    4. [gelöst]Problemsuche error node-gyp ble adapter
    • coyote
      coyote Most Active @Thomas Braun last edited by
      @thomas-braun sagte in Problemsuche error node-gyp ble adapter:
      iob rebuild iobroker.ble
      hat nichts gebracht.
      Adapter komplett neu installiert -> läuft 👍
      Danke für die Hilfe.
      • coyote
        @thomas-braun kann ich noch was machen, wegen dem Fehler vom LG TV Adapter?
          Thomas Braun Most Active @coyote last edited by
          @coyote sagte in Problemsuche error node-gyp ble adapter:
          Keine Ahnung. Hab den noch nie gesehen.
          • coyote
            Das hier meinte ich:
            Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/../node_modules/iobroker.lgtv/io-package.json: /opt/iobroker/node_modules/iobroker.lgtv/io-package.json: Unexpected token } in JSON at position 10582
            Wie gesagt, der ist gar nicht mehr installiert
              Ich würde die
              vermutlich löschen.
                crunchip Forum Testing Most Active @Thomas Braun last edited by
                @thomas-braun hab ich umbenannt und danach ble versucht
                Would you like to upgrade ble from @0.13.3 to @0.13.4 now? [(y)es, (n)o]: y
                Update ble from @0.13.3 to @0.13.4
                NPM version: 9.6.7
                Installing iobroker.ble@0.13.4... (System call)
                npm ERR! code 1
                npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
                npm ERR! command failed
                npm ERR! command sh -c node-gyp-build
                npm ERR! gyp info it worked if it ends with ok
                npm ERR! gyp info using node-gyp@7.1.2
                npm ERR! gyp info using node@18.17.0 | linux | x64
                npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
                npm ERR! (node:352773) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
                npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)
                npm ERR! gyp info spawn /usr/bin/python3
                npm ERR! gyp info spawn args [
                npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
                npm ERR! gyp info spawn args   'binding.gyp',
                npm ERR! gyp info spawn args   '-f',
                npm ERR! gyp info spawn args   'make',
                npm ERR! gyp info spawn args   '-I',
                npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build/config.gypi',
                npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
                npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.17.0/include/node/common.gypi',
                npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
                npm ERR! gyp info spawn args   '-Dvisibility=default',
                npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.17.0',
                npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
                npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.17.0/<(target_arch)/node.lib',
                npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble',
                npm ERR! gyp info spawn args   '-Dnode_engine=v8',
                npm ERR! gyp info spawn args   '--depth=.',
                npm ERR! gyp info spawn args   '--no-parallel',
                npm ERR! gyp info spawn args   '--generator-output',
                npm ERR! gyp info spawn args   'build',
                npm ERR! gyp info spawn args   '-Goutput_dir=.'
                npm ERR! gyp info spawn args ]
                npm ERR! Traceback (most recent call last):
                npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>
                npm ERR!     sys.exit(gyp.script_main())
                npm ERR!              ^^^^^^^^^^^^^^^^^
                npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main
                npm ERR!     return main(sys.argv[1:])
                npm ERR!            ^^^^^^^^^^^^^^^^^^
                npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main
                npm ERR!     return gyp_main(args)
                npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main
                npm ERR!     [generator, flat_list, targets, data] = Load(
                npm ERR!                                             ^^^^^
                npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load
                npm ERR!     result = gyp.input.Load(
                npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load
                npm ERR!     LoadTargetBuildFile(
                npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile
                npm ERR!     build_file_data = LoadOneBuildFile(
                npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile
                npm ERR!     build_file_contents = open(build_file_path, "rU").read()
                npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^
                npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp
                npm ERR! gyp ERR! configure error
                npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1
                npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)
                npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)
                npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)
                npm ERR! gyp ERR! System Linux 6.1.0-10-amd64
                npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
                npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
                npm ERR! gyp ERR! node -v v18.17.0
                npm ERR! gyp ERR! node-gyp -v v7.1.2
                npm ERR! gyp ERR! not ok
                npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-07-28T22_04_18_690Z-debug-0.log
                upload [5] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/.eslintrc.js .eslintrc.js application/javascript
                upload [4] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/ble.png ble.png image/png
                upload [3] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js build/index.js application/javascript
                upload [2] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js.map build/index.js.map application/json
                upload [1] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/index_m.html index_m.html text/html
                upload [0] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/style.css style.css text/css
                Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                  Thomas Braun Most Active @crunchip last edited by Thomas Braun
                  @crunchip
                  Dann schau in das genannte Log rein.
