    4. Support Adapter Energiefluss-erweitert v0.7.7
    • SKB
      SKB Developer Most Active @andi2055 last edited by
      @andi2055 was heißt die Animation funktioniert nicht mehr?
      Wie sieht es denn aus?
      Fehler im Log?
      Wo kannst Du keinen Alias auswählen?
        andi2055 @SKB last edited by andi2055
        @skb
        ja, hätte direkt mehr Infos geben können...
        Also die Linien sind einfach schwarz und nicht animiert
        Vor dem Update hatte es noch funktioniert
        Und wie geschrieben: auch mit einer neuen Instanz probiert.
        Im Log steht Folgendes - ich sehe aber keinen Fehler
        2023-07-29 18:21:30.662 - info: energiefluss-erweitert.0 (1113) Adapter started. Loading config!
        2023-07-29 18:21:30.684 - debug: energiefluss-erweitert.0 (1113) {"basic":{"enable_grid":true,"enable_animation":false,"enable_area_catch":true,"enable_config_icon":true,"enable_last_id":false,"enable_icon_proxy":false,"height":540,"width":530,"styles":"background-color: black","font":{"family":"\"Arial\", sans-serif","size":"20","color":"#1D00FF","fill":"#FF0000","align":"middle"},"rect":{"height":100,"width":100,"corners":10},"circle":{"radius":50},"elm":{"stroke_width":5,"color":"#1500FF","fill":"#FF0000","pos_x":50,"pos_y":50},"icon":{"height":24,"width":24,"color":"#0C00FF"}},"calculation":{"battery":{"dod":0,"capacity":0,"percent":null,"charge":null,"charge_prop":false,"charge_kw":false,"discharge":null,"discharge_prop":false,"discharge_kw":false}},"animation":{"stroke":"#ffce4a","stroke_dasharray":"10 17 10 17 10 72","stroke_width":6,"animation_duration":2000,"stroke_linecap":"round","animation_timing_function":"linear"},"animation_configuration":{"dots":3,"distance":17,"length":10},"line":{"stroke_width":8,"stroke":"#000000"},"elements":{"2":{"type":"text","subType":"datasource","id":2,"pos_x":106,"pos_y":84,"color":"none","fill":"rgb(255, 206, 74)","font_family":"Arial, sans-serif","font_size":18,"degree":0,"align":"middle","text":"ID 2","unit":"W","append":"","prepend":"","source":0,"source_option":-1,"source_display":"value","shadow":"","threshold":0,"calculate_kw":false,"convert":false,"decimal_places":0,"subtract":[-1],"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"6":{"type":"icon","id":"6","icon":"material-symbols:solar-power","width":24,"height":24,"color":"rgb(255, 206, 74)","pos_x":"94","pos_y":"47","shadow":"","css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":"","source":-1,"threshold":0},"7":{"type":"rect","id":7,"rx":10,"height":100,"width":100,"pos_x":192,"pos_y":201,"fill":"none","color":"rgb(242, 116, 44)","stroke":3,"shadow":"","frame":"_overlay","url":"","fill_value":null,"fill_type":"percent","fill_direction":90,"fill_max":null,"border_value":null,"border_type":-1,"border_direction":"cw","border_style":"round","border_max":null,"border_reverse_value":null,"border_reverse":false,"border_start":180,"source":-1,"threshold":0,"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"9":{"type":"text","subType":"datasource","id":9,"pos_x":242,"pos_y":243,"color":"none","fill":"rgb(242, 116, 44)","font_family":"Arial, sans-serif","font_size":18,"degree":0,"align":"middle","text":"ID 9","unit":"W","append":"","prepend":"","source":4,"source_option":-1,"source_display":"value","shadow":"","threshold":0,"calculate_kw":false,"convert":false,"decimal_places":0,"subtract":[-1],"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"10":{"type":"text","id":10,"pos_x":108,"pos_y":115,"color":"none","fill":"rgb(255, 206, 74)","font_family":"Arial, sans-serif","font_size":14,"degree":0,"align":"middle","text":"PV","shadow":"","css_general":""},"11":{"type":"text","id":11,"pos_x":242,"pos_y":277,"color":"none","fill":"rgb(242, 116, 44)","font_family":"Arial, sans-serif","font_size":14,"degree":0,"align":"middle","text":"Verbrauch","shadow":"","css_general":""},"12":{"type":"icon","id":"12","icon":"mdi:house-city","width":24,"height":24,"color":"rgb(242, 116, 44)","pos_x":"230","pos_y":"207","shadow":"","css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":"","source":1,"threshold":0},"14":{"type":"rect","id":14,"rx":10,"height":100,"width":100,"pos_x":56,"pos_y":367,"fill":"none","color":"rgba(97, 104, 122, 0.7)","stroke":3,"shadow":"","frame":"_overlay","url":"","fill_value":null,"fill_type":"percent","fill_direction":90,"fill_max":null,"border_value":null,"border_type":-1,"border_direction":"cw","border_style":"round","border_max":null,"border_reverse_value":null,"border_reverse":false,"border_start":180,"source":-1,"threshold":0,"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"19":{"type":"text","subType":"datasource","id":19,"pos_x":106,"pos_y":409,"color":"none","fill":"rgb(190, 195, 202)","font_family":"Arial, sans-serif","font_size":18,"degree":0,"align":"middle","text":"ID 19","unit":"W","append":"","prepend":"","source":3,"source_option":-1,"source_display":"value","shadow":"","threshold":0,"calculate_kw":false,"convert":false,"decimal_places":0,"subtract":[-1],"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"20":{"type":"icon","id":"20","icon":"mdi:electricity-from-grid","width":24,"height":24,"color":"rgb(190, 195, 202)","pos_x":"94","pos_y":"372","shadow":"","css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":"","source":-1,"threshold":0},"21":{"type":"text","id":21,"pos_x":106,"pos_y":443,"color":"none","fill":"rgb(190, 195, 202)","font_family":"Arial, sans-serif","font_size":14,"degree":0,"align":"middle","text":"Netz","shadow":"","css_general":""},"22":{"type":"rect","id":22,"rx":10,"height":100,"width":100,"pos_x":376,"pos_y":280,"fill":"none","color":"rgb(25, 207, 25)","stroke":3,"shadow":"","frame":"_overlay","url":"","fill_value":null,"fill_type":"percent","fill_direction":90,"fill_max":null,"border_value":null,"border_type":-1,"border_direction":"cw","border_style":"round","border_max":null,"border_reverse_value":null,"border_reverse":false,"border_start":180,"source":2,"threshold":0,"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"23":{"type":"icon","id":"23","icon":"material-symbols:heat-pump-outline","width":24,"height":24,"color":"rgb(25, 207, 25)","pos_x":"413","pos_y":"286","shadow":"","css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":"","source":-1,"threshold":0},"24":{"type":"text","id":24,"pos_x":425,"pos_y":356,"color":"none","fill":"rgb(25, 207, 25)","font_family":"Arial, sans-serif","font_size":14,"degree":0,"align":"middle","text":"LWP","shadow":"","css_general":""},"26":{"type":"text","subType":"datasource","id":26,"pos_x":426,"pos_y":321,"color":"none","fill":"rgb(25, 207, 25)","font_family":"Arial, sans-serif","font_size":18,"degree":0,"align":"middle","text":"ID 26","unit":"W","append":"","prepend":"","source":2,"source_option":-1,"source_display":"value","shadow":"","threshold":0,"calculate_kw":false,"convert":false,"decimal_places":0,"subtract":[-1],"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"28":{"type":"rect","id":28,"rx":10,"height":100,"width":100,"pos_x":372,"pos_y":123,"fill":"none","color":"rgb(37, 214, 