      todde @Michael Roling last edited by
      @michael-roling wäre es möglich change{"true":"an", "false":"aus"} auch beim GetState zu nutzen? Ich lese den Status eines Fensterkontaktes aus und bekomme true/false oder 1/0 zurück, würde aber gerne offen/zu als Antwort senden.
      Michael Roling 1 Reply Last reply Reply Quote 2
      • Negalein
        Negalein Global Moderator @Michael Roling last edited by
        @michael-roling
        Hallo Michael!
        Mit 0.3.0 funktioniert kein einziger SetState.
        GetState funktioniert wie immer problemlos.
        telegram-menu.0
        2023-07-26 23:33:28.967	debug	Send Value {"id":"hue.0.Wohnzimmer.on","confirm":"false","returnText":"-","userToSend":"Christian"}
        telegram-menu.0
        2023-07-26 23:33:28.967	debug	State, which is listen to was changed "hue.0.Wohnzimmer.on"
        telegram-menu.0
        2023-07-26 23:33:27.239	debug	Send Value {"id":"hue.0.Wohnzimmer.on","confirm":"false","returnText":"-","userToSend":"Christian"}
        telegram-menu.0
        2023-07-26 23:33:27.239	debug	State, which is listen to was changed "hue.0.Wohnzimmer.on"
        telegram-menu.0
        2023-07-26 23:33:27.218	debug	Value {"val":true,"ack":true,"ts":1690407199543,"q":0,"from":"system.adapter.hue.0","user":"system.user.admin","lc":1690407199543}
        telegram-menu.0
        2023-07-26 23:33:27.216	debug	Toggle
        telegram-menu.0
        2023-07-26 23:33:27.216	debug	Element to set {"id":"hue.0.Wohnzimmer.on","value":"-","toggle":true,"confirm":"false","returnText":"-"}
        telegram-menu.0
        2023-07-26 23:33:27.216	debug	Part {"switch":[{"id":"hue.0.Wohnzimmer.on","value":"-","toggle":true,"confirm":"false","returnText":"-"}]}
        telegram-menu.0
        2023-07-26 23:33:27.216	debug	Menu {"Global":{"Home":{"nav":[["Licht "],[" Strom "],[" Wetter"]],"text":"Wählen Sie eine Aktion"},"Licht":{"nav":[["Home "],[" Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip"]],"text":"Wähle eine Aktion"},"Strom":{"nav":[["Home "],[" Pelletsofen"," 3D Drucker"]],"text":"Wähle eine Aktion"},"Wetter":{"nav":[["Home "],[" Aussentemperatur"," Windstärke"," Regen"]],"text":"Wähle eine Aktion"},"Wintergarten Strip":{"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"-","toggle":true,"confirm":"true","returnText":"Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"Pelletsofen":{"switch":[{"id":"hs100.0.10_0_1_76.state","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Wohnzimmer Licht":{"switch":[{"id":"hue.0.Wohnzimmer.on","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Wintergarten Licht":{"switch":[{"id":"hue.0.Wintergarten.on","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"3D Drucker":{"switch":[{"id":"alias.0.EG.Strom.3D-Drucker","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Aussentemperatur":{"getData":[{"id":"0_userdata.0.Wetterstation.Aussentemperatur","text":"Aussentemperatur && °C","newline":"true"}]},"Windstärke":{"getData":[{"id":"0_userdata.0.Wetterstation.Wind","text":"Windstärke && km/h","newline":"true"}]},"Regen":{"getData":[{"id":"0_userdata.0.Wetterstation.Regen_Tag","text":"Regen heute && mm","newline":"true"}]}},"Christian":{"Startseite":{"nav":[["Licht"," Steckdose "],[" Iobroker"," Heizung"]],"text":"Wähle eine Aktion"}}}
        telegram-menu.0
