    4. Huawei Sun2000 & ioBroker via JS script funktioniert
      rainereglinsky last edited by
      Danke für das neue Script. Habe es eingebaut, bekomme aber massive Fehlermeldungen.
      2023-07-29 13:28:44.166 - info: admin.0 (3692) ==> Connected system.user.admin from ::1
      2023-07-29 13:28:46.771 - info: admin.0 (3692) <== Disconnect system.user.admin from ::1 javascript
      2023-07-29 13:29:00.017 - warn: javascript.0 (7268) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
      2023-07-29 13:29:15.203 - error: javascript.0 (7268) script.js.Huawei: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
      2023-07-29 13:29:15.204 - error: javascript.0 (7268) script.js.Huawei: Please disable that setting or use "getState" with a callback, e.g.: getState("javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.Battery1.BatterySOC", (err, state) => { ... });
      2023-07-29 13:29:15.204 - error: javascript.0 (7268) Error in callback: TypeError: Cannot read properties of undefined (reading 'val')
      2023-07-29 13:29:15.204 - error: javascript.0 (7268) at ProcessData (script.js.Huawei:425:120)
      2023-07-29 13:29:15.204 - error: javascript.0 (7268) at Object. (script.js.Huawei:503:13)
      2023-07-29 13:29:15.204 - error: javascript.0 (7268) at Timeout._onTimeout (C:\ioBroker\node_modules\iobroker.javascript\lib\sandbox.js:2723:34)
      2023-07-29 13:29:15.204 - error: javascript.0 (7268) at listOnTimeout (node:internal/timers:569:17)
      2023-07-29 13:29:15.204 - error: javascript.0 (7268) at processTimers (node:internal/timers:512:7)
      2023-07-29 13:29:44.291 - info: admin.0 (3692) <== Disconnect system.user.admin from ::1 admin
      2023-07-29 13:29:44.296 - info: admin.0 (3692) <== Disconnect system.user.admin from ::1 admin
      2023-07-29 13:29:53.494 - info: admin.0 (3692) ==> Connected system.user.admin from ::1
      2023-07-29 13:29:59.655 - info: admin.0 (3692) ==> Connected system.user.admin from ::1
      2023-07-29 13:30:00.020 - warn: javascript.0 (7268) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
      2023-07-29 13:30:02.417 - info: admin.0 (3692) <== Disconnect system.user.admin from ::1 javascript
      2023-07-29 13:30:05.292 - error: javascript.0 (7268) script.js.Huawei: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
      2023-07-29 13:30:05.292 - error: javascript.0 (7268) script.js.Huawei: Please disable that setting or use "getState" with a callback, e.g.: getState("javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.Battery1.BatterySOC", (err, state) => { ... });
      2023-07-29 13:30:05.293 - error: javascript.0 (7268) Error in callback: TypeError: Cannot read properties of undefined (reading 'val')
      2023-07-29 13:30:05.293 - error: javascript.0 (7268) at ProcessData (script.js.Huawei:425:120)
      2023-07-29 13:30:05.293 - error: javascript.0 (7268) at Object. (script.js.Huawei:503:13)
      2023-07-29 13:30:05.293 - error: javascript.0 (7268) at Timeout._onTimeout (C:\ioBroker\node_modules\iobroker.javascript\lib\sandbox.js:2723:34)
      2023-07-29 13:30:05.293 - error: javascript.0 (7268) at listOnTimeout (node:internal/timers:569:17)
      2023-07-29 13:30:05.293 - error: javascript.0 (7268) at processTimers (node:internal/timers:512:7)
      Muss die PowerMeterID in eckigen Klammern stehen (wie ModbusID) oder ohne Klammern wie im Script? Ist die ID "0" richtig?
      Habe mit PowerMeterID =0 oder [0] die gleichen Ergebnisse in den Objekten
      Alles "NULL" (erst grün, dann rot.