254)","stroke":3,"shadow":"","frame":"_overlay","url":"","fill_value":null,"fill_type":-1,"fill_direction":90,"fill_max":null,"border_value":null,"border_type":-1,"border_direction":"cw","border_style":"round","border_max":null,"border_reverse_value":null,"border_reverse":false,"border_start":180,"source":1,"threshold":0,"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"29":{"type":"icon","id":"29","icon":"mdi:house","width":24,"height":24,"color":"rgb(0, 181, 221)","pos_x":"408","pos_y":"125","shadow":"","css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":"","source":-1,"threshold":0},"30":{"type":"text","id":30,"pos_x":395,"pos_y":203,"color":"none","fill":"rgb(142, 224, 227)","font_family":"Arial, sans-serif","font_size":20,"degree":0,"align":"start","text":"Haus","shadow":"","css_general":""},"33":{"type":"text","subType":"datasource","id":33,"pos_x":421,"pos_y":172,"color":"none","fill":"rgb(0, 181, 221)","font_family":"Arial, sans-serif","font_size":18,"degree":0,"align":"middle","text":"ID 33","unit":"W","append":"","prepend":"","source":1,"source_option":-1,"source_display":"value","shadow":"","threshold":0,"calculate_kw":false,"convert":false,"decimal_places":0,"subtract":[-1],"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"34":{"type":"circle","id":34,"radius":60,"pos_x":106,"pos_y":82,"fill":"none","color":"rgb(255, 225, 31)","stroke":3,"shadow":"","frame":"_overlay","url":"","fill_value":null,"fill_type":"-1","fill_direction":"90","fill_max":"0","border_value":null,"border_type":"-1","border_direction":"cw","border_style":"round","border_max":"0","border_reverse_value":null,"border_reverse":false,"border_start":"180","source":-1,"threshold":0,"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""}},"defs":{"path_14_7":{"type":"def","id":"path_14_7","d":"M126 365.5 V 352.9 A 15 15 0 0 1 141 337.9 H 207 A 15 15 0 0 0 222 322.9 V 302.5","startSlot":"top_right","endSlot":"bottom_left"},"path_7_22":{"type":"def","id":"path_7_22","d":"M293.5 271 H 309.7 A 15 15 0 0 1 324.7 286 V 315 A 15 15 0 0 0 339.7 330 H 374.5","startSlot":"right_bottom","endSlot":"left"},"path_7_28":{"type":"def","id":"path_7_28","d":"M293.5 231 H 308.9 A 15 15 0 0 0 323.9 216 V 188 A 15 15 0 0 1 338.9 173 H 370.5","startSlot":"right_top","endSlot":"left"},"path_7_34":{"type":"def","id":"path_7_34","d":"M190.5 251 H 177.9 H 141.52120859954013 A 15 15 0 0 1 126.52120859954013 236 V 139.8815572471545","startSlot":"left","endSlot":"bottom_right"},"path_34_14":{"type":"def","id":"path_34_14","d":"M106 143.5 V 365.5","startSlot":"bottom","endSlot":"top"}},"lines":{"line_path_14_7":{"type":"line","id":"line_path_14_7","href":"#path_14_7","color":"rgb(0, 0, 0)","shadow":""},"line_path_7_22":{"type":"line","id":"line_path_7_22","href":"#path_7_22","color":"rgb(0, 0, 0)","shadow":""},"line_path_7_28":{"type":"line","id":"line_path_7_28","href":"#path_7_28","color":"rgb(0, 0, 0)","shadow":""},"line_path_7_34":{"type":"line","id":"line_path_7_34","href":"#path_7_34","color":"rgb(0, 0, 0)","shadow":""},"line_path_34_14":{"type":"line","id":"line_path_34_14","href":"#path_34_14","color":"rgb(0, 0, 0)","shadow":""}},"animations":{"anim_path_14_7":{"type":"animation","id":"anim_path_14_7","href":"#path_14_7","color":"rgb(255, 206, 74)","source":3,"threshold":10,"animation_properties":"positive","animation_option":false,"dots":0,"duration":0,"power":0,"animation_type":-1,"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"anim_path_7_22":{"type":"animation","id":"anim_path_7_22","href":"#path_7_22","color":"rgb(255, 206, 74)","source":2,"threshold":5,"animation_properties":"positive","animation_option":false,"dots":0,"duration":0,"power":0,"animation_type":-1,"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"anim_path_7_28":{"type":"animation","id":"anim_path_7_28","href":"#path_7_28","color":"rgb(255, 206, 74)","source":1,"threshold":5,"animation_properties":"positive","animation_option":false,"dots":0,"duration":0,"power":0,"animation_type":"dots","css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"anim_path_7_34":{"type":"animation","id":"anim_path_7_34","href":"#path_7_34","color":"rgb(255, 206, 74)","source":"2","threshold":"","animation_properties":"positive","animation_option":false,"dots":0,"duration":0,"power":0,"animation_type":"-1","css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"anim_path_34_14":{"type":"animation","id":"anim_path_34_14","href":"#path_34_14","color":"rgb(255, 206, 74)","source":"3","threshold":"","animation_properties":"negative","animation_option":false,"dots":0,"duration":0,"power":0,"animation_type":"-1","css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""}},"datasources":{"0":{"source":"alias.0.PV.30775_Measurement_GridMs_TotW","alias":"PV_Power"},"1":{"source":"alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung","alias":"Haus_Power"},"2":{"source":"alias.0.Stromzähler.Zwischenzähler_WP.LWP_Gesamtleistung","alias":"LWP_Power"},"3":{"source":"alias.0.Stromzähler.Stromzähler_Haupt.Power_total","alias":"Haupt_Power"},"4":{"source":"alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung","alias":"Verbrauch_gesamt"}}}
        2023-07-29 18:21:30.685 - debug: energiefluss-erweitert.0 (1113) Datasource: {"source":"alias.0.PV.30775_Measurement_GridMs_TotW","alias":"PV_Power"}
        2023-07-29 18:21:30.705 - debug: energiefluss-erweitert.0 (1113) Datasource: {"source":"alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung","alias":"Haus_Power"}
        2023-07-29 18:21:30.716 - debug: energiefluss-erweitert.0 (1113) Datasource: {"source":"alias.0.Stromzähler.Zwischenzähler_WP.LWP_Gesamtleistung","alias":"LWP_Power"}
        2023-07-29 18:21:30.729 - debug: energiefluss-erweitert.0 (1113) Datasource: {"source":"alias.0.Stromzähler.Stromzähler_Haupt.Power_total","alias":"Haupt_Power"}
        2023-07-29 18:21:30.743 - debug: energiefluss-erweitert.0 (1113) Datasource: {"source":"alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung","alias":"Verbrauch_gesamt"}
        2023-07-29 18:21:30.762 - debug: energiefluss-erweitert.0 (1113) Source for Element: 2 is: 0 Plain: alias.0.PV.30775_Measurement_GridMs_TotW
        2023-07-29 18:21:30.776 - debug: energiefluss-erweitert.0 (1113) Source for Element: 9 is: 4 Plain: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung
        2023-07-29 18:21:30.793 - debug: energiefluss-erweitert.0 (1113) Source for Element: 12 is: 1 Plain: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung
        2023-07-29 18:21:30.812 - debug: energiefluss-erweitert.0 (1113) Source for Element: 19 is: 3 Plain: alias.0.Stromzähler.Stromzähler_Haupt.Power_total
        2023-07-29 18:21:30.828 - debug: energiefluss-erweitert.0 (1113) Source for Element: 22 is: 2 Plain: alias.0.Stromzähler.Zwischenzähler_WP.LWP_Gesamtleistung
        2023-07-29 18:21:30.853 - debug: energiefluss-erweitert.0 (1113) Source for Element: 26 is: 2 Plain: alias.0.Stromzähler.Zwischenzähler_WP.LWP_Gesamtleistung
        2023-07-29 18:21:30.867 - debug: energiefluss-erweitert.0 (1113) Source for Element: 28 is: 1 Plain: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung
        2023-07-29 18:21:30.881 - debug: energiefluss-erweitert.0 (1113) Source for Element: 33 is: 1 Plain: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung
        2023-07-29 18:21:30.892 - debug: energiefluss-erweitert.0 (1113) Animation for Source: 3 is: anim_path_14_7
        2023-07-29 18:21:30.893 - debug: energiefluss-erweitert.0 (1113) Animation for Source: 2 is: anim_path_7_22
        2023-07-29 18:21:30.893 - debug: energiefluss-erweitert.0 (1113) Animation for Source: 1 is: anim_path_7_28
        2023-07-29 18:21:30.894 - debug: energiefluss-erweitert.0 (1113) Animation for Source: 2 is: anim_path_7_34
        2023-07-29 18:21:30.894 - debug: energiefluss-erweitert.0 (1113) Animation for Source: 3 is: anim_path_34_14
        2023-07-29 18:21:30.894 - debug: energiefluss-erweitert.0 (1113) CSS: {}
        2023-07-29 18:21:30.895 - debug: energiefluss-erweitert.0 (1113) Settings: {"2":{"threshold":0,"calculate_kw":false,"decimal_places":0,"convert":false,"type":"text","source_option":-1,"source_display":"value","subtract":[-1],"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"9":{"threshold":0,"calculate_kw":false,"decimal_places":0,"convert":false,"type":"text","source_option":-1,"source_display":"value","subtract":[-1],"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"12":{"threshold":0,"type":"icon","css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"19":{"threshold":0,"calculate_kw":false,"decimal_places":0,"convert":false,"type":"text","source_option":-1,"source_display":"value","subtract":[-1],"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"22":{"threshold":0,"type":"rect","css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"26":{"threshold":0,"calculate_kw":false,"decimal_places":0,"convert":false,"type":"text","source_option":-1,"source_display":"value","subtract":[-1],"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"28":{"threshold":0,"type":"rect","css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"33":{"threshold":0,"calculate_kw":false,"decimal_places":0,"convert":false,"type":"text","source_option":-1,"source_display":"value","subtract":[-1],"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"anim_path_14_7":{"properties":"positive","option":false,"threshold":10,"type":-1,"duration":0,"power":0,"dots":0,"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"anim_path_7_22":{"properties":"positive","option":false,"threshold":5,"type":-1,"duration":0,"power":0,"dots":0,"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"anim_path_7_28":{"properties":"positive","option":false,"threshold":5,"type":"dots","duration":0,"power":0,"dots":0,"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"anim_path_7_34":{"properties":"positive","option":false,"threshold":"","type":"-1","duration":0,"power":0,"dots":0,"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""},"anim_path_34_14":{"properties":"negative","option":false,"threshold":"","type":"-1","duration":0,"power":0,"dots":0,"css_general":"","css_active_positive":"","css_inactive_positive":"","css_active_negative":"","css_inactive_negative":""}}
        2023-07-29 18:21:30.895 - debug: energiefluss-erweitert.0 (1113) Initial Values: {"2":"1246","9":"393","19":"-849","26":"24","33":"373"}
        2023-07-29 18:21:30.896 - debug: energiefluss-erweitert.0 (1113) Initial Fill-Values: {"12":369,"22":24,"28":369}
        2023-07-29 18:21:30.896 - debug: energiefluss-erweitert.0 (1113) Sources: {"alias.0.PV.30775_Measurement_GridMs_TotW":{"id":0,"elmSources":["2"],"elmAnimations":[]},"alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung":{"id":1,"elmSources":["12","28","33"],"elmAnimations":["anim_path_7_28"]},"alias.0.Stromzähler.Zwischenzähler_WP.LWP_Gesamtleistung":{"id":2,"elmSources":["22","26"],"elmAnimations":["anim_path_7_22","anim_path_7_34"]},"alias.0.Stromzähler.Stromzähler_Haupt.Power_total":{"id":3,"elmSources":["19"],"elmAnimations":["anim_path_14_7","anim_path_34_14"]},"alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung":{"id":4,"elmSources":["9"],"elmAnimations":[]}}
        2023-07-29 18:21:30.896 - debug: energiefluss-erweitert.0 (1113) RAW-Values: {"2":1246,"9":393,"19":-849,"26":24,"33":373}
        2023-07-29 18:21:30.897 - debug: energiefluss-erweitert.0 (1113) RAW-Source-Values: {"0":1246,"1":369,"2":24,"3":-849,"4":393}
        2023-07-29 18:21:30.899 - info: energiefluss-erweitert.0 (1113) Configuration loaded!
        2023-07-29 18:21:30.899 - info: energiefluss-erweitert.0 (1113) Requesting the following states: energiefluss-erweitert.0.configuration,alias.0.PV.30775_Measurement_GridMs_TotW,alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung,alias.0.Stromzähler.Zwischenzähler_WP.LWP_Gesamtleistung,alias.0.Stromzähler.Stromzähler_Haupt.Power_total,alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung
        2023-07-29 18:21:31.296 - debug: energiefluss-erweitert.0 (1113) {"0":1246,"1":369,"2":24,"3":-849,"4":393}
        2023-07-29 18:21:31.297 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 22 found! Applying Settings!
        2023-07-29 18:21:31.297 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 26 found! Applying Settings!
        2023-07-29 18:21:31.298 - debug: energiefluss-erweitert.0 (1113) Threshold for: 26 is: 0
        2023-07-29 18:21:31.298 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_WP.LWP_Gesamtleistung! Applying!
        2023-07-29 18:21:31.299 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_7_22 found! Applying Settings!
        2023-07-29 18:21:31.299 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
        2023-07-29 18:21:31.299 - debug: energiefluss-erweitert.0 (1113) Value: 24 is greater than Threshold: 5 Applying Animation!
        2023-07-29 18:21:31.300 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_7_34 found! Applying Settings!
        2023-07-29 18:21:31.300 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
        2023-07-29 18:21:31.300 - debug: energiefluss-erweitert.0 (1113) Value: 24 is greater than Threshold: Applying Animation!
        2023-07-29 18:21:31.301 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_WP.LWP_Gesamtleistung with Value: 24 belongs to Elements: 22,26
        2023-07-29 18:21:31.696 - debug: energiefluss-erweitert.0 (1113) {"0":1246,"1":369,"2":24,"3":-847,"4":393}
        2023-07-29 18:21:31.697 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 19 found! Applying Settings!
        2023-07-29 18:21:31.698 - debug: energiefluss-erweitert.0 (1113) Threshold for: 19 is: 0
        2023-07-29 18:21:31.699 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Stromzähler_Haupt.Power_total! Applying!
        2023-07-29 18:21:31.700 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_14_7 found! Applying Settings!
        2023-07-29 18:21:31.701 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
        2023-07-29 18:21:31.702 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_34_14 found! Applying Settings!