        2023-07-26 23:33:27.216	debug	Nav {"Home":{"nav":[["Licht "],[" Strom "],[" Wetter"]],"text":"Wählen Sie eine Aktion"},"Licht":{"nav":[["Home "],[" Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip"]],"text":"Wähle eine Aktion"},"Strom":{"nav":[["Home "],[" Pelletsofen"," 3D Drucker"]],"text":"Wähle eine Aktion"},"Wetter":{"nav":[["Home "],[" Aussentemperatur"," Windstärke"," Regen"]],"text":"Wähle eine Aktion"},"Wintergarten Strip":{"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"-","toggle":true,"confirm":"true","returnText":"Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"Pelletsofen":{"switch":[{"id":"hs100.0.10_0_1_76.state","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Wohnzimmer Licht":{"switch":[{"id":"hue.0.Wohnzimmer.on","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Wintergarten Licht":{"switch":[{"id":"hue.0.Wintergarten.on","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"3D Drucker":{"switch":[{"id":"alias.0.EG.Strom.3D-Drucker","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Aussentemperatur":{"getData":[{"id":"0_userdata.0.Wetterstation.Aussentemperatur","text":"Aussentemperatur && °C","newline":"true"}]},"Windstärke":{"getData":[{"id":"0_userdata.0.Wetterstation.Wind","text":"Windstärke && km/h","newline":"true"}]},"Regen":{"getData":[{"id":"0_userdata.0.Wetterstation.Regen_Tag","text":"Regen heute && mm","newline":"true"}]}}
        telegram-menu.0
        2023-07-26 23:33:27.216	debug	Group with User "Global"
        telegram-menu.0
        2023-07-26 23:33:27.216	debug	user in group{"Global":["Christian"],"Christian":[""]}
        telegram-menu.0
        2023-07-26 23:33:27.216	debug	Todo: "Wohnzimmer Licht"
        telegram-menu.0
        2023-07-26 23:33:27.216	debug	User: "Christian"
        telegram-menu.0
        2023-07-26 23:33:27.215	debug	Value: "[Christian]Wohnzimmer Licht"
        telegram-menu.0
        2023-07-26 23:33:26.698	debug	Send Value {"id":"hue.0.Wintergarten.on","confirm":"false","returnText":"-","userToSend":"Christian"}
        telegram-menu.0
        2023-07-26 23:33:26.698	debug	State, which is listen to was changed "hue.0.Wintergarten.on"
        telegram-menu.0
        2023-07-26 23:33:25.479	debug	Send Value {"id":"hue.0.Wintergarten.on","confirm":"false","returnText":"-","userToSend":"Christian"}
        telegram-menu.0
        2023-07-26 23:33:25.478	debug	State, which is listen to was changed "hue.0.Wintergarten.on"
        telegram-menu.0
        2023-07-26 23:33:25.472	debug	Value {"val":false,"ack":true,"ts":1689881960456,"q":0,"from":"system.adapter.hue.0","user":"system.user.admin","lc":1689881960134}
        telegram-menu.0
        2023-07-26 23:33:25.469	debug	Toggle
        telegram-menu.0
        2023-07-26 23:33:25.469	debug	Element to set {"id":"hue.0.Wintergarten.on","value":"-","toggle":true,"confirm":"false","returnText":"-"}
        telegram-menu.0
        2023-07-26 23:33:25.469	debug	Part {"switch":[{"id":"hue.0.Wintergarten.on","value":"-","toggle":true,"confirm":"false","returnText":"-"}]}
        telegram-menu.0
        2023-07-26 23:33:25.469	debug	Menu {"Global":{"Home":{"nav":[["Licht "],[" Strom "],[" Wetter"]],"text":"Wählen Sie eine Aktion"},"Licht":{"nav":[["Home "],[" Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip"]],"text":"Wähle eine Aktion"},"Strom":{"nav":[["Home "],[" Pelletsofen"," 3D Drucker"]],"text":"Wähle eine Aktion"},"Wetter":{"nav":[["Home "],[" Aussentemperatur"," Windstärke"," Regen"]],"text":"Wähle eine Aktion"},"Wintergarten Strip":{"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"-","toggle":true,"confirm":"true","returnText":"Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"Pelletsofen":{"switch":[{"id":"hs100.0.10_0_1_76.state","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Wohnzimmer Licht":{"switch":[{"id":"hue.0.Wohnzimmer.on","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Wintergarten Licht":{"switch":[{"id":"hue.0.Wintergarten.on","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"3D Drucker":{"switch":[{"id":"alias.0.EG.Strom.3D-Drucker","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Aussentemperatur":{"getData":[{"id":"0_userdata.0.Wetterstation.Aussentemperatur","text":"Aussentemperatur && °C","newline":"true"}]},"Windstärke":{"getData":[{"id":"0_userdata.0.Wetterstation.Wind","text":"Windstärke && km/h","newline":"true"}]},"Regen":{"getData":[{"id":"0_userdata.0.Wetterstation.Regen_Tag","text":"Regen heute && mm","newline":"true"}]}},"Christian":{"Startseite":{"nav":[["Licht"," Steckdose "],[" Iobroker"," Heizung"]],"text":"Wähle eine Aktion"}}}