                  Hier schaut's auch nach einem Ansatz 'dirty workaround' aus:
                  https://stackoverflow.com/questions/74715990/node-gyp-err-invalid-mode-ru-while-trying-to-load-binding-gyp
                    0 verbose cli /usr/bin/node /usr/bin/npm
                    1 info using npm@9.6.7
                    2 info using node@v18.17.0
                    3 timing npm:load:whichnode Completed in 3ms
                    4 timing config:load:defaults Completed in 4ms
                    5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 1ms
                    6 timing config:load:builtin Completed in 1ms
                    7 timing config:load:cli Completed in 5ms
                    8 timing config:load:env Completed in 0ms
                    9 timing config:load:file:/opt/iobroker/.npmrc Completed in 4ms
                    10 timing config:load:project Completed in 6ms
                    11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
                    12 timing config:load:user Completed in 1ms
                    13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
                    14 timing config:load:global Completed in 1ms
                    15 timing config:load:setEnvs Completed in 2ms
                    16 timing config:load Completed in 23ms
                    17 timing npm:load:configload Completed in 23ms
                    18 timing npm:load:mkdirpcache Completed in 0ms
                    19 timing npm:load:mkdirplogs Completed in 0ms
                    20 verbose title npm install iobroker.admin@6.6.4
                    21 verbose argv "install" "--save-exact" "iobroker.admin@6.6.4"
                    22 timing npm:load:setTitle Completed in 3ms
                    23 timing config:load:flatten Completed in 10ms
                    24 timing npm:load:display Completed in 12ms
                    25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2023-07-28T22_14_54_602Z-
                    26 verbose logfile /home/iobroker/.npm/_logs/2023-07-28T22_14_54_602Z-debug-0.log
                    27 timing npm:load:logFile Completed in 22ms
                    28 timing npm:load:timers Completed in 0ms
                    29 timing npm:load:configScope Completed in 0ms
                    30 timing npm:load Completed in 68ms
                    31 timing arborist:ctor Completed in 1ms
                    32 silly logfile start cleaning logs, removing 2 files
                    33 silly logfile done cleaning log files
                    34 timing idealTree:init Completed in 5625ms
                    35 timing idealTree:userRequests Completed in 6ms
                    36 silly idealTree buildDeps
                    37 silly fetch manifest iobroker.admin@6.6.4
                    38 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.vis-2-widgets-energy
                    39 http fetch GET 200 https://registry.npmjs.org/iobroker.admin 5916ms (cache updated)
                    40 silly placeDep ROOT iobroker.admin@6.6.4 REPLACE for: iobroker.inst@3.0.0 want: 6.6.4
                    41 timing idealTree:#root Completed in 6017ms
                    42 timing idealTree:node_modules/iobroker.admin Completed in 0ms
                    43 timing idealTree:buildDeps Completed in 6020ms
                    44 timing idealTree:fixDepFlags Completed in 65ms
                    45 timing idealTree Completed in 11794ms
                    46 timing reify:loadTrees Completed in 11795ms
                    47 timing reify:diffTrees Completed in 115ms
                    48 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.admin' ]
                    49 silly reify moves {
                    49 silly reify   '/opt/iobroker/node_modules/iobroker.admin': '/opt/iobroker/node_modules/.iobroker.admin-TtUA2igk'
                    49 silly reify }
                    50 timing reify:retireShallow Completed in 6ms
                    51 timing reify:createSparse Completed in 4ms
                    52 timing reify:loadBundles Completed in 0ms
                    53 verbose reify failed optional dependency /opt/iobroker/node_modules/osx-temperature-sensor
                    54 silly reify mark deleted [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
                    55 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
                    56 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
                    57 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffprobe-installer/win32-x64
                    58 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffprobe-installer/win32-x64' ]
                    59 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffprobe-installer/win32-ia32
                    60 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffprobe-installer/win32-ia32' ]
                    61 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffprobe-installer/linux-ia32
                    62 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffprobe-installer/linux-ia32' ]
                    63 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffprobe-installer/linux-arm64
                    64 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffprobe-installer/linux-arm64' ]
                    65 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffprobe-installer/linux-arm
                    66 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffprobe-installer/linux-arm' ]
                    67 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffprobe-installer/darwin-x64
                    68 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffprobe-installer/darwin-x64' ]
                    69 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffprobe-installer/darwin-arm64
                    70 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffprobe-installer/darwin-arm64' ]
                    71 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffmpeg-installer/win32-x64
                    72 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffmpeg-installer/win32-x64' ]
                    73 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffmpeg-installer/win32-ia32
                    74 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffmpeg-installer/win32-ia32' ]
                    75 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffmpeg-installer/linux-ia32
