    4. js-controller 5.0.x jetzt in der BETA
      ticaki @foxriver76 last edited by ticaki
      @foxriver76
      Hab gleichartige Logeinträge ausgelassen (...) sind trotzdem sehr viele
      2023-07-27 18:34:14.145 - info: host.iobroker Controller will upgrade itself to version 5.0.9
      2023-07-27 18:34:14.859 - info: host.iobroker [CONTROLLER_AUTO_UPGRADE] Stopping controller
      2023-07-27 18:34:14.896 - info: javascript.0 (29336) Stop script script.js.Verwaltung.Luftbefeuchter
      2023-07-27 18:34:14.895 - info: backitup.0 (1377) cleaned everything up...
      2023-07-27 18:34:14.921 - info: backitup.0 (1377) terminating
      2023-07-27 18:34:14.923 - info: backitup.0 (1377) Terminated (NO_ERROR): Without reason
      2023-07-27 18:34:14.883 - info: host.iobroker received SIGTERM
      2023-07-27 18:34:14.888 - info: admin.0 (371) terminating https server on port 443
      2023-07-27 18:34:14.890 - info: yahka.0 (1252) cleaning up ...
      2023-07-27 18:34:14.893 - info: yahka.0 (1252) cleaned up ...
      2023-07-27 18:34:14.919 - info: yahka.0 (1252) terminating
      2023-07-27 18:34:14.919 - info: yahka.0 (1252) Terminated (NO_ERROR): Without reason
      2023-07-27 18:34:14.904 - info: reolink.0 (689) terminating
      2023-07-27 18:34:14.916 - info: reolink.0 (689) Terminated (NO_ERROR): Without reason
      2023-07-27 18:34:14.908 - info: admin.0 (371) terminating
      2023-07-27 18:34:14.909 - info: admin.0 (371) Terminated (NO_ERROR): Without reason
      2023-07-27 18:34:14.897 - info: javascript.0 (29336) Stop script script.js.Beleuchtung_(mehrere_Räume).hue_convert_Virtuelle_Light_on-off_0%-100%_brightness
      2023-07-27 18:34:14.913 - info: javascript.0 (29336) Stop script script.js.Messages.Sensorüberwachung
      2023-07-27 18:34:14.884 - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
      2023-07-27 18:34:14.916 - info: host.iobroker stopInstance system.adapter.backitup.0 (force=false, process=true)
      2023-07-27 18:34:14.947 - info: backitup.0 (1377) Got terminate signal TERMINATE_YOURSELF
      2023-07-27 18:34:14.951 - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
      2023-07-27 18:34:14.958 - info: javascript.0 (29336) Got terminate signal TERMINATE_YOURSELF
      2023-07-27 18:34:14.951 - info: host.iobroker stopInstance system.adapter.email.0 send kill signal
      2023-07-27 18:34:14.962 - info: javascript.0 (29336) terminating
      2023-07-27 18:34:14.962 - info: javascript.0 (29336) Terminated (NO_ERROR): Without reason
      2023-07-27 18:34:14.967 - info: telegram.0 (76948) Got terminate signal TERMINATE_YOURSELF
      2023-07-27 18:34:14.920 - info: fritzdect.0 (1230) cleaned everything up...
      2023-07-27 18:34:14.981 - info: fritzdect.0 (1230) Got terminate signal TERMINATE_YOURSELF
      2023-07-27 18:34:14.947 - info: notification-manager.0 (1345) terminating
      2023-07-27 18:34:14.988 - info: notification-manager.0 (1345) Terminated (NO_ERROR): Without reason
      2023-07-27 18:34:14.988 - info: notification-manager.0 (1345) Got terminate signal TERMINATE_YOURSELF
      2023-07-27 18:34:14.997 - warn: zigbee2mqtt.0 (772) Start try again in 1 seconds...
      2023-07-27 18:34:14.888 - error: mihome-vacuum.0 (508) Socket Close
      2023-07-27 18:34:14.923 - info: sma-em.0 (1329) cleaned everything up...
      2023-07-27 18:34:15.001 - info: sma-em.0 (1329) UDP Socket closed ...
      2023-07-27 18:34:14.911 - info: yahka.1 (757) cleaning up ...
      2023-07-27 18:34:14.915 - info: yahka.1 (757) cleaned up ...
      2023-07-27 18:34:14.973 - info: iot.0 (742) Got terminate signal TERMINATE_YOURSELF
      2023-07-27 18:34:15.012 - info: iot.0 (742) Connection changed: disconnect
      2023-07-27 18:34:15.017 - info: iot.0 (742) Connection lost
      2023-07-27 18:34:14.949 - info: pushover.0 (457) Got terminate signal TERMINATE_YOURSELF
      2023-07-27 18:34:14.974 - info: alexa2.0 (659) Got terminate signal TERMINATE_YOURSELF
      2023-07-27 18:34:14.945 - info: mqtt.0 (553) Disconnected from mqtt.tims.home: undefined
      2023-07-27 18:34:14.929 - info: hm-rpc.1 (24701) xmlrpc -> 192.168.179.201:42010/ init ["http://192.168.179.7:42010",""]
      2023-07-27 18:34:15.029 - info: hm-rpc.1 (24701) Got terminate signal TERMINATE_YOURSELF
      2023-07-27 18:34:14.953 - info: discovery.0 (725) terminating
      2023-07-27 18:34:15.022 - info: discovery.0 (725) Terminated (NO_ERROR): Without reason
      2023-07-27 18:34:15.027 - info: discovery.0 (725) Got terminate signal TERMINATE_YOURSELF
      2023-07-27 18:34:14.904 - info: homepilot20.0 (704) terminating homepilot20 adapter
      2023-07-27 18:34:14.999 - error: homepilot20.0 (704) Adapter will be stopped
      2023-07-27 18:34:15.032 - info: hyperion_ng.0 (1185) terminating
      2023-07-27 18:34:15.033 - info: hyperion_ng.0 (1185) Terminated (NO_ERROR): Without reason
      2023-07-27 18:34:14.932 - info: hm-rpc.0 (24716) xmlrpc -> 192.168.179.201:42001/ init ["http://192.168.179.7:42001",""]
      2023-07-27 18:34:15.035 - info: hm-rpc.0 (24716) Got terminate signal TERMINATE_YOURSELF
      2023-07-27 18:34:14.960 - info: hm-rega.0 (538) Got terminate signal TERMINATE_YOURSELF
      2023-07-27 18:34:15.036 - info: iot.0 (742) terminating