        2023-07-29 18:21:31.703 - debug: energiefluss-erweitert.0 (1113) Animation has a negative factor!
        2023-07-29 18:21:31.704 - debug: energiefluss-erweitert.0 (1113) Value: -847 is greater than Threshold: 0 Applying Animation!
        2023-07-29 18:21:31.705 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Stromzähler_Haupt.Power_total with Value: -847 belongs to Elements: 19
        2023-07-29 18:21:31.716 - debug: energiefluss-erweitert.0 (1113) {"0":1246,"1":375,"2":24,"3":-847,"4":393}
        2023-07-29 18:21:31.717 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 12 found! Applying Settings!
        2023-07-29 18:21:31.718 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 28 found! Applying Settings!
        2023-07-29 18:21:31.719 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 33 found! Applying Settings!
        2023-07-29 18:21:31.720 - debug: energiefluss-erweitert.0 (1113) Threshold for: 33 is: 0
        2023-07-29 18:21:31.720 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung! Applying!
        2023-07-29 18:21:31.721 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_7_28 found! Applying Settings!
        2023-07-29 18:21:31.722 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
        2023-07-29 18:21:31.723 - debug: energiefluss-erweitert.0 (1113) Value: 375 is greater than Threshold: 5 Applying Animation!
        2023-07-29 18:21:31.723 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung with Value: 375 belongs to Elements: 12,28,33
        2023-07-29 18:21:31.725 - debug: energiefluss-erweitert.0 (1113) {"0":1246,"1":375,"2":24,"3":-847,"4":399}
        2023-07-29 18:21:31.726 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 9 found! Applying Settings!
        2023-07-29 18:21:31.726 - debug: energiefluss-erweitert.0 (1113) Threshold for: 9 is: 0
        2023-07-29 18:21:31.727 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung! Applying!
        2023-07-29 18:21:31.727 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung with Value: 399 belongs to Elements: 9
        2023-07-29 18:21:32.075 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":375,"2":24,"3":-847,"4":399}
        2023-07-29 18:21:32.075 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 2 found! Applying Settings!
        2023-07-29 18:21:32.076 - debug: energiefluss-erweitert.0 (1113) Threshold for: 2 is: 0
        2023-07-29 18:21:32.076 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.PV.30775_Measurement_GridMs_TotW! Applying!
        2023-07-29 18:21:32.076 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.PV.30775_Measurement_GridMs_TotW with Value: 1236 belongs to Elements: 2
        2023-07-29 18:21:32.088 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":365,"2":24,"3":-847,"4":399}
        2023-07-29 18:21:32.088 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 12 found! Applying Settings!
        2023-07-29 18:21:32.089 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 28 found! Applying Settings!
        2023-07-29 18:21:32.089 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 33 found! Applying Settings!
        2023-07-29 18:21:32.089 - debug: energiefluss-erweitert.0 (1113) Threshold for: 33 is: 0
        2023-07-29 18:21:32.090 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung! Applying!
        2023-07-29 18:21:32.090 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_7_28 found! Applying Settings!
        2023-07-29 18:21:32.090 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
        2023-07-29 18:21:32.091 - debug: energiefluss-erweitert.0 (1113) Value: 365 is greater than Threshold: 5 Applying Animation!
        2023-07-29 18:21:32.091 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung with Value: 365 belongs to Elements: 12,28,33
        2023-07-29 18:21:32.097 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":365,"2":24,"3":-847,"4":389}
        2023-07-29 18:21:32.098 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 9 found! Applying Settings!
        2023-07-29 18:21:32.098 - debug: energiefluss-erweitert.0 (1113) Threshold for: 9 is: 0
        2023-07-29 18:21:32.099 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung! Applying!
        2023-07-29 18:21:32.099 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung with Value: 389 belongs to Elements: 9
        2023-07-29 18:21:32.703 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":365,"2":24,"3":-848,"4":389}
        2023-07-29 18:21:32.703 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 19 found! Applying Settings!
        2023-07-29 18:21:32.704 - debug: energiefluss-erweitert.0 (1113) Threshold for: 19 is: 0
        2023-07-29 18:21:32.705 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Stromzähler_Haupt.Power_total! Applying!
        2023-07-29 18:21:32.706 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_14_7 found! Applying Settings!
        2023-07-29 18:21:32.706 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
        2023-07-29 18:21:32.707 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_34_14 found! Applying Settings!
        2023-07-29 18:21:32.708 - debug: energiefluss-erweitert.0 (1113) Animation has a negative factor!
        2023-07-29 18:21:32.708 - debug: energiefluss-erweitert.0 (1113) Value: -848 is greater than Threshold: 0 Applying Animation!
        2023-07-29 18:21:32.709 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Stromzähler_Haupt.Power_total with Value: -848 belongs to Elements: 19
        2023-07-29 18:21:32.718 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":364,"2":24,"3":-848,"4":389}
        2023-07-29 18:21:32.719 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 12 found! Applying Settings!
        2023-07-29 18:21:32.719 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 28 found! Applying Settings!
        2023-07-29 18:21:32.720 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 33 found! Applying Settings!
        2023-07-29 18:21:32.721 - debug: energiefluss-erweitert.0 (1113) Threshold for: 33 is: 0
        2023-07-29 18:21:32.722 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung! Applying!
        2023-07-29 18:21:32.723 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_7_28 found! Applying Settings!
        2023-07-29 18:21:32.724 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
        2023-07-29 18:21:32.725 - debug: energiefluss-erweitert.0 (1113) Value: 364 is greater than Threshold: 5 Applying Animation!
        2023-07-29 18:21:32.727 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung with Value: 364 belongs to Elements: 12,28,33
        2023-07-29 18:21:32.741 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":364,"2":24,"3":-848,"4":388}
        2023-07-29 18:21:32.743 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 9 found! Applying Settings!
        2023-07-29 18:21:32.744 - debug: energiefluss-erweitert.0 (1113) Threshold for: 9 is: 0
        2023-07-29 18:21:32.745 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung! Applying!
        2023-07-29 18:21:32.746 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung with Value: 388 belongs to Elements: 9
        2023-07-29 18:21:33.568 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":364,"2":24,"3":-848,"4":388}
        2023-07-29 18:21:33.570 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 22 found! Applying Settings!
        2023-07-29 18:21:33.571 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 26 found! Applying Settings!
        2023-07-29 18:21:33.571 - debug: energiefluss-erweitert.0 (1113) Threshold for: 26 is: 0
        2023-07-29 18:21:33.572 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_WP.LWP_Gesamtleistung! Applying!
        2023-07-29 18:21:33.573 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_7_22 found! Applying Settings!
        2023-07-29 18:21:33.573 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
        2023-07-29 18:21:33.574 - debug: energiefluss-erweitert.0 (1113) Value: 24 is greater than Threshold: 5 Applying Animation!
        2023-07-29 18:21:33.575 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_7_34 found! Applying Settings!
        2023-07-29 18:21:33.575 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
        2023-07-29 18:21:33.576 - debug: energiefluss-erweitert.0 (1113) Value: 24 is greater than Threshold: Applying Animation!
        2023-07-29 18:21:33.577 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_WP.LWP_Gesamtleistung with Value: 24 belongs to Elements: 22,26
        2023-07-29 18:21:33.707 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":364,"2":24,"3":-847,"4":388}
        2023-07-29 18:21:33.707 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 19 found! Applying Settings!
        2023-07-29 18:21:33.708 - debug: energiefluss-erweitert.0 (1113) Threshold for: 19 is: 0
        2023-07-29 18:21:33.709 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Stromzähler_Haupt.Power_total! Applying!