        telegram-menu.0
        2023-07-26 23:33:25.469	debug	Nav {"Home":{"nav":[["Licht "],[" Strom "],[" Wetter"]],"text":"Wählen Sie eine Aktion"},"Licht":{"nav":[["Home "],[" Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip"]],"text":"Wähle eine Aktion"},"Strom":{"nav":[["Home "],[" Pelletsofen"," 3D Drucker"]],"text":"Wähle eine Aktion"},"Wetter":{"nav":[["Home "],[" Aussentemperatur"," Windstärke"," Regen"]],"text":"Wähle eine Aktion"},"Wintergarten Strip":{"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"-","toggle":true,"confirm":"true","returnText":"Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"Pelletsofen":{"switch":[{"id":"hs100.0.10_0_1_76.state","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Wohnzimmer Licht":{"switch":[{"id":"hue.0.Wohnzimmer.on","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Wintergarten Licht":{"switch":[{"id":"hue.0.Wintergarten.on","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"3D Drucker":{"switch":[{"id":"alias.0.EG.Strom.3D-Drucker","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Aussentemperatur":{"getData":[{"id":"0_userdata.0.Wetterstation.Aussentemperatur","text":"Aussentemperatur && °C","newline":"true"}]},"Windstärke":{"getData":[{"id":"0_userdata.0.Wetterstation.Wind","text":"Windstärke && km/h","newline":"true"}]},"Regen":{"getData":[{"id":"0_userdata.0.Wetterstation.Regen_Tag","text":"Regen heute && mm","newline":"true"}]}}
        telegram-menu.0
        2023-07-26 23:33:25.469	debug	Group with User "Global"
        telegram-menu.0
        2023-07-26 23:33:25.469	debug	user in group{"Global":["Christian"],"Christian":[""]}
        telegram-menu.0
        2023-07-26 23:33:25.469	debug	Todo: "Wintergarten Licht"
        telegram-menu.0
        2023-07-26 23:33:25.469	debug	User: "Christian"
        telegram-menu.0
        2023-07-26 23:33:25.468	debug	Value: "[Christian]Wintergarten Licht"
        telegram-menu.0
        2023-07-26 23:33:23.133	debug	Send this to : "Christian"
        telegram-menu.0
        2023-07-26 23:33:23.133	debug	Send this Value : "Wintergarten Light Strip ist ein "
        telegram-menu.0
        2023-07-26 23:33:23.133	debug	User "Christian"
        telegram-menu.0
        2023-07-26 23:33:23.133	debug	Send Value {"id":"hue.0.Wintergarten_Strip.on","confirm":"true","returnText":"Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}","userToSend":"Christian"}
        telegram-menu.0
        2023-07-26 23:33:23.133	debug	State, which is listen to was changed "hue.0.Wintergarten_Strip.on"
        telegram-menu.0
        2023-07-26 23:33:23.126	debug	Value {"val":false,"ack":true,"ts":1690407201878,"q":0,"from":"system.adapter.hue.0","user":"system.user.admin","lc":1690407201878}
        telegram-menu.0
        2023-07-26 23:33:23.124	debug	Toggle
        telegram-menu.0
        2023-07-26 23:33:23.124	debug	Element to set {"id":"hue.0.Wintergarten_Strip.on","value":"-","toggle":true,"confirm":"true","returnText":"Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}
        telegram-menu.0
        2023-07-26 23:33:23.124	debug	Part {"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"-","toggle":true,"confirm":"true","returnText":"Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]}
        telegram-menu.0