      Danke vorab für die Hilfe
        Chris_B @rainereglinsky last edited by
        @rainereglinsky
        1. Bei PowerMeterID: Keine eckigen Klammern. Das ist kein Array, nur eine Zahl.
        2. Ich denke irgend etwas in Deinen Javascript Settings auf iobroker ist nicht in Ordnung; Du hast ganz komische Fehlermeldungen. Versuch einmal folgendes: Unter den Einstellungen des Javascript Adapters "Nicht alle Zustände beim Start abonnieren" NICHT auswählen (d.h. nicht selektiert).
          Gruss
          juggi1962 @Chris_B last edited by
          @juggi1962 Ich habe die reconnect Funkion für Dich nun eingebaut. Ist im Code aber 'auskommentiert'. Um ihn zu aktivieren in den Zeilen 392 bis 395 jeweils das // ganz vorne löschen. Dann wird ein reconnect über den Aufruf von ConnectModbus() durchgeführt
          Hallo Christian vielen Dank, werde ich heute noch testen.
          Gruß Jürgen
            rainereglinsky @Chris_B last edited by
            @chris_b
            Danke für die Info, habe ich gemacht, - Fehler sind weg, dafür hunderte Warnungen. hier nur ein Teil....
            2023-07-30 17:41:28.939 - warn: javascript.1 (10152) getState "javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.Battery1.BatterySOC" not found (3) states[id]=null
            2023-07-30 17:41:28.940 - warn: javascript.1 (10152) at ProcessData (script.js.Huawei:425:24)
            2023-07-30 17:41:28.940 - warn: javascript.1 (10152) at Object. (script.js.Huawei:503:13)
            2023-07-30 17:41:28.940 - warn: javascript.1 (10152) at Timeout._onTimeout (C:\ioBroker\node_modules\iobroker.javascript\lib\sandbox.js:2723:34)
            2023-07-30 17:41:28.940 - warn: javascript.1 (10152) at listOnTimeout (node:internal/timers:569:17)
            2023-07-30 17:41:28.940 - warn: javascript.1 (10152) at processTimers (node:internal/timers:512:7)
            2023-07-30 17:41:28.940 - info: javascript.1 (10152) script.js.Huawei: setForeignState(id=javascript.0.Solarpower.Derived.BatteryOverview, state={"val":"null%","ack":false,"ts":1690731688940,"q":0,"from":"system.adapter.javascript.1","lc":1690731688940,"c":"script.js.Huawei"})
            2023-07-30 17:41:28.940 - warn: javascript.1 (10152) script.js.Huawei: setForeignState(id=javascript.0.Solarpower.Derived.BatteryOverview, state={"val":"null%","ack":false,"ts":1690731688940,"q":0,"from":"system.adapter.javascript.1","lc":1690731688940,"c":"script.js.Huawei"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
            2023-07-30 17:41:28.940 - info: javascript.1 (10152) script.js.Huawei: getState(id=javascript.0.Solarpower.Huawei.Inverter.1.InputPower, timerId=undefined) => not found
            2023-07-30 17:41:28.940 - warn: javascript.1 (10152) getState "javascript.0.Solarpower.Huawei.Inverter.1.InputPower" not found (3) states[id]=null
            2023-07-30 17:41:28.940 - warn: javascript.1 (10152) at ProcessData (script.js.Huawei:430:22)
            2023-07-30 17:41:28.940 - info: javascript.1 (10152) script.js.Huawei: getState(id=javascript.0.Solarpower.Derived.PeakPanelPower, timerId=undefined) => {"val":null,"ack":true}
            2023-07-30 17:41:28.940 - info: javascript.1 (10152) script.js.Huawei: getState(id=javascript.0.Solarpower.Huawei.Inverter.1.ActivePower, timerId=undefined) => not found
            2023-07-30 17:41:28.940 - warn: javascript.1 (10152) getState "javascript.0.Solarpower.Huawei.Inverter.1.ActivePower" not found (3) states[id]=null
            2023-07-30 17:41:28.941 - warn: javascript.1 (10152) at ProcessData (script.js.Huawei:435:66)