        2023-07-29 18:21:33.709 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_14_7 found! Applying Settings!
        2023-07-29 18:21:33.710 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
        2023-07-29 18:21:33.710 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_34_14 found! Applying Settings!
        2023-07-29 18:21:33.711 - debug: energiefluss-erweitert.0 (1113) Animation has a negative factor!
        2023-07-29 18:21:33.712 - debug: energiefluss-erweitert.0 (1113) Value: -847 is greater than Threshold: 0 Applying Animation!
        2023-07-29 18:21:33.712 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Stromzähler_Haupt.Power_total with Value: -847 belongs to Elements: 19
        2023-07-29 18:21:33.721 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":365,"2":24,"3":-847,"4":388}
        2023-07-29 18:21:33.722 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 12 found! Applying Settings!
        2023-07-29 18:21:33.723 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 28 found! Applying Settings!
        2023-07-29 18:21:33.723 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 33 found! Applying Settings!
        2023-07-29 18:21:33.724 - debug: energiefluss-erweitert.0 (1113) Threshold for: 33 is: 0
        2023-07-29 18:21:33.724 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung! Applying!
        2023-07-29 18:21:33.725 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_7_28 found! Applying Settings!
        2023-07-29 18:21:33.726 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
        2023-07-29 18:21:33.726 - debug: energiefluss-erweitert.0 (1113) Value: 365 is greater than Threshold: 5 Applying Animation!
        2023-07-29 18:21:33.727 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung with Value: 365 belongs to Elements: 12,28,33
        2023-07-29 18:21:33.734 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":365,"2":24,"3":-847,"4":389}
        2023-07-29 18:21:33.734 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 9 found! Applying Settings!
        2023-07-29 18:21:33.735 - debug: energiefluss-erweitert.0 (1113) Threshold for: 9 is: 0
        2023-07-29 18:21:33.736 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung! Applying!
        2023-07-29 18:21:33.736 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung with Value: 389 belongs to Elements: 9
        2023-07-29 18:21:34.754 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":365,"2":24,"3":2049,"4":389}
        2023-07-29 18:21:34.755 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 19 found! Applying Settings!
        2023-07-29 18:21:34.756 - debug: energiefluss-erweitert.0 (1113) Threshold for: 19 is: 0
        2023-07-29 18:21:34.756 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Stromzähler_Haupt.Power_total! Applying!
        2023-07-29 18:21:34.757 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_14_7 found! Applying Settings!
        2023-07-29 18:21:34.757 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
        2023-07-29 18:21:34.758 - debug: energiefluss-erweitert.0 (1113) Value: 2049 is greater than Threshold: 10 Applying Animation!
        2023-07-29 18:21:34.759 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_34_14 found! Applying Settings!
        2023-07-29 18:21:34.759 - debug: energiefluss-erweitert.0 (1113) Animation has a negative factor!
        2023-07-29 18:21:34.760 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Stromzähler_Haupt.Power_total with Value: 2049 belongs to Elements: 19
        2023-07-29 18:21:34.767 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":3261,"2":24,"3":2049,"4":389}
        2023-07-29 18:21:34.768 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 12 found! Applying Settings!
        2023-07-29 18:21:34.769 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 28 found! Applying Settings!
        2023-07-29 18:21:34.770 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 33 found! Applying Settings!
        2023-07-29 18:21:34.771 - debug: energiefluss-erweitert.0 (1113) Threshold for: 33 is: 0
        2023-07-29 18:21:34.771 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung! Applying!
        2023-07-29 18:21:34.772 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_7_28 found! Applying Settings!
        2023-07-29 18:21:34.772 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
        2023-07-29 18:21:34.773 - debug: energiefluss-erweitert.0 (1113) Value: 3261 is greater than Threshold: 5 Applying Animation!
        2023-07-29 18:21:34.774 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung with Value: 3261 belongs to Elements: 12,28,33
        2023-07-29 18:21:34.780 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":3261,"2":24,"3":2049,"4":3285}
        2023-07-29 18:21:34.781 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 9 found! Applying Settings!
        2023-07-29 18:21:34.782 - debug: energiefluss-erweitert.0 (1113) Threshold for: 9 is: 0
        2023-07-29 18:21:34.782 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung! Applying!
        2023-07-29 18:21:34.783 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung with Value: 3285 belongs to Elements: 9
        2023-07-29 18:21:35.702 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":3261,"2":24,"3":2423,"4":3285}
        2023-07-29 18:21:35.703 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 19 found! Applying Settings!
        2023-07-29 18:21:35.703 - debug: energiefluss-erweitert.0 (1113) Threshold for: 19 is: 0
        2023-07-29 18:21:35.704 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Stromzähler_Haupt.Power_total! Applying!
        2023-07-29 18:21:35.704 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_14_7 found! Applying Settings!
        2023-07-29 18:21:35.705 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
        2023-07-29 18:21:35.706 - debug: energiefluss-erweitert.0 (1113) Value: 2423 is greater than Threshold: 10 Applying Animation!
        2023-07-29 18:21:35.706 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_34_14 found! Applying Settings!
        2023-07-29 18:21:35.707 - debug: energiefluss-erweitert.0 (1113) Animation has a negative factor!
        2023-07-29 18:21:35.707 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Stromzähler_Haupt.Power_total with Value: 2423 belongs to Elements: 19
        2023-07-29 18:21:35.728 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":3635,"2":24,"3":2423,"4":3285}
        2023-07-29 18:21:35.729 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 12 found! Applying Settings!
        2023-07-29 18:21:35.730 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 28 found! Applying Settings!
        2023-07-29 18:21:35.730 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 33 found! Applying Settings!
        2023-07-29 18:21:35.731 - debug: energiefluss-erweitert.0 (1113) Threshold for: 33 is: 0
        2023-07-29 18:21:35.732 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung! Applying!
        2023-07-29 18:21:35.732 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_7_28 found! Applying Settings!
        2023-07-29 18:21:35.733 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
        2023-07-29 18:21:35.734 - debug: energiefluss-erweitert.0 (1113) Value: 3635 is greater than Threshold: 5 Applying Animation!
        2023-07-29 18:21:35.734 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_Haus.Haus_Gesamtleistung with Value: 3635 belongs to Elements: 12,28,33
        2023-07-29 18:21:35.741 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":3635,"2":24,"3":2423,"4":3659}
        2023-07-29 18:21:35.742 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 9 found! Applying Settings!
        2023-07-29 18:21:35.743 - debug: energiefluss-erweitert.0 (1113) Threshold for: 9 is: 0
        2023-07-29 18:21:35.744 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung! Applying!
        2023-07-29 18:21:35.744 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_gesamt.Verbrauch_gesamt_Leistung with Value: 3659 belongs to Elements: 9
        2023-07-29 18:21:35.852 - debug: energiefluss-erweitert.0 (1113) {"0":1236,"1":3635,"2":24,"3":2423,"4":3659}
        2023-07-29 18:21:35.852 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 22 found! Applying Settings!
        2023-07-29 18:21:35.853 - debug: energiefluss-erweitert.0 (1113) Value-Settings for Element 26 found! Applying Settings!
        2023-07-29 18:21:35.853 - debug: energiefluss-erweitert.0 (1113) Threshold for: 26 is: 0
        2023-07-29 18:21:35.854 - debug: energiefluss-erweitert.0 (1113) Found corresponding animations for ID: alias.0.Stromzähler.Zwischenzähler_WP.LWP_Gesamtleistung! Applying!