        2023-07-26 23:33:23.124	debug	Menu {"Global":{"Home":{"nav":[["Licht "],[" Strom "],[" Wetter"]],"text":"Wählen Sie eine Aktion"},"Licht":{"nav":[["Home "],[" Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip"]],"text":"Wähle eine Aktion"},"Strom":{"nav":[["Home "],[" Pelletsofen"," 3D Drucker"]],"text":"Wähle eine Aktion"},"Wetter":{"nav":[["Home "],[" Aussentemperatur"," Windstärke"," Regen"]],"text":"Wähle eine Aktion"},"Wintergarten Strip":{"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"-","toggle":true,"confirm":"true","returnText":"Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"Pelletsofen":{"switch":[{"id":"hs100.0.10_0_1_76.state","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Wohnzimmer Licht":{"switch":[{"id":"hue.0.Wohnzimmer.on","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Wintergarten Licht":{"switch":[{"id":"hue.0.Wintergarten.on","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"3D Drucker":{"switch":[{"id":"alias.0.EG.Strom.3D-Drucker","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Aussentemperatur":{"getData":[{"id":"0_userdata.0.Wetterstation.Aussentemperatur","text":"Aussentemperatur && °C","newline":"true"}]},"Windstärke":{"getData":[{"id":"0_userdata.0.Wetterstation.Wind","text":"Windstärke && km/h","newline":"true"}]},"Regen":{"getData":[{"id":"0_userdata.0.Wetterstation.Regen_Tag","text":"Regen heute && mm","newline":"true"}]}},"Christian":{"Startseite":{"nav":[["Licht"," Steckdose "],[" Iobroker"," Heizung"]],"text":"Wähle eine Aktion"}}}
        telegram-menu.0
        2023-07-26 23:33:23.124	debug	Nav {"Home":{"nav":[["Licht "],[" Strom "],[" Wetter"]],"text":"Wählen Sie eine Aktion"},"Licht":{"nav":[["Home "],[" Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip"]],"text":"Wähle eine Aktion"},"Strom":{"nav":[["Home "],[" Pelletsofen"," 3D Drucker"]],"text":"Wähle eine Aktion"},"Wetter":{"nav":[["Home "],[" Aussentemperatur"," Windstärke"," Regen"]],"text":"Wähle eine Aktion"},"Wintergarten Strip":{"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"-","toggle":true,"confirm":"true","returnText":"Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"Pelletsofen":{"switch":[{"id":"hs100.0.10_0_1_76.state","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Wohnzimmer Licht":{"switch":[{"id":"hue.0.Wohnzimmer.on","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Wintergarten Licht":{"switch":[{"id":"hue.0.Wintergarten.on","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"3D Drucker":{"switch":[{"id":"alias.0.EG.Strom.3D-Drucker","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Aussentemperatur":{"getData":[{"id":"0_userdata.0.Wetterstation.Aussentemperatur","text":"Aussentemperatur && °C","newline":"true"}]},"Windstärke":{"getData":[{"id":"0_userdata.0.Wetterstation.Wind","text":"Windstärke && km/h","newline":"true"}]},"Regen":{"getData":[{"id":"0_userdata.0.Wetterstation.Regen_Tag","text":"Regen heute && mm","newline":"true"}]}}
        telegram-menu.0
        2023-07-26 23:33:23.124	debug	Group with User "Global"
        telegram-menu.0
        2023-07-26 23:33:23.124	debug	user in group{"Global":["Christian"],"Christian":[""]}
        telegram-menu.0
        2023-07-26 23:33:23.124	debug	Todo: "Wintergarten Strip"
        telegram-menu.0
        2023-07-26 23:33:23.124	debug	User: "Christian"
        telegram-menu.0
        2023-07-26 23:33:23.123	debug	Value: "[Christian]Wintergarten Strip"
        telegram-menu.0
        2023-07-26 23:33:21.139	debug	Send this to : "Christian"
        telegram-menu.0
        2023-07-26 23:33:21.139	debug	Send this Value : "Wintergarten Light Strip ist ein "
        telegram-menu.0
        2023-07-26 23:33:21.139	debug	User "Christian"