            2023-07-30 17:41:28.941 - warn: javascript.1 (10152) at Object. (script.js.Huawei:503:13)
            2023-07-30 17:41:28.941 - warn: javascript.1 (10152) at Timeout._onTimeout (C:\ioBroker\node_modules\iobroker.javascript\lib\sandbox.js:2723:34)
            2023-07-30 17:41:28.941 - warn: javascript.1 (10152) at listOnTimeout (node:internal/timers:569:17)
            2023-07-30 17:41:28.941 - warn: javascript.1 (10152) at processTimers (node:internal/timers:512:7)
            2023-07-30 17:41:28.941 - info: javascript.1 (10152) script.js.Huawei: getState(id=javascript.0.Solarpower.Huawei.Meter.ActivePower, timerId=undefined) => not found
            2023-07-30 17:41:28.941 - warn: javascript.1 (10152) getState "javascript.0.Solarpower.Huawei.Meter.ActivePower" not found (3) states[id]=null
            2023-07-30 17:41:28.941 - warn: javascript.1 (10152) at ProcessData (script.js.Huawei:436:9)
            2023-07-30 17:41:28.941 - info: javascript.1 (10152) script.js.Huawei: setForeignState(id=javascript.0.Solarpower.Derived.HouseConsumption, state={"val":0,"ack":false,"ts":1690731688941,"q":0,"from":"system.adapter.javascript.1","lc":1690731688941,"c":"script.js.Huawei"})
            2023-07-30 17:41:28.941 - warn: javascript.1 (10152) script.js.Huawei: setForeignState(id=javascript.0.Solarpower.Derived.HouseConsumption, state={"val":0,"ack":false,"ts":1690731688941,"q":0,"from":"system.adapter.javascript.1","lc":1690731688941,"c":"script.js.Huawei"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
            2023-07-30 17:41:28.941 - info: javascript.1 (10152) script.js.Huawei: getState(id=javascript.0.Solarpower.Huawei.Inverter.1.DailyEnergyYield, timerId=undefined) => not found
            2023-07-30 17:41:28.941 - warn: javascript.1 (10152) getState "javascript.0.Solarpower.Huawei.Inverter.1.DailyEnergyYield" not found (3) states[id]=null
            2023-07-30 17:41:28.942 - warn: javascript.1 (10152) at ProcessData (script.js.Huawei:439:60)
            2023-07-30 17:41:28.942 - warn: javascript.1 (10152) at Object. (script.js.Huawei:503:13)
            2023-07-30 17:41:28.942 - warn: javascript.1 (10152) at Timeout._onTimeout (C:\ioBroker\node_modules\iobroker.javascript\lib\sandbox.js:2723:34)
            2023-07-30 17:41:28.942 - warn: javascript.1 (10152) at listOnTimeout (node:internal/timers:569:17)
            2023-07-30 17:41:28.942 - warn: javascript.1 (10152) at processTimers (node:internal/timers:512:7)
            2023-07-30 17:41:28.942 - info: javascript.1 (10152) script.js.Huawei: getState(id=javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.CurrentDayChargeCapacity, timerId=undefined) => not found
            2023-07-30 17:41:28.942 - warn: javascript.1 (10152) getState "javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.CurrentDayChargeCapacity" not found (3) states[id]=null
            2023-07-30 17:41:28.942 - warn: javascript.1 (10152) at ProcessData (script.js.Huawei:440:9)
            2023-07-30 17:41:28.943 - warn: javascript.1 (10152) at Object. (script.js.Huawei:503:13)
            2023-07-30 17:41:28.943 - warn: javascript.1 (10152) at Timeout._onTimeout (C:\ioBroker\node_modules\iobroker.javascript\lib\sandbox.js:2723:34)
            2023-07-30 17:41:28.943 - warn: javascript.1 (10152) at listOnTimeout (node:internal/timers:569:17)
            2023-07-30 17:41:28.943 - warn: javascript.1 (10152) at processTimers (node:internal/timers:512:7)
            2023-07-30 17:41:28.943 - info: javascript.1 (10152) script.js.Huawei: getState(id=javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.CurrentDayDischargeCapacity, timerId=undefined) => not found
