6    , installed 0.6.6
                    Adapter    "vis"          : 1.4.16   , installed 1.4.16
                    Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
                    Adapter    "vis-2-widgets-material": 0.8.2, installed 0.8.2
                    Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                    Adapter    "web"          : 6.0.3    , installed 6.0.3
                    Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
                    Adapter    "wled"         : 0.7.0    , installed 0.7.0
                    Adapter    "worx"         : 2.3.2    , installed 2.3.2
                    Adapter    "ws"           : 2.4.0    , installed 2.4.0
                    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                    Adapter    "zigbee"       : 1.8.18   , installed 1.8.18
                    coyote@ioBroker:~$ iob upgrade ble@0.13.4
                    Would you like to reinstall version 0.13.4 of ble now? [(y)es, (n)o]: y
                    Update ble from @0.13.4 to @0.13.4
                    NPM version: 9.6.7
                    Installing iobroker.ble@0.13.4... (System call)
                    up to date in 10s
                    158 packages are looking for funding
                      run `npm fund` for details
                    upload [5] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/.eslintrc.js .eslintrc.js application/javascript
                    upload [4] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/ble.png ble.png image/png
                    upload [3] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js build/index.js application/javascript
                    upload [2] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js.map build/index.js.map application/json
                    upload [1] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/index_m.html index_m.html text/html
                    upload [0] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/style.css style.css text/css
                      Da ist ja auch noch anderes schief...
                      coyote Homoran 2 Replies Last reply Reply Quote 0
                      • coyote
                        @thomas-braun das habe ich auch gerade erst gesehen, den Adapter habe ich gestern über die GUI deinstalliert
                          @coyote
                          cd /opt/iobroker && npm ls -a | grep ERR
                          • coyote
                            das kommt nix, Ausgabe ist leer
                              IMMER vollständige Ein- wie Ausgaben zeigen...
                              Nix nacherzählen...
                              • coyote
                                coyote@ioBroker:~$ cd /opt/iobroker && npm ls -a | grep ERR
                                coyote@ioBroker:/opt/iobroker$
                                  /js-controller
                                  Beta-Tester!
                                  • coyote
                                    coyote Most Active @Homoran last edited by
                                    @homoran Sicher, warum denn nicht? Schon ewig.
                                      Homoran Global Moderator Administrators @coyote last edited by
                                      @coyote es ist etwas snderes Adapter im Beta-Zustand zu testen, als in der produktiven Umgebung einen frühen Controller zu haben.
                                      • coyote
                                        @homoran ich bin mir der Sache bewusst. Backups sind genug da, kann ohne Probleme zurück. Ich will ja helfen Fehler zu finden. Habe ich beim vorherigen Controller auch gemacht.
                                        Es läuft ja auch alles soweit bisher, nur der BLE will nicht richtig bei mir.
                                          @coyote
                                          iob rebuild iobroker.ble
                                          mal versucht?
                                          Oder ganze Rolle rückwärts und Adapter deinstallieren und nochmal neu drauf.
                                          coyote 2 Replies Last reply Reply Quote 0
                                            hast du das mal im Betatester Thread für den Controller nachgesehen, oder nachgefragt ob das Problem eher dahr kommt?
                                            wobei mir die Fehlermeldung so aussieht, als ob du Probleme mit dem Controller hättest.
                                            ble adapter gyp error node error python
                                            3717
