    4. [gelöst]Problemsuche error node-gyp ble adapter
    • coyote
      coyote Most Active @Thomas Braun last edited by
      @thomas-braun sagte in Problemsuche error node-gyp ble adapter:
      iob upgrade ble@0.13.4
      Gleicher Fehler
        Thomas Braun Most Active @coyote last edited by
        @coyote sagte in Problemsuche error node-gyp ble adapter:
        Gleicher Fehler
        Immer vollständige Ein- und Ausgaben zeigen.
        • coyote
          coyote@ioBroker:~$ iob update
          Used repository: beta
          Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/../node_modules/iobroker.lgtv/io-package.json: /opt/iobroker/node_modules/iobroker.lgtv/io-package.json: Unexpected token } in JSON at position 10582
          Adapter    "admin"        : 6.6.4    , installed 6.6.4
          Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
          Adapter    "ble"          : 0.13.4   , installed 0.13.4
          Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
          Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
          Adapter    "esphome"      : 0.2.4    , installed 0.2.4
          Adapter    "eusec"        : 1.0.0    , installed 1.0.0
          Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
          Adapter    "frigate"      : 0.2.5    , installed 0.2.5
          Adapter    "heatingcontrol": 2.11.0  , installed 2.11.0
          Adapter    "history"      : 2.2.4    , installed 2.2.4
          Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
          Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
          Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
          Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
          Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
          Adapter    "javascript"   : 7.1.1    , installed 7.1.1
          Controller "js-controller": 5.0.9    , installed 5.0.9
          Adapter    "linux-control": 1.1.5    , installed 1.1.5
          Adapter    "modbus"       : 5.0.11   , installed 5.0.11
          Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
          Adapter    "mytime"       : 0.7.12   , installed 0.7.12
          Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
          Adapter    "node-red"     : 4.0.3    , installed 4.0.3
          Adapter    "opendtu"      : 0.1.7    , installed 0.1.7
          Adapter    "operating-hours": 1.0.4  , installed 1.0.4
          Adapter    "ph803w"       : 1.1.1    , installed 1.1.1
          Adapter    "shelly"       : 6.4.1    , installed 6.4.1
          Adapter    "shuttercontrol": 1.6.1   , installed 1.6.1
          Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
          Adapter    "socketio"     : 6.4.0    , installed 6.4.0
          Adapter    "solarmanpv"   : 0.5.0    , installed 0.5.0
          Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
          Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
          Adapter    "telegram"     : 1.16.0   , installed 1.16.0
          Adapter    "trashschedule": 2.2.0    , installed 2.2.0
          Adapter    "unifi"        : 0.6.6    , installed 0.6.6
          Adapter    "vis"          : 1.4.16   , installed 1.4.16
          Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
          Adapter    "vis-2-widgets-material": 0.8.2, installed 0.8.2
          Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
          Adapter    "vis-material" : 0.1.3    , installed 0.1.3
          Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
          Adapter    "web"          : 6.0.3    , installed 6.0.3
          Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
          Adapter    "wled"         : 0.7.0    , installed 0.7.0
          Adapter    "worx"         : 2.3.2    , installed 2.3.2
          Adapter    "ws"           : 2.4.0    , installed 2.4.0
          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
          Adapter    "zigbee"       : 1.8.18   , installed 1.8.18
          coyote@ioBroker:~$ iob upgrade ble@0.13.4
          Would you like to reinstall version 0.13.4 of ble now? [(y)es, (n)o]: y
          Update ble from @0.13.4 to @0.13.4
          NPM version: 9.6.7
          Installing iobroker.ble@0.13.4... (System call)
          up to date in 10s
          158 packages are looking for funding
            run `npm fund` for details
          upload [5] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/.eslintrc.js .eslintrc.js application/javascript
          upload [4] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/ble.png ble.png image/png
          upload [3] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js build/index.js application/javascript
          upload [2] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js.map build/index.js.map application/json
          upload [1] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/index_m.html index_m.html text/html
          upload [0] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/style.css style.css text/css
            Da ist ja auch noch anderes schief...
            coyote Homoran 2 Replies Last reply Reply Quote 0
            • coyote
              @thomas-braun das habe ich auch gerade erst gesehen, den Adapter habe ich gestern über die GUI deinstalliert
                @coyote
                cd /opt/iobroker && npm ls -a | grep ERR
                • coyote
                  das kommt nix, Ausgabe ist leer
                    IMMER vollständige Ein- wie Ausgaben zeigen...
                    Nix nacherzählen...
                    • coyote
                      coyote@ioBroker:~$ cd /opt/iobroker && npm ls -a | grep ERR
                      coyote@ioBroker:/opt/iobroker$
                        /js-controller
                        Beta-Tester!
                        • coyote
                          coyote Most Active @Homoran last edited by
                          @homoran Sicher, warum denn nicht? Schon ewig.
                            Homoran Global Moderator Administrators @coyote last edited by
                            @coyote es ist etwas snderes Adapter im Beta-Zustand zu testen, als in der produktiven Umgebung einen frühen Controller zu haben.
                            • coyote
                              @homoran ich bin mir der Sache bewusst. Backups sind genug da, kann ohne Probleme zurück. Ich will ja helfen Fehler zu finden. Habe ich beim vorherigen Controller auch gemacht.
                              Es läuft ja auch alles soweit bisher, nur der BLE will nicht richtig bei mir.
                                @coyote
                                iob rebuild iobroker.ble
                                mal versucht?
                                Oder ganze Rolle rückwärts und Adapter deinstallieren und nochmal neu drauf.
                                coyote 2 Replies Last reply Reply Quote 0
                                  hast du das mal im Betatester Thread für den Controller nachgesehen, oder nachgefragt ob das Problem eher dahr kommt?
                                  wobei mir die Fehlermeldung so aussieht, als ob du Probleme mit dem Controller hättest.
                                  • coyote
                                    hat nichts gebracht.
                                    Adapter komplett neu installiert -> läuft 👍
                                    Danke für die Hilfe.
                                    • coyote
                                      @thomas-braun kann ich noch was machen, wegen dem Fehler vom LG TV Adapter?
                                        Keine Ahnung. Hab den noch nie gesehen.
                                        • coyote
                                          Das hier meinte ich:
                                          Wie gesagt, der ist gar nicht mehr installiert
                                            Ich würde die
                                            vermutlich löschen.
                                            ble adapter gyp error node error python
                                            3712