            2023-07-30 17:41:28.943 - warn: javascript.1 (10152) getState "javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.CurrentDayDischargeCapacity" not found (3) states[id]=null
            2023-07-30 17:41:28.944 - warn: javascript.1 (10152) at ProcessData (script.js.Huawei:441:9)
            2023-07-30 17:41:28.944 - warn: javascript.1 (10152) at Object. (script.js.Huawei:503:13)
            2023-07-30 17:41:28.944 - warn: javascript.1 (10152) at Timeout._onTimeout (C:\ioBroker\node_modules\iobroker.javascript\lib\sandbox.js:2723:34)
            2023-07-30 17:41:28.944 - warn: javascript.1 (10152) at listOnTimeout (node:internal/timers:569:17)
            2023-07-30 17:41:28.944 - warn: javascript.1 (10152) at processTimers (node:internal/timers:512:7)
            Scheinbar werden die Variablen nicht gefunden. Nochmal zur PowerMeterID. Ist die immer "0" oder wo finde ich den wert in der Anlage?
            Danke vorab.
            Rainer
              Verbesserungen in dieser Version des Skripts:
              1. Array-Struktur optimiert (Faktor 3 kleiner).
              2. Es werden neu auch die "Battery Charging / Discharging Cutoff Capacities" gelesen (danke für den Tip @R4 ).
              3. Funktionsumbenennungen zur Verbesserung der Lesbarkeit (zumindest für mich).
              4. Reconnect Modbus Funktion 'auskommentiert' vorhanden, kann individuell aktiviert werden.
              Gruss, Christian
              Hallo Christian.
              Wollte dir nur mitteilen, dass dein Skript mit aktiviertem Reconnect Modbus seit gestern Abend ohne Probleme läuft.
              Hatte auch nur 2-3 Trying to reconnect Warnungen.
              Was mir aber bei meinem alten Skript mit reconnect ohne Batterie Abfrage aufgefallen ist,
              dass wenn dauernd Warnungen von Trying to reconnect kommen, hat ein neustart des JS Adapters geholfen.
              Vielleicht hilft das bei dir auch, da du ja geschrieben hast, dass du andauernd Fehlermeldungen bekommst,
              wenn reconnect an ist.
              Danke noch mal für deine super Arbeit und Hilfe.
              Gruß aus Tirol Jürgen.
                Chris_B @juggi1962 last edited by
                @juggi1962 Danke, für das positive Feedback. Ich werde das evtl. auch nochmals versuchen.
                Gruss aus Zürich, Christian
                  @rainereglinsky Hallo Rainer - hier ist die Antwort vermutlich relativ einfach:
                  Bei Dir scheint alles auf der Instanz javascript.1 zu laufen. Das ist (glaube ich zumindest) nicht sehr üblich. Normalerweise läuft das in der Instanz javascript.0.
                  Das Skript passt sich da nicht automatisch an.
                  Zwei Möglichkeiten: Entweder änderst Du das auf die javascript.0 Instanz; oder Du änderst im Skript alle momentan 57 Orte auf javascript.1 ab. Bevorzugen würde ich Ersteres.
                  Gruss, Christian
                  M R 2 Replies Last reply Reply Quote 0
                    meloneA @Chris_B last edited by
                    @chris_b ev solltest du dafür eine Zeile in der Scriptbeschreibung einfügen. Dieses Szenario kommt ggf noch öfters, z.B. wenn man über eine weitere iObroker Instanz auf einem Raspberry und sich direkt mit dem Wlan des Wechselrichters verbindet. In dem Fall muss man bei halbwegs aktueller Firmware auch den Port auf 6607 ändern. Diese Variante ist deutlich stabiler als der Dongle, insbesondere wenn man häufiger die Daten abfragt.