        2023-07-29 18:21:35.854 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_7_22 found! Applying Settings!
        2023-07-29 18:21:35.855 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
        2023-07-29 18:21:35.855 - debug: energiefluss-erweitert.0 (1113) Value: 24 is greater than Threshold: 5 Applying Animation!
        2023-07-29 18:21:35.856 - debug: energiefluss-erweitert.0 (1113) Animation-Settings for Element anim_path_7_34 found! Applying Settings!
        2023-07-29 18:21:35.856 - debug: energiefluss-erweitert.0 (1113) Animation has a positive factor!
        2023-07-29 18:21:35.857 - debug: energiefluss-erweitert.0 (1113) Value: 24 is greater than Threshold: Applying Animation!
        2023-07-29 18:21:35.857 - debug: energiefluss-erweitert.0 (1113) State changed! New value for Source: alias.0.Stromzähler.Zwischenzähler_WP.LWP_Gesamtleistung with Value: 24 belongs to Elements: 22,26
        Bei der Objetauswahl kann ich aus dem Alias-Ast nicht alles wählen, weil die standardmäßig als Channel angelegt werden vom Alias-Manager Adapter. Da fehlt also die Ebene mit den Objekt-Werten darunter.
        Im Objektbaum sieht das so aus:
        Danke für deine Hilfe!
        • SKB
          @andi2055 Mit den Alias'en schaue ich mir an.
          Bekommst Du Fehler in der Browserkonsole mit F12?
          Welchen Browser verwendest Du?
          Der Adapter schaltet die Animation richtig ein, wie ich das sehe. Sie wird wohl nicht auf die Linie angewendet.
            @skb
            Ausprobiert mit aktuellem Chrome & FF
            Chrome:
            FF:
            Attribut undefined? Welches? Muss ich irgendwas noch ausfüllen in der Config was derzeit leer/0 ist?
            • SKB
              @andi2055 Chrome ist etwas empfindlicher. Ist aber nicht tragisch.
              Firefox meldet den 'richtigen' Fehler.
              Die Anzeige wird nicht 'geupdated'.
              Wie sieht der Inhalt von 'data' unterhalb Energiefluss-erweitert aus?
                @skb
                  "values": {
                    "2": "0",
                    "9": "388",
                    "19": "388",
                    "26": "53",
                    "33": "335"
                  "unit": {
                    "2": "W",
                    "9": "W",
                    "19": "W",
                    "26": "W",
                    "33": "W"
                  "animations": {
                    "anim_path_14_7": true,
                    "anim_path_34_14": false,
                    "anim_path_7_28": true,
                    "anim_path_7_22": true,
                    "anim_path_7_34": true
                  "fillValues": {
                    "12": 335,
                    "22": 53,
                    "28": 335
                  "animationProperties": {
                    "anim_path_14_7": {
                      "option": ""
                    "anim_path_34_14": {},
                    "anim_path_7_28": {
                      "type": "dots",
                      "stroke": "",
                      "option": ""
                    "anim_path_7_22": {
                      "option": ""
                    "anim_path_7_34": {
                      "option": ""
                  "prepend": {
                    "2": "",
                    "9": "",
                    "19": "",
                    "26": "",
                    "33": ""
                  "append": {
                    "2": "",
                    "9": "",
                    "19": "",
                    "26": "",
                    "33": ""
                  "css": {
                    "2": {
                      "actPos": "",
                      "inactPos": " ",
                      "actNeg": "",
                      "inactNeg": " "
                    "9": {
                      "actPos": "",
                      "inactPos": "",
                      "actNeg": "",
                      "inactNeg": ""
                    "12": {
                      "actPos": "",
                      "inactPos": "",
                      "actNeg": "",
                      "inactNeg": ""
                    "19": {
                      "actPos": "",
                      "inactPos": "",
                      "actNeg": "",
                      "inactNeg": ""
                    "22": {
                      "actPos": "",
                      "inactPos": "",
                      "actNeg": "",
                      "inactNeg": ""
                    "26": {
                      "actPos": "",
                      "inactPos": "",
                      "actNeg": "",
                      "inactNeg": ""
                    "28": {
                      "actPos": "",
                      "inactPos": "",
                      "actNeg": "",
                      "inactNeg": ""
                    "33": {
                      "actPos": "",
                      "inactPos": "",
                      "actNeg": "",
                      "inactNeg": ""
                    "anim_path_14_7": {
                      "actPos": "",
                      "inactPos": "",
                      "actNeg": "",
                      "inactNeg": ""
                      "actPos": "",
                      "inactPos": "",
                      "actNeg": "",
                      "inactNeg": ""
                    "anim_path_7_28": {
                      "actPos": "",
                      "inactPos": "",
                      "actNeg": "",
                      "inactNeg": ""
                    "anim_path_7_22": {
                      "actPos": "",
                      "inactPos": "",
                      "actNeg": "",
                      "inactNeg": ""
                    "anim_path_7_34": {
                      "actPos": "",
                      "inactPos": "",
                      "actNeg": "",
                      "inactNeg": ""
                • SKB
                  @andi2055
                  Diese Animation hat keinen Inhalt. Kannst Du hier mal die Einstellungen prüfen?
                  Ich stelle die Fehlerausgabe später einmal um, dann können wir besser sehen, wo es klemmt.
                  Melde mich dann zurück.
                    @skb
                    Hatte "Animieren wenn negativ" dort gesetzt. Sonst eigentlich kein Unterschied.