        telegram-menu.0
        2023-07-26 23:33:21.139	debug	Send Value {"id":"hue.0.Wintergarten_Strip.on","confirm":"true","returnText":"Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}","userToSend":"Christian"}
        telegram-menu.0
        2023-07-26 23:33:21.139	debug	State, which is listen to was changed "hue.0.Wintergarten_Strip.on"
        telegram-menu.0
        2023-07-26 23:33:21.113	debug	Value {"val":false,"ack":true,"ts":1690407112858,"q":0,"from":"system.adapter.hue.0","user":"system.user.admin","lc":1690407112858}
        telegram-menu.0
        2023-07-26 23:33:21.111	debug	Toggle
        telegram-menu.0
        2023-07-26 23:33:21.111	debug	Element to set {"id":"hue.0.Wintergarten_Strip.on","value":"-","toggle":true,"confirm":"true","returnText":"Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}
        telegram-menu.0
        2023-07-26 23:33:21.110	debug	Part {"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"-","toggle":true,"confirm":"true","returnText":"Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]}
        telegram-menu.0
        2023-07-26 23:33:21.110	debug	Menu {"Global":{"Home":{"nav":[["Licht "],[" Strom "],[" Wetter"]],"text":"Wählen Sie eine Aktion"},"Licht":{"nav":[["Home "],[" Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip"]],"text":"Wähle eine Aktion"},"Strom":{"nav":[["Home "],[" Pelletsofen"," 3D Drucker"]],"text":"Wähle eine Aktion"},"Wetter":{"nav":[["Home "],[" Aussentemperatur"," Windstärke"," Regen"]],"text":"Wähle eine Aktion"},"Wintergarten Strip":{"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"-","toggle":true,"confirm":"true","returnText":"Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"Pelletsofen":{"switch":[{"id":"hs100.0.10_0_1_76.state","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Wohnzimmer Licht":{"switch":[{"id":"hue.0.Wohnzimmer.on","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Wintergarten Licht":{"switch":[{"id":"hue.0.Wintergarten.on","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"3D Drucker":{"switch":[{"id":"alias.0.EG.Strom.3D-Drucker","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Aussentemperatur":{"getData":[{"id":"0_userdata.0.Wetterstation.Aussentemperatur","text":"Aussentemperatur && °C","newline":"true"}]},"Windstärke":{"getData":[{"id":"0_userdata.0.Wetterstation.Wind","text":"Windstärke && km/h","newline":"true"}]},"Regen":{"getData":[{"id":"0_userdata.0.Wetterstation.Regen_Tag","text":"Regen heute && mm","newline":"true"}]}},"Christian":{"Startseite":{"nav":[["Licht"," Steckdose "],[" Iobroker"," Heizung"]],"text":"Wähle eine Aktion"}}}
        telegram-menu.0
        2023-07-26 23:33:21.110	debug	Nav {"Home":{"nav":[["Licht "],[" Strom "],[" Wetter"]],"text":"Wählen Sie eine Aktion"},"Licht":{"nav":[["Home "],[" Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip"]],"text":"Wähle eine Aktion"},"Strom":{"nav":[["Home "],[" Pelletsofen"," 3D Drucker"]],"text":"Wähle eine Aktion"},"Wetter":{"nav":[["Home "],[" Aussentemperatur"," Windstärke"," Regen"]],"text":"Wähle eine Aktion"},"Wintergarten Strip":{"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"-","toggle":true,"confirm":"true","returnText":"Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"Pelletsofen":{"switch":[{"id":"hs100.0.10_0_1_76.state","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Wohnzimmer Licht":{"switch":[{"id":"hue.0.Wohnzimmer.on","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Wintergarten Licht":{"switch":[{"id":"hue.0.Wintergarten.on","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"3D Drucker":{"switch":[{"id":"alias.0.EG.Strom.3D-Drucker","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Aussentemperatur":{"getData":[{"id":"0_userdata.0.Wetterstation.Aussentemperatur","text":"Aussentemperatur && °C","newline":"true"}]},"Windstärke":{"getData":[{"id":"0_userdata.0.Wetterstation.Wind","text":"Windstärke && km/h","newline":"true"}]},"Regen":{"getData":[{"id":"0_userdata.0.Wetterstation.Regen_Tag","text":"Regen heute && mm","newline":"true"}]}}