                    76 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffmpeg-installer/linux-ia32' ]
                    77 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffmpeg-installer/linux-arm64
                    78 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffmpeg-installer/linux-arm64' ]
                    79 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffmpeg-installer/linux-arm
                    80 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffmpeg-installer/linux-arm' ]
                    81 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffmpeg-installer/darwin-x64
                    82 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffmpeg-installer/darwin-x64' ]
                    83 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffmpeg-installer/darwin-arm64
                    84 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffmpeg-installer/darwin-arm64' ]
                    85 timing reifyNode:node_modules/osx-temperature-sensor Completed in 17ms
                    86 timing reifyNode:node_modules/fsevents Completed in 16ms
                    87 timing reifyNode:node_modules/@ffprobe-installer/win32-x64 Completed in 16ms
                    88 timing reifyNode:node_modules/@ffprobe-installer/win32-ia32 Completed in 15ms
                    89 timing reifyNode:node_modules/@ffprobe-installer/linux-ia32 Completed in 15ms
                    90 timing reifyNode:node_modules/@ffprobe-installer/linux-arm64 Completed in 16ms
                    91 timing reifyNode:node_modules/@ffprobe-installer/linux-arm Completed in 16ms
                    92 timing reifyNode:node_modules/@ffprobe-installer/darwin-x64 Completed in 16ms
                    93 timing reifyNode:node_modules/@ffprobe-installer/darwin-arm64 Completed in 16ms
                    94 timing reifyNode:node_modules/@ffmpeg-installer/win32-x64 Completed in 15ms
                    95 timing reifyNode:node_modules/@ffmpeg-installer/win32-ia32 Completed in 15ms
                    96 timing reifyNode:node_modules/@ffmpeg-installer/linux-ia32 Completed in 15ms
                    97 timing reifyNode:node_modules/@ffmpeg-installer/linux-arm64 Completed in 16ms
                    98 timing reifyNode:node_modules/@ffmpeg-installer/linux-arm Completed in 16ms
                    99 timing reifyNode:node_modules/@ffmpeg-installer/darwin-x64 Completed in 16ms
                    100 timing reifyNode:node_modules/@ffmpeg-installer/darwin-arm64 Completed in 16ms
                    101 silly tarball no local data for iobroker.admin@https://registry.npmjs.org/iobroker.admin/-/iobroker.admin-6.6.4.tgz. Extracting by manifest.
                    102 timing reifyNode:node_modules/buildcheck Completed in 109ms
                    103 timing reifyNode:node_modules/cpu-features Completed in 612ms
                    104 http fetch GET 200 https://registry.npmjs.org/iobroker.admin/-/iobroker.admin-6.6.4.tgz 4871ms (cache miss)
                    105 timing reifyNode:node_modules/iobroker.admin Completed in 4897ms
                    106 timing reify:unpack Completed in 4900ms
                    107 timing reify:unretire Completed in 19ms
                    108 timing build:queue Completed in 4ms
                    109 info run cpu-features@0.0.8 install node_modules/cpu-features node buildcheck.js > buildcheck.gypi && node-gyp rebuild
                    110 info run cpu-features@0.0.8 install { code: 1, signal: null }
                    111 verbose reify failed optional dependency /opt/iobroker/node_modules/cpu-features
                    112 silly reify mark deleted [ '/opt/iobroker/node_modules/cpu-features' ]
                    113 verbose reify failed optional dependency /opt/iobroker/node_modules/buildcheck
                    114 silly reify mark deleted [ '/opt/iobroker/node_modules/buildcheck' ]
                    115 timing build:run:install:node_modules/cpu-features Completed in 1175ms
                    116 timing build:run:install Completed in 1177ms
                    117 timing build:deps Completed in 1181ms
                    118 timing build Completed in 1182ms
                    119 timing reify:build Completed in 1184ms
                    120 timing reify:trash Completed in 132ms
                    121 timing reify:save Completed in 2140ms
                    122 timing reify Completed in 21181ms
                    123 silly ADD
                    124 silly ADD
                    125 silly ADD
                    126 silly ADD
                    127 silly ADD
                    128 silly ADD
                    129 silly ADD
                    130 silly ADD
                    131 silly ADD
                    132 silly ADD
                    133 silly ADD
                    134 silly ADD
                    135 silly ADD
                    136 silly ADD
                    137 silly ADD
                    138 silly ADD
                    139 silly ADD
                    140 silly ADD
                    141 silly CHANGE node_modules/iobroker.admin
                    142 timing command:install Completed in 21211ms
                    143 verbose exit 0
                    144 timing npm Completed in 21766ms
                    145 info ok
                      crunchip Forum Testing Most Active @Thomas Braun last edited by crunchip
                      'dirty workaround'
                      morgen in aller frische, bevor ich heut noch etwas kaputt mach
                      nach einem Ansatz
                      https://github.com/nodejs/node-gyp/issues/2219
                      BriceKrispies created this issue in nodejs/node-gyp
                      closed ValueError: invalid mode: 'rU' while trying to load binding.gyp (Python 3.9 compatibility issue) #2219
                        crunchip Forum Testing Most Active @crunchip last edited by
                        @crunchip sagte in Problemsuche error node-gyp ble adapter:
                        hab ich angepasst, von
                        else:
                        auf
                        else:
                                    build_file_contents = open(build_file_path, "r").read()
                        update lief jetzt durch
                        ble adapter gyp error node error python
                        3712