                    Vielleicht würde sich auch anbieten das Script und eine Doku auf Github zu stellen. Ich kann ggf gerne ein paar Zeilen für die Dokumentation beitragen.
                    C 1 Reply Last reply Reply Quote 1
                      Chris_B @meloneA last edited by
                      @melonea @melonea Guter Punkt. Dazu folgendes:
                      1. Ich denke, ich erweitere das Skript so, dass nur an einem Ort die javascript Instanz gesetzt wird, das macht Änderungen einfacher.
                      2. Weisst Du, wie ich im Skript die Javascript-Instanz-Nummer abfragen kann? Dann würde ich das ins Skript einbauen. Dann wäre das Problem komplett gelöst.
                      3. Das mit Github ist eine gute Idee. Arbeitest Du via VSCode zur Entwicklung von Code? Ich habe das einmal installiert und hatte dann ziemliche Probleme. Geht das bei Dir gut? Ich würde das gerne in Sachen Code-Versionierung tun, damit ist es dann auch schnell auf Github.
                        Gruss, Christian
                        @chris_b
                        Danke für den Tipp - hab ich geändert. Ich bekomme nun die Warnungen, dass der Debug-Modus aktiv ist. Habe ich aber bewusst nicht ausgeführt.
                        Werte sind natürlich alle "NULL"
                        Rainer
                        javascript.0
                        2023-07-31 11:38:25.544 warn script.js.Huawei: setForeignState(id=javascript.0.Solarpower.Derived.WorkingMode, state={"val":"undefined","ack":false,"ts":1690796305544,"q":0,"from":"system.adapter.javascript.0","lc":1690796305544,"c":"script.js.Huawei"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                        javascript.0
                        2023-07-31 11:38:25.543 warn script.js.Huawei: setForeignState(id=javascript.0.Solarpower.Derived.ConsumptionToday, state={"val":0,"ack":false,"ts":1690796305543,"q":0,"from":"system.adapter.javascript.0","lc":1690796305543,"c":"script.js.Huawei"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                        javascript.0
                        2023-07-31 11:38:25.543 warn script.js.Huawei: setForeignState(id=javascript.0.Solarpower.Derived.ConsumptionSum, state={"val":0,"ack":false,"ts":1690796305543,"q":0,"from":"system.adapter.javascript.0","lc":1690796305543,"c":"script.js.Huawei"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                        javascript.0
                        2023-07-31 11:38:25.543 warn script.js.Huawei: setForeignState(id=javascript.0.Solarpower.Derived.GridImportToday, state={"val":0,"ack":false,"ts":1690796305543,"q":0,"from":"system.adapter.javascript.0","lc":1690796305543,"c":"script.js.Huawei"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                        javascript.0
                        2023-07-31 11:38:25.543 warn script.js.Huawei: setForeignState(id=javascript.0.Solarpower.Derived.GridExportToday, state={"val":0,"ack":false,"ts":1690796305543,"q":0,"from":"system.adapter.javascript.0","lc":1690796305543,"c":"script.js.Huawei"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                        javascript.0
                        2023-07-31 11:38:25.543 warn script.js.Huawei: setForeignState(id=javascript.0.Solarpower.Derived.IsGridExporting, state={"val":0,"ack":false,"ts":1690796305543,"q":0,"from":"system.adapter.javascript.0","lc":1690796305543,"c":"script.js.Huawei"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                        javascript.0
                        2023-07-31 11:38:25.543 warn script.js.Huawei: setForeignState(id=javascript.0.Solarpower.Derived.IsBatteryLoading, state={"val":1,"ack":false,"ts":1690796305543,"q":0,"from":"system.adapter.javascript.0","lc":1690796305543,"c":"script.js.Huawei"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                        javascript.0
