    4. [gelöst]Problemsuche error node-gyp ble adapter
    • coyote
      coyote Most Active @Thomas Braun last edited by
      coyote@ioBroker:~$ iob update
      Used repository: beta
      Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/../node_modules/iobroker.lgtv/io-package.json: /opt/iobroker/node_modules/iobroker.lgtv/io-package.json: Unexpected token } in JSON at position 10582
      Adapter    "admin"        : 6.6.4    , installed 6.6.4
      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
      Adapter    "ble"          : 0.13.4   , installed 0.13.4
      Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
      Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
      Adapter    "esphome"      : 0.2.4    , installed 0.2.4
      Adapter    "eusec"        : 1.0.0    , installed 1.0.0
      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
      Adapter    "frigate"      : 0.2.5    , installed 0.2.5
      Adapter    "heatingcontrol": 2.11.0  , installed 2.11.0
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
      Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 7.1.1    , installed 7.1.1
      Controller "js-controller": 5.0.9    , installed 5.0.9
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "mytime"       : 0.7.12   , installed 0.7.12
      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
      Adapter    "opendtu"      : 0.1.7    , installed 0.1.7
      Adapter    "operating-hours": 1.0.4  , installed 1.0.4
      Adapter    "ph803w"       : 1.1.1    , installed 1.1.1
      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
      Adapter    "shuttercontrol": 1.6.1   , installed 1.6.1
      Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
      Adapter    "socketio"     : 6.4.0    , installed 6.4.0
      Adapter    "solarmanpv"   : 0.5.0    , installed 0.5.0
      Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "unifi"        : 0.6.6    , installed 0.6.6
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
      Adapter    "vis-2-widgets-material": 0.8.2, installed 0.8.2
      Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "web"          : 6.0.3    , installed 6.0.3
      Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
      Adapter    "wled"         : 0.7.0    , installed 0.7.0
      Adapter    "worx"         : 2.3.2    , installed 2.3.2
      Adapter    "ws"           : 2.4.0    , installed 2.4.0
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "zigbee"       : 1.8.18   , installed 1.8.18
      coyote@ioBroker:~$ iob upgrade ble@0.13.4
      Would you like to reinstall version 0.13.4 of ble now? [(y)es, (n)o]: y
      Update ble from @0.13.4 to @0.13.4
      NPM version: 9.6.7
      Installing iobroker.ble@0.13.4... (System call)
      up to date in 10s
      158 packages are looking for funding
        run `npm fund` for details
      upload [5] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/.eslintrc.js .eslintrc.js application/javascript
      upload [4] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/ble.png ble.png image/png
      upload [3] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js build/index.js application/javascript
      upload [2] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js.map build/index.js.map application/json
      upload [1] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/index_m.html index_m.html text/html
      upload [0] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/style.css style.css text/css
        Thomas Braun Most Active @coyote last edited by
        @coyote sagte in Problemsuche error node-gyp ble adapter:
        Da ist ja auch noch anderes schief...
        coyote Homoran 2 Replies Last reply Reply Quote 0
        • coyote
          @thomas-braun das habe ich auch gerade erst gesehen, den Adapter habe ich gestern über die GUI deinstalliert
            @coyote
            cd /opt/iobroker && npm ls -a | grep ERR
            • coyote
              @thomas-braun sagte in Problemsuche error node-gyp ble adapter:
              das kommt nix, Ausgabe ist leer
                IMMER vollständige Ein- wie Ausgaben zeigen...
                Nix nacherzählen...
                • coyote
                  coyote@ioBroker:~$ cd /opt/iobroker && npm ls -a | grep ERR
                  coyote@ioBroker:/opt/iobroker$
                    /js-controller
                    Beta-Tester!
                    • coyote
                      coyote Most Active @Homoran last edited by
                      @homoran Sicher, warum denn nicht? Schon ewig.
                        Homoran Global Moderator Administrators @coyote last edited by
                        @coyote es ist etwas snderes Adapter im Beta-Zustand zu testen, als in der produktiven Umgebung einen frühen Controller zu haben.
                        • coyote
                          @homoran ich bin mir der Sache bewusst. Backups sind genug da, kann ohne Probleme zurück. Ich will ja helfen Fehler zu finden. Habe ich beim vorherigen Controller auch gemacht.
                          Es läuft ja auch alles soweit bisher, nur der BLE will nicht richtig bei mir.
                            @coyote
                            iob rebuild iobroker.ble
                            mal versucht?
                            Oder ganze Rolle rückwärts und Adapter deinstallieren und nochmal neu drauf.