      2023-07-27 18:34:14.969 - info: daikin.0 (644) Got terminate signal TERMINATE_YOURSELF
      2023-07-27 18:34:15.036 - info: daikin.0 (644) terminating
      2023-07-27 18:34:15.037 - info: daikin.0 (644) Terminated (NO_ERROR): Without reason
      2023-07-27 18:34:14.999 - info: mihome-vacuum.0 (508) Got terminate signal TERMINATE_YOURSELF
      2023-07-27 18:34:15.039 - info: fritzdect.0 (1230) terminating
      2023-07-27 18:34:15.039 - info: fritzdect.0 (1230) Terminated (NO_ERROR): Without reason
      2023-07-27 18:34:15.004 - info: sma-em.0 (1329) Terminated (NO_ERROR): Without reason
      2023-07-27 18:34:15.036 - info: iot.0 (742) Terminated (NO_ERROR): Without reason
      2023-07-27 18:34:14.989 - warn: influxdb.1 (493) Store data for 149 points and 0 conflicts
      2023-07-27 18:34:15.045 - info: mihome-vacuum.0 (508) terminating
      2023-07-27 18:34:15.045 - info: mihome-vacuum.0 (508) Terminated (NO_ERROR): Without reason
      2023-07-27 18:34:15.032 - info: homepilot20.0 (704) Got terminate signal TERMINATE_YOURSELF
      2023-07-27 18:34:15.047 - info: alexa2.0 (659) terminating
      2023-07-27 18:34:15.047 - info: alexa2.0 (659) Terminated (NO_ERROR): Without reason
      2023-07-27 18:34:15.028 - info: mqtt.0 (553) Got terminate signal TERMINATE_YOURSELF
      2023-07-27 18:34:15.049 - info: hm-rpc.1 (24701) Disconnected
      2023-07-27 18:34:15.049 - info: homepilot20.0 (704) terminating
      2023-07-27 18:34:15.050 - info: homepilot20.0 (704) Terminated (NO_ERROR): Without reason
      2023-07-27 18:34:15.051 - info: hm-rpc.0 (24716) Disconnected
      2023-07-27 18:34:15.055 - info: hm-rpc.1 (24701) terminating
      2023-07-27 18:34:15.055 - info: hm-rpc.1 (24701) Terminated (NO_ERROR): Without reason
      2023-07-27 18:34:15.057 - info: hm-rpc.0 (24716) terminating
      2023-07-27 18:34:15.057 - info: hm-rpc.0 (24716) Terminated (NO_ERROR): Without reason
      2023-07-27 18:34:15.062 - info: hm-rega.0 (538) terminating
      2023-07-27 18:34:15.063 - info: hm-rega.0 (538) Terminated (NO_ERROR): Without reason
      2023-07-27 18:34:15.126 - info: zigbee2mqtt.0 (772) terminating
      2023-07-27 18:34:15.127 - info: zigbee2mqtt.0 (772) Terminated (NO_ERROR): Without reason
      2023-07-27 18:34:15.388 - info: pushover.0 (457) Terminated (NO_ERROR): Without reason
      2023-07-27 18:34:15.395 - info: mqtt.0 (553) Terminated (NO_ERROR): Without reason
      2023-07-27 18:34:15.403 - info: sonoff.0 (674) Terminated (NO_ERROR): Without reason
      2023-07-27 18:34:15.451 - info: telegram.0 (76948) Terminated (NO_ERROR): Without reason
      2023-07-27 18:34:15.459 - info: host.iobroker instance system.adapter.yahka.0 terminated with code 0 (NO_ERROR)
      2023-07-27 18:34:15.459 - info: host.iobroker stopInstance system.adapter.hyperion_ng.0 killing pid 1185
      2023-07-27 18:34:15.481 - info: fritzdect.0 (1230) terminating
      2023-07-27 18:34:15.484 - info: sma-em.0 (1329) terminating
      2023-07-27 18:34:15.482 - info: yahka.1 (757) terminating
      2023-07-27 18:34:15.500 - info: homepilot20.0 (704) terminating
      2023-07-27 18:34:15.528 - info: host.iobroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
      2023-07-27 18:34:15.528 - info: host.iobroker instance system.adapter.reolink.0 terminated with code 0 (NO_ERROR)
      2023-07-27 18:34:15.528 - info: host.iobroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
      2023-07-27 18:34:15.583 - warn: host.iobroker instance system.adapter.hyperion_ng.0 terminated due to SIGTERM
      2023-07-27 18:34:15.583 - info: host.iobroker instance system.adapter.hyperion_ng.0 terminated with code null ()
      2023-07-27 18:34:15.932 - info: host.iobroker instance system.adapter.sonoff.0 terminated with code 0 (NO_ERROR)
      2023-07-27 18:34:15.952 - info: host.iobroker stopInstance system.adapter.telegram.0 killing pid 76948
      2023-07-27 18:34:15.966 - warn: host.iobroker instance system.adapter.telegram.0 terminated due to SIGTERM
      2023-07-27 18:34:15.966 - info: host.iobroker instance system.adapter.telegram.0 terminated with code null ()
      2023-07-27 18:34:17.896 - info: tuya.0 (568) terminating
      2023-07-27 18:34:17.897 - info: tuya.0 (568) Terminated (NO_ERROR): Without reason
      2023-07-27 18:34:18.416 - info: host.iobroker instance system.adapter.tuya.0 terminated with code 0 (NO_ERROR)
      2023-07-27 18:34:18.417 - info: host.iobroker All instances are stopped.
      2023-07-27 18:34:18.555 - info: host.iobroker terminated
      2023-07-27 18:34:22.577 - info: host.iobroker [CONTROLLER_AUTO_UPGRADE] Successfully stopped js-controller
      2023-07-27 18:39:08.511 - info: host.iobroker iobroker.js-controller version 5.0.8 js-controller starting
        crunchip Forum Testing Most Active @foxriver76 last edited by crunchip
        @foxriver76 per gui ging es diesmal bei mir auch nicht, beim beenden der Adapter kamen viele Error, zum Schluss wurde js-controller beendet und dann tat sich nix mehr.
        Gesamte log kann ich gerne zur Verfügung stellen, bin aber grad nur per Handy on.
        @foxriver76 habs nur ein wenig eingekürzt
        js-controller.txt
        • Feuersturm
          Feuersturm last edited by
          Hier das gleiche Verhalten beim Update über die GUI.