                        2023-07-31 11:38:25.543 warn script.js.Huawei: setForeignState(id=javascript.0.Solarpower.Derived.YieldToday, state={"val":0,"ack":false,"ts":1690796305543,"q":0,"from":"system.adapter.javascript.0","lc":1690796305543,"c":"script.js.Huawei"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                        javascript.0
                        2023-07-31 11:38:25.543 warn script.js.Huawei: setForeignState(id=javascript.0.Solarpower.Derived.HouseConsumption, state={"val":0,"ack":false,"ts":1690796305543,"q":0,"from":"system.adapter.javascript.0","lc":1690796305543,"c":"script.js.Huawei"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                        javascript.0
                        2023-07-31 11:38:25.543 warn script.js.Huawei: setForeignState(id=javascript.0.Solarpower.Derived.BatteryOverview, state={"val":"null%","ack":false,"ts":1690796305543,"q":0,"from":"system.adapter.javascript.0","lc":1690796305543,"c":"script.js.Huawei"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                        javascript.0
                        2023-07-31 11:38:25.543 warn script.js.Huawei: setForeignState(id=javascript.0.Solarpower.Huawei.Meter.ActivePowerL3, state={"val":94,"ack":false,"ts":1690796305543,"q":0,"from":"system.adapter.javascript.0","lc":1690796305543,"c":"script.js.Huawei"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                        javascript.0
                        2023-07-31 11:38:25.543 warn script.js.Huawei: setForeignState(id=javascript.0.Solarpower.Huawei.Meter.ActivePowerL2, state={"val":128,"ack":false,"ts":1690796305543,"q":0,"from":"system.adapter.javascript.0","lc":1690796305543,"c":"script.js.Huawei"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                        javascript.0
                        2023-07-31 11:38:25.543 warn script.js.Huawei: setForeignState(id=javascript.0.Solarpower.Huawei.Meter.ActivePowerL1, state={"val":-225,"ack":false,"ts":1690796305543,"q":0,"from":"system.adapter.javascript.0","lc":1690796305543,"c":"script.js.Huawei"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                        javascript.0
                        2023-07-31 11:38:25.543 warn script.js.Huawei: setForeignState(id=javascript.0.Solarpower.Huawei.Meter.VoltageL3-L1, state={"val":404.3,"ack":false,"ts":1690796305543,"q":0,"from":"system.adapter.javascript.0","lc":1690796305543,"c":"script.js.Huawei"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                        javascript.0
                        2023-07-31 11:38:25.543 warn script.js.Huawei: setForeignState(id=javascript.0.Solarpower.Huawei.Meter.VoltageL2-L3, state={"val":404,"ack":false,"ts":1690796305543,"q":0,"from":"system.adapter.javascript.0","lc":1690796305543,"c":"script.js.Huawei"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                          @rainereglinsky im Script Editor hast du rechts-oben einen "Schraubenschlüssel". Dort kannst du den Debug de/aktivieren.
                            rainereglinsky @meloneA last edited by
                            @melonea
                            Ja, dort ist aber nichts eingestellt, was den Debug Modus auslösen sollte:
                              leonundjulie @Chris_B last edited by leonundjulie
                              @chris_b hallo. Ich docketed schon eine ganze Weile an der Idee, vom HUAWEi SUN 2000 die Werte auszulesen, respektive in meinen IOBroker einzulesen. Habe bis dato auf der Basis NODE RED gearbeitet. Leider bekomme ich dort nur einen Zyklus eingelesen.
                              Und gestern habe ich diesen Thread gefunden, und den Versuch via JS gestartet. Ich habe also die Erweiterung „Serial MODBUS“ im JS-Adapter eingefügt und im Script die IP des WR eingetragen (Batterie auf (0,0) gesetzt, weil ich keine habe.