                    Sieht jetzt so aus. Aber immer noch Fehler
                          "option": ""
                    Ich habe das Problem ja auch mit meiner neu erzeugten Instanz und meinem Mini-Testfall:
                      "basic": {
                        "enable_grid": true,
                        "enable_animation": false,
                        "enable_area_catch": true,
                        "enable_config_icon": true,
                        "enable_last_id": false,
                        "enable_icon_proxy": false,
                        "height": 540,
                        "width": 530,
                        "styles": "",
                        "font": {
                          "family": "\"Arial\", sans-serif",
                          "size": "20",
                          "color": "",
                          "fill": "",
                          "align": "middle"
                        "rect": {
                          "height": 100,
                          "width": 100,
                          "corners": 10
                        "circle": {
                          "radius": 50
                        "elm": {
                          "stroke_width": 5,
                          "color": "",
                          "fill": "",
                          "pos_x": 50,
                          "pos_y": 50
                        "icon": {
                          "height": 24,
                          "width": 24,
                          "color": ""
                      "calculation": {
                        "battery": {
                          "dod": 0,
                          "capacity": 0,
                          "percent": -1,
                          "charge": -1,
                          "charge_prop": false,
                          "charge_kw": false,
                          "discharge": -1,
                          "discharge_prop": false,
                          "discharge_kw": false
                      "animation": {
                        "stroke": "#ffce4a",
                        "stroke_dasharray": "10 17 10 17 10  72",
                        "stroke_width": "6",
                        "animation_duration": "2000",
                        "stroke_linecap": "round",
                        "animation_timing_function": "linear"
                      "animation_configuration": {
                        "dots": "3",
                        "distance": "17",
                        "length": "10"
                      "line": {
                        "stroke_width": "8",
                        "stroke": "#000000"
                      "elements": {
                        "2": {
                          "type": "text",
                          "subType": "datasource",
                          "id": 2,
                          "pos_x": 216,
                          "pos_y": 42,
                          "color": "none",
                          "fill": "rgb(255, 206, 74)",
                          "font_family": "Arial, sans-serif",
                          "font_size": 18,
                          "degree": 0,
                          "align": "middle",
                          "text": "ID 2",
                          "unit": "W",
                          "append": "",
                          "prepend": "",
                          "source": 1,
                          "source_option": -1,
                          "source_display": "value",
                          "shadow": "",
                          "threshold": 0,
                          "calculate_kw": false,
                          "convert": false,
                          "decimal_places": 2,
                          "subtract": [
                            -1
                          "css_general": "",
                          "css_active_positive": "",
                          "css_inactive_positive": "",
                          "css_active_negative": "",
                          "css_inactive_negative": ""
                        "5": {
                          "type": "rect",
                          "id": 5,
                          "rx": 10,
                          "height": 100,
                          "width": 100,
                          "pos_x": 167,
                          "pos_y": 2,
                          "fill": "none",
                          "color": "rgb(255, 206, 74)",
                          "stroke": 2,
                          "shadow": "rgba(0,0,0,0.7)",
                          "frame": "_overlay",
                          "url": "",
                          "fill_value": null,
                          "fill_type": "percent",
                          "fill_direction": 90,
                          "fill_max": null,
                          "border_value": null,
                          "border_type": -1,
                          "border_direction": "cw",
                          "border_style": "round",
                          "border_max": null,
                          "border_reverse_value": null,
                          "border_reverse": false,
                          "border_start": 180,
                          "source": -1,
                          "threshold": 0,
                          "css_general": "",
                        "6": {
                          "type": "icon",
                          "id": "6",
                          "icon": "mdi:solar-panel",
                          "width": 24,
                          "height": 24,
                          "color": "rgba(0, 0, 0, 0.7)",
                          "pos_x": "205",
                          "pos_y": "6",
                          "shadow": "",
                          "css_general": "",
                          "css_inactive_negative": "",
                          "source": -1,
                          "threshold": 0
                        "7": {
                          "type": "rect",
                          "id": 7,
                          "rx": 10,
                          "height": 100,
                          "width": 100,
                          "pos_x": 407,
                          "pos_y": 212,
                          "fill": "none",
                          "color": "rgb(0, 181, 221)",
                          "stroke": 2,
                          "url": "",
                          "fill_value": null,
                          "fill_max": null,
                          "border_type": -1,
                          "border_max": null,
                          "source": -1,
                          "threshold": 0,
                          "css_general": "",
                        "9": {
                          "type": "text",
                          "id": 9,
                          "pos_x": 457,
                          "pos_y": 254,
                          "color": "none",
                          "fill": "rgb(0, 181, 221)",
                          "font_size": 18,
                          "degree": 0,
                          "align": "middle",
                          "text": "ID 9",
                          "unit": "W",
                          "append": "",
                          "prepend": "",
                          "source": 1,
                          "shadow": "",
                          "threshold": 0,
                          "convert": false,
                          "subtract": [
                            -1
                          "css_general": "",
                        "10": {
                          "type": "text",
                          "id": 10,
                          "pos_x": 217,
                          "pos_y": 75,
                          "color": "none",
                          "fill": "rgba(0, 0, 0, 0.7)",
                          "font_size": 14,
                          "degree": 0,
                          "align": "middle",
                          "text": "Produktion",
                          "shadow": "",
                          "css_general": ""
                        "11": {
                          "type": "text",
                          "id": 11,
                          "pos_x": 457,
                          "pos_y": 288,
                          "color": "none",
                          "font_size": 14,
                          "degree": 0,
                          "align": "middle",
                          "text": "Verbrauch",
                          "shadow": "",
                          "css_general": ""
                        "12": {
                          "type": "icon",
                          "id": "12",
                          "icon": "mdi:house-city",
                          "width": 24,
                          "height": 24,
                          "pos_x": "445",
                          "pos_y": "218",
                          "shadow": "",
                          "css_general": "",
                          "source": -1,
                          "threshold": 0
                      "defs": {
                        "path_5_7": {
                          "type": "def",
                          "id": "path_5_7",
                          "d": "M237 103  V 124.6 A 15 15 0 0 0 252 139.6  H 422 A 15 15 0 0 1 437 154.6  V 211",
                          "startSlot": "bottom_right",
                          "endSlot": "top_left"
                      "lines": {
                        "line_path_5_7": {
                          "type": "line",
                          "id": "line_path_5_7",
                          "href": "#path_5_7",
                          "color": "rgb(211, 183, 135)",
                          "shadow": ""
                      "animations": {
                        "anim_path_5_7": {
                          "type": "animation",
                          "id": "anim_path_5_7",
                          "color": "rgb(52, 20, 255)",
                          "source": "1",
                          "threshold": "0",
                          "animation_properties": "positive",
                          "animation_option": false,
                          "dots": 0,
                          "duration": 0,
                          "power": 0,
                          "animation_type": "-1",
                          "css_general": "",
                      "datasources": {
                        "1": {
                          "source": "0_userdata.0.KG.Stromzähler.Haupt.Power_total",
                          "alias": "Haupt"
                      "values": {
                        "2": "248.00",
                        "9": "248.00"
                      "unit": {
                        "2": "W",
                        "9": "W"
                      "animations": {
                        "anim_path_5_7": true
                      "fillValues": {},
                        "anim_path_5_7": {
                          "option": ""
                      "prepend": {
                        "2": "",
                        "9": ""
                      "append": {
                        "2": "",
                        "9": ""
                      "css": {
                        "2": {
                          "actPos": "",
                          "inactPos": "",
                          "actNeg": "",
                          "inactNeg": ""
                        "9": {
                          "actPos": "",
                          "inactPos": "",
                          "actNeg": "",
                          "inactNeg": ""
                        "anim_path_5_7": {
                          "actPos": "",
                          "inactPos": "",
                          "actNeg": "",
                          "inactNeg": ""
                    Evtl. irgendein anderes Problem noch?
                    • SKB
                      SKB Developer Most Active @andi2055 last edited by SKB
                      @andi2055 Ich habe das "Error"-Handling einmal etwas angepasst.
                      Wenn Du nochmal drüber installierst und dann in die Konsole schaust, müsste immerhin der Fehler kommen, der auftritt.
                      Mit diesem kann ich dann weiterarbeiten.
                      Wärst Du so freundlich und installierst einmal drüber und schaust dann in die Konsole mit F12?
                      Die Alias'se habe ich getestet und es wird etwas angezeigt. Allerdings liefert ioBroker nur die States, welche man auswählen kann. Leere Ordner usw werden nicht übermittelt.