          Master lies sich in der Vergangenheit über die GUI erfolgreich aktualisieren, von 5.0.8 auf 5.0.9 nicht.
          js-controller wurde gestoppt, es wurde aber kein update im Hintergrund ausgeführt. Ich musste iobroker manuell starten.
          2023-07-27 20:24:10.269 - info: host.ioBrokerTestsystem Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
          2023-07-27 20:26:58.312 - info: host.ioBrokerTestsystem Controller will upgrade itself to version 5.0.9
          2023-07-27 20:27:04.381 - info: host.ioBrokerTestsystem [CONTROLLER_AUTO_UPGRADE] Stopping controller
          2023-07-27 20:27:04.514 - info: host.ioBrokerTestsystem received SIGTERM
          2023-07-27 20:27:04.540 - info: backitup.0 (550) cleaned everything up...
          2023-07-27 20:27:04.521 - info: javascript.0 (348) Stop script script.js.Skripte.Kalender.ical_0_ToHtmlTable
          2023-07-27 20:27:04.535 - info: hm-rpc.0 (502) xmlrpc -> 192.168.178.84:2010/ init ["http://192.168.178.77:2010",""]
          2023-07-27 20:27:04.548 - info: unifi.0 (478) cleaned everything up...
          2023-07-27 20:27:04.582 - info: hm-rpc.0 (502) Disconnected
          2023-07-27 20:27:04.563 - info: info.0 (598) cleaned everything up...
          2023-07-27 20:27:04.539 - info: admin.0 (337) terminating http server on port 8081
          2023-07-27 20:27:04.561 - info: javascript.0 (348) Stop script script.js.Skripte.Kalender.ical_2_ToHtmlTable
          2023-07-27 20:27:04.566 - info: javascript.0 (348) Stop script script.js.Skripte.Kalender.ical_3_ToHtmlTable
          2023-07-27 20:27:04.571 - info: javascript.0 (348) Stop script script.js.Skripte.Kalender.ical_4_ToHtmlTable
          2023-07-27 20:27:04.577 - info: javascript.0 (348) Stop script script.js.Skripte.Kalender.muellkalender
          2023-07-27 20:27:04.582 - info: javascript.0 (348) Stop script script.js.Skripte.Netzwerk.Unifi_Vouchers
          2023-07-27 20:27:04.611 - info: proxmox.0 (642) cleaned everything up...
          2023-07-27 20:27:04.563 - info: simple-api.0 (658) terminating http server on port 8087
          2023-07-27 20:27:04.656 - info: vis-inventwo.0 (1025) cleaned everything up...
          2023-07-27 20:27:04.613 - info: trashschedule.0 (747) cleaned everything up...
          2023-07-27 20:27:04.621 - info: valloxmv.0 (771) cleaned everything up...
          2023-07-27 20:27:04.636 - info: device-watcher.0 (933) cleaned everything up...
          2023-07-27 20:27:04.520 - info: host.ioBrokerTestsystem stopInstance system.adapter.admin.0 (force=false, process=true)
          2023-07-27 20:27:04.525 - info: host.ioBrokerTestsystem stopInstance system.adapter.influxdb.0 (force=false, process=false)
          2023-07-27 20:27:04.526 - info: host.ioBrokerTestsystem stopInstance system.adapter.javascript.0 (force=false, process=true)
          2023-07-27 20:27:04.546 - info: host.ioBrokerTestsystem stopInstance system.adapter.scenes.0 (force=false, process=true)
          2023-07-27 20:27:04.547 - info: host.ioBrokerTestsystem stopInstance system.adapter.telegram.0 (force=false, process=false)
          2023-07-27 20:27:04.549 - info: host.ioBrokerTestsystem stopInstance system.adapter.scheduler.0 (force=false, process=true)
          2023-07-27 20:27:04.550 - info: host.ioBrokerTestsystem stopInstance system.adapter.fritzbox.0 (force=false, process=true)
          2023-07-27 20:27:04.574 - info: host.ioBrokerTestsystem stopInstance system.adapter.hue.0 (force=false, process=false)
          2023-07-27 20:27:04.577 - info: host.ioBrokerTestsystem stopInstance system.adapter.ical.0 (force=false, process=false)
          2023-07-27 20:27:04.579 - info: host.ioBrokerTestsystem stopInstance system.adapter.ical.1 (force=false, process=false)
          2023-07-27 20:27:04.586 - info: host.ioBrokerTestsystem stopInstance system.adapter.ical.2 (force=false, process=false)
          2023-07-27 20:27:04.587 - info: host.ioBrokerTestsystem stopInstance system.adapter.ical.3 (force=false, process=false)
          2023-07-27 20:27:04.588 - info: host.ioBrokerTestsystem stopInstance system.adapter.ical.4 (force=false, process=false)
          2023-07-27 20:27:04.589 - info: host.ioBrokerTestsystem stopInstance system.adapter.ical.5 (force=false, process=false)
          2023-07-27 20:27:04.591 - info: host.ioBrokerTestsystem stopInstance canceled schedule system.adapter.ical.5
          2023-07-27 20:27:04.593 - info: host.ioBrokerTestsystem stopInstance system.adapter.mqtt.0 (force=false, process=false)
          2023-07-27 20:27:04.595 - info: host.ioBrokerTestsystem stopInstance system.adapter.samsung-community.0 (force=false, process=true)
          2023-07-27 20:27:04.638 - info: host.ioBrokerTestsystem stopInstance system.adapter.spotify-premium.0 (force=false, process=false)
          2023-07-27 20:27:04.642 - info: host.ioBrokerTestsystem stopInstance system.adapter.tr-064.0 (force=false, process=true)
          2023-07-27 20:27:04.648 - info: host.ioBrokerTestsystem stopInstance system.adapter.unifi.0 (force=false, process=true)
          2023-07-27 20:27:04.656 - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rpc.0 (force=false, process=true)
          2023-07-27 20:27:04.662 - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rega.0 (force=false, process=true)
          2023-07-27 20:27:04.664 - info: host.ioBrokerTestsystem stopInstance system.adapter.openweathermap.0 (force=false, process=false)
          2023-07-27 20:27:04.666 - info: host.ioBrokerTestsystem stopInstance canceled schedule system.adapter.openweathermap.0
          2023-07-27 20:27:04.667 - info: host.ioBrokerTestsystem stopInstance system.adapter.backitup.0 (force=false, process=true)
          2023-07-27 20:27:04.670 - info: host.ioBrokerTestsystem stopInstance system.adapter.benchmark.0 (force=false, process=false)
          2023-07-27 20:27:04.675 - info: host.ioBrokerTestsystem stopInstance system.adapter.daswetter.0 (force=false, process=false)