                            coyote 2 Replies Last reply Reply Quote 0
                              hast du das mal im Betatester Thread für den Controller nachgesehen, oder nachgefragt ob das Problem eher dahr kommt?
                              wobei mir die Fehlermeldung so aussieht, als ob du Probleme mit dem Controller hättest.
                              • coyote
                                hat nichts gebracht.
                                Adapter komplett neu installiert -> läuft 👍
                                Danke für die Hilfe.
                                • coyote
                                  @thomas-braun kann ich noch was machen, wegen dem Fehler vom LG TV Adapter?
                                    Keine Ahnung. Hab den noch nie gesehen.
                                    • coyote
                                      Das hier meinte ich:
                                      Wie gesagt, der ist gar nicht mehr installiert
                                        Ich würde die
                                        vermutlich löschen.
                                          crunchip Forum Testing Most Active @Thomas Braun last edited by
                                          @thomas-braun hab ich umbenannt und danach ble versucht
                                          Would you like to upgrade ble from @0.13.3 to @0.13.4 now? [(y)es, (n)o]: y
                                          Update ble from @0.13.3 to @0.13.4
                                          NPM version: 9.6.7
                                          npm ERR! code 1
                                          npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
                                          npm ERR! command failed
                                          npm ERR! command sh -c node-gyp-build
                                          npm ERR! gyp info it worked if it ends with ok
                                          npm ERR! gyp info using node-gyp@7.1.2
                                          npm ERR! gyp info using node@18.17.0 | linux | x64
                                          npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
                                          npm ERR! (node:352773) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
                                          npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)
                                          npm ERR! gyp info spawn /usr/bin/python3
                                          npm ERR! gyp info spawn args [
                                          npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
                                          npm ERR! gyp info spawn args   'binding.gyp',
                                          npm ERR! gyp info spawn args   '-f',
                                          npm ERR! gyp info spawn args   'make',
                                          npm ERR! gyp info spawn args   '-I',
                                          npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build/config.gypi',
                                          npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
                                          npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.17.0/include/node/common.gypi',
                                          npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
                                          npm ERR! gyp info spawn args   '-Dvisibility=default',
                                          npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.17.0',
                                          npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
                                          npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.17.0/<(target_arch)/node.lib',
                                          npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble',
                                          npm ERR! gyp info spawn args   '-Dnode_engine=v8',
                                          npm ERR! gyp info spawn args   '--depth=.',
                                          npm ERR! gyp info spawn args   '--no-parallel',
                                          npm ERR! gyp info spawn args   '--generator-output',
                                          npm ERR! gyp info spawn args   'build',
                                          npm ERR! gyp info spawn args   '-Goutput_dir=.'
                                          npm ERR! gyp info spawn args ]
                                          npm ERR! Traceback (most recent call last):
                                          npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>
                                          npm ERR!     sys.exit(gyp.script_main())
                                          npm ERR!              ^^^^^^^^^^^^^^^^^
                                          npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main
                                          npm ERR!     return main(sys.argv[1:])
                                          npm ERR!            ^^^^^^^^^^^^^^^^^^
                                          npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main
                                          npm ERR!     return gyp_main(args)
                                          npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main
                                          npm ERR!     [generator, flat_list, targets, data] = Load(
                                          npm ERR!                                             ^^^^^
                                          npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load
                                          npm ERR!     result = gyp.input.Load(
                                          npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load
                                          npm ERR!     LoadTargetBuildFile(
                                          npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile
                                          npm ERR!     build_file_data = LoadOneBuildFile(
                                          npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile
                                          npm ERR!     build_file_contents = open(build_file_path, "rU").read()
                                          npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^
                                          npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp
                                          npm ERR! gyp ERR! configure error
                                          npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1
                                          npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)
                                          npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)
                                          npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)
                                          npm ERR! gyp ERR! System Linux 6.1.0-10-amd64
                                          npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
                                          npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
                                          npm ERR! gyp ERR! node -v v18.17.0
                                          npm ERR! gyp ERR! node-gyp -v v7.1.2
                                          npm ERR! gyp ERR! not ok
                                          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-07-28T22_04_18_690Z-debug-0.log
                                          Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                                            Thomas Braun Most Active @crunchip last edited by Thomas Braun
                                            @crunchip
                                            Dann schau in das genannte Log rein.
                                            Hier schaut's auch nach einem Ansatz 'dirty workaround' aus:
                                            https://stackoverflow.com/questions/74715990/node-gyp-err-invalid-mode-ru-while-trying-to-load-binding-gyp
                                            ble adapter gyp error node error python
                                            3721
