    4. Steckdose mit 2 Datenpunkten für on off
      A Former User @DJMarc75 last edited by
      @djmarc75
      Keine Veränderung
      • DJMarc75
        DJMarc75 @Guest last edited by
        @vazi dann zeig mal die jeweiligen Objektdaten (Bleistift rechts anklicken) und poste die hier in Codetags
          A Former User @DJMarc75 last edited by A Former User
          @djmarc75 ```
            "type": "state",
            "common": {
              "name": "",
              "type": "boolean",
              "role": "boolean",
              "write": true,
              "read": true
            "native": {},
            "from": "system.adapter.smartthings.0",
            "user": "system.user.admin",
            "ts": 1690450416943,
            "_id": "smartthings.0.cbf9a2be-420b-4f59-80f6-d47727cd9727.capabilities.switch-off",
            "acl": {
              "object": 1636,
              "state": 1636,
              "owner": "system.user.admin",
            "type": "state",
            "common": {
              "name": "",
              "type": "boolean",
              "role": "boolean",
              "write": true,
              "read": true
            "native": {},
            "_id": "smartthings.0.cbf9a2be-420b-4f59-80f6-d47727cd9727.capabilities.switch-on",
            "acl": {
              "object": 1636,
              "state": 1636,
            "type": "state",
            "common": {
              "name": "value",
              "role": "text",
              "type": "string",
              "write": false,
              "read": true,
              "custom": {
                "iqontrol.0": {
                  "0": "",
                  "1": "",
                  "2": "",
                  "enabled": true,
                  "invert": false,
                  "confirm": false,
                  "pincode": "",
                  "roundDigits": 2,
                  "timeFormat": "x",
                  "timeDisplayFormat": "dddd, DD.MM.YYYY HH:mm:ss",
                  "timeDisplayDontShowDistance": false,
                  "targetValueId": "",
                  "statesAddInput": false,
                  "statesAddInputCaption": "Enter other value...",
                  "showOnlyTargetValues": false,
                  "readonly": true,
                  "unit": "",
                  "unit_zero": "",
                  "unit_one": "",
                  "min": "",
                  "max": "",
                  "step": "",
                  "type": "string",
                  "role": "text",
                  "states": {
                    "on": "Ein",
                    "off": "Aus"
            "native": {},
            "_id": "smartthings.0.cbf9a2be-420b-4f59-80f6-d47727cd9727.status.switch.switch.value",
            "acl": {
              "object": 1636,
              "state": 1636,
            "ts": 1690488136289
          • DJMarc75
            @vazi Jetzt versuchen wir mal einen Schuh daraus zu machen bitte:
            Du nutzt welchen Adapter? Diesen Smarthings ??
            Kann denn dieses Ledvance auch Zigbee?
            Falls ja, dann nutze den dementsprechenden Adapter (falls Du einen Zigbee-Koordinator hast)
            Der Smarthings Adapter ist ja eigentlich für SamsungDevices, wenn ich das aus der Doku richtig lese....
            Wie kommt man dann auf die Idee eine Ledvance per SamsungAdapter zu steuern ??
              @djmarc75 sagte in Steckdose mit 2 Datenpunkten für on off:
              Du nutzt welchen Adapter? Diesen Smarthings ?? JA
              Kann denn dieses Ledvance auch Zigbee? NEIN
              Über diesen Forumsbeitrag
              DJMarc75 2 Replies Last reply Reply Quote 0
              • DJMarc75
                @vazi na dann bin ich da raus und Du solltest in Deinem verlinkten Beitrag mal nachfragen 😉
                Alternativ wäre auch die Suchfunktion (oben rechts - die Lupe)
                https://forum.iobroker.net/search?term=Ledvance&in=titlesposts
                  @djmarc75 Danke Dir für all Deine Bemühungen und Ratschläge.
                  • DJMarc75
                    @vazi sagte in Steckdose mit 2 Datenpunkten für on off:
                    Noch mal zur Sicherheit nachgefragt: Die genau Bezeichnung von dem Leuchtmittel ist ??
                      • MartinP
                        MartinP @PeterL 0 last edited by MartinP
                        @peterl-0 Vielleicht ist das eine Pulsschaltung.
                        Ein True für 500 ms auf On schaltet ein, ein True für 500 ms auf Off schaltet aus.
                        Normalerweise sind beide False...
                        Wenn man keine explizite Rückmeldung über den aktuellen Zustand hat, muss man den auch noch selbst generieren...
                          A Former User @MartinP last edited by
                          @martinp Vielen Dank für Dein Tipp.... und wie realisiere ich dies nun genau? Sorry... stehe etwas auf der Leitung vor lauter Denken... 🤕
                            A Former User last edited by
                            @martinp
                            Dies wird vermutlich über ein Blockly realisiert?
                            Könntest Du mir helfen, wie ich diesen auf Grund meiner obigen Angaben zusammensetzen muss?
                            • MartinP
                              MartinP @Guest last edited by
                              @vazi Ich bin selber blockly rookie, sorry - bevor ich Dir etwas falsches Mitgebe
                              Man muss sehen, ob man den Zustand, den die Steckdose hat irgendwo braucht. Wenn das nicht nötig ist, dann kann man ja auch einfach die AN bzw AUS Pulse auch einfach so auslösen
                              Hier habe ich einen Puls ausgelöst ( 35 Sekunden Tauch-Pumpe im Regenfass an, um die Tomaten zu wässern)
                              Hängt aber an einem Zeitplan.
                              Man könnte da vielleich einen Datenpunkt in Userdata anlegen, den man setzen und löschen kann.
                              Der könnte dann statt des Zeitplans Auslöser der beiden Aktionen die der Zeitplan klammert sein..
                              Man braucht natürlich einen Puls zum Setzen und einen Puls zum Löschen ...
                              1693