          2023-07-27 20:27:04.676 - info: host.ioBrokerTestsystem stopInstance canceled schedule system.adapter.daswetter.0
          2023-07-27 20:27:04.678 - info: host.ioBrokerTestsystem stopInstance system.adapter.dwd.0 (force=false, process=false)
          2023-07-27 20:27:04.679 - info: host.ioBrokerTestsystem stopInstance canceled schedule system.adapter.dwd.0
          2023-07-27 20:27:04.682 - info: host.ioBrokerTestsystem stopInstance system.adapter.fully-tablet-control.0 (force=false, process=false)
          2023-07-27 20:27:04.683 - info: host.ioBrokerTestsystem stopInstance system.adapter.info.0 (force=false, process=true)
          2023-07-27 20:27:04.684 - info: host.ioBrokerTestsystem stopInstance system.adapter.nina.0 (force=false, process=true)
          2023-07-27 20:27:04.686 - info: host.ioBrokerTestsystem stopInstance system.adapter.proxmox.0 (force=false, process=true)
          2023-07-27 20:27:04.689 - info: host.ioBrokerTestsystem stopInstance system.adapter.rainbird.0 (force=false, process=false)
          2023-07-27 20:27:04.690 - info: host.ioBrokerTestsystem stopInstance system.adapter.sayit.0 (force=false, process=false)
          2023-07-27 20:27:04.692 - info: host.ioBrokerTestsystem stopInstance system.adapter.simple-api.0 (force=false, process=true)
          2023-07-27 20:27:04.695 - info: host.ioBrokerTestsystem stopInstance system.adapter.socketio.0 (force=false, process=false)
          2023-07-27 20:27:04.696 - info: host.ioBrokerTestsystem stopInstance system.adapter.tankerkoenig.0 (force=false, process=true)
          2023-07-27 20:27:04.698 - info: host.ioBrokerTestsystem stopInstance system.adapter.trashschedule.0 (force=false, process=true)
          2023-07-27 20:27:04.699 - info: host.ioBrokerTestsystem stopInstance system.adapter.valloxmv.0 (force=false, process=true)
          2023-07-27 20:27:04.701 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-fancyswitch.0 (force=false, process=false)
          2023-07-27 20:27:04.702 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-google-fonts.0 (force=false, process=false)
          2023-07-27 20:27:04.703 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-history.0 (force=false, process=false)
          2023-07-27 20:27:04.704 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-jqui-mfd.0 (force=false, process=false)
          2023-07-27 20:27:04.705 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-justgage.0 (force=false, process=false)
          2023-07-27 20:27:04.706 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-map.0 (force=false, process=false)
          2023-07-27 20:27:04.707 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-materialdesign.0 (force=false, process=false)
          2023-07-27 20:27:04.708 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-timeandweather.0 (force=false, process=false)
          2023-07-27 20:27:04.710 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis.0 (force=false, process=false)
          2023-07-27 20:27:04.711 - info: host.ioBrokerTestsystem stopInstance system.adapter.web.0 (force=false, process=true)
          2023-07-27 20:27:04.712 - info: host.ioBrokerTestsystem stopInstance system.adapter.worx.0 (force=false, process=false)
          2023-07-27 20:27:04.713 - info: host.ioBrokerTestsystem stopInstance system.adapter.device-watcher.0 (force=false, process=true)
          2023-07-27 20:27:04.715 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-2-beta.0 (force=false, process=true)
          2023-07-27 20:27:04.716 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-metro.0 (force=false, process=false)
          2023-07-27 20:27:04.718 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-2-widgets-jaeger-design.0 (force=false, process=false)
          2023-07-27 20:27:04.719 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-2-widgets-energy.0 (force=false, process=false)
          2023-07-27 20:27:04.720 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-2-widgets-gauges.0 (force=false, process=false)
          2023-07-27 20:27:04.729 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-2-widgets-material.0 (force=false, process=false)
          2023-07-27 20:27:04.730 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-inventwo.0 (force=false, process=true)
          2023-07-27 20:27:04.928 - info: unifi.0 (478) Got terminate signal TERMINATE_YOURSELF
          2023-07-27 20:27:04.930 - info: hm-rpc.0 (502) Got terminate signal TERMINATE_YOURSELF
          2023-07-27 20:27:04.934 - info: info.0 (598) Got terminate signal TERMINATE_YOURSELF
          2023-07-27 20:27:04.946 - info: backitup.0 (550) Got terminate signal TERMINATE_YOURSELF
          2023-07-27 20:27:04.908 - info: scenes.0 (371) terminating
          2023-07-27 20:27:04.925 - info: samsung-community.0 (447) Got terminate signal TERMINATE_YOURSELF
          2023-07-27 20:27:04.954 - info: proxmox.0 (642) Got terminate signal TERMINATE_YOURSELF
          2023-07-27 20:27:04.954 - info: scenes.0 (371) Terminated (NO_ERROR): Without reason
          2023-07-27 20:27:04.949 - info: simple-api.0 (658) Got terminate signal TERMINATE_YOURSELF
          2023-07-27 20:27:04.933 - info: hm-rega.0 (522) Got terminate signal TERMINATE_YOURSELF
          2023-07-27 20:27:04.944 - info: nina.0 (614) Got terminate signal TERMINATE_YOURSELF
          2023-07-27 20:27:04.962 - info: scenes.0 (371) Got terminate signal TERMINATE_YOURSELF
          2023-07-27 20:27:04.945 - info: tankerkoenig.0 (680) Got terminate signal TERMINATE_YOURSELF
          2023-07-27 20:27:04.926 - info: tr-064.0 (462) Got terminate signal TERMINATE_YOURSELF
          2023-07-27 20:27:04.957 - info: fritzbox.0 (417) Got terminate signal TERMINATE_YOURSELF
          2023-07-27 20:27:04.915 - info: admin.0 (337) Got terminate signal TERMINATE_YOURSELF
          2023-07-27 20:27:04.918 - info: javascript.0 (348) Got terminate signal TERMINATE_YOURSELF
