    4. [gelöst]Problemsuche error node-gyp ble adapter
      Thomas Braun Most Active @coyote last edited by
      @coyote
      iob update
      iob upgrade ble@0.13.4
      • coyote
        coyote Most Active @Thomas Braun last edited by
        @thomas-braun sagte in Problemsuche error node-gyp ble adapter:
        Gleicher Fehler
          @coyote sagte in Problemsuche error node-gyp ble adapter:
          Gleicher Fehler
          Immer vollständige Ein- und Ausgaben zeigen.
          • coyote
            coyote@ioBroker:~$ iob update
            Used repository: beta
            Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/../node_modules/iobroker.lgtv/io-package.json: /opt/iobroker/node_modules/iobroker.lgtv/io-package.json: Unexpected token } in JSON at position 10582
            Adapter    "admin"        : 6.6.4    , installed 6.6.4
            Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
            Adapter    "ble"          : 0.13.4   , installed 0.13.4
            Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
            Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
            Adapter    "esphome"      : 0.2.4    , installed 0.2.4
            Adapter    "eusec"        : 1.0.0    , installed 1.0.0
            Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
            Adapter    "frigate"      : 0.2.5    , installed 0.2.5
            Adapter    "heatingcontrol": 2.11.0  , installed 2.11.0
            Adapter    "history"      : 2.2.4    , installed 2.2.4
            Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
            Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
            Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
            Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
            Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
            Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
            Adapter    "javascript"   : 7.1.1    , installed 7.1.1
            Controller "js-controller": 5.0.9    , installed 5.0.9
            Adapter    "linux-control": 1.1.5    , installed 1.1.5
            Adapter    "modbus"       : 5.0.11   , installed 5.0.11
            Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
            Adapter    "mytime"       : 0.7.12   , installed 0.7.12
            Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
            Adapter    "node-red"     : 4.0.3    , installed 4.0.3
            Adapter    "opendtu"      : 0.1.7    , installed 0.1.7
            Adapter    "operating-hours": 1.0.4  , installed 1.0.4
            Adapter    "ph803w"       : 1.1.1    , installed 1.1.1
            Adapter    "shelly"       : 6.4.1    , installed 6.4.1
            Adapter    "shuttercontrol": 1.6.1   , installed 1.6.1
            Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
            Adapter    "socketio"     : 6.4.0    , installed 6.4.0
            Adapter    "solarmanpv"   : 0.5.0    , installed 0.5.0
            Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
            Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
            Adapter    "telegram"     : 1.16.0   , installed 1.16.0
            Adapter    "trashschedule": 2.2.0    , installed 2.2.0
            Adapter    "unifi"        : 0.6.6    , installed 0.6.6
            Adapter    "vis"          : 1.4.16   , installed 1.4.16
            Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
            Adapter    "vis-2-widgets-material": 0.8.2, installed 0.8.2
            Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
            Adapter    "vis-material" : 0.1.3    , installed 0.1.3
            Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
            Adapter    "web"          : 6.0.3    , installed 6.0.3
            Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
            Adapter    "wled"         : 0.7.0    , installed 0.7.0
            Adapter    "worx"         : 2.3.2    , installed 2.3.2
            Adapter    "ws"           : 2.4.0    , installed 2.4.0
            Adapter    "yahka"        : 1.0.3    , installed 1.0.3
            Adapter    "zigbee"       : 1.8.18   , installed 1.8.18
            coyote@ioBroker:~$ iob upgrade ble@0.13.4
            Would you like to reinstall version 0.13.4 of ble now? [(y)es, (n)o]: y
            Update ble from @0.13.4 to @0.13.4
            NPM version: 9.6.7
            Installing iobroker.ble@0.13.4... (System call)
            up to date in 10s
            158 packages are looking for funding
              run `npm fund` for details
            upload [5] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/.eslintrc.js .eslintrc.js application/javascript
            upload [4] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/ble.png ble.png image/png
            upload [3] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js build/index.js application/javascript
            upload [2] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js.map build/index.js.map application/json
            upload [1] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/index_m.html index_m.html text/html
            upload [0] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/style.css style.css text/css
              Da ist ja auch noch anderes schief...
              coyote Homoran 2 Replies Last reply Reply Quote 0
              • coyote
                @thomas-braun das habe ich auch gerade erst gesehen, den Adapter habe ich gestern über die GUI deinstalliert
                  @coyote
                  cd /opt/iobroker && npm ls -a | grep ERR
                  • coyote
                    das kommt nix, Ausgabe ist leer
                      IMMER vollständige Ein- wie Ausgaben zeigen...
                      Nix nacherzählen...
                      • coyote
                        coyote@ioBroker:~$ cd /opt/iobroker && npm ls -a | grep ERR
                        coyote@ioBroker:/opt/iobroker$
                          /js-controller
                          Beta-Tester!
                          • coyote
                            coyote Most Active @Homoran last edited by
                            @homoran Sicher, warum denn nicht? Schon ewig.
                              Homoran Global Moderator Administrators @coyote last edited by
                              @coyote es ist etwas snderes Adapter im Beta-Zustand zu testen, als in der produktiven Umgebung einen frühen Controller zu haben.
                              • coyote
                                @homoran ich bin mir der Sache bewusst. Backups sind genug da, kann ohne Probleme zurück. Ich will ja helfen Fehler zu finden. Habe ich beim vorherigen Controller auch gemacht.
                                Es läuft ja auch alles soweit bisher, nur der BLE will nicht richtig bei mir.
                                  @coyote
                                  iob rebuild iobroker.ble
                                  mal versucht?
                                  Oder ganze Rolle rückwärts und Adapter deinstallieren und nochmal neu drauf.
                                  coyote 2 Replies Last reply Reply Quote 0
                                    hast du das mal im Betatester Thread für den Controller nachgesehen, oder nachgefragt ob das Problem eher dahr kommt?
                                    wobei mir die Fehlermeldung so aussieht, als ob du Probleme mit dem Controller hättest.
                                    • coyote
                                      hat nichts gebracht.
                                      Adapter komplett neu installiert -> läuft 👍
                                      Danke für die Hilfe.
                                      • coyote
                                        @thomas-braun kann ich noch was machen, wegen dem Fehler vom LG TV Adapter?
                                          Keine Ahnung. Hab den noch nie gesehen.
                                          • coyote
                                            Das hier meinte ich:
                                            Wie gesagt, der ist gar nicht mehr installiert
                                            ble adapter gyp error node error python
                                            3710
