    4. [gelöst]Problemsuche error node-gyp ble adapter
    • coyote
      coyote Most Active @Thomas Braun last edited by
      @thomas-braun erledigt!
      Wie gehts jetzt weiter? Bekomme beim Start des BLE Adapters immer noch:
      ble.0
      2023-07-28 18:13:45.016	error	Cannot find module '../build/Release/bluetooth_hci_socket.node' Require stack: - /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/native.js - /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/index.js - /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/lib/hci-socket/hci.js - /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/lib/hci-socket/bindings.js - /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/lib/resolve-bindings.js - /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/with-custom-binding.js - /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/index.js - /opt/iobroker/node_modules/iobroker.ble/build/scanProcess.js
        Thomas Braun Most Active @coyote last edited by
        @coyote
        iob update
        iob upgrade ble@0.13.4
        • coyote
          @thomas-braun sagte in Problemsuche error node-gyp ble adapter:
          Gleicher Fehler
            @coyote sagte in Problemsuche error node-gyp ble adapter:
            Gleicher Fehler
            Immer vollständige Ein- und Ausgaben zeigen.
            • coyote
              coyote@ioBroker:~$ iob update
              Used repository: beta
              Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/../node_modules/iobroker.lgtv/io-package.json: /opt/iobroker/node_modules/iobroker.lgtv/io-package.json: Unexpected token } in JSON at position 10582
              Adapter    "admin"        : 6.6.4    , installed 6.6.4
              Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
              Adapter    "ble"          : 0.13.4   , installed 0.13.4
              Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
              Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
              Adapter    "esphome"      : 0.2.4    , installed 0.2.4
              Adapter    "eusec"        : 1.0.0    , installed 1.0.0
              Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
              Adapter    "frigate"      : 0.2.5    , installed 0.2.5
              Adapter    "heatingcontrol": 2.11.0  , installed 2.11.0
              Adapter    "history"      : 2.2.4    , installed 2.2.4
              Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
              Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
              Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
              Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
              Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
              Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
              Adapter    "javascript"   : 7.1.1    , installed 7.1.1
              Controller "js-controller": 5.0.9    , installed 5.0.9
              Adapter    "linux-control": 1.1.5    , installed 1.1.5
              Adapter    "modbus"       : 5.0.11   , installed 5.0.11
              Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
              Adapter    "mytime"       : 0.7.12   , installed 0.7.12
              Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
              Adapter    "node-red"     : 4.0.3    , installed 4.0.3
              Adapter    "opendtu"      : 0.1.7    , installed 0.1.7
              Adapter    "operating-hours": 1.0.4  , installed 1.0.4
              Adapter    "ph803w"       : 1.1.1    , installed 1.1.1
              Adapter    "shelly"       : 6.4.1    , installed 6.4.1
              Adapter    "shuttercontrol": 1.6.1   , installed 1.6.1
              Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
              Adapter    "socketio"     : 6.4.0    , installed 6.4.0
              Adapter    "solarmanpv"   : 0.5.0    , installed 0.5.0
              Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
              Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
              Adapter    "telegram"     : 1.16.0   , installed 1.16.0
              Adapter    "trashschedule": 2.2.0    , installed 2.2.0
              Adapter    "unifi"        : 0.6.6    , installed 0.6.6
              Adapter    "vis"          : 1.4.16   , installed 1.4.16
              Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
              Adapter    "vis-2-widgets-material": 0.8.2, installed 0.8.2
              Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
              Adapter    "vis-material" : 0.1.3    , installed 0.1.3
              Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
              Adapter    "web"          : 6.0.3    , installed 6.0.3
              Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
              Adapter    "wled"         : 0.7.0    , installed 0.7.0
              Adapter    "worx"         : 2.3.2    , installed 2.3.2
              Adapter    "ws"           : 2.4.0    , installed 2.4.0
              Adapter    "yahka"        : 1.0.3    , installed 1.0.3
              Adapter    "zigbee"       : 1.8.18   , installed 1.8.18
              coyote@ioBroker:~$ iob upgrade ble@0.13.4
              Would you like to reinstall version 0.13.4 of ble now? [(y)es, (n)o]: y
              Update ble from @0.13.4 to @0.13.4
              NPM version: 9.6.7
              Installing iobroker.ble@0.13.4... (System call)
              up to date in 10s
              158 packages are looking for funding
                run `npm fund` for details
              upload [5] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/.eslintrc.js .eslintrc.js application/javascript
              upload [4] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/ble.png ble.png image/png
              upload [3] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js build/index.js application/javascript
              upload [2] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js.map build/index.js.map application/json
              upload [1] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/index_m.html index_m.html text/html
              upload [0] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/style.css style.css text/css
                Da ist ja auch noch anderes schief...
                coyote Homoran 2 Replies Last reply Reply Quote 0
                • coyote
                  @thomas-braun das habe ich auch gerade erst gesehen, den Adapter habe ich gestern über die GUI deinstalliert
                    @coyote
                    cd /opt/iobroker && npm ls -a | grep ERR
                    • coyote
                      das kommt nix, Ausgabe ist leer
                        IMMER vollständige Ein- wie Ausgaben zeigen...
                        Nix nacherzählen...
                        • coyote
                          coyote@ioBroker:~$ cd /opt/iobroker && npm ls -a | grep ERR
                          coyote@ioBroker:/opt/iobroker$
                            /js-controller
                            Beta-Tester!
                            • coyote
                              coyote Most Active @Homoran last edited by
                              @homoran Sicher, warum denn nicht? Schon ewig.
                                Homoran Global Moderator Administrators @coyote last edited by
                                @coyote es ist etwas snderes Adapter im Beta-Zustand zu testen, als in der produktiven Umgebung einen frühen Controller zu haben.
                                • coyote
                                  @homoran ich bin mir der Sache bewusst. Backups sind genug da, kann ohne Probleme zurück. Ich will ja helfen Fehler zu finden. Habe ich beim vorherigen Controller auch gemacht.
                                  Es läuft ja auch alles soweit bisher, nur der BLE will nicht richtig bei mir.
                                    @coyote
                                    iob rebuild iobroker.ble
                                    mal versucht?
                                    Oder ganze Rolle rückwärts und Adapter deinstallieren und nochmal neu drauf.
                                    coyote 2 Replies Last reply Reply Quote 0
                                      hast du das mal im Betatester Thread für den Controller nachgesehen, oder nachgefragt ob das Problem eher dahr kommt?
                                      wobei mir die Fehlermeldung so aussieht, als ob du Probleme mit dem Controller hättest.
                                      • coyote
                                        hat nichts gebracht.
                                        Adapter komplett neu installiert -> läuft 👍
                                        Danke für die Hilfe.
                                        • coyote
                                          @thomas-braun kann ich noch was machen, wegen dem Fehler vom LG TV Adapter?
                                            Keine Ahnung. Hab den noch nie gesehen.
                                            ble adapter gyp error node error python
                                            3710