          2023-07-27 20:27:04.920 - info: scheduler.0 (398) Got terminate signal TERMINATE_YOURSELF
          2023-07-27 20:27:04.980 - info: trashschedule.0 (747) Got terminate signal TERMINATE_YOURSELF
          2023-07-27 20:27:04.981 - info: valloxmv.0 (771) Got terminate signal TERMINATE_YOURSELF
          2023-07-27 20:27:04.987 - info: web.0 (917) Got terminate signal TERMINATE_YOURSELF
          2023-07-27 20:27:05.003 - info: device-watcher.0 (933) Got terminate signal TERMINATE_YOURSELF
          2023-07-27 20:27:05.011 - info: vis-inventwo.0 (1025) Got terminate signal TERMINATE_YOURSELF
          2023-07-27 20:27:05.007 - info: vis-2-beta.0 (1014) Got terminate signal TERMINATE_YOURSELF
          2023-07-27 20:27:05.024 - info: fritzbox.0 (417) terminating
          2023-07-27 20:27:05.024 - info: tr-064.0 (462) terminating
          2023-07-27 20:27:05.028 - info: fritzbox.0 (417) Terminated (NO_ERROR): Without reason
          2023-07-27 20:27:05.024 - info: scheduler.0 (398) terminating
          2023-07-27 20:27:05.033 - info: unifi.0 (478) terminating
          2023-07-27 20:27:05.035 - info: hm-rpc.0 (502) terminating
          2023-07-27 20:27:05.032 - info: tr-064.0 (462) Terminated (NO_ERROR): Without reason
          2023-07-27 20:27:05.032 - info: samsung-community.0 (447) terminating
          2023-07-27 20:27:05.028 - info: scheduler.0 (398) Terminated (NO_ERROR): Without reason
          2023-07-27 20:27:05.039 - info: backitup.0 (550) terminating
          2023-07-27 20:27:05.038 - info: unifi.0 (478) Terminated (NO_ERROR): Without reason
          2023-07-27 20:27:05.038 - info: hm-rpc.0 (502) Terminated (NO_ERROR): Without reason
          2023-07-27 20:27:05.040 - info: samsung-community.0 (447) Terminated (NO_ERROR): Without reason
          2023-07-27 20:27:05.038 - info: nina.0 (614) terminating
          2023-07-27 20:27:05.036 - info: proxmox.0 (642) terminating
          2023-07-27 20:27:05.054 - info: trashschedule.0 (747) terminating
          2023-07-27 20:27:05.054 - info: vis-inventwo.0 (1025) terminating
          2023-07-27 20:27:05.044 - info: javascript.0 (348) terminating
          2023-07-27 20:27:05.057 - info: javascript.0 (348) Terminated (NO_ERROR): Without reason
          2023-07-27 20:27:05.064 - info: vis-2-beta.0 (1014) terminating
          2023-07-27 20:27:05.057 - info: vis-inventwo.0 (1025) Terminated (NO_ERROR): Without reason
          2023-07-27 20:27:05.053 - info: info.0 (598) terminating
          2023-07-27 20:27:05.057 - info: device-watcher.0 (933) terminating
          2023-07-27 20:27:05.067 - info: vis-2-beta.0 (1014) Terminated (NO_ERROR): Without reason
          2023-07-27 20:27:05.059 - info: valloxmv.0 (771) terminating
          2023-07-27 20:27:05.055 - info: simple-api.0 (658) terminating
          2023-07-27 20:27:05.053 - info: tankerkoenig.0 (680) terminating
          2023-07-27 20:27:05.048 - info: nina.0 (614) Terminated (NO_ERROR): Without reason
          2023-07-27 20:27:05.058 - info: admin.0 (337) terminating
          2023-07-27 20:27:05.049 - info: backitup.0 (550) Terminated (NO_ERROR): Without reason
          2023-07-27 20:27:05.077 - info: trashschedule.0 (747) Terminated (NO_ERROR): Without reason
          2023-07-27 20:27:05.047 - info: proxmox.0 (642) Terminated (NO_ERROR): Without reason
          2023-07-27 20:27:05.083 - info: device-watcher.0 (933) Terminated (NO_ERROR): Without reason
          2023-07-27 20:27:05.083 - info: info.0 (598) Terminated (NO_ERROR): Without reason
          2023-07-27 20:27:05.097 - info: simple-api.0 (658) Terminated (NO_ERROR): Without reason
          2023-07-27 20:27:05.078 - info: valloxmv.0 (771) Terminated (NO_ERROR): Without reason
          2023-07-27 20:27:05.094 - info: tankerkoenig.0 (680) Terminated (NO_ERROR): Without reason
          2023-07-27 20:27:05.086 - info: admin.0 (337) Terminated (NO_ERROR): Without reason
          2023-07-27 20:27:05.132 - warn: web.0 (917) Timeout by termination of web-extensions!
          2023-07-27 20:27:05.137 - info: web.0 (917) terminated http server on port 8082
          2023-07-27 20:27:05.177 - info: host.ioBrokerTestsystem stopInstance system.adapter.admin.0 send kill signal
          2023-07-27 20:27:05.205 - info: host.ioBrokerTestsystem stopInstance system.adapter.javascript.0 send kill signal
          2023-07-27 20:27:05.207 - info: host.ioBrokerTestsystem stopInstance system.adapter.scenes.0 send kill signal
          2023-07-27 20:27:05.208 - info: host.ioBrokerTestsystem stopInstance system.adapter.scheduler.0 send kill signal
          2023-07-27 20:27:05.209 - info: host.ioBrokerTestsystem stopInstance system.adapter.fritzbox.0 send kill signal
          2023-07-27 20:27:05.210 - info: host.ioBrokerTestsystem stopInstance system.adapter.samsung-community.0 send kill signal
          2023-07-27 20:27:05.212 - info: host.ioBrokerTestsystem stopInstance system.adapter.tr-064.0 send kill signal
          2023-07-27 20:27:05.213 - info: host.ioBrokerTestsystem stopInstance system.adapter.unifi.0 send kill signal
          2023-07-27 20:27:05.214 - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rpc.0 send kill signal
          2023-07-27 20:27:05.215 - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rega.0 send kill signal
          2023-07-27 20:27:05.216 - info: host.ioBrokerTestsystem stopInstance system.adapter.backitup.0 send kill signal
          2023-07-27 20:27:05.218 - info: host.ioBrokerTestsystem stopInstance system.adapter.info.0 send kill signal
          2023-07-27 20:27:05.219 - info: host.ioBrokerTestsystem stopInstance system.adapter.nina.0 send kill signal
          2023-07-27 20:27:05.220 - info: host.ioBrokerTestsystem stopInstance system.adapter.proxmox.0 send kill signal
          2023-07-27 20:27:05.222 - info: host.ioBrokerTestsystem stopInstance system.adapter.simple-api.0 send kill signal