                        @skb
                        Anbei das Log beim Neuladen
                        Using Instance: energiefluss-erweitert.1 functions.min.js:1:192
                        Ein iframe, der sowohl "allow-scripts" als auch "allow-same-origin" für sein "sandbox"-Attribut gesetzt hat, kann seine Sandbox entfernen. index.html
                        Loading config for instance: 1 functions.min.js:1:9129
                        Using direct load via iconify-API! functions.min.js:1:117511
                        Einige Cookies verwenden das empfohlene "SameSite"-Attribut inkorrekt. 4
                        Loaded additional file: js/iconify.min.js functions.min.js:1:77018
                        Loading User Config ... functions.min.js:1:19992
                        Using direct load via iconify-API! functions.min.js:1:22453
                        [Socket] subscribed to: energiefluss-erweitert.1.configuration,energiefluss-erweitert.1.data,system.adapter.energiefluss-erweitert.1.alive,energiefluss-erweitert.1.backup at 30.7.2023, 10:40:15 functions.min.js:1:3509
                        Loading initial Data. functions.min.js:1:10155
                        An error accured, while refreshing the data! The following Error was thrown: TypeError: can't convert undefined to object functions.min.js:1:8684
                            refreshData http://192.168.3.100:8082/energiefluss-erweitert/js/functions.min.js:1
                            loadConfig http://192.168.3.100:8082/energiefluss-erweitert/js/functions.min.js:1
                            onack http://192.168.3.100:8082/socket.io/socket.io.js:8
                            onpacket http://192.168.3.100:8082/socket.io/socket.io.js:8
                            exports http://192.168.3.100:8082/socket.io/socket.io.js:8
                            emit http://192.168.3.100:8082/socket.io/socket.io.js:6
                            ondecoded http://192.168.3.100:8082/socket.io/socket.io.js:6
                            add http://192.168.3.100:8082/socket.io/socket.io.js:6
                            ondata http://192.168.3.100:8082/socket.io/socket.io.js:6
                            onPacket http://192.168.3.100:8082/socket.io/socket.io.js:6
                            setTransport http://192.168.3.100:8082/socket.io/socket.io.js:6
                            onPacket http://192.168.3.100:8082/socket.io/socket.io.js:7
                            n http://192.168.3.100:8082/socket.io/socket.io.js:7
                            decodePayload http://192.168.3.100:8082/socket.io/socket.io.js:7
                            onData http://192.168.3.100:8082/socket.io/socket.io.js:7
                            doPoll http://192.168.3.100:8082/socket.io/socket.io.js:7
                            onLoad http://192.168.3.100:8082/socket.io/socket.io.js:7
                            onreadystatechange http://192.168.3.100:8082/socket.io/socket.io.js:7
                        An error accured, while refreshing the data! The following Error was thrown: TypeError: can't convert undefined to object 5 functions.min.js:1:8684
                            displayListener http://192.168.3.100:8082/energiefluss-erweitert/js/functions.min.js:1
                        An error accured, while refreshing the data! The following Error was thrown: TypeError: can't convert undefined to object 35 functions.min.js:1:8684
                            (Async: setTimeout handler)
                            onevent http://192.168.3.100:8082/socket.io/socket.io.js:8
                            onmessage http://192.168.3.100:8082/socket.io/socket.io.js:8
                        Das Problem beim Auswählen betrifft nur "Channel"
                        Wenn ich die manuell auf "Folder" ändere, dann sind die auswählbar
                        • SKB
                          @andi2055 Danke für die Rückmeldung. Musste noch etwas erweitern. Kannst Du nochmal drüber installieren?
                          Sorry, dass das jetzt ein "Suchen nach der Nadel wird" ...
                          Nach den Objekten im Browser gucke ich die Tage nochmal.
                            @skb
                            jetzt funktioniert es wieder! Danke dir für den Support!
                            PS: super Adapter! und vor allem super flexibel! Habe dich gerade auch zu 2 Bier eingeladen...
                            • SKB
                              @andi2055 Allerdings komisch. Es sollte ja noch mindestens 1 Fehler in der Konsole auftauchen, da ja eben nichts ging.
                              Eine Funktion müsste einen Fehler werfen. Kannst Du da nochmal ins Log gucken?
                              Prost übrigens 🙂
                                @skb
                                hm, keine Ahnung. Ich habe nur neu von Github installiert (so wie davor auch)
                                Direkt danach hat es funktioniert. Kein Fehler mehr...
                                • SKB
                                  @andi2055 Und das Mini-Projekt? Meldet dies einen Fehler?
                                    @skb
                                    das Mini-Projekt funktioniert nun ebenfalls ohne Fehler.
                                    Wenn du nun sagst, dass du nichts außer Error-Handling geändert hast, dann weiß ich auch nicht weshalb es nun funktioniert...?
                                    • SKB
                                      @andi2055 Das macht mich auch etwas stutzig gerade:D
                                      Beim Aktualisieren werden 4 Funktionen aufgerufen, um die Daten (Values, Styles, Animation und Borders) darzustellen. Die habe ich nun in eigene Error-Catcher gesetzt.
                                      Anscheinend lieferte eine Funktion keine plausiblen Werte. Man könnte jetzt jede der 4 Funktionen aus dem Error-Handling wieder rausnehmen, um zu schauen, woran es liegt. Aber, das muss ich dir nicht zumuten 🙂
                                        @skb
                                        wenn du mir sagst wie ich die 4 hintereinander ausprobieren kann, dann kein Problem. Oder kannst du irgendwas im Log ausgeben je nach catch?
                                        Ich habe gerade noch mit der Anzahl Punkte auf der Line je nach Wert gespielt. Zweimal ist der Adapter in einem Neustart-Loop gesprungen. Neustart hat das Problem wieder gelöst. Fehler im Log:
                                        2023-07-30 12:04:58.461	error	uncaught exception: Cannot read properties of undefined (reading 'id')
                                        2023-07-30 12:04:58.459	error	Cannot read properties of undefined (reading 'id')
                                        2023-07-30 12:04:58.458	error	TypeError: Cannot read properties of undefined (reading 'id') at EnergieflussErweitert.onStateChange (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:295:27) at EnergieflussErweitert.emit (node:events:514:28) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8382:57) at process.processImmediate (node:internal/timers:476:21)
                                        So ganz Blicke ich bei der Anzahl Punkte pro Linie auch noch nicht durch.
                                        Hier habe ich nun z.B. Folgendes eingetragen
                                        Bedeutet: bei 13000 Leistung (Wert der Linie ist nun zum Testen dem Wert oben im gelben Kreis - Bild unten) werden knapp die maximale Anzahl Punkte dargestellt? Weshalb sehe ich dann nur 6?
                                        Versuch 2: In der Konfig 6 Punkte + 13000 eingetragen - es werden auch 6 angezeigt
                                        Hier sind 6 Punkte und 3000 in der Konfig. Obwahl nur 25W werden 3 angezeigt?
                                        Oder hängt das noch mit dem Aktualisierungs-Bug vom Anfang zusammen?
                                        • SKB
                                          @andi2055 Die Animationen werden passend zu dem sich ändernden Wert ausgewertet. Also zum Zeitpunkt der Änderung.
                                          Dann wird die Linie mit neuen Punkten versehen. Heisst, wenn Du das Testen möchtest, Konfig abspeichern, Seite aufrufen und gucken - dann den Wert im DP ändern (lassen).
                                          Hier könnte allerdings, wie du sagst, vielleicht der Fehler in der Aktualisierung vorliegen. Erscheint denn ein Fehler im Log, wenn sich die Werte ändern?
                                            @skb
                                            in welchem Log. Also im Browser F12 habe ich nichts gesehen.
                                            Im ioB habe ich auf Warnung stehen und da sehe ich auch nichts.
                                            Manchmal werden auch die vollen Punkte (wie erwartet) angezeigt. Rechts bei LWP allerdings nicht. Die 25W sind allerdings auch teilweise stundenlang konstant solange die Wärmepumpe aus ist.
                                            Startet die Grafik also immer mit 3 Punkten und erst bei Änderung wird das angepasst?
                                            Teilweise habe ich beobachtet, dass 3 angezeigt werden und diese dann bei nur minimaler Änderung des Wertes auf 1 reduziert werden (so wie ich das erwarten würde bei kleinen Werten) - danach aber wieder auf 3 springen und manchmal dann nochmal auf 1 angepasst werden usw.
                                            So ich bin nun erst wieder heute Abend am PC...
                                            vis
                                            192
                                            4367
                                            5696117