                              Das Ergebnis: ganz viele Fehlermeldungen
                              2023-07-30 22:51:36.120 - info: admin.0 (5213) ==> Connected system.user.admin from ::ffff:192.168.178.87
                              2023-07-30 22:51:38.897 - info: javascript.0 (326144) Start javascript script.js.HUAWEI
                              2023-07-30 22:51:38.955 - info: javascript.0 (326144) script.js.HUAWEI: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                              2023-07-30 22:52:08.933 - warn: javascript.0 (326144) script.js.HUAWEI: Error received reading address 37700 from id: 1 with error: undefined
                              2023-07-30 22:52:13.931 - warn: javascript.0 (326144) script.js.HUAWEI: Error received reading address 38200 from id: 1 with error: undefined
                              2023-07-30 22:52:18.932 - warn: javascript.0 (326144) script.js.HUAWEI: Error received reading address 30000 from id: 1 with error: undefined
                              2023-07-30 22:52:23.947 - warn: javascript.0 (326144) getState "javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.CurrentDayChargeCapacity" not found (3)
                              2023-07-30 22:52:23.952 - warn: javascript.0 (326144) at ProcessData (script.js.HUAWEI:408:9)
                              2023-07-30 22:52:23.953 - warn: javascript.0 (326144) at Object. (script.js.HUAWEI:456:13)
                              2023-07-30 22:52:23.953 - warn: javascript.0 (326144) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2723:34)
                              2023-07-30 22:52:23.953 - warn: javascript.0 (326144) at listOnTimeout (node:internal/timers:569:17)
                              2023-07-30 22:52:23.953 - warn: javascript.0 (326144) at processTimers (node:internal/timers:512:7)
                              2023-07-30 22:52:23.953 - warn: javascript.0 (326144) getState "javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.CurrentDayDischargeCapacity" not found (3)
                              2023-07-30 22:52:23.954 - warn: javascript.0 (326144) at ProcessData (script.js.HUAWEI:409:9)
                              2023-07-30 22:52:23.954 - warn: javascript.0 (326144) at Object. (script.js.HUAWEI:456:13)
                              2023-07-30 22:52:23.954 - warn: javascript.0 (326144) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2723:34)
                              2023-07-30 22:52:23.954 - warn: javascript.0 (326144) at listOnTimeout (node:internal/timers:569:17)
                              2023-07-30 22:52:23.954 - warn: javascript.0 (326144) at processTimers (node:internal/timers:512:7)
                              2023-07-30 22:52:23.955 - warn: javascript.0 (326144) getState "javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.ChargeAndDischargePower" not found (3)
                              2023-07-30 22:52:23.955 - warn: javascript.0 (326144) at ProcessData (script.js.HUAWEI:412:66)
                              2023-07-30 22:52:23.955 - warn: javascript.0 (326144) at Object. (script.js.HUAWEI:456:13)
                              2023-07-30 22:52:23.956 - warn: javascript.0 (326144) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2723:34)
                              2023-07-30 22:52:23.956 - warn: javascript.0 (326144) at listOnTimeout (node:internal/timers:569:17)
                              2023-07-30 22:52:23.956 - warn: javascript.0 (326144) at processTimers (node:internal/timers:512:7)
                              2023-07-30 22:52:23.959 - warn: javascript.0 (326144) script.js.HUAWEI: Error received reading address 37800 from id: 1 with error: undefined
                              2023-07-30 22:52:28.932 - warn: javascript.0 (326144) script.js.HUAWEI: Error received reading address 38300 from id: 1 with error: undefined
                              2023-07-30 22:52:33.933 - warn: javascript.0 (326144) script.js.HUAWEI: Error received reading address 38400 from id: 1 with error: undefined
                              2023-07-30 22:52:38.933 - warn: javascript.0 (326144) script.js.HUAWEI: Error received reading address 32000 from id: 1 with error: undefined
                              2023-07-30 22:52:43.479 - info: javascript.0 (326144) Stop script script.js.HUAWEI
                              2023-07-30 22:52:43.932 - warn: javascript.0 (326144) script.js.HUAWEI: Error received reading address 37000 from id: 1 with error: undefined
                              2023-07-30 22:52:47.099 - info: admin.0 (5213) <== Disconnect system.user.admin from ::ffff:192.168.178.87 javascript
                              2023-07-30 22:52:48.933 - warn: javascript.0 (326144) script.js.HUAWEI: Error received reading address 37100 from id: 1 with error: undefined
                              Anfügen muss ich vielleicht noch, dass der MOD-Bus im WR voll zugänglich ist, die ID auf 1 eingestellt ist.