          2023-07-27 20:27:05.223 - info: host.ioBrokerTestsystem stopInstance system.adapter.tankerkoenig.0 send kill signal
          2023-07-27 20:27:05.224 - info: host.ioBrokerTestsystem stopInstance system.adapter.trashschedule.0 send kill signal
          2023-07-27 20:27:05.226 - info: host.ioBrokerTestsystem stopInstance system.adapter.valloxmv.0 send kill signal
          2023-07-27 20:27:05.227 - info: host.ioBrokerTestsystem stopInstance system.adapter.web.0 send kill signal
          2023-07-27 20:27:05.228 - info: host.ioBrokerTestsystem stopInstance system.adapter.device-watcher.0 send kill signal
          2023-07-27 20:27:05.228 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-2-beta.0 send kill signal
          2023-07-27 20:27:05.229 - info: host.ioBrokerTestsystem stopInstance system.adapter.vis-inventwo.0 send kill signal
          2023-07-27 20:27:05.288 - info: scenes.0 (371) terminating
          2023-07-27 20:27:05.351 - info: scheduler.0 (398) terminating
          2023-07-27 20:27:05.344 - info: fritzbox.0 (417) terminating
          2023-07-27 20:27:05.361 - info: unifi.0 (478) terminating
          2023-07-27 20:27:05.347 - info: tr-064.0 (462) terminating
          2023-07-27 20:27:05.367 - info: hm-rega.0 (522) terminating
          2023-07-27 20:27:05.367 - info: backitup.0 (550) terminating
          2023-07-27 20:27:05.374 - info: device-watcher.0 (933) terminating
          2023-07-27 20:27:05.368 - info: web.0 (917) terminating
          2023-07-27 20:27:05.375 - info: vis-2-beta.0 (1014) terminating
          2023-07-27 20:27:05.377 - info: trashschedule.0 (747) terminating
          2023-07-27 20:27:05.377 - info: valloxmv.0 (771) terminating
          2023-07-27 20:27:05.369 - info: tankerkoenig.0 (680) terminating
          2023-07-27 20:27:05.383 - info: hm-rega.0 (522) Terminated (NO_ERROR): Without reason
          2023-07-27 20:27:05.383 - info: javascript.0 (348) terminating
          2023-07-27 20:27:05.348 - info: samsung-community.0 (447) terminating
          2023-07-27 20:27:05.373 - info: simple-api.0 (658) terminating
          2023-07-27 20:27:05.350 - info: nina.0 (614) terminating
          2023-07-27 20:27:05.374 - info: vis-inventwo.0 (1025) terminating
          2023-07-27 20:27:05.370 - info: info.0 (598) terminating
          2023-07-27 20:27:05.403 - info: admin.0 (337) terminating
          2023-07-27 20:27:05.407 - info: proxmox.0 (642) terminating
          2023-07-27 20:27:05.408 - info: web.0 (917) Terminated (NO_ERROR): Without reason
          2023-07-27 20:27:05.414 - info: web.0 (917) terminating
          2023-07-27 20:27:05.484 - info: hm-rega.0 (522) terminating
          2023-07-27 20:27:05.573 - warn: hm-rpc.0 (502) get state error: Connection is closed.
          2023-07-27 20:27:05.576 - info: hm-rpc.0 (502) terminating
          2023-07-27 20:27:05.785 - info: host.ioBrokerTestsystem instance system.adapter.scenes.0 terminated with code 0 (NO_ERROR)
          2023-07-27 20:27:06.037 - info: hm-rega.0 (522) terminating with timeout
          2023-07-27 20:27:06.144 - info: web.0 (917) terminating with timeout
          2023-07-27 20:27:06.177 - info: admin.0 (337) terminating with timeout
          2023-07-27 20:27:06.210 - info: host.ioBrokerTestsystem stopInstance system.adapter.admin.0 killing pid 337
          2023-07-27 20:27:06.564 - info: host.ioBrokerTestsystem instance system.adapter.scheduler.0 terminated with code 0 (NO_ERROR)
          2023-07-27 20:27:06.571 - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rega.0 killing pid 522
          2023-07-27 20:27:06.573 - info: host.ioBrokerTestsystem stopInstance system.adapter.web.0 killing pid 917
          2023-07-27 20:27:08.661 - info: host.ioBrokerTestsystem instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
          2023-07-27 20:27:08.884 - info: host.ioBrokerTestsystem instance system.adapter.fritzbox.0 terminated with code 0 (NO_ERROR)
          2023-07-27 20:27:08.886 - info: host.ioBrokerTestsystem instance system.adapter.samsung-community.0 terminated with code 0 (NO_ERROR)
          2023-07-27 20:27:09.007 - info: host.ioBrokerTestsystem instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
          2023-07-27 20:27:09.009 - info: host.ioBrokerTestsystem instance system.adapter.unifi.0 terminated with code 0 (NO_ERROR)
          2023-07-27 20:27:09.052 - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
          2023-07-27 20:27:09.159 - info: host.ioBrokerTestsystem instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
          2023-07-27 20:27:09.160 - info: host.ioBrokerTestsystem instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
          2023-07-27 20:27:09.279 - info: host.ioBrokerTestsystem instance system.adapter.nina.0 terminated with code 0 (NO_ERROR)
          2023-07-27 20:27:09.281 - info: host.ioBrokerTestsystem instance system.adapter.proxmox.0 terminated with code 0 (NO_ERROR)
          2023-07-27 20:27:09.343 - info: host.ioBrokerTestsystem instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
          2023-07-27 20:27:09.508 - info: host.ioBrokerTestsystem instance system.adapter.tankerkoenig.0 terminated with code 0 (NO_ERROR)
          2023-07-27 20:27:09.509 - info: host.ioBrokerTestsystem instance system.adapter.trashschedule.0 terminated with code 0 (NO_ERROR)
          2023-07-27 20:27:09.586 - info: host.ioBrokerTestsystem instance system.adapter.valloxmv.0 terminated with code 0 (NO_ERROR)
          2023-07-27 20:27:09.587 - info: host.ioBrokerTestsystem instance system.adapter.device-watcher.0 terminated with code 0 (NO_ERROR)
          2023-07-27 20:27:09.653 - info: host.ioBrokerTestsystem instance system.adapter.vis-2-beta.0 terminated with code 0 (NO_ERROR)
          2023-07-27 20:27:09.758 - info: host.ioBrokerTestsystem instance system.adapter.vis-inventwo.0 terminated with code 0 (NO_ERROR)
          2023-07-27 20:27:09.760 - info: host.ioBrokerTestsystem All instances are stopped.