        telegram-menu.0
        2023-07-26 23:33:21.109	debug	Group with User "Global"
        telegram-menu.0
        2023-07-26 23:33:21.109	debug	user in group{"Global":["Christian"],"Christian":[""]}
        telegram-menu.0
        2023-07-26 23:33:21.109	debug	Todo: "Wintergarten Strip"
        telegram-menu.0
        2023-07-26 23:33:21.109	debug	User: "Christian"
        telegram-menu.0
        2023-07-26 23:33:21.109	debug	Value: "[Christian]Wintergarten Strip"
        telegram-menu.0
        2023-07-26 23:33:19.547	debug	Send Value {"id":"hue.0.Wohnzimmer.on","confirm":"false","returnText":"-","userToSend":"Christian"}
        telegram-menu.0
        2023-07-26 23:33:19.546	debug	State, which is listen to was changed "hue.0.Wohnzimmer.on"
        telegram-menu.0
        2023-07-26 23:33:18.824	debug	Send Value {"id":"hue.0.Wohnzimmer.on","confirm":"false","returnText":"-","userToSend":"Christian"}
        telegram-menu.0
        2023-07-26 23:33:18.823	debug	State, which is listen to was changed "hue.0.Wohnzimmer.on"
        telegram-menu.0
        2023-07-26 23:33:18.807	debug	Value {"val":true,"ack":true,"ts":1690407119722,"q":0,"from":"system.adapter.hue.0","user":"system.user.admin","lc":1690407119722}
        telegram-menu.0
        2023-07-26 23:33:18.783	debug	Toggle
        telegram-menu.0
        2023-07-26 23:33:18.783	debug	Element to set {"id":"hue.0.Wohnzimmer.on","value":"-","toggle":true,"confirm":"false","returnText":"-"}
        telegram-menu.0
        2023-07-26 23:33:18.783	debug	Part {"switch":[{"id":"hue.0.Wohnzimmer.on","value":"-","toggle":true,"confirm":"false","returnText":"-"}]}
        telegram-menu.0
        2023-07-26 23:33:18.780	debug	Menu {"Global":{"Home":{"nav":[["Licht "],[" Strom "],[" Wetter"]],"text":"Wählen Sie eine Aktion"},"Licht":{"nav":[["Home "],[" Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip"]],"text":"Wähle eine Aktion"},"Strom":{"nav":[["Home "],[" Pelletsofen"," 3D Drucker"]],"text":"Wähle eine Aktion"},"Wetter":{"nav":[["Home "],[" Aussentemperatur"," Windstärke"," Regen"]],"text":"Wähle eine Aktion"},"Wintergarten Strip":{"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"-","toggle":true,"confirm":"true","returnText":"Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"Pelletsofen":{"switch":[{"id":"hs100.0.10_0_1_76.state","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Wohnzimmer Licht":{"switch":[{"id":"hue.0.Wohnzimmer.on","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Wintergarten Licht":{"switch":[{"id":"hue.0.Wintergarten.on","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"3D Drucker":{"switch":[{"id":"alias.0.EG.Strom.3D-Drucker","value":"-","toggle":true,"confirm":"false","returnText":"-"}]},"Aussentemperatur":{"getData":[{"id":"0_userdata.0.Wetterstation.Aussentemperatur","text":"Aussentemperatur && °C","newline":"true"}]},"Windstärke":{"getData":[{"id":"0_userdata.0.Wetterstation.Wind","text":"Windstärke && km/h","newline":"true"}]},"Regen":{"getData":[{"id":"0_userdata.0.Wetterstation.Regen_Tag","text":"Regen heute && mm","newline":"true"}]}},"Christian":{"Startseite":{"nav":[["Licht"," Steckdose "],[" Iobroker"," Heizung"]],"text":"Wähle eine Aktion"}}}
        • Michael Roling
          Michael Roling Developer @Negalein last edited by
          @negalein
          Lade noch mal von Github. Wahrscheinlich hast du das neuste noch nicht dabei.