                              Hast Du eine Idee?
                                rainereglinsky @rainereglinsky last edited by
                                @rainereglinsky
                                Gelöst!
                                habe IOBroker deinstalliert und neu aufgesetzt. Funktioniert nun! Danke nochmals für eure Geduld mit einem Neuling.
                                  leonundjulie @leonundjulie last edited by
                                  @leonundjulie .... ich antworte mir mal selber 😊
                                  Ich habe das Skript nochmals gestartet, nachdem ich nochmals alle Werte geprüft habe. Und siehe da, ich bekomme nicht nur Fehler, sondern Werte 😳 . Also funktioniert das Skript - riesen Freude.👏 👏
                                  Die Fehler deuten meiner Meinung darauf hin, dass Register abgefragt werden, die es in meinem System nicht gibt ... das zu prüfen, steht für heute Abend auf dem Plan.
                                  Hier nochmals ein etwas längeres Protokoll:
                                    Chris_B @leonundjulie last edited by
                                    @leonundjulie Super, freut mich.
                                    Wenn Du mein neustes Skript genommen hast: bei 'const RegToRead' einfach diejenigen rausnehmen, die Du nicht brauchst. Achtung: RegFast auch entsprechend anpassen. Es werden eben viele Batterie Infos ausgelesen. Gruss
                                      @rainereglinsky
                                      kleines Problem noch: Ich bekomme in der Ausgabe nur einen PV String angezeigt, habe aber zwei Strings. Muss das im Script noch irgendwo eingetragen werden?
                                        meloneA @rainereglinsky last edited by
                                        @rainereglinsky
                                        der String2 ist auskommentiert, entferne einfach die // bei den 2 Zeilen
                                          @chris_b said in Huawei Sun2000 & ioBroker via JS script funktioniert:
                                          const RegToRead
                                          Danke für das schnelle Feedback. Wenn ich also keine Batterie habe, dann lösche ich die GELB markierten? Bzw kommentiere sie durch // raus, wie Du es in der blauen Zeile gemacht hast?
                                          Abschließend ändere ich entsprechend der beiden Sprechblasen?
                                          Nachbrenner (habe mir jetzt ein paar Minuten Dein Skript genauer angesehen - soweit ein Newby das überblickt: eigentlich müsste ich Dein Skript um ALLE Inhalte zu den Batterien rauswerfen, also nicht nur die von Dir aufgezeigten 'const RegToRead' .... dann wäre es schlank und würde zu meiner Konfiguration passen. Was hätst Du von Dem Ansatz, dass Du eine Globale BATTERY_ PRESENT definierst, die man als Nutzer mit 0 oder 1 füttert (so wie man auch sein IP eingeben muss) unddie Batterie rlevanten ANteile würde nur bearbeitet werden, wenn die Globale auf 1 sitzt. Das würde es sicherlich für viele einfacher machen und es gäbe weiterhin nur ein Source ... was hältst Du von dem Vorschlag?
                                              Gruss, Christian
                                            Ich denke es reicht schon aus wenn du wie für die IP, Port,.. auch eine Variable für die Instanz einbaust. Immerhin muss man auch im Scripting Adapter die entsprechende Instanz für den Slave eintragen. Von daher auch der Hinweis das es ggf schön wäre wenn wir das ganze z.B. auf Github dokumentieren.
                                            VScode bin ich eher Laie, aber kleine Commits und Doku´s bearbeiten funktioniert mit der GIT integration soweit eigenltich einwandfrei.
                                            477
                                            90786