          2023-07-27 20:27:09.763 - warn: host.ioBrokerTestsystem instance system.adapter.admin.0 terminated due to SIGTERM
          2023-07-27 20:27:09.764 - info: host.ioBrokerTestsystem instance system.adapter.admin.0 terminated with code null ()
          2023-07-27 20:27:09.765 - info: host.ioBrokerTestsystem All instances are stopped.
          2023-07-27 20:27:10.054 - warn: host.ioBrokerTestsystem instance system.adapter.hm-rega.0 terminated due to SIGTERM
          2023-07-27 20:27:10.055 - info: host.ioBrokerTestsystem instance system.adapter.hm-rega.0 terminated with code null ()
          2023-07-27 20:27:10.056 - info: host.ioBrokerTestsystem All instances are stopped.
          2023-07-27 20:27:10.098 - warn: host.ioBrokerTestsystem instance system.adapter.web.0 terminated due to SIGTERM
          2023-07-27 20:27:10.099 - info: host.ioBrokerTestsystem instance system.adapter.web.0 terminated with code null ()
          2023-07-27 20:27:10.100 - info: host.ioBrokerTestsystem All instances are stopped.
          2023-07-27 20:27:10.195 - info: host.ioBrokerTestsystem terminated
          2023-07-27 20:27:14.476 - info: host.ioBrokerTestsystem [CONTROLLER_AUTO_UPGRADE] Successfully stopped js-controller
          2023-07-27 20:27:14.490 - info: host.ioBrokerTestsystem [CONTROLLER_AUTO_UPGRADE] Server is running on http://localhost:8081
          2023-07-27 20:40:16.918 - info: host.ioBrokerTestsystem iobroker.js-controller version 5.0.8 js-controller starting
          2023-07-27 20:40:16.931 - info: host.ioBrokerTestsystem Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
          2023-07-27 20:40:16.934 - info: host.ioBrokerTestsystem hostname: ioBrokerTestsystem, node: v18.17.0
          2023-07-27 20:40:16.937 - info: host.ioBrokerTestsystem ip addresses: 192.168.178.77 fe80::f854:cfff:fe5f:6c25
          2023-07-27 20:40:20.323 - info: host.ioBrokerTestsystem connected to Objects and States
          2023-07-27 20:40:20.418 - info: host.ioBrokerTestsystem added notifications configuration of host
          2023-07-27 20:40:21.798 - info: host.ioBrokerTestsystem Delete state "system.host.ioBrokerTestsystem.versions.nodeCurrent"
          2023-07-27 20:40:21.802 - info: host.ioBrokerTestsystem 63 instances found
          2023-07-27 20:40:21.935 - info: host.ioBrokerTestsystem starting 33 instances
          • foxriver76
            foxriver76 Developer @Feuersturm last edited by
            @feuersturm hm ok dann haben wir in 5.0.8 irgendwas kaputt gemacht, schauen wir uns an.
            • NinjaTurtle85
              NinjaTurtle85 last edited by
              Ich kann seid dem Upgrade auf 5.0.9 keine Datenpunkte mehr in 0_userdata erstellen.
                A Former User @NinjaTurtle85 last edited by A Former User
                @ninjaturtle85 sagte in js-controller 5.0.x jetzt in der BETA:
                Stimmt, ist hier auch so, Browser Safari, das Popup kommt, ich Füll es aus, aber es lässt sich nur mit abbrechen schließen..
                Issue erstellt https://github.com/ioBroker/ioBroker.js-controller/issues/2364
                Ilovegym66 created this issue in ioBroker/ioBroker.js-controller
                closed 5.0.9 - can't add Objects in userdata #2004
                • foxriver76
                  foxriver76 Developer @Guest last edited by
                  @ilovegym Liegt mit 99 % Wahrscheinlichkeit am Admin Update
                  • DJMarc75
                    DJMarc75 last edited by
                    @NinjaTurtle85 @ilovegym @foxriver76
                    eben auch auf die Admin 6.6.3 gehoben und da scheint das Problem zu liegen - keine neuen Datenpunkte unter
                    0_userdata
                    erstellbar.
                    Zurück zu 6.6.1 - geht wieder
                    • ESP8266
                      ESP8266 last edited by
                      @djmarc75 , kann ich bestätigen.
                      • Feuersturm
                        Manuelles update auf 5.0.9 war auf meinem Master + Slave erfolgreich. Bisher keine Auffälligkeiten.
                        • foxriver76
                          foxriver76 Developer last edited by foxriver76
                          5.0.10 auf dem Weg
                          • Fixt das UI Upgrade Problem, wie gewohnt allerdings dann erst auf eine Folgeversion, sprich 5.0.8/5.0.9 auf 5.0.10 wird nicht via UI gehen
                          • Verbessertes Logging wenn der UI Upgrade Prozess crasht
                          • Für Devs: Die offiziellen Types von adapter-core Version 3 werden nun aus dem Controller direkt genommen, bei Problemen bitte im Controller ein Issue anlegen
                          ? 1 Reply Last reply Reply Quote 3
                            A Former User @foxriver76 last edited by
                            @foxriver76 sagte in js-controller 5.0.x jetzt in der BETA:
                            5.0.10 auf dem Weg
                            Moin,
                            bei mir wieder das gleiche Verhalten, wie beim Update von 5.0.8 -> 5.0.9
                            [iobroker@arch-iob iobroker]$ tail -f log/iobroker.current.log
                            2023-07-29 10:45:53.318  - warn: host.arch-iob instance system.adapter.web.0 terminated due to SIGTERM
                            2023-07-29 10:45:53.318  - info: host.arch-iob instance system.adapter.web.0 terminated with code null ()
                            2023-07-29 10:45:53.347  - info: host.arch-iob instance system.adapter.zigbee2mqtt.0 terminated with code 0 (NO_ERROR)
                            2023-07-29 10:45:55.181  - info: meross.0 (15291) terminating
                            2023-07-29 10:45:55.182  - info: meross.0 (15291) Terminated (NO_ERROR): Without reason
                            2023-07-29 10:45:55.729  - info: host.arch-iob instance system.adapter.meross.0 terminated with code 0 (NO_ERROR)
                            2023-07-29 10:45:55.729  - info: host.arch-iob All instances are stopped.