          Ich denke das bei dir die Werte gesetzt werden, aber mit Ack:true.
          Habe ich gestern geändert so das die standardmäßig mit ack:false gesetzt werden.
          • Michael Roling
            Michael Roling Developer @todde last edited by
            @todde
            Ja sicherlich
            • Michael Roling
              Michael Roling Developer @Markus Frankl last edited by
              @markus-frankl ich denke diese Woche. Der Adapter ist seit gestern auch im latest repository.
              • Negalein
                @michael-roling sagte in Test Adapter telegram-menu v.0.3.x:
                Danke, das wars. 🙂
                • Michael Roling
                  Der Adapter ist jetzt im latest mit Version 0.3.0 und 0.4.0.
                  In Version 0.4.0 sind die submenues enthalten.
                  Ich habe dazu die Doku aber noch nicht komplett fertig.
                  M 1 Reply Last reply Reply Quote 2
                    Markus Frankl @Michael Roling last edited by
                    @michael-roling
                    Hi erstmal cooles update.
                    Der Menü Text kommt in das Feld des Rückgabetextes bei Aktion oder? Wenn ich jetzt sagen wir mal Eine Lampe nehme und ich möchte 1x nur an aus und 1x mit Menü zum Dimmen, muss man da zwei Einträge erstellen?
                    Und was meinst du in der Doku mit einzigartiger Name? Sorry aber da steig ich noch nicht ganz durch. Der Rest funktioniert wunderbar.
                    • Michael Roling
                      @markus-frankl
                      ich habe die Doku angepasst, ich hoffe es ist verständlich so, habe auch ein paar Bilder dazu eingefügt.
                        liv-in-sky @Michael Roling last edited by liv-in-sky
                        @michael-roling
                        danke erstmal für deinen adapter
                        • könnte man die % eingabe auch auch so definieren, das es von z.b. 0 - 6 geht in einer schritten - ich versuche einen zahlenwert zu setzen - der kann nur zwischen 0 und 6 sein ?
                        • ich bekomme keine rückgabe werte - was kann das sein ?
                        • Michael Roling
                          Michael Roling Developer @liv-in-sky last edited by
                          @liv-in-sky nimm menu:number0-6-1-%:aussen:
                          liv-in-sky 2 Replies Last reply Reply Quote 1
                            danke - das funktioniert 🙂
                            Michael Roling 1 Reply Last reply Reply Quote 1
                            • Michael Roling
                              @liv-in-sky den rückgabewert bekommst du wahrscheinlich nicht weil ack:false gesetzt wird , d.h. im rückgabetext ack:true setzen. Sinn dahinter ist, das wenn man einen Wert an einen Adapter schickt, der Rückgabetext erst kommt wenn der Adapter den Wert bestätigt hat.
                                @michael-roling wegen des rückgabewertes bei setstate - muss ich da einen getstate definieren - eigentlich doch nicht
                                habe das jetzt so eingestellt - kommt auch kein rückgabe wert
                                • Michael Roling
                                  Michael Roling Developer @liv-in-sky last edited by Michael Roling
                                  @liv-in-sky da fehlt das ack:true, schau dir mal meinen post vorher an.
                                  schreibe: wert ist jetzt && ack:true
                                  liv-in-sky 3 Replies Last reply Reply Quote 1
                                    ack:true
                                    aahh - jetzt ist gut
                                      @michael-roling
                                      funktioniert aber nicht bei dem wert mit den zahlen 😞
                                        @michael-roling
                                        wegen den zahlen nochmal: da kommt ein undefined - find ich nicht so wichtig im moment - wollte es aber mal mitteilen
                                        gesetzt wird die zahl richtig!
                                        • Michael Roling
                                          @liv-in-sky
                                          welche Version hast du installiert? Du solltest von Github mal neu installieren
                                          • Michael Roling
                                            @liv-in-sky zeigt mal das menu wie du das geschrieben hast
                                            1795
                                            786128