                            2023-07-29 10:45:55.805  - info: host.arch-iob terminated
                            2023-07-29 10:45:59.869  - info: host.arch-iob [CONTROLLER_AUTO_UPGRADE] Successfully stopped js-controller
                            2023-07-29 10:45:59.874  - info: host.arch-iob [CONTROLLER_AUTO_UPGRADE] Server is running on http://localhost:8081
                            [iobroker@arch-iob iobroker]$ iob stop
                            [iobroker@arch-iob iobroker]$ iob update
                            Used repository: live-beta
                            Adapter    "admin"        : 6.6.4    , installed 6.6.4
                            Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
                            Adapter    "device-watcher": 2.9.3   , installed 2.9.3
                            Adapter    "esphome"      : 0.2.4    , installed 0.2.4
                            Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                            Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                            Adapter    "hoover"       : 0.1.0    , installed 0.1.0
                            Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                            Adapter    "iqontrol"     : 2.3.0    , installed 3.0.0-alpha0.1
                            Adapter    "javascript"   : 7.1.1    , installed 7.1.1
                            Controller "js-controller": 5.0.10   , installed 5.0.9  [Updatable]
                            Adapter    "meross"       : 1.15.1   , installed 1.15.1
                            Adapter    "mpd"          : 1.1.1    , installed 1.1.1
                            Adapter    "openweathermap": 0.3.11  , installed 0.3.11
                            Adapter    "snmp"         : 2.4.11   , installed 2.4.11
                            Adapter    "socketio"     : 6.4.0    , installed 6.4.0
                            Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
                            Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                            Adapter    "synochat"     : 1.3.0    , installed 1.3.0
                            Adapter    "tapo"         : 0.0.8    , installed 0.0.8
                            Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                            Adapter    "vw-connect"   : 0.0.72   , installed 0.0.72
                            Adapter    "web"          : 6.0.3    , installed 6.0.3
                            Adapter    "wolf-smartset": 1.1.1    , installed 1.1.1
                            Adapter    "ws"           : 2.4.0    , installed 2.4.0
                            Adapter    "zigbee2mqtt"  : 2.9.0    , installed 2.9.0
                            [iobroker@arch-iob iobroker]$ iob upgrade self
                            Update js-controller from @5.0.9 to @5.0.10
                            Stopped Objects DB
                            Stopped States DB
                            NPM version: 9.8.1
                            Installing iobroker.js-controller@5.0.10... (System call)
                            changed 12 packages in 30s
                            85 packages are looking for funding
                              run `npm fund` for details
                            [iobroker@arch-iob iobroker]$ iob start
                            Nach Update per Konsole/Terminal alles ok.
                            VG
                            Bernd
                            P.S.: ist vielleicht aber nur mein Problem, da ich nicht Debian, sondern Arch Linux nutze.
                            P.P.S.: Infos zum System
                                Plattform: linux
                                Betriebssystem: linux
                                Architektur: x64
                                CPUs: 4
                                Geschwindigkeit: 3200 MHz
                                Modell: AMD Phenom(tm) II X4 955 Processor
                                RAM: 4 GB
                                System-Betriebszeit: 2 T. 18:14:28
                                Node.js: v18.16.0
                                time: 1690620931252
                                timeOffset: -120
                                Adapter-Anzahl: 578
                                NPM: 9.8.1
                                Datenträgergröße: 8.0 GB
                                Freier Festplattenspeicher: 4.9 GB
                                Betriebszeit: 00:03:57
                                Aktive Instanzen: 21
                                Pfad: /opt/iobroker/
                                aktiv:
                            • foxriver76
                              @dp20eic gerne lesen was da sonst noch steht außer „1.0.20 auf dem Weg“ vielleicht erklärt es dir ja das Verhalten
                                Vertipper? 🙂
                                • foxriver76
                                  foxriver76 Developer @ticaki last edited by
                                  @ticaki Ups da war ich irgendwo bei der App Version in der Nähe 😄
                                  • ESP8266
                                    ESP8266 last edited by ESP8266
                                    Ich habe in letzter Zeit immer mehr das Problem, das sich die Sidebar nicht aufbaut und leer bleibt, weil ein Timeout abgelaufen ist. Bei der zigsten Brouser aktualisierung klapp es dann mal wieder. Es wird langsam zum Glücksspiel.
                                    Edit: Ich besitze keine Hochleistungrechner.
                                      A Former User @ESP8266 last edited by
                                      @esp8266
                                      Redis, JSON oder file?
                                      Version von Admin ?
                                      • ESP8266
                                        @ilovegym , einfach das öffnen von iob im Brouser. Egal welche Sitzung ich hatte. Javascript, Objekte, Logs etc.
                                        Admin 6.6.1
                                        Wenn alles da ist, ich mich im Hauptfenster bewege und zwischen den Ojekten, Instanzen, Javascript switche, gibt es keine Probleme. Nur beim Aktualiseren der Seite mit F5 etc.
                                        Das ganze passiert meistens auch, wenn ich die Rechner gerade hoch gefahren habe. Der Hauptrecher hängt am GB Lan und Schleppi im 5GHz Wlan.
                                        Es ist nicht immer aber sporadisch und wird in letzer Zeit immer heftiger. Manchmal braucht es bis zu 10 Aktualisierungen. Es erschient immer ein Timeout. Das muss man doch irgendwo einstellen können.
                                        und die linke Spalte bleibt dann leer.
                                        Gerade eins Ertappt.
                                        amg_666 ESP8266 2 Replies Last reply Reply Quote 0
                                        • amg_666
                                          amg_666 @ESP8266 last edited by
                                          Update von 5.0.8 auf 5.0.10 über Admin-Oberfläche klappt bei mir nicht.
                                          iob multihost, update auf dem Slave (pi 3b) hat funktioniert. Update des Masters bringt immer die Fehlermeldung
                                          und danach passiert nix mehr. Ich habe das mehrfach versucht, dachte dass da vielleicht temporär was klemmt, komme aber immer wieder auf das Ergebnis.
                                          Wenn ich den iob dann über Konsole neu starte läuft er wieder, aber eben noch mit 5.0.8
                                          iob auf proxmox container (debian12), node.js 18.17.0, npm 9.6.7, der raspberry slave hat denselben Stand.
                                            crunchip Forum Testing Most Active @amg_666 last edited by
                                            @amg_666 liest du hier auch mit?
                                            wenn 5.08 auf.9 nicht geht, warum soll es dann auf .10 funktionieren??
                                            amg_666 1 Reply Last reply Reply Quote 1
                                            580
                                            184934
